[PATCH 00/14] Some more env fixes
Hello Tom, Simon and others,
here are some various fixes for env. More are to follow after this, the code is horrible and I want to implement something there.
Marek Behún (14): env: sf: Cosmetic fix in env_sf_init_addr() env: sf: Use ENV_VALID enum names instead of literals env: sf: Put ENV_INVALID into gd->env_valid on CRC failure env: nand: Put ENV_INVALID into gd->env_valid if default environment env: nvram: Let generic env_init() assign default environment env: nvram: Cosmetic fix in env_nvram_init() env: nowhere: Let generic env_init() assign default environment env: nowhere: Cosmetic fix env: flash: Let generic env_init() assign default environment env: flash: Cosmetic fix board: synquacer: developerbox: Don't set gd->env_addr to default_environment board: freescale: various boards: Let env subsystem set gd->env_addr env: Always use char for default_environment env: Use static_assert() to check if default_environment is too large
board/Marvell/mvebu_armada-37xx/board.c | 2 +- board/freescale/ls1012afrdm/ls1012afrdm.c | 4 ---- board/freescale/ls1012aqds/ls1012aqds.c | 4 ---- board/freescale/ls1012ardb/ls1012ardb.c | 4 ---- board/freescale/ls1028a/ls1028a.c | 4 ---- board/freescale/ls1088a/ls1088a.c | 4 ---- board/freescale/ls2080aqds/ls2080aqds.c | 3 --- board/freescale/ls2080ardb/ls2080ardb.c | 3 --- board/freescale/lx2160a/lx2160a.c | 3 --- board/socionext/developerbox/developerbox.c | 2 -- env/common.c | 11 +++-------- env/flash.c | 5 +---- env/nand.c | 3 +-- env/nowhere.c | 5 ++--- env/nvram.c | 7 +++---- env/sf.c | 7 +++---- include/env_default.h | 10 ++++++++-- include/env_internal.h | 4 ++-- 18 files changed, 24 insertions(+), 61 deletions(-)
In the if clause we use tabs and in the else clause spaces. Let's use spaces in the if clause too.
Signed-off-by: Marek Behún marek.behun@nic.cz --- env/sf.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/env/sf.c b/env/sf.c index e4b7ca9e04..4096e18387 100644 --- a/env/sf.c +++ b/env/sf.c @@ -338,8 +338,8 @@ static int env_sf_init_addr(void) env_t *env_ptr = (env_t *)env_sf_get_env_addr();
if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { - gd->env_addr = (ulong)&(env_ptr->data); - gd->env_valid = 1; + gd->env_addr = (ulong)&(env_ptr->data); + gd->env_valid = 1; } else { gd->env_addr = (ulong)&default_environment[0]; gd->env_valid = 1;
Applied to u-boot-dm, thanks!
The function env_sf_init_addr() assigns number literals (1) instead of ENV_VALID to gd->env_valid. Fix this.
diff --git a/env/sf.c b/env/sf.c index 4096e18387..c251d076d7 100644 --- a/env/sf.c +++ b/env/sf.c @@ -339,10 +339,10 @@ static int env_sf_init_addr(void)
if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { gd->env_addr = (ulong)&(env_ptr->data); - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else { gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = 1; + gd->env_valid = ENV_VALID; }
env_sf_init_addr() says the environment is valid even if it is assigning default environment due to CRC failure. Change this to ENV_INVALID and let the generic env_init() function, which calls this initializer, assign the default environment.
Signed-off-by: Marek Behún marek.behun@nic.cz --- env/sf.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/env/sf.c b/env/sf.c index c251d076d7..6a4bb756f0 100644 --- a/env/sf.c +++ b/env/sf.c @@ -341,8 +341,7 @@ static int env_sf_init_addr(void) gd->env_addr = (ulong)&(env_ptr->data); gd->env_valid = ENV_VALID; } else { - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = ENV_VALID; + gd->env_valid = ENV_INVALID; }
env_nand_init() says the environment is valid even if it is assigning default environment due to not being able to access nand pre-reloaction (determined by macro values). Change this to ENV_INVALID and let the generic env_init() function, which calls this initializer, assign the default environment.
