[PULL] Pull request for u-boot master / v2021.07 = u-boot-stm32-20210312
Hi Tom
Please pull the STM32 related patches for u-boot/master, v2021.07: u-boot-stm32-20210312
CI status: https://source.denx.de/u-boot/custodians/u-boot-stm/-/pipelines/6732
he following changes since commit c5219c4a18f2b27547ecd799914f94e48b0fa86f:
Prepare v2021.04-rc3 (2021-03-01 22:46:41 -0500)
https://source.denx.de/u-boot/custodians/u-boot-stm.git tags/u-boot-stm32-20210312
for you to fetch changes up to b076cbe8aa2b3c29a3acc89fbea9fb7676f15fa7:
doc: stm32mp1: Use u-boot.itb if CONFIG_SPL_LOAD_FIT=y (2021-03-12 15:25:55 +0100)
---------------------------------------------------------------- - Add WATCHDOG_RESET() in MTD framework and STM32 QSPI driver - stm32mp1_trusted_defconfig rely on SCMI support - Remove the nand MTD configuration for NOR boot in stm32mp1 board - STM32programmer update - Bsec: manage clock when present in device tree - stm32mp15: move bootdelay configuration in defconfig - Update for stm32 dsi and dw_mipi_dsi - STM32 MCU's cleanup - Fix compilation issue depending on SYS_DCACHE_OFF and SYS_ICACHE_OFF flags - Update stm32mp1 doc
---------------------------------------------------------------- Etienne Carriere (2): ARM: dts: stm32mp1: explicit clock reference needed by RCC clock driver clk: stm32mp1: gets root clocks from fdt
Marek Vasut (1): doc: stm32mp1: Use u-boot.itb if CONFIG_SPL_LOAD_FIT=y
Patrice Chotard (7): mtd: spi-nor: Add WATCHDOG_RESET() in spi_nor_core callbacks spi: stm32_qspi: Add WATCHDOG_RESET in _stm32_qspi_read_fifo() mtd: nand: Add WATCHDOG_RESET() in nanddev_mtd_erase() mtd: spinand: Add WATCHDOG_RESET() in spinand_mtd_read/write() configs: stm32: Remove BOARD_EARLY_INIT_F and BOARD_LATE_INIT for stm32 boards board: st: Remove board_early_init_f and board_late_init callbacks for stm32 boards arm: stm32mp: Fix compilation issue when SYS_DCACHE_OFF and/or SYS_DCACHE_SYS are enabled
Patrick Delaunay (13): scmi: Include device_compat.h scmi: define LOG_CATEGORY scmi: cosmetic: reorder include files configs: stm32mp1_trusted_defconfig rely on SCMI support board: st: remove the nand MTD configuration for NOR boot in stm32mp1 board stm32mp: stm32prog: Add Kconfig file for stm32prog command stm32mp: stm32prog: Add CONFIG_CMD_STM32PROG_SERIAL and _USB stm32mp: stm32prog: reactivate console and display serial error stm32mp: stm32prog: replace alias by serial device sequence number stm32mp: bsec: manage clock when present in device tree configs: stm32mp15: move bootdelay configuration in defconfig video: stm32: remove all child of DSI bridge when its probe failed board: stm32mp1: use CONFIG_SYS_MMC_ENV_DEV when available
Yannick Fertre (2): video: dw_mipi_dsi: missing device to log debug video: dw_mipi_dsi: update log of dphy_enable
arch/arm/dts/stm32mp151.dtsi | 4 ++ arch/arm/mach-stm32mp/Kconfig | 18 +------ arch/arm/mach-stm32mp/Makefile | 2 +- arch/arm/mach-stm32mp/bsec.c | 10 ++++ arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig | 34 ++++++++++++ arch/arm/mach-stm32mp/cmd_stm32prog/Makefile | 8 +-- .../arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c | 4 +- arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h | 23 +++++++- .../mach-stm32mp/cmd_stm32prog/stm32prog_serial.c | 29 +++------- arch/arm/mach-stm32mp/cpu.c | 28 ++++++---- board/st/common/stm32mp_dfu.c | 9 ++-- board/st/common/stm32mp_mtdparts.c | 16 ++---- board/st/stm32f429-discovery/stm32f429-discovery.c | 5 -- .../st/stm32f429-evaluation/stm32f429-evaluation.c | 5 -- board/st/stm32f469-discovery/stm32f469-discovery.c | 5 -- board/st/stm32f746-disco/stm32f746-disco.c | 5 -- board/st/stm32h743-disco/stm32h743-disco.c | 10 ---- board/st/stm32h743-eval/stm32h743-eval.c | 10 ---- board/st/stm32mp1/stm32mp1.c | 8 ++- configs/stm32f429-discovery_defconfig | 1 - configs/stm32f429-evaluation_defconfig | 1 - configs/stm32f469-discovery_defconfig | 1 - configs/stm32f746-disco_defconfig | 1 - configs/stm32f769-disco_defconfig | 2 - configs/stm32h743-disco_defconfig | 2 - configs/stm32h743-eval_defconfig | 2 - configs/stm32mp15_basic_defconfig | 2 + configs/stm32mp15_dhcom_basic_defconfig | 1 + configs/stm32mp15_dhcor_basic_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 4 ++ doc/board/st/stm32mp1.rst | 16 ++++-- drivers/clk/clk_stm32mp1.c | 62 ++++++++-------------- drivers/firmware/scmi/mailbox_agent.c | 4 +- drivers/firmware/scmi/sandbox-scmi_agent.c | 2 + drivers/firmware/scmi/sandbox-scmi_devices.c | 2 + drivers/firmware/scmi/scmi_agent-uclass.c | 5 +- drivers/firmware/scmi/smccc_agent.c | 3 ++ drivers/firmware/scmi/smt.c | 2 + drivers/mtd/nand/core.c | 2 + drivers/mtd/nand/spi/core.c | 3 ++ drivers/mtd/spi/spi-nor-core.c | 3 ++ drivers/spi/stm32_qspi.c | 2 + drivers/video/dw_mipi_dsi.c | 9 ++-- drivers/video/stm32/stm32_dsi.c | 3 ++ include/configs/stm32mp1.h | 1 - 45 files changed, 193 insertions(+), 177 deletions(-) create mode 100644 arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig
On Mon, Mar 15, 2021 at 08:35:48AM +0100, Patrice CHOTARD wrote:
Hi Tom
Patrice CHOTARD
