[PATCH 00/16] board: Add new features for ROCKPi N8/N10
Add new features like USB, HDMI, PCIe on ROCKPi N8/N10 boards.
All dts patches are Synced from linux-next and mailing list.
Any inputs? Jagan.
Jagan Teki (8): ARM: dts: rockchip: Sync ROCKPi N8/N10 dts(i) from Linux ARM: dts: rockchip: Add usb host0 ohci node for rk3288 ARM: dts: rockchip: Add USB for RockPI N8/N10 arm: dts: rockchip: Add HDMI out for RockPI N8/N10 arm64: dts: rockchip: Add PCIe for RockPI N10 rock-pi-n10: Enable PCI/NVME arm64: dts: rockchip: Add u-boot,spl-boot-order for ROCKPi N10 rock-p-n8/n10: Disable RAM_ROCKCHIP_DEBUG
Suniel Mahesh (8): arm: dts: rockchip: Sync rk3288 dtsi from linux configs: Enable USB host on Rock-PI-N10 configs: Enable HDMI output configs: Enable USB Gadget for rock-pi-n10 configs: Enable USB 2.0 on Rock-PI-N8 configs: Enable USB Gadget on rock-pi-n8 rk3288: rock-pi-n8: Add console settings configs: Enable HDMI output for rock-pi-n8
arch/arm/dts/rk3288-rock-pi-n8.dts | 2 +- arch/arm/dts/rk3288-vmarc-som.dtsi | 132 +++++++----- arch/arm/dts/rk3288.dtsi | 17 +- .../arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi | 6 + arch/arm/dts/rk3399pro-rock-pi-n10.dts | 6 +- arch/arm/dts/rk3399pro-vmarc-som.dtsi | 201 ++++++++++++++---- .../dts/rockchip-radxa-dalang-carrier.dtsi | 95 ++++++--- configs/rock-pi-n10-rk3399pro_defconfig | 25 +++ configs/rock-pi-n8-rk3288_defconfig | 17 ++ include/configs/evb_rk3288.h | 6 +- 10 files changed, 379 insertions(+), 128 deletions(-)
Sync ROCKPi N8/N10 dts(i) changes from Linux.
commit <afd9eb880414> ("ARM: dts: rockchip: Add Radxa Rock Pi N8 initial support")
Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3288-rock-pi-n8.dts | 2 +- arch/arm/dts/rk3288-vmarc-som.dtsi | 80 ++++++----------- arch/arm/dts/rk3399pro-rock-pi-n10.dts | 6 +- arch/arm/dts/rk3399pro-vmarc-som.dtsi | 87 +++++++++---------- .../dts/rockchip-radxa-dalang-carrier.dtsi | 65 +++++++------- 5 files changed, 104 insertions(+), 136 deletions(-)
diff --git a/arch/arm/dts/rk3288-rock-pi-n8.dts b/arch/arm/dts/rk3288-rock-pi-n8.dts index c8637a50c1..c9894a60e7 100644 --- a/arch/arm/dts/rk3288-rock-pi-n8.dts +++ b/arch/arm/dts/rk3288-rock-pi-n8.dts @@ -7,8 +7,8 @@
/dts-v1/; #include "rk3288.dtsi" -#include "rk3288-vmarc-som.dtsi" #include <rockchip-radxa-dalang-carrier.dtsi> +#include "rk3288-vmarc-som.dtsi"
/ { model = "Radxa ROCK Pi N8"; diff --git a/arch/arm/dts/rk3288-vmarc-som.dtsi b/arch/arm/dts/rk3288-vmarc-som.dtsi index 3cffe61cdf..7a9fd40e5b 100644 --- a/arch/arm/dts/rk3288-vmarc-som.dtsi +++ b/arch/arm/dts/rk3288-vmarc-som.dtsi @@ -7,35 +7,17 @@
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/pwm/pwm.h>
/ { compatible = "vamrs,rk3288-vmarc-som", "rockchip,rk3288";
- ext_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - #clock-cells = <0>; - }; - vccio_flash: vccio-flash-regulator { compatible = "regulator-fixed"; regulator-name = "vccio_flash"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - startup-delay-us = <150>; vin-supply = <&vcc_io>; }; - - vcc_sys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; };
&emmc { @@ -45,23 +27,15 @@ non-removable; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; + vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vccio_flash>; status = "okay"; };
&gmac { assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - clock_in_out = "input"; - phy-mode = "rgmii"; phy-supply = <&vcc_io>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; snps,reset-gpio = <&gpio4 RK_PA7 GPIO_ACTIVE_HIGH>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x30>; - rx_delay = <0x10>; - max-speed = <1000>; };
&i2c0 { @@ -80,37 +54,37 @@ #clock-cells = <1>; clock-output-names = "rk808-clkout1", "rk808-clkout2";
- vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc6-supply = <&vcc_sys>; - vcc7-supply = <&vcc_sys>; + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc6-supply = <&vcc5v0_sys>; + vcc7-supply = <&vcc5v0_sys>; vcc8-supply = <&vcc_io>; vcc9-supply = <&vcc_io>; - vcc10-supply = <&vcc_sys>; - vcc11-supply = <&vcc_sys>; + vcc10-supply = <&vcc5v0_sys>; + vcc11-supply = <&vcc5v0_sys>; vcc12-supply = <&vcc_io>; vddio-supply = <&vcc_io>;
regulators { vdd_cpu: DCDC_REG1 { + regulator-name = "vdd_arm"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <750000>; regulator-max-microvolt = <1400000>; - regulator-name = "vdd_arm"; regulator-state-mem { regulator-off-in-suspend; }; };
vdd_gpu: DCDC_REG2 { + regulator-name = "vdd_gpu"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1250000>; - regulator-name = "vdd_gpu"; regulator-ramp-delay = <6000>; regulator-state-mem { regulator-off-in-suspend; @@ -118,20 +92,20 @@ };
vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; regulator-always-on; regulator-boot-on; - regulator-name = "vcc_ddr"; regulator-state-mem { regulator-on-in-suspend; }; };
vcc_io: DCDC_REG4 { + regulator-name = "vcc_io"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - regulator-name = "vcc_io"; regulator-state-mem { regulator-on-in-suspend; regulator-suspend-microvolt = <3300000>; @@ -139,22 +113,22 @@ };
vcc_tp: LDO_REG1 { + regulator-name = "vcc_tp"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - regulator-name = "vcc_tp"; regulator-state-mem { regulator-off-in-suspend; }; };
vcca_codec: LDO_REG2 { + regulator-name = "vcca_codec"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - regulator-name = "vcca_codec"; regulator-state-mem { regulator-on-in-suspend; regulator-suspend-microvolt = <3300000>; @@ -162,11 +136,11 @@ };
vdd_10: LDO_REG3 { + regulator-name = "vdd_10"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; - regulator-name = "vdd_10"; regulator-state-mem { regulator-on-in-suspend; regulator-suspend-microvolt = <1000000>; @@ -174,22 +148,22 @@ };
vcc_wl: LDO_REG4 { + regulator-name = "vcc_wl"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-name = "vcc_wl"; regulator-state-mem { regulator-on-in-suspend; }; };
vccio_sd: LDO_REG5 { + regulator-name = "vccio_sd"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3300000>; - regulator-name = "vccio_sd"; regulator-state-mem { regulator-on-in-suspend; regulator-suspend-microvolt = <3300000>; @@ -197,22 +171,22 @@ };
vdd10_lcd: LDO_REG6 { + regulator-name = "vdd10_lcd"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; - regulator-name = "vdd10_lcd"; regulator-state-mem { regulator-off-in-suspend; }; };
vcc_18: LDO_REG7 { + regulator-name = "vcc_18"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-name = "vcc_18"; regulator-state-mem { regulator-on-in-suspend; regulator-suspend-microvolt = <1800000>; @@ -220,29 +194,29 @@ };
vcc18_lcd: LDO_REG8 { + regulator-name = "vcc18_lcd"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-name = "vcc18_lcd"; regulator-state-mem { regulator-off-in-suspend; }; };
vcc_sd: SWITCH_REG1 { + regulator-name = "vcc_sd"; regulator-always-on; regulator-boot-on; - regulator-name = "vcc_sd"; regulator-state-mem { regulator-off-in-suspend; }; };
vcc_lcd: SWITCH_REG2 { + regulator-name = "vcc_lcd"; regulator-always-on; regulator-boot-on; - regulator-name = "vcc_lcd"; regulator-state-mem { regulator-off-in-suspend; }; @@ -277,13 +251,11 @@ };
sdmmc_clk: sdmmc-clk { - rockchip,pins = - <6 RK_PC4 1 &pcfg_pull_none_drv_8ma>; + rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_drv_8ma>; };
