[U-Boot] [PATCH v4] arm : Atmel : add at91sam9x5ek board support
Add at91sam9x5ek board support, this board support the following SoCs AT91SAM9G15, AT91SAM9G25, AT91SAM9G35, AT91SAM9X25, AT91SAM9X35
Using at91sam9x5ek_nandflash to configure for the board Now only supports NAND with software ECC boot up
Signed-off-by: Bo Shen voice.shen@atmel.com --- This patch is based on git://git.denx.de/u-boot-atmel.git
Changed since v3 Remove CONFIG_NET_MULTI which was globally removed Remove CONFIG_RESET_PHY_R related part which is empty unused function
Changed since v1 and v2 Modify the code according to Andreas's suggestion --- MAINTAINERS | 3 + arch/arm/cpu/arm926ejs/at91/Makefile | 1 + arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c | 232 ++++++++++++++++ arch/arm/cpu/arm926ejs/at91/clock.c | 12 +- arch/arm/include/asm/arch-at91/at91sam9_matrix.h | 2 + arch/arm/include/asm/arch-at91/at91sam9x5.h | 170 ++++++++++++ arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h | 91 ++++++ arch/arm/include/asm/arch-at91/hardware.h | 2 + board/atmel/at91sam9x5ek/Makefile | 52 ++++ board/atmel/at91sam9x5ek/at91sam9x5ek.c | 293 ++++++++++++++++++++ board/atmel/at91sam9x5ek/config.mk | 1 + boards.cfg | 1 + drivers/net/macb.c | 4 +- include/configs/at91sam9x5ek.h | 183 ++++++++++++ 14 files changed, 1043 insertions(+), 4 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c create mode 100644 arch/arm/include/asm/arch-at91/at91sam9x5.h create mode 100644 arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h create mode 100644 board/atmel/at91sam9x5ek/Makefile create mode 100644 board/atmel/at91sam9x5ek/at91sam9x5ek.c create mode 100644 board/atmel/at91sam9x5ek/config.mk create mode 100644 include/configs/at91sam9x5ek.h
diff --git a/MAINTAINERS b/MAINTAINERS index 6438e1c..a2fccbf 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -660,6 +660,9 @@ Sedji Gaouaousedji.gaouaou@atmel.com at91sam9g10ek ARM926EJS (AT91SAM9G10 SoC) at91sam9m10g45ek ARM926EJS (AT91SAM9G45 SoC)
+Bo Shen voice.shen@atmel.com + at91sam9x5ek ARM926EJS (AT91SAM9G15,G25,G35,X25,X35 SoC) + Simon Guinot simon.guinot@sequanux.org
inetspace_v2 ARM926EJS (Kirkwood SoC) diff --git a/arch/arm/cpu/arm926ejs/at91/Makefile b/arch/arm/cpu/arm926ejs/at91/Makefile index f333753..346e58f 100644 --- a/arch/arm/cpu/arm926ejs/at91/Makefile +++ b/arch/arm/cpu/arm926ejs/at91/Makefile @@ -35,6 +35,7 @@ COBJS-$(CONFIG_AT91SAM9263) += at91sam9263_devices.o COBJS-$(CONFIG_AT91SAM9RL) += at91sam9rl_devices.o COBJS-$(CONFIG_AT91SAM9M10G45) += at91sam9m10g45_devices.o COBJS-$(CONFIG_AT91SAM9G45) += at91sam9m10g45_devices.o +COBJS-$(CONFIG_AT91SAM9X5) += at91sam9x5_devices.o COBJS-$(CONFIG_AT91_EFLASH) += eflash.o COBJS-$(CONFIG_AT91_LED) += led.o COBJS-y += clock.o diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c new file mode 100644 index 0000000..7558ca2 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c @@ -0,0 +1,232 @@ +/* + * Copyright (C) 2012 Atmel Corporation + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/io.h> + +unsigned int get_chip_id(void) +{ + /* The 0x40 is the offset of cidr in DBGU */ + return readl(ATMEL_BASE_DBGU + 0x40) & ~ARCH_ID_VERSION_MASK; +} + +unsigned int get_extension_chip_id(void) +{ + /* The 0x44 is the offset of exid in DBGU */ + return readl(ATMEL_BASE_DBGU + 0x44); +} + +unsigned int has_emac1() +{ + return cpu_is_at91sam9x25(); +} + +unsigned int has_emac0() +{ + return !(cpu_is_at91sam9g15()); +} + +unsigned int has_lcdc() +{ + return cpu_is_at91sam9g15() || cpu_is_at91sam9g35() + || cpu_is_at91sam9x35(); +} + +char *get_cpu_name() +{ + unsigned int extension_id = get_extension_chip_id(); + + if (cpu_is_at91sam9x5()) { + switch (extension_id) { + case ARCH_EXID_AT91SAM9G15: + return CONFIG_SYS_AT91_G15_CPU_NAME; + case ARCH_EXID_AT91SAM9G25: + return CONFIG_SYS_AT91_G25_CPU_NAME; + case ARCH_EXID_AT91SAM9G35: + return CONFIG_SYS_AT91_G35_CPU_NAME; + case ARCH_EXID_AT91SAM9X25: + return CONFIG_SYS_AT91_X25_CPU_NAME; + case ARCH_EXID_AT91SAM9X35: + return CONFIG_SYS_AT91_X35_CPU_NAME; + default: + return CONFIG_SYS_AT91_UNKNOWN_CPU; + } + } else { + return CONFIG_SYS_AT91_UNKNOWN_CPU; + } +} + +void at91_seriald_hw_init(void) +{ + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 9, 0); /* DRXD */ + at91_set_a_periph(AT91_PIO_PORTA, 10, 1); /* DTXD */ + + writel(1 << ATMEL_ID_SYS, &pmc->pcer); +} + +void at91_serial0_hw_init(void) +{ + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 0, 1); /* TXD */ + at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* RXD */ + + writel(1 << ATMEL_ID_USART0, &pmc->pcer); +} + +void at91_serial1_hw_init(void) +{ + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 5, 1); /* TXD */ + at91_set_a_periph(AT91_PIO_PORTA, 6, 0); /* RXD */ + + writel(1 << ATMEL_ID_USART1, &pmc->pcer); +} + +void at91_serial2_hw_init(void) +{ + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 7, 1); /* TXD */ + at91_set_a_periph(AT91_PIO_PORTA, 