[U-Boot] [PATCH v2] Tegra114: Add support for more clock sources for T114 periphs
Some T114 peripherals can take up to 8 different clock sources (parents), including 4 new ones that don't exist on previous chips (PLLC2/C3/MEM2/SRC2). Expand clock/pll code/tables to support these additional bits/sources.
Changes were made to some common code. Testing on T30/T20 showed no changes in periph clock sources/divisors.
Also, peripheral clock sources that no longer exist on T114 were removed from the clock_periph_type table (CVE, TVDAC, etc.), and periphs that are gone or not needed in early init are no longer brought out of reset/enabled (FUSE, IRAMA/B/C/D, etc.).
Signed-off-by: Tom Warren twarren@nvidia.com --- v2: - Removed some periph enables/resets that are not needed for early init - Fixed an assert test for a divisor value (s/b >0, not >=0) - Remove some unused code
arch/arm/cpu/arm720t/tegra114/cpu.c | 8 - arch/arm/cpu/tegra-common/clock.c | 21 +- arch/arm/cpu/tegra114-common/clock.c | 422 +++++++++++++--------- arch/arm/cpu/tegra30-common/clock.c | 6 - arch/arm/include/asm/arch-tegra/clk_rst.h | 3 + arch/arm/include/asm/arch-tegra/clock.h | 17 + arch/arm/include/asm/arch-tegra114/clock-tables.h | 178 +++++---- 7 files changed, 390 insertions(+), 265 deletions(-)
diff --git a/arch/arm/cpu/arm720t/tegra114/cpu.c b/arch/arm/cpu/arm720t/tegra114/cpu.c index 8f7bce4..c8e54b6 100644 --- a/arch/arm/cpu/arm720t/tegra114/cpu.c +++ b/arch/arm/cpu/arm720t/tegra114/cpu.c @@ -152,18 +152,11 @@ void t114_init_clocks(void) clock_set_enable(PERIPH_ID_CACHE2, 1); clock_set_enable(PERIPH_ID_GPIO, 1); clock_set_enable(PERIPH_ID_TMR, 1); - clock_set_enable(PERIPH_ID_RTC, 1); clock_set_enable(PERIPH_ID_CPU, 1); clock_set_enable(PERIPH_ID_EMC, 1); clock_set_enable(PERIPH_ID_I2C5, 1); - clock_set_enable(PERIPH_ID_FUSE, 1); - clock_set_enable(PERIPH_ID_PMC, 1); clock_set_enable(PERIPH_ID_APBDMA, 1); clock_set_enable(PERIPH_ID_MEM, 1); - clock_set_enable(PERIPH_ID_IRAMA, 1); - clock_set_enable(PERIPH_ID_IRAMB, 1); - clock_set_enable(PERIPH_ID_IRAMC, 1); - clock_set_enable(PERIPH_ID_IRAMD, 1); clock_set_enable(PERIPH_ID_CORESIGHT, 1); clock_set_enable(PERIPH_ID_MSELECT, 1); clock_set_enable(PERIPH_ID_EMC1, 1); @@ -192,7 +185,6 @@ void t114_init_clocks(void) reset_set_enable(PERIPH_ID_COP, 0); reset_set_enable(PERIPH_ID_EMC, 0); reset_set_enable(PERIPH_ID_I2C5, 0); - reset_set_enable(PERIPH_ID_FUSE, 0); reset_set_enable(PERIPH_ID_APBDMA, 0); reset_set_enable(PERIPH_ID_MEM, 0); reset_set_enable(PERIPH_ID_CORESIGHT, 0); diff --git a/arch/arm/cpu/tegra-common/clock.c b/arch/arm/cpu/tegra-common/clock.c index 268fb91..62a2191 100644 --- a/arch/arm/cpu/tegra-common/clock.c +++ b/arch/arm/cpu/tegra-common/clock.c @@ -304,13 +304,24 @@ static int adjust_periph_pll(enum periph_id periph_id, int source, /* work out the source clock and set it */ if (source < 0) return -1; - if (mux_bits == 4) { - clrsetbits_le32(reg, OUT_CLK_SOURCE4_MASK, - source << OUT_CLK_SOURCE4_SHIFT); - } else { + + switch (mux_bits) { + case MASK_BITS_31_30: clrsetbits_le32(reg, OUT_CLK_SOURCE_MASK, source << OUT_CLK_SOURCE_SHIFT); + break; + + case MASK_BITS_31_29: + clrsetbits_le32(reg, OUT_CLK_SOURCE3_MASK, + source << OUT_CLK_SOURCE3_SHIFT); + break; + + case MASK_BITS_29_28: + clrsetbits_le32(reg, OUT_CLK_SOURCE4_MASK, + source << OUT_CLK_SOURCE4_SHIFT); + break; } + udelay(2); return 0; } @@ -332,7 +343,7 @@ unsigned clock_adjust_periph_pll_div(enum periph_id periph_id, if (extra_div) *extra_div = xdiv;
- assert(divider >= 0); + assert(divider > 0); if (adjust_periph_pll(periph_id, source, mux_bits, divider)) return -1U; debug("periph %d, rate=%d, reg=%p = %x\n", periph_id, rate, diff --git a/arch/arm/cpu/tegra114-common/clock.c b/arch/arm/cpu/tegra114-common/clock.c index e9a1a80..0626bcd 100644 --- a/arch/arm/cpu/tegra114-common/clock.c +++ b/arch/arm/cpu/tegra114-common/clock.c @@ -46,13 +46,22 @@ enum clock_type_id { CLOCK_TYPE_MCPT, CLOCK_TYPE_PCM, CLOCK_TYPE_PCMT, - CLOCK_TYPE_PCMT16, CLOCK_TYPE_PDCT, CLOCK_TYPE_ACPT, CLOCK_TYPE_ASPTE, CLOCK_TYPE_PMDACD2T, CLOCK_TYPE_PCST,
