[U-Boot] [PATCH v2] board/BuR/zynq/brsmarc2: initial commit
This commit adds the first of a few more Xilinx ZYNQ based SoM boards.
The SoM is based on Xilinx Zynq 7000 SoC. Mainly vxWorks 6.9.4.x is running on the board, doing some PLC stuff on various carrier boards.
Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com
Changes in v2: - fix SDPX tag in Make-files/rules
arch/arm/dts/Makefile | 2 + arch/arm/dts/zynq-brsmarc2.dts | 15 + arch/arm/dts/zynq-brsmarc2.dtsi | 278 ++++++++++ arch/arm/dts/zynq-brsmarc2_r512.dts | 16 + board/BuR/zynq/.gitignore | 1 + board/BuR/zynq/MAINTAINERS | 6 + board/BuR/zynq/Makefile | 16 + board/BuR/zynq/brsmarc2/board.c | 84 +++ board/BuR/zynq/brsmarc2/ps7_init_gpl.c | 814 ++++++++++++++++++++++++++++ board/BuR/zynq/brsmarc2_r512/board.c | 2 + board/BuR/zynq/brsmarc2_r512/ps7_init_gpl.c | 813 +++++++++++++++++++++++++++ board/BuR/zynq/config.mk | 49 ++ board/BuR/zynq/take_vivadoHandoff.sh | 36 ++ board/BuR/zynq/uncrustify.cfg | 91 ++++ configs/brsmarc2_defconfig | 72 +++ configs/brsmarc2_r512_defconfig | 72 +++ include/configs/brsmarc2.h | 166 ++++++ 17 files changed, 2533 insertions(+) create mode 100644 arch/arm/dts/zynq-brsmarc2.dts create mode 100644 arch/arm/dts/zynq-brsmarc2.dtsi create mode 100644 arch/arm/dts/zynq-brsmarc2_r512.dts create mode 100644 board/BuR/zynq/.gitignore create mode 100644 board/BuR/zynq/MAINTAINERS create mode 100644 board/BuR/zynq/Makefile create mode 100644 board/BuR/zynq/brsmarc2/board.c create mode 100644 board/BuR/zynq/brsmarc2/ps7_init_gpl.c create mode 100644 board/BuR/zynq/brsmarc2_r512/board.c create mode 100644 board/BuR/zynq/brsmarc2_r512/ps7_init_gpl.c create mode 100644 board/BuR/zynq/config.mk create mode 100755 board/BuR/zynq/take_vivadoHandoff.sh create mode 100644 board/BuR/zynq/uncrustify.cfg create mode 100644 configs/brsmarc2_defconfig create mode 100644 configs/brsmarc2_r512_defconfig create mode 100644 include/configs/brsmarc2.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index dfa5b02..2b00129 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -208,6 +208,8 @@ dtb-$(CONFIG_ARCH_ZYNQ) += \ zynq-zc770-xm011-x16.dtb \ zynq-zc770-xm012.dtb \ zynq-zc770-xm013.dtb \ + zynq-brsmarc2.dtb \ + zynq-brsmarc2_r512.dtb \ zynq-zed.dtb \ zynq-zturn.dtb \ zynq-zybo.dtb \ diff --git a/arch/arm/dts/zynq-brsmarc2.dts b/arch/arm/dts/zynq-brsmarc2.dts new file mode 100644 index 0000000..5ad5113 --- /dev/null +++ b/arch/arm/dts/zynq-brsmarc2.dts @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * B&R BRSMARC2 board base DTS file + * + * Copyright (C) 2018 B&R Industrial Automation GmbH + * + */ +/dts-v1/; +#include "zynq-brsmarc2.dtsi" +/ { + memory { + device_type = "memory"; + reg = <0x0 0x10000000>; + }; +}; diff --git a/arch/arm/dts/zynq-brsmarc2.dtsi b/arch/arm/dts/zynq-brsmarc2.dtsi new file mode 100644 index 0000000..d1aeffd --- /dev/null +++ b/arch/arm/dts/zynq-brsmarc2.dtsi @@ -0,0 +1,278 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * B&R BRSMARC2 board base DTS file + * + * Copyright (C) 2017 B&R Industrial Automation GmbH + * Copyright (C) 2011 - 2015 Xilinx + * Copyright (C) 2012 National Instruments Corp. + */ + +/include/ "zynq-7000.dtsi" +#include <dt-bindings/thermal/thermal.h> +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "BRSMARC2 Zynq SoM"; + compatible = "xlnx,zynq-7000"; + + fset: factory-settings { + bl-version = " "; + order-no = " "; + cpu-order-no = " "; + hw-revision = " "; + serial-no = <0>; + device-id = <0x0>; + parent-id = <0x0>; + hw-variant = <0x0>; + hw-platform = <0x0>; + fram-offset = <0x0>; + fram-size = <0x0>; + cache-disable = <0x0>; + cpu-clock = <0x0>; + }; + + aliases { + ethernet0 = &gem0; + ethernet1 = &gem1; + i2c0 = &i2c0; + serial0 = &uart0; + spi0 = &qspi; + mmc0 = &sdhci0; + fset = &fset; + can0 = &can0; + can1 = &can1; + }; + + memory { + device_type = "memory"; + reg = <0x0 0x10000000>; + }; + + board { + status = "okay"; + compatible = "bur,brsmarc2-som"; + usb0mux-gpios = <&gpio0 68 GPIO_ACTIVE_HIGH>; + usb1mux-gpios = <&gpio0 69 GPIO_ACTIVE_HIGH>; + powerdown-gpios = <&gpio0 0 GPIO_ACTIVE_LOW>; + reset-gpios = <&gpio0 9 GPIO_ACTIVE_LOW>; + }; + + fpga: fpga@40000000 { + #address-cells = <1>; + #size-cells = <1>; + status = "disabled"; + compatible = "bur,zynqPL", "simple-bus"; + reg = <0x40200000 0x1 /* version registers */ + 0x40200004 0x1>; /* misc registers */ + bur,upddest = &spi_flash; + bur,updaddr = <0x100000>; + bur,updsize = <0x200000>; + + plk: plk@80000000 { + status = "disabled"; + compatible = "bur,DdVxIoEplSMP"; + bur,hwtree = "IF9"; + reg = <0x80000000 0x8000>; + interrupt-parent = <&intc>; + interrupts = <0 68 4>, + <0 84 4>; + local-mac-address = [ 00 60 65 aa ab ac ]; + }; + + x2x: x2x@40100000 { + status = "disabled"; + compatible = "bur,xlk"; + bur,hwtree = "IF10"; + reg = <0x40100000 0x8000 + 0x40108000 0x8000>; + interrupt-parent = <&intc>; + interrupts = <0 65 4>; + }; + + uart2: serial@40200800 { + status = "disabled"; + compatible = "ns16550a", "bur,DdVxSf16x5xIO"; + bur,hwtree = "IF8"; + reg = <0x40200800 0x40>; + interrupt-parent = <&intc>; + interrupts = <0 66 4>; + term-gpios = <&gpio0 71 GPIO_ACTIVE_HIGH>; + }; + + uart3: serial@40200840 { + status = "disabled"; + compatible = "ns16550a", "bur,DdVxSf16x5xIO"; + bur,hwtree = "IF9"; + reg = <0x40200840 0x40>; + interrupt-parent = <&intc>; + interrupts = <0 67 4>; + term-gpios = <&gpio0 71 GPIO_ACTIVE_HIGH>; + }; + + uart4: serial@40200900 { + status = "disabled"; + compatible = "ns16550a", "bur,DdVxSf16x5xIO"; + bur,hwtree = "IF20"; + reg = <0x40200900 0x40>; + interrupt-parent = <&intc>; + interrupts = <0 88 4>; + }; + + uart5: serial@40200A00 { + status = "disabled"; + compatible = "ns16550a", "bur,DdVxSf16x5xIO"; + bur,hwtree = "IF21"; + reg = <0x40200A00 0x40>; + interrupt-parent = <&intc>; + interrupts = <0 90 4>; + }; + }; + + chosen { + bootargs = "console=ttyPS0,115200 earlyprintk"; + stdout-path = "serial0:115200n8"; + }; + + usb_phy0: phy0 { + compatible = "usb-nop-xceiv"; + #phy-cells = <0>; + }; + + board_thermal: board-thermal { + polling-delay-passive = <1000>; /* milliseconds */ + polling-delay = <2500>; /* milliseconds */ + + thermal-sensors = <&temp_core 0>; + + trips { + crit_trip: crit-trip { + temperature = <100000>; /* millicelsius */ + hysteresis = <5000>; /* millicelsius */ + type = "critical"; + }; + }; + cooling-maps { + map0 { + trip = <&crit_trip>; + cooling-device = <&resetc>; + }; + }; + }; +}; + +&amba { + ocm: sram@fffc0000 { + compatible = "mmio-sram"; + reg = <0xfffc0000 0x10000>; + }; +}; + +&clkc { + ps-clk-frequency = <33333333>; +}; + +&gem0 { + status = "okay"; + phy-mode = "rgmii-id"; + phy-handle = <ðernet_phy0>; + mac-address = [ 00 00 00 00 00 00 ]; + + ethernet_phy0: ethernet-phy@1 { + ti,ledcr = <0x0480>; + ti,rgmii-rxclk-shift; + reg = <1>; + }; +}; + +&gem1 { + status = "okay"; + phy-mode = "rgmii-id"; + phy-handle = <ðernet_phy1>; + mac-address = [ 00 00 00 00 00 00 ]; + + ethernet_phy1: ethernet-phy@3{ + ti,ledcr = <0x0480>; + reg = <3>; + }; +}; + +&i2c0 { + u-boot,dm-pre-reloc; + status = "okay"; + clock-frequency = <100000>; + + boardtemp: pct2075_0@49 { + #thermal-sensor-cells = <0>; + compatible = "nxp,pct2075"; + reg = <0x49>; + }; + + temp_core: tmp431_1@4C { /* temp. zynq die */ + #thermal-sensor-cells = <1>; + compatible = "ti,tmp431"; + reg = <0x4C>; + }; + + extrtc: rx8571@51 { /* realtime clock */ + compatible = "epson,rx8571"; + reg = <0x51>; + }; + + resetc: rststm@60 { /* reset controller */ + compatible = "bur,rststm"; + reg = <0x60>; + hit-gpios = <&gpio0 84 GPIO_ACTIVE_HIGH>; + cooling-min-state = <0>; + cooling-max-state = <1>; /* reset gets fired */ + #cooling-cells = <2>; /* min followed by max */ + }; +}; + +&i2c1 { + status = "okay"; + clock-frequency = <100000>; +}; + +&sdhci0 { + status = "okay"; + max-frequency = <25000000>; +}; + +&uart0 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&qspi { + u-boot,dm-pre-reloc; + status = "okay"; + spi-max-frequency = <100000000>; + spi_flash: spiflash@0 { + u-boot,dm-pre-reloc; + compatible = "spidev", "spi-flash"; + spi-max-frequency = <100000000>; + reg = <0>; + }; +}; + +&usb0 { + status = "okay"; + dr_mode = "host"; + usb-phy = <&usb_phy0>; +}; + +&gpio0 { + u-boot,dm-pre-reloc; +}; + +&can0 { + status = "disabled"; + bur,hwtree = "IF6"; + term-gpios = <&gpio0 70 GPIO_ACTIVE_HIGH>; +}; + +&can1 { + status = "disabled"; + bur,hwtree = "IF7"; + term-gpios = <&gpio0 71 GPIO_ACTIVE_HIGH>; +}; diff --git a/arch/arm/dts/zynq-brsmarc2_r512.dts b/arch/arm/dts/zynq-brsmarc2_r512.dts new file mode 100644 index 0000000..44bfd14 --- /dev/null +++ b/arch/arm/dts/zynq-brsmarc2_r512.dts @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * B&R BRSMARC2 board base DTS file + * + * Copyright (C) 2018 B&R Industrial Automation GmbH + * + */ +/dts-v1/; +#include "zynq-brsmarc2.dtsi" + +/ { + memory { + device_type = "memory"; + reg = <0x0 0x20000000>; + }; +}; diff --git a/board/BuR/zynq/.gitignore b/board/BuR/zynq/.gitignore new file mode 100644 index 0000000..fa64fbc --- /dev/null +++ b/board/BuR/zynq/.gitignore @@ -0,0 +1 @@ +./ps7_init_gpl.c diff --git a/board/BuR/zynq/MAINTAINERS b/board/BuR/zynq/MAINTAINERS new file mode 100644 index 0000000..c6b3cfb --- /dev/null +++ b/board/BuR/zynq/MAINTAINERS @@ -0,0 +1,6 @@ +BRSMARC2 BOARD +M: Hannes Schmelzer hannes.schmelzer@br-automation.com +S: Maintained +F: board/BuR/zynq/ +F: include/configs/brsmarc2.h +F: configs/brsmarc2_defconfig diff --git a/board/BuR/zynq/Makefile b/board/BuR/zynq/Makefile new file mode 100644 index 0000000..85a4b77 --- /dev/null +++ b/board/BuR/zynq/Makefile @@ -0,0 +1,16 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019 Hannes Schmelzer oe5hpm@oevsv.at - +# B&R Industrial Automation GmbH - http://www.br-automation.com +# + +hw-platform-y :=$(shell echo $(CONFIG_DEFAULT_DEVICE_TREE) | sed -e 's/zynq-//') + +obj-y := ../common/common.o +obj-y += ../common/br_resetc.o +obj-y += $(hw-platform-y)/board.o + +obj-$(CONFIG_SPL_BUILD) += $(hw-platform-y)/ps7_init_gpl.o + +# Suppress "warning: function declaration isn't a prototype" +CFLAGS_REMOVE_ps7_init_gpl.o := -Wstrict-prototypes diff --git a/board/BuR/zynq/brsmarc2/board.c b/board/BuR/zynq/brsmarc2/board.c new file mode 100644 index 0000000..b78b03a --- /dev/null +++ b/board/BuR/zynq/brsmarc2/board.c @@ -0,0 +1,84 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * board.c + * + * Board functions for B&R BRSMARC2 Board + * + * Copyright (C) 2017 Hannes Schmelzer oe5hpm@oevsv.at + * B&R Industrial Automation GmbH - http://www.br-automation.com + * + */ +#include <common.h> +#include <fdtdec.h> +#include <zynqpl.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <i2c.h> +#include "../../common/bur_common.h" +#include "../../common/br_resetc.h" + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_SPL_BUILD +int board_init(void) +{ + /* reset pulse for peripherals */ + gpio_request(9, "nRESET_PS_3V3"); + gpio_direction_output(9, 1); + + return 0; +} +#else +int board_init(void) +{ + return 0; +} +#endif + +int board_late_init(void) +{ + int rc; + struct udevice *i2cdev; + + br_resetc_bmode(); + brdefaultip_setup(0, 0x57); + + rc = i2c_get_chip_for_busnum(0, 0x5D, 1, &i2cdev); + if (rc >= 0) + rc = dm_i2c_write(i2cdev, 0xEF, NULL, 0); + if (rc != 0) + printf("WARN: cannot write to LEDs!\n"); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + return 0; +} + +int dram_init(void) +{ + int node; + fdt_addr_t addr; + fdt_size_t size; + const void *blob = gd->fdt_blob; + + node = fdt_node_offset_by_prop_value(blob, -1, "device_type", + "memory", 7); + if (node == -FDT_ERR_NOTFOUND) { + debug("ZYNQ DRAM: Can't get memory node\n"); + return -1; + } + addr = fdtdec_get_addr_size(blob, node, "reg", &size); + if (addr == FDT_ADDR_T_NONE || size == 0) { + debug("ZYNQ DRAM: Can't get base address or size\n"); + return -1; + } + gd->ram_size = get_ram_size((void *)addr, size); + + zynq_ddrc_init(); + + return 0; +} diff --git a/board/BuR/zynq/brsmarc2/ps7_init_gpl.c b/board/BuR/zynq/brsmarc2/ps7_init_gpl.c new file mode 100644 index 0000000..a44c9d2 --- /dev/null +++ b/board/BuR/zynq/brsmarc2/ps7_init_gpl.c @@ -0,0 +1,814 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include <asm/arch/ps7_init_gpl.h> + +unsigned long ps7_pll_init_data_3_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U, 0x000FA220U), + EMIT_MASKWRITE(0XF8000100, 0x0007F000U, 0x00028000U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U, 0x1F000200U), + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U, 0x0012C220U), + EMIT_MASKWRITE(0XF8000104, 0x0007F000U, 0x00020000U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U, 0x0C200003U), + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U, 0x001452C0U), + EMIT_MASKWRITE(0XF8000108, 0x0007F000U, 0x0001E000U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000000U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_clock_init_data_3_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U, 0x00700F01U), + EMIT_MASKWRITE(0XF8000138, 0x00000011U, 0x00000001U), + EMIT_MASKWRITE(0XF800013C, 0x00000011U, 0x00000011U), + EMIT_MASKWRITE(0XF8000140, 0x03F03F71U, 0x00500801U), + EMIT_MASKWRITE(0XF8000144, 0x03F03F71U, 0x00500141U), + EMIT_MASKWRITE(0XF800014C, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000150, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000158, 0x00003F33U, 0x00000503U), + EMIT_MASKWRITE(0XF800015C, 0x03F03F33U, 0x00501903U), + EMIT_MASKWRITE(0XF8000160, 0x007F007FU, 0x00000000U), + EMIT_MASKWRITE(0XF8000168, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00400500U), + EMIT_MASKWRITE(0XF80001C4, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU, 0x01DFC4CDU), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_ddr_init_data_3_0[] = { + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006004, 0x0007FFFFU, 0x00001040U), + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU, 0x03C0780FU), + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU, 0x02001001U), + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU, 0x00014001U), + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU, 0x00040EDAU), + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU, 0x44D258D4U), + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU, 0xB2024127U), + EMIT_MASKWRITE(0XF8006020, 0x7FDFFFFCU, 0x2B08B290U), + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFC3U, 0x00000000U), + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU, 0x00002007U), + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU, 0x00000018U), + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU, 0x00040970U), + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x000116D4U), + EMIT_MASKWRITE(0XF8006038, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU, 0x00000777U), + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU, 0xFFF00000U), + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU, 0x0FFF6666U), + EMIT_MASKWRITE(0XF8006048, 0x0003F03FU, 0x0003C008U), + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU, 0x77010800U), + EMIT_MASKWRITE(0XF8006058, 0x00010000U, 0x00000000U), + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU, 0x00005003U), + EMIT_MASKWRITE(0XF8006060, 0x000017FFU, 0x0000003EU), + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U, 0x00020000U), + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU, 0x00284545U), + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU, 0x00001610U), + EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU, 0x00466111U), + EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU, 0x00032222U), + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU, 0x10200802U), + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU, 0x0690CB73U), + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU, 0x000001FEU), + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU), + EMIT_MASKWRITE(0XF80060B4, 0x00000200U, 0x00000200U), + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU, 0x0020006AU), + EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060DC, 0x00000001U, 0x00000000U), + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU, 0x00000008U), + EMIT_MASKWRITE(0XF8006114, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU, 0x0001D400U), + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU, 0x0001C400U), + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU, 0x0001BC00U), + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU, 0x0001C800U), + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU, 0x0000007AU), + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU, 0x0000007DU), + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU, 0x0000007EU), + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU, 0x000000CAU), + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU, 0x000000C6U), + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU, 0x000000C4U), + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU, 0x000000C7U), + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU, 0x000000BAU), + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU, 0x000000BDU), + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU, 0x000000BEU), + EMIT_MASKWRITE(0XF8006190, 0x6FFFFEFEU, 0x00040080U), + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU, 0x0001FD04U), + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006208, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF800620C, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006210, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006214, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF80062A8, 0x00000FF5U, 0x00000000U), + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU, 0x00005125U), + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU, 0x000012A8U), + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000081U), + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + EMIT_EXIT(), +}; + +unsigned long ps7_mio_init_data_3_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU, 0x0018C068U), + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU, 0x00000260U), + EMIT_MASKWRITE(0XF8000B70, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000020U), + EMIT_MASKWRITE(0XF8000B70, 0x07FEFFFFU, 0x00000823U), + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x000016E1U), + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x000006E0U), + EMIT_MASKWRITE(0XF8000740, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000744, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000748, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF800074C, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000750, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000754, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000758, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF800075C, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000760, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000764, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000768, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF800076C, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x00000321U), + EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU, 0x00000320U), + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU, 0x00000320U), + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x00000321U), + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00000340U), + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00000340U), + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU, 0x00000280U), + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU, 0x00000280U), + EMIT_MASKWRITE(0XF8000830, 0x003F003FU, 0x00380037U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_peripherals_init_data_3_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B48, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B50, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B54, 0x00000180U, 0x00000180U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_MASKWRITE(0XE0000034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0XE0000000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0XE0000004, 0x000003FFU, 0x00000020U), + EMIT_MASKWRITE(0XE000D000, 0x00080000U, 0x00080000U), + EMIT_MASKWRITE(0XF8007000, 0x20000000U, 0x00000000U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_EXIT(), +}; + +unsigned long ps7_post_config_3_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU), + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU, 0x00000000U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_pll_init_data_2_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U, 0x000FA220U), + EMIT_MASKWRITE(0XF8000100, 0x0007F000U, 