8, 0); /* RXD */ + + writel(1 << ATMEL_ID_USART2, &pmc->pcer); +} + +#ifdef CONFIG_ATMEL_SPI +void at91_spi0_hw_init(unsigned long cs_mask) +{ + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_PMC_BASE; + + at91_set_a_periph(AT91_PIO_PORTA, 11, 0); /* SPI0_MISO */ + at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* SPI0_MOSI */ + at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* SPI0_SPCK */ + + /* Enable clock */ + writel(1 << ATMEL_ID_SPI0, &pmc->pcer); + + if (cs_mask & (1 << 0)) + at91_set_a_periph(AT91_PIO_PORTA, 14, 0); + if (cs_mask & (1 << 1)) + at91_set_b_periph(AT91_PIO_PORTA, 7, 0); + if (cs_mask & (1 << 2)) + at91_set_b_periph(AT91_PIO_PORTA, 1, 0); + if (cs_mask & (1 << 3)) + at91_set_b_periph(AT91_PIO_PORTB, 3, 0); + if (cs_mask & (1 << 4)) + at91_set_pio_output(AT91_PIO_PORTA, 14, 0); + if (cs_mask & (1 << 5)) + at91_set_pio_output(AT91_PIO_PORTA, 7, 0); + if (cs_mask & (1 << 6)) + at91_set_pio_output(AT91_PIO_PORTA, 1, 0); + if (cs_mask & (1 << 7)) + at91_set_pio_output(AT91_PIO_PORTB, 3, 0); +} + +void at91_spi1_hw_init(unsigned long cs_mask) +{ + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_PMC_BASE; + + at91_set_b_periph(AT91_PIO_PORTA, 21, 0); /* SPI1_MISO */ + at91_set_b_periph(AT91_PIO_PORTA, 22, 0); /* SPI1_MOSI */ + at91_set_b_periph(AT91_PIO_PORTA, 23, 0); /* SPI1_SPCK */ + + /* Enable clock */ + writel(1 << ATMEL_ID_SPI1, &pmc->pcer); + + if (cs_mask & (1 << 0)) + at91_set_b_periph(AT91_PIO_PORTA, 8, 0); + if (cs_mask & (1 << 1)) + at91_set_b_periph(AT91_PIO_PORTA, 0, 0); + if (cs_mask & (1 << 2)) + at91_set_b_periph(AT91_PIO_PORTA, 31, 0); + if (cs_mask & (1 << 3)) + at91_set_b_periph(AT91_PIO_PORTA, 30, 0); + if (cs_mask & (1 << 4)) + at91_set_pio_output(AT91_PIO_PORTA, 8, 0); + if (cs_mask & (1 << 5)) + at91_set_pio_output(AT91_PIO_PORTA, 0, 0); + if (cs_mask & (1 << 6)) + at91_set_pio_output(AT91_PIO_PORTA, 31, 0); + if (cs_mask & (1 << 7)) + at91_set_pio_output(AT91_PIO_PORTA, 30, 0); +} +#endif + +#ifdef CONFIG_MACB +void at91_macb_hw_init(void) +{ + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; + + if (has_emac0()) { + /* Enable EMAC0 clock */ + writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); + /* EMAC0 pins setup */ + at91_set_a_periph(AT91_PIO_PORTB, 4, 0); /* ETXCK */ + at91_set_a_periph(AT91_PIO_PORTB, 3, 0); /* ERXDV */ + at91_set_a_periph(AT91_PIO_PORTB, 0, 0); /* ERX0 */ + at91_set_a_periph(AT91_PIO_PORTB, 1, 0); /* ERX1 */ + at91_set_a_periph(AT91_PIO_PORTB, 2, 0); /* ERXER */ + at91_set_a_periph(AT91_PIO_PORTB, 7, 0); /* ETXEN */ + at91_set_a_periph(AT91_PIO_PORTB, 9, 0); /* ETX0 */ + at91_set_a_periph(AT91_PIO_PORTB, 10, 0); /* ETX1 */ + at91_set_a_periph(AT91_PIO_PORTB, 5, 0); /* EMDIO */ + at91_set_a_periph(AT91_PIO_PORTB, 6, 0); /* EMDC */ + } + + if (has_emac1()) { + /* Enable EMAC1 clock */ + writel(1 << ATMEL_ID_EMAC1, &pmc->pcer); + /* EMAC1 pins setup */ + at91_set_b_periph(AT91_PIO_PORTC, 29, 0); /* ETXCK */ + at91_set_b_periph(AT91_PIO_PORTC, 28, 0); /* ECRSDV */ + at91_set_b_periph(AT91_PIO_PORTC, 20, 0); /* ERXO */ + at91_set_b_periph(AT91_PIO_PORTC, 21, 0); /* ERX1 */ + at91_set_b_periph(AT91_PIO_PORTC, 16, 0); /* ERXER */ + at91_set_b_periph(AT91_PIO_PORTC, 27, 0); /* ETXEN */ + at91_set_b_periph(AT91_PIO_PORTC, 18, 0); /* ETX0 */ + at91_set_b_periph(AT91_PIO_PORTC, 19, 0); /* ETX1 */ + at91_set_b_periph(AT91_PIO_PORTC, 31, 0); /* EMDIO */ + at91_set_b_periph(AT91_PIO_PORTC, 30, 0); /* EMDC */ + } + +#ifndef CONFIG_RMII + /* Only emac0 support MII */ + if (has_emac0()) { + at91_set_b_periph(AT91_PIO_PORTB, 16, 0); /* ECRS */ + at91_set_b_periph(AT91_PIO_PORTB, 17, 0); /* ECOL */ + at91_set_b_periph(AT91_PIO_PORTB, 13, 0); /* ERX2 */ + at91_set_b_periph(AT91_PIO_PORTB, 14, 0); /* ERX3 */ + at91_set_b_periph(AT91_PIO_PORTB, 15, 0); /* ERXCK */ + at91_set_b_periph(AT91_PIO_PORTB, 11, 0); /* ETX2 */ + at91_set_b_periph(AT91_PIO_PORTB, 12, 0); /* ETX3 */ + at91_set_b_periph(AT91_PIO_PORTB, 8, 0); /* ETXER */ + } +#endif +} +#endif diff --git a/arch/arm/cpu/arm926ejs/at91/clock.c b/arch/arm/cpu/arm926ejs/at91/clock.c index a7085de..dc5c6c4 100644 --- a/arch/arm/cpu/arm926ejs/at91/clock.c +++ b/arch/arm/cpu/arm926ejs/at91/clock.c @@ -154,7 +154,8 @@ int at91_clock_init(unsigned long main_clock) * For now, assume this parentage won't change. */ mckr = readl(&pmc->mckr); -#if defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) +#if defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) \ + || defined(CONFIG_AT91SAM9X5) /* plla divisor by 2 */ gd->plla_rate_hz /= (1 << ((mckr & 1 << 12) >> 12)); #endif @@ -168,7 +169,14 @@ int at91_clock_init(unsigned long main_clock) freq / ((mckr & AT91_PMC_MCKR_MDIV_MASK) >> 7) : freq; if (mckr & AT91_PMC_MCKR_MDIV_MASK) freq /= 2; /* processor clock division */ -#elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) +#elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) \ + || defined(CONFIG_AT91SAM9X5) + /* mdiv <==> divisor + * 0 <==> 1 + * 1 <==> 2 + * 2 <==> 4 + * 3 <==> 3 + */ gd->mck_rate_hz = (mckr & AT91_PMC_MCKR_MDIV_MASK) == (AT91_PMC_MCKR_MDIV_2 | AT91_PMC_MCKR_MDIV_4) ? freq / 3 diff --git a/arch/arm/include/asm/arch-at91/at91sam9_matrix.h b/arch/arm/include/asm/arch-at91/at91sam9_matrix.h index 6d97189..b9a93b0 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9_matrix.h +++ b/arch/arm/include/asm/arch-at91/at91sam9_matrix.h @@ -23,6 +23,8 @@ #include <asm/arch/at91cap9_matrix.h> #elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) #include <asm/arch/at91sam9g45_matrix.h> +#elif defined(CONFIG_AT91SAM9X5) +#include <asm/arch/at91sam9x5_matrix.h> #else #error "Unsupported AT91SAM9/CAP9 processor" #endif diff --git a/arch/arm/include/asm/arch-at91/at91sam9x5.h b/arch/arm/include/asm/arch-at91/at91sam9x5.h new file mode 100644 index 0000000..0e728c9 --- /dev/null +++ b/arch/arm/include/asm/arch-at91/at91sam9x5.h @@ -0,0 +1,170 @@ +/* + * Chip-specific header file for the AT91SAM9x5 family + * + * Copyright (C) 2012 Atmel Corporation. + * + * Definitions for the SoC: + * AT91SAM9x5 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef __AT91SAM9X5_H__ +#define __AT91SAM9X5_H__ + +/* + * Peripheral identifiers/interrupts. + */ +#define ATMEL_ID_FIQ 0 /* Advanced Interrupt Controller (FIQ) */ +#define ATMEL_ID_SYS 1 /* System Controller Interrupt */ +#define ATMEL_ID_PIOAB 2 /* Parallel I/O Controller A and B */ +#define ATMEL_ID_PIOCD 3 /* Parallel I/O Controller C and D */ +#define ATMEL_ID_SMD 4 /* SMD Soft Modem (SMD) */ +#define ATMEL_ID_USART0 5 /* USART 0 */ +#define ATMEL_ID_USART1 6 /* USART 1 */ +#define ATMEL_ID_USART2 7 /* USART 2 */ +#define ATMEL_ID_TWI0 9 /* Two-Wire Interface 0 */ +#define ATMEL_ID_TWI1 10 /* Two-Wire Interface 1 */ +#define ATMEL_ID_TWI2 11 /* Two-Wire Interface 2 */ +#define ATMEL_ID_HSMCI0 12 /* High Speed Multimedia Card Interface 0 */ +#define ATMEL_ID_SPI0 13 /* Serial Peripheral Interface 0 */ +#define ATMEL_ID_SPI1 14 /* Serial Peripheral Interface 1 */ +#define ATMEL_ID_UART0 15 /* UART 0 */ +#define ATMEL_ID_UART1 16 /* UART 1 */ +#define ATMEL_ID_TC01 17 /* Timer Counter 0, 1, 2, 3, 4 and 5 */ +#define ATMEL_ID_PWM 18 /* Pulse Width Modulation Controller */ +#define ATMEL_ID_ADC 19 /* ADC Controller */ +#define ATMEL_ID_DMAC0 20 /* DMA Controller 0 */ +#define ATMEL_ID_DMAC1 21 /* DMA Controller 1 */ +#define ATMEL_ID_UHPHS 22 /* USB Host High Speed */ +#define ATMEL_ID_UDPHS 23 /* USB Device High Speed */ +#define ATMEL_ID_EMAC0 24 /* Ethernet MAC0 */ +#define ATMEL_ID_LCDC 25 /* LCD Controller */ +#define ATMEL_ID_HSMCI1 26 /* High Speed Multimedia Card Interface 1 */ +#define ATMEL_ID_EMAC1 27 /* Ethernet MAC1 */ +#define ATMEL_ID_SSC 28 /* Synchronous Serial Controller */ +#define ATMEL_ID_IRQ 31 /* Advanced Interrupt Controller */ + +/* + * User Peripheral physical base addresses. + */ +#define ATMEL_BASE_SPI0 0xf0000000 +#define ATMEL_BASE_SPI1 0xf0004000 +#define ATMEL_BASE_HSMCI0 0xf0008000 +#define ATMEL_BASE_HSMCI1 0xf000c000 +#define ATMEL_BASE_SSC 0xf0010000 +#define ATMEL_BASE_CAN0 0xf8000000 +#define ATMEL_BASE_CAN1 0xf8004000 +#define ATMEL_BASE_TC0 0xf8008000 +#define ATMEL_BASE_TC1 0xf8008040 +#define ATMEL_BASE_TC2 0xf8008080 +#define ATMEL_BASE_TC3 0xf800c000 +#define ATMEL_BASE_TC4 0xf800c040 +#define ATMEL_BASE_TC5 0xf800c080 +#define ATMEL_BASE_TWI0 0xf8010000 +#define ATMEL_BASE_TWI1 0xf8014000 +#define ATMEL_BASE_TWI2 0xf8018000 +#define ATMEL_BASE_USART0 0xf801c000 +#define ATMEL_BASE_USART1 0xf8020000 +#define ATMEL_BASE_USART2 0xf8024000 +#define ATMEL_BASE_USART3 0xf8028000 +#define ATMEL_BASE_EMAC0 0xf802c000 +#define ATMEL_BASE_EMAC1 0xf8030000 +#define ATMEL_BASE_PWM 0xf8034000 +#define ATMEL_BASE_LCDC 0xf8038000 +#define ATMEL_BASE_UDPHS 0xf803c000 +#define ATMEL_BASE_UART0 0xf8040000 +#define ATMEL_BASE_UART1 0xf8044000 +#define ATMEL_BASE_ISI 0xf8048000 +#define ATMEL_BASE_ADC 0xf804c000 +#define ATMEL_BASE_SYS 0xffffc000 + +/* + * System Peripherals + */ +#define ATMEL_BASE_MATRIX 0xffffde00 +#define ATMEL_BASE_PMECC 0xffffe000 +#define ATMEL_BASE_PMERRLOC 0xffffe600 +#define ATMEL_BASE_DDRSDRC 0xffffe800 +#define ATMEL_BASE_SMC 0xffffea00 +#define ATMEL_BASE_DMAC0 0xffffec00 +#define ATMEL_BASE_DMAC1 0xffffee00 +#define ATMEL_BASE_AIC 0xfffff000 +#define ATMEL_BASE_DBGU 0xfffff200 +#define ATMEL_BASE_PIOA 0xfffff400 +#define ATMEL_BASE_PIOB 0xfffff600 +#define ATMEL_BASE_PIOC 0xfffff800 +#define ATMEL_BASE_PIOD 0xfffffa00 +#define ATMEL_BASE_PMC 0xfffffc00 +#define ATMEL_BASE_RSTC 0xfffffe00 +#define ATMEL_BASE_SHDWC 0xfffffe10 +#define ATMEL_BASE_PIT 0xfffffe30 +#define ATMEL_BASE_WDT 0xfffffe40 +#define ATMEL_BASE_GPBR 0xfffffe60 +#define ATMEL_BASE_RTC 0xfffffeb0 + +/* + * Internal Memory. + */ +#define ATMEL_BASE_ROM 0x00100000 /* Internal ROM base address */ +#define ATMEL_BASE_SRAM 0x00300000 /* Internal SRAM base address */ +#define ATMEL_BASE_SMD 0x00400000 /* SMD Controller */ +#define ATMEL_BASE_UDPHS_FIFO 0x00500000 /* USB Device HS controller */ +#define ATMEL_BASE_OHCI 0x00600000 /* USB Host controller (OHCI) */ +#define ATMEL_BASE_EHCI 0x00700000 /* USB Host controller (EHCI) */ + +/* 9x5 series chip id definitions */ +#define ARCH_ID_AT91SAM9X5 0x819a05a0 +#define ARCH_ID_VERSION_MASK 0x1f +#define ARCH_EXID_AT91SAM9G15 0x00000000 +#define ARCH_EXID_AT91SAM9G35 0x00000001 +#define ARCH_EXID_AT91SAM9X35 0x00000002 +#define ARCH_EXID_AT91SAM9G25 0x00000003 +#define ARCH_EXID_AT91SAM9X25 0x00000004 + +#define cpu_is_at91sam9x5() (get_chip_id() == ARCH_ID_AT91SAM9X5) +#define cpu_is_at91sam9g15() (cpu_is_at91sam9x5() && \ + (get_extension_chip_id() == ARCH_EXID_AT91SAM9G15)) +#define cpu_is_at91sam9g25() (cpu_is_at91sam9x5() && \ + (get_extension_chip_id() == ARCH_EXID_AT91SAM9G25)) +#define cpu_is_at91sam9g35() (cpu_is_at91sam9x5() && \ + (get_extension_chip_id() == ARCH_EXID_AT91SAM9G35)) +#define cpu_is_at91sam9x25() (cpu_is_at91sam9x5() && \ + (get_extension_chip_id() == ARCH_EXID_AT91SAM9X25)) +#define cpu_is_at91sam9x35() (cpu_is_at91sam9x5() && \ + (get_extension_chip_id() == ARCH_EXID_AT91SAM9X35)) + +/* + * Cpu Name + */ +#define CONFIG_SYS_AT91_G15_CPU_NAME "AT91SAM9G15" +#define CONFIG_SYS_AT91_G25_CPU_NAME "AT91SAM9G25" +#define CONFIG_SYS_AT91_G35_CPU_NAME "AT91SAM9G35" +#define CONFIG_SYS_AT91_X25_CPU_NAME "AT91SAM9X25" +#define CONFIG_SYS_AT91_X35_CPU_NAME "AT91SAM9X35" +#define CONFIG_SYS_AT91_UNKNOWN_CPU "Unknown CPU type" +#define ATMEL_CPU_NAME get_cpu_name() + +/* + * Other misc defines + */ +#define ATMEL_PIO_PORTS 4 +#define CPU_HAS_PIO3 +#define PIO_SCDR_DIV (0x3fff << 0) /* Slow Clock Divider Mask */ + +/* + * at91sam9x5 specific prototypes + */ +#ifndef __ASSEMBLY__ +unsigned int get_chip_id(void); +unsigned int get_extension_chip_id(void); +unsigned int has_emac1(void); +unsigned int has_emac0(void); +unsigned int has_lcdc(void); +char *get_cpu_name(void); +#endif + +#endif diff --git a/arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h b/arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h new file mode 100644 index 0000000..d6ce6fa --- /dev/null +++ b/arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h @@ -0,0 +1,91 @@ +/* + * Matrix-centric header file for the AT91SAM9X5 family + * + * Copyright (C) 2012 Atmel Corporation. + * + * Memory Controllers (MATRIX, EBI) - System peripherals registers. + * Based on AT91SAM9X5 preliminary datasheet. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef __AT91SAM9X5_MATRIX_H__ +#define __AT91SAM9X5_MATRIX_H__ + +#ifndef __ASSEMBLY__ + +struct at91_matrix { + u32 mcfg[16]; + u32 scfg[16]; + u32 pras[16][2]; + u32 mrcr; /* 0x100 Master Remap Control */ + u32 filler[7]; + u32 ebicsa; + u32 filler4[47]; + u32 wpmr; + u32 wpsr; +}; + +#endif /* __ASSEMBLY__ */ + +#define AT91_MATRIX_ULBT_INFINITE (0 << 0) +#define AT91_MATRIX_ULBT_SINGLE (1 << 0) +#define AT91_MATRIX_ULBT_FOUR (2 << 0) +#define AT91_MATRIX_ULBT_EIGHT (3 << 0) +#define AT91_MATRIX_ULBT_SIXTEEN (4 << 0) +#define AT91_MATRIX_ULBT_THIRTYTWO (5 << 0) +#define AT91_MATRIX_ULBT_SIXTYFOUR (6 << 0) +#define AT91_MATRIX_ULBT_128 (7 << 0) + +#define AT91_MATRIX_DEFMSTR_TYPE_NONE (0 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_LAST (1 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_FIXED (2 << 16) +#define AT91_MATRIX_FIXED_DEFMSTR_SHIFT 18 + +#define AT91_MATRIX_M0PR_SHIFT 0 +#define AT91_MATRIX_M1PR_SHIFT 4 +#define AT91_MATRIX_M2PR_SHIFT 8 +#define AT91_MATRIX_M3PR_SHIFT 12 +#define AT91_MATRIX_M4PR_SHIFT 16 +#define AT91_MATRIX_M5PR_SHIFT 20 +#define AT91_MATRIX_M6PR_SHIFT 24 +#define AT91_MATRIX_M7PR_SHIFT 28 + +#define AT91_MATRIX_M8PR_SHIFT 0 /* register B */ +#define AT91_MATRIX_M9PR_SHIFT 4 /* register B */ +#define AT91_MATRIX_M10PR_SHIFT 8 /* register B */ +#define AT91_MATRIX_M11PR_SHIFT 12 /* register B */ + +#define AT91_MATRIX_RCB0 (1 << 0) +#define AT91_MATRIX_RCB1 (1 << 1) +#define AT91_MATRIX_RCB2 (1 << 2) +#define AT91_MATRIX_RCB3 (1 << 3) +#define AT91_MATRIX_RCB4 (1 << 4) +#define AT91_MATRIX_RCB5 (1 << 5) +#define AT91_MATRIX_RCB6 (1 << 6) +#define AT91_MATRIX_RCB7 (1 << 7) +#define AT91_MATRIX_RCB8 (1 << 8) +#define AT91_MATRIX_RCB9 (1 << 9) +#define AT91_MATRIX_RCB10 (1 << 10) + +#define AT91_MATRIX_EBI_CS1A_SMC (0 << 1) +#define AT91_MATRIX_EBI_CS1A_SDRAMC (1 << 1) +#define AT91_MATRIX_EBI_CS3A_SMC (0 << 3) +#define AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA (1 << 3) +#define AT91_MATRIX_EBI_DBPU_ON (0 << 8) +#define AT91_MATRIX_EBI_DBPU_OFF (1 << 8) +#define AT91_MATRIX_EBI_DBPD_ON (0 << 9) +#define AT91_MATRIX_EBI_DBPD_OFF (1 << 9) +#define AT91_MATRIX_EBI_VDDIOMSEL_1_8V (0 << 16) +#define AT91_MATRIX_EBI_VDDIOMSEL_3_3V (1 << 16) +#define AT91_MATRIX_EBI_EBI_IOSR_REDUCED (0 << 17) +#define AT91_MATRIX_EBI_EBI_IOSR_NORMAL (1 << 17) +#define AT91_MATRIX_NFD0_ON_D0 (0 << 24) +#define AT91_MATRIX_NFD0_ON_D16 (1 << 24) +#define