sdmmc_cmd: sdmmc-cmd { - rockchip,pins = - <6 RK_PC5 1 &pcfg_pull_up_drv_8ma>; + rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up_drv_8ma>; }; }; }; diff --git a/arch/arm/dts/rk3399pro-rock-pi-n10.dts b/arch/arm/dts/rk3399pro-rock-pi-n10.dts index 6ac2d4d721..bf026786fa 100644 --- a/arch/arm/dts/rk3399pro-rock-pi-n10.dts +++ b/arch/arm/dts/rk3399pro-rock-pi-n10.dts @@ -8,11 +8,15 @@ /dts-v1/; #include "rk3399.dtsi" #include "rk3399-opp.dtsi" -#include "rk3399pro-vmarc-som.dtsi" #include <rockchip-radxa-dalang-carrier.dtsi> +#include "rk3399pro-vmarc-som.dtsi"
/ { model = "Radxa ROCK Pi N10"; compatible = "radxa,rockpi-n10", "vamrs,rk3399pro-vmarc-som", "rockchip,rk3399pro"; + + chosen { + stdout-path = "serial2:1500000n8"; + }; }; diff --git a/arch/arm/dts/rk3399pro-vmarc-som.dtsi b/arch/arm/dts/rk3399pro-vmarc-som.dtsi index 6fd17e8a81..37ed95d5f7 100644 --- a/arch/arm/dts/rk3399pro-vmarc-som.dtsi +++ b/arch/arm/dts/rk3399pro-vmarc-som.dtsi @@ -11,32 +11,6 @@
/ { compatible = "vamrs,rk3399pro-vmarc-som", "rockchip,rk3399pro"; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - vcc12v_dcin: vcc12v-dcin-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_dcin"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - vcc5v0_sys: vcc5v0-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; };
&cpu_l0 { @@ -61,23 +35,14 @@
&gmac { assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x28>; - rx_delay = <0x11>; };
&i2c0 { clock-frequency = <400000>; - i2c-scl-rising-time-ns = <180>; i2c-scl-falling-time-ns = <30>; + i2c-scl-rising-time-ns = <180>; status = "okay";
rk809: pmic@20 { @@ -297,11 +262,48 @@ }; };
+&i2c1 { + i2c-scl-falling-time-ns = <30>; + i2c-scl-rising-time-ns = <140>; + status = "okay"; +}; + +&i2c2 { + clock-frequency = <400000>; + status = "okay"; + + hym8563: hym8563@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "hym8563"; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + interrupt-parent = <&gpio4>; + interrupts = <RK_PD6 IRQ_TYPE_LEVEL_LOW>; + }; +}; + &io_domains { status = "okay"; bt656-supply = <&vcca_1v8>; - sdmmc-supply = <&vccio_sd>; gpio1830-supply = <&vccio_3v0>; + sdmmc-supply = <&vccio_sd>; +}; + +&pinctrl { + hym8563 { + hym8563_int: hym8563-int { + rockchip,pins = <4 RK_PD6 0 &pcfg_pull_up>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <1 RK_PC2 0 &pcfg_pull_up>; + }; + }; };
&pmu_io_domains { @@ -323,16 +325,7 @@ };
&tsadc { - status = "okay"; rockchip,hw-tshut-mode = <1>; rockchip,hw-tshut-polarity = <1>; -}; - -&pinctrl { - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = - <1 RK_PC2 0 &pcfg_pull_up>; - }; - }; + status = "okay"; }; diff --git a/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi b/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi index 3e54f38f0a..450e5bb5af 100644 --- a/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi +++ b/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi @@ -8,36 +8,44 @@ #include <dt-bindings/pwm/pwm.h>
/ { - chosen { - stdout-path = "serial2:1500000n8"; + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; }; -};
-&gmac { - status = "okay"; -}; + vcc12v_dcin: vcc12v-dcin-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + };
-&i2c1 { - status = "okay"; - i2c-scl-rising-time-ns = <140>; - i2c-scl-falling-time-ns = <30>; + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; };
-&i2c2 { +&gmac { + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x28>; + rx_delay = <0x11>; status = "okay"; - clock-frequency = <400000>; - - hym8563: hym8563@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - #clock-cells = <0>; - clock-frequency = <32768>; - clock-output-names = "hym8563"; - pinctrl-names = "default"; - pinctrl-0 = <&hym8563_int>; - interrupt-parent = <&gpio4>; - interrupts = <30 IRQ_TYPE_LEVEL_LOW>; - }; };
