[PATCH v2 1/1] travis-ci: provide env__efi_fit_tftp_file
Provide dictionary env__efi_fit_tftp_file describing the file used for the UEFI FIT image test.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- Tested with https://gitlab.denx.de/u-boot/custodians/u-boot-efi/pipelines/1714
v2: remove quotes around tftp_dir --- py/travis-ci/travis_tftp.py | 20 +++++++++++++++++++ py/travis-ci/u_boot_boardenv_qemu_arm64_na.py | 1 + py/travis-ci/u_boot_boardenv_qemu_arm_na.py | 1 + .../u_boot_boardenv_qemu_x86_64_na.py | 2 ++ py/travis-ci/u_boot_boardenv_qemu_x86_na.py | 2 ++ .../u_boot_boardenv_vexpress_ca15_tc2_qemu.py | 1 + .../u_boot_boardenv_vexpress_ca9x4_qemu.py | 1 + 7 files changed, 28 insertions(+)
diff --git a/py/travis-ci/travis_tftp.py b/py/travis-ci/travis_tftp.py index 4ea5c06..0eb05bb 100644 --- a/py/travis-ci/travis_tftp.py +++ b/py/travis-ci/travis_tftp.py @@ -1,6 +1,26 @@ import os import binascii
+def efifit2env(addr=None): + """Create dictionary describing file for EFI fit image test + + @addr: address used for loading the file as int (e.g. 0x40400000) + Return: dictionary describing the file with entries + * fn - filename + * addr - loading address, optional + * dn - tftp directory + """ + tftp_dir = os.environ['UBOOT_TRAVIS_BUILD_DIR'] + + ret = { + "fn": "test-efi-fit.img", + "dn": tftp_dir, + } + if addr is not None: + ret['addr'] = addr + + return ret + def file2env(file_name, addr=None): """Create dictionary describing file
diff --git a/py/travis-ci/u_boot_boardenv_qemu_arm64_na.py b/py/travis-ci/u_boot_boardenv_qemu_arm64_na.py index 2986115..98ce873 100644 --- a/py/travis-ci/u_boot_boardenv_qemu_arm64_na.py +++ b/py/travis-ci/u_boot_boardenv_qemu_arm64_na.py @@ -6,3 +6,4 @@ env__net_dhcp_server = True env__net_tftp_readable_file = travis_tftp.file2env('u-boot.bin', 0x40400000) env__efi_loader_helloworld_file = travis_tftp.file2env('lib/efi_loader/helloworld.efi', 0x40400000) env__efi_loader_grub_file = travis_tftp.file2env('grub_arm64.efi', 0x40400000) +env__efi_fit_tftp_file = travis_tftp.efifit2env(0x40400000) diff --git a/py/travis-ci/u_boot_boardenv_qemu_arm_na.py b/py/travis-ci/u_boot_boardenv_qemu_arm_na.py index 391e3c4..3dbedde 100644 --- a/py/travis-ci/u_boot_boardenv_qemu_arm_na.py +++ b/py/travis-ci/u_boot_boardenv_qemu_arm_na.py @@ -6,3 +6,4 @@ env__net_dhcp_server = True env__net_tftp_readable_file = travis_tftp.file2env('u-boot.bin', 0x40400000) env__efi_loader_helloworld_file = travis_tftp.file2env('lib/efi_loader/helloworld.efi', 0x40400000) env__efi_loader_grub_file = travis_tftp.file2env('grub_arm.efi', 0x40400000) +env__efi_fit_tftp_file = travis_tftp.efifit2env(0x40400000) diff --git a/py/travis-ci/u_boot_boardenv_qemu_x86_64_na.py b/py/travis-ci/u_boot_boardenv_qemu_x86_64_na.py index 6f7c593..2fe72c8 100644 --- a/py/travis-ci/u_boot_boardenv_qemu_x86_64_na.py +++ b/py/travis-ci/u_boot_boardenv_qemu_x86_64_na.py @@ -8,3 +8,5 @@ env__efi_loader_helloworld_file = travis_tftp.file2env('lib/efi_loader/helloworl
env__efi_loader_check_smbios = True env__efi_loader_grub_file = travis_tftp.file2env('grub_x64.efi') + +env__efi_fit_tftp_file = travis_tftp.efifit2env() diff --git a/py/travis-ci/u_boot_boardenv_qemu_x86_na.py b/py/travis-ci/u_boot_boardenv_qemu_x86_na.py index 70dc0ae..62cc279 100644 --- a/py/travis-ci/u_boot_boardenv_qemu_x86_na.py +++ b/py/travis-ci/u_boot_boardenv_qemu_x86_na.py @@ -8,3 +8,5 @@ env__efi_loader_helloworld_file = travis_tftp.file2env('lib/efi_loader/helloworl
