[U-Boot] [PATCH] arm: arm64: only use general regs
When compiling with android toolchain, there is an instruction "str q0, [x8],#16", but x8 is not 16bytes aligned, this instruction will trigger sync abort.
So, following Linux kernel, only use general regs for arm64. If not, compiler may use simd registers Q[x]. We need to avoid using simd registers in U-Boot, because load/store Q[x] has restriction that 128bits aligned when str/ldr.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 5881fdc8e2..4db0398dde 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -18,7 +18,7 @@ arch-$(CONFIG_CPU_ARM1136) =-march=armv5 arch-$(CONFIG_CPU_ARM1176) =-march=armv5t arch-$(CONFIG_CPU_V7) =$(call cc-option, -march=armv7-a, \ $(call cc-option, -march=armv7, -march=armv5)) -arch-$(CONFIG_ARM64) =-march=armv8-a +arch-$(CONFIG_ARM64) =-march=armv8-a -mgeneral-regs-only
# On Tegra systems we must build SPL for the armv4 core on the device # but otherwise we can use the value in CONFIG_SYS_ARM_ARCH
The compiler should only output 16-byte-alignemnt-requiring instructions when it can safely assume that the variable in question is 16 byte aligned.
Where did x8 come from? That was probably just an unsafe cast?
For reference, I ran into something similar recently on 32bit ARM:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=82445
And this indeed turned out to be a compiler bug.
FWIW the main reason Linux doesn't want to use FPU registers in kernel space is simply that it doesn't want to bother saving/restoring them on syscalls or interrupts. But I don't quite see why we would care in U-Boot.
Alex
Hi Alexander, On Fri, Dec 01, 2017 at 10:46:29PM +0100, Alexander Graf wrote:
I am not able to resetup my compiler enviorment, it's long time since we found this issue.
Just objdump and seems it is memset/memcpy,
00000000007ee708 <memset>: 7ee708: 92400804 and x4, x0, #0x7 7ee70c: aa0003e3 mov x3, x0
7ee764: aa0003e8 mov x8, x0 7ee768: d2800007 mov x7, #0x0 // #0 7ee76c: 3c810500 str q0, [x8], #16
Thanks, Peng
Alex _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
I would assume this 16-byte aligned store only happens when the pointer is also 16-byte aligned.
Really, I am fairly sure if you ran into issues, we're looking at a compiler bug or an unsafe cast. We shouldn't disable vector register usage in U-Boot altogether because of either.
Alex
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Simon Glass sjg@chromium.org
This breaks s32v234evb building, please look into that, thanks!
-----Original Message----- From: Tom Rini [mailto:trini@konsulko.com] Sent: Sunday, December 03, 2017 12:02 PM To: Peng Fan peng.fan@nxp.com Cc: albert.u.boot@aribaud.net; sjg@chromium.org; York Sun york.sun@nxp.com; u-boot@lists.denx.de Subject: Re: [U-Boot] arm: arm64: only use general regs
I have no idea why use float here.
board/freescale/s32v234evb/clock.c: In function 'program_pll.constprop': board/freescale/s32v234evb/clock.c:91:7: error: '-mgeneral-regs-only' is incompatible with floating-point code fvco = ~~~~~^ (refclk_freq / plldv_prediv) * (plldv_mfd + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ pllfd_mfn / (float)20480); ~~~~~~~~~~~~~~~~~~~~~~~~~
Eddy, Could you help explain why use float to cast 20480? Could this cast be removed?
Thanks, Peng.
-- Tom
participants (5)
Alexander Graf
Peng Fan
Peng Fan
