[U-Boot] [PATCH 00/12] Add support for SD3.0 and eMMC HS200
This patch series adds support SD3.0 and eMMC HS200 modes for ZynqMP. This series also contains changes in mmc and sdhci framework to support SD3.0 and HS200.
Siva Durga Prasad Paladugu (12): mmc: sdhci: Update host capabilities about host controller mmc: sdhci: Add support for SD3.0 mmc: sdhci: Add support for platform/board specific tuning mmc: sdhci: Add support for platform specific delay mmc: sdhci: Make sdhci_ops of host as modifiable zynqmp: Define routines for mmio write and read mmc: sdhci: zynq: Define private structure arasan_sdhci_priv mmc: sdhci: zynqmp: Add support of SD3.0 mmc: sdhci: Add quirk for 1.8v switching not supported mmc: zynq_sdhci: Update quirk if 1.8v switching not supported mmc: sdhci: Add support for eMMC HS200 mode mmc: sdhci: zynqmp: Set tapdelays for eMMC HS200 mode
arch/arm/cpu/armv8/zynqmp/cpu.c | 51 ++++++ arch/arm/include/asm/arch-zynqmp/sys_proto.h | 3 + board/xilinx/zynqmp/Makefile | 1 + board/xilinx/zynqmp/tap_delays.c | 250 +++++++++++++++++++++++++++ drivers/mmc/mmc-uclass.c | 52 ++++++ drivers/mmc/mmc.c | 160 +++++++++++++++-- drivers/mmc/sdhci.c | 205 +++++++++++++++++++++- drivers/mmc/zynq_sdhci.c | 169 +++++++++++++++++- include/mmc.h | 72 +++++++- include/sdhci.h | 18 +- include/zynqmp_tap_delay.h | 20 +++ 11 files changed, 979 insertions(+), 22 deletions(-) create mode 100644 board/xilinx/zynqmp/tap_delays.c create mode 100644 include/zynqmp_tap_delay.h
Update host capabilities for driver with host controller information related to UHS modes incase of SD and HS200 mode incase of eMMC.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mmc/sdhci.c | 28 +++++++++++++++++++++++++++- include/mmc.h | 7 +++++++ include/sdhci.h | 5 +++++ 3 files changed, 39 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 5b404ff..95aae4d 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -515,7 +515,8 @@ static const struct mmc_ops sdhci_ops = { int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, u32 max_clk, u32 min_clk) { - u32 caps, caps_1; + u32 caps; + u32 caps_1 = 0;
caps = sdhci_readl(host, SDHCI_CAPABILITIES);
@@ -584,6 +585,31 @@ int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, SDHCI_CLOCK_MUL_SHIFT; }
+ if (!(cfg->voltages & MMC_VDD_165_195)) + caps_1 &= ~(SDHCI_SUPPORT_SDR104 | SDHCI_SUPPORT_SDR50 | + SDHCI_SUPPORT_DDR50); + + if (caps_1 & (SDHCI_SUPPORT_SDR104 | SDHCI_SUPPORT_SDR50 | + SDHCI_SUPPORT_DDR50)) + cfg->host_caps |= MMC_MODE_UHS_SDR12 | MMC_MODE_UHS_SDR25; + + if (caps_1 & SDHCI_SUPPORT_SDR104) { + cfg->host_caps |= MMC_MODE_UHS_SDR104 | MMC_MODE_UHS_SDR50; + /* + * SD3.0: SDR104 is supported so (for eMMC) the caps2 + * field can be promoted to support HS200. + */ + cfg->host_caps |= MMC_MODE_HS200; + } else if (caps_1 & SDHCI_SUPPORT_SDR50) { + cfg->host_caps |= MMC_MODE_UHS_SDR50; + } + + if (caps_1 & SDHCI_SUPPORT_DDR50) + cfg->host_caps |= MMC_MODE_UHS_DDR50; + + if (caps_1 & SDHCI_USE_SDR50_TUNING) + cfg->host_caps |= MMC_MODE_NEEDS_TUNING; + if (host->host_caps) cfg->host_caps |= host->host_caps;