env__efi_loader_check_smbios = True env__efi_loader_grub_file = travis_tftp.file2env('grub_x86.efi') + +env__efi_fit_tftp_file = travis_tftp.efifit2env() diff --git a/py/travis-ci/u_boot_boardenv_vexpress_ca15_tc2_qemu.py b/py/travis-ci/u_boot_boardenv_vexpress_ca15_tc2_qemu.py index 7437ae6..75f287c 100644 --- a/py/travis-ci/u_boot_boardenv_vexpress_ca15_tc2_qemu.py +++ b/py/travis-ci/u_boot_boardenv_vexpress_ca15_tc2_qemu.py @@ -5,3 +5,4 @@ env__net_dhcp_server = True env__net_tftp_readable_file = travis_tftp.file2env('u-boot') env__efi_loader_helloworld_file = travis_tftp.file2env('lib/efi_loader/helloworld.efi') env__efi_loader_grub_file = travis_tftp.file2env('grub_arm.efi') +env__efi_fit_tftp_file = travis_tftp.efifit2env() diff --git a/py/travis-ci/u_boot_boardenv_vexpress_ca9x4_qemu.py b/py/travis-ci/u_boot_boardenv_vexpress_ca9x4_qemu.py index 7437ae6..75f287c 100644 --- a/py/travis-ci/u_boot_boardenv_vexpress_ca9x4_qemu.py +++ b/py/travis-ci/u_boot_boardenv_vexpress_ca9x4_qemu.py @@ -5,3 +5,4 @@ env__net_dhcp_server = True env__net_tftp_readable_file = travis_tftp.file2env('u-boot') env__efi_loader_helloworld_file = travis_tftp.file2env('lib/efi_loader/helloworld.efi') env__efi_loader_grub_file = travis_tftp.file2env('grub_arm.efi') +env__efi_fit_tftp_file = travis_tftp.efifit2env() -- 2.24.1
- """Create dictionary describing file for EFI fit image test
- @addr: address used for loading the file as int (e.g. 0x40400000)
- Return: dictionary describing the file with entries
* fn - filename
- tftp_dir = os.environ['UBOOT_TRAVIS_BUILD_DIR']
- ret = {
If this function were to exist, then the filename shouldn't be hard-coded; it should be a parameter.
"dn": tftp_dir,
- if addr is not None:
ret['addr'] = addr
- return ret
However, all this function does is create a static dictionary. There's no need to introduce a function for this. Instead, simply put the dictionary directly into py/travis-ci/u_boot_boardenv_qemu_arm64_na.py etc. The only reason that file2env() exists is to automatically calculate the crc32 value, which doesn't apply here.
Hello Stephen,
thanks for reviewing.
This is the name of a generated file. It does not depend on the board.
+ return ret
I considered putting 6 lines into each board file:
import os
env__efi_fit_tftp_file = { "addr" = 0x4040000, "dn" = os.environ['UBOOT_TRAVIS_BUILD_DIR'], "fn" = "test-efi-fit.img", }
I assumed it would be better idea to have a single line in the board files.
Do you really want to increase the code size?
Best regards
Heinrich
Hello Stephen,
What generates the file and when/why?
Generated files should generally be put into u_boot_console.config.persistent_data_dir, and presumably the name hard-coded into the test that uses it.
Hello Stephen,
Hello Stephen,
this is the test case:
https://lists.denx.de/pipermail/u-boot/2019-December/394957.html test/py: Create a test for launching UEFI binaries from FIT images
The test can be run in different styles:
* A complete FIT image can be supplied. In this case the dictionary must contain a "size" entry. * The test can generate a FIT image from lib/efi_loader/helloworld.efi. In this case no "size" entry shall be supplied. The "fn" field provides the name of the generated file. The file is generated in cons.config.build_dir. The "dn" field" describes the tFTP root directory to which the generated file is copied.