&pwm0 { @@ -68,12 +76,3 @@ &uart2 { status = "okay"; }; - -&pinctrl { - hym8563 { - hym8563_int: hym8563-int { - rockchip,pins = - <4 RK_PD6 0 &pcfg_pull_up>; - }; - }; -};
Reviewed-by: Kever Yangkever.yang@rock-chips.com
Thanks, - Kever
#clock-cells = <0>;
regulator-boot-on;
&emmc {
tx_delay = <0x30>;
rx_delay = <0x10>;
&i2c0 {
vcc8-supply = <&vcc_io>; vcc9-supply = <&vcc_io>;vcc7-supply = <&vcc5v0_sys>;
regulator-name = "vdd_arm"; regulator-state-mem { regulator-off-in-suspend; }; }; vdd_gpu: DCDC_REG2 {
regulator-name = "vcc_ddr"; regulator-state-mem { regulator-on-in-suspend; }; }; vcc_io: DCDC_REG4 {
vcc_tp: LDO_REG1 {
regulator-name = "vcc_tp"; regulator-state-mem { regulator-off-in-suspend; }; }; vcca_codec: LDO_REG2 {
vdd_10: LDO_REG3 {
vcc_wl: LDO_REG4 {
regulator-name = "vcc_wl"; regulator-state-mem { regulator-on-in-suspend; }; }; vccio_sd: LDO_REG5 {
regulator-name = "vdd10_lcd"; regulator-state-mem { regulator-off-in-suspend; }; }; vcc_18: LDO_REG7 {
regulator-name = "vcc18_lcd"; regulator-state-mem { regulator-off-in-suspend; }; }; vcc_sd: SWITCH_REG1 {
regulator-name = "vcc_sd"; regulator-state-mem { regulator-off-in-suspend; }; }; vcc_lcd: SWITCH_REG2 {
rockchip,pins =
rockchip,pins =
}; }; };rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up_drv_8ma>;
- chosen {
#clock-cells = <0>;
regulator-boot-on;
regulator-boot-on;
&cpu_l0 {
@@ -61,23 +35,14 @@
phy-mode = "rgmii";
tx_delay = <0x28>;
rk809: pmic@20 {
+&i2c1 {
- status = "okay";
+&i2c2 {
- status = "okay";
reg = <0x51>;
#clock-cells = <0>;
- &io_domains { status = "okay"; bt656-supply = <&vcca_1v8>;
+&pinctrl {
hym8563 {
pmic {
&pmu_io_domains {
&tsadc {
-&pinctrl {
- pmic {
rockchip,pins =
- status = "okay"; };
- chosen {
};#clock-cells = <0>;
-&gmac {
- status = "okay";
regulator-boot-on;
-&i2c1 {
- status = "okay";
regulator-boot-on;
-&i2c2 { +&gmac {
- rx_delay = <0x11>; status = "okay";
reg = <0x51>;
#clock-cells = <0>;
&pwm0 {
-&pinctrl {
- hym8563 {
rockchip,pins =
This sync has changes required to use HDMI CEC pin in U-Boot.
Sync dts from linux v5.8-rc5 commit: "ARM: dts: rockchip: define the two possible rk3288 CEC pins" (sha1: 838980dd04e994bf81cf104fa01ae60802146b39)
Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3288.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index 866fc08215..18b372db3a 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -1085,6 +1085,12 @@ #interrupt-cells = <2>; };
+ hdmi { + hdmi_cec_c0: hdmi-cec-c0 { + rockchip,pins = <7 RK_PC0 2 &pcfg_pull_none>; + }; + }; + pcfg_pull_up: pcfg-pull-up { bias-pull-up; };
Thanks, - Kever
hdmi {
- pcfg_pull_up: pcfg-pull-up { bias-pull-up; };
rk3288 and rk3288w have a usb host0 ohci controller.
Although rk3288 ohci doesn't actually work on hardware, but rk3288w ohci can work well.
So add usb host0 ohci node in rk3288 dtsi and the quirk in ohci platform driver will disable ohci on rk3288.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3288.dtsi | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index 18b372db3a..22bb06cec5 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -431,7 +431,16 @@ status = "disabled"; };
- /* NOTE: ohci@ff520000 doesn't actually work on hardware */ + /* NOTE: doesn't work on RK3288, but fixed on RK3288W */ + usb_host0_ohci: usb@ff520000 { + compatible = "generic-ohci"; + reg = <0x0 0xff520000 0x0 0x100>; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_USBHOST0>; + phys = <&usbphy1>; + phy-names = "usb"; + status = "disabled"; + };
usb_host1: usb@ff540000 { compatible = "rockchip,rk3288-usb", "rockchip,rk3066-usb",
HI Jagan,
Does patch 3~6 also from mainline kernel?
