[U-Boot] [PATCH 0/4] This series implements fastboot on the "bcm28155_ap" boards.
The OTG hardware is a DWC2 controller and this series uses the existing gadget driver ("s3c_udc_otg.c").
JD (Jiandong) Zheng and Steve Rae (2): usb: gadget: bcm_udc_otg files implement Fastboot via USB OTG on bcm28155_ap boards
Steve Rae (2): g_dnl: add missing declaration usb: s3c-otg: support 8-bit interface
arch/arm/include/asm/arch-bcm281xx/sysmap.h | 7 ++++ board/broadcom/bcm28155_ap/bcm28155_ap.c | 40 +++++++++++++++++++++++ drivers/usb/gadget/Makefile | 1 + drivers/usb/gadget/bcm_udc_otg.h | 17 ++++++++++ drivers/usb/gadget/bcm_udc_otg_phy.c | 50 +++++++++++++++++++++++++++++ drivers/usb/gadget/s3c_udc_otg.c | 4 +++ include/configs/bcm28155_ap.h | 20 ++++++++++++ include/g_dnl.h | 1 + 8 files changed, 140 insertions(+) create mode 100644 drivers/usb/gadget/bcm_udc_otg.h create mode 100644 drivers/usb/gadget/bcm_udc_otg_phy.c
Signed-off-by: Steve Rae srae@broadcom.com ---
include/g_dnl.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/g_dnl.h b/include/g_dnl.h index 4eeb5e4..ba49f1f 100644 --- a/include/g_dnl.h +++ b/include/g_dnl.h @@ -34,6 +34,7 @@ struct g_dnl_bind_callback { };
int g_dnl_bind_fixup(struct usb_device_descriptor *, const char *); +int g_dnl_get_board_bcd_device_number(int gcnum); int g_dnl_board_usb_cable_connected(void); int g_dnl_register(const char *s); void g_dnl_unregister(void);
drivers/usb/gadget/s3c_udc_otg.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/usb/gadget/s3c_udc_otg.c b/drivers/usb/gadget/s3c_udc_otg.c index 7a2d1e7..2e3b4f7 100644 --- a/drivers/usb/gadget/s3c_udc_otg.c +++ b/drivers/usb/gadget/s3c_udc_otg.c @@ -414,7 +414,11 @@ static void reconfig_usbd(struct s3c_udc *dev) |0<<7 /* Ulpi DDR sel*/ |0<<6 /* 0: high speed utmi+, 1: full speed serial*/ |0<<4 /* 0: utmi+, 1:ulpi*/ +#ifdef CONFIG_USB_GADGET_PHY_8_BIT + |0<<3 /* phy i/f 0:8bit, 1:16bit*/ +#else |1<<3 /* phy i/f 0:8bit, 1:16bit*/ +#endif |0x7<<0; /* HS/FS Timeout**/
if (dev->pdata->usb_gusbcfg)
Add the required files for the Broadcom UDC OTG interface.
arch/arm/include/asm/arch-bcm281xx/sysmap.h | 7 ++++ drivers/usb/gadget/bcm_udc_otg.h | 17 ++++++++++ drivers/usb/gadget/bcm_udc_otg_phy.c | 50 +++++++++++++++++++++++++++++ 3 files changed, 74 insertions(+) create mode 100644 drivers/usb/gadget/bcm_udc_otg.h create mode 100644 drivers/usb/gadget/bcm_udc_otg_phy.c
diff --git a/arch/arm/include/asm/arch-bcm281xx/sysmap.h b/arch/arm/include/asm/arch-bcm281xx/sysmap.h index 93ebf34..dbcc88c 100644 --- a/arch/arm/include/asm/arch-bcm281xx/sysmap.h +++ b/arch/arm/include/asm/arch-bcm281xx/sysmap.h @@ -27,4 +27,11 @@ #define SECWD2_BASE_ADDR 0x35002f40 #define TIMER_BASE_ADDR 0x3e00d000
