[U-Boot] [PATCH v2 1/4] Flex-OneNAND driver
This patch adds support for MLC OneNAND and Flex-OneNAND devices.
The differences are like this.
OneNAND features: 1. 2KB page 2. 64 pages per block. 3. Upto 4 writes to a page allowed. 4. 1 ECC register 5. OOB read and OOB write commands present.
MLC OneNAND has following changes against OneNAND: 1. 4KB page - both datarams are needed for a read, so no read-while-load 2. Only 1 write per page. 3. OOB read and OOB write commands absent.
Flex-OneNAND has all changes as MLC OneNAND plus some more: 1. Can configure some blocks of a die as SLC and rest as MLC This configuration is in the form of SLC boundary which indicates last SLC block on the die. 2. SLC blocks have 64 pages per block (block size is 256KB). MLC blocks have 128 pages per block (block size is 512KB). 3. A single device is registered for Flex-OneNAND. This device has erase regions. Each erase region has different block size (either SLC or MLC). 4. 4 ECC registers. 5. LSB page recovery feature.
Signed-off-by: Rohit Hagargundgi h.rohit@samsung.com --- drivers/mtd/onenand/onenand_base.c | 711 ++++++++++++++++++++++++++++++----- drivers/mtd/onenand/onenand_bbt.c | 13 +- drivers/mtd/onenand/onenand_uboot.c | 4 +- include/linux/mtd/onenand.h | 15 + include/linux/mtd/onenand_regs.h | 18 +- include/onenand_uboot.h | 10 + 6 files changed, 672 insertions(+), 99 deletions(-)
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index 9b7bf3a..ebda48a 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -45,6 +45,14 @@ static const unsigned char ffchars[] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 48 */ 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 64 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 80 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 96 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 112 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 128 */ };
/** @@ -83,9 +91,11 @@ static int onenand_block_address(int device, int block) if (device & ONENAND_DEVICE_IS_DDP) { /* Device Flash Core select, NAND Flash Block Address */ int dfs = 0, density, mask; + int flex = device & DEVICE_IS_FLEXONENAND;
density = device >> ONENAND_DEVICE_DENSITY_SHIFT; - mask = (1 << (density + 6)); + density &= ONENAND_DEVICE_DENSITY_MASK; + mask = (1 << (density + (flex ? 4 : 6)));
if (block & mask) dfs = 1; @@ -109,9 +119,11 @@ static int onenand_bufferram_address(int device, int block) if (device & ONENAND_DEVICE_IS_DDP) { /* Device BufferRAM Select */ int dbs = 0, density, mask; + int flex = device & DEVICE_IS_FLEXONENAND;
if (block & mask) dbs = 1; @@ -169,6 +181,91 @@ static int onenand_buffer_address(int dataram1, int sectors, int count) }
/** + * flexonenand_get_block- For given address return block number and if slc + * @param this - OneNAND device structure + * @param addr - Address for which block number is needed + * @return isblkslc - Block is an SLC block or not + */ +static unsigned flexonenand_get_block(struct onenand_chip *this, loff_t addr, + unsigned *isblkslc) +{ + unsigned boundary, blk, die = 0; + + if (addr >= this->diesize[0]) { + die = 1; + addr -= this->diesize[0]; + } + + boundary = this->boundary[die]; + + blk = addr >> (this->erase_shift - 1); + if (blk > boundary) + blk = (blk + boundary + 1) >> 1; + + if (isblkslc) + *isblkslc = (blk <= boundary) ? 1 : 0; + + blk += die ? this->density_mask : 0; + return blk; +} + +inline unsigned onenand_get_block(struct onenand_chip *this, loff_t addr, + unsigned *isblkslc) +{ + if (!FLEXONENAND(this)) + return addr >> this->erase_shift; + return flexonenand_get_block(this, addr, isblkslc); +} + +/** + * flexonenand_get_addr - Return address of the block + * @this: OneNAND device structure + * @block: Block number on Flex-OneNAND + * + * Return address of the block + */ +static loff_t flexonenand_get_addr(struct onenand_chip *this, int block) +{ + loff_t ofs = 0; + int die = 0, boundary; + + if (this->dies == 2 && block >= this->density_mask) { + block -= this->density_mask; + die = 1; + ofs = this->diesize[0]; + } + + boundary = this->boundary[die]; + ofs += block << (this->erase_shift - 1); + if (block > (boundary + 1)) + ofs += (block - boundary - 1) << (this->erase_shift - 1); + return ofs; +} + +inline loff_t onenand_get_addr(struct onenand_chip *this, int block) +{ + if (!FLEXONENAND(this)) + return block << this->erase_shift; + return flexonenand_get_addr(this, block); +} + +/** + * flexonenand_region - [Flex-OneNAND] Return erase region of addr + * @param mtd MTD device structure + * @param addr address whose erase region needs to be identified + */ +inline int flexonenand_region(struct mtd_info *mtd, loff_t addr) +{ + int i; + + for (i = 0; i < mtd->numeraseregions && + addr >= mtd->eraseregions[i].offset; i++) + ; + i--; + return i; +} + +/** * onenand_command - [DEFAULT] Send command to OneNAND device * @param mtd MTD device structure * @param cmd the command to be sent @@ -182,10 +279,12 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, size_t len) { struct onenand_chip *this = mtd->priv; - int value, readcmd = 0; + int value; int block, page; + unsigned slc = 0; + /* Now we use page size operation */ - int sectors = 4, count = 4; + int sectors = 0, count = 0;
/* Address translation */ switch (cmd) { @@ -196,16 +295,30 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, page = -1; break;
+ case FLEXONENAND_CMD_PI_ACCESS: + /* addr contains die index */ + block = addr * this->density_mask; + page = -1; + break; + case ONENAND_CMD_ERASE: case ONENAND_CMD_BUFFERRAM: - block = (int)(addr >> this->erase_shift); + block = onenand_get_block(this, addr, NULL); page = -1; break;
+ case FLEXONENAND_CMD_READ_PI: + cmd = ONENAND_CMD_READ; + block = addr * this->density_mask; + page = 0; + break; + default: - block = (int)(addr >> this->erase_shift); - page = (int)(addr >> this->page_shift); + block = onenand_get_block(this, addr, &slc); + page = (int) (addr - onenand_get_addr(this, block)) >> this->page_shift; page &= this->page_mask; + if (slc) + page &= (this->page_mask >> 1); break; }
@@ -216,8 +329,11 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, this->write_word(value, this->base + ONENAND_REG_START_ADDRESS2);
- /* Switch to the next data buffer */ - ONENAND_SET_NEXT_BUFFERRAM(this); + if (ONENAND_IS_MLC(this)) + ONENAND_SET_BUFFERRAM0(this); + else + /* Switch to the next data buffer */ + ONENAND_SET_NEXT_BUFFERRAM(this);
return 0; } @@ -227,6 +343,10 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, value = onenand_block_address(this->device_id, block); this->write_word(value, this->base + ONENAND_REG_START_ADDRESS1); + /* Select DataRAM for DDP */ + value = onenand_bufferram_address(this->device_id, block); + this->write_word(value, + this->base + ONENAND_REG_START_ADDRESS2); }
if (page != -1) { @@ -235,8 +355,10 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, switch (cmd) { case ONENAND_CMD_READ: case ONENAND_CMD_READOOB: - dataram = ONENAND_SET_NEXT_BUFFERRAM(this); - readcmd = 1; + if (ONENAND_IS_MLC(this)) + dataram = ONENAND_SET_BUFFERRAM0(this); + else + dataram = ONENAND_SET_NEXT_BUFFERRAM(this); break;
default: @@ -253,14 +375,6 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, value = onenand_buffer_address(dataram, sectors, count); this->write_word(value, this->base + ONENAND_REG_START_BUFFER);
- if (readcmd) { - /* Select DataRAM for DDP */ - value = - onenand_bufferram_address(this->device_id, block); - this->write_word(value, - this->base + - ONENAND_REG_START_ADDRESS2); - } }
/* Interrupt clear */ @@ -272,6 +386,28 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, }
/** + * onenand_read_ecc - return ecc status + * @param this onenand chip structure + */ +static inline int onenand_read_ecc(struct onenand_chip *this) +{ + int ecc, i, result = 0; + + if (!FLEXONENAND(this)) + return this->read_word(this->base + ONENAND_REG_ECC_STATUS); + + for (i = 0; i < 4; i++) { + ecc = this->read_word(this->base + ((ONENAND_REG_ECC_STATUS + i) << 1)); + if (likely(!ecc)) + continue; + if (ecc & FLEXONENAND_UNCORRECTABLE_ERROR) + return ONENAND_ECC_2BIT_ALL; + } + + return result; +} + +/** * onenand_wait - [DEFAULT] wait until the command is done * @param mtd MTD device structure * @param state state to select the max. timeout value @@ -295,6 +431,15 @@ static int onenand_wait(struct mtd_info *mtd, int state)
ctrl = this->read_word(this->base + ONENAND_REG_CTRL_STATUS);
+ if (interrupt & ONENAND_INT_READ) { + ecc = onenand_read_ecc(this); + if (ecc & ONENAND_ECC_2BIT_ALL) { + MTDDEBUG (MTD_DEBUG_LEVEL0, + "onenand_wait: ECC error = 0x%04x\n", ecc); + return -EBADMSG; + } + } + if (ctrl & ONENAND_CTRL_ERROR) { MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_wait: controller error = 0x%04x\n", ctrl); @@ -307,15 +452,6 @@ static int onenand_wait(struct mtd_info *mtd, int state) return -EIO; }
- if (interrupt & ONENAND_INT_READ) { - ecc = this->read_word(this->base + ONENAND_REG_ECC_STATUS); - if (ecc & ONENAND_ECC_2BIT_ALL) { - MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_wait: ECC error = 0x%04x\n", ecc); - return -EBADMSG; - } - } - return 0; }
@@ -433,10 +569,13 @@ static int onenand_check_bufferram(struct mtd_info *mtd, loff_t addr) struct onenand_chip *this = mtd->priv; int block, page; int i; + unsigned slc = 0;
- block = (int)(addr >> this->erase_shift); + block = onenand_get_block(this, addr, &slc); page = (int)(addr >> this->page_shift); page &= this->page_mask; + if (slc) + page &= (this->page_mask >> 1);
i = ONENAND_CURRENT_BUFFERRAM(this);
@@ -462,10 +601,13 @@ static int onenand_update_bufferram(struct mtd_info *mtd, loff_t addr, struct onenand_chip *this = mtd->priv; int block, page; int i; + unsigned slc = 0;
/* Invalidate BufferRAM */ for (i = 0; i < MAX_BUFFERRAM; i++) { @@ -573,6 +715,48 @@ static int onenand_transfer_auto_oob(struct mtd_info *mtd, uint8_t *buf, }
/** + * onenand_recover_lsb - [Flex-OneNAND] Recover LSB page data + * @param mtd MTD device structure + * @param addr address to recover + * @param status return value from onenand_wait + * + * MLC NAND Flash cell has paired pages - LSB page and MSB page. LSB page has + * lower page address and MSB page has higher page address in paired pages. + * If power off occurs during MSB page program, the paired LSB page data can + * become corrupt. LSB page recovery read is a way to read LSB page though page + * data are corrupted. When uncorrectable error occurs as a result of LSB page + * read after power up, issue LSB page recovery read. + */ +static int onenand_recover_lsb(struct mtd_info *mtd, loff_t addr, int status) +{ + struct onenand_chip *this = mtd->priv; + unsigned slc = 0; + + /* Recovery is only for Flex-OneNAND */ + if (!FLEXONENAND(this)) + return status; + + /* check if we failed due to uncorrectable error */ + if (status != -EBADMSG && status != ONENAND_BBT_READ_ECC_ERROR) + return status; + + /* check if address lies in MLC region */ + onenand_get_block(this, addr, &slc); + if (slc) + return status; + + /* We are attempting to reread, so decrement stats.failed + * which was incremented by onenand_wait due to read failure + */ + printk(KERN_INFO "onenand_recover_lsb: Attempting to recover from uncorrectable read\n"); + mtd->ecc_stats.failed--; + + /* Issue the LSB page recovery command */ + this->command(mtd, FLEXONENAND_CMD_RECOVER_LSB, addr, this->writesize); + return this->wait(mtd, FL_READING); +} + +/** * onenand_read_ops_nolock - [OneNAND Interface] OneNAND read main and/or out-of-band * @param mtd MTD device structure * @param from offset to read from @@ -616,12 +800,14 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, stats = mtd->ecc_stats;
/* Read-while-load method */ + /* Note: We can't use this feature in MLC */
/* Do first load to bufferRAM */ if (read < len) { if (!onenand_check_bufferram(mtd, from)) { this->command(mtd, ONENAND_CMD_READ, from, writesize); ret = this->wait(mtd, FL_READING); + ret = ret ? onenand_recover_lsb(mtd, from, ret) : ret; onenand_update_bufferram(mtd, from, !ret); if (ret == -EBADMSG) ret = 0; @@ -636,7 +822,7 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, while (!ret) { /* If there is more to load then start next load */ from += thislen; - if (read + thislen < len) { + if (!ONENAND_IS_MLC(this) && read + thislen < len) { this->command(mtd, ONENAND_CMD_READ, from, writesize); /* * Chip boundary handling in DDP @@ -669,6 +855,15 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, oobcolumn = 0; }
+ if (ONENAND_IS_MLC(this) && (read + thislen < len)) { + this->command(mtd, ONENAND_CMD_READ, from, writesize); + ret = this->wait(mtd, FL_READING); + ret = ret ? onenand_recover_lsb(mtd, from, ret) : ret; + onenand_update_bufferram(mtd, from, !ret); + if (ret == -EBADMSG) + ret = 0; + } + /* See if we are done */ read += thislen; if (read == len) @@ -676,16 +871,19 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, /* Set up for next read from bufferRAM */ if (unlikely(boundary)) this->write_word(ONENAND_DDP_CHIP1, this->base + ONENAND_REG_START_ADDRESS2); - ONENAND_SET_NEXT_BUFFERRAM(this); + if (!ONENAND_IS_MLC(this)) + ONENAND_SET_NEXT_BUFFERRAM(this); buf += thislen; thislen = min_t(int, writesize, len - read); column = 0;
- /* Now wait for load */ - ret = this->wait(mtd, FL_READING); - onenand_update_bufferram(mtd, from, !ret); - if (ret == -EBADMSG) - ret = 0; + if (!ONENAND_IS_MLC(this)) { + /* Now wait for load */ + ret = this->wait(mtd, FL_READING); + onenand_update_bufferram(mtd, from, !ret); + if (ret == -EBADMSG) + ret = 0; + } }