0x00028000U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U, 0x1F000200U), + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U, 0x0012C220U), + EMIT_MASKWRITE(0XF8000104, 0x0007F000U, 0x00020000U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U, 0x0C200003U), + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U, 0x001452C0U), + EMIT_MASKWRITE(0XF8000108, 0x0007F000U, 0x0001E000U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000000U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_clock_init_data_2_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U, 0x00700F01U), + EMIT_MASKWRITE(0XF8000138, 0x00000011U, 0x00000001U), + EMIT_MASKWRITE(0XF800013C, 0x00000011U, 0x00000011U), + EMIT_MASKWRITE(0XF8000140, 0x03F03F71U, 0x00500801U), + EMIT_MASKWRITE(0XF8000144, 0x03F03F71U, 0x00500141U), + EMIT_MASKWRITE(0XF800014C, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000150, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000158, 0x00003F33U, 0x00000503U), + EMIT_MASKWRITE(0XF800015C, 0x03F03F33U, 0x00501903U), + EMIT_MASKWRITE(0XF8000160, 0x007F007FU, 0x00000000U), + EMIT_MASKWRITE(0XF8000168, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00400500U), + EMIT_MASKWRITE(0XF80001C4, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU, 0x01DFC4CDU), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_ddr_init_data_2_0[] = { + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006004, 0x1FFFFFFFU, 0x00081040U), + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU, 0x03C0780FU), + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU, 0x02001001U), + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU, 0x00014001U), + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU, 0x00040EDAU), + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU, 0x44D258D4U), + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU, 0xB2024127U), + EMIT_MASKWRITE(0XF8006020, 0xFFFFFFFCU, 0x2B28B290U), + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFFFU, 0x0000003CU), + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU, 0x00002007U), + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU, 0x00000018U), + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU, 0x00040970U), + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x000116D4U), + EMIT_MASKWRITE(0XF8006038, 0x00001FC3U, 0x00000000U), + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU, 0x00000777U), + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU, 0xFFF00000U), + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU, 0x0FFF6666U), + EMIT_MASKWRITE(0XF8006048, 0x3FFFFFFFU, 0x0003C248U), + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU, 0x77010800U), + EMIT_MASKWRITE(0XF8006058, 0x0001FFFFU, 0x00000101U), + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU, 0x00005003U), + EMIT_MASKWRITE(0XF8006060, 0x000017FFU, 0x0000003EU), + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U, 0x00020000U), + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU, 0x00284545U), + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU, 0x00001610U), + EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU, 0x00466111U), + EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU, 0x00032222U), + EMIT_MASKWRITE(0XF80060A0, 0x00FFFFFFU, 0x00008000U), + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU, 0x10200802U), + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU, 0x0690CB73U), + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU, 0x000001FEU), + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU), + EMIT_MASKWRITE(0XF80060B4, 0x000007FFU, 0x00000200U), + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU, 0x0020006AU), + EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060DC, 0x00000001U, 0x00000000U), + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU, 0x00000008U), + EMIT_MASKWRITE(0XF8006114, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU, 0x0001D400U), + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU, 0x0001C400U), + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU, 0x0001BC00U), + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU, 0x0001C800U), + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU, 0x0000007AU), + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU, 0x0000007DU), + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU, 0x0000007EU), + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU, 0x000000CAU), + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU, 0x000000C6U), + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU, 0x000000C4U), + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU, 0x000000C7U), + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU, 0x000000BAU), + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU, 0x000000BDU), + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU, 0x000000BEU), + EMIT_MASKWRITE(0XF8006190, 0xFFFFFFFFU, 0x10040080U), + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU, 0x0001FD04U), + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006208, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF800620C, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF8006210, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF8006214, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF80062A8, 0x00000FF7U, 0x00000000U), + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU, 0x00005125U), + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU, 0x000012A8U), + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000081U), + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + EMIT_EXIT(), +}; + +unsigned long ps7_mio_init_data_2_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU, 0x0018C068U), + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU, 0x00000260U), + EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000021U), + EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000020U), + EMIT_MASKWRITE(0XF8000B70, 0x07FFFFFFU, 0x00000823U), + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x000016E1U), + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x000006E0U), + EMIT_MASKWRITE(0XF8000740, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000744, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000748, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF800074C, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000750, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000754, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000758, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF800075C, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000760, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000764, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000768, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF800076C, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x00000321U), + EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU, 0x00000320U), + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU, 0x00000320U), + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x00000321U), + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00000340U), + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00000340U), + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU, 0x00000280U), + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU, 0x00000280U), + EMIT_MASKWRITE(0XF8000830, 0x003F003FU, 0x00380037U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_peripherals_init_data_2_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B48, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B50, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B54, 0x00000180U, 0x00000180U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_MASKWRITE(0XE0000034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0XE0000000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0XE0000004, 0x00000FFFU, 0x00000020U), + EMIT_MASKWRITE(0XE000D000, 0x00080000U, 0x00080000U), + EMIT_MASKWRITE(0XF8007000, 0x20000000U, 0x00000000U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_EXIT(), + +}; + +unsigned long ps7_post_config_2_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU), + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU, 0x00000000U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_pll_init_data_1_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U, 0x000FA220U), + EMIT_MASKWRITE(0XF8000100, 0x0007F000U, 0x00028000U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U, 0x1F000200U), + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U, 0x0012C220U), + EMIT_MASKWRITE(0XF8000104, 0x0007F000U, 0x00020000U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U, 0x0C200003U), + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U, 0x001452C0U), + EMIT_MASKWRITE(0XF8000108, 0x0007F000U, 0x0001E000U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000000U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_clock_init_data_1_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U, 0x00700F01U), + EMIT_MASKWRITE(0XF8000138, 0x00000011U, 0x00000001U), + EMIT_MASKWRITE(0XF800013C, 0x00000011U, 0x00000011U), + EMIT_MASKWRITE(0XF8000140, 0x03F03F71U, 0x00500801U), + EMIT_MASKWRITE(0XF8000144, 0x03F03F71U, 0x00500141U), + EMIT_MASKWRITE(0XF800014C, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000150, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000158, 0x00003F33U, 0x00000503U), + EMIT_MASKWRITE(0XF800015C, 0x03F03F33U, 0x00501903U), + EMIT_MASKWRITE(0XF8000160, 0x007F007FU, 0x00000000U), + EMIT_MASKWRITE(0XF8000168, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00400500U), + EMIT_MASKWRITE(0XF80001C4, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU, 0x01DFC4CDU), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_ddr_init_data_1_0[] = { + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006004, 0x1FFFFFFFU, 0x00081040U), + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU, 0x03C0780FU), + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU, 0x02001001U), + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU, 0x00014001U), + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU, 0x00040EDAU), + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU, 0x44D258D4U), + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU, 0xB2024127U), + EMIT_MASKWRITE(0XF8006020, 0xFFFFFFFCU, 0x2B28B290U), + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFFFU, 0x0000003CU), + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU, 0x00002007U), + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU, 0x00000018U), + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU, 0x00040970U), + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x000116D4U), + EMIT_MASKWRITE(0XF8006038, 0x00001FC3U, 0x00000000U), + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU, 0x00000777U), + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU, 0xFFF00000U), + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU, 0x0FFF6666U), + EMIT_MASKWRITE(0XF8006048, 0x3FFFFFFFU, 0x0003C248U), + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU, 0x77010800U), + EMIT_MASKWRITE(0XF8006058, 0x0001FFFFU, 0x00000101U), + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU, 0x00005003U), + EMIT_MASKWRITE(0XF8006060, 0x000017FFU, 0x0000003EU), + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U, 0x00020000U), + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU, 0x00284545U), + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU, 0x00001610U), + EMIT_MASKWRITE(0XF80060A0, 0x00FFFFFFU, 0x00008000U), + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU, 0x10200802U), + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU, 0x0690CB73U), + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU, 0x000001FEU), + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU), + EMIT_MASKWRITE(0XF80060B4, 0x000007FFU, 0x00000200U), + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU, 0x0020006AU), + EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060DC, 0x00000001U, 0x00000000U), + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU, 0x00000008U), + EMIT_MASKWRITE(0XF8006114, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU, 0x0001D400U), + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU, 0x0001C400U), + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU, 0x0001BC00U), + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU, 0x0001C800U), + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU, 0x0000007AU), + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU, 0x0000007DU), + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU, 0x0000007EU), + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU, 0x000000CAU), + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU, 0x000000C6U), + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU, 0x000000C4U), + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU, 0x000000C7U), + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU, 0x000000BAU), + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU, 0x000000BDU), + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU, 0x000000BEU), + EMIT_MASKWRITE(0XF8006190, 0xFFFFFFFFU, 0x10040080U), + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU, 0x0001FD04U), + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006208, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF800620C, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF8006210, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF8006214, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF80062A8, 0x00000FF7U, 0x00000000U), + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU, 0x00005125U), + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU, 0x000012A8U), + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000081U), + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + EMIT_EXIT(), +}; + +unsigned long ps7_mio_init_data_1_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU, 0x0018C068U), + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B6C, 0x000073FFU, 0x00000260U), + EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000021U), + EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000020U), + EMIT_MASKWRITE(0XF8000B70, 0x07FFFFFFU, 0x00000823U), + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x000016E1U), + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x000006E0U), + EMIT_MASKWRITE(0XF8000740, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000744, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000748, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF800074C, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000750, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000754, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000758, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF800075C, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000760, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000764, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000768, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF800076C, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x00000321U), + EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU, 0x00000320U), + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU, 0x00000320U), + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x00000321U), + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00000340U), + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00000340U), + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU, 0x00000280U), + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU, 0x00000280U), + EMIT_MASKWRITE(0XF8000830, 0x003F003FU, 0x00380037U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_peripherals_init_data_1_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B48, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B50, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B54, 0x00000180U, 0x00000180U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_MASKWRITE(0XE0000034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0XE0000000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0XE0000004, 0x00000FFFU, 0x00000020U), + EMIT_MASKWRITE(0XE000D000, 0x00080000U, 0x00080000U), + EMIT_MASKWRITE(0XF8007000, 0x20000000U, 0x00000000U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_EXIT(), +}; + +unsigned long ps7_post_config_1_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU), + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU, 0x00000000U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long get_ps7_siliconversion(void) +{ + unsigned long mask = 0xF0000000; + unsigned long *addr = (unsigned long *)0XF8007080; + unsigned long ps_version = (*addr & mask) >> 28; + + return ps_version; +} + +unsigned long *ps7_mio_init_data = ps7_mio_init_data_3_0; +unsigned long *ps7_pll_init_data = ps7_pll_init_data_3_0; +unsigned long *ps7_clock_init_data = ps7_clock_init_data_3_0; +unsigned long *ps7_ddr_init_data = ps7_ddr_init_data_3_0; +unsigned long *ps7_peripherals_init_data = ps7_peripherals_init_data_3_0; + +int ps7_post_config(void) +{ + unsigned long si_ver = get_ps7_siliconversion(); + int ret = -1; + + if (si_ver == PCW_SILICON_VERSION_1) { + ret = ps7_config(ps7_post_config_1_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + } else if (si_ver == PCW_SILICON_VERSION_2) { + ret = ps7_config(ps7_post_config_2_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + } else { + ret = ps7_config(ps7_post_config_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + } + return PS7_INIT_SUCCESS; +} + +int ps7_init(void) +{ + unsigned long si_ver = get_ps7_siliconversion(); + int ret; + + if (si_ver == PCW_SILICON_VERSION_1) { + ps7_mio_init_data = ps7_mio_init_data_1_0; + ps7_pll_init_data = ps7_pll_init_data_1_0; + ps7_clock_init_data = ps7_clock_init_data_1_0; + ps7_ddr_init_data = ps7_ddr_init_data_1_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_1_0; + + } else if (si_ver == PCW_SILICON_VERSION_2) { + ps7_mio_init_data = ps7_mio_init_data_2_0; + ps7_pll_init_data = ps7_pll_init_data_2_0; + ps7_clock_init_data = ps7_clock_init_data_2_0; + ps7_ddr_init_data = ps7_ddr_init_data_2_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_2_0; + + } else { + ps7_mio_init_data = ps7_mio_init_data_3_0; + ps7_pll_init_data = ps7_pll_init_data_3_0; + ps7_clock_init_data = ps7_clock_init_data_3_0; + ps7_ddr_init_data = ps7_ddr_init_data_3_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_3_0; + } + + ret = ps7_config(ps7_mio_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + + ret = ps7_config(ps7_pll_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + + ret = ps7_config(ps7_clock_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + + ret = ps7_config(ps7_ddr_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + + ret = ps7_config(ps7_peripherals_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + return PS7_INIT_SUCCESS; +} diff --git a/board/BuR/zynq/brsmarc2_r512/board.c b/board/BuR/zynq/brsmarc2_r512/board.c new file mode 100644 index 0000000..a70c2aa --- /dev/null +++ b/board/BuR/zynq/brsmarc2_r512/board.c @@ -0,0 +1,2 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include "../brsmarc2/board.c" diff --git a/board/BuR/zynq/brsmarc2_r512/ps7_init_gpl.c b/board/BuR/zynq/brsmarc2_r512/ps7_init_gpl.c new file mode 100644 index 0000000..8bda095 --- /dev/null +++ b/board/BuR/zynq/brsmarc2_r512/ps7_init_gpl.c @@ -0,0 +1,813 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include <asm/arch/ps7_init_gpl.h> + +unsigned long ps7_pll_init_data_3_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U, 0x000FA220U), + EMIT_MASKWRITE(0XF8000100, 0x0007F000U, 0x00028000U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U, 0x1F000200U), + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U, 0x0012C220U), + EMIT_MASKWRITE(0XF8000104, 0x0007F000U, 0x00020000U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U, 0x0C200003U), + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U, 0x001452C0U), + EMIT_MASKWRITE(0XF8000108, 0x0007F000U, 0x0001E000U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000000U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_clock_init_data_3_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U, 0x00700F01U), + EMIT_MASKWRITE(0XF8000138, 0x00000011U, 0x00000001U), + EMIT_MASKWRITE(0XF800013C, 0x00000011U, 0x00000011U), + EMIT_MASKWRITE(0XF8000140, 0x03F03F71U, 0x00500801U), + EMIT_MASKWRITE(0XF8000144, 0x03F03F71U, 0x00500141U), + EMIT_MASKWRITE(0XF800014C, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000150, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000158, 0x00003F33U, 0x00000503U), + EMIT_MASKWRITE(0XF800015C, 