The tFTP directory "dn" is only known in uboot-test-hooks.git.
test/py/README.md says --persistent-data-dir is used for data that may be re-used across test runs. Currently the FIT file is generated in every run. In principal it could be reused. So Christian could consider adjusting his patch.
Best regards
Heinrich
Hello Stephen,
Hello Stephen,
- A complete FIT image can be supplied. In this case the dictionary must contain a "size" entry.
- The test can generate a FIT image from lib/efi_loader/helloworld.efi. In this case no "size" entry shall be supplied. The "fn" field provides the name of the generated file. The file is generated in cons.config.build_dir. The "dn" field" describes the tFTP root directory to which the generated file is copied.
A small correction here: if the "size" entry is not provided in the dictionary, the test generates a FIT image using a hardcoded file name (test-efi-fit-helloworld.fit), so any "fn" entry provided in the dictionary is ignored in this case.
Yes, and this is actually the only mandatory information to be provided in the dictionary when the test is supposed to generate the FIT image. We could get rid of this, too, if we make the assumption that the tFTP root directory is u_boot_console.config.build_dir by default.
Actually the FIT image file can be generated multiple times per test run, with different content, which is determined by various combinations of flags. E.g. for sandbox we have: enable/disable GZIP compression, enable/disable FDT usage. Each combination is used in a subtest, that (re)generates the corresponding FIT image.
To re-use the generated data we need to introduce additional complexity to handle FIT image identification for each subtest and to invalidate those images when they become out of sync with the parametrized input data samples (ITS, FDT) used to generate their content.
Best regards
Heinrich
Hello Stephen,
Hello Stephen,
Best regards
Heinrich
I would propose the following:
def efifit2env(file_name=None, addr=None): """Create dictionary describing file for EFI fit image test
@filename: name of an existing file, optional @addr: address used for loading the file as int (e.g. 0x40400000) Return: dictionary describing the file with entries * dn - tftp directory * fn - filename, optional * size - file size in bytes, optional * crc32 - checksum using CRC-32 algorithm, optional * addr - loading address, optional """ tftp_dir = os.environ['UBOOT_TRAVIS_BUILD_DIR']
ret = { 'dn': tftp_dir, }
if addr is not None: ret['addr'] = addr
if file_name: file_full = tftp_dir + '/' + file_name if os.path.isfile(file_full): ret['fn'] = file_name ret['size'] = os.path.getsize(file_full) with open(file_full, 'rb') as f: ret['crc32'] = hex(binascii.crc32(f.read()) & 0xffffffff)[2:]
return ret
This allows the test to run in both scenarios described by Heinrich: * the FIT image is available outside the test -> efifit2env() is called with file_name pointing to an existing FIT image file, optionally pass also the addr * the FIT image is generated by the test itself -> efifit2env() is called without arguments, or optionally pass only the addr
Hello Stephen,
Hello Stephen,
Why does the size parameter affect whether the file name parameter is used? This test sounds like it's doing very odd things with configuration...
I'd propose removing the size and filename parameters completely, and instead just telling the test where the TFTP directory is. Then, we don't need any common function at all.
Also, if we do keep a function, then "efifit2env" is a really bad name; this function is just generating some configuration data, not converting anything, hence "2" or "to" in the function name doesn't make sense.
On 12/30/19 3:52 AM, Heinrich Schuchardt wrote: > Provide dictionary env__efi_fit_tftp_file describing the file > used for > the > UEFI FIT image test.
> diff --git a/py/travis-ci/travis_tftp.py > b/py/travis-ci/travis_tftp.py
> +def efifit2env(addr=None): > + """Create dictionary describing file for EFI fit image test > + > + @addr: address used for loading the file as int (e.g. > 0x40400000) > + Return: dictionary describing the file with entries > + * fn - filename > + * addr - loading address, optional > + * dn - tftp directory > + """ > + tftp_dir = os.environ['UBOOT_TRAVIS_BUILD_DIR'] > + > + ret = { > + "fn": "test-efi-fit.img",
Hello Stephen,
Hello Stephen,
We will need addr too.
I was wrong in assuming a filename was needed. If size is not provided to the test, it defaults to filename 'test-efi-fit-helloworld.fit'.
I will update the patch accordingly. Thanks for reviewing.
Best regards
Heinrich
Cristian Ciocaltea
Stephen Warren