/* @@ -722,7 +920,7 @@ static int onenand_read_oob_nolock(struct mtd_info *mtd, loff_t from, size_t len = ops->ooblen; mtd_oob_mode_t mode = ops->mode; u_char *buf = ops->oobbuf; - int ret = 0; + int ret = 0, readcmd;
from += ops->ooboffs;
@@ -755,15 +953,20 @@ static int onenand_read_oob_nolock(struct mtd_info *mtd, loff_t from,
+ readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB; + while (read < len) { thislen = oobsize - column; thislen = min_t(int, thislen, len);
- this->command(mtd, ONENAND_CMD_READOOB, from, mtd->oobsize); + this->command(mtd, readcmd, from, mtd->oobsize);
onenand_update_bufferram(mtd, from, 0);
ret = this->wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); + if (ret && ret != -EBADMSG) { printk(KERN_ERR "onenand_read_oob_nolock: read failed = 0x%x\n", ret); break; @@ -886,22 +1089,26 @@ static int onenand_bbt_wait(struct mtd_info *mtd, int state) interrupt = this->read_word(this->base + ONENAND_REG_INTERRUPT); ctrl = this->read_word(this->base + ONENAND_REG_CTRL_STATUS);
- /* Initial bad block case: 0x2400 or 0x0400 */ - if (ctrl & ONENAND_CTRL_ERROR) { - printk(KERN_DEBUG "onenand_bbt_wait: controller error = 0x%04x\n", ctrl); - return ONENAND_BBT_READ_ERROR; - } - if (interrupt & ONENAND_INT_READ) { - int ecc = this->read_word(this->base + ONENAND_REG_ECC_STATUS); - if (ecc & ONENAND_ECC_2BIT_ALL) + int ecc = onenand_read_ecc(this); + if (ecc & ONENAND_ECC_2BIT_ALL) { + printk(KERN_INFO "onenand_bbt_wait: ecc error = 0x%04x" + ", controller = 0x%04x\n", ecc, ctrl); return ONENAND_BBT_READ_ERROR; + } } else { printk(KERN_ERR "onenand_bbt_wait: read timeout!" "ctrl=0x%04x intr=0x%04x\n", ctrl, interrupt); return ONENAND_BBT_READ_FATAL_ERROR; }
+ /* Initial bad block case: 0x2400 or 0x0400 */ + if (ctrl & ONENAND_CTRL_ERROR) { + printk(KERN_DEBUG "onenand_bbt_wait: controller error" + " = 0x%04x\n", ctrl); + return ONENAND_BBT_READ_ERROR; + } + return 0; }
@@ -918,7 +1125,7 @@ int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, { struct onenand_chip *this = mtd->priv; int read = 0, thislen, column; - int ret = 0; + int ret = 0, readcmd; size_t len = ops->ooblen; u_char *buf = ops->oobbuf;
@@ -926,6 +1133,8 @@ int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, "onenand_bbt_read_oob: from = 0x%08x, len = %zi\n", (unsigned int) from, len);
+ readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB; + /* Initialize return value */ ops->oobretlen = 0;
@@ -945,11 +1154,14 @@ int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, thislen = mtd->oobsize - column; thislen = min_t(int, thislen, len);
ret = onenand_bbt_wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); + if (ret) break;
@@ -987,9 +1199,11 @@ static int onenand_verify_oob(struct mtd_info *mtd, const u_char *buf, loff_t to { struct onenand_chip *this = mtd->priv; u_char *oob_buf = this->oob_buf; - int status, i; + int status, i, readcmd; + + readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB;
- this->command(mtd, ONENAND_CMD_READOOB, to, mtd->oobsize); + this->command(mtd, readcmd, to, mtd->oobsize); onenand_update_bufferram(mtd, to, 0); status = this->wait(mtd, FL_READING); if (status) @@ -1167,7 +1381,7 @@ static int onenand_write_ops_nolock(struct mtd_info *mtd, loff_t to, oobbuf = this->oob_buf;
/* We send data to spare ram with oobsize - * * to prevent byte access */ + * to prevent byte access */ memset(oobbuf, 0xff, mtd->oobsize); if (ops->mode == MTD_OOB_AUTO) onenand_fill_auto_oob(mtd, oobbuf, oob, oobcolumn, thisooblen); @@ -1236,7 +1450,7 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to, { struct onenand_chip *this = mtd->priv; int column, ret = 0, oobsize; - int written = 0; + int written = 0, oobcmd; u_char *oobbuf; size_t len = ops->ooblen; const u_char *buf = ops->oobbuf; @@ -1280,6 +1494,8 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to,
+ oobcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_PROG : ONENAND_CMD_PROGOOB; + /* Loop until all data write */ while (written < len) { int thislen = min_t(int, oobsize, len - written); @@ -1295,7 +1511,14 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to, memcpy(oobbuf + column, buf, thislen); this->write_bufferram(mtd, ONENAND_SPARERAM, oobbuf, 0, mtd->oobsize);
- this->command(mtd, ONENAND_CMD_PROGOOB, to, mtd->oobsize); + if (ONENAND_IS_MLC(this)) { + /* Set main area of DataRAM to 0xff*/ + memset(this->page_buf, 0xff, mtd->writesize); + this->write_bufferram(mtd, ONENAND_DATARAM, + this->page_buf, 0, mtd->writesize); + } + + this->command(mtd, oobcmd, to, mtd->oobsize);
onenand_update_bufferram(mtd, to, 0); if (ONENAND_IS_2PLANE(this)) { @@ -1422,34 +1645,50 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) { struct onenand_chip *this = mtd->priv; unsigned int block_size; - loff_t addr; - int len; - int ret = 0; - - MTDDEBUG (MTD_DEBUG_LEVEL3, - "onenand_erase: start = 0x%08x, len = %i\n", - (unsigned int)instr->addr, (unsigned int)instr->len); + loff_t addr = instr->addr; + unsigned int len = instr->len; + int ret = 0, i; + struct mtd_erase_region_info *region = NULL; + unsigned int region_end = 0;
- block_size = (1 << this->erase_shift); + MTDDEBUG (MTD_DEBUG_LEVEL3, "onenand_erase: start = 0x%08x, len = %i\n", + (unsigned int) addr, len);
- /* Start address must align on block boundary */ - if (unlikely(instr->addr & (block_size - 1))) { - MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_erase: Unaligned address\n"); + /* Do not allow erase past end of device */ + if (unlikely((len + addr) > mtd->size)) { + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: Erase past end of device\n"); return -EINVAL; }
- /* Length must align on block boundary */ - if (unlikely(instr->len & (block_size - 1))) { - MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_erase: Length not block aligned\n"); - return -EINVAL; + if (mtd->numeraseregions > 1) { + /* Find the eraseregion of this address */ + i = flexonenand_region(mtd, addr); + region = &mtd->eraseregions[i]; + + block_size = region->erasesize; + region_end = region->offset + region->erasesize * region->numblocks; + + /* Start address within region must align on block boundary. + * Erase region's start offset is always block start address. + */ + if (unlikely((addr - region->offset) & (block_size - 1))) { + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: Unaligned address\n"); + return -EINVAL; + } + } else { + block_size = 1 << this->erase_shift; + + /* Start address must align on block boundary */ + if (unlikely(addr & (block_size - 1))) { + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: Unaligned address\n"); + return -EINVAL; + } }
- /* Do not allow erase past end of device */ - if (unlikely((instr->len + instr->addr) > mtd->size)) { + /* Length must align on block boundary */ + if (unlikely(len & (block_size - 1))) { MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_erase: Erase past end of device\n"); + "onenand_erase: Length not block aligned\n"); return -EINVAL; }
@@ -1459,9 +1698,6 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) onenand_get_device(mtd, FL_ERASING);
/* Loop throught the pages */ - len = instr->len; - addr = instr->addr; - instr->state = MTD_ERASING;
while (len) { @@ -1481,7 +1717,7 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) else MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: " "Failed erase, block %d\n", - (unsigned)(addr >> this->erase_shift)); + onenand_get_block(this, addr, NULL)); instr->state = MTD_ERASE_FAILED; instr->fail_addr = addr; goto erase_exit; @@ -1489,6 +1725,22 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr)
len -= block_size; addr += block_size; + + if (addr == region_end) { + if (!len) + break; + region++; + + block_size = region->erasesize; + region_end = region->offset + region->erasesize * region->numblocks; + + if (len & (block_size - 1)) { + /* FIXME: This should be handled at MTD partitioning level. */ + printk(KERN_ERR "onenand_erase: Unaligned address\n"); + goto erase_exit; + } + } + }
instr->state = MTD_ERASE_DONE; @@ -1581,8 +1833,8 @@ int onenand_unlock(struct mtd_info *mtd, loff_t ofs, size_t len) struct onenand_chip *this = mtd->priv; int start, end, block, value, status;
- start = ofs >> this->erase_shift; - end = len >> this->erase_shift; + start = onenand_get_block(this, ofs, NULL); + end = onenand_get_block(this, ofs + len, NULL) - 1;
/* Continuous lock scheme */ if (this->options & ONENAND_CONT_LOCK) { @@ -1590,7 +1842,7 @@ int onenand_unlock(struct mtd_info *mtd, loff_t ofs, size_t len) this->write_word(start, this->base + ONENAND_REG_START_BLOCK_ADDRESS); /* Set end block address */ - this->write_word(end - 1, + this->write_word(end, this->base + ONENAND_REG_END_BLOCK_ADDRESS); /* Write unlock command */ this->command(mtd, ONENAND_CMD_UNLOCK, 0, 0); @@ -1612,7 +1864,17 @@ int onenand_unlock(struct mtd_info *mtd, loff_t ofs, size_t len) }
/* Block lock scheme */ - for (block = start; block < end; block++) { + for (block = start; block < end + 1; block++) { + /* Set block address */ + value = onenand_block_address(this->device_id, block); + this->write_word(value, + this->base + ONENAND_REG_START_ADDRESS1); + + /* Select DataRAM for DDP */ + value = onenand_bufferram_address(this->device_id, block); + this->write_word(value, + this->base + ONENAND_REG_START_ADDRESS2); + /* Set start block address */ this->write_word(block, this->base + ONENAND_REG_START_BLOCK_ADDRESS); @@ -1650,15 +1912,18 @@ int onenand_unlock(struct mtd_info *mtd, loff_t ofs, size_t len) */ char * onenand_print_device_info(int device) { - int vcc, demuxed, ddp, density; + int vcc, demuxed, ddp, density, flexonenand; char *dev_info = malloc(80);
vcc = device & ONENAND_DEVICE_VCC_MASK; demuxed = device & ONENAND_DEVICE_IS_DEMUX; ddp = device & ONENAND_DEVICE_IS_DDP; density = device >> ONENAND_DEVICE_DENSITY_SHIFT; - sprintf(dev_info, "%sOneNAND%s %dMB %sV 16-bit (0x%02x)", - demuxed ? "" : "Muxed ", + density &= ONENAND_DEVICE_DENSITY_MASK; + flexonenand = device & DEVICE_IS_FLEXONENAND; + sprintf(dev_info, "%s%sOneNAND%s %dMB %sV 16-bit (0x%02x)", + demuxed ? "" : "Muxed ", + flexonenand ? "Flex-" : "", ddp ? "(DDP)" : "", (16 << density), vcc ? "2.65/3.3" : "1.8", device);
@@ -1694,6 +1959,243 @@ static int onenand_check_maf(int manuf) }
/** +* flexonenand_get_boundary - Reads the SLC boundary +* @param onenand_info - onenand info structure +**/ +static int flexonenand_get_boundary(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + unsigned die, bdry; + int ret, syscfg, locked; + + /* Disable ECC */ + syscfg = this->read_word(this->base + ONENAND_REG_SYS_CFG1); + this->write_word((syscfg | 0x0100), this->base + ONENAND_REG_SYS_CFG1); + + for (die = 0; die < this->dies; die++) { + this->command(mtd, FLEXONENAND_CMD_PI_ACCESS, die, 0); + this->wait(mtd, FL_SYNCING); + + this->command(mtd, FLEXONENAND_CMD_READ_PI, die, 0); + ret = this->wait(mtd, FL_READING); + + bdry = this->read_word(this->base + ONENAND_DATARAM); + locked = bdry >> FLEXONENAND_PI_UNLOCK_SHIFT; + locked = (locked == 0x3) ? 0 : 1; + this->boundary[die] = bdry & FLEXONENAND_PI_MASK; + + this->command(mtd, ONENAND_CMD_RESET, 0, 0); + ret = this->wait(mtd, FL_RESETING); + + printk(KERN_INFO "Die %d boundary: %d%s\n", die, + this->boundary[die], locked ? "(Locked)" : "(Unlocked)"); + } + + /* Enable ECC */ + this->write_word(syscfg, this->base + ONENAND_REG_SYS_CFG1); + return 0; +} + +/** + * flexonenand_get_size - Fill up fields in onenand_chip + * boundary[], diesize[], mtd->size + * @param mtd - MTD device structure + */ +static void flexonenand_get_size(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + int die, ofs, i, eraseshift, density; + int blksperdie, maxbdry; + + density = this->device_id >> ONENAND_DEVICE_DENSITY_SHIFT; + density &= ONENAND_DEVICE_DENSITY_MASK; + blksperdie = ((16 << density) << 20) >> (this->erase_shift); + blksperdie >>= ONENAND_IS_DDP(this) ? 