[U-Boot] [PATCH 0/6] mips: mscc: gpio: Add MSCC serial GPIO driver
This patch series add the GPIO device (SIO) in the MSCC VCoreIII-based SOCs, and enables it on the supported platforms.
Lars Povlsen (6): mips: mscc_sgpio: Add the MSCC serial GPIO device (SIO) mips: mscc_sgpio: Add DT bindings documentation mips: luton: DT: Enable use of serial gpio mips: luton: Enable use of serial gpio for LED mips: ocelot: DT: Enable use of serial gpio mips: ocelot: Enable use of serial gpio for LED
arch/mips/dts/luton_pcb090.dts | 23 ++ arch/mips/dts/luton_pcb091.dts | 26 ++ arch/mips/dts/mscc,luton.dtsi | 23 ++ arch/mips/dts/mscc,ocelot.dtsi | 25 ++ arch/mips/dts/ocelot_pcb120.dts | 76 ++++++ arch/mips/dts/ocelot_pcb123.dts | 25 ++ board/mscc/luton/luton.c | 6 + board/mscc/ocelot/ocelot.c | 6 + configs/mscc_luton_defconfig | 3 + configs/mscc_ocelot_defconfig | 3 + doc/device-tree-bindings/gpio/mscc_sgpio.txt | 39 +++ drivers/gpio/Kconfig | 11 + drivers/gpio/Makefile | 1 + drivers/gpio/mscc_sgpio.c | 252 +++++++++++++++++++ 14 files changed, 519 insertions(+) create mode 100644 doc/device-tree-bindings/gpio/mscc_sgpio.txt create mode 100644 drivers/gpio/mscc_sgpio.c
This add support for the the MSCC serial GPIO driver in MSCC VCoreIII-based SOCs.
By using a serial interface, the SIO controller significantly extends the number of available GPIOs with a minimum number of additional pins on the device. The primary purpose of the SIO controller is to connect control signals from SFP modules and to act as an LED controller.
This adds the base driver.
Signed-off-by: Lars Povlsen lars.povlsen@microchip.com --- drivers/gpio/Kconfig | 11 ++ drivers/gpio/Makefile | 1 + drivers/gpio/mscc_sgpio.c | 252 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 264 insertions(+) create mode 100644 drivers/gpio/mscc_sgpio.c
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index c8c6c60623..aa55ff43c4 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -106,6 +106,17 @@ config MSCC_BITBANG_SPI_GPIO Support controlling the GPIO used for SPI bitbang by software. Can be used by the VCoreIII SoCs, but it was mainly useful for Luton.
+config MSCC_SGPIO + bool "Microsemi Serial GPIO driver" + depends on DM_GPIO && SOC_VCOREIII + help + Support for the VCoreIII SoC serial GPIO device. By using a + serial interface, the SIO controller significantly extends + the number of available GPIOs with a minimum number of + additional pins on the device. The primary purpose of the + SIO controller is to connect control signals from SFP + modules and to act as an LED controller. + config MSM_GPIO bool "Qualcomm GPIO driver" depends on DM_GPIO diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 61feda1537..be2b3c792f 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -60,3 +60,4 @@ obj-$(CONFIG_$(SPL_)PCF8575_GPIO) += pcf8575_gpio.o obj-$(CONFIG_PM8916_GPIO) += pm8916_gpio.o obj-$(CONFIG_MT7621_GPIO) += mt7621_gpio.o obj-$(CONFIG_MSCC_BITBANG_SPI_GPIO) += gpio-mscc-bitbang-spi.o +obj-$(CONFIG_MSCC_SGPIO) += mscc_sgpio.o diff --git a/drivers/gpio/mscc_sgpio.c b/drivers/gpio/mscc_sgpio.c new file mode 100644 index 0000000000..28f60498fd --- /dev/null +++ b/drivers/gpio/mscc_sgpio.c @@ -0,0 +1,252 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Microsemi SoCs serial gpio driver + * + * Author: lars.povlsen@microchip.com + * License: Dual MIT/GPL + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <common.h> +#include <dm.