+#define HSOTG_DCTL_OFFSET 0x00000804 +#define HSOTG_DCTL_SFTDISCON_MASK 0x00000002 + +#define HSOTG_CTRL_PHY_P1CTL_OFFSET 0x00000008 +#define HSOTG_CTRL_PHY_P1CTL_SOFT_RESET_MASK 0x00000002 +#define HSOTG_CTRL_PHY_P1CTL_NON_DRIVING_MASK 0x00000001 + #endif diff --git a/drivers/usb/gadget/bcm_udc_otg.h b/drivers/usb/gadget/bcm_udc_otg.h new file mode 100644 index 0000000..81a1fc0 --- /dev/null +++ b/drivers/usb/gadget/bcm_udc_otg.h @@ -0,0 +1,17 @@ +/* + * Copyright 2015 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __BCM_UDC_OTG_H +#define __BCM_UDC_OTG_H + +#include <linux/types.h> + +#define wfld_set(addr, fld_val, fld_mask) \ + (writel(((readl(addr) & ~(fld_mask)) | (fld_val)), (addr))) +#define wfld_clear(addr, fld_mask) \ + (writel((readl(addr) & ~(fld_mask)), (addr))) + +#endif diff --git a/drivers/usb/gadget/bcm_udc_otg_phy.c b/drivers/usb/gadget/bcm_udc_otg_phy.c new file mode 100644 index 0000000..1aa9f91 --- /dev/null +++ b/drivers/usb/gadget/bcm_udc_otg_phy.c @@ -0,0 +1,50 @@ +/* + * Copyright 2015 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sysmap.h> + +#include <usb/s3c_udc.h> +#include "bcm_udc_otg.h" + +void otg_phy_init(struct s3c_udc *dev) +{ + /* set Phy to driving mode */ + wfld_clear(HSOTG_CTRL_BASE_ADDR + HSOTG_CTRL_PHY_P1CTL_OFFSET, + HSOTG_CTRL_PHY_P1CTL_NON_DRIVING_MASK); + + udelay(100); + + /* clear Soft Disconnect */ + wfld_clear(HSOTG_BASE_ADDR + HSOTG_DCTL_OFFSET, + HSOTG_DCTL_SFTDISCON_MASK); + + /* invoke Reset (active low) */ + wfld_clear(HSOTG_CTRL_BASE_ADDR + HSOTG_CTRL_PHY_P1CTL_OFFSET, + HSOTG_CTRL_PHY_P1CTL_SOFT_RESET_MASK); + + udelay(10000); + + /* release Reset */ + wfld_set(HSOTG_CTRL_BASE_ADDR + HSOTG_CTRL_PHY_P1CTL_OFFSET, + HSOTG_CTRL_PHY_P1CTL_SOFT_RESET_MASK, + HSOTG_CTRL_PHY_P1CTL_SOFT_RESET_MASK); +} + +void otg_phy_off(struct s3c_udc *dev) +{ + /* Soft Disconnect */ + wfld_set(HSOTG_BASE_ADDR + HSOTG_DCTL_OFFSET, + HSOTG_DCTL_SFTDISCON_MASK, + HSOTG_DCTL_SFTDISCON_MASK); + + /* set Phy to non-driving (reset) mode */ + wfld_set(HSOTG_CTRL_BASE_ADDR + HSOTG_CTRL_PHY_P1CTL_OFFSET, + HSOTG_CTRL_PHY_P1CTL_NON_DRIVING_MASK, + HSOTG_CTRL_PHY_P1CTL_NON_DRIVING_MASK); +}
board/broadcom/bcm28155_ap/bcm28155_ap.c | 40 ++++++++++++++++++++++++++++++++ drivers/usb/gadget/Makefile | 1 + include/configs/bcm28155_ap.h | 20 ++++++++++++++++ 3 files changed, 61 insertions(+)
diff --git a/board/broadcom/bcm28155_ap/bcm28155_ap.c b/board/broadcom/bcm28155_ap/bcm28155_ap.c index 940a1c2..20eb191 100644 --- a/board/broadcom/bcm28155_ap/bcm28155_ap.c +++ b/board/broadcom/bcm28155_ap/bcm28155_ap.c @@ -12,12 +12,20 @@ #include <asm/kona-common/clk.h> #include <asm/arch/sysmap.h>
+#include <usb.h> +#include <usb/s3c_udc.h> +#include <g_dnl.h> + #define SECWATCHDOG_SDOGCR_OFFSET 0x00000000 #define SECWATCHDOG_SDOGCR_EN_SHIFT 27 #define SECWATCHDOG_SDOGCR_SRSTEN_SHIFT 26 #define SECWATCHDOG_SDOGCR_CLKS_SHIFT 20 #define SECWATCHDOG_SDOGCR_LD_SHIFT 0
+#ifndef CONFIG_USB_SERIALNO +#define CONFIG_USB_SERIALNO "1234567890" +#endif + DECLARE_GLOBAL_DATA_PTR;
