[U-Boot] [PATCH 1/8 v2] UBIFS: Implement read-only UBIFS support in U-Boot (Part 1)
This patchset adds UBIFS read-only support to U-Boot. The following commands are implemented:
- ubifsmount Mount an UBIFS volume
- ubifsls List a directory of the mounted UBIFS volume
- ubifsload Load a file from the mounted UBIFS volume to memory
The U-Boot UBIFS implementation is largely a direct copy from the current Linux version (2.6.29-rc6). As already done in the UBI version we have an "abstraction layer" to redefine or remove some OS calls (e.g. mutex_lock() ...). This makes it possible to use the original Linux code with very little changes. And by this we can better update to later Linux versions.
I removed some of the Linux features that are not used in the U-Boot version (e.g. garbage-collection, write support).
Signed-off-by: Stefan Roese sr@denx.de CC: Artem Bityutskiy dedekind@infradead.org CC: Adrian Hunter ext-Adrian.Hunter@nokia.com --- Changes in v2: - Now symbolic links are handled correctly
fs/ubifs/budget.c | 113 +++++++++++++++ fs/ubifs/crc16.c | 60 ++++++++ fs/ubifs/crc16.h | 30 ++++ fs/ubifs/debug.c | 156 +++++++++++++++++++++ fs/ubifs/debug.h | 392 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 751 insertions(+), 0 deletions(-) create mode 100644 fs/ubifs/budget.c create mode 100644 fs/ubifs/crc16.c create mode 100644 fs/ubifs/crc16.h create mode 100644 fs/ubifs/debug.c create mode 100644 fs/ubifs/debug.h
diff --git a/fs/ubifs/budget.c b/fs/ubifs/budget.c new file mode 100644 index 0000000..85377ea --- /dev/null +++ b/fs/ubifs/budget.c @@ -0,0 +1,113 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Adrian Hunter + * Artem Bityutskiy (Битюцкий Артём) + */ + +/* + * This file implements the budgeting sub-system which is responsible for UBIFS + * space management. + * + * Factors such as compression, wasted space at the ends of LEBs, space in other + * journal heads, the effect of updates on the index, and so on, make it + * impossible to accurately predict the amount of space needed. Consequently + * approximations are used. + */ + +#include "ubifs.h" +#include <linux/math64.h> + +/** + * ubifs_calc_min_idx_lebs - calculate amount of eraseblocks for the index. + * @c: UBIFS file-system description object + * + * This function calculates and returns the number of eraseblocks which should + * be kept for index usage. + */ +int ubifs_calc_min_idx_lebs(struct ubifs_info *c) +{ + int idx_lebs, eff_leb_size = c->leb_size - c->max_idx_node_sz; + long long idx_size; + + idx_size = c->old_idx_sz + c->budg_idx_growth + c->budg_uncommitted_idx; + + /* And make sure we have thrice the index size of space reserved */ + idx_size = idx_size + (idx_size << 1); + + /* + * We do not maintain 'old_idx_size' as 'old_idx_lebs'/'old_idx_bytes' + * pair, nor similarly the two variables for the new index size, so we + * have to do this costly 64-bit division on fast-path. + */ + idx_size += eff_leb_size - 1; + idx_lebs = div_u64(idx_size, eff_leb_size); + /* + * The index head is not available for the in-the-gaps method, so add an + * extra LEB to compensate. + */ + idx_lebs += 1; + if (idx_lebs < MIN_INDEX_LEBS) + idx_lebs = MIN_INDEX_LEBS; + return