diff --git a/include/mmc.h b/include/mmc.h index fad12d6..5c94eae 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -58,6 +58,13 @@ #define MMC_MODE_8BIT (1 << 3) #define MMC_MODE_SPI (1 << 4) #define MMC_MODE_DDR_52MHz (1 << 5) +#define MMC_MODE_UHS_SDR12 (1 << 6) +#define MMC_MODE_UHS_SDR25 (1 << 7) +#define MMC_MODE_UHS_SDR50 (1 << 8) +#define MMC_MODE_UHS_SDR104 (1 << 9) +#define MMC_MODE_UHS_DDR50 (1 << 10) +#define MMC_MODE_NEEDS_TUNING (1 << 11) +#define MMC_MODE_HS200 (1 << 12)
#define SD_DATA_4BIT 0x00040000
diff --git a/include/sdhci.h b/include/sdhci.h index 7544b49..873bd98 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -167,6 +167,11 @@ #define SDHCI_CAN_64BIT BIT(28)
#define SDHCI_CAPABILITIES_1 0x44 +#define SDHCI_SUPPORT_SDR50 0x00000001 +#define SDHCI_SUPPORT_SDR104 0x00000002 +#define SDHCI_SUPPORT_DDR50 0x00000004 +#define SDHCI_USE_SDR50_TUNING 0x00002000 +#define SDHCI_SUPPORT_HS400 0x80000000 /* Non-standard */ #define SDHCI_CLOCK_MUL_MASK 0x00FF0000 #define SDHCI_CLOCK_MUL_SHIFT 16
Add support for all UHS modes of SD3.0. The SD3.0 needs voltage switching to 1.8V based on host and cards capabilities and also needs to switch to one of the uhs modes based on cards capability. This supports frequencies till 200MHz.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mmc/mmc-uclass.c | 52 ++++++++++++++++ drivers/mmc/mmc.c | 138 +++++++++++++++++++++++++++++++++++++++-- drivers/mmc/sdhci.c | 157 ++++++++++++++++++++++++++++++++++++++++++++++- include/mmc.h | 55 ++++++++++++++++- include/sdhci.h | 8 +++ 5 files changed, 401 insertions(+), 9 deletions(-)
diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index 2fe5d61..3ca3e49 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -77,6 +77,58 @@ int mmc_getcd(struct mmc *mmc) { return dm_mmc_get_cd(mmc->dev); } + +int dm_mmc_set_voltage(struct udevice *dev) +{ + struct dm_mmc_ops *ops = mmc_get_ops(dev); + + if (!ops->set_voltage) + return -ENOSYS; + + return ops->set_voltage(dev); +} + +int mmc_set_voltage(struct mmc *mmc) +{ + return dm_mmc_set_voltage(mmc->dev); +} + +int dm_mmc_set_uhs(struct udevice *dev) +{ + struct dm_mmc_ops *ops = mmc_get_ops(dev); + + if (!ops->set_uhs) + return -ENOSYS; + + return ops->set_uhs(dev); +} + +int mmc_switch_uhs(struct mmc *mmc) +{ + return dm_mmc_set_uhs(mmc->dev); +} + +int dm_mmc_execute_tuning(struct udevice *dev) +{ + struct mmc *mmc = mmc_get_mmc_dev(dev); + struct dm_mmc_ops *ops = mmc_get_ops(dev); + u8 opcode; + + if (!ops->execute_tuning) + return -ENOSYS; + + if (IS_SD(mmc)) + opcode = MMC_CMD_SEND_TUNING_BLOCK; + else + opcode = MMC_CMD_SEND_TUNING_BLOCK_HS200; + + return ops->execute_tuning(dev, opcode); +} + +int mmc_execute_tuning(struct mmc *mmc) +{ + return dm_mmc_execute_tuning(mmc->dev); +} #endif
struct mmc *mmc_get_mmc_dev(struct udevice *dev) diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 9f8368a..d4ea0c2 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -339,6 +339,47 @@ static int mmc_go_idle(struct mmc *mmc) return 0; }
