[U-Boot] [PATCH v3 0/2] at91: video: add driver for Atmel HLCD controller
The i2c driver includes two parts. 1) Driver code to implement the HLCD function. 2) Device tree binding documentation, it describes how to add the HLCD in device tree.
Changes in v3: - Replace lcdc_readl/lcdc_writel with real/writel - Replace while() with wait_for_bit(). - Disable the clock if the clock is enabled and error occurs. - Add 'atmel,output-mode' entry in dts.
Changes in v2: - Due to the peripheral clock driver improvement, remove the unneccessary clock calling.
Songjun Wu (2): at91: video: Support driver-model for the HLCD driver at91: video: DT binding for HLCDC driver
doc/device-tree-bindings/video/atme-hlcdc.txt | 42 +++ drivers/video/Kconfig | 6 + drivers/video/atmel_hlcdfb.c | 481 ++++++++++++++++++++++---- 3 files changed, 458 insertions(+), 71 deletions(-) create mode 100644 doc/device-tree-bindings/video/atme-hlcdc.txt
Add driver-model support to this driver.
Signed-off-by: Songjun Wu songjun.wu@microchip.com ---
drivers/video/Kconfig | 6 + drivers/video/atmel_hlcdfb.c | 481 ++++++++++++++++++++++++++++++++++++------- 2 files changed, 416 insertions(+), 71 deletions(-)
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 2069576958..0f49612cd0 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -371,6 +371,12 @@ config DISPLAY The devices provide a simple interface to start up the display, read display information and enable it.
+config ATMEL_HLCD + bool "Enable ATMEL video support using HLCDC" + depends on DM_VIDEO + help + HLCDC supports video output to an attached LCD panel. + config VIDEO_BROADWELL_IGD bool "Enable Intel Broadwell integrated graphics device" depends on X86 diff --git a/drivers/video/atmel_hlcdfb.c b/drivers/video/atmel_hlcdfb.c index 960b474b76..ef1dbccd27 100644 --- a/drivers/video/atmel_hlcdfb.c +++ b/drivers/video/atmel_hlcdfb.c @@ -10,13 +10,22 @@ #include <asm/io.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> +#include <clk.h> +#include <dm.h> +#include <fdtdec.h> #include <lcd.h> +#include <video.h> +#include <wait_bit.h> #include <atmel_hlcdc.h>
#if defined(CONFIG_LCD_LOGO) #include <bmp_logo.h> #endif
+DECLARE_GLOBAL_DATA_PTR; + +#ifndef CONFIG_DM_VIDEO + /* configurable parameters */ #define ATMEL_LCDC_CVAL_DEFAULT 0xc8 #define ATMEL_LCDC_DMA_BURST_LEN 8 @@ -26,19 +35,16 @@
#define ATMEL_LCDC_FIFO_SIZE 512
-#define lcdc_readl(reg) __raw_readl((reg)) -#define lcdc_writel(reg, val) __raw_writel((val), (reg)) - /* * the CLUT register map as following * RCLUT(24 ~ 16), GCLUT(15 ~ 8), BCLUT(7 ~ 0) */ void lcd_setcolreg(ushort regno, ushort red, ushort green, ushort blue) { - lcdc_writel(((red << LCDC_BASECLUT_RCLUT_Pos) & LCDC_BASECLUT_RCLUT_Msk) - | ((green << LCDC_BASECLUT_GCLUT_Pos) & LCDC_BASECLUT_GCLUT_Msk) - | ((blue << LCDC_BASECLUT_BCLUT_Pos) & LCDC_BASECLUT_BCLUT_Msk), - panel_info.mmio + ATMEL_LCDC_LUT(regno)); + writel(panel_info.mmio + ATMEL_LCDC_LUT(regno), + ((red << LCDC_BASECLUT_RCLUT_Pos) & LCDC_BASECLUT_RCLUT_Msk) + | ((green << LCDC_BASECLUT_GCLUT_Pos) & LCDC_BASECLUT_GCLUT_Msk) + | ((blue << LCDC_BASECLUT_BCLUT_Pos) & LCDC_BASECLUT_BCLUT_Msk)); }