idx_lebs; +} + +/** + * ubifs_reported_space - calculate reported free space. + * @c: the UBIFS file-system description object + * @free: amount of free space + * + * This function calculates amount of free space which will be reported to + * user-space. User-space application tend to expect that if the file-system + * (e.g., via the 'statfs()' call) reports that it has N bytes available, they + * are able to write a file of size N. UBIFS attaches node headers to each data + * node and it has to write indexing nodes as well. This introduces additional + * overhead, and UBIFS has to report slightly less free space to meet the above + * expectations. + * + * This function assumes free space is made up of uncompressed data nodes and + * full index nodes (one per data node, tripled because we always allow enough + * space to write the index thrice). + * + * Note, the calculation is pessimistic, which means that most of the time + * UBIFS reports less space than it actually has. + */ +long long ubifs_reported_space(const struct ubifs_info *c, long long free) +{ + int divisor, factor, f; + + /* + * Reported space size is @free * X, where X is UBIFS block size + * divided by UBIFS block size + all overhead one data block + * introduces. The overhead is the node header + indexing overhead. + * + * Indexing overhead calculations are based on the following formula: + * I = N/(f - 1) + 1, where I - number of indexing nodes, N - number + * of data nodes, f - fanout. Because effective UBIFS fanout is twice + * as less than maximum fanout, we assume that each data node + * introduces 3 * @c->max_idx_node_sz / (@c->fanout/2 - 1) bytes. + * Note, the multiplier 3 is because UBIFS reserves thrice as more space + * for the index. + */ + f = c->fanout > 3 ? c->fanout >> 1 : 2; + factor = UBIFS_BLOCK_SIZE; + divisor = UBIFS_MAX_DATA_NODE_SZ; + divisor += (c->max_idx_node_sz * 3) / (f - 1); + free *= factor; + return div_u64(free, divisor); +} diff --git a/fs/ubifs/crc16.c b/fs/ubifs/crc16.c new file mode 100644 index 0000000..443ccf8 --- /dev/null +++ b/fs/ubifs/crc16.c @@ -0,0 +1,60 @@ +/* + * crc16.c + * + * This source code is licensed under the GNU General Public License, + * Version 2. See the file COPYING for more details. + */ + +#include <linux/types.h> +#include "crc16.h" + +/** CRC table for the CRC-16. The poly is 0x8005 (x^16 + x^15 + x^2 + 1) */ +u16 const crc16_table[256] = { + 0x0000, 0xC0C1, 0xC181, 0x0140, 0xC301, 0x03C0, 0x0280, 0xC241, + 0xC601, 0x06C0, 0x0780, 0xC741, 0x0500, 0xC5C1, 0xC481, 0x0440, + 0xCC01, 0x0CC0, 0x0D80, 0xCD41, 0x0F00, 0xCFC1, 0xCE81, 0x0E40, + 0x0A00, 0xCAC1, 0xCB81, 0x0B40, 0xC901, 0x09C0, 0x0880, 0xC841, + 0xD801, 0x18C0, 0x1980, 0xD941, 0x1B00, 0xDBC1, 0xDA81, 0x1A40, + 0x1E00, 0xDEC1, 0xDF81, 0x1F40, 0xDD01, 0x1DC0, 0x1C80, 0xDC41, + 0x1400, 0xD4C1, 0xD581, 0x1540, 0xD701, 0x17C0, 0x1680, 0xD641, + 0xD201, 0x12C0, 0x1380, 0xD341, 0x1100, 0xD1C1, 0xD081, 0x1040, + 0xF001, 0x30C0, 0x3180, 0xF141, 0x3300, 0xF3C1, 0xF281, 0x3240, + 0x3600, 0xF6C1, 0xF781, 0x3740, 0xF501, 0x35C0, 0x3480, 0xF441, + 0x3C00, 0xFCC1, 0xFD81, 0x3D40, 0xFF01, 0x3FC0, 0x3E80, 0xFE41, + 0xFA01, 0x3AC0, 0x3B80, 0xFB41, 0x3900, 0xF9C1, 0xF881, 