+#ifndef CONFIG_DM_MMC_OPS +static int mmc_set_voltage(struct mmc *mmc) +{ + int err = 0; + + if (mmc->cfg->ops->set_voltage) { + err = mmc->cfg->ops->set_voltage(mmc); + if (err) + return err; + } + + return err; +} +#endif + +static int mmc_switch_voltage(struct mmc *mmc) +{ + struct mmc_cmd cmd; + int err = 0; + + cmd.cmdidx = SD_CMD_SWITCH_UHS18V; + cmd.cmdarg = 0; + cmd.resp_type = MMC_RSP_NONE; + + err = mmc_send_cmd(mmc, &cmd, NULL); + if (err) + return err; + + err = mmc_set_voltage(mmc); + + return err; +} + +static int mmc_host_uhs(struct mmc *mmc) +{ + return mmc->cfg->host_caps & + (MMC_MODE_UHS_SDR12 | MMC_MODE_UHS_SDR25 | + MMC_MODE_UHS_SDR50 | MMC_MODE_UHS_SDR104 | + MMC_MODE_UHS_DDR50); +} + static int sd_send_op_cond(struct mmc *mmc) { int timeout = 1000; @@ -371,6 +412,9 @@ static int sd_send_op_cond(struct mmc *mmc) if (mmc->version == SD_VERSION_2) cmd.cmdarg |= OCR_HCS;
+ if (mmc_host_uhs(mmc)) + cmd.cmdarg |= SD_OCR_S18R; + err = mmc_send_cmd(mmc, &cmd, NULL);
if (err) @@ -401,6 +445,13 @@ static int sd_send_op_cond(struct mmc *mmc)
mmc->ocr = cmd.response[0];
+ if (mmc->ocr & SD_OCR_S18R) { + err = mmc_switch_voltage(mmc); + if (err) + return err; + mmc->is_uhs = 1; + } + mmc->high_capacity = ((mmc->ocr & OCR_HCS) == OCR_HCS); mmc->rca = 0;
@@ -886,6 +937,7 @@ static int sd_change_freq(struct mmc *mmc) ALLOC_CACHE_ALIGN_BUFFER(uint, switch_status, 16); struct mmc_data data; int timeout; + u8 mode;
mmc->card_caps = 0;
@@ -963,6 +1015,40 @@ retry_scr: break; }
+ mode = MMC_TIMING_HS; + + if (mmc->is_uhs && mmc->version >= SD_VERSION_3) { + if (!(mmc_host_uhs(mmc))) + return 0; + + if (__be32_to_cpu(switch_status[3]) & + SD_UHS_SPEED_SDR104) { + mode = MMC_TIMING_UHS_SDR104; + mmc->card_caps |= MMC_MODE_UHS_SDR104; + mmc->tran_speed = 208000000; + } else if (__be32_to_cpu(switch_status[3]) & + SD_UHS_SPEED_SDR50) { + mode = MMC_TIMING_UHS_SDR50; + mmc->card_caps |= MMC_MODE_UHS_SDR50; + mmc->tran_speed = 100000000; + } else if (__be32_to_cpu(switch_status[3]) & + SD_UHS_SPEED_DDR50) { + mode = MMC_TIMING_UHS_DDR50; + mmc->card_caps |= MMC_MODE_UHS_DDR50; + mmc->tran_speed = 50000000; + } else if (__be32_to_cpu(switch_status[3]) & + SD_UHS_SPEED_SDR25) { + mode = MMC_TIMING_UHS_SDR25; + mmc->card_caps |= MMC_MODE_UHS_SDR25; + mmc->tran_speed = 50000000; + } else { + mode = MMC_TIMING_UHS_SDR12; + mmc->card_caps |= MMC_MODE_UHS_SDR12; + mmc->tran_speed = 25000000; + } + mmc->uhsmode = mode; + } + /* If high-speed isn't supported, we return */ if (!(__be32_to_cpu(switch_status[3]) & SD_HIGHSPEED_SUPPORTED)) return 0; @@ -977,7 +1063,7 @@ retry_scr: (mmc->cfg->host_caps & MMC_MODE_HS))) return 0;
- err = sd_switch(mmc, SD_SWITCH_SWITCH, 0, 1, (u8 *)switch_status); + err = sd_switch(mmc, SD_SWITCH_SWITCH, 0, mode, (u8 *)switch_status);
if (err) return err; @@ -1102,6 +1188,33 @@ static void mmc_set_bus_width(struct mmc *mmc, uint width)