Signed-off-by: Marek Behún marek.behun@nic.cz --- env/nand.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/env/nand.c b/env/nand.c index be82e97d69..21aa367d5b 100644 --- a/env/nand.c +++ b/env/nand.c @@ -107,8 +107,7 @@ static int env_nand_init(void) gd->env_addr = (ulong)env_ptr->data;
#else /* ENV_IS_EMBEDDED || CONFIG_NAND_ENV_DST */ - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = ENV_VALID; + gd->env_valid = ENV_INVALID; #endif /* ENV_IS_EMBEDDED || CONFIG_NAND_ENV_DST */
env_nvram_init() assigns default environment if ENV_INVALID, but this is done in the generic env_init() function, which calls this initializer, so drop it from here.
Signed-off-by: Marek Behún marek.behun@nic.cz --- env/nvram.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/env/nvram.c b/env/nvram.c index 261b31edfb..297573c4ed 100644 --- a/env/nvram.c +++ b/env/nvram.c @@ -94,8 +94,7 @@ static int env_nvram_init(void) #endif gd->env_valid = ENV_VALID; } else { - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = ENV_INVALID; + gd->env_valid = ENV_INVALID; }
Use spaces consistently in assignments instead of tabs.
Signed-off-by: Marek Behún marek.behun@nic.cz --- env/nvram.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/env/nvram.c b/env/nvram.c index 297573c4ed..fb265235af 100644 --- a/env/nvram.c +++ b/env/nvram.c @@ -87,10 +87,10 @@ static int env_nvram_init(void) nvram_read(data, CONFIG_ENV_ADDR + sizeof(ulong), ENV_SIZE);
if (crc32(0, data, ENV_SIZE) == crc) { - gd->env_addr = (ulong)CONFIG_ENV_ADDR + sizeof(long); + gd->env_addr = (ulong)CONFIG_ENV_ADDR + sizeof(long); #else if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { - gd->env_addr = (ulong)&env_ptr->data; + gd->env_addr = (ulong)&env_ptr->data; #endif gd->env_valid = ENV_VALID; } else {
env_nowhere_init() assigns default environment if ENV_INVALID, but this is done in the generic env_init() function, which calls this initializer, so drop it from here.
Signed-off-by: Marek Behún marek.behun@nic.cz --- env/nowhere.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/env/nowhere.c b/env/nowhere.c index 1fcf503453..dc93b6f2e4 100644 --- a/env/nowhere.c +++ b/env/nowhere.c @@ -22,7 +22,6 @@ DECLARE_GLOBAL_DATA_PTR; */ static int env_nowhere_init(void) { - gd->env_addr = (ulong)&default_environment[0]; gd->env_valid = ENV_INVALID;
Use spaces instead of tabs in assignments, since there are no lines to align assignment values to.
Signed-off-by: Marek Behún marek.behun@nic.cz --- env/nowhere.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/env/nowhere.c b/env/nowhere.c index dc93b6f2e4..9ebc357dbd 100644 --- a/env/nowhere.c +++ b/env/nowhere.c @@ -22,7 +22,7 @@ DECLARE_GLOBAL_DATA_PTR; */ static int env_nowhere_init(void) { - gd->env_valid = ENV_INVALID; + gd->env_valid = ENV_INVALID;
return 0; } @@ -37,7 +37,7 @@ static int env_nowhere_load(void) if (!IS_ENABLED(CONFIG_SPL_BUILD)) env_set_default(NULL, 0);
return 0; }
env_flash_init() (both implementations) assigns default environment if ENV_INVALID, but this is done in the generic env_init() function, which calls this initializer, so drop it from here.