Thanks,
- Kever
phys = <&usbphy1>;
phy-names = "usb";
Hi Kever,
On Tue, Jul 21, 2020 at 8:48 AM Kever Yang kever.yang@rock-chips.com wrote:
HI Jagan,
Yes, in mailing lists.
Thanks,
- Kever
phys = <&usbphy1>;
phy-names = "usb";
}; usb_host1: usb@ff540000 { compatible = "rockchip,rk3288-usb", "rockchip,rk3066-usb",
-- Jagan Teki, Amarula Solutions India Pvt. Ltd. Co-Founder & Embedded Linux Architect 405/E-Block, Sri Lakshmi Shubham Arcade, Chandanagar, Hyderabad - 500050, India M. (+91) 910 009 0959 [`as] http://www.amarulasolutions.com
Radxa dalang carrier board has 2x USB 2.0 and 1x USB 3.0 ports.
This patch adds support to enable all these USB ports for N10 and N8 combinations SBCs.
Note that the USB 3.0 port on RockPI N8 combination works as USB 2.0 OTG since it is driven from RK3288.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3288-vmarc-som.dtsi | 42 ++++++++++ arch/arm/dts/rk3399pro-vmarc-som.dtsi | 78 +++++++++++++++++++ .../dts/rockchip-radxa-dalang-carrier.dtsi | 18 +++++ 3 files changed, 138 insertions(+)
diff --git a/arch/arm/dts/rk3288-vmarc-som.dtsi b/arch/arm/dts/rk3288-vmarc-som.dtsi index 7a9fd40e5b..72a503e50d 100644 --- a/arch/arm/dts/rk3288-vmarc-som.dtsi +++ b/arch/arm/dts/rk3288-vmarc-som.dtsi @@ -258,4 +258,46 @@ rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up_drv_8ma>; }; }; + + vbus_host { + usb1_en_oc: usb1-en-oc { + rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + vbus_typec { + usb0_en_oc: usb0-en-oc { + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; + +&usbphy { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1 { + status = "okay"; +}; + +&usb_otg { + status = "okay"; +}; + +&vbus_host { + enable-active-high; + gpio = <&gpio0 RK_PC1 GPIO_ACTIVE_HIGH>; /* USB1_EN_OC# */ +}; + +&vbus_typec { + enable-active-high; + gpio = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; /* USB0_EN_OC# */ }; diff --git a/arch/arm/dts/rk3399pro-vmarc-som.dtsi b/arch/arm/dts/rk3399pro-vmarc-som.dtsi index 37ed95d5f7..111d6cf9a4 100644 --- a/arch/arm/dts/rk3399pro-vmarc-som.dtsi +++ b/arch/arm/dts/rk3399pro-vmarc-som.dtsi @@ -304,6 +304,18 @@ rockchip,pins = <1 RK_PC2 0 &pcfg_pull_up>; }; }; + + vbus_host { + usb1_en_oc: usb1-en-oc { + rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + vbus_typec { + usb0_en_oc: usb0-en-oc { + rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; };
&pmu_io_domains { @@ -324,8 +336,74 @@ max-frequency = <150000000>; };
+&tcphy0 { + status = "okay"; +}; + &tsadc { rockchip,hw-tshut-mode = <1>; rockchip,hw-tshut-polarity = <1>; status = "okay"; }; + +&u2phy0 { + status = "okay"; + + u2phy0_otg: otg-port { + phy-supply = <&vbus_typec>; + status = "okay"; + }; + + u2phy0_host: host-port { + phy-supply = <&vbus_host>; + status = "okay"; + }; +}; + + +&u2phy1 { + status = "okay"; + + u2phy1_host: host-port { + phy-supply = <&vbus_host>; + status = "okay"; + }; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usbdrd3_0 { + status = "okay"; +}; + +&usbdrd_dwc3_0 { + status = "okay"; +}; + +&vbus_host { + enable-active-high; + gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; /* USB1_EN_OC# */ + pinctrl-names = "default"; + pinctrl-0 = <&usb1_en_oc>; +}; + +&vbus_typec { + enable-active-high; + gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; /* USB0_EN_OC# */ + pinctrl-names = "default"; + pinctrl-0 = <&usb0_en_oc>; +}; diff --git a/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi b/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi index 450e5bb5af..d2b6ead148 100644 --- a/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi +++ b/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi @@ -33,6 +33,24 @@ regulator-max-microvolt = <5000000>; vin-supply = <&vcc12v_dcin>; }; + + vbus_host: vbus-host { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&usb1_en_oc>; + regulator-name = "vbus_host"; /* HOST-5V */ + regulator-always-on; + vin-supply = <&vcc5v0_sys>; + }; + + vbus_typec: vbus-typec { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&usb0_en_oc>; + regulator-name = "vbus_typec"; + regulator-always-on; + vin-supply = <&vcc5v0_sys>; + }; };