ushort *configuration_get_cmap(void) @@ -55,6 +61,7 @@ void lcd_ctrl_init(void *lcdbase) unsigned long value; struct lcd_dma_desc *desc; struct atmel_hlcd_regs *regs; + int ret;
if (!has_lcdc()) return; /* No lcdc */ @@ -62,21 +69,29 @@ void lcd_ctrl_init(void *lcdbase) regs = (struct atmel_hlcd_regs *)panel_info.mmio;
/* Disable DISP signal */ - lcdc_writel(®s->lcdc_lcddis, LCDC_LCDDIS_DISPDIS); - while ((lcdc_readl(®s->lcdc_lcdsr) & LCDC_LCDSR_DISPSTS)) - udelay(1); + writel(LCDC_LCDDIS_DISPDIS, ®s->lcdc_lcddis); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_DISPSTS, + false, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); /* Disable synchronization */ - lcdc_writel(®s->lcdc_lcddis, LCDC_LCDDIS_SYNCDIS); - while ((lcdc_readl(®s->lcdc_lcdsr) & LCDC_LCDSR_LCDSTS)) - udelay(1); + writel(LCDC_LCDDIS_SYNCDIS, ®s->lcdc_lcddis); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_LCDSTS, + false, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); /* Disable pixel clock */ - lcdc_writel(®s->lcdc_lcddis, LCDC_LCDDIS_CLKDIS); - while ((lcdc_readl(®s->lcdc_lcdsr) & LCDC_LCDSR_CLKSTS)) - udelay(1); + writel(LCDC_LCDDIS_CLKDIS, ®s->lcdc_lcddis); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_CLKSTS, + false, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); /* Disable PWM */ - lcdc_writel(®s->lcdc_lcddis, LCDC_LCDDIS_PWMDIS); - while ((lcdc_readl(®s->lcdc_lcdsr) & LCDC_LCDSR_PWMSTS)) - udelay(1); + writel(LCDC_LCDDIS_PWMDIS, ®s->lcdc_lcddis); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_PWMSTS, + false, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__);
/* Set pixel clock */ value = get_lcdc_clk_rate(0) / panel_info.vl_clk; @@ -85,23 +100,23 @@ void lcd_ctrl_init(void *lcdbase)
if (value < 1) { /* Using system clock as pixel clock */ - lcdc_writel(®s->lcdc_lcdcfg0, - LCDC_LCDCFG0_CLKDIV(0) - | LCDC_LCDCFG0_CGDISHCR - | LCDC_LCDCFG0_CGDISHEO - | LCDC_LCDCFG0_CGDISOVR1 - | LCDC_LCDCFG0_CGDISBASE - | panel_info.vl_clk_pol - | LCDC_LCDCFG0_CLKSEL); + writel(LCDC_LCDCFG0_CLKDIV(0) + | LCDC_LCDCFG0_CGDISHCR + | LCDC_LCDCFG0_CGDISHEO + | LCDC_LCDCFG0_CGDISOVR1 + | LCDC_LCDCFG0_CGDISBASE + | panel_info.vl_clk_pol + | LCDC_LCDCFG0_CLKSEL, + ®s->lcdc_lcdcfg0);
} else { - lcdc_writel(®s->lcdc_lcdcfg0, - LCDC_LCDCFG0_CLKDIV(value - 2) - | LCDC_LCDCFG0_CGDISHCR - | LCDC_LCDCFG0_CGDISHEO - | LCDC_LCDCFG0_CGDISOVR1 - | LCDC_LCDCFG0_CGDISBASE - | panel_info.vl_clk_pol); + writel(LCDC_LCDCFG0_CLKDIV(value - 2) + | LCDC_LCDCFG0_CGDISHCR + | LCDC_LCDCFG0_CGDISHEO + | LCDC_LCDCFG0_CGDISOVR1 + | LCDC_LCDCFG0_CGDISBASE + | panel_info.vl_clk_pol, + ®s->lcdc_lcdcfg0); }