+ CLOCK_TYPE_PC2CC3M, + CLOCK_TYPE_PC2CC3S_T, + CLOCK_TYPE_PC2CC3M_T, + CLOCK_TYPE_PC2CC3M_T16, /* PC2CC3M_T, but w/16-bit divisor (I2C) */ + CLOCK_TYPE_MC2CC3P_A, + CLOCK_TYPE_M, + CLOCK_TYPE_MCPTM2C2C3, + CLOCK_TYPE_PC2CC3T_S, + CLOCK_TYPE_AC2CC3P_TS2, + CLOCK_TYPE_COUNT, CLOCK_TYPE_NONE = -1, /* invalid clock type */ }; @@ -61,12 +70,6 @@ enum { CLOCK_MAX_MUX = 8 /* number of source options for each clock */ };
-enum { - MASK_BITS_31_30 = 2, /* num of bits used to specify clock source */ - MASK_BITS_31_29, - MASK_BITS_29_28, -}; - /* * Clock source mux for each clock type. This just converts our enum into * a list of mux sources for use by the code. @@ -92,9 +95,6 @@ static enum clock_id clock_source[CLOCK_TYPE_COUNT][CLOCK_MAX_MUX+1] = { { CLK(PERIPH), CLK(CGENERAL), CLK(MEMORY), CLK(OSC), CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), MASK_BITS_31_30}, - { CLK(PERIPH), CLK(CGENERAL), CLK(MEMORY), CLK(OSC), - CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), - MASK_BITS_31_30}, { CLK(PERIPH), CLK(DISPLAY), CLK(CGENERAL), CLK(OSC), CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), MASK_BITS_31_30}, @@ -109,7 +109,45 @@ static enum clock_id clock_source[CLOCK_TYPE_COUNT][CLOCK_MAX_MUX+1] = { MASK_BITS_31_29}, { CLK(PERIPH), CLK(CGENERAL), CLK(SFROM32KHZ), CLK(OSC), CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), - MASK_BITS_29_28} + MASK_BITS_29_28}, + + /* Additional clock types on T114 */ + /* CLOCK_TYPE_PC2CC3M */ + { CLK(PERIPH), CLK(CGENERAL2), CLK(CGENERAL), CLK(CGENERAL3), + CLK(MEMORY), CLK(NONE), CLK(NONE), CLK(NONE), + MASK_BITS_31_29}, + /* CLOCK_TYPE_PC2CC3S_T */ + { CLK(PERIPH), CLK(CGENERAL2), CLK(CGENERAL), CLK(CGENERAL3), + CLK(SFROM32KHZ), CLK(NONE), CLK(OSC), CLK(NONE), + MASK_BITS_31_29}, + /* CLOCK_TYPE_PC2CC3M_T */ + { CLK(PERIPH), CLK(CGENERAL2), CLK(CGENERAL), CLK(CGENERAL3), + CLK(MEMORY), CLK(NONE), CLK(OSC), CLK(NONE), + MASK_BITS_31_29}, + /* CLOCK_TYPE_PC2CC3M_T, w/16-bit divisor (I2C) */ + { CLK(PERIPH), CLK(CGENERAL2), CLK(CGENERAL), CLK(CGENERAL3), + CLK(MEMORY), CLK(NONE), CLK(OSC), CLK(NONE), + MASK_BITS_31_29}, + /* CLOCK_TYPE_MC2CC3P_A */ + { CLK(MEMORY), CLK(CGENERAL2), CLK(CGENERAL), CLK(CGENERAL3), + CLK(PERIPH), CLK(NONE), CLK(AUDIO), CLK(NONE), + MASK_BITS_31_29}, + /* CLOCK_TYPE_M */ + { CLK(MEMORY), CLK(NONE), CLK(NONE), CLK(NONE), + CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), + MASK_BITS_31_30}, + /* CLOCK_TYPE_MCPTM2C2C3 */ + { CLK(MEMORY), CLK(CGENERAL), CLK(PERIPH), CLK(OSC), + CLK(MEMORY2), CLK(CGENERAL2), CLK(CGENERAL3), CLK(NONE), + MASK_BITS_31_29}, + /* CLOCK_TYPE_PC2CC3T_S */ + { CLK(PERIPH), CLK(CGENERAL2), CLK(CGENERAL), CLK(CGENERAL3), + CLK(OSC), CLK(NONE), CLK(SFROM32KHZ), CLK(NONE), + MASK_BITS_31_29}, + /* CLOCK_TYPE_AC2CC3P_TS2 */ + { CLK(AUDIO), CLK(CGENERAL2), CLK(CGENERAL), CLK(CGENERAL3), + CLK(PERIPH), CLK(NONE), CLK(OSC), CLK(SRC2), + MASK_BITS_31_29}, };
/* @@ -122,110 +160,120 @@ static enum clock_type_id clock_periph_type[PERIPHC_COUNT] = { TYPE(PERIPHC_I2S1, CLOCK_TYPE_AXPT), TYPE(PERIPHC_I2S2, CLOCK_TYPE_AXPT), TYPE(PERIPHC_SPDIF_OUT, CLOCK_TYPE_AXPT), - TYPE(PERIPHC_SPDIF_IN, CLOCK_TYPE_PCM), - TYPE(PERIPHC_PWM, CLOCK_TYPE_PCST), /* only PWM uses b29:28 */ - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_SBC2, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_SBC3, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_SPDIF_IN, CLOCK_TYPE_PC2CC3M), + TYPE(PERIPHC_PWM, CLOCK_TYPE_PC2CC3S_T), + TYPE(PERIPHC_05h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_SBC2, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_SBC3, CLOCK_TYPE_PC2CC3M_T),
/* 0x08 */ - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_I2C1, CLOCK_TYPE_PCMT16), - TYPE(PERIPHC_I2C5, CLOCK_TYPE_PCMT16), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_SBC1, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_08h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_I2C1, CLOCK_TYPE_PC2CC3M_T16), + TYPE(PERIPHC_I2C5, CLOCK_TYPE_PC2CC3M_T16), + TYPE(PERIPHC_0bh, CLOCK_TYPE_NONE), + TYPE(PERIPHC_0ch, CLOCK_TYPE_NONE), + TYPE(PERIPHC_SBC1, CLOCK_TYPE_PC2CC3M_T), TYPE(PERIPHC_DISP1, CLOCK_TYPE_PMDACD2T), TYPE(PERIPHC_DISP2, CLOCK_TYPE_PMDACD2T),