1 : 0; + maxbdry = blksperdie - 1; + eraseshift = this->erase_shift - 1; + + + mtd->numeraseregions = this->dies << 1; + + /* This fills up the device boundary */ + flexonenand_get_boundary(mtd); + die = ofs = 0; + i = -1; + for (; die < this->dies; die++) { + if (!die || this->boundary[die-1] != maxbdry) { + i++; + mtd->eraseregions[i].offset = ofs; + mtd->eraseregions[i].erasesize = 1 << eraseshift; + mtd->eraseregions[i].numblocks = + this->boundary[die] + 1; + ofs += mtd->eraseregions[i].numblocks << eraseshift; + eraseshift++; + } else { + mtd->numeraseregions -= 1; + mtd->eraseregions[i].numblocks += + this->boundary[die] + 1; + ofs += (this->boundary[die] + 1) << (eraseshift - 1); + } + if (this->boundary[die] != maxbdry) { + i++; + mtd->eraseregions[i].offset = ofs; + mtd->eraseregions[i].erasesize = 1 << eraseshift; + mtd->eraseregions[i].numblocks = maxbdry ^ + this->boundary[die]; + ofs += mtd->eraseregions[i].numblocks << eraseshift; + eraseshift--; + } else + mtd->numeraseregions -= 1; + } + + mtd->erasesize = 1 << (this->erase_shift); + if (mtd->numeraseregions == 1) + mtd->erasesize >>= 1; + + printk(KERN_INFO "Device has %d eraseregions\n", mtd->numeraseregions); + for (i = 0; i < mtd->numeraseregions; i++) + printk(KERN_INFO "[offset: 0x%08x, erasesize: 0x%05x," + " numblocks: %04u]\n", mtd->eraseregions[i].offset, + mtd->eraseregions[i].erasesize, + mtd->eraseregions[i].numblocks); + + for (die = 0, mtd->size = 0; die < this->dies; die++) { + this->diesize[die] = (blksperdie << this->erase_shift); + this->diesize[die] -= (this->boundary[die] + 1) + << (this->erase_shift - 1); + mtd->size += this->diesize[die]; + } +} + +/** + * flexonenand_check_blocks_erased - Check if blocks are erased + * @param mtd_info - mtd info structure + * @param start - first erase block to check + * @param end - last erase block to check + * + * Converting an unerased block from MLC to SLC + * causes byte values to change. Since both data and its ECC + * have changed, reads on the block give uncorrectable error. + * This might lead to the block being detected as bad. + * + * Avoid this by ensuring that the block to be converted is + * erased. + */ +static int flexonenand_check_blocks_erased(struct mtd_info *mtd, int start, int end) +{ + struct onenand_chip *this = mtd->priv; + int i, ret; + int block; + struct mtd_oob_ops ops = { + .mode = MTD_OOB_PLACE, + .ooboffs = 0, + .ooblen = mtd->oobsize, + .datbuf = NULL, + .oobbuf = this->oob_buf, + }; + loff_t addr; + + printk(KERN_DEBUG "Check blocks from %d to %d\n", start, end); + + for (block = start; block <= end; block++) { + addr = flexonenand_get_addr(this, block); + if (onenand_block_isbad_nolock(mtd, addr, 0)) + continue; + + /* + * Since main area write results in ECC write to spare, + * it is sufficient to check only ECC bytes for change. + */ + ret = onenand_read_oob_nolock(mtd, addr, &ops); + if (ret) + return ret; + + for (i = 0; i < mtd->oobsize; i++) + if (this->oob_buf[i] != 0xff) + break; + + if (i != mtd->oobsize) { + printk(KERN_WARNING "Block %d not erased.\n", block); + return 1; + } + } + + return 0; +} + +/** + * flexonenand_set_boundary - Writes the SLC boundary + * @param onenand_info - onenand info structure + */ +int flexonenand_set_boundary(struct mtd_info *mtd, int die, + int boundary, int lock) +{ + struct onenand_chip *this = mtd->priv; + int ret, density, blksperdie, old, new; + unsigned addr; + + density = this->device_id >> ONENAND_DEVICE_DENSITY_SHIFT; + density &= ONENAND_DEVICE_DENSITY_MASK; + + blksperdie = ((16 << density) << 20) >> this->erase_shift; + blksperdie >>= (this->device_id & ONENAND_DEVICE_IS_DDP) ? 1 : 0; + + addr = die ? this->diesize[0] : 0; + + if (boundary >= blksperdie) { + printk(KERN_ERR "Invalid boundary value.\n"); + return -1; + } + + if (this->boundary[die] == boundary) + return -1; + + /* Check if converting blocks are erased */ + old = this->boundary[die] + (die * this->density_mask); + new = boundary + (die * this->density_mask); + ret = flexonenand_check_blocks_erased(mtd, min(old, new) + 1, max(old, new)); + if (ret) { + printk(KERN_ERR "flexonenand_set_boundary: Please erase blocks before boundary change\n"); + return ret; + } + + printk(KERN_INFO "Changing boundary: %d%s\n", boundary, lock ? + "(Locked)" : "(Unlocked)"); + boundary &= FLEXONENAND_PI_MASK; + boundary |= lock ? 0 : (3 << FLEXONENAND_PI_UNLOCK_SHIFT); + + this->command(mtd, FLEXONENAND_CMD_PI_ACCESS, die, 0); + this->wait(mtd, FL_SYNCING); + + this->command(mtd, ONENAND_CMD_ERASE, addr, 0); + ret = this->wait(mtd, FL_ERASING); + if (ret) { + printk(KERN_ERR "flexonenand_set_boundary: Failed PI erase for Die %d\n", die); + goto out; + } + + + this->write_word(boundary, this->base + ONENAND_DATARAM); + this->command(mtd, ONENAND_CMD_PROG, addr, 0); + ret = this->wait(mtd, FL_WRITING); + if (ret) { + printk(KERN_ERR "flexonenand_set_boundary: Failed PI write for Die %d\n", die); + goto out; + } + + this->command(mtd, FLEXONENAND_CMD_PI_UPDATE, die, 0); + ret = this->wait(mtd, FL_WRITING); +out: + this->write_word(ONENAND_CMD_RESET, this->base + ONENAND_REG_COMMAND); + this->wait(mtd, FL_RESETING); + if (!ret) + /* Recalculate device size on boundary change*/ + flexonenand_get_size(mtd); + + return ret; +} + +/** * onenand_probe - [OneNAND Interface] Probe the OneNAND device * @param mtd MTD device structure * @@ -1727,42 +2229,64 @@ static int onenand_probe(struct mtd_info *mtd) /* Read manufacturer and device IDs from Register */ maf_id = this->read_word(this->base + ONENAND_REG_MANUFACTURER_ID); dev_id = this->read_word(this->base + ONENAND_REG_DEVICE_ID); + this->technology = this->read_word(this->base + ONENAND_REG_TECHNOLOGY);
/* Check OneNAND device */ if (maf_id != bram_maf_id || dev_id != bram_dev_id) return -ENXIO;
- /* FIXME : Current OneNAND MTD doesn't support Flex-OneNAND */ - if (dev_id & (1 << 9)) { - printk("Not yet support Flex-OneNAND\n"); - return -ENXIO; - } - /* Flash device information */ mtd->name = onenand_print_device_info(dev_id); this->device_id = dev_id;
density = dev_id >> ONENAND_DEVICE_DENSITY_SHIFT; + density &= ONENAND_DEVICE_DENSITY_MASK; + if (FLEXONENAND(this)) { + this->dies = (dev_id & ONENAND_DEVICE_IS_DDP) ? 2 : 1; + /* Maximum possible erase regions */ + mtd->numeraseregions = this->dies << 1; + mtd->eraseregions = malloc(sizeof(struct mtd_erase_region_info) + * (this->dies << 1)); + if (!mtd->eraseregions) + return -ENOMEM; + } + + /* + * For Flex-OneNAND, chipsize represents maximum possible device size. + * mtd->size represents the actual device size. + */ this->chipsize = (16 << density) << 20;
/* OneNAND page size & block size */ /* The data buffer size is equal to page size */ mtd->writesize = this->read_word(this->base + ONENAND_REG_DATA_BUFFER_SIZE); + /* We use the full BufferRAM */ + if (ONENAND_IS_MLC(this)) + mtd->writesize <<= 1; + mtd->oobsize = mtd->writesize >> 5; /* Pagers per block is always 64 in OneNAND */ mtd->erasesize = mtd->writesize << 6; + /* Flex-OneNAND always has 128 pages per block */ + mtd->erasesize <<= FLEXONENAND(this) ? 1 : 0;
this->erase_shift = ffs(mtd->erasesize) - 1; this->page_shift = ffs(mtd->writesize) - 1; this->ppb_shift = (this->erase_shift - this->page_shift); this->page_mask = (mtd->erasesize / mtd->writesize) - 1; + /* Set density mask. it is used for DDP */ + if (ONENAND_IS_DDP(this)) + this->density_mask = this->chipsize >> (this->erase_shift + 1); /* It's real page size */ this->writesize = mtd->writesize;
/* REVIST: Multichip handling */
- mtd->size = this->chipsize; + if (FLEXONENAND(this)) + flexonenand_get_size(mtd); + else + mtd->size = this->chipsize;
/* Version ID */ version_id = this->read_word(this->base + ONENAND_REG_VERSION_ID); @@ -1787,6 +2311,9 @@ static int onenand_probe(struct mtd_info *mtd) mtd->block_isbad = onenand_block_isbad; mtd->block_markbad = onenand_block_markbad;
+ if (FLEXONENAND(this)) + this->options &= ~ONENAND_CONT_LOCK; + return 0; }
diff --git a/drivers/mtd/onenand/onenand_bbt.c b/drivers/mtd/onenand/onenand_bbt.c index f6092b9..3cf1758 100644 --- a/drivers/mtd/onenand/onenand_bbt.c +++ b/drivers/mtd/onenand/onenand_bbt.c @@ -66,6 +66,7 @@ static int create_bbt(struct mtd_info *mtd, uint8_t * buf, struct bbm_info *bbm = this->bbm; int i, j, numblocks, len, scanlen; int startblock; + unsigned slc = 0; loff_t from; size_t readlen, ooblen; struct mtd_oob_ops ops; @@ -82,7 +83,7 @@ static int create_bbt(struct mtd_info *mtd, uint8_t * buf, /* Note that numblocks is 2 * (real numblocks) here; * see i += 2 below as it makses shifting and masking less painful */ - numblocks = mtd->size >> (bbm->bbt_erase_shift - 1); + numblocks = this->chipsize >> (bbm->bbt_erase_shift - 1); startblock = 0; from = 0;
@@ -115,7 +116,11 @@ static int create_bbt(struct mtd_info *mtd, uint8_t * buf, } } i += 2; - from += (1 << bbm->bbt_erase_shift); + onenand_get_block(this, from, &slc); + if (slc) + from += (1 << bbm->bbt_erase_shift) >> 1; + else + from += (1 << bbm->bbt_erase_shift); }
return 0; @@ -152,7 +157,7 @@ static int onenand_isbad_bbt(struct mtd_info *mtd, loff_t offs, int allowbbt) uint8_t res;
/* Get block number * 2 */ - block = (int)(offs >> (bbm->bbt_erase_shift - 1)); + block = (int) (onenand_get_block(this, offs, NULL) << 1); res = (bbm->bbt[block >> 3] >> (block & 0x06)) & 0x03;
MTDDEBUG (MTD_DEBUG_LEVEL2, @@ -191,7 +196,7 @@ int onenand_scan_bbt(struct mtd_info *mtd, struct nand_bbt_descr *bd) struct bbm_info *bbm = this->bbm; int len, ret = 0;
- len = mtd->size >> (this->erase_shift + 2); + len = this->chipsize >> (this->erase_shift + 2); /* Allocate memory (2bit per block) */ bbm->bbt = malloc(len); if (!bbm->bbt) { diff --git a/drivers/mtd/onenand/onenand_uboot.c b/drivers/mtd/onenand/onenand_uboot.c index 08082f3..419db34 100644 --- a/drivers/mtd/onenand/onenand_uboot.c +++ b/drivers/mtd/onenand/onenand_uboot.c @@ -31,6 +31,8 @@ void onenand_init(void)
onenand_scan(&onenand_mtd, 1);
+ if (onenand_chip.device_id & DEVICE_IS_FLEXONENAND) + puts("Flex-"); puts("OneNAND: "); - print_size(onenand_mtd.size, "\n"); + print_size(onenand_chip.chipsize, "\n"); } diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index 4467c2b..a1bb0fd 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -20,6 +20,7 @@ #include <linux/mtd/compat.h> #include <linux/mtd/bbm.h>
+#define MAX_DIES 2 #define MAX_BUFFERRAM 2 #define MAX_ONENAND_PAGESIZE (2048 + 64)
@@ -43,8 +44,13 @@ struct onenand_bufferram { /** * struct onenand_chip - OneNAND Private Flash Chip Data * @param base [BOARDSPECIFIC] address to access OneNAND + * @dies: [INTERN][FLEXONENAND] number of dies on chip + * @boundary: [INTERN][FLEXONENAND] Boundary of the dies + * @diesize: [INTERN][FLEXONENAND] Size of the dies * @param chipsize [INTERN] the size of one chip for multichip arrays * @param device_id [INTERN] device ID + * @technology [INTERN] describes the internal NAND array technology such as SLC or MLC. + * @density_mask: [INTERN] chip density, used for DDP devices * @param verstion_id [INTERN] version ID * @param options [BOARDSPECIFIC] various chip options. They can partly be set to inform onenand_scan about * @param erase_shift [INTERN] number of address bits in a block @@ -68,8 +74,13 @@ struct onenand_bufferram { */ struct onenand_chip { void __iomem *base; + unsigned int dies; + unsigned int boundary[MAX_DIES]; + unsigned int diesize[MAX_DIES]; unsigned int chipsize; unsigned int device_id; + unsigned int technology; + unsigned int density_mask; unsigned int options;
unsigned int erase_shift; @@ -117,6 +128,8 @@ struct onenand_chip { #define ONENAND_SET_BUFFERRAM0(this) (this->bufferram_index = 0) #define ONENAND_SET_BUFFERRAM1(this) (this->bufferram_index = 1)
+#define FLEXONENAND(this) (this->device_id & DEVICE_IS_FLEXONENAND) +#define ONENAND_IS_MLC(this) (this->technology & ONENAND_TECHNOLOGY_IS_MLC) #define ONENAND_IS_DDP(this) \ (this->device_id & ONENAND_DEVICE_IS_DDP)
@@ -148,4 +161,6 @@ struct onenand_manufacturers { int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, struct mtd_oob_ops *ops);
+unsigned onenand_get_block(struct onenand_chip *this, loff_t addr, + unsigned *isblkslc); #endif /* __LINUX_MTD_ONENAND_H */ diff --git a/include/linux/mtd/onenand_regs.h b/include/linux/mtd/onenand_regs.h index a245e14..34977dc 100644 --- a/include/linux/mtd/onenand_regs.h +++ b/include/linux/mtd/onenand_regs.h @@ -67,6 +67,9 @@ /* * Device ID Register F001h (R) */ +#define DEVICE_IS_FLEXONENAND (1 << 9) +#define FLEXONENAND_PI_MASK (0x3ff) +#define FLEXONENAND_PI_UNLOCK_SHIFT (14) #define ONENAND_DEVICE_DENSITY_MASK (0xf) #define ONENAND_DEVICE_DENSITY_SHIFT (4) #define ONENAND_DEVICE_IS_DDP (1 << 3) @@ -84,6 +87,11 @@ #define ONENAND_VERSION_PROCESS_SHIFT (8)
/* + * Technology Register F006h (R) + */ +#define ONENAND_TECHNOLOGY_IS_MLC (1 << 0) + +/* * Start Address 1 F100h (R/W) */ #define ONENAND_DDP_SHIFT (15) @@ -93,7 +101,7 @@ /* * Start Address 8 F107h (R/W) */ -#define ONENAND_FPA_MASK (0x3f) +#define ONENAND_FPA_MASK (0x7f) #define ONENAND_FPA_SHIFT (2) #define ONENAND_FSA_MASK (0x03)
@@ -105,7 +113,7 @@ #define ONENAND_BSA_BOOTRAM (0 << 2) #define ONENAND_BSA_DATARAM0 (2 << 2) #define ONENAND_BSA_DATARAM1 (3 << 2) -#define ONENAND_BSC_MASK (0x03) +#define ONENAND_BSC_MASK (0x07)
/* * Command Register F220h (R/W) @@ -122,9 +130,14 @@ #define ONENAND_CMD_ERASE (0x94) #define ONENAND_CMD_RESET (0xF0) #define ONENAND_CMD_READID (0x90) +#define FLEXONENAND_CMD_RESET (0xF3) +#define FLEXONENAND_CMD_PI_UPDATE (0x05) +#define FLEXONENAND_CMD_PI_ACCESS (0x66) +#define FLEXONENAND_CMD_RECOVER_LSB (0x05)
/* NOTE: Those are not *REAL* commands */ #define ONENAND_CMD_BUFFERRAM (0x1978) +#define FLEXONENAND_CMD_READ_PI (0x1985)
/* * System Configuration 1 Register F221h (R, R/W) @@ -185,5 +198,6 @@ #define ONENAND_ECC_1BIT (1 << 0) #define ONENAND_ECC_2BIT (1 << 1) #define ONENAND_ECC_2BIT_ALL (0xAAAA) +#define FLEXONENAND_UNCORRECTABLE_ERROR (0x1010)
#endif /* __ONENAND_REG_H */ diff --git a/include/onenand_uboot.h b/include/onenand_uboot.h index e960257..53754ba 100644 --- a/include/onenand_uboot.h +++ b/include/onenand_uboot.h @@ -21,6 +21,7 @@ struct mtd_info; struct erase_info;
extern struct mtd_info onenand_mtd; +extern struct onenand_chip onenand_chip;
/* Functions */ extern void onenand_init(void); @@ -36,4 +37,13 @@ extern int onenand_unlock(struct mtd_info *mtd, loff_t ofs, size_t len);
extern char *onenand_print_device_info(int device);
+extern unsigned onenand_get_block(struct onenand_chip *this, loff_t addr, + unsigned *isblkslc); + +extern loff_t onenand_get_addr(struct onenand_chip *this, int block); + +extern int flexonenand_region(struct mtd_info *mtd, loff_t addr); + +extern int flexonenand_set_boundary(struct mtd_info *mtd, int die, + int boundary, int lock); #endif /* __UBOOT_ONENAND_H */
Patch does not apply to u-boot-nand-flash/next (the master branch is for 2008.12 bugfixes only).
