[U-Boot] [PATCH] ARM: rmobile: Drop PRR syscon driver
The PRR syscon driver is available too late for Multi DTB build of U-Boot. Replace it with simple check whether a platform is Gen3 or not and produce an address of the PRR.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com --- arch/arm/mach-rmobile/cpu_info-rcar.c | 61 ++++----------------------- 1 file changed, 8 insertions(+), 53 deletions(-)
diff --git a/arch/arm/mach-rmobile/cpu_info-rcar.c b/arch/arm/mach-rmobile/cpu_info-rcar.c index ccb7a32ac4..ce9312f9d8 100644 --- a/arch/arm/mach-rmobile/cpu_info-rcar.c +++ b/arch/arm/mach-rmobile/cpu_info-rcar.c @@ -11,7 +11,14 @@ #define R8A7796_REV_1_0 0x5200 #define R8A7796_REV_1_1 0x5210
-static u32 rmobile_get_prr(void); +static u32 rmobile_get_prr(void) +{ +#ifdef CONFIG_RCAR_GEN3 + return readl(0xFFF00044); +#else + return readl(0xFF000044); +#endif +}
u32 rmobile_get_cpu_type(void) { @@ -37,55 +44,3 @@ u32 rmobile_get_cpu_rev_fraction(void) else return prr & 0x0000000F; } - -#if !CONFIG_IS_ENABLED(DM) || !CONFIG_IS_ENABLED(SYSCON) -static u32 rmobile_get_prr(void) -{ - /* - * On RCar/RMobile Gen2 and older systems, the PRR is always - * located at the address below. On newer systems, the PRR - * may be located at different address, but that information - * is obtained from DT. This code will be removed when all - * of the older systems get converted to DM and OF control. - */ - return readl(0xFF000044); -} -#else - -#include <dm.h> -#include <syscon.h> -#include <regmap.h> - -struct renesas_prr_priv { - fdt_addr_t regs; -}; - -enum { - PRR_RCAR, -}; - -static u32 rmobile_get_prr(void) -{ - struct regmap *map; - - map = syscon_get_regmap_by_driver_data(PRR_RCAR); - if (!map) { - printf("PRR regmap failed!\n"); - hang(); - } - - return readl(map->ranges[0].start); -} - -static const struct udevice_id renesas_prr_ids[] = { - { .compatible = "renesas,prr", .data = PRR_RCAR }, - { } -}; - -U_BOOT_DRIVER(renesas_prr) = { - .name = "renesas_prr", - .id = UCLASS_SYSCON, - .of_match = renesas_prr_ids, - .flags = DM_FLAG_PRE_RELOC, -}; -#endif