/* Initialize control register 5 */ @@ -134,50 +149,50 @@ void lcd_ctrl_init(void *lcdbase)
value |= LCDC_LCDCFG5_GUARDTIME(ATMEL_LCDC_GUARD_TIME); value |= (LCDC_LCDCFG5_DISPDLY | LCDC_LCDCFG5_VSPDLYS); - lcdc_writel(®s->lcdc_lcdcfg5, value); + writel(value, ®s->lcdc_lcdcfg5);
/* Vertical & Horizontal Timing */ value = LCDC_LCDCFG1_VSPW(panel_info.vl_vsync_len - 1); value |= LCDC_LCDCFG1_HSPW(panel_info.vl_hsync_len - 1); - lcdc_writel(®s->lcdc_lcdcfg1, value); + writel(value, ®s->lcdc_lcdcfg1);
value = LCDC_LCDCFG2_VBPW(panel_info.vl_upper_margin); value |= LCDC_LCDCFG2_VFPW(panel_info.vl_lower_margin - 1); - lcdc_writel(®s->lcdc_lcdcfg2, value); + writel(value, ®s->lcdc_lcdcfg2);
value = LCDC_LCDCFG3_HBPW(panel_info.vl_left_margin - 1); value |= LCDC_LCDCFG3_HFPW(panel_info.vl_right_margin - 1); - lcdc_writel(®s->lcdc_lcdcfg3, value); + writel(value, ®s->lcdc_lcdcfg3);
/* Display size */ value = LCDC_LCDCFG4_RPF(panel_info.vl_row - 1); value |= LCDC_LCDCFG4_PPL(panel_info.vl_col - 1); - lcdc_writel(®s->lcdc_lcdcfg4, value); + writel(value, ®s->lcdc_lcdcfg4);
- lcdc_writel(®s->lcdc_basecfg0, - LCDC_BASECFG0_BLEN_AHB_INCR4 | LCDC_BASECFG0_DLBO); + writel(LCDC_BASECFG0_BLEN_AHB_INCR4 | LCDC_BASECFG0_DLBO, + ®s->lcdc_basecfg0);
switch (NBITS(panel_info.vl_bpix)) { case 16: - lcdc_writel(®s->lcdc_basecfg1, - LCDC_BASECFG1_RGBMODE_16BPP_RGB_565); + writel(LCDC_BASECFG1_RGBMODE_16BPP_RGB_565, + ®s->lcdc_basecfg1); break; case 32: - lcdc_writel(®s->lcdc_basecfg1, - LCDC_BASECFG1_RGBMODE_24BPP_RGB_888); + writel(LCDC_BASECFG1_RGBMODE_24BPP_RGB_888, + ®s->lcdc_basecfg1); break; default: BUG(); break; }
- lcdc_writel(®s->lcdc_basecfg2, LCDC_BASECFG2_XSTRIDE(0)); - lcdc_writel(®s->lcdc_basecfg3, 0); - lcdc_writel(®s->lcdc_basecfg4, LCDC_BASECFG4_DMA); + writel(LCDC_BASECFG2_XSTRIDE(0), ®s->lcdc_basecfg2); + writel(0, ®s->lcdc_basecfg3); + writel(LCDC_BASECFG4_DMA, ®s->lcdc_basecfg4);
/* Disable all interrupts */ - lcdc_writel(®s->lcdc_lcdidr, ~0UL); - lcdc_writel(®s->lcdc_baseidr, ~0UL); + writel(~0UL, ®s->lcdc_lcdidr); + writel(~0UL, ®s->lcdc_baseidr);
/* Setup the DMA descriptor, this descriptor will loop to itself */ desc = (struct lcd_dma_desc *)(lcdbase - 16); @@ -191,30 +206,354 @@ void lcd_ctrl_init(void *lcdbase) /* Flush the DMA descriptor if we enabled dcache */ flush_dcache_range((u32)desc, (u32)desc + sizeof(*desc));
- lcdc_writel(®s->lcdc_baseaddr, desc->address); - lcdc_writel(®s->lcdc_basectrl, desc->control); - lcdc_writel(®s->lcdc_basenext, desc->next); - lcdc_writel(®s->lcdc_basecher, LCDC_BASECHER_CHEN | - LCDC_BASECHER_UPDATEEN); + writel(desc->address, ®s->lcdc_baseaddr); + writel(desc->control, ®s->lcdc_basectrl); + writel(desc->next, ®s->lcdc_basenext); + writel(LCDC_BASECHER_CHEN | LCDC_BASECHER_UPDATEEN, + ®s->lcdc_basecher);