It's looking a lot better (though I'm not familiar enough with this hardware to comment on the functional bits), though while you're rebasing, I have some style nits:
- unsigned boundary, blk, die = 0;
"unsigned int"
Compiler should be able to figure out inlines by itself.
- int i;
- for (i = 0; i < mtd->numeraseregions &&
Align the continuation line with "i = 0", making it distinct from the if-body.
Move the addr >= mtd->eraseregions[i].offset test into the if-body, for readability.
- i--;
- return i;
Just return i - 1.
if (ret) ret = onenand_recover_lsb(mtd, from, ret);
The ?: usually decreases readability rather than increases it; it's best to avoid unless using it would eliminate duplication or a temporary variable.
- for (block = start; block < end + 1; block++) {
block <= end
if ((bdry >> FLEXONENAND_PI_UNLOCK_SHIFT) == 3) locked = 0; else locked = 1;
- eraseshift = this->erase_shift - 1;
- mtd->numeraseregions = this->dies << 1;
Only one blank line.
- mtd->erasesize = 1 << (this->erase_shift);
Unnecessary parens.
-Scott
Sorries for the delay
rebased to next branch.
Thanks, Rohit
Signed-off-by: Rohit Hagargundgi <h.rohit at samsung.com> --- drivers/mtd/onenand/onenand_base.c | 718 +++++++++++++++++++++++++++++++----- drivers/mtd/onenand/onenand_bbt.c | 14 drivers/mtd/onenand/onenand_uboot.c | 4 include/linux/mtd/onenand.h | 16 include/linux/mtd/onenand_regs.h | 18 include/onenand_uboot.h | 10 6 files changed, 680 insertions(+), 100 deletions(-)
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index d482437..e4d4a47 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -37,6 +37,27 @@ static inline void *memcpy_16(void *dst, const void *src, unsigned int len) }
/** + * onenand_oob_128 - oob info for Flex-Onenand with 4KB page + * For now, we expose only 64 out of 80 ecc bytes + */ +static struct nand_ecclayout onenand_oob_128 = { + .eccbytes = 64, + .eccpos = { + 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, + 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, + 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, + 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, + 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, + 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, + 102, 103, 104, 105 + }, + .oobfree = { + {2, 4}, {18, 4}, {34, 4}, {50, 4}, + {66, 4}, {82, 4}, {98, 4}, {114, 4} + } +}; + +/** * onenand_oob_64 - oob info for large (2KB) page */ static struct nand_ecclayout onenand_oob_64 = { @@ -74,6 +95,14 @@ static const unsigned char ffchars[] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 48 */ 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 64 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 80 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 96 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 112 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 128 */ };
/** @@ -180,6 +209,84 @@ static int onenand_buffer_address(int dataram1, int sectors, int count) }
/** + * flexonenand_block - Return block number for flash address + * @param this - OneNAND device structure + * @param addr - Address for which block number is needed + */ +static unsigned int flexonenand_block(struct onenand_chip *this, loff_t addr) +{ + unsigned int boundary, blk, die = 0; + + if (ONENAND_IS_DDP(this) && addr >= this->diesize[0]) { + die = 1; + addr -= this->diesize[0]; + } + + boundary = this->boundary[die]; + + blk = addr >> (this->erase_shift - 1); + if (blk > boundary) + blk = (blk + boundary + 1) >> 1; + + blk += die ? this->density_mask : 0; + return blk; +} + +inline unsigned int onenand_block(struct onenand_chip *this, loff_t addr) +{ + if (!FLEXONENAND(this)) + return addr >> this->erase_shift; + return flexonenand_block(this, addr); +} + +/** + * flexonenand_addr - Return address of the block + * @this: OneNAND device structure + * @block: Block number on Flex-OneNAND + * + * Return address of the block + */ +static loff_t flexonenand_addr(struct onenand_chip *this, int block) +{ + loff_t ofs = 0; + int die = 0, boundary; + + if (ONENAND_IS_DDP(this) && block >= this->density_mask) { + block -= this->density_mask; + die = 1; + ofs = this->diesize[0]; + } + + boundary = this->boundary[die]; + ofs += block << (this->erase_shift - 1); + if (block > (boundary + 1)) + ofs += (block - boundary - 1) << (this->erase_shift - 1); + return ofs; +} + +inline loff_t onenand_addr(struct onenand_chip *this, int block) +{ + if (!FLEXONENAND(this)) + return block << this->erase_shift; + return flexonenand_addr(this, block); +} + +/** + * flexonenand_region - [Flex-OneNAND] Return erase region of addr + * @param mtd MTD device structure + * @param addr address whose erase region needs to be identified + */ +int flexonenand_region(struct mtd_info *mtd, loff_t addr) +{ + int i; + + for (i = 0; i < mtd->numeraseregions; i++) + if (addr < mtd->eraseregions[i].offset) + break; + return i - 1; +} + +/** * onenand_get_density - [DEFAULT] Get OneNAND density * @param dev_id OneNAND device ID * @@ -205,10 +312,11 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, size_t len) { struct onenand_chip *this = mtd->priv; - int value, readcmd = 0; + int value; int block, page; + /* Now we use page size operation */ - int sectors = 4, count = 4; + int sectors = 0, count = 0;
/* Address translation */ switch (cmd) { @@ -220,15 +328,27 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, page = -1; break;
+ case FLEXONENAND_CMD_PI_ACCESS: + /* addr contains die index */ + block = addr * this->density_mask; + page = -1; + break; + case ONENAND_CMD_ERASE: case ONENAND_CMD_BUFFERRAM: - block = (int)(addr >> this->erase_shift); + block = onenand_block(this, addr); page = -1; break;
+ case FLEXONENAND_CMD_READ_PI: + cmd = ONENAND_CMD_READ; + block = addr * this->density_mask; + page = 0; + break; + default: - block = (int)(addr >> this->erase_shift); - page = (int)(addr >> this->page_shift); + block = onenand_block(this, addr); + page = (int) (addr - onenand_addr(this, block)) >> this->page_shift; page &= this->page_mask; break; } @@ -240,8 +360,11 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, this->write_word(value, this->base + ONENAND_REG_START_ADDRESS2);
return 0; } @@ -252,7 +375,7 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, this->write_word(value, this->base + ONENAND_REG_START_ADDRESS1);
- /* Write 'DFS, FBA' of Flash */ + /* Select DataRAM for DDP */ value = onenand_bufferram_address(this, block); this->write_word(value, this->base + ONENAND_REG_START_ADDRESS2); @@ -262,10 +385,14 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, int dataram;
switch (cmd) { + case FLEXONENAND_CMD_RECOVER_LSB: case ONENAND_CMD_READ: case ONENAND_CMD_READOOB: - dataram = ONENAND_SET_NEXT_BUFFERRAM(this); - readcmd = 1; + if (ONENAND_IS_MLC(this)) + dataram = ONENAND_SET_BUFFERRAM0(this); + else + dataram = ONENAND_SET_NEXT_BUFFERRAM(this); + break;
default: @@ -292,6 +419,28 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, }
/** + * onenand_read_ecc - return ecc status + * @param this onenand chip structure + */ +static inline int onenand_read_ecc(struct onenand_chip *this) +{ + int ecc, i; + + if (!FLEXONENAND(this)) + return this->read_word(this->base + ONENAND_REG_ECC_STATUS); + + for (i = 0; i < 4; i++) { + ecc = this->read_word(this->base + ((ONENAND_REG_ECC_STATUS + i) << 1)); + if (likely(!ecc)) + continue; + if (ecc & FLEXONENAND_UNCORRECTABLE_ERROR) + return ONENAND_ECC_2BIT_ALL; + } + + return 0; +} + +/** * onenand_wait - [DEFAULT] wait until the command is done * @param mtd MTD device structure * @param state state to select the max. timeout value @@ -305,7 +454,7 @@ static int onenand_wait(struct mtd_info *mtd, int state) struct onenand_chip *this = mtd->priv; unsigned int flags = ONENAND_INT_MASTER; unsigned int interrupt = 0; - unsigned int ctrl, ecc; + unsigned int ctrl;
while (1) { interrupt = this->read_word(this->base + ONENAND_REG_INTERRUPT); @@ -315,6 +464,14 @@ static int onenand_wait(struct mtd_info *mtd, int state)
+ if (interrupt & ONENAND_INT_READ) { + int ecc = onenand_read_ecc(this); + if (ecc & ONENAND_ECC_2BIT_ALL) { + printk("onenand_wait: ECC error = 0x%04x\n", ecc); + return -EBADMSG; + } + } + if (ctrl & ONENAND_CTRL_ERROR) { printk("onenand_wait: controller error = 0x%04x\n", ctrl); if (ctrl & ONENAND_CTRL_LOCK) @@ -324,14 +481,6 @@ static int onenand_wait(struct mtd_info *mtd, int state) return -EIO; }
return 0; } @@ -499,7 +648,7 @@ static int onenand_check_bufferram(struct mtd_info *mtd, loff_t addr)
if (found && ONENAND_IS_DDP(this)) { /* Select DataRAM for DDP */ - int block = (int) (addr >> this->erase_shift); + int block = onenand_block(this, addr); int value = onenand_bufferram_address(this, block); this->write_word(value, this->base + ONENAND_REG_START_ADDRESS2); } @@ -632,6 +781,44 @@ static int onenand_transfer_auto_oob(struct mtd_info *mtd, uint8_t *buf, }
/** + * onenand_recover_lsb - [Flex-OneNAND] Recover LSB page data + * @param mtd MTD device structure + * @param addr address to recover + * @param status return value from onenand_wait + * + * MLC NAND Flash cell has paired pages - LSB page and MSB page. LSB page has + * lower page address and MSB page has higher page address in paired pages. + * If power off occurs during MSB page program, the paired LSB page data can + * become corrupt. LSB page recovery read is a way to read LSB page though page + * data are corrupted. When uncorrectable error occurs as a result of LSB page + * read after power up, issue LSB page recovery read. + */ +static int onenand_recover_lsb(struct mtd_info *mtd, loff_t addr, int status) +{ + struct onenand_chip *this = mtd->priv; + int i; + + /* Recovery is only for Flex-OneNAND */ + if (!FLEXONENAND(this)) + return status; + + /* check if we failed due to uncorrectable error */ + if (status != -EBADMSG && status != ONENAND_BBT_READ_ECC_ERROR) + return status; + + /* check if address lies in MLC region */ + i = flexonenand_region(mtd, addr); + if (mtd->eraseregions[i].erasesize < (1 << this->erase_shift)) + return status; + + printk("onenand_recover_lsb: Attempting to recover from uncorrectable read\n"); + + /* Issue the LSB page recovery command */ + this->command(mtd, FLEXONENAND_CMD_RECOVER_LSB, addr, this->writesize); + return this->wait(mtd, FL_READING); +} + +/** * onenand_read_ops_nolock - [OneNAND Interface] OneNAND read main and/or out-of-band * @param mtd MTD device structure * @param from offset to read from @@ -673,6 +860,7 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, stats = mtd->ecc_stats;
/* Do first load to bufferRAM */ if (read < len) { @@ -680,6 +868,8 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, this->main_buf = buf; this->command(mtd, ONENAND_CMD_READ, from, writesize); ret = this->wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); onenand_update_bufferram(mtd, from, !ret); if (ret == -EBADMSG) ret = 0; @@ -694,7 +884,7 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, while (!ret) { /* If there is more to load then start next load */ from += thislen; - if (read + thislen < len) { + if (!ONENAND_IS_MLC(this) && read + thislen < len) { this->main_buf = buf + thislen; this->command(mtd, ONENAND_CMD_READ, from, writesize); /* @@ -728,6 +918,16 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, oobcolumn = 0; }
+ if (ONENAND_IS_MLC(this) && (read + thislen < len)) { + this->command(mtd, ONENAND_CMD_READ, from, writesize); + ret = this->wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); + onenand_update_bufferram(mtd, from, !ret); + if (ret == -EBADMSG) + ret = 0; + } + /* See if we are done */ read += thislen; if (read == len) @@ -735,16 +935,19 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, /* Set up for next read from bufferRAM */ if (unlikely(boundary)) this->write_word(ONENAND_DDP_CHIP1, this->base + ONENAND_REG_START_ADDRESS2); - ONENAND_SET_NEXT_BUFFERRAM(this); + if (!ONENAND_IS_MLC(this)) + ONENAND_SET_NEXT_BUFFERRAM(this); buf += thislen; thislen = min_t(int, writesize, len - read); column = 0;
/* @@ -781,7 +984,7 @@ static int onenand_read_oob_nolock(struct mtd_info *mtd, loff_t from, size_t len = ops->ooblen; mtd_oob_mode_t mode = ops->mode; u_char *buf = ops->oobbuf; - int ret = 0; + int ret = 0, readcmd;