0x03F03F33U, 0x00501903U), + EMIT_MASKWRITE(0XF8000160, 0x007F007FU, 0x00000000U), + EMIT_MASKWRITE(0XF8000168, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00400500U), + EMIT_MASKWRITE(0XF80001C4, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU, 0x01DFC4CDU), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_ddr_init_data_3_0[] = { + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006004, 0x0007FFFFU, 0x00001040U), + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU, 0x03C0780FU), + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU, 0x02001001U), + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU, 0x00014001U), + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU, 0x0004159AU), + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU, 0x44D258D4U), + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU, 0xB2024127U), + EMIT_MASKWRITE(0XF8006020, 0x7FDFFFFCU, 0x2B08B290U), + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFC3U, 0x00000000U), + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU, 0x00002007U), + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU, 0x00000018U), + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU, 0x00040970U), + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x000116D4U), + EMIT_MASKWRITE(0XF8006038, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU, 0x00000777U), + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU, 0xFFF00000U), + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU, 0x0FF66666U), + EMIT_MASKWRITE(0XF8006048, 0x0003F03FU, 0x0003C008U), + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU, 0x77010800U), + EMIT_MASKWRITE(0XF8006058, 0x00010000U, 0x00000000U), + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU, 0x00005003U), + EMIT_MASKWRITE(0XF8006060, 0x000017FFU, 0x0000003EU), + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U, 0x00020000U), + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU, 0x00284545U), + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU, 0x00001610U), + EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU, 0x00466111U), + EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU, 0x00032222U), + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU, 0x10200802U), + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU, 0x0690CB73U), + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU, 0x000001FEU), + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU), + EMIT_MASKWRITE(0XF80060B4, 0x00000200U, 0x00000200U), + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU, 0x0020006AU), + EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060DC, 0x00000001U, 0x00000000U), + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU, 0x00000008U), + EMIT_MASKWRITE(0XF8006114, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU, 0x0001D400U), + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU, 0x0001C400U), + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU, 0x0001BC00U), + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU, 0x0001C800U), + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU, 0x0000007AU), + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU, 0x0000007DU), + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU, 0x0000007EU), + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU, 0x000000CAU), + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU, 0x000000C6U), + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU, 0x000000C4U), + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU, 0x000000C7U), + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU, 0x000000BAU), + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU, 0x000000BDU), + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU, 0x000000BEU), + EMIT_MASKWRITE(0XF8006190, 0x6FFFFEFEU, 0x00040080U), + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU, 0x0001FD04U), + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006208, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF800620C, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006210, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006214, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF80062A8, 0x00000FF5U, 0x00000000U), + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU, 0x00005125U), + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU, 0x000012A8U), + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000081U), + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + EMIT_EXIT(), +}; + +unsigned long ps7_mio_init_data_3_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU, 0x0018C068U), + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU, 0x00000260U), + EMIT_MASKWRITE(0XF8000B70, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000020U), + EMIT_MASKWRITE(0XF8000B70, 0x07FEFFFFU, 0x00000823U), + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x000016E1U), + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x000006E0U), + EMIT_MASKWRITE(0XF8000740, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000744, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000748, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF800074C, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000750, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000754, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000758, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF800075C, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000760, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000764, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000768, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF800076C, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x00000321U), + EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU, 0x00000320U), + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU, 0x00000320U), + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x00000321U), + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00000340U), + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00000340U), + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU, 0x00000280U), + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU, 0x00000280U), + EMIT_MASKWRITE(0XF8000830, 0x003F003FU, 0x00380037U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_peripherals_init_data_3_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B48, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B50, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B54, 0x00000180U, 0x00000180U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_MASKWRITE(0XE0000034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0XE0000000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0XE0000004, 0x000003FFU, 0x00000020U), + EMIT_MASKWRITE(0XE000D000, 0x00080000U, 0x00080000U), + EMIT_MASKWRITE(0XF8007000, 0x20000000U, 0x00000000U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_EXIT(), +}; + +unsigned long ps7_post_config_3_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU), + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU, 0x00000000U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_pll_init_data_2_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U, 0x000FA220U), + EMIT_MASKWRITE(0XF8000100, 0x0007F000U, 0x00028000U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U, 0x1F000200U), + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U, 0x0012C220U), + EMIT_MASKWRITE(0XF8000104, 0x0007F000U, 0x00020000U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U, 0x0C200003U), + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U, 0x001452C0U), + EMIT_MASKWRITE(0XF8000108, 0x0007F000U, 0x0001E000U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000000U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_clock_init_data_2_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U, 0x00700F01U), + EMIT_MASKWRITE(0XF8000138, 0x00000011U, 0x00000001U), + EMIT_MASKWRITE(0XF800013C, 0x00000011U, 0x00000011U), + EMIT_MASKWRITE(0XF8000140, 0x03F03F71U, 0x00500801U), + EMIT_MASKWRITE(0XF8000144, 0x03F03F71U, 0x00500141U), + EMIT_MASKWRITE(0XF800014C, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000150, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000158, 0x00003F33U, 0x00000503U), + EMIT_MASKWRITE(0XF800015C, 0x03F03F33U, 0x00501903U), + EMIT_MASKWRITE(0XF8000160, 0x007F007FU, 0x00000000U), + EMIT_MASKWRITE(0XF8000168, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00400500U), + EMIT_MASKWRITE(0XF80001C4, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU, 0x01DFC4CDU), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_ddr_init_data_2_0[] = { + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006004, 0x1FFFFFFFU, 0x00081040U), + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU, 0x03C0780FU), + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU, 0x02001001U), + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU, 0x00014001U), + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU, 0x0004159AU), + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU, 0x44D258D4U), + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU, 0xB2024127U), + EMIT_MASKWRITE(0XF8006020, 0xFFFFFFFCU, 0x2B28B290U), + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFFFU, 0x0000003CU), + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU, 0x00002007U), + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU, 0x00000018U), + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU, 0x00040970U), + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x000116D4U), + EMIT_MASKWRITE(0XF8006038, 0x00001FC3U, 0x00000000U), + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU, 0x00000777U), + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU, 0xFFF00000U), + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU, 0x0FF66666U), + EMIT_MASKWRITE(0XF8006048, 0x3FFFFFFFU, 0x0003C248U), + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU, 0x77010800U), + EMIT_MASKWRITE(0XF8006058, 0x0001FFFFU, 0x00000101U), + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU, 0x00005003U), + EMIT_MASKWRITE(0XF8006060, 0x000017FFU, 0x0000003EU), + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U, 0x00020000U), + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU, 0x00284545U), + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU, 0x00001610U), + EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU, 0x00466111U), + EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU, 0x00032222U), + EMIT_MASKWRITE(0XF80060A0, 0x00FFFFFFU, 0x00008000U), + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU, 0x10200802U), + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU, 0x0690CB73U), + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU, 0x000001FEU), + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU), + EMIT_MASKWRITE(0XF80060B4, 0x000007FFU, 0x00000200U), + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU, 0x0020006AU), + EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060DC, 0x00000001U, 0x00000000U), + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU, 0x00000008U), + EMIT_MASKWRITE(0XF8006114, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU, 0x0001D400U), + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU, 0x0001C400U), + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU, 0x0001BC00U), + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU, 0x0001C800U), + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU, 0x0000007AU), + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU, 0x0000007DU), + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU, 0x0000007EU), + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU, 0x000000CAU), + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU, 0x000000C6U), + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU, 0x000000C4U), + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU, 0x000000C7U), + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU, 0x000000BAU), + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU, 0x000000BDU), + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU, 0x000000BEU), + EMIT_MASKWRITE(0XF8006190, 0xFFFFFFFFU, 0x10040080U), + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU, 0x0001FD04U), + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006208, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF800620C, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF8006210, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF8006214, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF80062A8, 0x00000FF7U, 0x00000000U), + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU, 0x00005125U), + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU, 0x000012A8U), + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000081U), + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + EMIT_EXIT(), +}; + +unsigned long ps7_mio_init_data_2_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU, 0x0018C068U), + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU, 0x00000260U), + EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000021U), + EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000020U), + EMIT_MASKWRITE(0XF8000B70, 0x07FFFFFFU, 0x00000823U), + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x000016E1U), + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x000006E0U), + EMIT_MASKWRITE(0XF8000740, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000744, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000748, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF800074C, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000750, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000754, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000758, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF800075C, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000760, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000764, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000768, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF800076C, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x00000321U), + EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU, 0x00000320U), + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU, 0x00000320U), + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x00000321U), + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00000340U), + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00000340U), + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU, 0x00000280U), + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU, 0x00000280U), + EMIT_MASKWRITE(0XF8000830, 0x003F003FU, 0x00380037U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_peripherals_init_data_2_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B48, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B50, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B54, 0x00000180U, 0x00000180U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_MASKWRITE(0XE0000034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0XE0000000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0XE0000004, 0x00000FFFU, 0x00000020U), + EMIT_MASKWRITE(0XE000D000, 0x00080000U, 0x00080000U), + EMIT_MASKWRITE(0XF8007000, 0x20000000U, 0x00000000U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_EXIT(), +}; + +unsigned long ps7_post_config_2_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU), + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU, 0x00000000U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_pll_init_data_1_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U, 0x000FA220U), + EMIT_MASKWRITE(0XF8000100, 0x0007F000U, 0x00028000U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U, 0x1F000200U), + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U, 0x0012C220U), + EMIT_MASKWRITE(0XF8000104, 0x0007F000U, 0x00020000U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U, 0x0C200003U), + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U, 0x001452C0U), + EMIT_MASKWRITE(0XF8000108, 0x0007F000U, 0x0001E000U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000000U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_clock_init_data_1_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U, 0x00700F01U), + EMIT_MASKWRITE(0XF8000138, 0x00000011U, 0x00000001U), + EMIT_MASKWRITE(0XF800013C, 0x00000011U, 0x00000011U), + EMIT_MASKWRITE(0XF8000140, 0x03F03F71U, 0x00500801U), + EMIT_MASKWRITE(0XF8000144, 0x03F03F71U, 0x00500141U), + EMIT_MASKWRITE(0XF800014C, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000150, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000158, 0x00003F33U, 0x00000503U), + EMIT_MASKWRITE(0XF800015C, 0x03F03F33U, 0x00501903U), + EMIT_MASKWRITE(0XF8000160, 0x007F007FU, 0x00000000U), + EMIT_MASKWRITE(0XF8000168, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00400500U), + EMIT_MASKWRITE(0XF80001C4, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU, 0x01DFC4CDU), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_ddr_init_data_1_0[] = { + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006004, 0x1FFFFFFFU, 0x00081040U), + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU, 0x03C0780FU), + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU, 0x02001001U), + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU, 0x00014001U), + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU, 0x0004159AU), + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU, 0x44D258D4U), + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU, 0xB2024127U), + EMIT_MASKWRITE(0XF8006020, 0xFFFFFFFCU, 0x2B28B290U), + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFFFU, 0x0000003CU), + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU, 0x00002007U), + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU, 0x00000018U), + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU, 0x00040970U), + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x000116D4U), + EMIT_MASKWRITE(0XF8006038, 0x00001FC3U, 0x00000000U), + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU, 0x00000777U), + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU, 0xFFF00000U), + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU, 0x0FF66666U), + EMIT_MASKWRITE(0XF8006048, 0x3FFFFFFFU, 0x0003C248U), + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU, 0x77010800U), + EMIT_MASKWRITE(0XF8006058, 0x0001FFFFU, 0x00000101U), + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU, 0x00005003U), + EMIT_MASKWRITE(0XF8006060, 0x000017FFU, 0x0000003EU), + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U, 0x00020000U), + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU, 0x00284545U), + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU, 0x00001610U), + EMIT_MASKWRITE(0XF80060A0, 0x00FFFFFFU, 0x00008000U), + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU, 0x10200802U), + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU, 0x0690CB73U), + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU, 0x000001FEU), + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU), + EMIT_MASKWRITE(0XF80060B4, 0x000007FFU, 0x00000200U), + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU, 0x0020006AU), + EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060DC, 0x00000001U, 0x00000000U), + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU, 0x00000008U), + EMIT_MASKWRITE(0XF8006114, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFFFU, 0x40000001U), + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU, 0x0001D400U), + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU, 0x0001C400U), + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU, 0x0001BC00U), + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU, 0x0001C800U), + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU, 0x0000007AU), + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU, 0x0000007DU), + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU, 0x0000007EU), + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU, 0x000000CAU), + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU, 0x000000C6U), + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU, 0x000000C4U), + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU, 0x000000C7U), + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU, 0x000000BAU), + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU, 0x000000BDU), + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU, 0x000000BEU), + EMIT_MASKWRITE(0XF8006190, 0xFFFFFFFFU, 0x10040080U), + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU, 