[U-Boot] Please pull u-boot-marvell master
Hi Tom,
can you please pull various mvebu enhancements from Stefan?
The following changes since commit 5ec0003b19cbdf06ccd6941237cbc0d1c3468e2d:
Prepare v2015.10 (2015-10-19 19:59:38 -0400)
git://git.denx.de/u-boot-marvell.git
for you to fetch changes up to 5b37212a3d78f546b5ef3f97a75155b3a0fd88cb:
mmc: mv_sdhci: Configure the SDHCI MBUS bridge windows (2015-10-21 02:25:02 +0200)
---------------------------------------------------------------- Stefan Roese (12): arm: mvebu: Move Armada XP/38x Kconfig to mach specific Kconfig file arm: mvebu: Add option to use UART xmodem protocol via kwboot arm: mvebu: Only set CONFIG_SKIP_LOWLEVEL_INIT for SPL dm: core: Enable optional use of fdt_translate_address() kwbimage: Align payload size to 4 bytes arm: mvebu: Do not call board_init_r() from board_init_f() arm: mvebu: Add basic Armada XP / 38x dtsi/dts files arm: mvebu: Add DM (driver model) support usb: ehci-marvell.c: Add DM support arm: mvebu: Enable DM_USB on AXP / A38x boards arm: mvebu: Enable DM_SERIAL on AXP / A38x boards mmc: mv_sdhci: Configure the SDHCI MBUS bridge windows
Makefile | 14 +- arch/arm/Kconfig | 20 +- arch/arm/dts/Makefile | 5 + arch/arm/dts/armada-370-xp.dtsi | 333 ++++++++++++++++++ arch/arm/dts/armada-380.dtsi | 152 +++++++++ arch/arm/dts/armada-385.dtsi | 184 ++++++++++ arch/arm/dts/armada-388-gp.dts | 413 +++++++++++++++++++++++ arch/arm/dts/armada-388.dtsi | 70 ++++ arch/arm/dts/armada-38x.dtsi | 600 +++++++++++++++++++++++++++++++++ arch/arm/dts/armada-xp-gp.dts | 245 ++++++++++++++ arch/arm/dts/armada-xp-mv78230.dtsi | 231 +++++++++++++ arch/arm/dts/armada-xp-mv78260.dtsi | 333 ++++++++++++++++++ arch/arm/dts/armada-xp-mv78460.dtsi | 371 ++++++++++++++++++++ arch/arm/dts/armada-xp.dtsi | 320 ++++++++++++++++++ arch/arm/mach-mvebu/Kconfig | 31 ++ arch/arm/mach-mvebu/cpu.c | 31 +- arch/arm/mach-mvebu/include/mach/cpu.h | 2 + arch/arm/mach-mvebu/include/mach/soc.h | 2 +- arch/arm/mach-mvebu/lowlevel_spl.S | 16 + arch/arm/mach-mvebu/spl.c | 26 +- board/Marvell/db-88f6820-gp/Kconfig | 3 - board/Marvell/db-mv784mp-gp/Kconfig | 3 - board/maxbcm/Kconfig | 3 - configs/db-88f6820-gp_defconfig | 7 + configs/db-mv784mp-gp_defconfig | 7 + configs/maxbcm_defconfig | 2 + drivers/core/Kconfig | 30 ++ drivers/core/device.c | 20 ++ drivers/mmc/mv_sdhci.c | 41 +++ drivers/usb/host/Kconfig | 7 + drivers/usb/host/ehci-marvell.c | 86 ++++- include/configs/db-88f6820-gp.h | 6 +- include/configs/db-mv784mp-gp.h | 6 +- include/configs/maxbcm.h | 2 + include/configs/mv-common.h | 10 +- tools/kwbimage.c | 3 + 36 files changed, 3570 insertions(+), 65 deletions(-) create mode 100644 arch/arm/dts/armada-370-xp.dtsi create mode 100644 arch/arm/dts/armada-380.dtsi create mode 100644 arch/arm/dts/armada-385.dtsi create mode 100644 arch/arm/dts/armada-388-gp.dts create mode 100644 arch/arm/dts/armada-388.dtsi create mode 100644 arch/arm/dts/armada-38x.dtsi create mode 100644 arch/arm/dts/armada-xp-gp.dts create mode 100644 arch/arm/dts/armada-xp-mv78230.dtsi create mode 100644 arch/arm/dts/armada-xp-mv78260.dtsi create mode 100644 arch/arm/dts/armada-xp-mv78460.dtsi create mode 100644 arch/arm/dts/armada-xp.dtsi create mode 100644 arch/arm/mach-mvebu/Kconfig
Thanks, Luka
On Wed, Oct 21, 2015 at 12:29:46AM +0000, Luka Perkov wrote:
Hi Tom,
Thanks for being the second pull request and.. Applied to u-boot/master, thanks!
Luka Perkov