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <errno.h> +#include <clk.h> + +#define MSCC_SGPIOS_PER_BANK 32 +#define MSCC_SGPIO_BANK_DEPTH 4 + +enum { + REG_INPUT_DATA, + REG_PORT_CONFIG, + REG_PORT_ENABLE, + REG_SIO_CONFIG, + REG_SIO_CLOCK, + MAXREG +}; + +struct mscc_sgpio_bf { + u8 beg; + u8 end; +}; + +struct mscc_sgpio_props { + u8 regoff[MAXREG]; + struct mscc_sgpio_bf auto_repeat; + struct mscc_sgpio_bf port_width; + struct mscc_sgpio_bf clk_freq; + struct mscc_sgpio_bf bit_source; +}; + +#define __M(bf) GENMASK((bf).end, (bf).beg) +#define __F(bf, x) (__M(bf) & ((x) << (bf).beg)) +#define __X(bf, x) (((x) >> (bf).beg) & GENMASK(((bf).end - (bf).beg), 0)) + +#define MSCC_M_CFG_SIO_AUTO_REPEAT(p) BIT(p->props->auto_repeat.beg) +#define MSCC_F_CFG_SIO_PORT_WIDTH(p, x) __F(p->props->port_width, x) +#define MSCC_M_CFG_SIO_PORT_WIDTH(p) __M(p->props->port_width) +#define MSCC_F_CLOCK_SIO_CLK_FREQ(p, x) __F(p->props->clk_freq, x) +#define MSCC_M_CLOCK_SIO_CLK_FREQ(p) __M(p->props->clk_freq) +#define MSCC_F_PORT_CFG_BIT_SOURCE(p, x) __F(p->props->bit_source, x) +#define MSCC_X_PORT_CFG_BIT_SOURCE(p, x) __X(p->props->bit_source, x) + +const struct mscc_sgpio_props props_luton = { + .regoff = { 0x00, 0x09, 0x29, 0x2a, 0x2b }, + .auto_repeat = { 5, 5 }, + .port_width = { 2, 3 }, + .clk_freq = { 0, 11 }, + .bit_source = { 0, 11 }, +}; + +const struct mscc_sgpio_props props_ocelot = { + .regoff = { 0x00, 0x06, 0x26, 0x04, 0x05 }, + .auto_repeat = { 10, 10 }, + .port_width = { 7, 8 }, + .clk_freq = { 8, 19 }, + .bit_source = { 12, 23 }, +}; + +struct mscc_sgpio_priv { + u32 bitcount; + u32 ports; + u32 clock; + u32 mode[MSCC_SGPIOS_PER_BANK]; + u32 __iomem *regs; + const struct mscc_sgpio_props *props; +}; + +static inline u32 sgpio_readl(struct mscc_sgpio_priv *priv, u32 rno, u32 off) +{ + u32 __iomem *reg = &priv->regs[priv->props->regoff[rno] + off]; + + return readl(reg); +} + +static inline void sgpio_writel(struct mscc_sgpio_priv *priv, + u32 val, u32 rno, u32 off) +{ + u32 __iomem *reg = &priv->regs[priv->props->regoff[rno] + off]; + + writel(val, reg); +} + +static void sgpio_clrsetbits(struct mscc_sgpio_priv *priv, + u32 rno, u32 off, u32 clear, u32 set) +{ + u32 __iomem *reg = &priv->regs[priv->props->regoff[rno] + off]; + + clrsetbits_le32(reg, clear, set); +} + +static int mscc_sgpio_direction_input(struct udevice *dev, unsigned int gpio) +{ + struct mscc_sgpio_priv *priv = dev_get_priv(dev); + + u32 port = gpio % MSCC_SGPIOS_PER_BANK; + u32 bit = gpio / MSCC_SGPIOS_PER_BANK; + + priv->mode[port] |= BIT(bit); + + return 0; +} + +static int mscc_sgpio_direction_output(struct udevice *dev, + unsigned int gpio, int value) +{ + struct mscc_sgpio_priv *priv = dev_get_priv(dev); + u32 port = gpio % MSCC_SGPIOS_PER_BANK; + u32 bit = gpio / MSCC_SGPIOS_PER_BANK; + u32 mask = 3 << (3 * bit); + + debug("set: port %d, bit %d, mask 0x%08x, value %d\n", + port, bit, mask, value); + + value = (value & 3) << (3 * bit); + sgpio_clrsetbits(priv, REG_PORT_CONFIG, port, + MSCC_F_PORT_CFG_BIT_SOURCE(priv, mask), + MSCC_F_PORT_CFG_BIT_SOURCE(priv, value)); + clrbits_le32(&priv->mode[port], BIT(bit)); + + return 0; +} + +static int mscc_sgpio_get_function(struct udevice *dev, unsigned int gpio) +{ + struct mscc_sgpio_priv *priv = dev_get_priv(dev); + u32 port = gpio % MSCC_SGPIOS_PER_BANK; + u32 bit = gpio / MSCC_SGPIOS_PER_BANK; + u32 val = priv->mode[port] & BIT(bit); + + if (val) + return GPIOF_INPUT; + else + return GPIOF_OUTPUT; +} + +static int mscc_sgpio_set_value(struct udevice *dev, + unsigned int gpio, int value) +{ + return mscc_sgpio_direction_output(dev, gpio, value); +} + +static int mscc_sgpio_get_value(struct udevice *dev, unsigned int gpio) +{ + struct mscc_sgpio_priv *priv = dev_get_priv(dev); + u32 port = gpio % MSCC_SGPIOS_PER_BANK; + u32 bit = gpio / MSCC_SGPIOS_PER_BANK; + int ret; + + if (mscc_sgpio_get_function(dev, gpio) == GPIOF_INPUT) { + ret = !!(sgpio_readl(priv, REG_INPUT_DATA, bit) & BIT(port)); + } else { + u32 portval = sgpio_readl(priv, REG_PORT_CONFIG, port); + + ret = MSCC_X_PORT_CFG_BIT_SOURCE(priv, portval); + ret = !!(ret & (3 << (3 * bit))); + } + + debug("get: gpio %d, port %d, bit %d, value %d\n", + gpio, port, bit, ret); + return ret; +} + +static int mscc_sgpio_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct mscc_sgpio_priv *priv = dev_get_priv(dev); + const void *fdt = gd->fdt_blob; + int err, div_clock = 0, port, node = dev_of_offset(dev); + u32 val; + struct clk clk; + + err = clk_get_by_index(dev, 0, &clk); + if (!err) { + err = clk_get_rate(&clk); + if (!IS_ERR_VALUE(err)) + div_clock = err; + } else { + debug("mscc_sgpio: failed to get clock\n"); + return err; + } + + priv->props = (const struct mscc_sgpio_props *)dev_get_driver_data(dev); + priv->ports = fdtdec_get_int(fdt, node, "mscc,sgpio-ports", 0xFFFFFFFF); + priv->clock = fdtdec_get_int(fdt, node, + "mscc,sgpio-frequency", 12500000); + if (priv->clock <= 0 || priv->clock > div_clock) { + printf("mscc_sgpio: Invalid frequency %d\n", priv->clock); + return -EINVAL; + } + priv->bitcount = fdtdec_get_int(fdt, node, + "mscc,sgpio-bitcount", 2); + if (priv->bitcount < 1 || priv->bitcount > 4) { + printf("mscc_sgpio: bit count %d\n", priv->bitcount); + return -EINVAL; + } + priv->regs = (u32 __iomem *)devfdt_get_addr(dev); + uc_priv->gpio_count = MSCC_SGPIOS_PER_BANK * priv->bitcount; + uc_priv->bank_name = "sgpio"; + + sgpio_clrsetbits(priv, REG_SIO_CONFIG, 0, + MSCC_M_CFG_SIO_PORT_WIDTH(priv), + MSCC_F_CFG_SIO_PORT_WIDTH(priv, priv->bitcount - 1) | + MSCC_M_CFG_SIO_AUTO_REPEAT(priv)); + val = div_clock / priv->clock; + debug("probe: div-clock = %d KHz, freq = %d KHz, div = %d\n", + div_clock / 1000, priv->clock / 1000, val); + sgpio_clrsetbits(priv, REG_SIO_CLOCK, 0, + MSCC_M_CLOCK_SIO_CLK_FREQ(priv), + MSCC_F_CLOCK_SIO_CLK_FREQ(priv, val)); + + for (port = 0; port < 32; port++) + sgpio_writel(priv, 0, REG_PORT_CONFIG, port); + sgpio_writel(priv, priv->ports, REG_PORT_ENABLE, 0); + + debug("probe: sgpio regs = %p\n", priv->regs); + + return 0; +} + +static const struct dm_gpio_ops mscc_sgpio_ops = { + .direction_input = mscc_sgpio_direction_input, + .direction_output = mscc_sgpio_direction_output, + .get_function = mscc_sgpio_get_function, + .get_value = mscc_sgpio_get_value, + .set_value = mscc_sgpio_set_value, +}; + +static const struct udevice_id mscc_sgpio_ids[] = { + { .compatible = "mscc,luton-sgpio", .data = (ulong)&props_luton }, + { .compatible = "mscc,ocelot-sgpio", .data = (ulong)&props_ocelot }, + { } +}; + +U_BOOT_DRIVER(gpio_mscc_sgpio) = { + .name = "mscc-sgpio", + .id = UCLASS_GPIO, + .of_match = mscc_sgpio_ids, + .ops = &mscc_sgpio_ops, + .probe = mscc_sgpio_probe, + .priv_auto_alloc_size = sizeof(struct mscc_sgpio_priv), +};
Am 20.12.18 um 21:11 schrieb Lars Povlsen:
+config MSCC_SGPIO
- bool "Microsemi Serial GPIO driver"
- depends on DM_GPIO && SOC_VCOREIII
- help
- Microsemi SoCs serial gpio driver
- Author: lars.povlsen@microchip.com
- License: Dual MIT/GPL
this line is redundant due to the SPDX identifier
- Copyright (c) 2018 Microsemi Corporation
+enum {
- REG_INPUT_DATA,
- REG_PORT_CONFIG,
- REG_PORT_ENABLE,
- REG_SIO_CONFIG,
- REG_SIO_CLOCK,
- MAXREG
- u8 beg;
- u8 end;
- u8 regoff[MAXREG];
- struct mscc_sgpio_bf auto_repeat;
- struct mscc_sgpio_bf port_width;
- struct mscc_sgpio_bf clk_freq;
- struct mscc_sgpio_bf bit_source;
- .regoff = { 0x00, 0x09, 0x29, 0x2a, 0x2b },
- .auto_repeat = { 5, 5 },
- .port_width = { 2, 3 },
- .clk_freq = { 0, 11 },
- .bit_source = { 0, 11 },
- .regoff = { 0x00, 0x06, 0x26, 0x04, 0x05 },
- .auto_repeat = { 10, 10 },
- .port_width = { 7, 8 },
- .clk_freq = { 8, 19 },
- .bit_source = { 12, 23 },
- u32 bitcount;
- u32 ports;
- u32 clock;
- u32 mode[MSCC_SGPIOS_PER_BANK];
- u32 __iomem *regs;
- const struct mscc_sgpio_props *props;
- u32 __iomem *reg = &priv->regs[priv->props->regoff[rno] + off];
- return readl(reg);
- writel(val, reg);
- clrsetbits_le32(reg, clear, set);
- struct mscc_sgpio_priv *priv = dev_get_priv(dev);
- u32 port = gpio % MSCC_SGPIOS_PER_BANK;
- u32 bit = gpio / MSCC_SGPIOS_PER_BANK;
- priv->mode[port] |= BIT(bit);
- u32 mask = 3 << (3 * bit);
- debug("set: port %d, bit %d, mask 0x%08x, value %d\n",
- value = (value & 3) << (3 * bit);
- sgpio_clrsetbits(priv, REG_PORT_CONFIG, port,
- clrbits_le32(&priv->mode[port], BIT(bit));
- u32 val = priv->mode[port] & BIT(bit);
- if (val)
return GPIOF_INPUT;
- else
- return mscc_sgpio_direction_output(dev, gpio, value);
- int ret;
- if (mscc_sgpio_get_function(dev, gpio) == GPIOF_INPUT) {
- } else {
- debug("get: gpio %d, port %d, bit %d, value %d\n",
- return ret;
- struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- const void *fdt = gd->fdt_blob;
- int err, div_clock = 0, port, node = dev_of_offset(dev);
- u32 val;
- struct clk clk;
- err = clk_get_by_index(dev, 0, &clk);
- if (!err) {
div_clock = err;
- } else {
return err;
- priv->props = (const struct mscc_sgpio_props *)dev_get_driver_data(dev);
- priv->ports = fdtdec_get_int(fdt, node, "mscc,sgpio-ports", 0xFFFFFFFF);
- priv->clock = fdtdec_get_int(fdt, node,
- if (priv->clock <= 0 || priv->clock > div_clock) {
return -EINVAL;
- priv->bitcount = fdtdec_get_int(fdt, node,
you should use the newer DM API from include/dm/read.h which is more readable and you don't need to poke on gd->fdt_blob anymore. This would also make your driver live-tree compatible in case you want to enable that in the future.