0x0001FD04U), + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006208, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF800620C, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF8006210, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF8006214, 0x000F03FFU, 0x000803FFU), + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF80062A8, 0x00000FF7U, 0x00000000U), + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU, 0x00005125U), + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU, 0x000012A8U), + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000081U), + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + EMIT_EXIT(), +}; + +unsigned long ps7_mio_init_data_1_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU, 0x0018C068U), + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU, 0x00F98068U), + EMIT_MASKWRITE(0XF8000B6C, 0x000073FFU, 0x00000260U), + EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000021U), + EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000020U), + EMIT_MASKWRITE(0XF8000B70, 0x07FFFFFFU, 0x00000823U), + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x00000702U), + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x00000700U), + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x000007A0U), + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x000016E1U), + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x000006E0U), + EMIT_MASKWRITE(0XF8000740, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000744, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000748, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF800074C, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000750, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000754, 0x00003FFFU, 0x00000302U), + EMIT_MASKWRITE(0XF8000758, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF800075C, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000760, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000764, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000768, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF800076C, 0x00003FFFU, 0x00000303U), + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU, 0x00000205U), + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU, 0x00000204U), + EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00000380U), + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x00000321U), + EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU, 0x00000320U), + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU, 0x00000320U), + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x00000321U), + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00000340U), + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00000340U), + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU, 0x00000280U), + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU, 0x00000280U), + EMIT_MASKWRITE(0XF8000830, 0x003F003FU, 0x00380037U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_peripherals_init_data_1_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B48, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B50, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B54, 0x00000180U, 0x00000180U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_MASKWRITE(0XE0000034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0XE0000000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0XE0000004, 0x00000FFFU, 0x00000020U), + EMIT_MASKWRITE(0XE000D000, 0x00080000U, 0x00080000U), + EMIT_MASKWRITE(0XF8007000, 0x20000000U, 0x00000000U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_EXIT(), +}; + +unsigned long ps7_post_config_1_0[] = { + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU), + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU, 0x00000000U), + EMIT_WRITE(0XF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long get_ps7_siliconversion(void) +{ + unsigned long mask = 0xF0000000; + unsigned long *addr = (unsigned long *)0XF8007080; + unsigned long ps_version = (*addr & mask) >> 28; + + return ps_version; +} + +unsigned long *ps7_mio_init_data = ps7_mio_init_data_3_0; +unsigned long *ps7_pll_init_data = ps7_pll_init_data_3_0; +unsigned long *ps7_clock_init_data = ps7_clock_init_data_3_0; +unsigned long *ps7_ddr_init_data = ps7_ddr_init_data_3_0; +unsigned long *ps7_peripherals_init_data = ps7_peripherals_init_data_3_0; + +int ps7_post_config(void) +{ + unsigned long si_ver = get_ps7_siliconversion(); + int ret = -1; + + if (si_ver == PCW_SILICON_VERSION_1) { + ret = ps7_config(ps7_post_config_1_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + } else if (si_ver == PCW_SILICON_VERSION_2) { + ret = ps7_config(ps7_post_config_2_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + } else { + ret = ps7_config(ps7_post_config_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + } + return PS7_INIT_SUCCESS; +} + +int ps7_init(void) +{ + unsigned long si_ver = get_ps7_siliconversion(); + int ret; + + if (si_ver == PCW_SILICON_VERSION_1) { + ps7_mio_init_data = ps7_mio_init_data_1_0; + ps7_pll_init_data = ps7_pll_init_data_1_0; + ps7_clock_init_data = ps7_clock_init_data_1_0; + ps7_ddr_init_data = ps7_ddr_init_data_1_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_1_0; + + } else if (si_ver == PCW_SILICON_VERSION_2) { + ps7_mio_init_data = ps7_mio_init_data_2_0; + ps7_pll_init_data = ps7_pll_init_data_2_0; + ps7_clock_init_data = ps7_clock_init_data_2_0; + ps7_ddr_init_data = ps7_ddr_init_data_2_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_2_0; + + } else { + ps7_mio_init_data = ps7_mio_init_data_3_0; + ps7_pll_init_data = ps7_pll_init_data_3_0; + ps7_clock_init_data = ps7_clock_init_data_3_0; + ps7_ddr_init_data = ps7_ddr_init_data_3_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_3_0; + } + + ret = ps7_config(ps7_mio_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + + ret = ps7_config(ps7_pll_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + + ret = ps7_config(ps7_clock_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + + ret = ps7_config(ps7_ddr_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + + ret = ps7_config(ps7_peripherals_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + return PS7_INIT_SUCCESS; +} diff --git a/board/BuR/zynq/config.mk b/board/BuR/zynq/config.mk new file mode 100644 index 0000000..17e3d57 --- /dev/null +++ b/board/BuR/zynq/config.mk @@ -0,0 +1,49 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019 Hannes Schmelzer oe5hpm@oevsv.at - +# B&R Industrial Automation GmbH - http://www.br-automation.com +# + +hw-platform-y :=$(shell echo $(CONFIG_DEFAULT_DEVICE_TREE) | sed -e 's/zynq-//') + +payload_off :=$(shell printf "%d" $(CONFIG_SYS_SPI_U_BOOT_OFFS)) + +fpga_path := $(shell echo $(KBUILD_SRC)/board/$(BOARDDIR)/$(hw-platform-y)) +fpga_src := $(shell ls $(fpga_path)/*.bit 2>/dev/null) +fpga_file := $(shell echo $(fpga_src) | rev | cut -d/ -f1 | rev) +fpga_off := $(shell printf "%d" \ + $(shell cat $(fpga_path)/${fpga_file}.offset 2>/dev/null)) +flen_min := $(shell expr ${payload_off} + ${fpga_off}) + +quiet_cmd_prodbin = PRODBIN $@ $(payload_off) +cmd_prodbin = \ + dd if=/dev/zero bs=1 count=${flen_min} 2>/dev/null | tr "\000" "\377" >$@ && \ + dd conv=notrunc bs=1 if=spl/boot.bin of=$@ seek=0 2>/dev/null && \ + test -z ${fpga_src} && dd conv=notrunc bs=1 if=u-boot-dtb.img of=$@ seek=$(payload_off) 2>/dev/null && \ + test -z ${fpga_src} || ( \ + dd conv=notrunc bs=1 if=u-boot-dtb.img of=$@ seek=$(payload_off) 2>/dev/null; \ + dd obs=1 if=$(fpga_file) of=$@ seek=$(fpga_off) 2>/dev/null \ + ) + +quiet_cmd_prodzip = SAPZIP $@ +cmd_prodzip = \ + test -d misc && rm -r misc; \ + mkdir misc && \ + cp spl/boot.bin misc/ && \ + cp u-boot-dtb.img misc/ && \ + zip -9 -r $@ misc/* >/dev/null $< + +quiet_cmd_fpga = FPGA $@ ($(fpga_file)) @ $(fpga_off) +cmd_fpga = test -z ${fpga_src} || cp ${fpga_src} $(fpga_file) + +$(hw-platform-y)_fpga: + $(call if_changed,fpga) + +$(hw-platform-y)_prog.bin: u-boot-dtb.img spl/boot.bin $(hw-platform-y)_fpga + $(call if_changed,prodbin) + +$(hw-platform-y)_prod.zip: $(hw-platform-y)_prog.bin + $(call if_changed,prodzip) + + +ALL-y += $(hw-platform-y)_prod.zip diff --git a/board/BuR/zynq/take_vivadoHandoff.sh b/board/BuR/zynq/take_vivadoHandoff.sh new file mode 100755 index 0000000..227c0f7 --- /dev/null +++ b/board/BuR/zynq/take_vivadoHandoff.sh @@ -0,0 +1,36 @@ +#!/bin/bash +# SPDX-License-Identifier: GPL-2.0+ +FILE=ps7_init_gpl.c + +# remove DOS line-endings +sed -i "s/^M//" $FILE +# uncrustify +uncrustify -c ./uncrustify.cfg --no-backup $FILE +# strip trailing white space +sed -i 's/[[:space:]]*$//' $FILE +# fix identation +indent -npro -kr -i8 -ts8 -sob -l80 -ss -ncs -cp1 -il0 $FILE + +# fix leftover comments +sed -i '/xil_printf/d' $FILE +# drop comments on register accesses +sed -i '/**/d' $FILE +sed -i '/ */d' $FILE +sed -i '/* ../d' $FILE +# use common header files +sed -i\ + 's/#include "ps7_init_gpl.h"/#include <asm/arch/ps7_init_gpl.h>/g' $FILE +# insert SPDX license identifier +sed -i '1s/^/// SPDX-License-Identifier: GPL-2.0+\n/' $FILE + +pushd ../../../ +echo "######## running checkpatch script ..." +scripts/checkpatch.pl\ + -f board/BuR/zynq/$FILE --fix-inplace + +echo "######## running checkpatch script (again) ..." +scripts/checkpatch.pl\ + -f board/BuR/zynq/$FILE --fix-inplace + +popd +rm $FILE~ diff --git a/board/BuR/zynq/uncrustify.cfg b/board/BuR/zynq/uncrustify.cfg new file mode 100644 index 0000000..c5370f1 --- /dev/null +++ b/board/BuR/zynq/uncrustify.cfg @@ -0,0 +1,91 @@ +# +# uncrustify config file for the linux kernel +# +# http://uncrustify.sourceforge.net/config.txt + +indent_with_tabs = 2 # 1=indent to level only, 2=indent with tabs +input_tab_size = 8 # original tab size +output_tab_size = 8 # new tab size +indent_columns = output_tab_size + +indent_label = 1 # pos: absolute col, neg: relative column + + +# +# inter-symbol newlines +# + +nl_enum_brace = remove # "enum {" vs "enum \n {" +nl_union_brace = remove # "union {" vs "union \n {" +nl_struct_brace = remove # "struct {" vs "struct \n {" +nl_do_brace = remove # "do {" vs "do \n {" +nl_if_brace = remove # "if () {" vs "if () \n {" +nl_for_brace = remove # "for () {" vs "for () \n {" +nl_else_brace = remove # "else {" vs "else \n {" +nl_while_brace = remove # "while () {" vs "while () \n {" +nl_switch_brace = remove # "switch () {" vs "switch () \n {" +nl_brace_while = remove # "} while" vs "} \n while" - cuddle while +nl_brace_else = remove # "} else" vs "} \n else" - cuddle else +nl_func_var_def_blk = 1 +nl_fcall_brace = remove # "list_for_each() {" vs "list_for_each()\n{" +nl_fdef_brace = add # "int foo() {" vs "int foo()\n{" +# nl_after_return = TRUE; +# nl_before_case = 1 + +# +# Source code modifications +# + +mod_paren_on_return = remove # "return 1;" vs "return (1);" +mod_full_brace_if = remove # "if (a) a--;" vs "if (a) { a--; }" +mod_full_brace_for = remove # "for () a--;" vs "for () { a--; }" +mod_full_brace_do = remove # "do a--; while ();" vs "do { a--; } while ();" +mod_full_brace_while = remove # "while (a) a--;" vs "while (a) { a--; }" +mod_full_brace_nl = 3 # don't remove if more than 3 newlines + + +# +# inter-character spacing options +# + +# sp_return_paren = force # "return (1);" vs "return(1);" +sp_sizeof_paren = remove # "sizeof (int)" vs "sizeof(int)" +sp_before_sparen = force # "if (" vs "if(" +sp_after_sparen = force # "if () {" vs "if (){" +sp_after_cast = remove # "(int) a" vs "(int)a" +sp_inside_braces = add # "{ 1 }" vs "{1}" +sp_inside_braces_struct = add # "{ 1 }" vs "{1}" +sp_inside_braces_enum = add # "{ 1 }" vs "{1}" +sp_assign = add +sp_arith = add +sp_bool = add +sp_compare = add +sp_assign = add +sp_after_comma = add +sp_func_def_paren = remove # "int foo (){" vs "int foo(){" +sp_func_call_paren = remove # "foo (" vs "foo(" +sp_func_proto_paren = remove # "int foo ();" vs "int foo();" + +# +# Aligning stuff +# +align_with_tabs = TRUE # use tabs to align +align_on_tabstop = TRUE # align on tabstops +# align_keep_tabs = true +align_enum_equ_span = 4 # '=' in enum definition +# align_nl_cont = TRUE +# align_var_def_span = 2 +# align_var_def_inline = TRUE +# align_var_def_star = FALSE +# align_var_def_colon = TRUE +# align_assign_span = 1 +align_struct_init_span = 3 # align stuff in a structure init '= { }' +align_right_cmt_span = 3 +# align_pp_define_span = 8; +# align_pp_define_gap = 4; + +# cmt_star_cont = FALSE + +# indent_brace = 0 + +cmt_cpp_to_c = TRUE diff --git a/configs/brsmarc2_defconfig b/configs/brsmarc2_defconfig new file mode 100644 index 0000000..e73292d --- /dev/null +++ b/configs/brsmarc2_defconfig @@ -0,0 +1,72 @@ +CONFIG_ARM=y +CONFIG_SYS_VENDOR="BuR" +CONFIG_SYS_CONFIG_NAME="brsmarc2" +CONFIG_ARCH_ZYNQ=y +CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_SPL_GPIO_SUPPORT=y +# CONFIG_SPL_MMC_SUPPORT is not set +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x20000 +CONFIG_SPL=y +CONFIG_ZYNQ_SDHCI_MAX_FREQ=100000000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTDELAY=0 +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="run b_default" +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_SPL_RAM_SUPPORT is not set +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_FPGA_LOADFS=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +# CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="zynq-brsmarc2" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_FPGA_XILINX=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CADENCE=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_NATSEMI=y +CONFIG_ZYNQ_GEM=y +CONFIG_ZYNQ_QSPI=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_STORAGE=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/brsmarc2_r512_defconfig b/configs/brsmarc2_r512_defconfig new file mode 100644 index 0000000..a920635 --- /dev/null +++ b/configs/brsmarc2_r512_defconfig @@ -0,0 +1,72 @@ +CONFIG_ARM=y +CONFIG_SYS_VENDOR="BuR" +CONFIG_SYS_CONFIG_NAME="brsmarc2" +CONFIG_ARCH_ZYNQ=y +CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_SPL_GPIO_SUPPORT=y +# CONFIG_SPL_MMC_SUPPORT is not set +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x20000 +CONFIG_SPL=y +CONFIG_ZYNQ_SDHCI_MAX_FREQ=100000000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTDELAY=0 +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="run b_default" +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_SPL_RAM_SUPPORT is not set +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_FPGA_LOADFS=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +# CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="zynq-brsmarc2_r512" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_FPGA_XILINX=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CADENCE=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_NATSEMI=y +CONFIG_ZYNQ_GEM=y +CONFIG_ZYNQ_QSPI=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_STORAGE=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/brsmarc2.h b/include/configs/brsmarc2.h new file mode 100644 index 0000000..fc8968c --- /dev/null +++ b/include/configs/brsmarc2.h @@ -0,0 +1,166 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * specific parts for B&R X20CP Motherboard + * + * Copyright (C) 2016 Hannes Schmelzer oe5hpm@oevsv.at - + * B&R Industrial Automation GmbH - http://www.br-automation.com + * + */ + +#ifndef __CONFIG_BRSMARC2_H__ +#define __CONFIG_BRSMARC2_H__ + +#include <configs/bur_cfg_common.h> + +/* Cache options */ +#define CONFIG_SYS_L2CACHE_OFF +#ifndef CONFIG_SYS_L2CACHE_OFF +# define CONFIG_SYS_L2_PL310 +# define CONFIG_SYS_PL310_BASE 0xf8f02000 +#endif + +#define ZYNQ_SCUTIMER_BASEADDR 0xF8F00600 +#define CONFIG_SYS_TIMERBASE ZYNQ_SCUTIMER_BASEADDR +#define CONFIG_SYS_TIMER_COUNTS_DOWN +#define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMERBASE + 0x4) + +/* Serial drivers */ +#define CONFIG_BAUDRATE 115200 +/* The following table includes the supported baudrates */ +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400} +#define CONFIG_ZYNQ_SERIAL + +/* Ethernet driver */ +#ifdef CONFIG_ZYNQ_GEM +# define CONFIG_MII +# define CONFIG_BOOTP_MAY_FAIL +#endif + +/* MMC */ +#define CONFIG_ZYNQ_HISPD_BROKEN + +#define CONFIG_EHCI_IS_TDI +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 + +/* Allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Environment */ +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ + CONFIG_ENV_SECT_SIZE) +#define CONFIG_EXTRA_ENV_SETTINGS \ +BUR_COMMON_ENV \ +"board_id=0xFF\0" \ +"autoload=0\0" \ +"scradr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ +"dtbaddr=0x4000000\0" \ +"loadaddr=0x2000000\0" \ +"fpgaaddr=fdt get value fpgabase /fpga bur,updaddr;" \ +" fdt get value fpgasize /fpga bur,updsize\0" \ +"fpga=setenv fpgastatus disabled; run fpgaaddr;" \ +" sf read ${loadaddr} ${fpgabase} ${fpgasize} &&" \ +" fpga loadb 0 ${loadaddr} ${fpgasize} && setenv fpgastatus okay\0" \ +"fpgastatus=disabled\0" \ +"fpgaupd=run fpgaaddr && tftp ${loadaddr} X20CP04xx.bit &&" \ +" sf erase ${fpgabase} +${filesize} &&" \ +" sf write ${loadaddr} ${fpgabase} ${filesize}\0" \ +"netupd=tftp ${loadaddr} boot.bin && sf probe &&" \ +" sf erase 0 +${filesize} && sf write ${loadaddr} 0 ${filesize} &&" \ +" tftp ${loadaddr} u-boot-dtb.img &&" \ +" sf erase 0x40000 +${filesize} && sf write ${loadaddr} 0x40000 ${filesize}\0" \ +"cfgscr=mw ${dtbaddr} 0;" \ +" sf probe && sf read ${scradr} 0xC0000 0x10000 && source ${scradr};" \ +" fdt addr ${dtbaddr} || cp ${fdtcontroladdr} ${dtbaddr} 4000\0" \ +"vxargs=setenv bootargs gem(0,0)host:vxWorks h=${serverip}" \ +" e=${ipaddr}:${netmask} g=${gatewayip} u=vxWorksFTP pw=vxWorks\0" \ +"vxfdt=fdt addr ${dtbaddr}; fdt resize 0x10000;" \ +" fdt set /fpga status ${fpgastatus};" \ +" fdt boardsetup\0" \ +"startvx=run vxargs && mw 0x1100 0 && run vxfdt &&" \ +" bootm ${loadaddr} - ${dtbaddr}\0" \ +"b_break=0\0" \ +"b_tgts_std=mmc spi usb0 net0 net1\0" \ +"b_tgts_rcy=spi usb0 net0 net1\0" \ +"b_tgts_pme=usb0 net0 net1 mmc spi\0" \ +"b_deftgts=if test ${b_mode} = 12; then setenv b_tgts ${b_tgts_pme};" \ +" elif test ${b_mode} = 0; then setenv b_tgts ${b_tgts_rcy};" \ +" else setenv b_tgts ${b_tgts_std}; fi\0" \ +"b_mmc=run fpga; mmc dev 0; load mmc 0 ${loadaddr} arimg && run startvx\0" \ +"b_spi=run fpga; sf read ${loadaddr} 900000 700000 && run startvx\0" \ +"b_net0=tftp ${scradr} netscr-brsmarc2-${board_id}.img && source ${scradr}\0" \ +"b_net1=tftp ${scradr} netscript.img && source ${scradr}\0" \ +"b_usb0=usb start && load usb 0 ${scradr} bootscr.img && source ${scradr}\0" \ +"b_default=run b_deftgts; for target in ${b_tgts};"\ +" do run b_${target}; if test ${b_break} = 1; then; exit; fi; done\0" + +#define CONFIG_SYS_LOAD_ADDR 0xC0000 /* + * default load and execution + * address for loads / scripts + */ +/* Support both device trees and ATAGs. */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_MACH_TYPE 0xFFFFFFFF + +/* Miscellaneous configurable options */ +#define CONFIG_CLOCKS +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_BOOTM_LEN (32 * 1024 * 1024) +/* Physical Memory map */ +#define CONFIG_SYS_TEXT_BASE 0x4000000 + +#define CONFIG_SYS_SDRAM_BASE 0 + +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x1000) + +#define CONFIG_SYS_MALLOC_LEN 0x1400000 +#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_MALLOC_LEN +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +/* Enable the PL to be downloaded */ +#define CONFIG_FPGA_ZYNQPL + +#define CONFIG_SYS_LDSCRIPT "arch/arm/mach-zynq/u-boot.lds" + +/* SPL part */ +#define CONFIG_SPL_I2C_SUPPORT + +#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-zynq/u-boot-spl.lds" + +/* Disable dcache for SPL just for sure */ +#ifdef CONFIG_SPL_BUILD +# define CONFIG_SYS_DCACHE_OFF +#endif /* CONFIG_SPL_BUILD */ + +#ifdef CONFIG_ZYNQ_QSPI +# define CONFIG_SPL_SPI_LOAD +# define CONFIG_SYS_SPI_U_BOOT_OFFS 0x40000 +#endif /* CONFIG_ZYNQ_QSPI */ + +/* SP location before relocation, must use scratch RAM */ +#define CONFIG_SPL_TEXT_BASE 0x0 +/* 3 * 64kB blocks of OCM - one is on the top because of bootrom */ +#define CONFIG_SPL_MAX_SIZE 0x30000 +/* The highest 64k OCM address */ +#define OCM_HIGH_ADDR 0xffff0000 +/* Just define any reasonable size */ +#define CONFIG_SPL_STACK_SIZE 0x2000 +/* SPL stack position - and stack goes down */ +#define CONFIG_SPL_STACK (OCM_HIGH_ADDR + CONFIG_SPL_STACK_SIZE) +/* On the top of OCM space */ +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_STACK + \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x8000 +/* BSS setup */ +#define CONFIG_SPL_BSS_START_ADDR 0x100000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x100000 +#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE + +#endif /* __CONFIG_BRSMARC2_H__ */
On 02. 05. 19 5:14, Hannes Schmelzer wrote:
This commit adds the first of a few more Xilinx ZYNQ based SoM boards.
