[U-Boot-Users] [PATCH] cfi-flash: Add CFG_FLASH_AUTOPROTECT_LIST
This patch adds a configurable flash auto protection list that can be used to make U-Boot protect flash regions in flash_init().
The idea has been discussed on the u-boot mailing list starting on Nov 18th, 2007.
Even this patch brings a new feature it is used as a bugfix for 4xx platforms where flash_init() does not completely protect the monitor's flash range in all situations.
U-Boot protects the flash range from CFG_MONITOR_BASE to (CFG_MONITOR_BASE + monitor_flash_len - 1) by default. This does not include the reset vector at 0xfffffffc.
Example: #define CFG_FLASH_AUTOPROTECT_LIST {{0xfff80000, 0x80000}}
This config option will auto protect the last 512k of flash that contains the bootloader on board like APC405 and PMC405.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- drivers/mtd/cfi_flash.c | 17 +++++++++++++++++ 1 files changed, 17 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index e3cfb8a..68ab55f 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1873,6 +1873,12 @@ unsigned long flash_init (void) { unsigned long size = 0; int i; +#if defined(CFG_FLASH_AUTOPROTECT_LIST) + struct apl_s { + ulong start; + ulong size; + } apl[] = CFG_FLASH_AUTOPROTECT_LIST; +#endif
#ifdef CFG_FLASH_PROTECTION char *s = getenv("unlock"); @@ -1966,6 +1972,17 @@ unsigned long flash_init (void) CFG_ENV_ADDR_REDUND + CFG_ENV_SIZE_REDUND - 1, flash_get_info(CFG_ENV_ADDR_REDUND)); #endif + +#if defined(CFG_FLASH_AUTOPROTECT_LIST) + for (i = 0; i < (sizeof(apl) / sizeof(struct apl_s)); i++) { + debug("autoprotecting from %08x to %08x\n", + apl[i].start, apl[i].start + apl[i].size - 1); + flash_protect (FLAG_PROTECT_SET, + apl[i].start, + apl[i].start + apl[i].size - 1, + flash_get_info(apl[i].start)); + } +#endif return (size); }
- struct apl_s {
ulong start;
ulong size;
- } apl[] = CFG_FLASH_AUTOPROTECT_LIST;
I think it will be better to create a weak structure.
Best Regards, J.
Hi Jean-Christophe,
is it possible to use weak structures? Or do you mean a weak function that initializes my autoprotect list?
Please give me an idea and I will implement it.
Matthias
- struct apl_s {
ulong start;
ulong size;
Best Regards, J.
Hi Matthias,
I don't know if it's possible to implement a weak structure, but I would prefer something like this instead of your original implementation (no #ifdef's in the code):
struct apl_s { u32 start; u32 size; };
#if !defined(CFG_FLASH_AUTOPROTECT_LIST) struct apl_s apl[] = { }; #else struct apl_s apl[] = CFG_FLASH_AUTOPROTECT_LIST; #endif
And then later in the code:
+ for (i = 0; i < ARRAY_SIZE(apl); i++) { + debug("autoprotecting from %08x to %08x\n", + apl[i].start, apl[i].start + apl[i].size - 1); + flash_protect (FLAG_PROTECT_SET, + apl[i].start, + apl[i].start + apl[i].size - 1, + flash_get_info(apl[i].start)); + }
What do you think?
Matthias
- struct apl_s {
ulong start;
ulong size;
Best Regards, J.
!DSPAM:4809d80874783629025813!
Hi Stefan,
I could also life with your approach, but it will add code even to platforms that do not use the new option.
In this case I would prefer it against the weak implementation.
Matthias
On Saturday 19 April 2008 14:02:23 Stefan Roese wrote:
Hi Matthias,
apl[i].start,
What do you think?
Matthias
- struct apl_s {
ulong start;
ulong size;
Best Regards, J.
On 16:50 Sat 19 Apr , Matthias Fuchs wrote:
Hi Stefan,
I've already answer about it to Timur in this e-mail http://article.gmane.org/gmane.comp.boot-loaders.u-boot/37814/match=weak
I'm preparing a path about adding this define
import compiler-gcc header from linux and add
#ifndef __weak_alias #ifndef __weak_alias(fct) __attribute__((weak,alias(#fct))) #endif
so just add __weak to your default stucture and overwrite in the board
Best Regards, J.