- if (priv->bitcount < 1 || priv->bitcount > 4) {
return -EINVAL;
- priv->regs = (u32 __iomem *)devfdt_get_addr(dev);
don't you need some mapping to a virtual address? Or is this mapped through TLB? Actually the address from device tree should be a physical one.
- uc_priv->gpio_count = MSCC_SGPIOS_PER_BANK * priv->bitcount;
- uc_priv->bank_name = "sgpio";
- sgpio_clrsetbits(priv, REG_SIO_CONFIG, 0,
- val = div_clock / priv->clock;
- debug("probe: div-clock = %d KHz, freq = %d KHz, div = %d\n",
- sgpio_clrsetbits(priv, REG_SIO_CLOCK, 0,
- for (port = 0; port < 32; port++)
- sgpio_writel(priv, priv->ports, REG_PORT_ENABLE, 0);
- debug("probe: sgpio regs = %p\n", priv->regs);
- .direction_input = mscc_sgpio_direction_input,
- .direction_output = mscc_sgpio_direction_output,
- .get_function = mscc_sgpio_get_function,
- .get_value = mscc_sgpio_get_value,
- .set_value = mscc_sgpio_set_value,
- { .compatible = "mscc,luton-sgpio", .data = (ulong)&props_luton },
- { .compatible = "mscc,ocelot-sgpio", .data = (ulong)&props_ocelot },
- .name = "mscc-sgpio",
- .id = UCLASS_GPIO,
- .of_match = mscc_sgpio_ids,
- .ops = &mscc_sgpio_ops,
- .probe = mscc_sgpio_probe,
- .priv_auto_alloc_size = sizeof(struct mscc_sgpio_priv),
Hi Daniel!
Thank you for the input. I am about to have a new v2 ready.
Comments below.
---Lars
-----Original Message----- From: Daniel Schwierzeck daniel.schwierzeck@gmail.com Sent: Thursday, December 20, 2018 21:53 To: Lars Povlsen - M31675 Lars.Povlsen@microchip.com; u- boot@lists.denx.de Cc: gregory.clement@bootlin.com; Horatiu Vultur - M31836 Horatiu.Vultur@microchip.com Subject: Re: [PATCH 1/6] mips: mscc_sgpio: Add the MSCC serial GPIO device (SIO)
[snip]
Removed.
[snip]
- u32 val;
- struct clk clk;
- if (!err) {
div_clock = err;
- } else {
return err;
0xFFFFFFFF);
return -EINVAL;
Now using dev_read_u32_default() instead.
return -EINVAL;
There is a 1:1 phys to virtual TLB mapping. Also, most of the other GPIO drivers do it the same, but I added a map_physmem() call.
---Lars
- Daniel
This add device tree binding documentation for the MSCC serial GPIO driver.