The SoM is based on Xilinx Zynq 7000 SoC. Mainly vxWorks 6.9.4.x is running on the board, doing some PLC stuff on various carrier boards.
Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com
Changes in v2:
- fix SDPX tag in Make-files/rules
arch/arm/dts/Makefile | 2 + arch/arm/dts/zynq-brsmarc2.dts | 15 + arch/arm/dts/zynq-brsmarc2.dtsi | 278 ++++++++++ arch/arm/dts/zynq-brsmarc2_r512.dts | 16 + board/BuR/zynq/.gitignore | 1 + board/BuR/zynq/MAINTAINERS | 6 + board/BuR/zynq/Makefile | 16 + board/BuR/zynq/brsmarc2/board.c | 84 +++ board/BuR/zynq/brsmarc2/ps7_init_gpl.c | 814 ++++++++++++++++++++++++++++ board/BuR/zynq/brsmarc2_r512/board.c | 2 + board/BuR/zynq/brsmarc2_r512/ps7_init_gpl.c | 813 +++++++++++++++++++++++++++ board/BuR/zynq/config.mk | 49 ++ board/BuR/zynq/take_vivadoHandoff.sh | 36 ++ board/BuR/zynq/uncrustify.cfg | 91 ++++ configs/brsmarc2_defconfig | 72 +++ configs/brsmarc2_r512_defconfig | 72 +++ include/configs/brsmarc2.h | 166 ++++++ 17 files changed, 2533 insertions(+) create mode 100644 arch/arm/dts/zynq-brsmarc2.dts create mode 100644 arch/arm/dts/zynq-brsmarc2.dtsi create mode 100644 arch/arm/dts/zynq-brsmarc2_r512.dts create mode 100644 board/BuR/zynq/.gitignore create mode 100644 board/BuR/zynq/MAINTAINERS create mode 100644 board/BuR/zynq/Makefile create mode 100644 board/BuR/zynq/brsmarc2/board.c create mode 100644 board/BuR/zynq/brsmarc2/ps7_init_gpl.c create mode 100644 board/BuR/zynq/brsmarc2_r512/board.c create mode 100644 board/BuR/zynq/brsmarc2_r512/ps7_init_gpl.c create mode 100644 board/BuR/zynq/config.mk create mode 100755 board/BuR/zynq/take_vivadoHandoff.sh create mode 100644 board/BuR/zynq/uncrustify.cfg create mode 100644 configs/brsmarc2_defconfig create mode 100644 configs/brsmarc2_r512_defconfig create mode 100644 include/configs/brsmarc2.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index dfa5b02..2b00129 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -208,6 +208,8 @@ dtb-$(CONFIG_ARCH_ZYNQ) += \ zynq-zc770-xm011-x16.dtb \ zynq-zc770-xm012.dtb \ zynq-zc770-xm013.dtb \
- zynq-brsmarc2.dtb \
- zynq-brsmarc2_r512.dtb \
Can't you detect it if you have 512M version? u-boot itself has code for these kind of detection.
long get_ram_size(long *base, long maxsize)
zynq-zed.dtb \ zynq-zturn.dtb \ zynq-zybo.dtb \ diff --git a/arch/arm/dts/zynq-brsmarc2.dts b/arch/arm/dts/zynq-brsmarc2.dts new file mode 100644 index 0000000..5ad5113 --- /dev/null +++ b/arch/arm/dts/zynq-brsmarc2.dts @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- B&R BRSMARC2 board base DTS file
- Copyright (C) 2018 B&R Industrial Automation GmbH
+/dts-v1/; +#include "zynq-brsmarc2.dtsi" +/ {
- memory {
device_type = "memory";
reg = <0x0 0x10000000>;
+}; diff --git a/arch/arm/dts/zynq-brsmarc2.dtsi b/arch/arm/dts/zynq-brsmarc2.dtsi new file mode 100644 index 0000000..d1aeffd --- /dev/null +++ b/arch/arm/dts/zynq-brsmarc2.dtsi @@ -0,0 +1,278 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright (C) 2017 B&R Industrial Automation GmbH
- Copyright (C) 2011 - 2015 Xilinx
- Copyright (C) 2012 National Instruments Corp.
+/include/ "zynq-7000.dtsi" +#include <dt-bindings/thermal/thermal.h> +#include <dt-bindings/gpio/gpio.h>
- model = "BRSMARC2 Zynq SoM";
- compatible = "xlnx,zynq-7000";
- fset: factory-settings {
bl-version = " ";
order-no = " ";
cpu-order-no = " ";
hw-revision = " ";
serial-no = <0>;
device-id = <0x0>;
parent-id = <0x0>;
hw-variant = <0x0>;
hw-platform = <0x0>;
fram-offset = <0x0>;
fram-size = <0x0>;
cache-disable = <0x0>;
cpu-clock = <0x0>;
What's this? No compatible string. This looks quite hacky.
- aliases {
ethernet0 = &gem0;
ethernet1 = &gem1;
i2c0 = &i2c0;
serial0 = &uart0;
spi0 = &qspi;
mmc0 = &sdhci0;
fset = &fset;
can0 = &can0;
can1 = &can1;
- memory {
- board {
status = "okay";
compatible = "bur,brsmarc2-som";
usb0mux-gpios = <&gpio0 68 GPIO_ACTIVE_HIGH>;
usb1mux-gpios = <&gpio0 69 GPIO_ACTIVE_HIGH>;
powerdown-gpios = <&gpio0 0 GPIO_ACTIVE_LOW>;
reset-gpios = <&gpio0 9 GPIO_ACTIVE_LOW>;
Where is mainline dt binding for this?
- fpga: fpga@40000000 {
#address-cells = <1>;
#size-cells = <1>;
status = "disabled";
compatible = "bur,zynqPL", "simple-bus";
is bur even recoreded for your company.
compatible is wrong.
reg = <0x40200000 0x1 /* version registers */
0x40200004 0x1>; /* misc registers */
bur,upddest = &spi_flash;
bur,updaddr = <0x100000>;
bur,updsize = <0x200000>;
likely undocumented
plk: plk@80000000 {
compatible = "bur,DdVxIoEplSMP";
ditto
bur,hwtree = "IF9";
reg = <0x80000000 0x8000>;
interrupt-parent = <&intc>;
interrupts = <0 68 4>,
<0 84 4>;
local-mac-address = [ 00 60 65 aa ab ac ];
x2x: x2x@40100000 {
compatible = "bur,xlk";
ditoo.
bur,hwtree = "IF10";
reg = <0x40100000 0x8000
0x40108000 0x8000>;
interrupts = <0 65 4>;
uart2: serial@40200800 {
compatible = "ns16550a", "bur,DdVxSf16x5xIO";
bur,hwtree = "IF8";
reg = <0x40200800 0x40>;
interrupts = <0 66 4>;
term-gpios = <&gpio0 71 GPIO_ACTIVE_HIGH>;
uart3: serial@40200840 {
bur,hwtree = "IF9";
reg = <0x40200840 0x40>;
interrupts = <0 67 4>;
uart4: serial@40200900 {
bur,hwtree = "IF20";
reg = <0x40200900 0x40>;
interrupts = <0 88 4>;
uart5: serial@40200A00 {
bur,hwtree = "IF21";
reg = <0x40200A00 0x40>;
interrupts = <0 90 4>;
all these PL stuff can't go to mainline.
- chosen {
bootargs = "console=ttyPS0,115200 earlyprintk";
stdout-path = "serial0:115200n8";
- usb_phy0: phy0 {
compatible = "usb-nop-xceiv";
#phy-cells = <0>;
- board_thermal: board-thermal {
polling-delay-passive = <1000>; /* milliseconds */
polling-delay = <2500>; /* milliseconds */
thermal-sensors = <&temp_core 0>;
trips {
crit_trip: crit-trip {
temperature = <100000>; /* millicelsius */
hysteresis = <5000>; /* millicelsius */
type = "critical";
cooling-maps {
map0 {
trip = <&crit_trip>;
cooling-device = <&resetc>;
+&amba {
- ocm: sram@fffc0000 {
compatible = "mmio-sram";
reg = <0xfffc0000 0x10000>;
+&clkc {
- ps-clk-frequency = <33333333>;
+&gem0 {
- status = "okay";
- phy-mode = "rgmii-id";
- phy-handle = <ðernet_phy0>;
- mac-address = [ 00 00 00 00 00 00 ];
0 mac is wrong.
- ethernet_phy0: ethernet-phy@1 {
ti,ledcr = <0x0480>;
ti,rgmii-rxclk-shift;
reg = <1>;
+&gem1 {
- status = "okay";
- phy-handle = <ðernet_phy1>;
ditto.
- ethernet_phy1: ethernet-phy@3{
coding style. Comment about phy type would be useful.
reg = <3>;
+&i2c0 {
- u-boot,dm-pre-reloc;
- status = "okay";
- clock-frequency = <100000>;
- boardtemp: pct2075_0@49 {
#thermal-sensor-cells = <0>;
compatible = "nxp,pct2075";
reg = <0x49>;
- temp_core: tmp431_1@4C { /* temp. zynq die */
#thermal-sensor-cells = <1>;
compatible = "ti,tmp431";
reg = <0x4C>;
- extrtc: rx8571@51 { /* realtime clock */
compatible = "epson,rx8571";
reg = <0x51>;
- resetc: rststm@60 { /* reset controller */
compatible = "bur,rststm";
reg = <0x60>;
hit-gpios = <&gpio0 84 GPIO_ACTIVE_HIGH>;
cooling-min-state = <0>;
cooling-max-state = <1>; /* reset gets fired */
#cooling-cells = <2>; /* min followed by max */
+&i2c1 {
- status = "okay";
+&sdhci0 {
- status = "okay";
- max-frequency = <25000000>;
+&uart0 {
- status = "okay";
+&qspi {
- status = "okay";
- spi-max-frequency = <100000000>;
- spi_flash: spiflash@0 {
compatible = "spidev", "spi-flash";
reg = <0>;
+&usb0 {
- status = "okay";
- dr_mode = "host";
- usb-phy = <&usb_phy0>;
+&gpio0 {
+&can0 {
- status = "disabled";
- bur,hwtree = "IF6";
- term-gpios = <&gpio0 70 GPIO_ACTIVE_HIGH>;
+&can1 {
- bur,hwtree = "IF7";
- term-gpios = <&gpio0 71 GPIO_ACTIVE_HIGH>;
you should really revisit the whole dts. Only PS part should be here and only stuff which have approved mainline dt binding.
diff --git a/arch/arm/dts/zynq-brsmarc2_r512.dts b/arch/arm/dts/zynq-brsmarc2_r512.dts new file mode 100644 index 0000000..44bfd14 --- /dev/null +++ b/arch/arm/dts/zynq-brsmarc2_r512.dts @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- memory {
reg = <0x0 0x20000000>;
+}; diff --git a/board/BuR/zynq/.gitignore b/board/BuR/zynq/.gitignore new file mode 100644 index 0000000..fa64fbc --- /dev/null +++ b/board/BuR/zynq/.gitignore @@ -0,0 +1 @@ +./ps7_init_gpl.c diff --git a/board/BuR/zynq/MAINTAINERS b/board/BuR/zynq/MAINTAINERS new file mode 100644 index 0000000..c6b3cfb --- /dev/null +++ b/board/BuR/zynq/MAINTAINERS @@ -0,0 +1,6 @@ +BRSMARC2 BOARD +M: Hannes Schmelzer hannes.schmelzer@br-automation.com +S: Maintained +F: board/BuR/zynq/ +F: include/configs/brsmarc2.h +F: configs/brsmarc2_defconfig diff --git a/board/BuR/zynq/Makefile b/board/BuR/zynq/Makefile new file mode 100644 index 0000000..85a4b77 --- /dev/null +++ b/board/BuR/zynq/Makefile @@ -0,0 +1,16 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019 Hannes Schmelzer oe5hpm@oevsv.at - +# B&R Industrial Automation GmbH - http://www.br-automation.com +#
+obj-y := ../common/common.o +obj-y += ../common/br_resetc.o +obj-y += $(hw-platform-y)/board.o
+obj-$(CONFIG_SPL_BUILD) += $(hw-platform-y)/ps7_init_gpl.o
+# Suppress "warning: function declaration isn't a prototype" +CFLAGS_REMOVE_ps7_init_gpl.o := -Wstrict-prototypes diff --git a/board/BuR/zynq/brsmarc2/board.c b/board/BuR/zynq/brsmarc2/board.c new file mode 100644 index 0000000..b78b03a --- /dev/null +++ b/board/BuR/zynq/brsmarc2/board.c @@ -0,0 +1,84 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- board.c
- Board functions for B&R BRSMARC2 Board
- Copyright (C) 2017 Hannes Schmelzer oe5hpm@oevsv.at
- B&R Industrial Automation GmbH - http://www.br-automation.com
+#include <common.h> +#include <fdtdec.h> +#include <zynqpl.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <i2c.h> +#include "../../common/bur_common.h" +#include "../../common/br_resetc.h"
+DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_SPL_BUILD +int board_init(void) +{
- /* reset pulse for peripherals */
- gpio_request(9, "nRESET_PS_3V3");
- gpio_direction_output(9, 1);
+} +#else +int board_init(void) +{
+} +#endif
+int board_late_init(void) +{
- int rc;
- struct udevice *i2cdev;
- br_resetc_bmode();
- brdefaultip_setup(0, 0x57);
- rc = i2c_get_chip_for_busnum(0, 0x5D, 1, &i2cdev);
- if (rc >= 0)
rc = dm_i2c_write(i2cdev, 0xEF, NULL, 0);
- if (rc != 0)
printf("WARN: cannot write to LEDs!\n");
+int board_eth_init(bd_t *bis) +{
is this really used? With DM this should be gone.
+int dram_init(void) +{
- int node;
- fdt_addr_t addr;
- fdt_size_t size;
- const void *blob = gd->fdt_blob;
- node = fdt_node_offset_by_prop_value(blob, -1, "device_type",
"memory", 7);
- if (node == -FDT_ERR_NOTFOUND) {
debug("ZYNQ DRAM: Can't get memory node\n");
return -1;
- addr = fdtdec_get_addr_size(blob, node, "reg", &size);
- if (addr == FDT_ADDR_T_NONE || size == 0) {
debug("ZYNQ DRAM: Can't get base address or size\n");
return -1;
- gd->ram_size = get_ram_size((void *)addr, size);
- zynq_ddrc_init();
This is just hybrid between DT/non DT case. Look at zynq boards and choose one. If you have two boards you can just use fixed case for 512MB version.