@@ -812,16 +1015,21 @@ static int onenand_read_oob_nolock(struct mtd_info *mtd, loff_t from,
this->spare_buf = buf; - this->command(mtd, ONENAND_CMD_READOOB, from, mtd->oobsize); + this->command(mtd, readcmd, from, mtd->oobsize);
ret = this->wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); + if (ret && ret != -EBADMSG) { printk(KERN_ERR "onenand_read_oob_nolock: read failed = 0x%x\n", ret); break; @@ -945,9 +1153,12 @@ static int onenand_bbt_wait(struct mtd_info *mtd, int state) ctrl = this->read_word(this->base + ONENAND_REG_CTRL_STATUS);
if (interrupt & ONENAND_INT_READ) { - int ecc = this->read_word(this->base + ONENAND_REG_ECC_STATUS); - if (ecc & ONENAND_ECC_2BIT_ALL) + int ecc = onenand_read_ecc(this); + if (ecc & ONENAND_ECC_2BIT_ALL) { + printk(KERN_INFO "onenand_bbt_wait: ecc error = 0x%04x" + ", controller = 0x%04x\n", ecc, ctrl); return ONENAND_BBT_READ_ERROR; + } } else { printk(KERN_ERR "onenand_bbt_wait: read timeout!" "ctrl=0x%04x intr=0x%04x\n", ctrl, interrupt); @@ -976,12 +1187,14 @@ int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, { struct onenand_chip *this = mtd->priv; int read = 0, thislen, column; - int ret = 0; + int ret = 0, readcmd; size_t len = ops->ooblen; u_char *buf = ops->oobbuf;
MTDDEBUG(MTD_DEBUG_LEVEL3, "onenand_bbt_read_oob: from = 0x%08x, len = %zi\n", (unsigned int) from, len);
@@ -1002,11 +1215,14 @@ int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, thislen = min_t(int, thislen, len);
ret = this->bbt_wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); + if (ret) break;
@@ -1044,9 +1260,11 @@ static int onenand_verify_oob(struct mtd_info *mtd, const u_char *buf, loff_t to { struct onenand_chip *this = mtd->priv; u_char *oob_buf = this->oob_buf; - int status, i; + int status, i, readcmd; + + readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB;
- this->command(mtd, ONENAND_CMD_READOOB, to, mtd->oobsize); + this->command(mtd, readcmd, to, mtd->oobsize); onenand_update_bufferram(mtd, to, 0); status = this->wait(mtd, FL_READING); if (status) @@ -1291,7 +1509,7 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to, { struct onenand_chip *this = mtd->priv; int column, ret = 0, oobsize; - int written = 0; + int written = 0, oobcmd; u_char *oobbuf; size_t len = ops->ooblen; const u_char *buf = ops->oobbuf; @@ -1333,6 +1551,8 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to,
+ oobcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_PROG : ONENAND_CMD_PROGOOB; + /* Loop until all data write */ while (written < len) { int thislen = min_t(int, oobsize, len - written); @@ -1348,7 +1568,14 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to, memcpy(oobbuf + column, buf, thislen); this->write_bufferram(mtd, 0, ONENAND_SPARERAM, oobbuf, 0, mtd->oobsize);
- this->command(mtd, ONENAND_CMD_PROGOOB, to, mtd->oobsize); + if (ONENAND_IS_MLC(this)) { + /* Set main area of DataRAM to 0xff*/ + memset(this->page_buf, 0xff, mtd->writesize); + this->write_bufferram(mtd, 0, ONENAND_DATARAM, + this->page_buf, 0, mtd->writesize); + } + + this->command(mtd, oobcmd, to, mtd->oobsize);
onenand_update_bufferram(mtd, to, 0); if (ONENAND_IS_2PLANE(this)) { @@ -1475,34 +1702,50 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) { struct onenand_chip *this = mtd->priv; unsigned int block_size; - loff_t addr; - int len; - int ret = 0; - - MTDDEBUG (MTD_DEBUG_LEVEL3, - "onenand_erase: start = 0x%08x, len = %i\n", - (unsigned int)instr->addr, (unsigned int)instr->len); + loff_t addr = instr->addr; + unsigned int len = instr->len; + int ret = 0, i; + struct mtd_erase_region_info *region = NULL; + unsigned int region_end = 0;
- /* Length must align on block boundary */ - if (unlikely(instr->len & (block_size - 1))) { - MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_erase: Length not block aligned\n"); - return -EINVAL; + if (FLEXONENAND(this)) { + /* Find the eraseregion of this address */ + i = flexonenand_region(mtd, addr); + region = &mtd->eraseregions[i]; + + block_size = region->erasesize; + region_end = region->offset + region->erasesize * region->numblocks; + + /* Start address within region must align on block boundary. + * Erase region's start offset is always block start address. + */ + if (unlikely((addr - region->offset) & (block_size - 1))) { + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: Unaligned address\n"); + return -EINVAL; + } + } else { + block_size = 1 << this->erase_shift; + + /* Start address must align on block boundary */ + if (unlikely(addr & (block_size - 1))) { + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: Unaligned address\n"); + return -EINVAL; + } }
@@ -1512,9 +1755,6 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) onenand_get_device(mtd, FL_ERASING);
while (len) { @@ -1541,14 +1781,7 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) else MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: " "Failed erase, block %d\n", - (unsigned)(addr >> this->erase_shift)); - if (ret == -EPERM) - printk("onenand_erase: " - "Device is write protected!!!\n"); - else - printk("onenand_erase: " - "Failed erase, block %d\n", - (unsigned)(addr >> this->erase_shift)); + onenand_block(this, addr)); instr->state = MTD_ERASE_FAILED; instr->fail_addr = addr;
@@ -1557,6 +1790,21 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr)
len -= block_size; addr += block_size; + + if (addr == region_end) { + if (!len) + break; + region++; + + block_size = region->erasesize; + region_end = region->offset + region->erasesize * region->numblocks; + + if (len & (block_size - 1)) { + /* This has been checked at MTD partitioning level. */ + printk(KERN_ERR "onenand_erase: Unaligned address\n"); + goto erase_exit; + } + } }
instr->state = MTD_ERASE_DONE; @@ -1634,7 +1882,7 @@ static int onenand_default_block_markbad(struct mtd_info *mtd, loff_t ofs) int block;
/* Get block number */ - block = ((int) ofs) >> bbm->bbt_erase_shift; + block = onenand_block(this, ofs); if (bbm->bbt) bbm->bbt[block >> 2] |= 0x01 << ((block & 0x03) << 1);
@@ -1682,8 +1930,8 @@ static int onenand_do_lock_cmd(struct mtd_info *mtd, loff_t ofs, size_t len, int int start, end, block, value, status; int wp_status_mask;
- start = ofs >> this->erase_shift; - end = len >> this->erase_shift; + start = onenand_block(this, ofs); + end = onenand_block(this, ofs + len);
if (cmd == ONENAND_CMD_LOCK) wp_status_mask = ONENAND_WP_LS; @@ -1718,7 +1966,7 @@ static int onenand_do_lock_cmd(struct mtd_info *mtd, loff_t ofs, size_t len, int }
/* Block lock scheme */ - for (block = start; block < start + end; block++) { + for (block = start; block < end; block++) { /* Set block address */ value = onenand_block_address(this, block); this->write_word(value, this->base + ONENAND_REG_START_ADDRESS1); @@ -1831,7 +2079,7 @@ static void onenand_unlock_all(struct mtd_info *mtd) { struct onenand_chip *this = mtd->priv; loff_t ofs = 0; - size_t len = this->chipsize; + size_t len = mtd->size;
if (this->options & ONENAND_HAS_UNLOCK_ALL) { /* Set start block address */ @@ -1847,14 +2095,12 @@ static void onenand_unlock_all(struct mtd_info *mtd) & ONENAND_CTRL_ONGO) continue;
- return; - /* Check lock status */ if (onenand_check_lock_status(this)) return;
/* Workaround for all block unlock in DDP */ - if (ONENAND_IS_DDP(this)) { + if (ONENAND_IS_DDP(this) && !FLEXONENAND(this)) { /* All blocks on another chip */ ofs = this->chipsize >> 1; len = this->chipsize >> 1; @@ -1906,6 +2152,14 @@ static void onenand_check_features(struct mtd_info *mtd) break; }
+ if (ONENAND_IS_MLC(this)) + this->options &= ~ONENAND_HAS_2PLANE; + + if (FLEXONENAND(this)) { + this->options &= ~ONENAND_HAS_CONT_LOCK; + this->options |= ONENAND_HAS_UNLOCK_ALL; + } + if (this->options & ONENAND_HAS_CONT_LOCK) printk(KERN_DEBUG "Lock scheme is Continuous Lock\n"); if (this->options & ONENAND_HAS_UNLOCK_ALL) @@ -1922,16 +2176,18 @@ static void onenand_check_features(struct mtd_info *mtd) */ char *onenand_print_device_info(int device, int version) { - int vcc, demuxed, ddp, density; + int vcc, demuxed, ddp, density, flexonenand; char *dev_info = malloc(80); char *p = dev_info;
vcc = device & ONENAND_DEVICE_VCC_MASK; demuxed = device & ONENAND_DEVICE_IS_DEMUX; ddp = device & ONENAND_DEVICE_IS_DDP; - density = device >> ONENAND_DEVICE_DENSITY_SHIFT; - p += sprintf(dev_info, "%sOneNAND%s %dMB %sV 16-bit (0x%02x)", + density = onenand_get_density(device); + flexonenand = device & DEVICE_IS_FLEXONENAND; + p += sprintf(dev_info, "%s%sOneNAND%s %dMB %sV 16-bit (0x%02x)", demuxed ? "" : "Muxed ", + flexonenand ? "Flex-" : "", ddp ? "(DDP)" : "", (16 << density), vcc ? "2.65/3.3" : "1.8", device);
@@ -1957,7 +2213,7 @@ static int onenand_check_maf(int manuf) char *name; int i;
- for (i = 0; size; i++) + for (i = 0; i < size; i++) if (manuf == onenand_manuf_ids[i].id) break;
@@ -1974,6 +2230,258 @@ static int onenand_check_maf(int manuf) }
/** +* flexonenand_get_boundary - Reads the SLC boundary +* @param onenand_info - onenand info structure +* +* Fill up boundary[] field in onenand_chip +**/ +static int flexonenand_get_boundary(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + unsigned int die, bdry; + int ret, syscfg, locked; + + /* Disable ECC */ + syscfg = this->read_word(this->base + ONENAND_REG_SYS_CFG1); + this->write_word((syscfg | 0x0100), this->base + ONENAND_REG_SYS_CFG1); + + for (die = 0; die < this->dies; die++) { + this->command(mtd, FLEXONENAND_CMD_PI_ACCESS, die, 0); + this->wait(mtd, FL_SYNCING); + + this->command(mtd, FLEXONENAND_CMD_READ_PI, die, 0); + ret = this->wait(mtd, FL_READING); + + bdry = this->read_word(this->base + ONENAND_DATARAM); + if ((bdry >> FLEXONENAND_PI_UNLOCK_SHIFT) == 3) + locked = 0; + else + locked = 1; + this->boundary[die] = bdry & FLEXONENAND_PI_MASK; + + this->command(mtd, ONENAND_CMD_RESET, 0, 0); + ret = this->wait(mtd, FL_RESETING); + + printk(KERN_INFO "Die %d boundary: %d%s\n", die, + this->boundary[die], locked ? "(Locked)" : "(Unlocked)"); + } + + /* Enable ECC */ + this->write_word(syscfg, this->base + ONENAND_REG_SYS_CFG1); + return 0; +} + +/** + * flexonenand_get_size - Fill up fields in onenand_chip and mtd_info + * boundary[], diesize[], mtd->size, mtd->erasesize, + * mtd->eraseregions + * @param mtd - MTD device structure + */ +static void flexonenand_get_size(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + int die, ofs, i, eraseshift, density; + int blksperdie, maxbdry; + + density = onenand_get_density(this->device_id); + blksperdie = ((16 << density) << 20) >> (this->erase_shift); + blksperdie >>= ONENAND_IS_DDP(this) ? 1 : 0; + maxbdry = blksperdie - 1; + eraseshift = this->erase_shift - 1; + + mtd->numeraseregions = this->dies << 1; + + /* This fills up the device boundary */ + flexonenand_get_boundary(mtd); + die = ofs = 0; + i = -1; + for (; die < this->dies; die++) { + if (!die || this->boundary[die-1] != maxbdry) { + i++; + mtd->eraseregions[i].offset = ofs; + mtd->eraseregions[i].erasesize = 1 << eraseshift; + mtd->eraseregions[i].numblocks = + this->boundary[die] + 1; + ofs += mtd->eraseregions[i].numblocks << eraseshift; + eraseshift++; + } else { + mtd->numeraseregions -= 1; + mtd->eraseregions[i].numblocks += + this->boundary[die] + 1; + ofs += (this->boundary[die] + 1) << (eraseshift - 1); + } + if (this->boundary[die] != maxbdry) { + i++; + mtd->eraseregions[i].offset = ofs; + mtd->eraseregions[i].erasesize = 1 << eraseshift; + mtd->eraseregions[i].numblocks = maxbdry ^ + this->boundary[die]; + ofs += mtd->eraseregions[i].numblocks << eraseshift; + eraseshift--; + } else + mtd->numeraseregions -= 1; + } + + /* Expose MLC erase size except when all blocks are SLC */ + mtd->erasesize = 1 << this->erase_shift; + if (mtd->numeraseregions == 1) + mtd->erasesize >>= 1; + + printk(KERN_INFO "Device has %d eraseregions\n", mtd->numeraseregions); + for (i = 0; i < mtd->numeraseregions; i++) + printk(KERN_INFO "[offset: 0x%08x, erasesize: 0x%05x," + " numblocks: %04u]\n", mtd->eraseregions[i].offset, + mtd->eraseregions[i].erasesize, + mtd->eraseregions[i].numblocks); + + for (die = 0, mtd->size = 0; die < this->dies; die++) { + this->diesize[die] = (blksperdie << this->erase_shift); + this->diesize[die] -= (this->boundary[die] + 1) + << (this->erase_shift - 1); + mtd->size += this->diesize[die]; + } +} + +/** + * flexonenand_check_blocks_erased - Check if blocks are erased + * @param mtd_info - mtd info structure + * @param start - first erase block to check + * @param end - last erase block to check + * + * Converting an unerased block from MLC to SLC + * causes byte values to change. Since both data and its ECC + * have changed, reads on the block give uncorrectable error. + * This might lead to the block being detected as bad. + * + * Avoid this by ensuring that the block to be converted is + * erased. + */ +static int flexonenand_check_blocks_erased(struct mtd_info *mtd, int start, int end) +{ + struct onenand_chip *this = mtd->priv; + int i, ret; + int block; + struct mtd_oob_ops ops = { + .mode = MTD_OOB_PLACE, + .ooboffs = 0, + .ooblen = mtd->oobsize, + .datbuf = NULL, + .oobbuf = this->oob_buf, + }; + loff_t addr; + + printk(KERN_DEBUG "Check blocks from %d to %d\n", start, end); + + for (block = start; block <= end; block++) { + addr = flexonenand_addr(this, block); + if (onenand_block_isbad_nolock(mtd, addr, 0)) + continue; + + /* + * Since main area write results in ECC write to spare, + * it is sufficient to check only ECC bytes for change. + */ + ret = onenand_read_oob_nolock(mtd, addr, &ops); + if (ret) + return ret; + + for (i = 0; i < mtd->oobsize; i++) + if (this->oob_buf[i] != 0xff) + break; + + if (i != mtd->oobsize) { + printk(KERN_WARNING "Block %d not erased.