mmc_set_ios(mmc); } +#ifndef CONFIG_DM_MMC_OPS +static int mmc_switch_uhs(struct mmc *mmc) +{ + int err = 0; + + if (mmc->cfg->ops->set_uhs) + err = mmc->cfg->ops->set_uhs(mmc); + + return err; +} + +static int mmc_execute_tuning(struct mmc *mmc) +{ + int err = 0; + u8 cmd; + + if (mmc->cfg->ops->execute_tuning) { + if (IS_SD(mmc)) + cmd = MMC_CMD_SEND_TUNING_BLOCK; + else + cmd = MMC_CMD_SEND_TUNING_BLOCK_HS200; + err = mmc->cfg->ops->execute_tuning(mmc, cmd); + } + + return err; +} +#endif
static int mmc_startup(struct mmc *mmc) { @@ -1452,11 +1565,16 @@ static int mmc_startup(struct mmc *mmc) err = sd_read_ssr(mmc); if (err) return err; - - if (mmc->card_caps & MMC_MODE_HS) - mmc->tran_speed = 50000000; - else - mmc->tran_speed = 25000000; + if (mmc->card_caps & MMC_MODE_UHS) { + err = mmc_switch_uhs(mmc); + if (err) + return err; + } else { + if (mmc->card_caps & MMC_MODE_HS) + mmc->tran_speed = 50000000; + else + mmc->tran_speed = 25000000; + } } else if (mmc->version >= MMC_VERSION_4) { /* Only version 4 of MMC supports wider bus widths */ int idx; @@ -1551,6 +1669,14 @@ static int mmc_startup(struct mmc *mmc)
mmc_set_clock(mmc, mmc->tran_speed);
+ if ((mmc->card_caps & (MMC_MODE_UHS_SDR50 | + MMC_MODE_UHS_SDR104)) && + (mmc->cfg->host_caps & MMC_MODE_NEEDS_TUNING)) { + err = mmc_execute_tuning(mmc); + if (err) + return err; + } + /* Fix the block length for DDR mode */ if (mmc->ddr_mode) { mmc->read_bl_len = MMC_MAX_BLOCK_LEN; diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 95aae4d..5ae56e0 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <mmc.h> #include <sdhci.h> +#include <wait_bit.h>
#if defined(CONFIG_FIXED_SDHCI_ALIGNED_BUFFER) void *aligned_buffer = (void *)CONFIG_FIXED_SDHCI_ALIGNED_BUFFER; @@ -155,7 +156,8 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd,
/* We shouldn't wait for data inihibit for stop commands, even though they might use busy signaling */ - if (cmd->cmdidx == MMC_CMD_STOP_TRANSMISSION) + if ((cmd->cmdidx == MMC_CMD_STOP_TRANSMISSION) || + (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK)) mask &= ~SDHCI_DATA_INHIBIT;
while (sdhci_readl(host, SDHCI_PRESENT_STATE) & mask) { @@ -175,6 +177,11 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, }
mask = SDHCI_INT_RESPONSE; + + /* only buffer read ready interrupt whil tuning */ + if (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK) + mask = SDHCI_INT_DATA_AVAIL; + if (!(cmd->resp_type & MMC_RSP_PRESENT)) flags = SDHCI_CMD_RESP_NONE; else if (cmd->resp_type & MMC_RSP_136) @@ -190,7 +197,7 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, flags |= SDHCI_CMD_CRC; if (cmd->resp_type & MMC_RSP_OPCODE) flags |= SDHCI_CMD_INDEX; - if (data) + if (data || (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK)) flags |= SDHCI_CMD_DATA;