0x3840, + 0x2800, 0xE8C1, 0xE981, 0x2940, 0xEB01, 0x2BC0, 0x2A80, 0xEA41, + 0xEE01, 0x2EC0, 0x2F80, 0xEF41, 0x2D00, 0xEDC1, 0xEC81, 0x2C40, + 0xE401, 0x24C0, 0x2580, 0xE541, 0x2700, 0xE7C1, 0xE681, 0x2640, + 0x2200, 0xE2C1, 0xE381, 0x2340, 0xE101, 0x21C0, 0x2080, 0xE041, + 0xA001, 0x60C0, 0x6180, 0xA141, 0x6300, 0xA3C1, 0xA281, 0x6240, + 0x6600, 0xA6C1, 0xA781, 0x6740, 0xA501, 0x65C0, 0x6480, 0xA441, + 0x6C00, 0xACC1, 0xAD81, 0x6D40, 0xAF01, 0x6FC0, 0x6E80, 0xAE41, + 0xAA01, 0x6AC0, 0x6B80, 0xAB41, 0x6900, 0xA9C1, 0xA881, 0x6840, + 0x7800, 0xB8C1, 0xB981, 0x7940, 0xBB01, 0x7BC0, 0x7A80, 0xBA41, + 0xBE01, 0x7EC0, 0x7F80, 0xBF41, 0x7D00, 0xBDC1, 0xBC81, 0x7C40, + 0xB401, 0x74C0, 0x7580, 0xB541, 0x7700, 0xB7C1, 0xB681, 0x7640, + 0x7200, 0xB2C1, 0xB381, 0x7340, 0xB101, 0x71C0, 0x7080, 0xB041, + 0x5000, 0x90C1, 0x9181, 0x5140, 0x9301, 0x53C0, 0x5280, 0x9241, + 0x9601, 0x56C0, 0x5780, 0x9741, 0x5500, 0x95C1, 0x9481, 0x5440, + 0x9C01, 0x5CC0, 0x5D80, 0x9D41, 0x5F00, 0x9FC1, 0x9E81, 0x5E40, + 0x5A00, 0x9AC1, 0x9B81, 0x5B40, 0x9901, 0x59C0, 0x5880, 0x9841, + 0x8801, 0x48C0, 0x4980, 0x8941, 0x4B00, 0x8BC1, 0x8A81, 0x4A40, + 0x4E00, 0x8EC1, 0x8F81, 0x4F40, 0x8D01, 0x4DC0, 0x4C80, 0x8C41, + 0x4400, 0x84C1, 0x8581, 0x4540, 0x8701, 0x47C0, 0x4680, 0x8641, + 0x8201, 0x42C0, 0x4380, 0x8341, 0x4100, 0x81C1, 0x8081, 0x4040 +}; + +/** + * crc16 - compute the CRC-16 for the data buffer + * @crc: previous CRC value + * @buffer: data pointer + * @len: number of bytes in the buffer + * + * Returns the updated CRC value. + */ +u16 crc16(u16 crc, u8 const *buffer, size_t len) +{ + while (len--) + crc = crc16_byte(crc, *buffer++); + return crc; +} diff --git a/fs/ubifs/crc16.h b/fs/ubifs/crc16.h new file mode 100644 index 0000000..9443c08 --- /dev/null +++ b/fs/ubifs/crc16.h @@ -0,0 +1,30 @@ +/* + * crc16.h - CRC-16 routine + * + * Implements the standard CRC-16: + * Width 16 + * Poly 0x8005 (x^16 + x^15 + x^2 + 1) + * Init 0 + * + * Copyright (c) 2005 Ben Gardner bgardner@wabtec.com + * + * This source code is licensed under the GNU General Public License, + * Version 2. See the file COPYING for more details. + */ + +#ifndef __CRC16_H +#define __CRC16_H + +#include <linux/types.h> + +extern u16 const crc16_table[256]; + +extern u16 crc16(u16 crc, const u8 *buffer, size_t len); + +static inline u16 crc16_byte(u16 crc, const u8 data) +{ + return (crc >> 8) ^ crc16_table[(crc ^ data) & 0xff]; +} + +#endif /* __CRC16_H */ + diff --git a/fs/ubifs/debug.c b/fs/ubifs/debug.c new file mode 100644 index 0000000..6afb883 --- /dev/null +++ b/fs/ubifs/debug.c @@ -0,0 +1,156 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Artem Bityutskiy (Битюцкий Артём) + * Adrian Hunter + */ + +/* + * This file implements most of the debugging stuff which is compiled in only + * when it is enabled. But some debugging check functions are implemented in + * corresponding subsystem, just because they are closely related and utilize + * various local functions of those subsystems. + */ + +#define UBIFS_DBG_PRESERVE_UBI + +#include "ubifs.h" + +#ifdef CONFIG_UBIFS_FS_DEBUG + +DEFINE_SPINLOCK(dbg_lock); + +static char dbg_key_buf0[128]; +static char dbg_key_buf1[128]; + +unsigned int ubifs_msg_flags = UBIFS_MSG_FLAGS_DEFAULT; +unsigned int ubifs_chk_flags = UBIFS_CHK_FLAGS_DEFAULT; +unsigned int ubifs_tst_flags; + +module_param_named(debug_msgs, ubifs_msg_flags, uint, S_IRUGO | S_IWUSR); +module_param_named(debug_chks, ubifs_chk_flags, uint, S_IRUGO | S_IWUSR); +module_param_named(debug_tsts, ubifs_tst_flags, uint, S_IRUGO | S_IWUSR); + +MODULE_PARM_DESC(debug_msgs, "Debug message type flags"); +MODULE_PARM_DESC(debug_chks, "Debug check flags"); +MODULE_PARM_DESC(debug_tsts, "Debug special test flags"); + +static const char *get_key_type(int type) +{ + switch (type) { + case UBIFS_INO_KEY: + return "inode"; + case UBIFS_DENT_KEY: + return "direntry"; + case UBIFS_XENT_KEY: + return "xentry"; + case UBIFS_DATA_KEY: + return "data"; + case UBIFS_TRUN_KEY: + return "truncate"; + default: + return "unknown/invalid key"; + } +} + +static void sprintf_key(const struct ubifs_info *c, const union ubifs_key *key, + char *buffer) +{ + char *p = buffer; + int type = key_type(c, key); + + if (c->key_fmt == UBIFS_SIMPLE_KEY_FMT) { + switch (type) { + case UBIFS_INO_KEY: + sprintf(p, "(%lu, %s)", (unsigned long)key_inum(c, key), + get_key_type(type)); + break; + case UBIFS_DENT_KEY: + case UBIFS_XENT_KEY: + sprintf(p, "(%lu, %s, %#08x)", + (unsigned long)key_inum(c, key), + get_key_type(type), key_hash(c, key)); + break; + case UBIFS_DATA_KEY: + sprintf(p, "(%lu, %s, %u)", + (unsigned long)key_inum(c, key), + get_key_type(type), key_block(c, key)); + break; + case UBIFS_TRUN_KEY: + sprintf(p, "(%lu, %s)", + (unsigned long)key_inum(c, key), + get_key_type(type)); + break; + default: + sprintf(p, "(bad key type: %#08x, %#08x)", + key->u32[0], key->u32[1]); + } + } else + sprintf(p, "bad key format %d", c->key_fmt); +} + +const char *dbg_key_str0(const struct ubifs_info *c, const union ubifs_key *key) +{ + /* dbg_lock must be held */ + sprintf_key(c, key, dbg_key_buf0); + return dbg_key_buf0; +} + +const char *dbg_key_str1(const struct ubifs_info *c, const union ubifs_key *key) +{ + /* dbg_lock must be held */ + sprintf_key(c, key, dbg_key_buf1); + return dbg_key_buf1; +} + +/** + * ubifs_debugging_init - initialize UBIFS debugging. + * @c: UBIFS file-system description object + * + * This function initializes debugging-related data for the file system. + * Returns zero in case of success and a negative error code in case of + * failure. + */ +int ubifs_debugging_init(struct ubifs_info *c) +{ + c->dbg = kzalloc(sizeof(struct ubifs_debug_info), GFP_KERNEL); + if (!c->dbg) + return -ENOMEM; + + c->dbg->buf = vmalloc(c->leb_size); + if (!c->dbg->buf) + goto out; + + return 0; + +out: + kfree(c->dbg); + return -ENOMEM; +} + +/** + * ubifs_debugging_exit - free debugging data. + * @c: UBIFS file-system description object + */ +void ubifs_debugging_exit(struct ubifs_info *c) +{ + vfree(c->dbg->buf); + kfree(c->dbg); +} + +#endif /* CONFIG_UBIFS_FS_DEBUG */ diff --git a/fs/ubifs/debug.h b/fs/ubifs/debug.h new file mode 100644 index 0000000..62617b6 --- /dev/null +++ b/fs/ubifs/debug.h @@ -0,0 +1,392 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Artem Bityutskiy (Битюцкий Артём) + * Adrian Hunter + */ + +#ifndef __UBIFS_DEBUG_H__ +#define __UBIFS_DEBUG_H__ + +#ifdef CONFIG_UBIFS_FS_DEBUG + +/** + * ubifs_debug_info - per-FS debugging information. + * @buf: a buffer of LEB size, used for various purposes + * @old_zroot: old index root - used by 'dbg_check_old_index()' + * @old_zroot_level: old index root level - used by 'dbg_check_old_index()' + * @old_zroot_sqnum: old index root sqnum - used by 'dbg_check_old_index()' + * @failure_mode: failure mode for recovery testing + * @fail_delay: 0=>don't delay, 1=>delay a time, 2=>delay a number of calls + * @fail_timeout: time in jiffies when delay of failure mode expires + * @fail_cnt: current number of calls to failure mode I/O functions + * @fail_cnt_max: number of calls by which to delay failure mode + * @chk_lpt_sz: used by LPT tree size checker + * @chk_lpt_sz2: used by LPT tree size checker + * @chk_lpt_wastage: used by LPT tree size checker + * @chk_lpt_lebs: used by LPT tree size checker + * @new_nhead_offs: used by LPT tree size checker + * @new_ihead_lnum: used by debugging to check @c->ihead_lnum + * @new_ihead_offs: used by debugging to check @c->ihead_offs + * + * @saved_lst: saved lprops statistics (used by 'dbg_save_space_info()') + * @saved_free: saved free space (used by 'dbg_save_space_info()') + * + * dfs_dir_name: name of debugfs directory containing this file-system's files + * dfs_dir: direntry object of the file-system debugfs directory + * dfs_dump_lprops: "dump lprops" debugfs knob + * dfs_dump_budg: "dump budgeting information" debugfs knob + * dfs_dump_tnc: "dump TNC" debugfs knob + */ +struct ubifs_debug_info { + void *buf; + struct ubifs_zbranch old_zroot; + int old_zroot_level; + unsigned long long old_zroot_sqnum; + int failure_mode; + int fail_delay; + unsigned long fail_timeout; + unsigned int fail_cnt; + unsigned int fail_cnt_max; + long long chk_lpt_sz; + long long chk_lpt_sz2; + long long chk_lpt_wastage; + int chk_lpt_lebs; + int new_nhead_offs; + int new_ihead_lnum; + int new_ihead_offs; + + struct ubifs_lp_stats saved_lst; + long long saved_free; + + char dfs_dir_name[100]; + struct dentry *dfs_dir; + struct dentry *dfs_dump_lprops; + struct dentry *dfs_dump_budg; + struct dentry *dfs_dump_tnc; +}; + +#define UBIFS_DBG(op) op + +#define ubifs_assert(expr) do { \ + if (unlikely(!(expr))) { \ + printk(KERN_CRIT "UBIFS assert failed in %s at %u (pid %d)\n", \ + __func__, __LINE__, 0); \ + dbg_dump_stack(); \ + } \ +} while (0) + +#define ubifs_assert_cmt_locked(c) do { \ + if (unlikely(down_write_trylock(&(c)->commit_sem))) { \ + up_write(&(c)->commit_sem); \ + printk(KERN_CRIT "commit lock is not locked!\n"); \ + ubifs_assert(0); \ + } \ +} while (0) + +#define dbg_dump_stack() do { \ + if (!dbg_failure_mode) \ + dump_stack(); \ +} while (0) + +/* Generic debugging messages */ +#define dbg_msg(fmt, ...) do { \ + spin_lock(&dbg_lock); \ + printk(KERN_DEBUG "UBIFS DBG (pid %d): %s: " fmt "\n", 0, \ + __func__, ##__VA_ARGS__); \ + spin_unlock(&dbg_lock); \ +} while (0) + +#define dbg_do_msg(typ, fmt, ...) do { \ + if (ubifs_msg_flags & typ) \ + dbg_msg(fmt, ##__VA_ARGS__); \ +} while (0) + +#define dbg_err(fmt, ...) do { \ + spin_lock(&dbg_lock); \ + ubifs_err(fmt, ##__VA_ARGS__); \ + spin_unlock(&dbg_lock); \ +} while (0) + +const char *dbg_key_str0(const struct ubifs_info *c, + const union ubifs_key *key); +const char *dbg_key_str1(const struct ubifs_info *c, + const union ubifs_key *key); + +/* + * DBGKEY macros require @dbg_lock to be held, which it is in the dbg message + * macros. + */ +#define DBGKEY(key) dbg_key_str0(c, (key)) +#define DBGKEY1(key) dbg_key_str1(c, (key)) + +/* General messages */ +#define dbg_gen(fmt, ...) dbg_do_msg(UBIFS_MSG_GEN, fmt, ##__VA_ARGS__) + +/* Additional journal messages */ +#define dbg_jnl(fmt, ...) dbg_do_msg(UBIFS_MSG_JNL, fmt, ##__VA_ARGS__) + +/* Additional TNC messages */ +#define dbg_tnc(fmt, ...) dbg_do_msg(UBIFS_MSG_TNC, fmt, ##__VA_ARGS__) + +/* Additional lprops messages */ +#define dbg_lp(fmt, ...) dbg_do_msg(UBIFS_MSG_LP, fmt, ##__VA_ARGS__) + +/* Additional LEB find messages */ +#define dbg_find(fmt, ...) dbg_do_msg(UBIFS_MSG_FIND, fmt, ##__VA_ARGS__) + +/* Additional mount messages */ +#define dbg_mnt(fmt, ...) dbg_do_msg(UBIFS_MSG_MNT, fmt, ##__VA_ARGS__) + +/* Additional I/O messages */ +#define dbg_io(fmt, ...) dbg_do_msg(UBIFS_MSG_IO, fmt, ##__VA_ARGS__) + +/* Additional commit messages */ +#define dbg_cmt(fmt, ...) dbg_do_msg(UBIFS_MSG_CMT, fmt, ##__VA_ARGS__) + +/* Additional budgeting messages */ +#define dbg_budg(fmt, ...) dbg_do_msg(UBIFS_MSG_BUDG, fmt, ##__VA_ARGS__) + +/* Additional log messages */ +#define dbg_log(fmt, ...) dbg_do_msg(UBIFS_MSG_LOG, fmt, ##__VA_ARGS__) + +/* Additional gc messages */ +#define dbg_gc(fmt, ...) dbg_do_msg(UBIFS_MSG_GC, fmt, ##__VA_ARGS__) + +/* Additional scan messages */ +#define dbg_scan(fmt, ...) dbg_do_msg(UBIFS_MSG_SCAN, fmt, ##__VA_ARGS__) + +/* Additional recovery messages */ +#define dbg_rcvry(fmt, ...) dbg_do_msg(UBIFS_MSG_RCVRY, fmt, ##__VA_ARGS__) + +/* + * Debugging message type flags (must match msg_type_names in debug.c). + * + * UBIFS_MSG_GEN: general messages + * UBIFS_MSG_JNL: journal messages + * UBIFS_MSG_MNT: mount messages + * UBIFS_MSG_CMT: commit messages + * UBIFS_MSG_FIND: LEB find messages + * UBIFS_MSG_BUDG: budgeting messages + * UBIFS_MSG_GC: garbage collection messages + * UBIFS_MSG_TNC: TNC messages + * UBIFS_MSG_LP: lprops messages + * UBIFS_MSG_IO: I/O messages + * UBIFS_MSG_LOG: log messages + * UBIFS_MSG_SCAN: scan messages + * UBIFS_MSG_RCVRY: recovery messages + */ +enum { + UBIFS_MSG_GEN = 0x1, + UBIFS_MSG_JNL = 0x2, + UBIFS_MSG_MNT = 0x4, + UBIFS_MSG_CMT = 0x8, + UBIFS_MSG_FIND = 0x10, + UBIFS_MSG_BUDG = 0x20, + UBIFS_MSG_GC = 0x40, + UBIFS_MSG_TNC = 0x80, + UBIFS_MSG_LP = 0x100, + UBIFS_MSG_IO = 0x200, + UBIFS_MSG_LOG = 0x400, + UBIFS_MSG_SCAN = 0x800, + UBIFS_MSG_RCVRY = 0x1000, +}; + +/* Debugging message type flags for each default debug message level */ +#define UBIFS_MSG_LVL_0 0 +#define UBIFS_MSG_LVL_1 0x1 +#define UBIFS_MSG_LVL_2 0x7f +#define UBIFS_MSG_LVL_3 0xffff + +/* + * Debugging check flags (must match chk_names in debug.c). + * + * UBIFS_CHK_GEN: general checks + * UBIFS_CHK_TNC: check TNC + * UBIFS_CHK_IDX_SZ: check index size + * UBIFS_CHK_ORPH: check orphans + * UBIFS_CHK_OLD_IDX: check the old index + * UBIFS_CHK_LPROPS: check lprops + * UBIFS_CHK_FS: check the file-system + */ +enum { + UBIFS_CHK_GEN = 0x1, + UBIFS_CHK_TNC = 0x2, + UBIFS_CHK_IDX_SZ = 0x4, + UBIFS_CHK_ORPH = 0x8, + UBIFS_CHK_OLD_IDX = 0x10, + UBIFS_CHK_LPROPS = 0x20, + UBIFS_CHK_FS = 0x40, +}; + +/* + * Special testing flags (must match tst_names in debug.c). + * + * UBIFS_TST_FORCE_IN_THE_GAPS: force the use of in-the-gaps method + * UBIFS_TST_RCVRY: failure mode for recovery testing + */ +enum { + UBIFS_TST_FORCE_IN_THE_GAPS = 0x2, + UBIFS_TST_RCVRY = 0x4, +}; + +#if CONFIG_UBIFS_FS_DEBUG_MSG_LVL == 1 +#define UBIFS_MSG_FLAGS_DEFAULT UBIFS_MSG_LVL_1 +#elif CONFIG_UBIFS_FS_DEBUG_MSG_LVL == 2 +#define UBIFS_MSG_FLAGS_DEFAULT UBIFS_MSG_LVL_2 +#elif CONFIG_UBIFS_FS_DEBUG_MSG_LVL == 3 +#define UBIFS_MSG_FLAGS_DEFAULT UBIFS_MSG_LVL_3 +#else +#define UBIFS_MSG_FLAGS_DEFAULT UBIFS_MSG_LVL_0 +#endif + +#ifdef CONFIG_UBIFS_FS_DEBUG_CHKS +#define UBIFS_CHK_FLAGS_DEFAULT 0xffffffff +#else +#define UBIFS_CHK_FLAGS_DEFAULT 0 +#endif + +#define dbg_ntype(type) "" +#define dbg_cstate(cmt_state) "" +#define dbg_get_key_dump(c, key) ({}) +#define dbg_dump_inode(c, inode) ({}) +#define dbg_dump_node(c, node) ({}) +#define dbg_dump_budget_req(req) ({}) +#define dbg_dump_lstats(lst) ({}) +#define dbg_dump_budg(c) ({}) +#define dbg_dump_lprop(c, lp) ({}) +#define dbg_dump_lprops(c) ({}) +#define dbg_dump_lpt_info(c) ({}) +#define dbg_dump_leb(c, lnum) ({}) +#define dbg_dump_znode(c, znode) ({}) +#define dbg_dump_heap(c, heap, cat) ({}) +#define dbg_dump_pnode(c, pnode, parent, iip) ({}) +#define dbg_dump_tnc(c) ({}) +#define dbg_dump_index(c) ({}) + +#define dbg_walk_index(c, leaf_cb, znode_cb, priv) 0 +#define dbg_old_index_check_init(c, zroot) 0 +#define dbg_check_old_index(c, zroot) 0 +#define dbg_check_cats(c) 0 +#define dbg_check_ltab(c) 0 +#define dbg_chk_lpt_free_spc(c) 0 +#define dbg_chk_lpt_sz(c, action, len) 0 +#define dbg_check_synced_i_size(inode) 0 +#define dbg_check_dir_size(c, dir) 0 +#define dbg_check_tnc(c, x) 0 +#define dbg_check_idx_size(c, idx_size) 0 +#define dbg_check_filesystem(c) 0 +#define dbg_check_heap(c, heap, cat, add_pos) ({}) +#define dbg_check_lprops(c) 0 +#define dbg_check_lpt_nodes(c, cnode, row, col) 0 +#define dbg_force_in_the_gaps_enabled 0 +#define dbg_force_in_the_gaps() 0 +#define dbg_failure_mode 0 +#define dbg_failure_mode_registration(c) ({}) +#define dbg_failure_mode_deregistration(c) ({}) + +int ubifs_debugging_init(struct ubifs_info *c); +void ubifs_debugging_exit(struct ubifs_info *c); + +#else /* !CONFIG_UBIFS_FS_DEBUG */ + +#define UBIFS_DBG(op) + +/* Use "if (0)" to make compiler check arguments even if debugging is off */ +#define ubifs_assert(expr) do { \ + if (0 && (expr)) \ + printk(KERN_CRIT "UBIFS assert failed in %s at %u (pid %d)\n", \ + __func__, __LINE__, 0); \ +} while (0) + +#define dbg_err(fmt, ...) do { \ + if (0) \ + ubifs_err(fmt, ##__VA_ARGS__); \ +} while (0) + +#define dbg_msg(fmt, ...) do { \ + if (0) \ + printk(KERN_DEBUG "UBIFS DBG (pid %d): %s: " fmt "\n", \ + 0, __func__, ##__VA_ARGS__); \ +} while (0) + +#define dbg_dump_stack() +#define ubifs_assert_cmt_locked(c) + +#define dbg_gen(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#define dbg_jnl(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#define