+} diff --git a/board/BuR/zynq/brsmarc2/ps7_init_gpl.c b/board/BuR/zynq/brsmarc2/ps7_init_gpl.c new file mode 100644 index 0000000..a44c9d2 --- /dev/null +++ b/board/BuR/zynq/brsmarc2/ps7_init_gpl.c @@ -0,0 +1,814 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include <asm/arch/ps7_init_gpl.h>
+unsigned long ps7_pll_init_data_3_0[] = {
- EMIT_WRITE(0XF8000008, 0x0000DF0DU),
- EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U, 0x000FA220U),
- EMIT_MASKWRITE(0XF8000100, 0x0007F000U, 0x00028000U),
- EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000010U),
- EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000000U),
- EMIT_MASKPOLL(0XF800010C, 0x00000001U),
- EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000000U),
- EMIT_MASKWRITE(0XF8000120, 0x1F003F30U, 0x1F000200U),
- EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U, 0x0012C220U),
- EMIT_MASKWRITE(0XF8000104, 0x0007F000U, 0x00020000U),
- EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000010U),
- EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000000U),
- EMIT_MASKPOLL(0XF800010C, 0x00000002U),
- EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000000U),
- EMIT_MASKWRITE(0XF8000124, 0xFFF00003U, 0x0C200003U),
- EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U, 0x001452C0U),
- EMIT_MASKWRITE(0XF8000108, 0x0007F000U, 0x0001E000U),
- EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000010U),
- EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000000U),
- EMIT_MASKPOLL(0XF800010C, 0x00000004U),
- EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000000U),
- EMIT_WRITE(0XF8000004, 0x0000767BU),
- EMIT_EXIT(),
+unsigned long ps7_clock_init_data_3_0[] = {
- EMIT_MASKWRITE(0XF8000128, 0x03F03F01U, 0x00700F01U),
- EMIT_MASKWRITE(0XF8000138, 0x00000011U, 0x00000001U),
- EMIT_MASKWRITE(0XF800013C, 0x00000011U, 0x00000011U),
- EMIT_MASKWRITE(0XF8000140, 0x03F03F71U, 0x00500801U),
- EMIT_MASKWRITE(0XF8000144, 0x03F03F71U, 0x00500141U),
- EMIT_MASKWRITE(0XF800014C, 0x00003F31U, 0x00000501U),
- EMIT_MASKWRITE(0XF8000150, 0x00003F33U, 0x00000A01U),
- EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A01U),
- EMIT_MASKWRITE(0XF8000158, 0x00003F33U, 0x00000503U),
- EMIT_MASKWRITE(0XF800015C, 0x03F03F33U, 0x00501903U),
- EMIT_MASKWRITE(0XF8000160, 0x007F007FU, 0x00000000U),
- EMIT_MASKWRITE(0XF8000168, 0x00003F31U, 0x00000501U),
- EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00400500U),
- EMIT_MASKWRITE(0XF80001C4, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU, 0x01DFC4CDU),
- EMIT_EXIT(),
+unsigned long ps7_ddr_init_data_3_0[] = {
- EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000080U),
- EMIT_MASKWRITE(0XF8006004, 0x0007FFFFU, 0x00001040U),
- EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU, 0x03C0780FU),
- EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU, 0x02001001U),
- EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU, 0x00014001U),
- EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU, 0x00040EDAU),
- EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU, 0x44D258D4U),
- EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU, 0xB2024127U),
- EMIT_MASKWRITE(0XF8006020, 0x7FDFFFFCU, 0x2B08B290U),
- EMIT_MASKWRITE(0XF8006024, 0x0FFFFFC3U, 0x00000000U),
- EMIT_MASKWRITE(0XF8006028, 0x00003FFFU, 0x00002007U),
- EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU, 0x00000018U),
- EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU, 0x00040970U),
- EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x000116D4U),
- EMIT_MASKWRITE(0XF8006038, 0x00000003U, 0x00000000U),
- EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU, 0x00000777U),
- EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU, 0xFFF00000U),
- EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU, 0x0FFF6666U),
- EMIT_MASKWRITE(0XF8006048, 0x0003F03FU, 0x0003C008U),
- EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU, 0x77010800U),
- EMIT_MASKWRITE(0XF8006058, 0x00010000U, 0x00000000U),
- EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU, 0x00005003U),
- EMIT_MASKWRITE(0XF8006060, 0x000017FFU, 0x0000003EU),
- EMIT_MASKWRITE(0XF8006064, 0x00021FE0U, 0x00020000U),
- EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU, 0x00284545U),
- EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU, 0x00001610U),
- EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU, 0x00466111U),
- EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU, 0x00032222U),
- EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU, 0x10200802U),
- EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU, 0x0690CB73U),
- EMIT_MASKWRITE(0XF80060AC, 0x000001FFU, 0x000001FEU),
- EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU),
- EMIT_MASKWRITE(0XF80060B4, 0x00000200U, 0x00000200U),
- EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU, 0x0020006AU),
- EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000000U),
- EMIT_MASKWRITE(0XF80060C8, 0x000000FFU, 0x00000000U),
- EMIT_MASKWRITE(0XF80060DC, 0x00000001U, 0x00000000U),
- EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU, 0x00000000U),
- EMIT_MASKWRITE(0XF80060F4, 0x0000000FU, 0x00000008U),
- EMIT_MASKWRITE(0XF8006114, 0x000000FFU, 0x00000000U),
- EMIT_MASKWRITE(0XF8006118, 0x7FFFFFCFU, 0x40000001U),
- EMIT_MASKWRITE(0XF800611C, 0x7FFFFFCFU, 0x40000001U),
- EMIT_MASKWRITE(0XF8006120, 0x7FFFFFCFU, 0x40000001U),
- EMIT_MASKWRITE(0XF8006124, 0x7FFFFFCFU, 0x40000001U),
- EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU, 0x0001D400U),
- EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU, 0x0001C400U),
- EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU, 0x0001BC00U),
- EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU, 0x0001C800U),
- EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU, 0x00000035U),
- EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU, 0x00000035U),
- EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU, 0x00000035U),
- EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU, 0x00000035U),
- EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU, 0x0000007AU),
- EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU, 0x0000007DU),
- EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU, 0x00000080U),
- EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU, 0x0000007EU),
- EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU, 0x000000CAU),
- EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU, 0x000000C6U),
- EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU, 0x000000C4U),
- EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU, 0x000000C7U),
- EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU, 0x000000BAU),
- EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU, 0x000000BDU),
- EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU, 0x000000C0U),
- EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU, 0x000000BEU),
- EMIT_MASKWRITE(0XF8006190, 0x6FFFFEFEU, 0x00040080U),
- EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU, 0x0001FD04U),
- EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU, 0x00000000U),
- EMIT_MASKWRITE(0XF8006208, 0x000703FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF800620C, 0x000703FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF8006210, 0x000703FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF8006214, 0x000703FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF8006218, 0x000F03FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF800621C, 0x000F03FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF8006220, 0x000F03FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF8006224, 0x000F03FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF80062A8, 0x00000FF5U, 0x00000000U),
- EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU, 0x00000000U),
- EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU, 0x00005125U),
- EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU, 0x000012A8U),
- EMIT_MASKPOLL(0XF8000B74, 0x00002000U),
- EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000081U),
- EMIT_MASKPOLL(0XF8006054, 0x00000007U),
- EMIT_EXIT(),
+unsigned long ps7_mio_init_data_3_0[] = {
- EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU, 0x00000600U),
- EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU, 0x00000600U),
- EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU, 0x00000672U),
- EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU, 0x00000672U),
- EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU, 0x00000674U),
- EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU, 0x00000674U),
- EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU, 0x00000600U),
- EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU, 0x0018C068U),
- EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU, 0x00F98068U),
- EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU, 0x00F98068U),
- EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU, 0x00F98068U),
- EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU, 0x00000260U),
- EMIT_MASKWRITE(0XF8000B70, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000020U),
- EMIT_MASKWRITE(0XF8000B70, 0x07FEFFFFU, 0x00000823U),
- EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00000700U),
- EMIT_MASKWRITE(0XF8000704, 0x00003FFFU, 0x00000702U),
- EMIT_MASKWRITE(0XF8000708, 0x00003FFFU, 0x00000702U),
- EMIT_MASKWRITE(0XF800070C, 0x00003FFFU, 0x00000702U),
- EMIT_MASKWRITE(0XF8000710, 0x00003FFFU, 0x00000702U),
- EMIT_MASKWRITE(0XF8000714, 0x00003FFFU, 0x00000702U),
- EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000702U),
- EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000700U),
- EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x00000702U),
- EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x00000700U),
- EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x000007A0U),
- EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x000007A0U),
- EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x000007A0U),
- EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x000007A0U),
- EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x000016E1U),
- EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x000006E0U),
- EMIT_MASKWRITE(0XF8000740, 0x00003FFFU, 0x00000302U),
- EMIT_MASKWRITE(0XF8000744, 0x00003FFFU, 0x00000302U),
- EMIT_MASKWRITE(0XF8000748, 0x00003FFFU, 0x00000302U),
- EMIT_MASKWRITE(0XF800074C, 0x00003FFFU, 0x00000302U),
- EMIT_MASKWRITE(0XF8000750, 0x00003FFFU, 0x00000302U),
- EMIT_MASKWRITE(0XF8000754, 0x00003FFFU, 0x00000302U),
- EMIT_MASKWRITE(0XF8000758, 0x00003FFFU, 0x00000303U),
- EMIT_MASKWRITE(0XF800075C, 0x00003FFFU, 0x00000303U),
- EMIT_MASKWRITE(0XF8000760, 0x00003FFFU, 0x00000303U),
- EMIT_MASKWRITE(0XF8000764, 0x00003FFFU, 0x00000303U),
- EMIT_MASKWRITE(0XF8000768, 0x00003FFFU, 0x00000303U),
- EMIT_MASKWRITE(0XF800076C, 0x00003FFFU, 0x00000303U),
- EMIT_MASKWRITE(0XF8000770, 0x00003FFFU, 0x00000204U),
- EMIT_MASKWRITE(0XF8000774, 0x00003FFFU, 0x00000205U),
- EMIT_MASKWRITE(0XF8000778, 0x00003FFFU, 0x00000204U),
- EMIT_MASKWRITE(0XF800077C, 0x00003FFFU, 0x00000205U),
- EMIT_MASKWRITE(0XF8000780, 0x00003FFFU, 0x00000204U),
- EMIT_MASKWRITE(0XF8000784, 0x00003FFFU, 0x00000204U),
- EMIT_MASKWRITE(0XF8000788, 0x00003FFFU, 0x00000204U),
- EMIT_MASKWRITE(0XF800078C, 0x00003FFFU, 0x00000204U),
- EMIT_MASKWRITE(0XF8000790, 0x00003FFFU, 0x00000205U),
- EMIT_MASKWRITE(0XF8000794, 0x00003FFFU, 0x00000204U),
- EMIT_MASKWRITE(0XF8000798, 0x00003FFFU, 0x00000204U),
- EMIT_MASKWRITE(0XF800079C, 0x00003FFFU, 0x00000204U),
- EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU, 0x00000380U),
- EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU, 0x00000380U),
- EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU, 0x00000380U),
- EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU, 0x00000380U),
- EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU, 0x00000380U),
- EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00000380U),
- EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x00000321U),
- EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU, 0x00000320U),
- EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU, 0x00000320U),
- EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x00000321U),
- EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00000340U),
- EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00000340U),
- EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU, 0x00000280U),
- EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU, 0x00000280U),
- EMIT_MASKWRITE(0XF8000830, 0x003F003FU, 0x00380037U),
- EMIT_EXIT(),
+unsigned long ps7_peripherals_init_data_3_0[] = {
- EMIT_MASKWRITE(0XF8000B48, 0x00000180U, 0x00000180U),
- EMIT_MASKWRITE(0XF8000B4C, 0x00000180U, 0x00000180U),
- EMIT_MASKWRITE(0XF8000B50, 0x00000180U, 0x00000180U),
- EMIT_MASKWRITE(0XF8000B54, 0x00000180U, 0x00000180U),
- EMIT_MASKWRITE(0XE0000034, 0x000000FFU, 0x00000006U),
- EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU, 0x0000007CU),
- EMIT_MASKWRITE(0XE0000000, 0x000001FFU, 0x00000017U),
- EMIT_MASKWRITE(0XE0000004, 0x000003FFU, 0x00000020U),
- EMIT_MASKWRITE(0XE000D000, 0x00080000U, 0x00080000U),
- EMIT_MASKWRITE(0XF8007000, 0x20000000U, 0x00000000U),
- EMIT_MASKDELAY(0XF8F00200, 1),
- EMIT_EXIT(),
+unsigned long ps7_post_config_3_0[] = {
- EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU),
- EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU, 0x00000000U),
- EMIT_EXIT(),
+unsigned long ps7_pll_init_data_2_0[] = {
- EMIT_EXIT(),
+unsigned long ps7_clock_init_data_2_0[] = {
- EMIT_EXIT(),
+unsigned long ps7_ddr_init_data_2_0[] = {
- EMIT_MASKWRITE(0XF8006004, 0x1FFFFFFFU, 0x00081040U),
- EMIT_MASKWRITE(0XF8006020, 0xFFFFFFFCU, 0x2B28B290U),
- EMIT_MASKWRITE(0XF8006024, 0x0FFFFFFFU, 0x0000003CU),
- EMIT_MASKWRITE(0XF8006038, 0x00001FC3U, 0x00000000U),
- EMIT_MASKWRITE(0XF8006048, 0x3FFFFFFFU, 0x0003C248U),
- EMIT_MASKWRITE(0XF8006058, 0x0001FFFFU, 0x00000101U),
- EMIT_MASKWRITE(0XF80060A0, 0x00FFFFFFU, 0x00008000U),
- EMIT_MASKWRITE(0XF80060B4, 0x000007FFU, 0x00000200U),
- EMIT_MASKWRITE(0XF8006118, 0x7FFFFFFFU, 0x40000001U),
- EMIT_MASKWRITE(0XF800611C, 0x7FFFFFFFU, 0x40000001U),
- EMIT_MASKWRITE(0XF8006120, 0x7FFFFFFFU, 0x40000001U),
- EMIT_MASKWRITE(0XF8006124, 0x7FFFFFFFU, 0x40000001U),
- EMIT_MASKWRITE(0XF8006190, 0xFFFFFFFFU, 0x10040080U),
- EMIT_MASKWRITE(0XF8006208, 0x000F03FFU, 0x000803FFU),
- EMIT_MASKWRITE(0XF800620C, 0x000F03FFU, 0x000803FFU),
- EMIT_MASKWRITE(0XF8006210, 0x000F03FFU, 0x000803FFU),
- EMIT_MASKWRITE(0XF8006214, 0x000F03FFU, 0x000803FFU),
- EMIT_MASKWRITE(0XF80062A8, 0x00000FF7U, 0x00000000U),
- EMIT_EXIT(),
+unsigned long ps7_mio_init_data_2_0[] = {
- EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000021U),
- EMIT_MASKWRITE(0XF8000B70, 0x07FFFFFFU, 0x00000823U),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XE0000004, 0x00000FFFU, 0x00000020U),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XF8000B6C, 0x000073FFU, 0x00000260U),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- unsigned long mask = 0xF0000000;
- unsigned long *addr = (unsigned long *)0XF8007080;
- unsigned long ps_version = (*addr & mask) >> 28;
- return ps_version;
- unsigned long si_ver = get_ps7_siliconversion();
- int ret = -1;
- if (si_ver == PCW_SILICON_VERSION_1) {
return ret;
- } else if (si_ver == PCW_SILICON_VERSION_2) {
return ret;
I don't think you are using v1 silicon and I would be very very surprised if you use v2 silicon also. This should be production silicon that's why just keep stuff for v3 only.
- } else {
return ret;
- return PS7_INIT_SUCCESS;
- int ret;
- } else {
ditto.
- ret = ps7_config(ps7_mio_init_data);
- if (ret != PS7_INIT_SUCCESS)
return ret;
- ret = ps7_config(ps7_pll_init_data);
return ret;
- ret = ps7_config(ps7_clock_init_data);
return ret;
- ret = ps7_config(ps7_ddr_init_data);
return ret;
- ret = ps7_config(ps7_peripherals_init_data);
return ret;
+} diff --git a/board/BuR/zynq/brsmarc2_r512/board.c b/board/BuR/zynq/brsmarc2_r512/board.c new file mode 100644 index 0000000..a70c2aa --- /dev/null +++ b/board/BuR/zynq/brsmarc2_r512/board.c @@ -0,0 +1,2 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include "../brsmarc2/board.c" diff --git a/board/BuR/zynq/brsmarc2_r512/ps7_init_gpl.c b/board/BuR/zynq/brsmarc2_r512/ps7_init_gpl.c new file mode 100644 index 0000000..8bda095 --- /dev/null +++ b/board/BuR/zynq/brsmarc2_r512/ps7_init_gpl.c @@ -0,0 +1,813 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include <asm/arch/ps7_init_gpl.h>
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU, 0x0004159AU),
- EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU, 0x0FF66666U),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- int ret = -1;
return ret;
return ret;
- } else {
return ret;
- int ret;
- } else {
return ret;
return ret;
return ret;
return ret;
return ret;
- dd if=/dev/zero bs=1 count=${flen_min} 2>/dev/null | tr "\000" "\377" >$@ && \
- dd conv=notrunc bs=1 if=spl/boot.bin of=$@ seek=0 2>/dev/null && \
- test -z ${fpga_src} && dd conv=notrunc bs=1 if=u-boot-dtb.img of=$@ seek=$(payload_off) 2>/dev/null && \
- test -z ${fpga_src} || ( \
- test -d misc && rm -r misc; \
- mkdir misc && \
- cp spl/boot.bin misc/ && \
- cp u-boot-dtb.img misc/ && \
- zip -9 -r $@ misc/* >/dev/null $<
What's the purpose of this code? What's your boot mode?
There shouldn't be a need to do these hacks. Just let SPL load fit with bitstream in it. SPL will load it for you without any hack.
- $(call if_changed,fpga)
- $(call if_changed,prodbin)
- $(call if_changed,prodzip)
- 's/#include "ps7_init_gpl.h"/#include <asm/arch/ps7_init_gpl.h>/g' $FILE
- -f board/BuR/zynq/$FILE --fix-inplace
+popd +rm $FILE~
:-) we should put this to xilinx folder. IIRC I was sending these steps long time ago to ML but never had time to clean it up. Anyway some documentation what this is for will be useful.
+# indent_brace = 0
- specific parts for B&R X20CP Motherboard
- Copyright (C) 2016 Hannes Schmelzer oe5hpm@oevsv.at -
you should be able to source zynq-7000.h and just change stuff what are missing there or you want to change.
- {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400}
please check if these can't be setup via Kconfig. If not feel free to move it to Kconfig first.
weird.
we are trying to get rid of these variables. Please enable distro boot and put all of these to scripts and run them.
this is definitely in Kconfig already.
There shouldn't be a need to duplicate these setups. Just use what it is there already and source common header.