\n", block); + return 1; + } + } + + return 0; +} + +/** + * flexonenand_set_boundary - Writes the SLC boundary + * @param mtd - mtd info structure + */ +int flexonenand_set_boundary(struct mtd_info *mtd, int die, + int boundary, int lock) +{ + struct onenand_chip *this = mtd->priv; + int ret, density, blksperdie, old, new, thisboundary; + loff_t addr; + + if (die >= this->dies) + return -EINVAL; + + if (boundary == this->boundary[die]) + return 0; + + density = onenand_get_density(this->device_id); + blksperdie = ((16 << density) << 20) >> this->erase_shift; + blksperdie >>= ONENAND_IS_DDP(this) ? 1 : 0; + + if (boundary >= blksperdie) { + printk(KERN_ERR "flexonenand_set_boundary: Invalid boundary value. " + "Boundary not changed.\n"); + return -EINVAL; + } + + /* Check if converting blocks are erased */ + old = this->boundary[die] + (die * this->density_mask); + new = boundary + (die * this->density_mask); + ret = flexonenand_check_blocks_erased(mtd, min(old, new) + 1, max(old, new)); + if (ret) { + printk(KERN_ERR "flexonenand_set_boundary: Please erase blocks before boundary change\n"); + return ret; + } + + this->command(mtd, FLEXONENAND_CMD_PI_ACCESS, die, 0); + this->wait(mtd, FL_SYNCING); + + /* Check is boundary is locked */ + this->command(mtd, FLEXONENAND_CMD_READ_PI, die, 0); + ret = this->wait(mtd, FL_READING); + + thisboundary = this->read_word(this->base + ONENAND_DATARAM); + if ((thisboundary >> FLEXONENAND_PI_UNLOCK_SHIFT) != 3) { + printk(KERN_ERR "flexonenand_set_boundary: boundary locked\n"); + goto out; + } + + printk(KERN_INFO "flexonenand_set_boundary: Changing die %d boundary: %d%s\n", + die, boundary, lock ? "(Locked)" : "(Unlocked)"); + + boundary &= FLEXONENAND_PI_MASK; + boundary |= lock ? 0 : (3 << FLEXONENAND_PI_UNLOCK_SHIFT); + + addr = die ? this->diesize[0] : 0; + this->command(mtd, ONENAND_CMD_ERASE, addr, 0); + ret = this->wait(mtd, FL_ERASING); + if (ret) { + printk(KERN_ERR "flexonenand_set_boundary: Failed PI erase for Die %d\n", die); + goto out; + } + + this->write_word(boundary, this->base + ONENAND_DATARAM); + this->command(mtd, ONENAND_CMD_PROG, addr, 0); + ret = this->wait(mtd, FL_WRITING); + if (ret) { + printk(KERN_ERR "flexonenand_set_boundary: Failed PI write for Die %d\n", die); + goto out; + } + + this->command(mtd, FLEXONENAND_CMD_PI_UPDATE, die, 0); + ret = this->wait(mtd, FL_WRITING); +out: + this->write_word(ONENAND_CMD_RESET, this->base + ONENAND_REG_COMMAND); + this->wait(mtd, FL_RESETING); + if (!ret) + /* Recalculate device size on boundary change*/ + flexonenand_get_size(mtd); + + return ret; +} + +/** * onenand_probe - [OneNAND Interface] Probe the OneNAND device * @param mtd MTD device structure * @@ -2016,48 +2524,69 @@ static int onenand_probe(struct mtd_info *mtd) maf_id = this->read_word(this->base + ONENAND_REG_MANUFACTURER_ID); dev_id = this->read_word(this->base + ONENAND_REG_DEVICE_ID); ver_id = this->read_word(this->base + ONENAND_REG_VERSION_ID); + this->technology = this->read_word(this->base + ONENAND_REG_TECHNOLOGY);
- /* FIXME : Current OneNAND MTD doesn't support Flex-OneNAND */ - if (dev_id & (1 << 9)) { - printk("Not yet support Flex-OneNAND\n"); - return -ENXIO; - } - /* Flash device information */ mtd->name = onenand_print_device_info(dev_id, ver_id); this->device_id = dev_id; this->version_id = ver_id;
density = onenand_get_density(dev_id); + if (FLEXONENAND(this)) { + this->dies = ONENAND_IS_DDP(this) ? 2 : 1; + /* Maximum possible erase regions */ + mtd->numeraseregions = this->dies << 1; + mtd->eraseregions = malloc(sizeof(struct mtd_erase_region_info) + * (this->dies << 1)); + if (!mtd->eraseregions) + return -ENOMEM; + } + + /* + * For Flex-OneNAND, chipsize represents maximum possible device size. + * mtd->size represents the actual device size. + */ this->chipsize = (16 << density) << 20; - /* Set density mask. it is used for DDP */ - if (ONENAND_IS_DDP(this)) - this->density_mask = (1 << (density + 6)); - else - this->density_mask = 0;
/* OneNAND page size & block size */ /* The data buffer size is equal to page size */ mtd->writesize = this->read_word(this->base + ONENAND_REG_DATA_BUFFER_SIZE); + /* We use the full BufferRAM */ + if (ONENAND_IS_MLC(this)) + mtd->writesize <<= 1; + mtd->oobsize = mtd->writesize >> 5; /* Pagers per block is always 64 in OneNAND */ mtd->erasesize = mtd->writesize << 6; + /* + * Flex-OneNAND SLC area has 64 pages per block. + * Flex-OneNAND MLC area has 128 pages per block. + * Expose MLC erase size to find erase_shift and page_mask. + */ + if (FLEXONENAND(this)) + mtd->erasesize <<= 1;
/* Check OneNAND features */ onenand_check_features(mtd); @@ -2151,6 +2680,11 @@ int onenand_scan(struct mtd_info *mtd, int maxchips) * Allow subpage writes up to oobsize. */ switch (mtd->oobsize) { + case 128: + this->ecclayout = &onenand_oob_128; + mtd->subpage_sft = 0; + break; + case 64: this->ecclayout = &onenand_oob_64; mtd->subpage_sft = 2; diff --git a/drivers/mtd/onenand/onenand_bbt.c b/drivers/mtd/onenand/onenand_bbt.c index d538f95..1354877 100644 --- a/drivers/mtd/onenand/onenand_bbt.c +++ b/drivers/mtd/onenand/onenand_bbt.c @@ -69,6 +69,7 @@ static int create_bbt(struct mtd_info *mtd, uint8_t * buf, loff_t from; size_t readlen, ooblen; struct mtd_oob_ops ops; + int rgn;
printk(KERN_INFO "Scanning device for bad blocks\n");
@@ -115,7 +116,12 @@ static int create_bbt(struct mtd_info *mtd, uint8_t * buf, } } i += 2; - from += (1 << bbm->bbt_erase_shift); + + if (FLEXONENAND(this)) { + rgn = flexonenand_region(mtd, from); + from += mtd->eraseregions[rgn].erasesize; + } else + from += (1 << bbm->bbt_erase_shift); }
return 0; @@ -152,7 +158,7 @@ static int onenand_isbad_bbt(struct mtd_info *mtd, loff_t offs, int allowbbt) uint8_t res;
/* Get block number * 2 */ - block = (int)(offs >> (bbm->bbt_erase_shift - 1)); + block = (int) (onenand_block(this, offs) << 1); res = (bbm->bbt[block >> 3] >> (block & 0x06)) & 0x03;
MTDDEBUG (MTD_DEBUG_LEVEL2, @@ -191,7 +197,7 @@ int onenand_scan_bbt(struct mtd_info *mtd, struct nand_bbt_descr *bd) struct bbm_info *bbm = this->bbm; int len, ret = 0;
- len = mtd->size >> (this->erase_shift + 2); + len = this->chipsize >> (this->erase_shift + 2); /* Allocate memory (2bit per block) */ bbm->bbt = malloc(len); if (!bbm->bbt) { diff --git a/drivers/mtd/onenand/onenand_uboot.c b/drivers/mtd/onenand/onenand_uboot.c index 4541b22..90dad46 100644 --- a/drivers/mtd/onenand/onenand_uboot.c +++ b/drivers/mtd/onenand/onenand_uboot.c @@ -39,6 +39,8 @@ void onenand_init(void)
+ if (onenand_chip.device_id & DEVICE_IS_FLEXONENAND) + puts("Flex-"); puts("OneNAND: "); - print_size(onenand_mtd.size, "\n"); + print_size(onenand_chip.chipsize, "\n"); } diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index 2597e34..5ed5b48 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -20,8 +20,9 @@ #include <linux/mtd/compat.h> #include <linux/mtd/bbm.h>
+#define MAX_DIES 2 #define MAX_BUFFERRAM 2 -#define MAX_ONENAND_PAGESIZE (2048 + 64) +#define MAX_ONENAND_PAGESIZE (4096 + 128)
/* Scan and identify a OneNAND device */ extern int onenand_scan (struct mtd_info *mtd, int max_chips); @@ -39,9 +40,14 @@ struct onenand_bufferram { /** * struct onenand_chip - OneNAND Private Flash Chip Data * @param base [BOARDSPECIFIC] address to access OneNAND + * @dies: [INTERN][FLEXONENAND] number of dies on chip + * @boundary: [INTERN][FLEXONENAND] Boundary of the dies + * @diesize: [INTERN][FLEXONENAND] Size of the dies * @param chipsize [INTERN] the size of one chip for multichip arrays * @param device_id [INTERN] device ID * @param verstion_id [INTERN] version ID + * @technology [INTERN] describes the internal NAND array technology such as SLC or MLC. + * @density_mask: [INTERN] chip density, used for DDP devices * @param options [BOARDSPECIFIC] various chip options. They can partly be set to inform onenand_scan about * @param erase_shift [INTERN] number of address bits in a block * @param page_shift [INTERN] number of address bits in a page @@ -64,9 +70,13 @@ struct onenand_bufferram { */ struct onenand_chip { void __iomem *base; + unsigned int dies; + unsigned int boundary[MAX_DIES]; + unsigned int diesize[MAX_DIES]; unsigned int chipsize; unsigned int device_id; unsigned int version_id; + unsigned int technology; unsigned int density_mask; unsigned int options;
@@ -125,6 +135,8 @@ struct onenand_chip { #define ONENAND_SET_BUFFERRAM0(this) (this->bufferram_index = 0) #define ONENAND_SET_BUFFERRAM1(this) (this->bufferram_index = 1)
@@ -157,4 +169,6 @@ struct onenand_manufacturers { int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, struct mtd_oob_ops *ops);
+unsigned int onenand_block(struct onenand_chip *this, loff_t addr); +int flexonenand_region(struct mtd_info *mtd, loff_t addr); #endif /* __LINUX_MTD_ONENAND_H */ diff --git a/include/linux/mtd/onenand_regs.h b/include/linux/mtd/onenand_regs.h index fc63380..bc2bb4a 100644 --- a/include/linux/mtd/onenand_regs.h +++ b/include/linux/mtd/onenand_regs.h @@ -67,6 +67,9 @@ /* * Device ID Register F001h (R) */ +#define DEVICE_IS_FLEXONENAND (1 << 9) +#define FLEXONENAND_PI_MASK (0x3ff) +#define FLEXONENAND_PI_UNLOCK_SHIFT (14) #define ONENAND_DEVICE_DENSITY_MASK (0xf) #define ONENAND_DEVICE_DENSITY_SHIFT (4) #define ONENAND_DEVICE_IS_DDP (1 << 3) @@ -84,6 +87,11 @@ #define ONENAND_VERSION_PROCESS_SHIFT (8)
/* * Command Register F220h (R/W) @@ -123,9 +131,14 @@ #define ONENAND_CMD_ERASE (0x94) #define ONENAND_CMD_RESET (0xF0) #define ONENAND_CMD_READID (0x90) +#define FLEXONENAND_CMD_RESET (0xF3) +#define FLEXONENAND_CMD_PI_UPDATE (0x05) +#define FLEXONENAND_CMD_PI_ACCESS (0x66) +#define FLEXONENAND_CMD_RECOVER_LSB (0x05)
/* * System Configuration 1 Register F221h (R, R/W) @@ -186,5 +199,6 @@ #define ONENAND_ECC_1BIT (1 << 0) #define ONENAND_ECC_2BIT (1 << 1) #define ONENAND_ECC_2BIT_ALL (0xAAAA) +#define FLEXONENAND_UNCORRECTABLE_ERROR (0x1010)
#endif /* __ONENAND_REG_H */ diff --git a/include/onenand_uboot.h b/include/onenand_uboot.h index 5a4fded..c6eac7d 100644 --- a/include/onenand_uboot.h +++ b/include/onenand_uboot.h @@ -21,6 +21,7 @@ struct erase_info; struct onenand_chip;
/* board */ extern void onenand_board_init(struct mtd_info *); @@ -36,6 +37,15 @@ extern int onenand_erase(struct mtd_info *mtd, struct erase_info *instr);
extern char *onenand_print_device_info(int device, int version);
+extern unsigned onenand_block(struct onenand_chip *this, loff_t addr); + +extern loff_t onenand_addr(struct onenand_chip *this, int block); + +extern int flexonenand_region(struct mtd_info *mtd, loff_t addr); + +extern int flexonenand_set_boundary(struct mtd_info *mtd, int die, + int boundary, int lock); + /* S3C64xx */ extern void s3c64xx_onenand_init(struct mtd_info *); extern void s3c64xx_set_width_regs(struct onenand_chip *);
This patch adds support for MLC OneNAND and Flex-OneNAND devices.
