[U-Boot] [PATCH 3/4] cfi_flash: Simplify dynamic flash bank number detection
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By moving these optional variables and defines into the common code, board specific code is minimized. Currently only the following board use this feature:
APC405, IDS8247, TQM834x
And IDS8247 doesn't seem to really need this feature, since its not updating the bank number variable at all. So this patch removes the definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port.
This new framework will be used by the upcoming lwmon5 update as well.
Signed-off-by: Stefan Roese sr@denx.de Cc: Matthias Fuchs matthias.fuchs@esd.eu Cc: Heiko Schocher hs@denx.de --- board/esd/apc405/apc405.c | 6 ++---- board/tqc/tqm834x/tqm834x.c | 12 +++++------- common/cmd_bootm.c | 1 + common/flash.c | 1 + drivers/mtd/cfi_flash.c | 15 ++++----------- include/configs/APC405.h | 6 ------ include/configs/IDS8247.h | 3 +-- include/configs/TQM834x.h | 4 ---- include/flash.h | 2 ++ include/mtd/cfi_flash.h | 18 ++++++++++++++++++ 10 files changed, 34 insertions(+), 34 deletions(-)
diff --git a/board/esd/apc405/apc405.c b/board/esd/apc405/apc405.c index 564ee00..52477d7 100644 --- a/board/esd/apc405/apc405.c +++ b/board/esd/apc405/apc405.c @@ -30,6 +30,7 @@ #include <command.h> #include <malloc.h> #include <flash.h> +#include <mtd/cfi_flash.h> #include <asm/4xx_pci.h> #include <pci.h>
@@ -39,9 +40,6 @@ DECLARE_GLOBAL_DATA_PTR;
extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); extern void lxt971_no_sleep(void); -extern ulong flash_get_size (ulong base, int banknum); - -int flash_banks = CONFIG_SYS_MAX_FLASH_BANKS_DETECT;
/* fpga configuration data - gzip compressed and generated by bin2c */ const unsigned char fpgadata[] = @@ -185,7 +183,7 @@ int board_early_init_f (void) int board_early_init_r(void) { if (gd->board_type >= 8) - flash_banks = 1; + cfi_flash_num_flash_banks = 1;
return 0; } diff --git a/board/tqc/tqm834x/tqm834x.c b/board/tqc/tqm834x/tqm834x.c index 8d046f4..2aa97f2 100644 --- a/board/tqc/tqm834x/tqm834x.c +++ b/board/tqc/tqm834x/tqm834x.c @@ -30,6 +30,8 @@ #include <miiphy.h> #include <asm/mmu.h> #include <pci.h> +#include <flash.h> +#include <mtd/cfi_flash.h>
@@ -52,12 +54,8 @@ DECLARE_GLOBAL_DATA_PTR; #define INITIAL_CS_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_12 | \ CSCONFIG_COL_BIT_9)
-/* Global variable used to store detected number of banks */ -int tqm834x_num_flash_banks; - /* External definitions */ ulong flash_get_size (ulong base, int banknum); -extern flash_info_t flash_info[];
/* Local functions */ static int detect_num_flash_banks(void); @@ -190,7 +188,7 @@ static int detect_num_flash_banks(void) ulong bank2_size; ulong total_size;
- tqm834x_num_flash_banks = 2; /* assume two banks */ + cfi_flash_num_flash_banks = 2; /* assume two banks */
/* Get bank 1 and 2 information */ bank1_size = flash_get_size(CONFIG_SYS_FLASH_BASE, 0); @@ -244,13 +242,13 @@ static int detect_num_flash_banks(void) * we got the some data reading from Flash. * There is only one mirrored bank. */ - tqm834x_num_flash_banks = 1; + cfi_flash_num_flash_banks = 1; total_size = bank1_size; } } }
- debug("Number of flash banks detected: %d\n", tqm834x_num_flash_banks); + debug("Number of flash banks detected: %d\n", cfi_flash_num_flash_banks);
/* set OR0 and BR0 */ set_lbc_or(0, CONFIG_SYS_OR_TIMING_FLASH | diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 4c6ed48..46efd77 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -77,6 +77,7 @@ static int image_info (unsigned long addr);
#if defined(CONFIG_CMD_IMLS) #include <flash.h> +#include <mtd/cfi_flash.h> extern flash_info_t flash_info[]; /* info for FLASH chips */ static int do_imls (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); #endif diff --git a/common/flash.c b/common/flash.c index 683978e..781cb9c 100644 --- a/common/flash.c +++ b/common/flash.c @@ -27,6 +27,7 @@ #include <flash.h>
#if !defined(CONFIG_SYS_NO_FLASH) +#include <mtd/cfi_flash.h>
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index f10e09e..314393f 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -62,20 +62,9 @@ * reading and writing ... (yes there is such a Hardware). */