/* Set Transfer mode regarding to data flag */ @@ -291,6 +298,80 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, else return -ECOMM; } +#ifdef CONFIG_DM_MMC_OPS +static int sdhci_execute_tuning(struct udevice *dev, u8 opcode) +{ + struct mmc *mmc = mmc_get_mmc_dev(dev); +#else +static int sdhci_execute_tuning(struct mmc *mmc, u8 opcode) +{ +#endif + struct mmc_cmd cmd; + struct mmc_data data; + u32 ctrl; + u8 tuning_loop_counter = 40; + struct sdhci_host *host = mmc->priv; + + debug("%s\n", __func__); + + ctrl = sdhci_readw(host, SDHCI_HOST_CTRL2); + ctrl |= SDHCI_CTRL_EXEC_TUNING; + sdhci_writew(host, ctrl, SDHCI_HOST_CTRL2); + + sdhci_writel(host, SDHCI_INT_DATA_AVAIL, SDHCI_INT_ENABLE); + sdhci_writel(host, SDHCI_INT_DATA_AVAIL, SDHCI_SIGNAL_ENABLE); + + do { + cmd.cmdidx = opcode; + cmd.resp_type = MMC_RSP_R1; + cmd.cmdarg = 0; + + data.blocksize = 64; + data.blocks = 1; + data.flags = MMC_DATA_READ; + + if (tuning_loop_counter == 0) + break; + + tuning_loop_counter--; + + if (cmd.cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200 && + mmc->bus_width == 8) { + data.blocksize = 128; + } + + sdhci_writew(host, SDHCI_MAKE_BLKSZ(SDHCI_DEFAULT_BOUNDARY_ARG, + data.blocksize), + SDHCI_BLOCK_SIZE); + sdhci_writew(host, data.blocks, SDHCI_BLOCK_COUNT); + sdhci_writew(host, SDHCI_TRNS_READ, SDHCI_TRANSFER_MODE); + + sdhci_send_command(dev, &cmd, &data); + ctrl = sdhci_readw(host, SDHCI_HOST_CTRL2); + + if (cmd.cmdidx == MMC_CMD_SEND_TUNING_BLOCK) + udelay(1); + + } while (ctrl & SDHCI_CTRL_EXEC_TUNING); + + if (tuning_loop_counter < 0) { + ctrl &= ~SDHCI_CTRL_TUNED_CLK; + sdhci_writel(host, ctrl, SDHCI_HOST_CTRL2); + } + + if (!(ctrl & SDHCI_CTRL_TUNED_CLK)) { + debug("%s:Tuning failed\n", __func__); + return -1; + } + + /* Enable only interrupts served by the SD controller */ + sdhci_writel(host, SDHCI_INT_DATA_MASK | SDHCI_INT_CMD_MASK, + SDHCI_INT_ENABLE); + /* Mask all sdhci interrupt sources */ + sdhci_writel(host, 0x0, SDHCI_SIGNAL_ENABLE); + + return 0; +}
static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) { @@ -386,6 +467,72 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) return 0; }
+#ifdef CONFIG_DM_MMC_OPS +static int sdhci_set_voltage(struct udevice *dev) +{ + struct mmc *mmc = mmc_get_mmc_dev(dev); +#else +static int sdhci_set_voltage(struct mmc *mmc) +{ +#endif + struct sdhci_host *host = mmc->priv; + u32 reg; + int err; + + debug("%s\n", __func__); + + reg = (unsigned long)host->ioaddr + SDHCI_PRESENT_STATE; + /* Wait max 20ms for the bits to clear*/ + err = wait_for_bit(__func__, (const u32 *)(uintptr_t)reg, + (SDHCI_CMD_INHIBIT | SDHCI_DATA_INHIBIT), + false, 20, false); + if (err < 0) + return err; + + reg = sdhci_readw(host, SDHCI_CLOCK_CONTROL); + reg &= ~(SDHCI_CLOCK_CARD_EN | SDHCI_CLOCK_INT_EN); + sdhci_writew(host, reg, SDHCI_CLOCK_CONTROL); + + /* keep clock gated for 5 msec as per spec */ + udelay(5000); + + reg = sdhci_readw(host, SDHCI_HOST_CTRL2); + reg |= SDHCI_18V_SIGNAL; + sdhci_writew(host, reg, SDHCI_HOST_CTRL2); + + sdhci_set_clock(mmc, mmc->cfg->f_min); + + reg = (unsigned long)host->ioaddr + SDHCI_PRESENT_STATE; + /* Wait max 20ms for bits to be clear */ + err = wait_for_bit(__func__, (const u32 *)(uintptr_t)reg, + (SDHCI_CMD_BUSY | SDHCI_DATA_BUSY), + true, 20, false); + if (err < 0) + return err; + + return 0; +} + +#ifdef CONFIG_DM_MMC_OPS +static