/* 0x10 */ - TYPE(PERIPHC_CVE, CLOCK_TYPE_PDCT), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_VI, CLOCK_TYPE_MCPA), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_SDMMC1, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_SDMMC2, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_G3D, CLOCK_TYPE_MCPA), - TYPE(PERIPHC_G2D, CLOCK_TYPE_MCPA), + TYPE(PERIPHC_10h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_11h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_VI, CLOCK_TYPE_MC2CC3P_A), + TYPE(PERIPHC_13h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_SDMMC1, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_SDMMC2, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_G3D, CLOCK_TYPE_MC2CC3P_A), + TYPE(PERIPHC_G2D, CLOCK_TYPE_MC2CC3P_A),
/* 0x18 */ - TYPE(PERIPHC_NDFLASH, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_SDMMC4, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_VFIR, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_EPP, CLOCK_TYPE_MCPA), - TYPE(PERIPHC_MPE, CLOCK_TYPE_MCPA), - TYPE(PERIPHC_MIPI, CLOCK_TYPE_PCMT), /* MIPI base-band HSI */ - TYPE(PERIPHC_UART1, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_UART2, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_NDFLASH, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_SDMMC4, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_VFIR, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_EPP, CLOCK_TYPE_MC2CC3P_A), + TYPE(PERIPHC_MPE, CLOCK_TYPE_M), + TYPE(PERIPHC_HSI, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_UART1, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_UART2, CLOCK_TYPE_PC2CC3M_T),
/* 0x20 */ - TYPE(PERIPHC_HOST1X, CLOCK_TYPE_MCPA), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_TVO, CLOCK_TYPE_PDCT), + TYPE(PERIPHC_HOST1X, CLOCK_TYPE_MC2CC3P_A), + TYPE(PERIPHC_21h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_22h, CLOCK_TYPE_NONE), TYPE(PERIPHC_HDMI, CLOCK_TYPE_PMDACD2T), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_TVDAC, CLOCK_TYPE_PDCT), - TYPE(PERIPHC_I2C2, CLOCK_TYPE_PCMT16), - TYPE(PERIPHC_EMC, CLOCK_TYPE_MCPT), + TYPE(PERIPHC_24h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_25h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_I2C2, CLOCK_TYPE_PC2CC3M_T16), + TYPE(PERIPHC_EMC, CLOCK_TYPE_MCPTM2C2C3),
/* 0x28 */ - TYPE(PERIPHC_UART3, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_VI, CLOCK_TYPE_MCPA), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_SBC4, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_I2C3, CLOCK_TYPE_PCMT16), - TYPE(PERIPHC_SDMMC3, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_UART3, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_29h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_VI_SENSOR, CLOCK_TYPE_MC2CC3P_A), + TYPE(PERIPHC_2bh, CLOCK_TYPE_NONE), + TYPE(PERIPHC_2ch, CLOCK_TYPE_NONE), + TYPE(PERIPHC_SBC4, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_I2C3, CLOCK_TYPE_PC2CC3M_T16), + TYPE(PERIPHC_SDMMC3, CLOCK_TYPE_PC2CC3M_T),
/* 0x30 */ - TYPE(PERIPHC_UART4, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_UART5, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_VDE, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_OWR, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_NOR, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_CSITE, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_I2S0, CLOCK_TYPE_AXPT), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - - /* 0x38h */ /* Jumps to reg offset 0x3B0h */ - TYPE(PERIPHC_G3D2, CLOCK_TYPE_MCPA), - TYPE(PERIPHC_MSELECT, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_TSENSOR, CLOCK_TYPE_PCST), /* s/b PCTS */ + TYPE(PERIPHC_UART4, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_UART5, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_VDE, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_OWR, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_NOR, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_CSITE, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_I2S0, CLOCK_TYPE_AXPT), + TYPE(PERIPHC_DTV, CLOCK_TYPE_NONE), + + /* 0x38 */ + TYPE(PERIPHC_38h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_39h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_3ah, CLOCK_TYPE_NONE), + TYPE(PERIPHC_3bh, CLOCK_TYPE_NONE), + TYPE(PERIPHC_MSENC, CLOCK_TYPE_MC2CC3P_A), + TYPE(PERIPHC_TSEC, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_3eh, CLOCK_TYPE_NONE), + TYPE(PERIPHC_OSC, CLOCK_TYPE_NONE), + + /* 0x40 */ + TYPE(PERIPHC_G3D2, CLOCK_TYPE_MC2CC3P_A), /* start with 0x3b0 */ + TYPE(PERIPHC_MSELECT, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_TSENSOR, CLOCK_TYPE_PC2CC3T_S), TYPE(PERIPHC_I2S3, CLOCK_TYPE_AXPT), TYPE(PERIPHC_I2S4, CLOCK_TYPE_AXPT), - TYPE(PERIPHC_I2C4, CLOCK_TYPE_PCMT16), - TYPE(PERIPHC_SBC5, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_SBC6, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_I2C4, CLOCK_TYPE_PC2CC3M_T16), + TYPE(PERIPHC_SBC5, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_SBC6, CLOCK_TYPE_PC2CC3M_T),
- /* 0x40 */ - TYPE(PERIPHC_AUDIO, CLOCK_TYPE_ACPT), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_DAM0, CLOCK_TYPE_ACPT), - TYPE(PERIPHC_DAM1, CLOCK_TYPE_ACPT), - TYPE(PERIPHC_DAM2, CLOCK_TYPE_ACPT), - TYPE(PERIPHC_HDA2CODEC2X, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_ACTMON, CLOCK_TYPE_PCST), /* MASK 31:30 */ + /* 0x48 */ + TYPE(PERIPHC_AUDIO, CLOCK_TYPE_AC2CC3P_TS2), + TYPE(PERIPHC_49h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_DAM0, CLOCK_TYPE_AC2CC3P_TS2), + TYPE(PERIPHC_DAM1, CLOCK_TYPE_AC2CC3P_TS2), + TYPE(PERIPHC_DAM2, CLOCK_TYPE_AC2CC3P_TS2), + TYPE(PERIPHC_HDA2CODEC2X, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_ACTMON, CLOCK_TYPE_PC2CC3S_T), TYPE(PERIPHC_EXTPERIPH1, CLOCK_TYPE_ASPTE),
- /* 0x48 */ + /* 0x50 */ TYPE(PERIPHC_EXTPERIPH2, CLOCK_TYPE_ASPTE), TYPE(PERIPHC_EXTPERIPH3, CLOCK_TYPE_ASPTE), - TYPE(PERIPHC_NANDSPEED, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_I2CSLOW, CLOCK_TYPE_PCST), /* MASK 31:30 */ + TYPE(PERIPHC_NANDSPEED, CLOCK_TYPE_PC2CC3M_T), + TYPE(PERIPHC_I2CSLOW, CLOCK_TYPE_PC2CC3S_T), TYPE(PERIPHC_SYS, CLOCK_TYPE_NONE), - TYPE(PERIPHC_SPEEDO, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - - /* 0x50 */ - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_NONE, CLOCK_TYPE_NONE), - TYPE(PERIPHC_SATAOOB, CLOCK_TYPE_PCMT), /* offset 0x420h */ + TYPE(PERIPHC_55h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_56h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_57h, CLOCK_TYPE_NONE), + + /* 0x58 */ + TYPE(PERIPHC_58h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_59h, CLOCK_TYPE_NONE), + TYPE(PERIPHC_5ah, CLOCK_TYPE_NONE), + TYPE(PERIPHC_5bh, CLOCK_TYPE_NONE), + TYPE(PERIPHC_SATAOOB, CLOCK_TYPE_PCMT), TYPE(PERIPHC_SATA, CLOCK_TYPE_PCMT), - TYPE(PERIPHC_HDA, CLOCK_TYPE_PCMT), + TYPE(PERIPHC_HDA, CLOCK_TYPE_PC2CC3M_T), };
/* @@ -244,7 +292,7 @@ static s8 periph_id_to_internal_id[PERIPH_ID_COUNT] = { NONE(COP), NONE(TRIGSYS), NONE(RESERVED3), - NONE(RTC), + NONE(RESERVED4), NONE(TMR), PERIPHC_UART1, PERIPHC_UART2, /* and vfir 0x68 */ @@ -252,7 +300,7 @@ static s8 periph_id_to_internal_id[PERIPH_ID_COUNT] = { /* 8 */ NONE(GPIO), PERIPHC_SDMMC2, - NONE(SPDIF), /* 0x08 and 0x0c, unclear which to use */ + PERIPHC_SPDIF_IN, PERIPHC_I2S1, PERIPHC_I2C1, PERIPHC_NDFLASH, @@ -291,7 +339,7 @@ static s8 periph_id_to_internal_id[PERIPH_ID_COUNT] = {
/* 40 */ NONE(KFUSE), - NONE(SBC1), /* SBC1, 0x34, is this SPI1? */ + NONE(SBC1), /* SBC1, SPI1 */ PERIPHC_NOR, NONE(RESERVED43), PERIPHC_SBC2, @@ -301,16 +349,16 @@ static s8 periph_id_to_internal_id[PERIPH_ID_COUNT] = {
/* 48 */ NONE(DSI), - PERIPHC_TVO, /* also CVE 0x40 */ - PERIPHC_MIPI, + NONE(RESERVED49), + PERIPHC_HSI, PERIPHC_HDMI, NONE(CSI), - PERIPHC_TVDAC, + NONE(RESERVED53), PERIPHC_I2C2, PERIPHC_UART3,
/* 56 */ - NONE(RESERVED56), + NONE(MIPI_CAL), PERIPHC_EMC, NONE(USB2), NONE(USB3), @@ -320,7 +368,7 @@ static s8 periph_id_to_internal_id[PERIPH_ID_COUNT] = { NONE(BSEV),
/* Upper word 95:64 */ - PERIPHC_SPEEDO, + NONE(RESERVED64), PERIPHC_UART4, PERIPHC_UART5, PERIPHC_I2C3, @@ -335,41 +383,41 @@ static s8 periph_id_to_internal_id[PERIPH_ID_COUNT] = { NONE(PCIEXCLK), NONE(AVPUCQ), NONE(RESERVED76), - NONE(RESERVED77), - NONE(RESERVED78), + NONE(TRACECLKIN), + NONE(SOC_THERM), NONE(DTV),