Signed-off-by: Marek Behún marek.behun@nic.cz --- env/flash.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/env/flash.c b/env/flash.c index ebee9069e4..77d4c030a5 100644 --- a/env/flash.c +++ b/env/flash.c @@ -77,7 +77,6 @@ static int env_flash_init(void) uchar flag1 = flash_addr->flags; uchar flag2 = flash_addr_new->flags;
- ulong addr_default = (ulong)&default_environment[0]; ulong addr1 = (ulong)&(flash_addr->data); ulong addr2 = (ulong)&(flash_addr_new->data);
@@ -92,7 +91,6 @@ static int env_flash_init(void) gd->env_addr = addr2; gd->env_valid = ENV_VALID; } else if (!crc1_ok && !crc2_ok) { - gd->env_addr = addr_default; gd->env_valid = ENV_INVALID; } else if (flag1 == ENV_REDUND_ACTIVE && flag2 == ENV_REDUND_OBSOLETE) { @@ -231,7 +229,6 @@ static int env_flash_init(void) return 0; }
- gd->env_addr = (ulong)&default_environment[0]; gd->env_valid = ENV_INVALID; return 0; }
Change tab to space in env_flash_init().
Signed-off-by: Marek Behún marek.behun@nic.cz --- env/flash.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/env/flash.c b/env/flash.c index 77d4c030a5..b928880502 100644 --- a/env/flash.c +++ b/env/flash.c @@ -229,7 +229,7 @@ static int env_flash_init(void) return 0; }
- gd->env_valid = ENV_INVALID; + gd->env_valid = ENV_INVALID; return 0; } #endif
Feel free to do these code-style all in one patch in the future.
This board sets gd->env_addr to default_environment in board_init(), but the board has environment in SPI flash according to defconfig. Let the env API handle environment automatically.
Signed-off-by: Marek Behún marek.behun@nic.cz Cc: Masami Hiramatsu masami.hiramatsu@linaro.org --- board/socionext/developerbox/developerbox.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/board/socionext/developerbox/developerbox.c b/board/socionext/developerbox/developerbox.c index 9552bfcdc3..31b1349514 100644 --- a/board/socionext/developerbox/developerbox.c +++ b/board/socionext/developerbox/developerbox.c @@ -82,8 +82,6 @@ int board_init(void) { gd->bd->bi_boot_params = CONFIG_SYS_LOAD_ADDR + LOAD_OFFSET;
- gd->env_addr = (ulong)&default_environment[0]; - synquacer_setup_scbm_smmu();
Hi Marek,
I found this cause a synchronous abort on boot on the developerbox when the env_vars on SPI flash is corrupted. See below log. Can we revert it? I confirmed that reverting this patch fixes the problem.
Thank you,
[2021-11-17 13:49:19] U-Boot 2021.10-01018-g535870f3b0 (Nov 17 2021 - 13:45:48 +0900) [2021-11-17 13:49:19] [2021-11-17 13:49:19] CPU: SC2A11:Cortex-A53 MPCore 24cores [2021-11-17 13:49:19] Model: Socionext Developer Box [2021-11-17 13:49:19] DRAM: 3.9 GiB [2021-11-17 13:49:20] MMC: sdhci@52300000: 0 [2021-11-17 13:49:20] Loading Environment from SPIFlash... SF: Detected mx66u51235f with page size 2 56 Bytes, erase size 4 KiB, total 64 MiB [2021-11-17 13:49:20] *** Warning - bad CRC, using default environment [2021-11-17 13:49:20] [2021-11-17 13:49:20] "Synchronous Abort" handler, esr 0x96000210 [2021-11-17 13:49:20] elr: 0000000008245cbc lr : 0000000008245ca4 (reloc) [2021-11-17 13:49:20] elr: 00000000fbf5acbc lr : 00000000fbf5aca4 [2021-11-17 13:49:20] x0 : 000000000000000a x1 : 0000000000000001 [2021-11-17 13:49:20] x2 : 0000000000000000 x3 : 0000000000010301 [2021-11-17 13:49:20] x4 : 0000000000000000 x5 : 0000000000000000 [2021-11-17 13:49:20] x6 : 0000000000000000 x7 : 0000000000000000 [2021-11-17 13:49:20] x8 : 0000000000000004 x9 : 0000000000000008 [2021-11-17 13:49:20] x10: 00000000000186a0 x11: 00000000ffffffd0 [2021-11-17 13:49:20] x12: 0000000000000006 x13: 000000000001869f [2021-11-17 13:49:20] x14: 00000000faee0b00 x15: 0000000000000000 [2021-11-17 13:49:20] x16: 00000000fbf52b24 x17: 0000000000000000 [2021-11-17 13:49:20] x18: 00000000faee4d80 x19: 00000000faf1aad8 [2021-11-17 13:49:20] x20: 000000000828eadf x21: 000000000000000a [2021-11-17 13:49:20] x22: 0000000000000020 x23: 00000000fbfaa016 [2021-11-17 13:49:20] x24: 00000000faee4e70 x25: 000000000828eadf [2021-11-17 13:49:20] x26: 0000000000000400 x27: 000000000002ffff [2021-11-17 13:49:20] x28: 0000000000000000 x29: 00000000faee06b0 [2021-11-17 13:49:20]
2021年10月22日(金) 22:47 Marek Behún kabel@kernel.org:
synquacer_setup_scbm_smmu(); return 0;
-- 2.32.0
Hi Masami,
On Tue, 16 Nov 2021 at 21:59, Masami Hiramatsu masami.hiramatsu@linaro.org wrote:
Hi Marek,
Yes, can you send a patch?