int sdhci_set_uhs(struct udevice *dev) +{ + struct mmc *mmc = mmc_get_mmc_dev(dev); +#else +static int sdhci_set_uhs(struct mmc *mmc) +{ +#endif + struct sdhci_host *host = mmc->priv; + u32 reg; + + debug("%s\n", __func__); + reg = sdhci_readw(host, SDHCI_HOST_CTRL2); + reg &= ~SDHCI_CTRL2_MODE_MASK; + reg |= mmc->uhsmode; + sdhci_writew(host, reg, SDHCI_HOST_CTRL2); + + return 0; +} + static void sdhci_set_power(struct sdhci_host *host, unsigned short power) { u8 pwr = 0; @@ -503,12 +650,18 @@ int sdhci_probe(struct udevice *dev) const struct dm_mmc_ops sdhci_ops = { .send_cmd = sdhci_send_command, .set_ios = sdhci_set_ios, + .set_voltage = sdhci_set_voltage, + .set_uhs = sdhci_set_uhs, + .execute_tuning = sdhci_execute_tuning, }; #else static const struct mmc_ops sdhci_ops = { .send_cmd = sdhci_send_command, .set_ios = sdhci_set_ios, .init = sdhci_init, + .set_voltage = sdhci_set_voltage, + .set_uhs = sdhci_set_uhs, + .execute_tuning = sdhci_execute_tuning, }; #endif
diff --git a/include/mmc.h b/include/mmc.h index 5c94eae..56395ee 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -66,6 +66,9 @@ #define MMC_MODE_NEEDS_TUNING (1 << 11) #define MMC_MODE_HS200 (1 << 12)
+#define MMC_MODE_UHS (MMC_MODE_UHS_SDR12 | MMC_MODE_UHS_SDR25 | \ + MMC_MODE_UHS_SDR50 | MMC_MODE_UHS_SDR104 | \ + MMC_MODE_UHS_DDR50) #define SD_DATA_4BIT 0x00040000
#define IS_SD(x) ((x)->version & SD_VERSION_SD) @@ -89,6 +92,8 @@ #define MMC_CMD_SET_BLOCKLEN 16 #define MMC_CMD_READ_SINGLE_BLOCK 17 #define MMC_CMD_READ_MULTIPLE_BLOCK 18 +#define MMC_CMD_SEND_TUNING_BLOCK 19 +#define MMC_CMD_SEND_TUNING_BLOCK_HS200 21 #define MMC_CMD_SET_BLOCK_COUNT 23 #define MMC_CMD_WRITE_SINGLE_BLOCK 24 #define MMC_CMD_WRITE_MULTIPLE_BLOCK 25 @@ -119,12 +124,18 @@ /* SCR definitions in different words */ #define SD_HIGHSPEED_BUSY 0x00020000 #define SD_HIGHSPEED_SUPPORTED 0x00020000 +#define SD_UHS_SPEED_SDR104 0x00080000 +#define SD_UHS_SPEED_SDR50 0x00040000 +#define SD_UHS_SPEED_DDR50 0x00100000 +#define SD_UHS_SPEED_SDR25 0x00020000
#define OCR_BUSY 0x80000000 #define OCR_HCS 0x40000000 #define OCR_VOLTAGE_MASK 0x007FFF80 #define OCR_ACCESS_MODE 0x60000000
+#define SD_OCR_S18R (1 << 24) + #define MMC_ERASE_ARG 0x00000000 #define MMC_SECURE_ERASE_ARG 0x80000000 #define MMC_TRIM_ARG 0x00000001 @@ -277,6 +288,13 @@ #define MMC_NUM_BOOT_PARTITION 2 #define MMC_PART_RPMB 3 /* RPMB partition number */
+#define MMC_TIMING_UHS_SDR12 0 +#define MMC_TIMING_UHS_SDR25 1 +#define MMC_TIMING_UHS_SDR50 2 +#define MMC_TIMING_UHS_SDR104 3 +#define MMC_TIMING_UHS_DDR50 4 +#define MMC_TIMING_HS 1 + /* Driver model support */
/** @@ -364,6 +382,31 @@ struct dm_mmc_ops { * @return 0 if write-enabled, 1 if write-protected, -ve on error */ int (*get_wp)(struct udevice *dev); + + /** + * set_volatge() - Switches host for new voltage + * @dev:>-------Device to check + * + * @return 0 on success otherwise error value + */ + int (*set_voltage)(struct udevice *dev); + + /** + * set_uhs() - Sets the controller for specific uhs mode + * @dev:>-------Device to check + * + * @return 0 after setting uhs mode + */ + int (*set_uhs)(struct udevice *dev); + + /** + * execute_tuning() - Executes the required tuning sequence + * @dev:>-------Device to check + * @opcode:>----Command to be sent for tuning + * + * @return 0 on success otherwise error value + */ + int (*execute_tuning)(struct udevice *dev, u8 opcode); };