/* 80 */ PERIPHC_NANDSPEED, PERIPHC_I2CSLOW, NONE(DSIB), - NONE(RESERVED83), - NONE(IRAMA), - NONE(IRAMB), - NONE(IRAMC), - NONE(IRAMD), + PERIPHC_TSEC, + NONE(RESERVED84), + NONE(RESERVED85), + NONE(RESERVED86), + NONE(EMUCIF),
/* 88 */ - NONE(CRAM2), - NONE(RESERVED89), - NONE(MDOUBLER), - NONE(RESERVED91), - NONE(SUSOUT), + NONE(RESERVED88), + NONE(XUSB_HOST), + NONE(RESERVED90), + PERIPHC_MSENC, + NONE(RESERVED92), NONE(RESERVED93), NONE(RESERVED94), - NONE(RESERVED95), + NONE(XUSB_DEV),
/* V word: 31:0 */ NONE(CPUG), NONE(CPULP), PERIPHC_G3D2, PERIPHC_MSELECT, - PERIPHC_TSENSOR, + NONE(V_RESERVED4), PERIPHC_I2S3, PERIPHC_I2S4, PERIPHC_I2C4,
- /* 08 */ + /* 104 */ PERIPHC_SBC5, PERIPHC_SBC6, PERIPHC_AUDIO, @@ -379,63 +427,63 @@ static s8 periph_id_to_internal_id[PERIPH_ID_COUNT] = { PERIPHC_DAM2, PERIPHC_HDA2CODEC2X,
- /* 16 */ + /* 112 */ NONE(ATOMICS), - NONE(RESERVED17), - NONE(RESERVED18), - NONE(RESERVED19), - NONE(RESERVED20), - NONE(RESERVED21), - NONE(RESERVED22), + NONE(V_RESERVED17), + NONE(V_RESERVED18), + NONE(V_RESERVED19), + NONE(V_RESERVED20), + NONE(V_RESERVED21), + NONE(V_RESERVED22), PERIPHC_ACTMON,
- /* 24 */ - NONE(RESERVED24), - NONE(RESERVED25), - NONE(RESERVED26), - NONE(RESERVED27), + /* 120 */ + NONE(V_RESERVED24), + NONE(V_RESERVED25), + NONE(V_RESERVED26), + NONE(V_RESERVED27), PERIPHC_SATA, PERIPHC_HDA, - NONE(RESERVED30), - NONE(RESERVED31), + NONE(V_RESERVED30), + NONE(V_RESERVED31),
/* W word: 31:0 */ NONE(HDA2HDMICODEC), - NONE(RESERVED1_SATACOLD), - NONE(RESERVED2_PCIERX0), - NONE(RESERVED3_PCIERX1), - NONE(RESERVED4_PCIERX2), - NONE(RESERVED5_PCIERX3), - NONE(RESERVED6_PCIERX4), - NONE(RESERVED7_PCIERX5), - - /* 40 */ + NONE(SATACOLD), + NONE(W_RESERVED2), + NONE(W_RESERVED3), + NONE(W_RESERVED4), + NONE(W_RESERVED5), + NONE(W_RESERVED6), + NONE(W_RESERVED7), + + /* 136 */ NONE(CEC), - NONE(PCIE2_IOBIST), - NONE(EMC_IOBIST), - NONE(HDMI_IOBIST), - NONE(SATA_IOBIST), - NONE(MIPI_IOBIST), - NONE(EMC1_IOBIST), - NONE(XUSB), - - /* 48 */ - NONE(CILAB), - NONE(CILCD), - NONE(CILE), - NONE(DSIA_LP), - NONE(DSIB_LP), - NONE(RESERVED21_ENTROPY), - NONE(RESERVED22_W), - NONE(RESERVED23_W), - - /* 56 */ - NONE(RESERVED24_W), + NONE(W_RESERVED9), + NONE(W_RESERVED10), + NONE(W_RESERVED11), + NONE(W_RESERVED12), + NONE(W_RESERVED13), + NONE(XUSB_PADCTL), + NONE(W_RESERVED15), + + /* 144 */ + NONE(W_RESERVED16), + NONE(W_RESERVED17), + NONE(W_RESERVED18), + NONE(W_RESERVED19), + NONE(W_RESERVED20), + NONE(ENTROPY), + NONE(W_RESERVED22), + NONE(W_RESERVED23), + + /* 152 */ + NONE(W_RESERVED24), NONE(AMX0), NONE(ADX0), NONE(DVFS), NONE(XUSB_SS), - NONE(EMC_DLL), + NONE(W_RESERVED29), NONE(MC1), NONE(EMC1), }; @@ -510,7 +558,7 @@ int get_periph_clock_source(enum periph_id periph_id,
*mux_bits = clock_source[type][CLOCK_MAX_MUX];
- if (type == CLOCK_TYPE_PCMT16) + if (type == CLOCK_TYPE_PC2CC3M_T16) *divider_bits = 16; else *divider_bits = 8; @@ -583,21 +631,61 @@ enum periph_id clk_id_to_periph_id(int clk_id)
switch (clk_id) { case PERIPH_ID_RESERVED3: + case PERIPH_ID_RESERVED4: case PERIPH_ID_RESERVED16: - case PERIPH_ID_RESERVED24: + case PERIPH_ID_RESERVED25: case PERIPH_ID_RESERVED35: + case PERIPH_ID_RESERVED36: + case PERIPH_ID_RESERVED38: + case PERIPH_ID_RESERVED39: case PERIPH_ID_RESERVED43: case PERIPH_ID_RESERVED45: - case PERIPH_ID_RESERVED56: + case PERIPH_ID_RESERVED49: + case PERIPH_ID_RESERVED53: + case PERIPH_ID_RESERVED64: case PERIPH_ID_RESERVED76: - case PERIPH_ID_RESERVED77: - case PERIPH_ID_RESERVED78: - case PERIPH_ID_RESERVED83: - case PERIPH_ID_RESERVED89: - case PERIPH_ID_RESERVED91: + case PERIPH_ID_RESERVED84: + case PERIPH_ID_RESERVED85: + case PERIPH_ID_RESERVED86: + case PERIPH_ID_RESERVED88: + case PERIPH_ID_RESERVED90: + case PERIPH_ID_RESERVED92: case PERIPH_ID_RESERVED93: case PERIPH_ID_RESERVED94: - case PERIPH_ID_RESERVED95: + case PERIPH_ID_V_RESERVED4: + case PERIPH_ID_V_RESERVED17: + case PERIPH_ID_V_RESERVED18: + case PERIPH_ID_V_RESERVED19: + case PERIPH_ID_V_RESERVED20: + case PERIPH_ID_V_RESERVED21: + case PERIPH_ID_V_RESERVED22: + case PERIPH_ID_V_RESERVED24: + case PERIPH_ID_V_RESERVED25: + case PERIPH_ID_V_RESERVED26: + case PERIPH_ID_V_RESERVED27: + case PERIPH_ID_V_RESERVED30: + case PERIPH_ID_V_RESERVED31: + case PERIPH_ID_W_RESERVED2: + case