-#ifndef CONFIG_SYS_FLASH_BANKS_LIST -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } -#endif - static uint flash_offset_cfi[2] = { FLASH_OFFSET_CFI, FLASH_OFFSET_CFI_ALT }; static uint flash_verbose = 1;
-/* use CONFIG_SYS_MAX_FLASH_BANKS_DETECT if defined */ -#ifdef CONFIG_SYS_MAX_FLASH_BANKS_DETECT -# define CFI_MAX_FLASH_BANKS CONFIG_SYS_MAX_FLASH_BANKS_DETECT -#else -# define CFI_MAX_FLASH_BANKS CONFIG_SYS_MAX_FLASH_BANKS -#endif - flash_info_t flash_info[CFI_MAX_FLASH_BANKS]; /* FLASH chips info */
/* @@ -85,6 +74,10 @@ flash_info_t flash_info[CFI_MAX_FLASH_BANKS]; /* FLASH chips info */ #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_8BIT #endif
+#if defined(CONFIG_SYS_MAX_FLASH_BANKS_DETECT) +int cfi_flash_num_flash_banks = CONFIG_SYS_MAX_FLASH_BANKS_DETECT; +#endif + static phys_addr_t __cfi_flash_bank_addr(int i) { return ((phys_addr_t [])CONFIG_SYS_FLASH_BANKS_LIST)[i]; diff --git a/include/configs/APC405.h b/include/configs/APC405.h index 20849bc..ffaf309 100644 --- a/include/configs/APC405.h +++ b/include/configs/APC405.h @@ -263,16 +263,10 @@ /* * FLASH organization */ -#ifndef __ASSEMBLY__ -extern int flash_banks; -#endif - #define CONFIG_SYS_FLASH_BASE 0xFE000000 #define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ #define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max num of sects on one chip */ -#define CONFIG_SYS_MAX_FLASH_BANKS flash_banks /* max num of flash banks */ - /* updated in board_early_init_r */ #define CONFIG_SYS_MAX_FLASH_BANKS_DETECT 2 #define CONFIG_SYS_FLASH_QUIET_TEST 1 #define CONFIG_SYS_FLASH_INCREMENT 0x01000000 diff --git a/include/configs/IDS8247.h b/include/configs/IDS8247.h index 71bb7b4..4e73941 100644 --- a/include/configs/IDS8247.h +++ b/include/configs/IDS8247.h @@ -227,7 +227,7 @@ #define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */ #define CONFIG_FLASH_CFI_DRIVER /* Use common CFI driver */ #define CONFIG_SYS_FLASH_BANKS_LIST { 0xFF800000 } -#define CONFIG_SYS_MAX_FLASH_BANKS_DETECT 1 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ /* What should the base address of the main FLASH be and how big is * it (in MBytes)? This must contain TEXT_BASE from board/ids8247/config.mk * The main FLASH is whichever is connected to *CS0. @@ -242,7 +242,6 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of memory banks */ #define CONFIG_SYS_MAX_FLASH_SECT 128 /* max num of sects on one chip */
#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index c1e0e64..9193b51 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -101,10 +101,6 @@ * defined as tqm834x_num_flash_banks. */ #define CONFIG_SYS_MAX_FLASH_BANKS_DETECT 2 -#ifndef __ASSEMBLY__ -extern int tqm834x_num_flash_banks; -#endif -#define CONFIG_SYS_MAX_FLASH_BANKS (tqm834x_num_flash_banks)
#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max sectors per device */
diff --git a/include/flash.h b/include/flash.h index 8feca1b..1b6821a 100644 --- a/include/flash.h +++ b/include/flash.h @@ -58,6 +58,8 @@ typedef struct { #endif } flash_info_t;
+extern flash_info_t flash_info[]; /* info for FLASH chips */ + typedef unsigned long flash_sect_t;
/* diff --git a/include/mtd/cfi_flash.h b/include/mtd/cfi_flash.h index 2aa6911..2ff00f2 100644 --- a/include/mtd/cfi_flash.h +++ b/include/mtd/cfi_flash.h @@ -151,6 +151,24 @@ struct cfi_pri_hdr { u8 minor_version; } __attribute__((packed));
+#ifndef CONFIG_SYS_FLASH_BANKS_LIST +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } +#endif + +/* + * CFI_MAX_FLASH_BANKS only used for flash_info struct declaration. + * + * Use CONFIG_SYS_MAX_FLASH_BANKS_DETECT if defined + */ +#if defined(CONFIG_SYS_MAX_FLASH_BANKS_DETECT) +#define CONFIG_SYS_MAX_FLASH_BANKS (cfi_flash_num_flash_banks) +#define CFI_MAX_FLASH_BANKS CONFIG_SYS_MAX_FLASH_BANKS_DETECT +/* board code can update this variable before CFI detection */ +extern int cfi_flash_num_flash_banks; +#else +#define CFI_MAX_FLASH_BANKS CONFIG_SYS_MAX_FLASH_BANKS +#endif + void flash_write_cmd(flash_info_t * info, flash_sect_t sect, uint offset, u32 cmd);
Hello Stefan,
Acked-by: Heiko Schocherhs@denx.de
bye, Heiko
Heiko Schocher
Stefan Roese