#define mmc_get_ops(dev) ((struct dm_mmc_ops *)(dev)->driver->ops) @@ -373,12 +416,17 @@ int dm_mmc_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, int dm_mmc_set_ios(struct udevice *dev); int dm_mmc_get_cd(struct udevice *dev); int dm_mmc_get_wp(struct udevice *dev); +int dm_mmc_set_voltage(struct udevice *dev); +int dm_mmc_set_uhs(struct udevice *dev); +int dm_mmc_execute_tuning(struct udevice *dev);
/* Transition functions for compatibility */ int mmc_set_ios(struct mmc *mmc); int mmc_getcd(struct mmc *mmc); int mmc_getwp(struct mmc *mmc); - +int mmc_set_voltage(struct mmc *mmc); +int mmc_switch_uhs(struct mmc *mmc); +int mmc_execute_tuning(struct mmc *mmc); #else struct mmc_ops { int (*send_cmd)(struct mmc *mmc, @@ -387,6 +435,9 @@ struct mmc_ops { int (*init)(struct mmc *mmc); int (*getcd)(struct mmc *mmc); int (*getwp)(struct mmc *mmc); + int (*set_voltage)(struct mmc *mmc); + int (*set_uhs)(struct mmc *mmc); + int (*execute_tuning)(struct mmc *mmc, u8 opcode); }; #endif
@@ -461,6 +512,8 @@ struct mmc { #ifdef CONFIG_DM_MMC struct udevice *dev; /* Device for this MMC controller */ #endif + u8 is_uhs; + u8 uhsmode; };
struct mmc_hwpart_conf { diff --git a/include/sdhci.h b/include/sdhci.h index 873bd98..4d877eb 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -64,6 +64,8 @@ #define SDHCI_CARD_STATE_STABLE BIT(17) #define SDHCI_CARD_DETECT_PIN_LEVEL BIT(18) #define SDHCI_WRITE_PROTECT BIT(19) +#define SDHCI_DATA_BUSY 0xF00000 +#define SDHCI_CMD_BUSY 0x1000000
#define SDHCI_HOST_CONTROL 0x28 #define SDHCI_CTRL_LED BIT(0) @@ -146,6 +148,12 @@ #define SDHCI_ACMD12_ERR 0x3C
/* 3E-3F reserved */ +#define SDHCI_HOST_CTRL2 0x3E +#define SDHCI_CTRL2_MODE_MASK 0x7 + +#define SDHCI_18V_SIGNAL 0x8 +#define SDHCI_CTRL_EXEC_TUNING 0x0040 +#define SDHCI_CTRL_TUNED_CLK 0x80
#define SDHCI_CAPABILITIES 0x40 #define SDHCI_TIMEOUT_CLK_MASK 0x0000003F
Add support to execute platform/board specific tuning needed for SDR104 and SDR50 UHS modes.This patch adds hook routine to support specific tuning requirements.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mmc/sdhci.c | 8 ++++++++ include/sdhci.h | 1 + 2 files changed, 9 insertions(+)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 5ae56e0..7b968d5 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -309,11 +309,19 @@ static int sdhci_execute_tuning(struct mmc *mmc, u8 opcode) struct mmc_cmd cmd; struct mmc_data data; u32 ctrl; + int err; u8 tuning_loop_counter = 40; struct sdhci_host *host = mmc->priv;