AT91_MATRIX_MP_OFF (0 << 25) +#define AT91_MATRIX_MP_ON (1 << 25) + +#endif diff --git a/arch/arm/include/asm/arch-at91/hardware.h b/arch/arm/include/asm/arch-at91/hardware.h index 85c2889..4c4ee70 100644 --- a/arch/arm/include/asm/arch-at91/hardware.h +++ b/arch/arm/include/asm/arch-at91/hardware.h @@ -37,6 +37,8 @@ # include <asm/arch/at91sam9rl.h> #elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) # include <asm/arch/at91sam9g45.h> +#elif defined(CONFIG_AT91SAM9X5) +# include <asm/arch/at91sam9x5.h> #elif defined(CONFIG_AT91CAP9) # include <asm/arch/at91cap9.h> #elif defined(CONFIG_AT91X40) diff --git a/board/atmel/at91sam9x5ek/Makefile b/board/atmel/at91sam9x5ek/Makefile new file mode 100644 index 0000000..458d9a0 --- /dev/null +++ b/board/atmel/at91sam9x5ek/Makefile @@ -0,0 +1,52 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian@popies.net +# Lead Tech Design <www.leadtechdesign.com> +# +# (C) Copyright 2012 +# Bo Shen voice.shen@atmel.com +# Atmel corporation <www.atmel.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += at91sam9x5ek.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c new file mode 100644 index 0000000..17db0fd --- /dev/null +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -0,0 +1,293 @@ +/* + * Copyright (C) 2012 Atmel Corporation + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91sam9x5_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/clk.h> +#include <lcd.h> +#include <atmel_hlcdc.h> +#ifdef CONFIG_MACB +#include <net.h> +#endif +#include <netdev.h> +#ifdef CONFIG_LCD_INFO +#include <nand.h> +#include <version.h> +#endif +#ifdef CONFIG_ATMEL_SPI +#include <spi.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ +#ifdef CONFIG_CMD_NAND +static void at91sam9x5ek_nand_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + unsigned long csa; + + /* Enable CS3 */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA; + writel(csa, &matrix->ebicsa); + + /* Configure SMC CS3 for NAND/SmartMedia */ + writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(4) | + AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(4), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(7), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_MODE_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_MODE_DBW_8 | +#endif + AT91_SMC_MODE_TDF_CYCLE(3), + &smc->cs[3].mode); + + writel(1 << ATMEL_ID_PIOCD, &pmc->pcer); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); + + at91_set_a_periph(AT91_PIO_PORTD, 0, 1); /* NAND OE */ + at91_set_a_periph(AT91_PIO_PORTD, 1, 1); /* NAND WE */ + at91_set_a_periph(AT91_PIO_PORTD, 2, 1); /* NAND ALE */ + at91_set_a_periph(AT91_PIO_PORTD, 3, 1); /* NAND CLE */ + at91_set_a_periph(AT91_PIO_PORTD, 6, 1); + at91_set_a_periph(AT91_PIO_PORTD, 7, 1); + at91_set_a_periph(AT91_PIO_PORTD, 8, 1); + at91_set_a_periph(AT91_PIO_PORTD, 9, 1); + at91_set_a_periph(AT91_PIO_PORTD, 10, 1); + at91_set_a_periph(AT91_PIO_PORTD, 11, 1); + at91_set_a_periph(AT91_PIO_PORTD, 12, 1); + at91_set_a_periph(AT91_PIO_PORTD, 13, 1); +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; + +#ifdef CONFIG_MACB + if (has_emac0()) + rc = macb_eth_initialize(0, + (void *)ATMEL_BASE_EMAC0, 0x00); + if (has_emac1()) + rc = macb_eth_initialize(1, + (void *)ATMEL_BASE_EMAC1, 0x00); +#endif + return rc; +} + +#ifdef CONFIG_LCD +vidinfo_t panel_info = { + .vl_col = 800, + .vl_row = 480, + .vl_clk = 24000000, + .vl_sync = LCDC_LCDCFG5_HSPOL | LCDC_LCDCFG5_VSPOL, + .vl_bpix = LCD_BPP, + .vl_tft = 1, + .vl_clk_pol = 1, + .vl_hsync_len = 128, + .vl_left_margin = 64, + .vl_right_margin = 64, + .vl_vsync_len = 2, + .vl_upper_margin = 22, + .vl_lower_margin = 21, + .mmio = ATMEL_BASE_LCDC, +}; + +void lcd_enable(void) +{ + if (has_lcdc()) + at91_set_a_periph(AT91_PIO_PORTC, 29, 1); /* power up */ +} + +void lcd_disable(void) +{ + if (has_lcdc()) + at91_set_a_periph(AT91_PIO_PORTC, 29, 0); /* power down */ +} + +static void at91sam9x5ek_lcd_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + if (has_lcdc()) { + at91_set_a_periph(AT91_PIO_PORTC, 26, 0); /* LCDPWM */ + at91_set_a_periph(AT91_PIO_PORTC, 27, 0); /* LCDVSYNC */ + at91_set_a_periph(AT91_PIO_PORTC, 28, 0); /* LCDHSYNC */ + at91_set_a_periph(AT91_PIO_PORTC, 24, 0); /* LCDDISP */ + at91_set_a_periph(AT91_PIO_PORTC, 29, 0); /* LCDDEN */ + at91_set_a_periph(AT91_PIO_PORTC, 30, 0); /* LCDPCK */ + + at91_set_a_periph(AT91_PIO_PORTC, 0, 0); /* LCDD0 */ + at91_set_a_periph(AT91_PIO_PORTC, 1, 0); /* LCDD1 */ + at91_set_a_periph(AT91_PIO_PORTC, 2, 0); /* LCDD2 */ + at91_set_a_periph(AT91_PIO_PORTC, 3, 0); /* LCDD3 */ + at91_set_a_periph(AT91_PIO_PORTC, 4, 0); /* LCDD4 */ + at91_set_a_periph(AT91_PIO_PORTC, 5, 0); /* LCDD5 */ + at91_set_a_periph(AT91_PIO_PORTC, 6, 0); /* LCDD6 */ + at91_set_a_periph(AT91_PIO_PORTC, 7, 0); /* LCDD7 */ + at91_set_a_periph(AT91_PIO_PORTC, 8, 0); /* LCDD8 */ + at91_set_a_periph(AT91_PIO_PORTC, 9, 0); /* LCDD9 */ + at91_set_a_periph(AT91_PIO_PORTC, 