Signed-off-by: Lars Povlsen lars.povlsen@microsemi.com --- doc/device-tree-bindings/gpio/mscc_sgpio.txt | 39 ++++++++++++++++++++ 1 file changed, 39 insertions(+) create mode 100644 doc/device-tree-bindings/gpio/mscc_sgpio.txt
diff --git a/doc/device-tree-bindings/gpio/mscc_sgpio.txt b/doc/device-tree-bindings/gpio/mscc_sgpio.txt new file mode 100644 index 0000000000..24e6aa345e --- /dev/null +++ b/doc/device-tree-bindings/gpio/mscc_sgpio.txt @@ -0,0 +1,39 @@ +MSCC Serial GPIO driver + +Required properties: +- compatible : "mscc,luton-sgpio" or "mscc,ocelot-sgpio" +- clock: Reference clock used to generate clock divider setting. See + mscc,sgpio-frequency property. +- reg : Physical base address and length of the controller's registers. +- #gpio-cells : Should be two. The first cell is the pin number and the + second cell is used to specify optional parameters: + - bit 0 specifies polarity (0 for normal, 1 for inverted) +- gpio-controller : Marks the device node as a GPIO controller. +- gpio-ranges: The 4th cell will typically be 32*<sgpio-bitcount> + +Optional properties: +- mscc,sgpio-frequency: The frequency at which the serial bitstream is + generated and sampled. Default: 12500000 (Hz). +- mscc,sgpio-bitcount: The number of bits enabled per + port. (1-4). Default: 2. +- mscc,sgpio-ports: A bitmask (32 bits) of which ports are enabled in + the serialized gpio stream. Default: 0xFFFFFFFF. + +Typically the pinctrl-0 and pinctrl-names properties will also be +present to enable the use of the SIO CLK, LD, DI and DO for some +regular GPIO pins. + +Example: + +sgpio: gpio@10700f8 { + compatible = "mscc,ocelot-sgpio"; + pinctrl-0 = <&sgpio_pins>; + pinctrl-names = "default"; + reg = <0x10700f8 0x100>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&sgpio 0 0 64>; // 32*<sgpio-bitcount> + mscc,sgpio-frequency = <12500>; + mscc,sgpio-bitcount = <2>; + mscc,sgpio-ports = <0x000FFFFF>; +};
This enables the use of the MSCC serial GPIO driver, and add gpio-leds nodes to the 'luton' pcb090 and pcb091 DT.
Signed-off-by: Lars Povlsen lars.povlsen@microsemi.com --- arch/mips/dts/luton_pcb090.dts | 23 +++++++++++++++++++++++ arch/mips/dts/luton_pcb091.dts | 26 ++++++++++++++++++++++++++ arch/mips/dts/mscc,luton.dtsi | 23 +++++++++++++++++++++++ 3 files changed, 72 insertions(+)
diff --git a/arch/mips/dts/luton_pcb090.dts b/arch/mips/dts/luton_pcb090.dts index a3f8926ad9..15fdb2a1cb 100644 --- a/arch/mips/dts/luton_pcb090.dts +++ b/arch/mips/dts/luton_pcb090.dts @@ -18,6 +18,29 @@ chosen { stdout-path = "serial0:115200n8"; }; + + gpio-leds { + compatible = "gpio-leds"; + + status_green { + label = "pcb090:green:status"; + gpios = <&sgpio 64 GPIO_ACTIVE_HIGH>; // p0.2 + default-state = "on"; + }; + + status_red { + label = "pcb090:red:status"; + gpios = <&sgpio 65 GPIO_ACTIVE_HIGH>; // p1.2 + default-state = "off"; + }; + }; +}; + +&sgpio { + status = "okay"; + gpio-ranges = <&sgpio 0 0 96>; // 32*<sgpio-bitcount> + sgpio-ports = <0xFFFFFFFF>; + sgpio-bitcount = <3>; };
&uart0 { diff --git a/arch/mips/dts/luton_pcb091.dts b/arch/mips/dts/luton_pcb091.dts index 74f9274c21..a94e888f98 100644 --- a/arch/mips/dts/luton_pcb091.dts +++ b/arch/mips/dts/luton_pcb091.dts @@ -18,6 +18,32 @@ chosen { stdout-path = "serial0:115200n8"; }; + + gpio-leds { + compatible = "gpio-leds"; + + top_dimmer { + label = "pcb091:top:dimmer"; + gpios = <&gpio 29 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + + status_green { + label = "pcb091:green:status"; + gpios = <&sgpio 26 GPIO_ACTIVE_HIGH>; /* p26.0 */ + default-state = "on"; + }; + + status_red { + label = "pcb091:red:status"; + gpios = <&sgpio 58 GPIO_ACTIVE_HIGH>; /* p26.1 */ + default-state = "off"; + }; + }; +}; + +&sgpio { + status = "okay"; };
&uart0 { diff --git a/arch/mips/dts/mscc,luton.dtsi b/arch/mips/dts/mscc,luton.dtsi index 6a4ad2a5be..d2b6843a7a 100644 --- a/arch/mips/dts/mscc,luton.dtsi +++ b/arch/mips/dts/mscc,luton.dtsi @@ -25,6 +25,11 @@ serial0 = &uart0; };
+ sys_clk: sys-clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <250000000>; + }; ahb_clk: ahb-clk { compatible = "fixed-clock"; #clock-cells = <0>; @@ -57,11 +62,29 @@ #gpio-cells = <2>; gpio-ranges = <&gpio 0 0 32>;
+ sgpio_pins: sgpio-pins { + pins = "GPIO_0", "GPIO_1", "GPIO_2", "GPIO_3"; + function = "sio"; + }; uart_pins: uart-pins { pins = "GPIO_30", "GPIO_31"; function = "uart"; }; + };
+ sgpio: gpio@70130 { + compatible = "mscc,luton-sgpio"; + status = "disabled"; + clocks = <&sys_clk>; + pinctrl-0 = <&sgpio_pins>; + pinctrl-names = "default"; + reg = <0x0070130 0x100>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&sgpio 0 0 64>; /* 32*<sgpio-bitcount> */ + mscc,sgpio-ports = <0xFFF000FF>; + mscc,sgpio-frequency = <12500000>; + mscc,sgpio-bitcount = <2>; };
gpio_spi_bitbang: gpio@10000064 {
This enables the use of the MSCC serial GPIO driver to control the LEDs on the MSCC VCoreIII 'luton' SoC.