&gmac {
This patch adds support to enable HDMI out for N10 and N8 combinations SBCs.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3288-vmarc-som.dtsi | 10 ++++++++++ arch/arm/dts/rk3399pro-vmarc-som.dtsi | 12 +++++++++++ .../dts/rockchip-radxa-dalang-carrier.dtsi | 20 +++++++++++++++++++ 3 files changed, 42 insertions(+)
diff --git a/arch/arm/dts/rk3288-vmarc-som.dtsi b/arch/arm/dts/rk3288-vmarc-som.dtsi index 72a503e50d..717cb3dc81 100644 --- a/arch/arm/dts/rk3288-vmarc-som.dtsi +++ b/arch/arm/dts/rk3288-vmarc-som.dtsi @@ -38,6 +38,12 @@ snps,reset-gpio = <&gpio4 RK_PA7 GPIO_ACTIVE_HIGH>; };
+&hdmi { + ddc-i2c-bus = <&i2c5>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_cec_c0>; +}; + &i2c0 { clock-frequency = <400000>; status = "okay"; @@ -225,6 +231,10 @@ }; };
+&i2c5 { + status = "okay"; +}; + &pinctrl { pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma { drive-strength = <8>; diff --git a/arch/arm/dts/rk3399pro-vmarc-som.dtsi b/arch/arm/dts/rk3399pro-vmarc-som.dtsi index 111d6cf9a4..ebccc4a153 100644 --- a/arch/arm/dts/rk3399pro-vmarc-som.dtsi +++ b/arch/arm/dts/rk3399pro-vmarc-som.dtsi @@ -39,6 +39,12 @@ snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; };
+&hdmi { + ddc-i2c-bus = <&i2c3>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_cec>; +}; + &i2c0 { clock-frequency = <400000>; i2c-scl-falling-time-ns = <30>; @@ -285,6 +291,12 @@ }; };
+&i2c3 { + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + &io_domains { status = "okay"; bt656-supply = <&vcca_1v8>; diff --git a/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi b/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi index d2b6ead148..26b53eac47 100644 --- a/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi +++ b/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi @@ -66,6 +66,10 @@ status = "okay"; };
+&hdmi { + status = "okay"; +}; + &pwm0 { status = "okay"; }; @@ -94,3 +98,19 @@ &uart2 { status = "okay"; }; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +};
This patch adds support to enable PCIe for RockPI N10.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399pro-vmarc-som.dtsi | 40 +++++++++++++++++++++++++-- 1 file changed, 38 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/rk3399pro-vmarc-som.dtsi b/arch/arm/dts/rk3399pro-vmarc-som.dtsi index ebccc4a153..5d087be04a 100644 --- a/arch/arm/dts/rk3399pro-vmarc-som.dtsi +++ b/arch/arm/dts/rk3399pro-vmarc-som.dtsi @@ -11,6 +11,18 @@
/ { compatible = "vamrs,rk3399pro-vmarc-som", "rockchip,rk3399pro"; + + vcc3v3_pcie: vcc-pcie-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PD4 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_pwr>; + regulator-name = "vcc3v3_pcie"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + }; };
&cpu_l0 { @@ -142,7 +154,8 @@ regulator-min-microvolt = <900000>; regulator-max-microvolt = <900000>; regulator-state-mem { - regulator-off-in-suspend; + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; }; };
@@ -177,7 +190,8 @@ regulator-min-microvolt = <1850000>; regulator-max-microvolt = <1850000>; regulator-state-mem { - regulator-off-in-suspend; + regulator-on-in-suspend; + regulator-suspend-microvolt = <1850000>; }; };
@@ -304,6 +318,22 @@ sdmmc-supply = <&vccio_sd>; };
+&pcie_phy { + status = "okay"; +}; + +&pcie0 { + ep-gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; + max-link-speed = <2>; + num-lanes = <4>; + pinctrl-0 = <&pcie_clkreqnb_cpm>; + pinctrl-names = "default"; + vpcie0v9-supply = <&vcca_0v9>; /* VCC_0V9_S0 */ + vpcie1v8-supply = <&vcca_1v8>; /* VCC_1V8_S0 */ + vpcie3v3-supply = <&vcc3v3_pcie>; + status = "okay"; +}; + &pinctrl { hym8563 { hym8563_int: hym8563-int { @@ -311,6 +341,12 @@ }; };
+ pcie { + pcie_pwr: pcie-pwr { + rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + pmic { pmic_int_l: pmic-int-l { rockchip,pins = <1 RK_PC2 0 &pcfg_pull_up>;
Enable USB 3.0 and 2.0 and related configs for the Rock-PI-N10 target, which hosts RK3399Pro-VMARC-SOM.