I tried this in cfi_flash.c:
struct apl_s { ulong start; ulong size; }
struct apl_s apl[] __attribute__((weak)) = {};
I added a redeclaration of apl into my board code.
Now I ran into the problem that the ARRAY_SIZE macro on apl in cfi_flash.c does not take care of the redeclation. So it evaluated to 0 instead of the real size of the array from my board code.
Now I could
a) add a delimiter to the apl array (e.g. size=0 for the last entry) b) implement Stefan approach c) ???
Any idea?
Matthias
Hi Stefan,
Best Regards, J.
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Don't miss this year's exciting event. There's still time to save $100. Use priority code J8TL2D2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/java one _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
The problem with weak var is that the first declaration define the sizeof the var. and the other define the data;
As sugest Wolfgang we could do it like this
in cfi_flash.c
--- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1873,6 +1873,12 @@ unsigned long flash_init (void) { unsigned long size = 0; int i; +if define(CONFIG_FLASH_AUTOPROTECT) +struct apl_s apl[] = init_flash_autoprotect(); +#endif
#ifdef CFG_FLASH_PROTECTION char *s = getenv("unlock"); @@ -1966,6 +1972,17 @@ unsigned long flash_init (void) CFG_ENV_ADDR_REDUND + CFG_ENV_SIZE_REDUND - 1, flash_get_info(CFG_ENV_ADDR_REDUND)); #endif + +#if defined(CONFIG_FLASH_AUTOPROTECT) + for (i = 0; i < (sizeof(apl) / sizeof(struct apl_s)); i++) { + debug("autoprotecting from %08x to %08x\n", + apl[i].start, apl[i].start + apl[i].size - 1); + flash_protect (FLAG_PROTECT_SET, + apl[i].start, + apl[i].start + apl[i].size - 1, + flash_get_info(apl[i].start)); + } +#endif
in config header
struct apl_s apl* inline init_flash_autoprotect() { struct apl_s a[] = { {1, 3}, {4, 5}, };
return a; } Best Regards, J.
I did not suggest to use weak at all here!
return a; }
Are you sure this works?
- struct apl_s {
ulong start;
ulong size;
In the interest of memory footprint I prefer to stick with the #ifdef here.
Hi Wolfgang,
even though I like the weak stuff, I agree with you. I also like Stefan's idea about removing the #ifdef from the code.
So I will update my patch in this direction.
The main idea behind my patch is to fix the bootloader autoprotection for 4xx. Do you (sr, J., others) think i is also a good idea to add this:
/* Monitor protection ON by default */ #if (CFG_MONITOR_BASE >= CFG_FLASH_BASE) flash_protect (FLAG_PROTECT_SET, CFG_MONITOR_BASE, +#if defined(CONFIG_4xx) 0xffffffff, +#else CFG_MONITOR_BASE + monitor_flash_len - 1, +#endif flash_get_info(CFG_MONITOR_BASE)); #endif
To be honest, I hope to get my autoprotection patch into 1.3.3 (as a bug fix). But the above three lines would be satisfactory for fixing the issue. Finally I would like to have both changes applied.
Matthias
- struct apl_s {
ulong start;
ulong size;
Dear Matthias,
Thanks.
No, I don't think this is a good idea.
First, I don't see what is so special about 4xx here. There are other processors which have the reset vector at the end of the address space as well, so why do it for 4xx and not - for example - for 85xx?
Also, what makes you think it is reasonable to protect everything from CFG_MONITOR_BASE to the end of memory? Yes, we usually pot U-Boot close to the end of the flash memory, but there is no guarantee that every board configuration works that way. We could put U-Boot at the beginning of the flash instead and just reserve a single sector at the end of the flash for the reset vector. OK, that would need adaption of the linker script as well, but ...
I don't think this hardwired, absolute constant makes sense to me. If 0xffffffff is really the value to use, then it should be identical to the "CFG_MONITOR_BASE + monitor_flash_len - 1" expression, and then we should have no need for the #ifdef at all.
I see.
Matthias Fuchs
Stefan Roese