dbg_tnc(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#define dbg_lp(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#define dbg_find(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#define dbg_mnt(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#define dbg_io(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#define dbg_cmt(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#define dbg_budg(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#define dbg_log(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#define dbg_gc(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#define dbg_scan(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#define dbg_rcvry(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) + +#define DBGKEY(key) ((char *)(key)) +#define DBGKEY1(key) ((char *)(key)) + +#define ubifs_debugging_init(c) 0 +#define ubifs_debugging_exit(c) ({}) + +#define dbg_ntype(type) "" +#define dbg_cstate(cmt_state) "" +#define dbg_get_key_dump(c, key) ({}) +#define dbg_dump_inode(c, inode) ({}) +#define dbg_dump_node(c, node) ({}) +#define dbg_dump_budget_req(req) ({}) +#define dbg_dump_lstats(lst) ({}) +#define dbg_dump_budg(c) ({}) +#define dbg_dump_lprop(c, lp) ({}) +#define dbg_dump_lprops(c) ({}) +#define dbg_dump_lpt_info(c) ({}) +#define dbg_dump_leb(c, lnum) ({}) +#define dbg_dump_znode(c, znode) ({}) +#define dbg_dump_heap(c, heap, cat) ({}) +#define dbg_dump_pnode(c, pnode, parent, iip) ({}) +#define dbg_dump_tnc(c) ({}) +#define dbg_dump_index(c) ({}) + +#define dbg_walk_index(c, leaf_cb, znode_cb, priv) 0 +#define dbg_old_index_check_init(c, zroot) 0 +#define dbg_check_old_index(c, zroot) 0 +#define dbg_check_cats(c) 0 +#define dbg_check_ltab(c) 0 +#define dbg_chk_lpt_free_spc(c) 0 +#define dbg_chk_lpt_sz(c, action, len) 0 +#define dbg_check_synced_i_size(inode) 0 +#define dbg_check_dir_size(c, dir) 0 +#define dbg_check_tnc(c, x) 0 +#define dbg_check_idx_size(c, idx_size) 0 +#define dbg_check_filesystem(c) 0 +#define dbg_check_heap(c, heap, cat, add_pos) ({}) +#define dbg_check_lprops(c) 0 +#define dbg_check_lpt_nodes(c, cnode, row, col) 0 +#define dbg_force_in_the_gaps_enabled 0 +#define dbg_force_in_the_gaps() 0 +#define dbg_failure_mode 0 +#define dbg_failure_mode_registration(c) ({}) +#define dbg_failure_mode_deregistration(c) ({}) + +#endif /* !CONFIG_UBIFS_FS_DEBUG */ + +#endif /* !__UBIFS_DEBUG_H__ */
Dear Stefan Roese,
In message 1236866146-22095-1-git-send-email-sr@denx.de you wrote:
--===============2128501430==
I don't understand the split of this patchset into 8 patches, which all use the very same subject (= commit title line) and commit message.
It seems the splitting was done just for size reasons, not taking into account any logic parts that belong together or bi-sectability.
Please explain why this is not just a single commit?
Hi Wolfgang,
Correct. Even though it should still be git bisectable.
Sure. It's the list limit. It was my understanding that patches > 100k usually are not accepted on the list. This UBIFS support is approx. 500k in total, so I didn't even try to send it as a single patch.
OK, I'll send the patch to list again in a short while.
Best regards, Stefan
Stefan Roese