/* Enable LCD */ - value = lcdc_readl(®s->lcdc_lcden); - lcdc_writel(®s->lcdc_lcden, value | LCDC_LCDEN_CLKEN); - while (!(lcdc_readl(®s->lcdc_lcdsr) & LCDC_LCDSR_CLKSTS)) - udelay(1); - value = lcdc_readl(®s->lcdc_lcden); - lcdc_writel(®s->lcdc_lcden, value | LCDC_LCDEN_SYNCEN); - while (!(lcdc_readl(®s->lcdc_lcdsr) & LCDC_LCDSR_LCDSTS)) - udelay(1); - value = lcdc_readl(®s->lcdc_lcden); - lcdc_writel(®s->lcdc_lcden, value | LCDC_LCDEN_DISPEN); - while (!(lcdc_readl(®s->lcdc_lcdsr) & LCDC_LCDSR_DISPSTS)) - udelay(1); - value = lcdc_readl(®s->lcdc_lcden); - lcdc_writel(®s->lcdc_lcden, value | LCDC_LCDEN_PWMEN); - while (!(lcdc_readl(®s->lcdc_lcdsr) & LCDC_LCDSR_PWMSTS)) - udelay(1); + value = readl(®s->lcdc_lcden); + writel(value | LCDC_LCDEN_CLKEN, ®s->lcdc_lcden); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_CLKSTS, + true, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); + value = readl(®s->lcdc_lcden); + writel(value | LCDC_LCDEN_SYNCEN, ®s->lcdc_lcden); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_LCDSTS, + true, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); + value = readl(®s->lcdc_lcden); + writel(value | LCDC_LCDEN_DISPEN, ®s->lcdc_lcden); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_DISPSTS, + true, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); + value = readl(®s->lcdc_lcden); + writel(value | LCDC_LCDEN_PWMEN, ®s->lcdc_lcden); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_PWMSTS, + true, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__);
/* Enable flushing if we enabled dcache */ lcd_set_flush_dcache(1); } + +#else + +enum { + LCD_MAX_WIDTH = 1024, + LCD_MAX_HEIGHT = 768, + LCD_MAX_LOG2_BPP = VIDEO_BPP16, +}; + +struct atmel_hlcdc_priv { + struct atmel_hlcd_regs *regs; + struct display_timing timing; + unsigned int vl_bpix; + unsigned int output_mode; + unsigned int guard_time; + ulong clk_rate; +}; + +static int at91_hlcdc_enable_clk(struct udevice *dev) +{ + struct atmel_hlcdc_priv *priv = dev_get_priv(dev); + struct clk clk; + ulong clk_rate; + int ret; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return -EINVAL; + + ret = clk_enable(&clk); + if (ret) + return ret; + + clk_rate = clk_get_rate(&clk); + if (!clk_rate) { + clk_disable(&clk); + return -ENODEV; + } + + priv->clk_rate = clk_rate; + + clk_free(&clk); + + return 0; +} + +static void atmel_hlcdc_init(struct udevice *dev) +{ + struct video_uc_platdata *uc_plat = dev_get_uclass_platdata(dev); + struct atmel_hlcdc_priv *priv = dev_get_priv(dev); + struct atmel_hlcd_regs *regs = priv->regs; + struct display_timing *timing = &priv->timing; + struct lcd_dma_desc *desc; + unsigned long value, vl_clk_pol; + int ret; + + /* Disable DISP signal */ + writel(LCDC_LCDDIS_DISPDIS, ®s->lcdc_lcddis); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_DISPSTS, + false, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); + /* Disable synchronization */ + writel(LCDC_LCDDIS_SYNCDIS, ®s->lcdc_lcddis); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_LCDSTS, + false, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); + /* Disable pixel clock */ + writel(LCDC_LCDDIS_CLKDIS, ®s->lcdc_lcddis); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_CLKSTS, + false, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); + /* Disable PWM */ + writel(LCDC_LCDDIS_PWMDIS, ®s->lcdc_lcddis); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_PWMSTS, + false, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); + + /* Set pixel clock */ + value = priv->clk_rate / timing->pixelclock.typ; + if (priv->clk_rate % timing->pixelclock.typ) + value++; + + vl_clk_pol = 0; + if (timing->flags & DISPLAY_FLAGS_PIXDATA_NEGEDGE) + vl_clk_pol = LCDC_LCDCFG0_CLKPOL; + + if (value < 1) { + /* Using system clock as pixel clock */ + writel(LCDC_LCDCFG0_CLKDIV(0) + | LCDC_LCDCFG0_CGDISHCR + | LCDC_LCDCFG0_CGDISHEO + | LCDC_LCDCFG0_CGDISOVR1 + | LCDC_LCDCFG0_CGDISBASE + | vl_clk_pol + | LCDC_LCDCFG0_CLKSEL, + ®s->lcdc_lcdcfg0); + + } else { + writel(LCDC_LCDCFG0_CLKDIV(value - 2) + | LCDC_LCDCFG0_CGDISHCR + | LCDC_LCDCFG0_CGDISHEO + | LCDC_LCDCFG0_CGDISOVR1 + | LCDC_LCDCFG0_CGDISBASE + | vl_clk_pol, + ®s->lcdc_lcdcfg0); + } + + /* Initialize control register 5 */ + value = 0; + + if (!(timing->flags & DISPLAY_FLAGS_HSYNC_HIGH)) + value |= LCDC_LCDCFG5_HSPOL; + if (!(timing->flags & DISPLAY_FLAGS_VSYNC_HIGH)) + value |= LCDC_LCDCFG5_VSPOL; + + switch (priv->output_mode) { + case 12: + value |= LCDC_LCDCFG5_MODE_OUTPUT_12BPP; + break; + case 16: + value |= LCDC_LCDCFG5_MODE_OUTPUT_16BPP; + break; + case 18: + value |= LCDC_LCDCFG5_MODE_OUTPUT_18BPP; + break; + case 24: + value |= LCDC_LCDCFG5_MODE_OUTPUT_24BPP; + break; + default: + BUG(); + break; + } + + value |= LCDC_LCDCFG5_GUARDTIME(priv->guard_time); + value |= (LCDC_LCDCFG5_DISPDLY | LCDC_LCDCFG5_VSPDLYS); + writel(value, ®s->lcdc_lcdcfg5); + + /* Vertical & Horizontal Timing */ + value = LCDC_LCDCFG1_VSPW(timing->vsync_len.typ - 1); + value |= LCDC_LCDCFG1_HSPW(timing->hsync_len.typ - 1); + writel(value, ®s->lcdc_lcdcfg1); + + value = LCDC_LCDCFG2_VBPW(timing->vback_porch.typ); + value |= LCDC_LCDCFG2_VFPW(timing->vfront_porch.typ - 1); + writel(value, ®s->lcdc_lcdcfg2); + + value = LCDC_LCDCFG3_HBPW(timing->hback_porch.typ - 1); + value |= LCDC_LCDCFG3_HFPW(timing->hfront_porch.typ - 1); + writel(value, ®s->lcdc_lcdcfg3); + + /* Display size */ + value = LCDC_LCDCFG4_RPF(timing->vactive.typ - 1); + value |= LCDC_LCDCFG4_PPL(timing->hactive.typ - 1); + writel(value, ®s->lcdc_lcdcfg4); + + writel(LCDC_BASECFG0_BLEN_AHB_INCR4 | LCDC_BASECFG0_DLBO, + ®s->lcdc_basecfg0); + + switch (VNBITS(priv->vl_bpix)) { + case 16: + writel(LCDC_BASECFG1_RGBMODE_16BPP_RGB_565, + ®s->lcdc_basecfg1); + break; + case 32: + writel(LCDC_BASECFG1_RGBMODE_24BPP_RGB_888, + ®s->lcdc_basecfg1); + break; + default: + BUG(); + break; + } + + writel(LCDC_BASECFG2_XSTRIDE(0), ®s->lcdc_basecfg2); + writel(0, ®s->lcdc_basecfg3); + writel(LCDC_BASECFG4_DMA, ®s->lcdc_basecfg4); + + /* Disable all interrupts */ + writel(~0UL, ®s->lcdc_lcdidr); + writel(~0UL, ®s->lcdc_baseidr); + + /* Setup the DMA descriptor, this descriptor will loop to itself */ + desc = (struct lcd_dma_desc *)(uc_plat->base - 16); + + desc->address = (u32)uc_plat->base; + + /* Disable DMA transfer interrupt & descriptor loaded interrupt. */ + desc->control = LCDC_BASECTRL_ADDIEN | LCDC_BASECTRL_DSCRIEN + | LCDC_BASECTRL_DMAIEN | LCDC_BASECTRL_DFETCH; + desc->next = (u32)desc; + + /* Flush the DMA descriptor if we enabled dcache */ + flush_dcache_range((u32)desc, (u32)desc + sizeof(*desc)); + + writel(desc->address, ®s->lcdc_baseaddr); + writel(desc->control, ®s->lcdc_basectrl); + writel(desc->next, ®s->lcdc_basenext); + writel(LCDC_BASECHER_CHEN | LCDC_BASECHER_UPDATEEN, + ®s->lcdc_basecher); + + /* Enable LCD */ + value = readl(®s->lcdc_lcden); + writel(value | LCDC_LCDEN_CLKEN, ®s->lcdc_lcden); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_CLKSTS, + true, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); + value = readl(®s->lcdc_lcden); + writel(value | LCDC_LCDEN_SYNCEN, ®s->lcdc_lcden); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_LCDSTS, + true, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); + value = readl(®s->lcdc_lcden); + writel(value | LCDC_LCDEN_DISPEN, ®s->lcdc_lcden); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_DISPSTS, + true, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); + value = readl(®s->lcdc_lcden); + writel(value | LCDC_LCDEN_PWMEN, ®s->lcdc_lcden); + ret = wait_for_bit(__func__, ®s->lcdc_lcdsr, LCDC_LCDSR_PWMSTS, + true, 1000, false); + if (ret) + printf("%s: %d: Timeout!\n", __func__, __LINE__); +} + +static int atmel_hlcdc_probe(struct udevice *dev) +{ + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + struct atmel_hlcdc_priv *priv = dev_get_priv(dev); + int ret; + + ret = at91_hlcdc_enable_clk(dev); + if (ret) + return ret; + + atmel_hlcdc_init(dev); + + uc_priv->xsize = priv->timing.hactive.typ; + uc_priv->ysize = priv->timing.vactive.typ; + uc_priv->bpix = priv->vl_bpix; + + /* Enable flushing if we enabled dcache */ + video_set_flush_dcache(dev, true); + + return 0; +} + +static int atmel_hlcdc_ofdata_to_platdata(struct udevice *dev) +{ + struct atmel_hlcdc_priv *priv = dev_get_priv(dev); + const void *blob = gd->fdt_blob; + int node = dev->of_offset; + + priv->regs = (struct atmel_hlcd_regs *)dev_get_addr(dev); + if (!priv->regs) { + debug("%s: No display controller address\n", __func__); + return -EINVAL; + } + + if (fdtdec_decode_display_timing(blob, dev->of_offset, + 0, &priv->timing)) { + debug("%s: Failed to decode display timing\n", __func__); + return -EINVAL; + } + + if (priv->timing.hactive.typ > LCD_MAX_WIDTH) + priv->timing.hactive.typ = LCD_MAX_WIDTH; + + if (priv->timing.vactive.typ > LCD_MAX_HEIGHT) + priv->timing.vactive.typ = LCD_MAX_HEIGHT; + + priv->vl_bpix = fdtdec_get_int(blob, node, "atmel,vl-bpix", 0); + if (!priv->vl_bpix) { + debug("%s: Failed to get bits per pixel\n", __func__); + return -EINVAL; + } + + priv->output_mode = fdtdec_get_int(blob, node, "atmel,output-mode", 24); + priv->guard_time = fdtdec_get_int(blob, node, "atmel,guard-time", 1); + + return 0; +} + +static int atmel_hlcdc_bind(struct udevice *dev) +{ + struct video_uc_platdata *uc_plat = dev_get_uclass_platdata(dev); + + uc_plat->size = LCD_MAX_WIDTH * LCD_MAX_HEIGHT * + (1 << LCD_MAX_LOG2_BPP) / 8; + + debug("%s: Frame buffer size %x\n", __func__, uc_plat->size); + + return 0; +} + +static const struct udevice_id atmel_hlcdc_ids[] = { + { .compatible = "atmel,sama5d2-hlcdc" }, + { } +}; + +U_BOOT_DRIVER(atmel_hlcdfb) = { + .name = "atmel_hlcdfb", + .id = UCLASS_VIDEO, + .of_match = atmel_hlcdc_ids, + .bind = atmel_hlcdc_bind, + .probe = atmel_hlcdc_probe, + .ofdata_to_platdata = atmel_hlcdc_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct atmel_hlcdc_priv), +}; + +#endif
DT binding documentation for atmel HLCDC driver.
Changes in v3: - Add 'atmel,output-mode' entry in dts.
Changes in v2: None
doc/device-tree-bindings/video/atme-hlcdc.txt | 42 +++++++++++++++++++++++++++ 1 file changed, 42 insertions(+) create mode 100644 doc/device-tree-bindings/video/atme-hlcdc.txt
diff --git a/doc/device-tree-bindings/video/atme-hlcdc.txt b/doc/device-tree-bindings/video/atme-hlcdc.txt new file mode 100644 index 0000000000..8a126943c0 --- /dev/null +++ b/doc/device-tree-bindings/video/atme-hlcdc.txt @@ -0,0 +1,42 @@ +Atmel HLCDC Framebuffer +----------------------------------------------------- +Required properties: +- compatible : + "atmel,sama5d2-hlcdc". +- reg: physical base address of the controller and length of memory mapped + region. +- clocks: phandles to input clocks. +- atmel,vl-bpix: Bits per pixel. +- atmel,output-mode: LCD Controller Output Mode, + The unit is bits per pixel, there are four values, + <12>, <16>, <18>, <24>, the default value is <24>. +- atmel,guard-time: lcd guard time (Delay in frame periods). +- display-timings: please refer the displaymode.txt. + +Example: +hlcdc: hlcdc@f0000000 { + u-boot,dm-pre-reloc; + compatible = "atmel,sama5d2-hlcdc"; + reg = <0xf0000000 0x2000>; + clocks = <&lcdc_clk>; + atmel,vl-bpix = <4>; + atmel,output-mode = <24>; + atmel,guard-time = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcd_base &pinctrl_lcd_pwm &pinctrl_lcd_rgb666>; + status = "okay"; + + display-timings { + 480x272 { + clock-frequency = <9000000>; + hactive = <480>; + vactive = <272>; + hsync-len = <41>; + hfront-porch = <2>; + hback-porch = <2>; + vfront-porch = <2>; + vback-porch = <2>; + vsync-len = <11>; + }; + }; +}; \ No newline at end of file
Songjun Wu