/* @@ -85,3 +93,35 @@ int board_mmc_init(bd_t *bis) return ret; } #endif + +#ifdef CONFIG_USB_GADGET +static struct s3c_plat_otg_data bcm_otg_data = { + .regs_otg = HSOTG_BASE_ADDR +}; + +int board_usb_init(int index, enum usb_init_type init) +{ + debug("%s: performing s3c_udc_probe\n", __func__); + return s3c_udc_probe(&bcm_otg_data); +} + +int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) +{ + debug("%s\n", __func__); + if (!getenv("serial#")) + g_dnl_set_serialnumber(CONFIG_USB_SERIALNO); + return 0; +} + +int g_dnl_get_board_bcd_device_number(int gcnum) +{ + debug("%s\n", __func__); + return 1; +} + +int board_usb_cleanup(int index, enum usb_init_type init) +{ + debug("%s\n", __func__); + return 0; +} +#endif diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 70bb550..d370f1c 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -20,6 +20,7 @@ obj-$(CONFIG_USBDOWNLOAD_GADGET) += g_dnl.o obj-$(CONFIG_DFU_FUNCTION) += f_dfu.o obj-$(CONFIG_USB_GADGET_MASS_STORAGE) += f_mass_storage.o obj-$(CONFIG_CMD_FASTBOOT) += f_fastboot.o +obj-$(CONFIG_USB_GADGET_BCM_UDC_OTG_PHY) += bcm_udc_otg_phy.o endif ifdef CONFIG_USB_ETHER obj-y += ether.o diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index 900dc42..e5fdc90 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -109,6 +109,7 @@ * for example. */ #define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION
/* version string, parser, etc */ #define CONFIG_VERSION_VARIABLE @@ -136,4 +137,23 @@
#undef CONFIG_CMD_NFS
+/* Fastboot and USB OTG */ +#define CONFIG_CMD_FASTBOOT +#define CONFIG_FASTBOOT_FLASH +#define CONFIG_FASTBOOT_FLASH_MMC_DEV 0 +#define CONFIG_SYS_CACHELINE_SIZE 64 +#define CONFIG_USB_FASTBOOT_BUF_SIZE (CONFIG_SYS_SDRAM_SIZE - (1024 * 1024)) +#define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_SDRAM_BASE +#define CONFIG_USB_GADGET +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_GADGET_VBUS_DRAW 0 +#define CONFIG_USB_GADGET_S3C_UDC_OTG +#define CONFIG_USB_GADGET_BCM_UDC_OTG_PHY +#define CONFIG_USB_GADGET_PHY_8_BIT +#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USBID_ADDR 0x34052c46 +#define CONFIG_G_DNL_VENDOR_NUM 0x18d1 /* google */ +#define CONFIG_G_DNL_PRODUCT_NUM 0x0d02 /* nexus one */ +#define CONFIG_G_DNL_MANUFACTURER "Broadcom Corporation" + #endif /* __BCM28155_AP_H */
- .regs_otg = HSOTG_BASE_ADDR
- debug("%s: performing s3c_udc_probe\n", __func__);
- return s3c_udc_probe(&bcm_otg_data);
- debug("%s\n", __func__);
- if (!getenv("serial#"))
- return 1;
- for example.
You should probably rebase this against u-boot-dfu's latest HEAD, and adapt for the renames I made (for consistency)!
- #define SECWATCHDOG_SDOGCR_OFFSET 0x00000000 #define SECWATCHDOG_SDOGCR_EN_SHIFT 27 #define SECWATCHDOG_SDOGCR_SRSTEN_SHIFT 26 #define SECWATCHDOG_SDOGCR_CLKS_SHIFT 20 #define SECWATCHDOG_SDOGCR_LD_SHIFT 0
- return 1;
- for example.
OK -- see v2
- #endif /* __BCM28155_AP_H */
Paul Kocialkowski
Steve Rae