10, 0); /* LCDD10 */ + at91_set_a_periph(AT91_PIO_PORTC, 11, 0); /* LCDD11 */ + at91_set_a_periph(AT91_PIO_PORTC, 12, 0); /* LCDD12 */ + at91_set_a_periph(AT91_PIO_PORTC, 13, 0); /* LCDD13 */ + at91_set_a_periph(AT91_PIO_PORTC, 14, 0); /* LCDD14 */ + at91_set_a_periph(AT91_PIO_PORTC, 15, 0); /* LCDD15 */ + at91_set_a_periph(AT91_PIO_PORTC, 16, 0); /* LCDD16 */ + at91_set_a_periph(AT91_PIO_PORTC, 17, 0); /* LCDD17 */ + at91_set_a_periph(AT91_PIO_PORTC, 18, 0); /* LCDD18 */ + at91_set_a_periph(AT91_PIO_PORTC, 19, 0); /* LCDD19 */ + at91_set_a_periph(AT91_PIO_PORTC, 20, 0); /* LCDD20 */ + at91_set_a_periph(AT91_PIO_PORTC, 21, 0); /* LCDD21 */ + at91_set_a_periph(AT91_PIO_PORTC, 22, 0); /* LCDD22 */ + at91_set_a_periph(AT91_PIO_PORTC, 23, 0); /* LCDD23 */ + + writel(1 << ATMEL_ID_LCDC, &pmc->pcer); + } +} + +#ifdef CONFIG_LCD_INFO +void lcd_show_board_info(void) +{ + ulong dram_size, nand_size; + int i; + char temp[32]; + + if (has_lcdc()) { + lcd_printf("%s\n", U_BOOT_VERSION); + lcd_printf("(C) 2012 ATMEL Corp\n"); + lcd_printf("at91support@atmel.com\n"); + lcd_printf("%s CPU at %s MHz\n", + get_cpu_name(), + strmhz(temp, get_cpu_clk_rate())); + + dram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) + dram_size += gd->bd->bi_dram[i].size; + nand_size = 0; + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) + nand_size += nand_info[i].size; + lcd_printf(" %ld MB SDRAM, %ld MB NAND\n", + dram_size >> 20, + nand_size >> 20); + } +} +#endif /* CONFIG_LCD_INFO */ +#endif /* CONFIG_LCD */ + +/* SPI chip select control */ +#ifdef CONFIG_ATMEL_SPI +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus == 0 && cs < 2; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + switch (slave->cs) { + case 1: + at91_set_pio_output(AT91_PIO_PORTA, 7, 0); + break; + case 0: + default: + at91_set_pio_output(AT91_PIO_PORTA, 14, 0); + break; + } +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + switch (slave->cs) { + case 1: + at91_set_pio_output(AT91_PIO_PORTA, 7, 1); + break; + case 0: + default: + at91_set_pio_output(AT91_PIO_PORTA, 14, 1); + break; + } +} +#endif /* CONFIG_ATMEL_SPI */ + +int board_early_init_f(void) +{ + at91_seriald_hw_init(); + return 0; +} + +int board_init(void) +{ + /* arch number of AT91SAM9X5EK-Board */ + gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9X5EK; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + +#ifdef CONFIG_CMD_NAND + at91sam9x5ek_nand_hw_init(); +#endif + +#ifdef CONFIG_ATMEL_SPI + at91_spi0_hw_init(1 << 0); + at91_spi0_hw_init(1 << 4); +#endif + +#ifdef CONFIG_MACB + at91_macb_hw_init(); +#endif + +#ifdef CONFIG_LCD + at91sam9x5ek_lcd_hw_init(); +#endif + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *) CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} diff --git a/board/atmel/at91sam9x5ek/config.mk b/board/atmel/at91sam9x5ek/config.mk new file mode 100644 index 0000000..6589a12 --- /dev/null +++ b/board/atmel/at91sam9x5ek/config.mk @@ -0,0 +1 @@ +CONFIG_SYS_TEXT_BASE = 0x26f00000 diff --git a/boards.cfg b/boards.cfg index 9205070..c9bd1b3 100644 --- a/boards.cfg +++ b/boards.cfg @@ -89,6 +89,7 @@ at91sam9g20ek_nandflash arm arm926ejs at91sam9260ek atmel at91sam9m10g45ek_nandflash arm arm926ejs at91sam9m10g45ek atmel at91 at91sam9m10g45ek:AT91SAM9M10G45,SYS_USE_NANDFLASH at91sam9rlek_dataflash arm arm926ejs at91sam9rlek atmel at91 at91sam9rlek:AT91SAM9RL,SYS_USE_DATAFLASH at91sam9rlek_nandflash arm arm926ejs at91sam9rlek atmel at91 at91sam9rlek:AT91SAM9RL,SYS_USE_NANDFLASH +at91sam9x5ek_nandflash arm arm926ejs at91sam9x5ek atmel at91 at91sam9x5ek:AT91SAM9X5,SYS_USE_NANDFLASH at91sam9xeek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS0 at91sam9xeek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS1 at91sam9xeek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_NANDFLASH diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 4578467..8f55cdc 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -471,7 +471,7 @@ static int macb_init(struct eth_device *netdev, bd_t *bd) #if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) || \ defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) || \ - defined(CONFIG_AT91SAM9XE) + defined(CONFIG_AT91SAM9XE) || defined(CONFIG_AT91SAM9X5) macb_writel(macb, USRIO, MACB_BIT(RMII) | MACB_BIT(CLKEN)); #else macb_writel(macb, USRIO, 0); @@ -480,7 +480,7 @@ static int macb_init(struct eth_device *netdev, bd_t *bd) #if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) || \ defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) || \ - defined(CONFIG_AT91SAM9XE) + defined(CONFIG_AT91SAM9XE) || defined(CONFIG_AT91SAM9X5) macb_writel(macb, USRIO, MACB_BIT(CLKEN)); #else macb_writel(macb, USRIO, MACB_BIT(MII)); diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h new file mode 100644 index 0000000..f8bd870 --- /dev/null +++ b/include/configs/at91sam9x5ek.h @@ -0,0 +1,183 @@ +/* + * Copyright (C) 2012 Atmel Corporation + * + * Configuation