Signed-off-by: Lars Povlsen lars.povlsen@microchip.com --- board/mscc/luton/luton.c | 6 ++++++ configs/mscc_luton_defconfig | 3 +++ 2 files changed, 9 insertions(+)
diff --git a/board/mscc/luton/luton.c b/board/mscc/luton/luton.c index b509b6beb3..807c717e33 100644 --- a/board/mscc/luton/luton.c +++ b/board/mscc/luton/luton.c @@ -5,6 +5,7 @@
#include <common.h> #include <asm/io.h> +#include <led.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -27,6 +28,11 @@ int board_early_init_r(void)
/* Address of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE; + + /* LED setup */ + if (IS_ENABLED(CONFIG_LED)) + led_default_state(); + return 0; }
diff --git a/configs/mscc_luton_defconfig b/configs/mscc_luton_defconfig index 03922f5379..0b3eb3865c 100644 --- a/configs/mscc_luton_defconfig +++ b/configs/mscc_luton_defconfig @@ -46,6 +46,9 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_GPIO=y +CONFIG_MSCC_SGPIO=y +CONFIG_LED=y +CONFIG_LED_GPIO=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y
This enables the use of the MSCC serial GPIO driver on the MSCC VCoreIII 'ocelot' SOC, and add gpio-leds nodes to the pcb123 and pcb120 DT.
Signed-off-by: Lars Povlsen lars.povlsen@microsemi.com --- arch/mips/dts/mscc,ocelot.dtsi | 25 +++++++++++ arch/mips/dts/ocelot_pcb120.dts | 76 +++++++++++++++++++++++++++++++++ arch/mips/dts/ocelot_pcb123.dts | 25 +++++++++++ 3 files changed, 126 insertions(+)
diff --git a/arch/mips/dts/mscc,ocelot.dtsi b/arch/mips/dts/mscc,ocelot.dtsi index 87b4736285..e22bd2c949 100644 --- a/arch/mips/dts/mscc,ocelot.dtsi +++ b/arch/mips/dts/mscc,ocelot.dtsi @@ -37,6 +37,12 @@ clock-frequency = <500000000>; };
+ sys_clk: sys-clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <250000000>; + }; + ahb_clk: ahb-clk { compatible = "fixed-clock"; #clock-cells = <0>; @@ -118,6 +124,11 @@ #gpio-cells = <2>; gpio-ranges = <&gpio 0 0 22>;
+ sgpio_pins: sgpio-pins { + pins = "GPIO_0", "GPIO_1", "GPIO_2", "GPIO_3"; + function = "sg0"; + }; + uart_pins: uart-pins { pins = "GPIO_6", "GPIO_7"; function = "uart"; @@ -148,5 +159,19 @@ function = "si"; }; }; + + sgpio: gpio@10700f8 { + compatible = "mscc,ocelot-sgpio"; + status = "disabled"; + clocks = <&sys_clk>; + pinctrl-0 = <&sgpio_pins>; + pinctrl-names = "default"; + reg = <0x10700f8 0x100>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&sgpio 0 0 64>; /* 32*<sgpio-bitcount> */ + mscc,sgpio-frequency = <12500000>; + mscc,sgpio-bitcount = <2>; + }; }; }; diff --git a/arch/mips/dts/ocelot_pcb120.dts b/arch/mips/dts/ocelot_pcb120.dts index 47d305a614..658719e684 100644 --- a/arch/mips/dts/ocelot_pcb120.dts +++ b/arch/mips/dts/ocelot_pcb120.dts @@ -9,4 +9,80 @@ / { model = "Ocelot PCB120 Reference Board"; compatible = "mscc,ocelot-pcb120", "mscc,ocelot"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + gpio-leds { + compatible = "gpio-leds"; + + poe_green { + label = "pcb120:green:poe"; + gpios = <&sgpio 44 1>; /* p12.1 */ + default-state = "off"; + }; + + poe_red { + label = "pcb120:red:poe"; + gpios = <&sgpio 12 1>; /* p12.0 */ + default-state = "off"; + }; + + alarm_green { + label = "pcb120:green:alarm"; + gpios = <&sgpio 45 1>; /* p13.1 */ + default-state = "off"; + }; + + alarm_red { + label = "pcb120:red:alarm"; + gpios = <&sgpio 13 1>; /* p13.0 */ + default-state = "off"; + }; + + dc_a_green { + label = "pcb120:green:dc_a"; + gpios = <&sgpio 46 1>; /* p14.1 */ + default-state = "off"; + }; + + dc_a_red { + label = "pcb120:red:dc_a"; + gpios = <&sgpio 14 1>; /* p14.0 */ + default-state = "off"; + }; + + dc_b_green { + label = "pcb120:green:dc_b"; + gpios = <&sgpio 47 1>; /* p15.1 */ + default-state = "off"; + }; + + dc_b_red { + label = "pcb120:red:dc_b"; + gpios = <&sgpio 15 1>; /* p15.0 */ + default-state = "off"; + }; + + status_green { + label = "pcb120:green:status"; + gpios = <&sgpio 48 1>; /* p16.1 */ + default-state = "on"; + }; + + status_red { + label = "pcb120:red:alarm"; + gpios = <&sgpio 16 1>; /* p16.0 */ + default-state = "off"; + }; + + }; + +}; + +&sgpio { + status = "okay"; + mscc,sgpio-ports = <0x000FFFFF>; }; + diff --git a/arch/mips/dts/ocelot_pcb123.dts b/arch/mips/dts/ocelot_pcb123.dts index 17d8d326ce..c4cb7a1194 100644 --- a/arch/mips/dts/ocelot_pcb123.dts +++ b/arch/mips/dts/ocelot_pcb123.dts @@ -9,4 +9,29 @@ / { model = "Ocelot PCB123 Reference Board"; compatible = "mscc,ocelot-pcb123", "mscc,ocelot"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + gpio-leds { + compatible = "gpio-leds"; + + status_green { + label = "pcb123:green:status"; + gpios = <&sgpio 43 1>; /* p11.1 */ + default-state = "on"; + }; + + status_red { + label = "pcb123:red:status"; + gpios = <&sgpio 11 1>; /* p11.0 */ + default-state = "off"; + }; + }; +}; + +&sgpio { + status = "okay"; + mscc,sgpio-ports = <0x00FFFFFF>; };
This enables the use of the MSCC serial GPIO driver to control the LEDs on the MSCC VCoreIII 'ocelot' pcb123 and pcb120.
Signed-off-by: Lars Povlsen lars.povlsen@microchip.com --- board/mscc/ocelot/ocelot.c | 6 ++++++ configs/mscc_ocelot_defconfig | 3 +++ 2 files changed, 9 insertions(+)
diff --git a/board/mscc/ocelot/ocelot.c b/board/mscc/ocelot/ocelot.c index a557cacd1b..a05c308669 100644 --- a/board/mscc/ocelot/ocelot.c +++ b/board/mscc/ocelot/ocelot.c @@ -9,6 +9,7 @@ #include <asm/types.h> #include <environment.h> #include <spi.h> +#include <led.h>
@@ -56,6 +57,11 @@ int board_early_init_r(void)
diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index 66451000d9..fb6a5bdc31 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -48,6 +48,9 @@ CONFIG_CLK=y CONFIG_DM_GPIO=y CONFIG_MTD=y CONFIG_MTD_SPI_NAND=y +CONFIG_MSCC_SGPIO=y +CONFIG_LED=y +CONFIG_LED_GPIO=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y
Daniel Schwierzeck
Lars Povlsen