Please send patches with a ready-for-git commit message.
Thanks, Rohit
Comments that don't go into git, such as changes from a previous version, go below the above --- line.
Do you see this going into Linux soon? Unless there's some particular obstacle to that (other than the code's readiness) I think I'd rather wait for it to be accepted there, with (hopefully) more eyes looking over it, and then bring the result into u-boot.
- boundary = this->boundary[die];
- ofs += block << (this->erase_shift - 1);
- if (block > (boundary + 1))
- return ofs;
In the Linux patch here: http://groups.google.com/group/fa.linux.kernel/msg/8edda44803373f33?hl=en&am...
you deal with 64-bit offsets, but that's missing above.
- if (!FLEXONENAND(this))
- return flexonenand_addr(this, block);
Let the compiler figure out what is inline. Can this function be static?
- if (FLEXONENAND(this)) {
return -EINVAL;
- } else {
return -EINVAL;
It might be worthwhile to factor out the various if/else bits into some sort of "ops" struct, so that the differences in chip type are concentrated in one spot (and it's easier to add a third type if it comes along).
len = instr->len;
addr = instr->addr;
while (len) {
if (ret == -EPERM)
else
if (!len)
break;
region++;
goto erase_exit;
- block = onenand_block(this, ofs); if (bbm->bbt) bbm->bbt[block >> 2] |= 0x01 << ((block & 0x03) << 1);
- for (block = start; block < end; block++) { /* Set block address */ value = onenand_block_address(this, block); this->write_word(value, this->base + ONENAND_REG_START_ADDRESS1);
return;
- if (ONENAND_IS_MLC(this))
- if (this->options & ONENAND_HAS_CONT_LOCK) printk(KERN_DEBUG "Lock scheme is Continuous Lock\n"); if (this->options & ONENAND_HAS_UNLOCK_ALL)
- density = onenand_get_density(device);
- flexonenand = device & DEVICE_IS_FLEXONENAND;
- p += sprintf(dev_info, "%s%sOneNAND%s %dMB %sV 16-bit (0x%02x)", demuxed ? "" : "Muxed ",
- for (i = 0; i < size; i++) if (manuf == onenand_manuf_ids[i].id) break;
- struct onenand_chip *this = mtd->priv;
- unsigned int die, bdry;
- int ret, syscfg, locked;
- /* Disable ECC */
- syscfg = this->read_word(this->base + ONENAND_REG_SYS_CFG1);
- this->write_word((syscfg | 0x0100), this->base + ONENAND_REG_SYS_CFG1);
- for (die = 0; die < this->dies; die++) {
locked = 0;
else
locked = 1;
- /* Enable ECC */
- this->write_word(syscfg, this->base + ONENAND_REG_SYS_CFG1);
- flexonenand_get_size - Fill up fields in onenand_chip and mtd_info
mtd->eraseregions
- @param mtd - MTD device structure
- int die, ofs, i, eraseshift, density;
- int blksperdie, maxbdry;
- density = onenand_get_density(this->device_id);
- blksperdie = ((16 << density) << 20) >> (this->erase_shift);
Can this overflow? Might be better as:
blksperdie = 16 << (density + 20 - this->erase_shift);
- die = ofs = 0;
- i = -1;
- for (; die < this->dies; die++) {
i++;
eraseshift++;
} else {
i++;
eraseshift--;
} else
Can the above be simplified, or at least documented? I'm having a hard time following it.
-Scott
Hi Scott,
All the review comments are closed up to date; it will hopefully get merged there.
- ofs += (block - boundary - 1) << (this->erase_shift - 1);
- return ofs;
Accepted and resolved.
- return block << this->erase_shift;
Removed the inline. Converted to static.
- /* Find the eraseregion of this address */
- i = flexonenand_region(mtd, addr);
- region = &mtd->eraseregions[i];
- block_size = region->erasesize;
- region_end = region->offset + region->erasesize * region->numblocks;
- /* Start address within region must align on block boundary.
- Erase region's start offset is always block start address.
- if (unlikely((addr - region->offset) & (block_size - 1))) {
- MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: Unaligned address\n");
- return -EINVAL;
- } else {
- block_size = 1 << this->erase_shift;
- /* Start address must align on block boundary */
- if (unlikely(addr & (block_size - 1))) {
- return -EINVAL;
This is a good idea; we will consider it in later versions.
- boundary[], diesize[], mtd->size, mtd->erasesize,
- mtd->eraseregions
- die = ofs = 0;
- i = -1;
- if (!die || this->boundary[die-1] != maxbdry) {
- i++;
- mtd->eraseregions[i].offset = ofs;
- mtd->eraseregions[i].erasesize = 1 << eraseshift;
- mtd->eraseregions[i].numblocks =
- this->boundary[die] + 1;
- ofs += mtd->eraseregions[i].numblocks << eraseshift;
- eraseshift++;
- } else {
- mtd->numeraseregions -= 1;
- mtd->eraseregions[i].numblocks +=
- ofs += (this->boundary[die] + 1) << (eraseshift - 1);
- if (this->boundary[die] != maxbdry) {
- i++;
- mtd->eraseregions[i].numblocks = maxbdry ^
- this->boundary[die];
- eraseshift--;
- } else
Documented the above section in function header.
Thank You, Amul Kumar Saha
Signed-off-by: Rohit Hagargundgi <h.rohit at samsung.com> Signed-off-by: Amul Kumar Saha <amul.saha at samsung.com> --- drivers/mtd/onenand/onenand_base.c | 749 ++++++++++++++++++++++++++++++----- drivers/mtd/onenand/onenand_bbt.c | 14 +- drivers/mtd/onenand/onenand_uboot.c | 4 +- include/linux/mtd/onenand.h | 16 +- include/linux/mtd/onenand_regs.h | 18 +- include/onenand_uboot.h | 8 + 6 files changed, 709 insertions(+), 100 deletions(-)
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index d482437..8c621c7 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -37,6 +37,27 @@ static inline void *memcpy_16(void *dst, const void *src, unsigned int len) }
/** + * flexonenand_block - Return block number for flash address + * @param this - OneNAND device structure + * @param addr - Address for which block number is needed + */ +static unsigned int flexonenand_block(struct onenand_chip *this, loff_t addr) +{ + unsigned int boundary, blk, die = 0; + + if (ONENAND_IS_DDP(this) && addr >= this->diesize[0]) { + die = 1; + addr -= this->diesize[0]; + } + + boundary = this->boundary[die]; + + blk = addr >> (this->erase_shift - 1); + if (blk > boundary) + blk = (blk + boundary + 1) >> 1; + + blk += die ? this->density_mask : 0; + return blk; +} + +inline unsigned int onenand_block(struct onenand_chip *this, loff_t addr) +{ + if (!FLEXONENAND(this)) + return addr >> this->erase_shift; + return flexonenand_block(this, addr); +} + +/** + * flexonenand_addr - Return address of the block + * @this: OneNAND device structure + * @block: Block number on Flex-OneNAND + * + * Return address of the block + */ +static loff_t flexonenand_addr(struct onenand_chip *this, int block) +{ + loff_t ofs = 0; + int die = 0, boundary; + + if (ONENAND_IS_DDP(this) && block >= this->density_mask) { + block -= this->density_mask; + die = 1; + ofs = this->diesize[0]; + } + + boundary = this->boundary[die]; + ofs += (loff_t)block << (this->erase_shift - 1); + if (block > (boundary + 1)) + ofs += (loff_t)(block - boundary - 1) << (this->erase_shift - 1); + return ofs; +} + +static loff_t onenand_addr(struct onenand_chip *this, int block) +{ + if (!FLEXONENAND(this)) + return (loff_t)(block << this->erase_shift); + return flexonenand_addr(this, block); +} + +/** + * flexonenand_region - [Flex-OneNAND] Return erase region of addr + * @param mtd MTD device structure + * @param addr address whose erase region needs to be identified + */ +int flexonenand_region(struct mtd_info *mtd, loff_t addr) +{ + int i; + + for (i = 0; i < mtd->numeraseregions; i++) + if (addr < mtd->eraseregions[i].offset) + break; + return i - 1; +} + +/** * onenand_get_density - [DEFAULT] Get OneNAND density * @param dev_id OneNAND device ID * @@ -205,10 +312,11 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, size_t len) { struct onenand_chip *this = mtd->priv; - int value, readcmd = 0; + int value; int block, page; + /* Now we use page size operation */ - int sectors = 4, count = 4; + int sectors = 0, count = 0;
- /* Switch to the next data buffer */ - ONENAND_SET_NEXT_BUFFERRAM(this); + if (ONENAND_IS_MLC(this)) + ONENAND_SET_BUFFERRAM0(this); + else + /* Switch to the next data buffer */ + ONENAND_SET_NEXT_BUFFERRAM(this);
- if (interrupt & ONENAND_INT_READ) { - ecc = this->read_word(this->base + ONENAND_REG_ECC_STATUS); - if (ecc & ONENAND_ECC_2BIT_ALL) { - MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_wait: ECC error = 0x%04x\n", ecc); - return -EBADMSG; - } - }
/* Read-while-load method */ + /* Note: We can't use this feature in MLC */
- /* Now wait for load */ - ret = this->wait(mtd, FL_READING); - onenand_update_bufferram(mtd, from, !ret); - if (ret == -EBADMSG) - ret = 0; + if (!ONENAND_IS_MLC(this)) { + /* Now wait for load */ + ret = this->wait(mtd, FL_READING); + onenand_update_bufferram(mtd, from, !ret); + if (ret == -EBADMSG) + ret = 0; + } }
from += ops->ooboffs;
+ readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB; + while (read < len) { thislen = oobsize - column; thislen = min_t(int, thislen, len);
onenand_update_bufferram(mtd, from, 0);
+ readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB; + /* Initialize return value */ ops->oobretlen = 0;
- this->command(mtd, ONENAND_CMD_READOOB, to, mtd->oobsize); + readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB; + + this->command(mtd, readcmd, to, mtd->oobsize); onenand_update_bufferram(mtd, to, 0); status = this->wait(mtd, FL_READING); if (status) @@ -1291,7 +1509,7 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to, { struct onenand_chip *this = mtd->priv; int column, ret = 0, oobsize; - int written = 0; + int written = 0, oobcmd; u_char *oobbuf; size_t len = ops->ooblen; const u_char *buf = ops->oobbuf; @@ -1333,6 +1551,8 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to,
oobbuf = this->oob_buf;
onenand_update_bufferram(mtd, to, 0); if (ONENAND_IS_2PLANE(this)) { @@ -1475,34 +1702,50 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) { struct onenand_chip *this = mtd->priv; unsigned int block_size; - loff_t addr; - int len; - int ret = 0; + loff_t addr = instr->addr; + loff_t len = (loff_t)(instr->len); + int ret = 0, i; + struct mtd_erase_region_info *region = NULL; + loff_t region_end = 0;
- MTDDEBUG (MTD_DEBUG_LEVEL3, - "onenand_erase: start = 0x%08x, len = %i\n", - (unsigned int)instr->addr, (unsigned int)instr->len); + MTDDEBUG (MTD_DEBUG_LEVEL3, "onenand_erase: start = 0x%08x, len = %i\n", + (unsigned int) addr, len);
- block_size = (1 << this->erase_shift); - - /* Start address must align on block boundary */ - if (unlikely(instr->addr & (block_size - 1))) { - MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_erase: Unaligned address\n"); + /* Do not allow erase past end of device */ + if (unlikely((len + addr) > mtd->size)) { + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: Erase past end of device\n"); return -EINVAL; }
- /* Do not allow erase past end of device */ - if (unlikely((instr->len + instr->addr) > mtd->size)) { + /* Length must align on block boundary */ + if (unlikely(len & (block_size - 1))) { MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_erase: Erase past end of device\n"); + "onenand_erase: Length not block aligned\n"); return -EINVAL; }
/* Loop throught the pages */ - len = instr->len; - addr = instr->addr; - instr->state = MTD_ERASING;
@@ -1974,6 +2230,289 @@ static int onenand_check_maf(int manuf) }