M
On 5/2/19 6:06 PM, Michal Simek wrote:
Hi Michal,
I actually think not, because i need different ps7_init stuff for the two different RAM chips. (timing, adress lines, ...) But i will check if i even can drop the two different dts files.
bl-version = " ";
order-no = " ";
cpu-order-no = " ";
hw-revision = " ";
serial-no = <0>;
device-id = <0x0>;
parent-id = <0x0>;
hw-variant = <0x0>;
fram-size = <0x0>;
cpu-clock = <0x0>;
This are factory settings, used by the OS (in this case vxWorks), to identify on which hardware it runs, and have per device unique stuff (serial number). But you're right, it would be nice to have here some compatible string, i will change this. Today we just search for the node "factory-setting". A more comfortable ways would be vxFdtNodeOffsetByCompatible(....)
- aliases {
ethernet0 = &gem0;
ethernet1 = &gem1;
i2c0 = &i2c0;
serial0 = &uart0;
spi0 = &qspi;
mmc0 = &sdhci0;
fset = &fset;
can0 = &can0;
can1 = &can1;
- memory {
- board {
status = "okay";
Nowhere, because u-boot nor linux does use this, this is only for the vxWorks OS.
#size-cells = <1>;
No think not, i didn't know so far that this is necessary. But this is a very good input. Can you give me some hint where i have to go for it?
No, compatible is correct. Because i have my own (bur,) zynqPL driver in vxWorks to handle the FPGA stuff.
likely undocumented
Right, actually i have no real good documentation along the source of the opposite. The vxWorks driver who handles update in flash.
plk: plk@80000000 {
ditto
bur,hwtree = "IF9";
<0 84 4>;
x2x: x2x@40100000 {
ditoo.
0x40108000 0x8000>;
bur,hwtree = "IF8";
bur,hwtree = "IF9";
Please explain me the reason why this PL stuff cannot go mainline? Maybe a solution cold be to drop those in the mainline dts and then patch it again into it on the local branch. But that would be a way which i don't prefer.
+&gem0 {
- status = "okay";
0 mac is wrong.
No, this zeros are placeholder. The real MAC-Adresses are get into the dts during u-boot's fdt_fixup(...). They come from environment, and th environment is setup from some u-boot script.
reg = <1>;
+&gem1 {
- status = "okay";
ditto.
same as eth0.
Yes, i will provide some compatible node for the used DP83867 phy.
reg = <3>;
+&i2c0 {
- status = "okay";
reg = <0x49>;
reg = <0x4C>;
reg = <0x51>;
reg = <0x60>;
+&i2c1 {
- status = "okay";
+&sdhci0 {
- status = "okay";
+&uart0 {
- status = "okay";
+&qspi {
- status = "okay";
reg = <0>;
+&usb0 {
- status = "okay";
- dr_mode = "host";
+&gpio0 {
+&can0 {
+&can1 {
Yes, some rework is necessary and will be done. But i'm actually not the opinion that only the PS part should take place.
- memory {
- board.c
+} +#endif
- int rc;
- if (rc >= 0)
- if (rc != 0)
I will drop this, this is maybe some leftover of the early days when i started the project.
- int node;
- fdt_addr_t addr;
- fdt_size_t size;
"memory", 7);
return -1;
return -1;
- zynq_ddrc_init();
I will review this again and maybe dropping this in V3.
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
+unsigned long ps7_peripherals_init_data_2_0[] = {
- EMIT_EXIT(),
+unsigned long ps7_post_config_2_0[] = {
- EMIT_EXIT(),
+unsigned long ps7_pll_init_data_1_0[] = {
- EMIT_EXIT(),
+unsigned long ps7_clock_init_data_1_0[] = {
- EMIT_EXIT(),
+unsigned long ps7_ddr_init_data_1_0[] = {
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- int ret = -1;
return ret;
return ret;
Fine ... i will drop the older silicon version. Maybe also Xilinx could eliminate those output in vivado.
- mkdir misc && \
The main purpose is to generate at this place a 'production-binary', a binary which can be flashed into the QSPI during series production. Goal is, as often as possible, having here a very small binary - because flashing QSPI during production is time intensive and therefore expensive. It is much cheaper burning this flash out of a real OS which can drive full speed and quad mode.
Most of the time at no FPGA stuff is needed to bring up the system to a point where it can access ethernet and boot some vxWorks from there, from where several other stuff is (even the FPGA bitstream) loaded and burnt into QSPI. Also there exist cases, where the bitstream isn't within QSPI at all and always downloaded with DMA to the PL during runtime and the other extreme is that bitstream must be already programmed into flash because ethernet relies on the FPGA stuff.
+popd +rm $FILE~
Good idea, so just for clarify: drop it from this patch and clean it up a bit and create a new patch for having it within xilinx?
+# indent_brace = 0
should this walk into xilinx folder too?
i need some default environment from the bur_cfg_common. Also i don't really like to use the zynq-7000.h, because i want to stay here independent of some global configuration. Long days ago i did choose same strategy on my am335x boards, it showed up that this was the right way.
I will do so in v3.
weird.
Can you explain me more ?
No, i don't want some distro defaults ... because we've our own boot strategy.
ok. i will drop it in V3. Maybe we also need to adapt the config whitelist.
as told already, i will review again if i can use the common header without disturbing me ;-)
M
thanks again for your good review and helping me in this.
cheers, hannes
Hi Michal,
bl-version = " ";
order-no = " ";
cpu-order-no = " ";
hw-revision = " ";
serial-no = <0>;
device-id = <0x0>;
parent-id = <0x0>;
hw-variant = <0x0>;
fram-size = <0x0>;
cpu-clock = <0x0>;
- aliases {
ethernet0 = &gem0;
ethernet1 = &gem1;
i2c0 = &i2c0;
serial0 = &uart0;
spi0 = &qspi;
mmc0 = &sdhci0;
fset = &fset;
can0 = &can0;
can1 = &can1;
- memory {
- board {
status = "okay";
This is what I kinda figured was the case. We now have some interesting times ahead of us as yes, we normally think about DTS reviews in terms of Linux. But this is all for a board that uses vxWorks. Perhaps the best thing to do here is note (and for all of the other boards too, but you can wait for general feedback before v3'ing them all) in the dts comment that it's for vxWorks as people tend to assume a DTS file is for Linux (even with many counter examples).
[snip]
So, now that we're clear this is for vxWorks, "PL stuff" ? The only thing I see here that's not spelled out (but based on cursory examination of the kernel, implied as normal) is interrupt-parent as a property.
+&gem0 {
- status = "okay";
0 mac is wrong.
But we shouldn't need the node here to set the property is I think the point.
[snip]
How much of this strategy is common to all the BuR platforms? Perhaps the answer is that you should make include/environment/bur/ and put the common script in there. Thanks!
Hi Michal,
I just tried to get rid of this. But i'm still in trouble.
Actually i use the 'CONFIG_DEFAULT_DEVICE_TREE' variable within my makefile to distinguish which zynq board variant is being built, since every of those boards do have its own dts this works fine.
Does anybody know some better idea to handle this ?
cheers, Hannes
Hi Michal,
bl-version = " ";
order-no = " ";
cpu-order-no = " ";
hw-revision = " ";
serial-no = <0>;
device-id = <0x0>;
parent-id = <0x0>;
hw-variant = <0x0>;
fram-size = <0x0>;
cpu-clock = <0x0>;
- aliases {
ethernet0 = &gem0;
ethernet1 = &gem1;
i2c0 = &i2c0;
serial0 = &uart0;
spi0 = &qspi;
mmc0 = &sdhci0;
fset = &fset;
can0 = &can0;
can1 = &can1;
- memory {
- board {
status = "okay";
OK. Thanks.
would it be fine having it like this ?
/* factory-settings for the vxWorks target */ fset: factory-settings { compatible = "bur,fsetv1"; bl-version = " "; ..... };
/* misc. peripheral, used in vxWorks */ board { status = "okay"; ... };
Or might be a general description on top would be more helpful?
In general i pay attention to describe devices as generic as possible, meaning that a) syntax is correct, b) some linux or even u-boot isn't disturbed by this descriptions.
With a look to the paragraph below, the implemented UART in FPGA, is 16550 compatible, so there might be a chance that it would work with Linux as well.
[snip]
Right. The spelling about interrupt is the same as the other peripherals within the SoC (zynq-7000.dtsi).
+&gem0 {
- status = "okay";
0 mac is wrong.
OK ... i will take here "real" or at least formal correct MAC-addresses into for having a fallback if nothing is programmed at all and bring up the interface initially.
[snip]
The strategy itself (having b_mode and then try several targets) is always the same but the boot-targets itself are individual. I will start a project for catching the "core" into 'include/environment/bur/' over all BuR boards. But this will take more time than a simple rework of this patch, meaning that this will follow later on.
thanks for your time, cheers, Hannes
Hi Michal,
bl-version = " ";
order-no = " ";
cpu-order-no = " ";
hw-revision = " ";
serial-no = <0>;
device-id = <0x0>;
parent-id = <0x0>;
hw-variant = <0x0>;
fram-size = <0x0>;
cpu-clock = <0x0>;
- aliases {
ethernet0 = &gem0;
ethernet1 = &gem1;
i2c0 = &i2c0;
serial0 = &uart0;
spi0 = &qspi;
mmc0 = &sdhci0;
fset = &fset;
can0 = &can0;
can1 = &can1;
- memory {
- board {
status = "okay";
OK. Thanks.
I think a general comment at the top saying that this tree is only valid for vxWorks and U-Boot is enough detail.
wrt the UART, are there specified bindings in vxWorks? That seems like a case where the DTS needs to be valid for what U-Boot says the binding is (and in turn, what Linux does). And perhaps there's room for clarifications to those bindings.
[snip]
+&gem0 {
- status = "okay";
0 mac is wrong.
Well, what I mean is that in the code, we can add the node and should then populate it with either a "real" value that we read from something (eeprom, just the env, whatever) or a real random address. We shouldn't need to have the dts file say there's a mac-address property with all zeros, we can add that at run-time.
[snip]
I'm OK with that, thanks!
Hi Michal,
bl-version = " ";
order-no = " ";
cpu-order-no = " ";
hw-revision = " ";
serial-no = <0>;
device-id = <0x0>;
parent-id = <0x0>;
hw-variant = <0x0>;
fram-size = <0x0>;
cpu-clock = <0x0>;
- aliases {
ethernet0 = &gem0;
ethernet1 = &gem1;
i2c0 = &i2c0;
serial0 = &uart0;
spi0 = &qspi;
mmc0 = &sdhci0;
fset = &fset;
can0 = &can0;
can1 = &can1;
- memory {
- board {
status = "okay";
OK. Thanks.
It would be much better to simply put vxworks stuff to one dtsi file and common stuff to another. That it will be clear what it is vxworks part and what it is common.
I think we need to get more clarity what exactly vxworks expects and what are just your "hacks" to get it work. If vxworks deviates existing dt binding, or create completely new one.
[snip]
+&gem0 {
- status = "okay";
0 mac is wrong.
+1
[snip]
Zynq/ZynqMP code prioritize bootmode with distro boot. I personally want to have less include/configs/* files for the same type of boards. It means do whatever you want but wire that via scripts. Let distro boot to load your scripts and do that stuff there. And I also have no problem to have these scripts in u-boot to show others what you do.
Thanks, Michal
On Fri, May 03, 2019 at 09:29:32AM -0700, Michal Simek wrote: [snip]
Hold up. If it's not in the spec itself (and most stuff is not), the Linux bindings are no more authoritative than the BSD ones (which are also not, unless things have changed, the Linux ones) than the vxWorks ones than anything else. For a board that is not supported in Linux, I don't think it makes sense to treat the primary OS support as something that's added to another DT.
And in yet another case of "check, then send, NOT send, then check", I see FreeBSD has changed. vxWorks however has not it would seem.
This board is using u-boot which is using linux binding. It means this should be IMHO in separate file from the rest what vxworks expects. Then we can review u-boot configurations properly.
Thanks, Michal
I see. I've always looked at it as "primary OS + u-boot additions in another file". When we use bindings they are the Linux ones, yes (when they aren't our own things). I've always seen it as making sync with the authoritative DTS for the HW easy as why we copy Linux and add to it. The end goal to me is to make sure that DTS maintenance is easy on the HW owner.
But still you can do right split with soc dtsi/clock dtsi/board/vxworks.
And we have done a decision long time ago in Linux and also the same decision was taken to u-boot that mainline DT file won't contain any fpga/pl description. If you still want to do it that you should pack dt overlay with bitstream to FIT and let u-boot to do the job. But this PL overlay shouldn't land in mainline.
Thanks, Michal
Hi Michal,
On 02. 05. 19 5:14, Hannes Schmelzer wrote: > diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile > index dfa5b02..2b00129 100644 > --- a/arch/arm/dts/Makefile > +++ b/arch/arm/dts/Makefile > @@ -208,6 +208,8 @@ dtb-$(CONFIG_ARCH_ZYNQ) += \ > zynq-zc770-xm011-x16.dtb \ > zynq-zc770-xm012.dtb \ > zynq-zc770-xm013.dtb \ > + zynq-brsmarc2.dtb \ > + zynq-brsmarc2_r512.dtb \ Can't you detect it if you have 512M version? u-boot itself has code for these kind of detection.
> +/ { > + model = "BRSMARC2 Zynq SoM"; > + compatible = "xlnx,zynq-7000"; > + > + fset: factory-settings { > + bl-version = " "; > + order-no = " "; > + cpu-order-no = " "; > + hw-revision = " "; > + serial-no = <0>; > + device-id = <0x0>; > + parent-id = <0x0>; > + hw-variant = <0x0>; > + hw-platform = <0x0>; > + fram-offset = <0x0>; > + fram-size = <0x0>; > + cache-disable = <0x0>; > + cpu-clock = <0x0>; > + }; What's this? No compatible string. This looks quite hacky.
> + > + aliases { > + ethernet0 = &gem0; > + ethernet1 = &gem1; > + i2c0 = &i2c0; > + serial0 = &uart0; > + spi0 = &qspi; > + mmc0 = &sdhci0; > + fset = &fset; > + can0 = &can0; > + can1 = &can1; > + }; > + > + memory { > + device_type = "memory"; > + reg = <0x0 0x10000000>; > + }; > + > + board { > + status = "okay"; > + compatible = "bur,brsmarc2-som"; > + usb0mux-gpios = <&gpio0 68 GPIO_ACTIVE_HIGH>; > + usb1mux-gpios = <&gpio0 69 GPIO_ACTIVE_HIGH>; > + powerdown-gpios = <&gpio0 0 GPIO_ACTIVE_LOW>; > + reset-gpios = <&gpio0 9 GPIO_ACTIVE_LOW>; > + }; Where is mainline dt binding for this?
OK. Thanks.
Okay, i will do so like this: /* * This devicetree is only valid for u-boot and the primary OS (vxWorks 6.9.4.x) * of this board. */
actually i think the UART is described valid in the fdt and can be used by u-boot or linux as well even i've not tested it yet.
One thing to say is, that vxWorks 6.9.4.x doesn't support fdt out of the box. All the support and usage of fdt within 6.9.4.x is introduced or backported from vxWorks 7 (which is based on fdt, even with their own and mostly different bindings) by myself - so called my "hacks" - because i don't want have thousand of different vxWorks images for one board in various only very little different hw-variants. Excactly for this purpose is the fdt.
My thinking of the dts file for a board is that it should be good readable and easy maintainable by the board maintainer - in this case it's me. So splitting it up into one more file does only degrade readability.
[snip]
> + uart5: serial@40200A00 { > + status = "disabled"; > + compatible = "ns16550a", "bur,DdVxSf16x5xIO"; > + bur,hwtree = "IF21"; > + reg = <0x40200A00 0x40>; > + interrupt-parent = <&intc>; > + interrupts = <0 90 4>; > + }; all these PL stuff can't go to mainline.
> +&gem0 { > + status = "okay"; > + phy-mode = "rgmii-id"; > + phy-handle = <ðernet_phy0>; > + mac-address = [ 00 00 00 00 00 00 ]; 0 mac is wrong.
+1
OK ... will be modified in cooming soon V3.