Marek, I think you are working on respinning the rest of your series. Can you take a look at this problem? It would be nice if we could repeat it on sandbox.
Regardds, SImon
Thank you,
-- 2.32.0
-- Masami Hiramatsu
Hi Simon,
2021年11月18日(木) 5:36 Simon Glass sjg@chromium.org:
Hi Masami,
Hi Marek,
OK, I'll send it soon.
Thank you!
Regardds, SImon
Thank you,
-- 2.32.0
-- Masami Hiramatsu
Without default setting of gd->env_addr, U-Boot will cause a synchronous abort if the env-variables on the SPI flash is broken or not saved corectly. Set gd->env_addr correctly.
This reverts commit 535870f3b0fb09ee9b2885409f05304111464643.
Signed-off-by: Masami Hiramatsu masami.hiramatsu@linaro.org --- board/socionext/developerbox/developerbox.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/socionext/developerbox/developerbox.c b/board/socionext/developerbox/developerbox.c index 31b1349514..9552bfcdc3 100644 --- a/board/socionext/developerbox/developerbox.c +++ b/board/socionext/developerbox/developerbox.c @@ -82,6 +82,8 @@ int board_init(void) { gd->bd->bi_boot_params = CONFIG_SYS_LOAD_ADDR + LOAD_OFFSET;
+ gd->env_addr = (ulong)&default_environment[0]; + synquacer_setup_scbm_smmu();
On Thu, 18 Nov 2021 14:45:25 +0900 Masami Hiramatsu masami.hiramatsu@linaro.org wrote:
Reviewed-by: Marek Behún marek.behun@nic.cz
I will look into this when I respin the default environment series.
Marek
Signed-off-by: Masami Hiramatsu masami.hiramatsu@linaro.org Reviewed-by: Marek Behún marek.behun@nic.cz
Various freescale boards set gd->env_addr to default_environment in board_init(), conditional on CONFIG_ENV_IS_NOWHERE, but this is redundant, since it is done by env_init() before board_init() is called.
Let the env subsystem handle this.