PERIPH_ID_W_RESERVED3: + case PERIPH_ID_W_RESERVED4: + case PERIPH_ID_W_RESERVED5: + case PERIPH_ID_W_RESERVED6: + case PERIPH_ID_W_RESERVED7: + case PERIPH_ID_W_RESERVED9: + case PERIPH_ID_W_RESERVED10: + case PERIPH_ID_W_RESERVED11: + case PERIPH_ID_W_RESERVED12: + case PERIPH_ID_W_RESERVED13: + case PERIPH_ID_W_RESERVED15: + case PERIPH_ID_W_RESERVED16: + case PERIPH_ID_W_RESERVED17: + case PERIPH_ID_W_RESERVED18: + case PERIPH_ID_W_RESERVED19: + case PERIPH_ID_W_RESERVED20: + case PERIPH_ID_W_RESERVED22: + case PERIPH_ID_W_RESERVED23: + case PERIPH_ID_W_RESERVED24: + case PERIPH_ID_W_RESERVED29: return PERIPH_ID_NONE; default: return clk_id; diff --git a/arch/arm/cpu/tegra30-common/clock.c b/arch/arm/cpu/tegra30-common/clock.c index 74bd22b..89c3529 100644 --- a/arch/arm/cpu/tegra30-common/clock.c +++ b/arch/arm/cpu/tegra30-common/clock.c @@ -60,12 +60,6 @@ enum { CLOCK_MAX_MUX = 8 /* number of source options for each clock */ };
-enum { - MASK_BITS_31_30 = 2, /* num of bits used to specify clock source */ - MASK_BITS_31_29, - MASK_BITS_29_28, -}; - /* * Clock source mux for each clock type. This just converts our enum into * a list of mux sources for use by the code. diff --git a/arch/arm/include/asm/arch-tegra/clk_rst.h b/arch/arm/include/asm/arch-tegra/clk_rst.h index a4c17e7..8200090 100644 --- a/arch/arm/include/asm/arch-tegra/clk_rst.h +++ b/arch/arm/include/asm/arch-tegra/clk_rst.h @@ -243,6 +243,9 @@ enum { #define OUT_CLK_SOURCE_SHIFT 30 #define OUT_CLK_SOURCE_MASK (3U << OUT_CLK_SOURCE_SHIFT)
+#define OUT_CLK_SOURCE3_SHIFT 29 +#define OUT_CLK_SOURCE3_MASK (7U << OUT_CLK_SOURCE3_SHIFT) + #define OUT_CLK_SOURCE4_SHIFT 28 #define OUT_CLK_SOURCE4_MASK (15U << OUT_CLK_SOURCE4_SHIFT)
diff --git a/arch/arm/include/asm/arch-tegra/clock.h b/arch/arm/include/asm/arch-tegra/clock.h index c3174bd..9495179 100644 --- a/arch/arm/include/asm/arch-tegra/clock.h +++ b/arch/arm/include/asm/arch-tegra/clock.h @@ -20,6 +20,12 @@ enum clock_osc_freq { CLOCK_OSC_FREQ_COUNT, };
+enum { + MASK_BITS_31_30 = 2, /* num of bits used to specify clock source */ + MASK_BITS_31_29, + MASK_BITS_29_28, +}; + #include <asm/arch/clock-tables.h> /* PLL stabilization delay in usec */ #define CLOCK_PLL_STABLE_DELAY_US 300 @@ -305,4 +311,15 @@ int clock_set_rate(enum clock_id clkid, u32 n, u32 m, u32 p, u32 cpcon); /* SoC-specific TSC init */ void arch_timer_init(void);
+/** + * Enable a peripheral clock with a certain clock source/divisor + * + * @param periph_id peripheral to enable/change + * @param src PLL id of required parent clock + * @param divisor required integer divisor (not 7.1) + * @return 0 if ok + * -1 on error (bad divisor, etc.). + */ +int clock_periph_enable(enum periph_id pid, int src, int divisor); + #endif /* _TEGRA_CLOCK_H_ */ diff --git a/arch/arm/include/asm/arch-tegra114/clock-tables.h b/arch/arm/include/asm/arch-tegra114/clock-tables.h index d8fa0e1..19b8acf 100644 --- a/arch/arm/include/asm/arch-tegra114/clock-tables.h +++ b/arch/arm/include/asm/arch-tegra114/clock-tables.h @@ -40,7 +40,17 @@ enum clock_id { CLOCK_ID_OSC,
CLOCK_ID_COUNT, /* number of PLLs */ - CLOCK_ID_DISPLAY2, /* placeholder */ + + /* + * These are clock ids that are used in table clock_source[][] + * but will not be assigned as a clock source for any peripheral. + */ + CLOCK_ID_DISPLAY2, + CLOCK_ID_CGENERAL2, + CLOCK_ID_CGENERAL3, + CLOCK_ID_MEMORY2, + CLOCK_ID_SRC2, + CLOCK_ID_NONE = -1, };
@@ -53,7 +63,7 @@ enum periph_id { PERIPH_ID_COP, PERIPH_ID_TRIGSYS, PERIPH_ID_RESERVED3, - PERIPH_ID_RTC, + PERIPH_ID_RESERVED4, PERIPH_ID_TMR, PERIPH_ID_UART1, PERIPH_ID_UART2, @@ -80,7 +90,7 @@ enum periph_id {
/* 24 */ PERIPH_ID_3D, - PERIPH_ID_RESERVED24, + PERIPH_ID_RESERVED25, PERIPH_ID_DISP2, PERIPH_ID_DISP1, PERIPH_ID_HOST1X, @@ -93,10 +103,10 @@ enum periph_id { PERIPH_ID_AHBDMA, PERIPH_ID_APBDMA, PERIPH_ID_RESERVED35, - PERIPH_ID_KBC, + PERIPH_ID_RESERVED36, PERIPH_ID_STAT_MON, - PERIPH_ID_PMC, - PERIPH_ID_FUSE, + PERIPH_ID_RESERVED38, + PERIPH_ID_RESERVED39,
/* 40 */ PERIPH_ID_KFUSE, @@ -110,16 +120,16 @@ enum periph_id {
/* 48 */ PERIPH_ID_DSI, - PERIPH_ID_TVO, - PERIPH_ID_MIPI, + PERIPH_ID_RESERVED49, + PERIPH_ID_HSI, PERIPH_ID_HDMI, PERIPH_ID_CSI, - PERIPH_ID_TVDAC, + PERIPH_ID_RESERVED53, PERIPH_ID_I2C2, PERIPH_ID_UART3,