[snip]
> +"scradr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ > +"dtbaddr=0x4000000\0" \ > +"loadaddr=0x2000000\0" \ > +"fpgaaddr=fdt get value fpgabase /fpga bur,updaddr;" \ > +" fdt get value fpgasize /fpga bur,updsize\0" \ > +"fpga=setenv fpgastatus disabled; run fpgaaddr;" \ > +" sf read ${loadaddr} ${fpgabase} ${fpgasize} &&" \ > +" fpga loadb 0 ${loadaddr} ${fpgasize} && setenv fpgastatus okay\0" \ > +"fpgastatus=disabled\0" \ > +"fpgaupd=run fpgaaddr && tftp ${loadaddr} X20CP04xx.bit &&" \ > +" sf erase ${fpgabase} +${filesize} &&" \ > +" sf write ${loadaddr} ${fpgabase} ${filesize}\0" \ > +"netupd=tftp ${loadaddr} boot.bin && sf probe &&" \ > +" sf erase 0 +${filesize} && sf write ${loadaddr} 0 ${filesize} &&" \ > +" tftp ${loadaddr} u-boot-dtb.img &&" \ > +" sf erase 0x40000 +${filesize} && sf write ${loadaddr} 0x40000 ${filesize}\0" \ > +"cfgscr=mw ${dtbaddr} 0;" \ > +" sf probe && sf read ${scradr} 0xC0000 0x10000 && source ${scradr};" \ > +" fdt addr ${dtbaddr} || cp ${fdtcontroladdr} ${dtbaddr} 4000\0" \ > +"vxargs=setenv bootargs gem(0,0)host:vxWorks h=${serverip}" \ > +" e=${ipaddr}:${netmask} g=${gatewayip} u=vxWorksFTP pw=vxWorks\0" \ > +"vxfdt=fdt addr ${dtbaddr}; fdt resize 0x10000;" \ > +" fdt set /fpga status ${fpgastatus};" \ > +" fdt boardsetup\0" \ > +"startvx=run vxargs && mw 0x1100 0 && run vxfdt &&" \ > +" bootm ${loadaddr} - ${dtbaddr}\0" \ > +"b_break=0\0" \ > +"b_tgts_std=mmc spi usb0 net0 net1\0" \ > +"b_tgts_rcy=spi usb0 net0 net1\0" \ > +"b_tgts_pme=usb0 net0 net1 mmc spi\0" \ > +"b_deftgts=if test ${b_mode} = 12; then setenv b_tgts ${b_tgts_pme};" \ > +" elif test ${b_mode} = 0; then setenv b_tgts ${b_tgts_rcy};" \ > +" else setenv b_tgts ${b_tgts_std}; fi\0" \ > +"b_mmc=run fpga; mmc dev 0; load mmc 0 ${loadaddr} arimg && run startvx\0" \ > +"b_spi=run fpga; sf read ${loadaddr} 900000 700000 && run startvx\0" \ > +"b_net0=tftp ${scradr} netscr-brsmarc2-${board_id}.img && source ${scradr}\0" \ > +"b_net1=tftp ${scradr} netscript.img && source ${scradr}\0" \ > +"b_usb0=usb start && load usb 0 ${scradr} bootscr.img && source ${scradr}\0" \ > +"b_default=run b_deftgts; for target in ${b_tgts};"\ > +" do run b_${target}; if test ${b_break} = 1; then; exit; fi; done\0" we are trying to get rid of these variables. Please enable distro boot and put all of these to scripts and run them.
I think that the existing code doesn't fit to my needs. I have here some resetcontroller and/or gpios below which tell me how to boot. This is really specific to b&r boards. So i will walk the above.
But i will take up the idea for having different scripts which run on different boot targets. As told already i have too look here over all "my" b&r boards and not only the zynq board for having a standard how b&r boards are working.
Thanks, Michal
thanks for your time and valuable input, cheers, Hannes
On 5/2/19 6:06 PM, Michal Simek wrote: > Hi, Hi Michal, > On 02. 05. 19 5:14, Hannes Schmelzer wrote: >> diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile >> index dfa5b02..2b00129 100644 >> --- a/arch/arm/dts/Makefile >> +++ b/arch/arm/dts/Makefile >> @@ -208,6 +208,8 @@ dtb-$(CONFIG_ARCH_ZYNQ) += \ >> zynq-zc770-xm011-x16.dtb \ >> zynq-zc770-xm012.dtb \ >> zynq-zc770-xm013.dtb \ >> + zynq-brsmarc2.dtb \ >> + zynq-brsmarc2_r512.dtb \ > Can't you detect it if you have 512M version? > u-boot itself has code for these kind of detection. > > long get_ram_size(long *base, long maxsize) I actually think not, because i need different ps7_init stuff for the two different RAM chips. (timing, adress lines, ...) But i will check if i even can drop the two different dts files. >> +/ { >> + model = "BRSMARC2 Zynq SoM"; >> + compatible = "xlnx,zynq-7000"; >> + >> + fset: factory-settings { >> + bl-version = " "; >> + order-no = " "; >> + cpu-order-no = " "; >> + hw-revision = " "; >> + serial-no = <0>; >> + device-id = <0x0>; >> + parent-id = <0x0>; >> + hw-variant = <0x0>; >> + hw-platform = <0x0>; >> + fram-offset = <0x0>; >> + fram-size = <0x0>; >> + cache-disable = <0x0>; >> + cpu-clock = <0x0>; >> + }; > What's this? No compatible string. This looks quite hacky. This are factory settings, used by the OS (in this case vxWorks), to identify on which hardware it runs, and have per device unique stuff (serial number). But you're right, it would be nice to have here some compatible string, i will change this. Today we just search for the node "factory-setting". A more comfortable ways would be vxFdtNodeOffsetByCompatible(....) >> + >> + aliases { >> + ethernet0 = &gem0; >> + ethernet1 = &gem1; >> + i2c0 = &i2c0; >> + serial0 = &uart0; >> + spi0 = &qspi; >> + mmc0 = &sdhci0; >> + fset = &fset; >> + can0 = &can0; >> + can1 = &can1; >> + }; >> + >> + memory { >> + device_type = "memory"; >> + reg = <0x0 0x10000000>; >> + }; >> + >> + board { >> + status = "okay"; >> + compatible = "bur,brsmarc2-som"; >> + usb0mux-gpios = <&gpio0 68 GPIO_ACTIVE_HIGH>; >> + usb1mux-gpios = <&gpio0 69 GPIO_ACTIVE_HIGH>; >> + powerdown-gpios = <&gpio0 0 GPIO_ACTIVE_LOW>; >> + reset-gpios = <&gpio0 9 GPIO_ACTIVE_LOW>; >> + }; > Where is mainline dt binding for this? Nowhere, because u-boot nor linux does use this, this is only for the vxWorks OS.
OK. Thanks.
I don't agree with this. It is not only for you. We are doing all reviews to have codebase nice and clean. And adding hacky code(C/asm/dt) to u-boot because it is used only one person is simply bad thing to do.
>> +"scradr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ >> +"dtbaddr=0x4000000\0" \ >> +"loadaddr=0x2000000\0" \ >> +"fpgaaddr=fdt get value fpgabase /fpga bur,updaddr;" \ >> +" fdt get value fpgasize /fpga bur,updsize\0" \ >> +"fpga=setenv fpgastatus disabled; run fpgaaddr;" \ >> +" sf read ${loadaddr} ${fpgabase} ${fpgasize} &&" \ >> +" fpga loadb 0 ${loadaddr} ${fpgasize} && setenv fpgastatus >> okay\0" \ >> +"fpgastatus=disabled\0" \ >> +"fpgaupd=run fpgaaddr && tftp ${loadaddr} X20CP04xx.bit &&" \ >> +" sf erase ${fpgabase} +${filesize} &&" \ >> +" sf write ${loadaddr} ${fpgabase} ${filesize}\0" \ >> +"netupd=tftp ${loadaddr} boot.bin && sf probe &&" \ >> +" sf erase 0 +${filesize} && sf write ${loadaddr} 0 ${filesize} >> &&" \ >> +" tftp ${loadaddr} u-boot-dtb.img &&" \ >> +" sf erase 0x40000 +${filesize} && sf write ${loadaddr} 0x40000 >> ${filesize}\0" \ >> +"cfgscr=mw ${dtbaddr} 0;" \ >> +" sf probe && sf read ${scradr} 0xC0000 0x10000 && source >> ${scradr};" \ >> +" fdt addr ${dtbaddr} || cp ${fdtcontroladdr} ${dtbaddr} 4000\0" \ >> +"vxargs=setenv bootargs gem(0,0)host:vxWorks h=${serverip}" \ >> +" e=${ipaddr}:${netmask} g=${gatewayip} u=vxWorksFTP >> pw=vxWorks\0" \ >> +"vxfdt=fdt addr ${dtbaddr}; fdt resize 0x10000;" \ >> +" fdt set /fpga status ${fpgastatus};" \ >> +" fdt boardsetup\0" \ >> +"startvx=run vxargs && mw 0x1100 0 && run vxfdt &&" \ >> +" bootm ${loadaddr} - ${dtbaddr}\0" \ >> +"b_break=0\0" \ >> +"b_tgts_std=mmc spi usb0 net0 net1\0" \ >> +"b_tgts_rcy=spi usb0 net0 net1\0" \ >> +"b_tgts_pme=usb0 net0 net1 mmc spi\0" \ >> +"b_deftgts=if test ${b_mode} = 12; then setenv b_tgts >> ${b_tgts_pme};" \ >> +" elif test ${b_mode} = 0; then setenv b_tgts ${b_tgts_rcy};" \ >> +" else setenv b_tgts ${b_tgts_std}; fi\0" \ >> +"b_mmc=run fpga; mmc dev 0; load mmc 0 ${loadaddr} arimg && run >> startvx\0" \ >> +"b_spi=run fpga; sf read ${loadaddr} 900000 700000 && run >> startvx\0" \ >> +"b_net0=tftp ${scradr} netscr-brsmarc2-${board_id}.img && >> source ${scradr}\0" \ >> +"b_net1=tftp ${scradr} netscript.img && source ${scradr}\0" \ >> +"b_usb0=usb start && load usb 0 ${scradr} bootscr.img && source >> ${scradr}\0" \ >> +"b_default=run b_deftgts; for target in ${b_tgts};"\ >> +" do run b_${target}; if test ${b_break} = 1; then; exit; fi; >> done\0" > we are trying to get rid of these variables. Please enable distro > boot > and put all of these to scripts and run them. No, i don't want some distro defaults ... because we've our own boot strategy.
Then fix it.
Then do it properly and it can be useful for others too
Ok. Looking forward for v3.
Thanks, Michal
On Thu, May 02, 2019 at 08:34:32PM +0200, Hannes Schmelzer wrote: > On 5/2/19 6:06 PM, Michal Simek wrote: >> Hi, > Hi Michal, >> On 02. 05. 19 5:14, Hannes Schmelzer wrote: >>> diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile >>> index dfa5b02..2b00129 100644 >>> --- a/arch/arm/dts/Makefile >>> +++ b/arch/arm/dts/Makefile >>> @@ -208,6 +208,8 @@ dtb-$(CONFIG_ARCH_ZYNQ) += \ >>> zynq-zc770-xm011-x16.dtb \ >>> zynq-zc770-xm012.dtb \ >>> zynq-zc770-xm013.dtb \ >>> + zynq-brsmarc2.dtb \ >>> + zynq-brsmarc2_r512.dtb \ >> Can't you detect it if you have 512M version? >> u-boot itself has code for these kind of detection. >> >> long get_ram_size(long *base, long maxsize) > I actually think not, > because i need different ps7_init stuff for the two different RAM > chips. > (timing, adress lines, ...) But i will check if i even can drop > the two > different dts files. >>> +/ { >>> + model = "BRSMARC2 Zynq SoM"; >>> + compatible = "xlnx,zynq-7000"; >>> + >>> + fset: factory-settings { >>> + bl-version = " "; >>> + order-no = " "; >>> + cpu-order-no = " "; >>> + hw-revision = " "; >>> + serial-no = <0>; >>> + device-id = <0x0>; >>> + parent-id = <0x0>; >>> + hw-variant = <0x0>; >>> + hw-platform = <0x0>; >>> + fram-offset = <0x0>; >>> + fram-size = <0x0>; >>> + cache-disable = <0x0>; >>> + cpu-clock = <0x0>; >>> + }; >> What's this? No compatible string. This looks quite hacky. > This are factory settings, used by the OS (in this case vxWorks), > to identify on which hardware it runs, and have per device unique > stuff > (serial number). > But you're right, it would be nice to have here some compatible > string, > i will change this. Today we just search for the node > "factory-setting". > A more comfortable ways would be vxFdtNodeOffsetByCompatible(....) >>> + >>> + aliases { >>> + ethernet0 = &gem0; >>> + ethernet1 = &gem1; >>> + i2c0 = &i2c0; >>> + serial0 = &uart0; >>> + spi0 = &qspi; >>> + mmc0 = &sdhci0; >>> + fset = &fset; >>> + can0 = &can0; >>> + can1 = &can1; >>> + }; >>> + >>> + memory { >>> + device_type = "memory"; >>> + reg = <0x0 0x10000000>; >>> + }; >>> + >>> + board { >>> + status = "okay"; >>> + compatible = "bur,brsmarc2-som"; >>> + usb0mux-gpios = <&gpio0 68 GPIO_ACTIVE_HIGH>; >>> + usb1mux-gpios = <&gpio0 69 GPIO_ACTIVE_HIGH>; >>> + powerdown-gpios = <&gpio0 0 GPIO_ACTIVE_LOW>; >>> + reset-gpios = <&gpio0 9 GPIO_ACTIVE_LOW>; >>> + }; >> Where is mainline dt binding for this? > Nowhere, because u-boot nor linux does use this, > this is only for the vxWorks OS. This is what I kinda figured was the case. We now have some interesting times ahead of us as yes, we normally think about DTS reviews in terms of Linux. But this is all for a board that uses vxWorks. Perhaps the best thing to do here is note (and for all of the other boards too, but you can wait for general feedback before v3'ing them all) in the dts comment that it's for vxWorks as people tend to assume a DTS file is for Linux (even with many counter examples).
OK. Thanks.
OK. i will split them up. have a look to V3.
>>> +"scradr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ >>> +"dtbaddr=0x4000000\0" \ >>> +"loadaddr=0x2000000\0" \ >>> +"fpgaaddr=fdt get value fpgabase /fpga bur,updaddr;" \ >>> +" fdt get value fpgasize /fpga bur,updsize\0" \ >>> +"fpga=setenv fpgastatus disabled; run fpgaaddr;" \ >>> +" sf read ${loadaddr} ${fpgabase} ${fpgasize} &&" \ >>> +" fpga loadb 0 ${loadaddr} ${fpgasize} && setenv fpgastatus >>> okay\0" \ >>> +"fpgastatus=disabled\0" \ >>> +"fpgaupd=run fpgaaddr && tftp ${loadaddr} X20CP04xx.bit &&" \ >>> +" sf erase ${fpgabase} +${filesize} &&" \ >>> +" sf write ${loadaddr} ${fpgabase} ${filesize}\0" \ >>> +"netupd=tftp ${loadaddr} boot.bin && sf probe &&" \ >>> +" sf erase 0 +${filesize} && sf write ${loadaddr} 0 ${filesize} >>> &&" \ >>> +" tftp ${loadaddr} u-boot-dtb.img &&" \ >>> +" sf erase 0x40000 +${filesize} && sf write ${loadaddr} 0x40000 >>> ${filesize}\0" \ >>> +"cfgscr=mw ${dtbaddr} 0;" \ >>> +" sf probe && sf read ${scradr} 0xC0000 0x10000 && source >>> ${scradr};" \ >>> +" fdt addr ${dtbaddr} || cp ${fdtcontroladdr} ${dtbaddr} 4000\0" \ >>> +"vxargs=setenv bootargs gem(0,0)host:vxWorks h=${serverip}" \ >>> +" e=${ipaddr}:${netmask} g=${gatewayip} u=vxWorksFTP >>> pw=vxWorks\0" \ >>> +"vxfdt=fdt addr ${dtbaddr}; fdt resize 0x10000;" \ >>> +" fdt set /fpga status ${fpgastatus};" \ >>> +" fdt boardsetup\0" \ >>> +"startvx=run vxargs && mw 0x1100 0 && run vxfdt &&" \ >>> +" bootm ${loadaddr} - ${dtbaddr}\0" \ >>> +"b_break=0\0" \ >>> +"b_tgts_std=mmc spi usb0 net0 net1\0" \ >>> +"b_tgts_rcy=spi usb0 net0 net1\0" \ >>> +"b_tgts_pme=usb0 net0 net1 mmc spi\0" \ >>> +"b_deftgts=if test ${b_mode} = 12; then setenv b_tgts >>> ${b_tgts_pme};" \ >>> +" elif test ${b_mode} = 0; then setenv b_tgts ${b_tgts_rcy};" \ >>> +" else setenv b_tgts ${b_tgts_std}; fi\0" \ >>> +"b_mmc=run fpga; mmc dev 0; load mmc 0 ${loadaddr} arimg && run >>> startvx\0" \ >>> +"b_spi=run fpga; sf read ${loadaddr} 900000 700000 && run >>> startvx\0" \ >>> +"b_net0=tftp ${scradr} netscr-brsmarc2-${board_id}.img && >>> source ${scradr}\0" \ >>> +"b_net1=tftp ${scradr} netscript.img && source ${scradr}\0" \ >>> +"b_usb0=usb start && load usb 0 ${scradr} bootscr.img && source >>> ${scradr}\0" \ >>> +"b_default=run b_deftgts; for target in ${b_tgts};"\ >>> +" do run b_${target}; if test ${b_break} = 1; then; exit; fi; >>> done\0" >> we are trying to get rid of these variables. Please enable distro >> boot >> and put all of these to scripts and run them. > No, i don't want some distro defaults ... because we've our own boot > strategy. How much of this strategy is common to all the BuR platforms? Perhaps the answer is that you should make include/environment/bur/ and put the common script in there. Thanks!
Then fix it.
No. The existing code will not be modified to fit for my specific hardware. It doesn't make sense at all and i have absolutely no chance to test boards which may be affected from my changes.
It is done well for my point of view! I have here some specific hardware to support. Nobody else, except those who have this B&R specific hardware, will find this useful. Maybe somebody is looking at it and can fork an idea from the b&r stuff, that would be ok.
Thanks, Michal
cheers, Hannes
Hannes Schmelzer
Hannes Schmelzer
Michal Simek