Log: Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... cannot reset port 1!? 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | +-2 Mass Storage (5 Gb/s, 224mA) SanDisk Dual Drive 04019c9b2e1a58f24ee318c3c123aa5 => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Mass Storage (480 Mb/s, 224mA) SanDisk Dual Drive 04019c9b2e1a58f24ee318c3c123aa5
Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/rock-pi-n10-rk3399pro_defconfig | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index c705ce01ce..e09e656fbc 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -19,6 +19,7 @@ CONFIG_TPL=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_SPL_OF_CONTROL=y @@ -36,11 +37,23 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_TYPEC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y +CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_KEYBOARD=y +# CONFIG_USB_KEYBOARD_FN_KEYS is not set CONFIG_ERRNO_STR=y
Hi Jagan,
For the same board config, please just enable all the features you need in one patch
since the drivers already there, no need the split them into pieces.
BTW: please add prefix "rockchip" in subject
Thanks,
- Kever
1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller 1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | +-2 Mass Storage (5 Gb/s, 224mA) SanDisk Dual Drive 04019c9b2e1a58f24ee318c3c123aa5
Enable config options to get HDMI output on RockPI-N10 target which hosts a RK3399Pro-VMARC-SOM.
Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/rock-pi-n10-rk3399pro_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index e09e656fbc..ba2babe20f 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +# CONFIG_CONSOLE_MUX is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399pro-rock-pi-n10.dtb" CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_BOARDINFO_LATE=y @@ -56,4 +57,8 @@ CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y # CONFIG_USB_KEYBOARD_FN_KEYS is not set +CONFIG_DM_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_HDMI=y CONFIG_ERRNO_STR=y
Enable fastboot and USB gadget related config options for rock-pi-n10 target which hosts RK3399Pro-VMARC-SOM .
Note: Connect the Host USB cable (Type A) to rock-pi-n10 USB 3.0 port on carrier board for fastboot.
Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/rock-pi-n10-rk3399pro_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index ba2babe20f..895820fbe6 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +# CONFIG_ANDROID_BOOT_IMAGE is not set # CONFIG_CONSOLE_MUX is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399pro-rock-pi-n10.dtb" CONFIG_MISC_INIT_R=y @@ -55,8 +56,10 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y +CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_KEYBOARD=y # CONFIG_USB_KEYBOARD_FN_KEYS is not set +CONFIG_USB_GADGET=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y
Enable USB 2.0 and related configs for the Rock-PI-N8 target, which hosts RK3288-VMARC-SOM.
Log: Bus usb@ff500000: USB EHCI 1.00 Bus usb@ff540000: USB DWC2 Bus usb@ff580000: USB DWC2 scanning bus usb@ff500000 for devices... 2 USB Device(s) found scanning bus usb@ff540000 for devices... 1 USB Device(s) found scanning bus usb@ff580000 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Mass Storage (480 Mb/s, 224mA) SanDisk Dual Drive 04019c9b2e1a58f24ee318c3c123aa5
1 Hub (480 Mb/s, 0mA) U-Boot Root Hub
Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/rock-pi-n8-rk3288_defconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/configs/rock-pi-n8-rk3288_defconfig b/configs/rock-pi-n8-rk3288_defconfig index 6b31e19eda..4cbb07d870 100644 --- a/configs/rock-pi-n8-rk3288_defconfig +++ b/configs/rock-pi-n8-rk3288_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y @@ -63,4 +64,11 @@ CONFIG_RAM=y CONFIG_SPL_RAM=y CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC2=y +CONFIG_ROCKCHIP_USB2_PHY=y +CONFIG_USB_KEYBOARD=y +# CONFIG_USB_KEYBOARD_FN_KEYS is not set CONFIG_ERRNO_STR=y
Enable fastboot and USB gadget related config options for rock-pi-n8 target which hosts RK3288-VMARC-SOM .