/** +* flexonenand_get_boundary - Reads the SLC boundary +* @param onenand_info - onenand info structure +* +* Fill up boundary[] field in onenand_chip +**/ +static int flexonenand_get_boundary(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + unsigned int die, bdry; + int ret, syscfg, locked; + + /* Disable ECC */ + syscfg = this->read_word(this->base + ONENAND_REG_SYS_CFG1); + this->write_word((syscfg | 0x0100), this->base + ONENAND_REG_SYS_CFG1); + + for (die = 0; die < this->dies; die++) { + this->command(mtd, FLEXONENAND_CMD_PI_ACCESS, die, 0); + this->wait(mtd, FL_SYNCING); + + this->command(mtd, FLEXONENAND_CMD_READ_PI, die, 0); + ret = this->wait(mtd, FL_READING); + + bdry = this->read_word(this->base + ONENAND_DATARAM); + if ((bdry >> FLEXONENAND_PI_UNLOCK_SHIFT) == 3) + locked = 0; + else + locked = 1; + this->boundary[die] = bdry & FLEXONENAND_PI_MASK; + + this->command(mtd, ONENAND_CMD_RESET, 0, 0); + ret = this->wait(mtd, FL_RESETING); + + printk(KERN_INFO "Die %d boundary: %d%s\n", die, + this->boundary[die], locked ? "(Locked)" : "(Unlocked)"); + } + + /* Enable ECC */ + this->write_word(syscfg, this->base + ONENAND_REG_SYS_CFG1); + return 0; +} + +/** + * flexonenand_get_size - Fill up fields in onenand_chip and mtd_info + * boundary[], diesize[], mtd->size, mtd->erasesize, + * mtd->eraseregions + * @param mtd - MTD device structure + * + * Possible configurable scenarios:- + * + * S: SLC + * M: MLC + * Case 1: eraseregion = 4 boundary[die=0]!=maxbdry boundary[die=1]!=maxbdry + * Case 2: eraseregion = 3 boundary[die=0]!=maxbdry boundary[die=1]==maxbdry + * Case 3: eraseregion = 2 boundary[die=0]==maxbdry boundary[die=1]!=maxbdry + * Case 4: eraseregion = 1 boundary[die=0]==maxbdry boundary[die=1]==maxbdry + * + * 1 2 + * ___ __ ___ __ + * |S| |S| |S| |S| + * -- -- -- | | + * |M| |M| |M| | | + * -- -- -- -- + * + * 3 4 + * ___ __ ___ __ + * |S| |S| |S| |S| + * | | -- | | | | + * | | |M| | | | | + * -- -- -- -- + */ +static void flexonenand_get_size(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + int die, ofs, i, eraseshift, density; + int blksperdie, maxbdry; + + density = onenand_get_density(this->device_id); + blksperdie = 16 << (density + 20 - this->erase_shift); + blksperdie >>= ONENAND_IS_DDP(this) ? 1 : 0; + maxbdry = blksperdie - 1; + eraseshift = this->erase_shift - 1; + + mtd->numeraseregions = this->dies << 1; + + /* This fills up the device boundary */ + flexonenand_get_boundary(mtd); + die = ofs = 0; + i = -1; + + for (; die < this->dies; die++) { + /* + * Case 1 OR 2 + */ + if (!die || this->boundary[die-1] != maxbdry) { + i++; + mtd->eraseregions[i].offset = ofs; + mtd->eraseregions[i].erasesize = 1 << eraseshift; + mtd->eraseregions[i].numblocks = + this->boundary[die] + 1; + ofs += mtd->eraseregions[i].numblocks << eraseshift; + eraseshift++; + } + /* + * Case 3 OR 4 + */ + else { + mtd->numeraseregions -= 1; + mtd->eraseregions[i].numblocks += + this->boundary[die] + 1; + ofs += (this->boundary[die] + 1) << (eraseshift - 1); + } + if (this->boundary[die] != maxbdry) { + i++; + mtd->eraseregions[i].offset = ofs; + mtd->eraseregions[i].erasesize = 1 << eraseshift; + mtd->eraseregions[i].numblocks = maxbdry ^ + this->boundary[die]; + ofs += mtd->eraseregions[i].numblocks << eraseshift; + eraseshift--; + } else + mtd->numeraseregions -= 1; + } + + /* Expose MLC erase size except when all blocks are SLC */ + mtd->erasesize = 1 << this->erase_shift; + if (mtd->numeraseregions == 1) + mtd->erasesize >>= 1; + + printk(KERN_INFO "Device has %d eraseregions\n", mtd->numeraseregions); + for (i = 0; i < mtd->numeraseregions; i++) + printk(KERN_INFO "[offset: 0x%08x, erasesize: 0x%05x," + " numblocks: %04u]\n", mtd->eraseregions[i].offset, + mtd->eraseregions[i].erasesize, + mtd->eraseregions[i].numblocks); + + for (die = 0, mtd->size = 0; die < this->dies; die++) { + this->diesize[die] = (loff_t)(blksperdie << this->erase_shift); + this->diesize[die] -= (loff_t)(this->boundary[die] + 1) + << (this->erase_shift - 1); + mtd->size += this->diesize[die]; + } +} + +/** + * flexonenand_check_blocks_erased - Check if blocks are erased + * @param mtd_info - mtd info structure + * @param start - first erase block to check + * @param end - last erase block to check + * + * Converting an unerased block from MLC to SLC + * causes byte values to change. Since both data and its ECC + * have changed, reads on the block give uncorrectable error. + * This might lead to the block being detected as bad. + * + * Avoid this by ensuring that the block to be converted is + * erased. + */ +static int flexonenand_check_blocks_erased(struct mtd_info *mtd, int start, int end) +{ + struct onenand_chip *this = mtd->priv; + int i, ret; + int block; + struct mtd_oob_ops ops = { + .mode = MTD_OOB_PLACE, + .ooboffs = 0, + .ooblen = mtd->oobsize, + .datbuf = NULL, + .oobbuf = this->oob_buf, + }; + loff_t addr; + + printk(KERN_DEBUG "Check blocks from %d to %d\n", start, end); + + for (block = start; block <= end; block++) { + addr = flexonenand_addr(this, block); + if (onenand_block_isbad_nolock(mtd, addr, 0)) + continue; + + /* + * Since main area write results in ECC write to spare, + * it is sufficient to check only ECC bytes for change. + */ + ret = onenand_read_oob_nolock(mtd, addr, &ops); + if (ret) + return ret; + + for (i = 0; i < mtd->oobsize; i++) + if (this->oob_buf[i] != 0xff) + break; + + if (i != mtd->oobsize) { + printk(KERN_WARNING "Block %d not erased.\n", block); + return 1; + } + } + + return 0; +} + +/** + * flexonenand_set_boundary - Writes the SLC boundary + * @param mtd - mtd info structure + */ +int flexonenand_set_boundary(struct mtd_info *mtd, int die, + int boundary, int lock) +{ + struct onenand_chip *this = mtd->priv; + int ret, density, blksperdie, old, new, thisboundary; + loff_t addr; + + if (die >= this->dies) + return -EINVAL; + + if (boundary == this->boundary[die]) + return 0; + + density = onenand_get_density(this->device_id); + blksperdie = ((16 << density) << 20) >> this->erase_shift; + blksperdie >>= ONENAND_IS_DDP(this) ? 1 : 0; + + if (boundary >= blksperdie) { + printk(KERN_ERR "flexonenand_set_boundary: Invalid boundary value. " + "Boundary not changed.\n"); + return -EINVAL; + } + + /* Check if converting blocks are erased */ + old = this->boundary[die] + (die * this->density_mask); + new = boundary + (die * this->density_mask); + ret = flexonenand_check_blocks_erased(mtd, min(old, new) + 1, max(old, new)); + if (ret) { + printk(KERN_ERR "flexonenand_set_boundary: Please erase blocks before boundary change\n"); + return ret; + } + + this->command(mtd, FLEXONENAND_CMD_PI_ACCESS, die, 0); + this->wait(mtd, FL_SYNCING); + + /* Check is boundary is locked */ + this->command(mtd, FLEXONENAND_CMD_READ_PI, die, 0); + ret = this->wait(mtd, FL_READING); + + thisboundary = this->read_word(this->base + ONENAND_DATARAM); + if ((thisboundary >> FLEXONENAND_PI_UNLOCK_SHIFT) != 3) { + printk(KERN_ERR "flexonenand_set_boundary: boundary locked\n"); + goto out; + } + + printk(KERN_INFO "flexonenand_set_boundary: Changing die %d boundary: %d%s\n", + die, boundary, lock ? "(Locked)" : "(Unlocked)"); + + boundary &= FLEXONENAND_PI_MASK; + boundary |= lock ? 0 : (3 << FLEXONENAND_PI_UNLOCK_SHIFT); + + addr = die ? this->diesize[0] : 0; + this->command(mtd, ONENAND_CMD_ERASE, addr, 0); + ret = this->wait(mtd, FL_ERASING); + if (ret) { + printk(KERN_ERR "flexonenand_set_boundary: Failed PI erase for Die %d\n", die); + goto out; + } + + this->write_word(boundary, this->base + ONENAND_DATARAM); + this->command(mtd, ONENAND_CMD_PROG, addr, 0); + ret = this->wait(mtd, FL_WRITING); + if (ret) { + printk(KERN_ERR "flexonenand_set_boundary: Failed PI write for Die %d\n", die); + goto out; + } + + this->command(mtd, FLEXONENAND_CMD_PI_UPDATE, die, 0); + ret = this->wait(mtd, FL_WRITING); +out: + this->write_word(ONENAND_CMD_RESET, this->base + ONENAND_REG_COMMAND); + this->wait(mtd, FL_RESETING); + if (!ret) + /* Recalculate device size on boundary change*/ + flexonenand_get_size(mtd); + + return ret; +} + +/** * onenand_probe - [OneNAND Interface] Probe the OneNAND device * @param mtd MTD device structure * @@ -2016,48 +2555,69 @@ static int onenand_probe(struct mtd_info *mtd) maf_id = this->read_word(this->base + ONENAND_REG_MANUFACTURER_ID); dev_id = this->read_word(this->base + ONENAND_REG_DEVICE_ID); ver_id = this->read_word(this->base + ONENAND_REG_VERSION_ID); + this->technology = this->read_word(this->base + ONENAND_REG_TECHNOLOGY);
/* Check OneNAND device */ if (maf_id != bram_maf_id || dev_id != bram_dev_id) return -ENXIO;
this->erase_shift = ffs(mtd->erasesize) - 1; this->page_shift = ffs(mtd->writesize) - 1; this->ppb_shift = (this->erase_shift - this->page_shift); this->page_mask = (mtd->erasesize / mtd->writesize) - 1; + /* Set density mask. it is used for DDP */ + if (ONENAND_IS_DDP(this)) + this->density_mask = this->chipsize >> (this->erase_shift + 1); /* It's real page size */ this->writesize = mtd->writesize;
/* REVIST: Multichip handling */
- mtd->size = this->chipsize; + if (FLEXONENAND(this)) + flexonenand_get_size(mtd); + else + mtd->size = this->chipsize;
/* Check OneNAND features */ onenand_check_features(mtd); @@ -2151,6 +2711,11 @@ int onenand_scan(struct mtd_info *mtd, int maxchips) * Allow subpage writes up to oobsize. */ switch (mtd->oobsize) { + case 128: + this->ecclayout = &onenand_oob_128; + mtd->subpage_sft = 0; + break; + case 64: this->ecclayout = &onenand_oob_64; mtd->subpage_sft = 2; diff --git a/drivers/mtd/onenand/onenand_bbt.c b/drivers/mtd/onenand/onenand_bbt.c index d538f95..1354877 100644 --- a/drivers/mtd/onenand/onenand_bbt.c +++ b/drivers/mtd/onenand/onenand_bbt.c @@ -69,6 +69,7 @@ static int create_bbt(struct mtd_info *mtd, uint8_t * buf, loff_t from; size_t readlen, ooblen; struct mtd_oob_ops ops; + int rgn;
@@ -82,7 +83,7 @@ static int create_bbt(struct mtd_info *mtd, uint8_t * buf, /* Note that numblocks is 2 * (real numblocks) here; * see i += 2 below as it makses shifting and masking less painful */ - numblocks = mtd->size >> (bbm->bbt_erase_shift - 1); + numblocks = this->chipsize >> (bbm->bbt_erase_shift - 1); startblock = 0; from = 0;
onenand_scan(&onenand_mtd, 1);
+ if (onenand_chip.device_id & DEVICE_IS_FLEXONENAND) + puts("Flex-"); puts("OneNAND: "); - print_size(onenand_mtd.size, "\n"); + print_size(onenand_chip.chipsize, "\n"); } diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index 2597e34..6c2f718 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -20,8 +20,9 @@ #include <linux/mtd/compat.h> #include <linux/mtd/bbm.h>
/* Scan and identify a OneNAND device */ extern int onenand_scan (struct mtd_info *mtd, int max_chips); @@ -39,9 +40,14 @@ struct onenand_bufferram { /** * struct onenand_chip - OneNAND Private Flash Chip Data * @param base [BOARDSPECIFIC] address to access OneNAND + * @dies: [INTERN][FLEXONENAND] number of dies on chip + * @boundary: [INTERN][FLEXONENAND] Boundary of the dies + * @diesize: [INTERN][FLEXONENAND] Size of the dies * @param chipsize [INTERN] the size of one chip for multichip arrays * @param device_id [INTERN] device ID * @param verstion_id [INTERN] version ID + * @technology [INTERN] describes the internal NAND array technology such as SLC or MLC. + * @density_mask: [INTERN] chip density, used for DDP devices * @param options [BOARDSPECIFIC] various chip options. They can partly be set to inform onenand_scan about * @param erase_shift [INTERN] number of address bits in a block * @param page_shift [INTERN] number of address bits in a page @@ -64,9 +70,13 @@ struct onenand_bufferram { */ struct onenand_chip { void __iomem *base; + unsigned int dies; + unsigned int boundary[MAX_DIES]; + loff_t diesize[MAX_DIES]; unsigned int chipsize; unsigned int device_id; unsigned int version_id; + unsigned int technology; unsigned int density_mask; unsigned int options;
+#define FLEXONENAND(this) (this->device_id & DEVICE_IS_FLEXONENAND) +#define ONENAND_IS_MLC(this) (this->technology & ONENAND_TECHNOLOGY_IS_MLC) #define ONENAND_IS_DDP(this) \ (this->device_id & ONENAND_DEVICE_IS_DDP)
/* + * Technology Register F006h (R) + */ +#define ONENAND_TECHNOLOGY_IS_MLC (1 << 0) + +/* * Start Address 1 F100h (R/W) */ #define ONENAND_DDP_SHIFT (15) @@ -93,7 +101,7 @@ /* * Start Address 8 F107h (R/W) */ -#define ONENAND_FPA_MASK (0x3f) +#define ONENAND_FPA_MASK (0x7f) #define ONENAND_FPA_SHIFT (2) #define ONENAND_FSA_MASK (0x03)
@@ -105,7 +113,7 @@ #define ONENAND_BSA_BOOTRAM (0 << 2) #define ONENAND_BSA_DATARAM0 (2 << 2) #define ONENAND_BSA_DATARAM1 (3 << 2) -#define ONENAND_BSC_MASK (0x03) +#define ONENAND_BSC_MASK (0x07)
/* NOTE: Those are not *REAL* commands */ #define ONENAND_CMD_BUFFERRAM (0x1978) +#define FLEXONENAND_CMD_READ_PI (0x1985)
#endif /* __ONENAND_REG_H */ diff --git a/include/onenand_uboot.h b/include/onenand_uboot.h index 49da9d0..cfa46f8 100644 --- a/include/onenand_uboot.h +++ b/include/onenand_uboot.h @@ -23,6 +23,7 @@ struct erase_info; struct onenand_chip;
extern struct mtd_info onenand_mtd; +extern struct onenand_chip onenand_chip;
/* board */ extern void onenand_board_init(struct mtd_info *); @@ -38,6 +39,13 @@ extern int onenand_erase(struct mtd_info *mtd, struct erase_info *instr);
+extern unsigned onenand_block(struct onenand_chip *this, loff_t addr); + +extern int flexonenand_region(struct mtd_info *mtd, loff_t addr); + +extern int flexonenand_set_boundary(struct mtd_info *mtd, int die, + int boundary, int lock); + /* S3C64xx */ extern void s3c64xx_onenand_init(struct mtd_info *); extern void s3c64xx_set_width_regs(struct onenand_chip *);
Amul Kumar Saha
Rohit Hagargundgi
Scott Wood