Signed-off-by: Marek Behún marek.behun@nic.cz Cc: Ramon Fried rfried.dev@gmail.com Cc: Priyanka Jain priyanka.jain@nxp.com Cc: Mian Yousaf Kaukab ykaukab@suse.de --- board/freescale/ls1012afrdm/ls1012afrdm.c | 4 ---- board/freescale/ls1012aqds/ls1012aqds.c | 4 ---- board/freescale/ls1012ardb/ls1012ardb.c | 4 ---- board/freescale/ls1028a/ls1028a.c | 4 ---- board/freescale/ls1088a/ls1088a.c | 4 ---- board/freescale/ls2080aqds/ls2080aqds.c | 3 --- board/freescale/ls2080ardb/ls2080ardb.c | 3 --- board/freescale/lx2160a/lx2160a.c | 3 --- 8 files changed, 29 deletions(-)
diff --git a/board/freescale/ls1012afrdm/ls1012afrdm.c b/board/freescale/ls1012afrdm/ls1012afrdm.c index 6473ee0572..5dd19cfcd9 100644 --- a/board/freescale/ls1012afrdm/ls1012afrdm.c +++ b/board/freescale/ls1012afrdm/ls1012afrdm.c @@ -172,10 +172,6 @@ int board_init(void) if (current_el() == 3) out_le32(&cci->ctrl_ord, CCI400_CTRLORD_EN_BARRIER);
-#ifdef CONFIG_ENV_IS_NOWHERE - gd->env_addr = (ulong)&default_environment[0]; -#endif - #ifdef CONFIG_FSL_CAAM sec_init(); #endif diff --git a/board/freescale/ls1012aqds/ls1012aqds.c b/board/freescale/ls1012aqds/ls1012aqds.c index 6e21040601..68578e81a5 100644 --- a/board/freescale/ls1012aqds/ls1012aqds.c +++ b/board/freescale/ls1012aqds/ls1012aqds.c @@ -150,10 +150,6 @@ int board_init(void) erratum_a010315(); #endif
-#ifdef CONFIG_ENV_IS_NOWHERE - gd->env_addr = (ulong)&default_environment[0]; -#endif - #ifdef CONFIG_FSL_CAAM sec_init(); #endif diff --git a/board/freescale/ls1012ardb/ls1012ardb.c b/board/freescale/ls1012ardb/ls1012ardb.c index 62e8af48cf..064fb4d39f 100644 --- a/board/freescale/ls1012ardb/ls1012ardb.c +++ b/board/freescale/ls1012ardb/ls1012ardb.c @@ -173,10 +173,6 @@ int board_init(void) erratum_a010315(); #endif
-#ifdef CONFIG_ENV_IS_NOWHERE - gd->env_addr = (ulong)&default_environment[0]; -#endif - #ifdef CONFIG_FSL_CAAM sec_init(); #endif diff --git a/board/freescale/ls1028a/ls1028a.c b/board/freescale/ls1028a/ls1028a.c index 461c571b36..486a544d35 100644 --- a/board/freescale/ls1028a/ls1028a.c +++ b/board/freescale/ls1028a/ls1028a.c @@ -73,10 +73,6 @@ u32 get_lpuart_clk(void)
int board_init(void) { -#ifdef CONFIG_ENV_IS_NOWHERE - gd->env_addr = (ulong)&default_environment[0]; -#endif - #ifdef CONFIG_FSL_CAAM sec_init(); #endif diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index 2f422634d5..7046fbaeb5 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -810,10 +810,6 @@ int board_init(void) select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT, 0); board_retimer_init();
-#ifdef CONFIG_ENV_IS_NOWHERE - gd->env_addr = (ulong)&default_environment[0]; -#endif - #if defined(CONFIG_TARGET_LS1088ARDB) && defined(CONFIG_FSL_MC_ENET) /* invert AQR105 IRQ pins polarity */ out_le32(irq_ccsr + IRQCR_OFFSET / 4, AQR105_IRQ_MASK); diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 62658c4702..2f0139edef 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -211,9 +211,6 @@ int board_init(void) FSL_QIXIS_BRDCFG9_QSPI); #endif
-#ifdef CONFIG_ENV_IS_NOWHERE - gd->env_addr = (ulong)&default_environment[0]; -#endif select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT, 0);
#ifdef CONFIG_RTC_ENABLE_32KHZ_OUTPUT diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index 58b852383e..bf660a8e65 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -281,9 +281,6 @@ int board_init(void)
init_final_memctl_regs();
#ifdef CONFIG_FSL_QIXIS diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index e61289d228..bd5abb677a 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -588,9 +588,6 @@ int board_init(void) #if defined(CONFIG_FSL_MC_ENET) && defined(CONFIG_TARGET_LX2160ARDB) u32 __iomem *irq_ccsr = (u32 __iomem *)ISC_BASE; #endif -#ifdef CONFIG_ENV_IS_NOWHERE - gd->env_addr = (ulong)&default_environment[0]; -#endif
Sometimes we use uchar and sometimes char for the default environment array. By always using char, we can get rid of some explicit casts.