/* 56 */ - PERIPH_ID_RESERVED56, + PERIPH_ID_MIPI_CAL, PERIPH_ID_EMC, PERIPH_ID_USB2, PERIPH_ID_USB3, @@ -129,7 +139,7 @@ enum periph_id { PERIPH_ID_BSEV,
/* Upper word 95:64 (DEVICES_U) */ - PERIPH_ID_SPEEDO, + PERIPH_ID_RESERVED64, PERIPH_ID_UART4, PERIPH_ID_UART5, PERIPH_ID_I2C3, @@ -144,29 +154,29 @@ enum periph_id { PERIPH_ID_PCIEXCLK, PERIPH_ID_AVPUCQ, PERIPH_ID_RESERVED76, - PERIPH_ID_RESERVED77, - PERIPH_ID_RESERVED78, + PERIPH_ID_TRACECLKIN, + PERIPH_ID_SOC_THERM, PERIPH_ID_DTV,
/* 80 */ PERIPH_ID_NANDSPEED, PERIPH_ID_I2CSLOW, PERIPH_ID_DSIB, - PERIPH_ID_RESERVED83, - PERIPH_ID_IRAMA, - PERIPH_ID_IRAMB, - PERIPH_ID_IRAMC, - PERIPH_ID_IRAMD, + PERIPH_ID_TSEC, + PERIPH_ID_RESERVED84, + PERIPH_ID_RESERVED85, + PERIPH_ID_RESERVED86, + PERIPH_ID_EMUCIF,
/* 88 */ - PERIPH_ID_CRAM2, - PERIPH_ID_RESERVED89, - PERIPH_ID_MDOUBLER, - PERIPH_ID_RESERVED91, - PERIPH_ID_SUSOUT, + PERIPH_ID_RESERVED88, + PERIPH_ID_XUSB_HOST, + PERIPH_ID_RESERVED90, + PERIPH_ID_MSENC, + PERIPH_ID_RESERVED92, PERIPH_ID_RESERVED93, PERIPH_ID_RESERVED94, - PERIPH_ID_RESERVED95, + PERIPH_ID_XUSB_DEV,
PERIPH_ID_VW_FIRST, /* V word: 31:0 */ @@ -174,7 +184,7 @@ enum periph_id { PERIPH_ID_CPULP, PERIPH_ID_3D2, PERIPH_ID_MSELECT, - PERIPH_ID_TSENSOR, + PERIPH_ID_V_RESERVED4, PERIPH_ID_I2S3, PERIPH_ID_I2S4, PERIPH_ID_I2C4, @@ -191,61 +201,61 @@ enum periph_id {
/* 112 */ PERIPH_ID_ATOMICS, - PERIPH_ID_EX_RESERVED17, - PERIPH_ID_EX_RESERVED18, - PERIPH_ID_EX_RESERVED19, - PERIPH_ID_EX_RESERVED20, - PERIPH_ID_EX_RESERVED21, - PERIPH_ID_EX_RESERVED22, + PERIPH_ID_V_RESERVED17, + PERIPH_ID_V_RESERVED18, + PERIPH_ID_V_RESERVED19, + PERIPH_ID_V_RESERVED20, + PERIPH_ID_V_RESERVED21, + PERIPH_ID_V_RESERVED22, PERIPH_ID_ACTMON,
/* 120 */ - PERIPH_ID_EX_RESERVED24, - PERIPH_ID_EX_RESERVED25, - PERIPH_ID_EX_RESERVED26, - PERIPH_ID_EX_RESERVED27, + PERIPH_ID_V_RESERVED24, + PERIPH_ID_V_RESERVED25, + PERIPH_ID_V_RESERVED26, + PERIPH_ID_V_RESERVED27, PERIPH_ID_SATA, PERIPH_ID_HDA, - PERIPH_ID_EX_RESERVED30, - PERIPH_ID_EX_RESERVED31, + PERIPH_ID_V_RESERVED30, + PERIPH_ID_V_RESERVED31,
/* W word: 31:0 */ PERIPH_ID_HDA2HDMICODEC, - PERIPH_ID_RESERVED1_SATACOLD, - PERIPH_ID_RESERVED2_PCIERX0, - PERIPH_ID_RESERVED3_PCIERX1, - PERIPH_ID_RESERVED4_PCIERX2, - PERIPH_ID_RESERVED5_PCIERX3, - PERIPH_ID_RESERVED6_PCIERX4, - PERIPH_ID_RESERVED7_PCIERX5, + PERIPH_ID_SATACOLD, + PERIPH_ID_W_RESERVED2, + PERIPH_ID_W_RESERVED3, + PERIPH_ID_W_RESERVED4, + PERIPH_ID_W_RESERVED5, + PERIPH_ID_W_RESERVED6, + PERIPH_ID_W_RESERVED7,
/* 136 */ PERIPH_ID_CEC, - PERIPH_ID_PCIE2_IOBIST, - PERIPH_ID_EMC_IOBIST, - PERIPH_ID_HDMI_IOBIST, - PERIPH_ID_SATA_IOBIST, - PERIPH_ID_MIPI_IOBIST, - PERIPH_ID_EMC1_IOBIST, - PERIPH_ID_XUSB, + PERIPH_ID_W_RESERVED9, + PERIPH_ID_W_RESERVED10, + PERIPH_ID_W_RESERVED11, + PERIPH_ID_W_RESERVED12, + PERIPH_ID_W_RESERVED13, + PERIPH_ID_XUSB_PADCTL, + PERIPH_ID_W_RESERVED15,
/* 144 */ - PERIPH_ID_CILAB, - PERIPH_ID_CILCD, - PERIPH_ID_CILE, - PERIPH_ID_DSIA_LP, - PERIPH_ID_DSIB_LP, - PERIPH_ID_RESERVED21_ENTROPY, - PERIPH_ID_RESERVED22_W, - PERIPH_ID_RESERVED23_W, + PERIPH_ID_W_RESERVED16, + PERIPH_ID_W_RESERVED17, + PERIPH_ID_W_RESERVED18, + PERIPH_ID_W_RESERVED19, + PERIPH_ID_W_RESERVED20, + PERIPH_ID_ENTROPY, + PERIPH_ID_W_RESERVED22, + PERIPH_ID_W_RESERVED23,
/* 152 */ - PERIPH_ID_RESERVED24_W, + PERIPH_ID_W_RESERVED24, PERIPH_ID_AMX0, PERIPH_ID_ADX0, PERIPH_ID_DVFS, PERIPH_ID_XUSB_SS, - PERIPH_ID_EMC_DLL, + PERIPH_ID_W_RESERVED29, PERIPH_ID_MC1, PERIPH_ID_EMC1,
@@ -290,7 +300,7 @@ enum periphc_internal_id { PERIPHC_DISP2,
/* 0x10 */ - PERIPHC_CVE, + PERIPHC_10h, PERIPHC_11h, PERIPHC_VI, PERIPHC_13h, @@ -305,17 +315,17 @@ enum periphc_internal_id { PERIPHC_VFIR, PERIPHC_EPP, PERIPHC_MPE, - PERIPHC_MIPI, + PERIPHC_HSI, PERIPHC_UART1, PERIPHC_UART2,
/* 0x20 */ PERIPHC_HOST1X, PERIPHC_21h, - PERIPHC_TVO, + PERIPHC_22h, PERIPHC_HDMI, PERIPHC_24h, - PERIPHC_TVDAC, + PERIPHC_25h, PERIPHC_I2C2, PERIPHC_EMC,
@@ -337,10 +347,20 @@ enum periphc_internal_id { PERIPHC_NOR, PERIPHC_CSITE, PERIPHC_I2S0, - PERIPHC_37h, + PERIPHC_DTV,