settings for the AT91SAM9X5EK board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H__ +#define __CONFIG_H__ + +#include <asm/hardware.h> + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 +#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_AT91SAM9X5EK +#define CONFIG_AT91FAMILY + +#define CONFIG_ARCH_CPU_INIT + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_DISPLAY_CPUINFO + +/* general purpose I/O */ +#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ +#define CONFIG_AT91_GPIO + +/* serial console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS + +/* LCD */ +#define CONFIG_LCD +#define LCD_BPP LCD_COLOR16 +#define LCD_OUTPUT_BPP 24 +#define CONFIG_LCD_LOGO +#undef LCD_TEST_PATTERN +#define CONFIG_LCD_INFO +#define CONFIG_LCD_INFO_BELOW_LOGO +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_ATMEL_HLCD +#define CONFIG_ATMEL_LCD_RGB565 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NAND + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE 0x20000000 +#define CONFIG_SYS_SDRAM_SIZE 0x08000000 /* 128 megs */ + +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE) + +/* DataFlash */ +#ifdef CONFIG_ATMEL_SPI +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_ATMEL +#define CONFIG_SYS_MAX_DATAFLASH_BANKS +#endif + +/* no NOR flash */ +#define CONFIG_SYS_NO_FLASH + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD4 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PD5 + +#define CONFIG_MTD_DEVICE +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_RBTREE +#define CONFIG_LZO +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#endif + +/* Ethernet */ +#define CONFIG_MACB +#define CONFIG_RMII +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_MACB_SEARCH_PHY + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END 0x26e00000 + +#ifdef CONFIG_SYS_USE_NANDFLASH +/* bootstrap + u-boot + env + linux in nandflash */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0xc0000 +#define CONFIG_ENV_OFFSET_REDUND 0x100000 +#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND "nand read " \ + "0x22000000 0x200000 0x300000; " \ + "bootm 0x22000000" +#endif + +#define CONFIG_BOOTARGS "mem=128M console=ttyS0,115200 " \ + "mtdparts=atmel_nand:" \ + "8M(bootstrap/uboot/kernel)ro,-(rootfs) " \ + "root=/dev/mtdblock1 rw " \ + "rootfstype=ubifs ubi.mtd=1 root=ubi0:rootfs" + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) \ + + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (512 * 1024 + 0x1000) + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
ping
- Copyright (C) 2012 Atmel Corporation
- project.
- MA 02111-1307 USA
- /* The 0x40 is the offset of cidr in DBGU */
- return readl(ATMEL_BASE_DBGU + 0x40) & ~ARCH_ID_VERSION_MASK;
- /* The 0x44 is the offset of exid in DBGU */
- return readl(ATMEL_BASE_DBGU + 0x44);
- return cpu_is_at91sam9x25();
- return !(cpu_is_at91sam9g15());
- return cpu_is_at91sam9g15() || cpu_is_at91sam9g35()
- unsigned int extension_id = get_extension_chip_id();
- if (cpu_is_at91sam9x5()) {
default:
- } else {
- at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
- at91_set_a_periph(AT91_PIO_PORTA, 9, 0); /* DRXD */
- at91_set_a_periph(AT91_PIO_PORTA, 10, 1); /* DTXD */
- writel(1 << ATMEL_ID_SYS, &pmc->pcer);
- at91_set_a_periph(AT91_PIO_PORTA, 0, 1); /* TXD */
- at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* RXD */
- writel(1 << ATMEL_ID_USART0, &pmc->pcer);
- at91_set_a_periph(AT91_PIO_PORTA, 5, 1); /* TXD */
- at91_set_a_periph(AT91_PIO_PORTA, 6, 0); /* RXD */
- writel(1 << ATMEL_ID_USART1, &pmc->pcer);
- at91_set_a_periph(AT91_PIO_PORTA, 7, 1); /* TXD */
- at91_set_a_periph(AT91_PIO_PORTA, 8, 0); /* RXD */
- writel(1 << ATMEL_ID_USART2, &pmc->pcer);
- at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_PMC_BASE;
- at91_set_a_periph(AT91_PIO_PORTA, 11, 0); /* SPI0_MISO */
- at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* SPI0_MOSI */
- at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* SPI0_SPCK */
- /* Enable clock */
- writel(1 << ATMEL_ID_SPI0, &pmc->pcer);
- if (cs_mask & (1 << 0))
- if (cs_mask & (1 << 1))
- if (cs_mask & (1 << 2))
- if (cs_mask & (1 << 3))
- if (cs_mask & (1 << 4))
- if (cs_mask & (1 << 5))
- if (cs_mask & (1 << 6))
- if (cs_mask & (1 << 7))
- at91_set_b_periph(AT91_PIO_PORTA, 21, 0); /* SPI1_MISO */
- at91_set_b_periph(AT91_PIO_PORTA, 22, 0); /* SPI1_MOSI */
- at91_set_b_periph(AT91_PIO_PORTA, 23, 0); /* SPI1_SPCK */
- writel(1 << ATMEL_ID_SPI1, &pmc->pcer);
+} +#endif
- if (has_emac0()) {
- if (has_emac1()) {
- /* Only emac0 support MII */
/* plla divisor by 2 */ gd->plla_rate_hz /= (1 << ((mckr & 1 << 12) >> 12)); #endif|| defined(CONFIG_AT91SAM9X5)
- /* mdiv <==> divisor
* 0 <==> 1
* 1 <==> 2
* 2 <==> 4
* 3 <==> 3
gd->mck_rate_hz = (mckr & AT91_PMC_MCKR_MDIV_MASK) == (AT91_PMC_MCKR_MDIV_2 | AT91_PMC_MCKR_MDIV_4) ? freq / 3*/
- Chip-specific header file for the AT91SAM9x5 family
- Copyright (C) 2012 Atmel Corporation.