Note: Connect the Host USB cable (Type A) to rock-pi-n8 USB 3.0 port on carrier board for fastboot.
Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/rock-pi-n8-rk3288_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/rock-pi-n8-rk3288_defconfig b/configs/rock-pi-n8-rk3288_defconfig index 4cbb07d870..aafa2cac2a 100644 --- a/configs/rock-pi-n8-rk3288_defconfig +++ b/configs/rock-pi-n8-rk3288_defconfig @@ -11,6 +11,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +# CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-rock-pi-n8.dtb" @@ -71,4 +72,6 @@ CONFIG_USB_DWC2=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_KEYBOARD=y # CONFIG_USB_KEYBOARD_FN_KEYS is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_ERRNO_STR=y
Add console settings like stdin, stdout and stderr as usbkbd and vidconsole respectively for rock-pi-n8 target.
This would certainly help to detect the attached video devices (like HDMI) and print the console messages on display.
Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com --- include/configs/evb_rk3288.h | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/include/configs/evb_rk3288.h b/include/configs/evb_rk3288.h index ddd7012c8f..e19fa90212 100644 --- a/include/configs/evb_rk3288.h +++ b/include/configs/evb_rk3288.h @@ -6,7 +6,11 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define ROCKCHIP_DEVICE_SETTINGS +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdin=serial,usbkbd\0" \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + #include <configs/rk3288_common.h>
#define CONFIG_SYS_MMC_ENV_DEV 0
Enable config options to get HDMI output on RockPI-N8 target which hosts a RK3288-VMARC-SOM.
Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com --- configs/rock-pi-n8-rk3288_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/rock-pi-n8-rk3288_defconfig b/configs/rock-pi-n8-rk3288_defconfig index aafa2cac2a..d218852d79 100644 --- a/configs/rock-pi-n8-rk3288_defconfig +++ b/configs/rock-pi-n8-rk3288_defconfig @@ -14,6 +14,7 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y +# CONFIG_CONSOLE_MUX is not set CONFIG_DEFAULT_FDT_FILE="rk3288-rock-pi-n8.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y @@ -74,4 +75,8 @@ CONFIG_USB_KEYBOARD=y # CONFIG_USB_KEYBOARD_FN_KEYS is not set CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_DM_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_HDMI=y CONFIG_ERRNO_STR=y
Enable PCI/NVME for M.2 Slot on RockPI-4 boards.
=> nvme info Device 0: Vendor: 0x144d Rev: 4L1QCXB7 Prod: S35FNX0J623292 Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512)
diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index 895820fbe6..2aa2fafaa4 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -21,6 +21,7 @@ CONFIG_TPL=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y @@ -39,6 +40,8 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_NVME=y +CONFIG_PCI=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PHY_ROCKCHIP_TYPEC=y CONFIG_PMIC_RK8XX=y
Add u-boot,spl-boot-order for ROCKPi N10, so-that it can able to boot from eMMC and SDMMC in order.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi b/arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi index 946a0230db..7c66e1145a 100644 --- a/arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi +++ b/arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi @@ -5,3 +5,9 @@
#include "rk3399pro-u-boot.dtsi" #include "rk3399-sdram-lpddr3-4GB-1600.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc; + }; +};
Disable ram rockchip debug driver for ROCKPi N8/N10 boards since we have verified ram in many instances with respective U-Boot versions.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/rock-pi-n10-rk3399pro_defconfig | 1 + configs/rock-pi-n8-rk3288_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index 2aa2fafaa4..4a5bff44ef 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -48,6 +48,7 @@ CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y +# CONFIG_RAM_ROCKCHIP_DEBUG is not set CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/rock-pi-n8-rk3288_defconfig b/configs/rock-pi-n8-rk3288_defconfig index d218852d79..630ec6e491 100644 --- a/configs/rock-pi-n8-rk3288_defconfig +++ b/configs/rock-pi-n8-rk3288_defconfig @@ -64,6 +64,7 @@ CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y CONFIG_RAM=y CONFIG_SPL_RAM=y +# CONFIG_RAM_ROCKCHIP_DEBUG is not set CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y CONFIG_USB=y
Jagan Teki
Kever Yang