- PERIPHC_VW_FIRST, /* 0x38 */ + PERIPHC_38h, + PERIPHC_39h, + PERIPHC_3ah, + PERIPHC_3bh, + PERIPHC_MSENC, + PERIPHC_TSEC, + PERIPHC_3eh, + PERIPHC_OSC, + + PERIPHC_VW_FIRST, + /* 0x40 */ PERIPHC_G3D2 = PERIPHC_VW_FIRST, PERIPHC_MSELECT, PERIPHC_TSENSOR, @@ -350,9 +370,9 @@ enum periphc_internal_id { PERIPHC_SBC5, PERIPHC_SBC6,
- /* 0x40 */ + /* 0x48 */ PERIPHC_AUDIO, - PERIPHC_41h, + PERIPHC_49h, PERIPHC_DAM0, PERIPHC_DAM1, PERIPHC_DAM2, @@ -360,21 +380,21 @@ enum periphc_internal_id { PERIPHC_ACTMON, PERIPHC_EXTPERIPH1,
- /* 0x48 */ + /* 0x50 */ PERIPHC_EXTPERIPH2, PERIPHC_EXTPERIPH3, PERIPHC_NANDSPEED, PERIPHC_I2CSLOW, PERIPHC_SYS, - PERIPHC_SPEEDO, - PERIPHC_4eh, - PERIPHC_4fh, - - /* 0x50 */ - PERIPHC_50h, - PERIPHC_51h, - PERIPHC_52h, - PERIPHC_53h, + PERIPHC_55h, + PERIPHC_56h, + PERIPHC_57h, + + /* 0x58 */ + PERIPHC_58h, + PERIPHC_59h, + PERIPHC_5ah, + PERIPHC_5bh, PERIPHC_SATAOOB, PERIPHC_SATA, PERIPHC_HDA,
I would really like Peter De Schrijver to review this patch, since he wrote the upstream Tegra124 clock driver, which involved a lot of driver unification with previous SoCs. I'd like him to take a look at the mux mask widths in particular, w.r.t. making sure that U-Boot, the kernel, and the TRM all agree on which peripherals have which size mux field.
In particular, clk-tegra-periph.c in Peter's patches contains clocks with mux fields in bits 31:30 or bits 31:29; there is no clock with a mux field in bits 31:28. Yet, OUT_CLK_SOURCE4_* in U-Boot (before this patch) represent a mux field in bits 31:28. If this is wrong, I believe we need to fix it before applying this patch. If the TRM is wrong, we need to file a bug agaist it.
As I mentioned in the response I just sent to V1, removing things seems like it should be in a separate patch, so each patch does just one logical thing.
mux_bits is a parameter to this function. I don't see this patch changing the way this function is called, so I have to assume that the same values are passed to the function before and after this patch. Based on the switch statement that's added below, I assume that the defines MASK_BITS_* are passed into this function as mux_bits.
In that case, the "4" in that if expression means MASK_BITS_29_28. However, OUT_CLK_SOURCE4_MASK/SHIFT means a mask in bits 31:28. Perhaps the "4" wasn't originally meant to indicate "number of bits in mux field", but rather "number of possible values representable in the mux field"?
While this may be a pre-existing issue, I believe it is imperative that we fix this before confusing the matter further by building more patches on top of it.
- } else {
- switch (mux_bits) {
- case MASK_BITS_31_30: clrsetbits_le32(reg, OUT_CLK_SOURCE_MASK, source << OUT_CLK_SOURCE_SHIFT);
OUT_CLK_SOURCE_* do indeed represent a mask/shift for bits 31:30, so that's probably OK.
break;
- case MASK_BITS_31_29:
OUT_CLK_SOURCE3_* do indeed represent a mask/shift for bits 31:30, so that's probably OK.
break;
- case MASK_BITS_29_28:
OUT_CLK_SOURCE4_* do NOT represent a mask/shift for bits 29:28, but rather for bits 31:28. Again, I think the meaning, value, and name of MASK_BITS_29_28 and OUT_CLK_SOURCE4_* need to be fixed and made consistent prior to this patch.
I would also suggest making separate patches for the following so they're all much simpler:
* Removing clock definitions.
* Removing reset twiddling for some clocks.
* The assert fix.
* Updating adjust_periph_pll() to support different mux mask location/size.
* Adding new clocks that rely on the the new mux mask location/size. Or, perhaps just adding new clocks, period.
v2:
- assert(divider > 0); if (adjust_periph_pll(periph_id, source, mux_bits, divider)) return -1U; debug("periph %d, rate=%d, reg=%p = %x\n", periph_id, rate,
(For context, I'm working on applying the review feedback to this patch myself, so save Tom some time)
I think that's the wrong assert to change.
When I pointed out this issue in V1 of the patch, the problem was inside function clock_periph_enable(). However, that function isn't actually used anywhere, and was dropped from V2 of the patch.
So, unless you tell me otherwise, I think I'll drop the change I quoted above from this patch, since it doesn't seem right.
v2:
periph_id,
Sounds good to me.
Stephen Warren
Tom Warren