Signed-off-by: Marek Behún marek.behun@nic.cz --- board/Marvell/mvebu_armada-37xx/board.c | 2 +- env/common.c | 6 +++--- include/env_default.h | 4 ++-- include/env_internal.h | 4 ++-- 4 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index 2de9c2ac17..d7b6ecafbf 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -87,7 +87,7 @@ int board_init(void) #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { - char *ptr = (char *)&default_environment[0]; + char *ptr = &default_environment[0]; struct udevice *dev; struct mmc *mmc_dev; bool ddr4, emmc; diff --git a/env/common.c b/env/common.c index db213b7748..664d2e688e 100644 --- a/env/common.c +++ b/env/common.c @@ -162,7 +162,7 @@ int env_get_f(const char *name, char *buf, unsigned len) name_len = strlen(name);
if (gd->env_valid == ENV_INVALID) - env = (const char *)default_environment; + env = default_environment; else env = (const char *)gd->env_addr;
@@ -264,7 +264,7 @@ void env_set_default(const char *s, int flags) }
flags |= H_DEFAULT; - if (himport_r(&env_htab, (char *)default_environment, + if (himport_r(&env_htab, default_environment, sizeof(default_environment), '\0', flags, 0, 0, NULL) == 0) pr_err("## Error: Environment import failed: errno = %d\n", @@ -283,7 +283,7 @@ int env_set_default_vars(int nvars, char * const vars[], int flags) * (and use \0 as a separator) */ flags |= H_NOCLEAR | H_DEFAULT; - return himport_r(&env_htab, (const char *)default_environment, + return himport_r(&env_htab, default_environment, sizeof(default_environment), '\0', flags, 0, nvars, vars); } diff --git a/include/env_default.h b/include/env_default.h index 66e203eb6e..a6724719ec 100644 --- a/include/env_default.h +++ b/include/env_default.h @@ -20,9 +20,9 @@ env_t embedded_environment __UBOOT_ENV_SECTION__(environment) = { #elif defined(DEFAULT_ENV_INSTANCE_STATIC) static char default_environment[] = { #elif defined(DEFAULT_ENV_IS_RW) -uchar default_environment[] = { +char default_environment[] = { #else -const uchar default_environment[] = { +const char default_environment[] = { #endif #ifndef CONFIG_USE_DEFAULT_ENV_FILE #ifdef CONFIG_ENV_CALLBACK_LIST_DEFAULT diff --git a/include/env_internal.h b/include/env_internal.h index b7bddcb00d..f74927cd64 100644 --- a/include/env_internal.h +++ b/include/env_internal.h @@ -112,9 +112,9 @@ extern env_t embedded_environment; #endif /* ENV_IS_EMBEDDED */
#ifdef DEFAULT_ENV_IS_RW -extern unsigned char default_environment[]; +extern char default_environment[]; #else -extern const unsigned char default_environment[]; +extern const char default_environment[]; #endif
#ifndef DO_DEPS_ONLY
Check sizeof(default_environment) against ENV_SIZE in a static_assert() instead of runtime. Only check if !USE_HOSTCC (for in fw_env tool ENV_SIZE expands to a variable, and cannot be checked statically) nad !DEFAULT_ENV_INSTANCE_EMBEDDED, for in that case the default_environment variable is not set.
Signed-off-by: Marek Behún marek.behun@nic.cz --- env/common.c | 5 ----- include/env_default.h | 6 ++++++ 2 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/env/common.c b/env/common.c index 664d2e688e..99729ca002 100644 --- a/env/common.c +++ b/env/common.c @@ -247,11 +247,6 @@ char *env_get_default(const char *name)
void env_set_default(const char *s, int flags) { - if (sizeof(default_environment) > ENV_SIZE) { - puts("*** Error - default environment is too large\n\n"); - return; - } - if (s) { if ((flags & H_INTERACTIVE) == 0) { printf("*** Warning - %s, " diff --git a/include/env_default.h b/include/env_default.h index a6724719ec..23430dc70d 100644 --- a/include/env_default.h +++ b/include/env_default.h @@ -121,3 +121,9 @@ const char default_environment[] = { } #endif }; + +#if !defined(USE_HOSTCC) && !defined(DEFAULT_ENV_INSTANCE_EMBEDDED) +#include <env_internal.h> +static_assert(sizeof(default_environment) <= ENV_SIZE, + "Default environment is too large"); +#endif
Marek Behún
Masami Hiramatsu