- Definitions for the SoC:
- AT91SAM9x5
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Peripheral identifiers/interrupts.
- User Peripheral physical base addresses.
- System Peripherals
- Internal Memory.
- Cpu Name
- Other misc defines
- at91sam9x5 specific prototypes
- Matrix-centric header file for the AT91SAM9X5 family
- Memory Controllers (MATRIX, EBI) - System peripherals registers.
- Based on AT91SAM9X5 preliminary datasheet.
- u32 mcfg[16];
- u32 scfg[16];
- u32 pras[16][2];
- u32 mrcr; /* 0x100 Master Remap Control */
- u32 filler[7];
- u32 ebicsa;
- u32 filler4[47];
- u32 wpmr;
- u32 wpsr;
- $(call cmd_link_o_target, $(OBJS) $(SOBJS))
- project.
- MA 02111-1307 USA
- Miscelaneous platform dependent initialisations
- struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC;
- struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX;
- struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
- unsigned long csa;
- /* Enable CS3 */
- csa = readl(&matrix->ebicsa);
- csa |= AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA;
- writel(csa, &matrix->ebicsa);
- /* Configure SMC CS3 for NAND/SmartMedia */
- writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) |
&smc->cs[3].setup);
- writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(4) |
&smc->cs[3].pulse);
- writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(7),
&smc->cs[3].cycle);
- writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE |
&smc->cs[3].mode);
- writel(1 << ATMEL_ID_PIOCD, &pmc->pcer);
- /* Configure RDY/BSY */
- at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1);
- /* Enable NandFlash */
- at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1);
- at91_set_a_periph(AT91_PIO_PORTD, 0, 1); /* NAND OE */
- at91_set_a_periph(AT91_PIO_PORTD, 1, 1); /* NAND WE */
- at91_set_a_periph(AT91_PIO_PORTD, 2, 1); /* NAND ALE */
- at91_set_a_periph(AT91_PIO_PORTD, 3, 1); /* NAND CLE */
- at91_set_a_periph(AT91_PIO_PORTD, 6, 1);
- at91_set_a_periph(AT91_PIO_PORTD, 7, 1);
- at91_set_a_periph(AT91_PIO_PORTD, 8, 1);
- at91_set_a_periph(AT91_PIO_PORTD, 9, 1);
- at91_set_a_periph(AT91_PIO_PORTD, 10, 1);
- at91_set_a_periph(AT91_PIO_PORTD, 11, 1);
- at91_set_a_periph(AT91_PIO_PORTD, 12, 1);
- at91_set_a_periph(AT91_PIO_PORTD, 13, 1);
+} +#endif
- int rc = 0;
+#ifdef CONFIG_MACB
- if (has_emac0())
- if (has_emac1())
- return rc;
- .vl_col = 800,
- .vl_row = 480,
- .vl_clk = 24000000,
- .vl_sync = LCDC_LCDCFG5_HSPOL | LCDC_LCDCFG5_VSPOL,
- .vl_bpix = LCD_BPP,
- .vl_tft = 1,
- .vl_clk_pol = 1,
- .vl_hsync_len = 128,
- .vl_left_margin = 64,
- .vl_right_margin = 64,
- .vl_vsync_len = 2,
- .vl_upper_margin = 22,
- .vl_lower_margin = 21,
- .mmio = ATMEL_BASE_LCDC,
- if (has_lcdc())
- if (has_lcdc())
- if (has_lcdc()) {
- ulong dram_size, nand_size;
- int i;
- char temp[32];
- if (has_lcdc()) {
get_cpu_name(),
dram_size = 0;
nand_size = 0;
dram_size >> 20,
nand_size >> 20);
- return bus == 0 && cs < 2;
- switch (slave->cs) {
- case 1:
break;
- case 0:
- default:
break;
- case 1:
break;
- case 0:
- default:
break;
- at91_seriald_hw_init();
- /* arch number of AT91SAM9X5EK-Board */
- gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9X5EK;
- /* adress of boot parameters */
- gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- at91sam9x5ek_nand_hw_init();
- at91_spi0_hw_init(1 << 0);
- at91_spi0_hw_init(1 << 4);
+#ifdef CONFIG_MACB
- at91_macb_hw_init();
+#ifdef CONFIG_LCD
- at91sam9x5ek_lcd_hw_init();
- gd->ram_size = get_ram_size((void *) CONFIG_SYS_SDRAM_BASE,
- defined(CONFIG_AT91SAM9XE) || defined(CONFIG_AT91SAM9X5) macb_writel(macb, USRIO, MACB_BIT(RMII) | MACB_BIT(CLKEN)); #else macb_writel(macb, USRIO, 0);
- defined(CONFIG_AT91SAM9XE) || defined(CONFIG_AT91SAM9X5) macb_writel(macb, USRIO, MACB_BIT(CLKEN)); #else macb_writel(macb, USRIO, MACB_BIT(MII));
- Configuation settings for the AT91SAM9X5EK board.
- project.
- MA 02111-1307 USA
- BOOTP options
- Command line configuration.
- (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE)
"bootm 0x22000000"
+ 16)
- Size of malloc() pool
Dear Bo,
ping
I'm just back from vacation, will it apply ASAP.
best regards
Andreas Bießmann
Hi Andreas,
On 8/1/2012 16:20, Andreas Bießmann wrote:
Dear Bo,
ping
Thanks
Best Regards,
Bo Shen
best regards
Andreas Bießmann
Dear Bo Shen,
Applied to u-boot-atmel, thanks.
Best regards
Andreas Bießmann
Andreas Bießmann
Bo Shen