+ if (host->ops->platform_execute_tuning) { + err = host->ops->platform_execute_tuning(mmc, opcode); + if (err) + return err; + return 0; + } + ctrl = sdhci_readw(host, SDHCI_HOST_CTRL2); ctrl |= SDHCI_CTRL_EXEC_TUNING; sdhci_writew(host, ctrl, SDHCI_HOST_CTRL2); diff --git a/include/sdhci.h b/include/sdhci.h index 4d877eb..ae19be6 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -249,6 +249,7 @@ struct sdhci_ops { int (*get_cd)(struct sdhci_host *host); void (*set_control_reg)(struct sdhci_host *host); void (*set_clock)(struct sdhci_host *host, u32 div); + int (*platform_execute_tuning)(struct mmc *host, u8 opcode); };
struct sdhci_host {
if (err)
return err;
This can be just this: if (host->ops->platform_execute_tuning) return host->ops->platform_execute_tuning(mmc, opcode);
M
Add support for any platform/board specific delays requirement while setting clocks. Some boards needs to program tapdelay for setting certain high frequencies and this patch adds hook for supporting the same.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mmc/sdhci.c | 3 +++ include/sdhci.h | 1 + 2 files changed, 4 insertions(+)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 7b968d5..a2fcf18 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -407,6 +407,9 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) if (clock == 0) return 0;
+ if (mmc->is_uhs && host->ops->set_delay) + host->ops->set_delay(host, mmc->uhsmode); + if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) { /* * Check if the Host Controller supports Programmable Clock diff --git a/include/sdhci.h b/include/sdhci.h index ae19be6..54c2ea2 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -250,6 +250,7 @@ struct sdhci_ops { void (*set_control_reg)(struct sdhci_host *host); void (*set_clock)(struct sdhci_host *host, u32 div); int (*platform_execute_tuning)(struct mmc *host, u8 opcode); + void (*set_delay)(struct sdhci_host *host, u8 uhsmode); };
struct sdhci_host {
Make sdhci_ops of host modifiable as ops may contain platform specific funtion pointers which may need to be defined for some platforms(example: platform specific tuning and delays)
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- include/sdhci.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/sdhci.h b/include/sdhci.h index 54c2ea2..c00beb8 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -262,7 +262,7 @@ struct sdhci_host { unsigned int clk_mul; /* Clock Multiplier value */ unsigned int clock; struct mmc *mmc; - const struct sdhci_ops *ops; + struct sdhci_ops *ops; int index;
int bus_width;
Define routines of mmio write and read functionalities for zynqmp platform.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- arch/arm/cpu/armv8/zynqmp/cpu.c | 51 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-zynqmp/sys_proto.h | 3 ++ 2 files changed, 54 insertions(+)
diff --git a/arch/arm/cpu/armv8/zynqmp/cpu.c b/arch/arm/cpu/armv8/zynqmp/cpu.c index b0f1295..54afa9e 100644 --- a/arch/arm/cpu/armv8/zynqmp/cpu.c +++ b/arch/arm/cpu/armv8/zynqmp/cpu.c @@ -104,3 +104,54 @@ unsigned int zynqmp_get_silicon_version(void)
return ZYNQMP_CSU_VERSION_SILICON; } + +#define PAYLOAD_ARG_CNT 5 +#define ZYNQMP_MMIO_READ 0xC2000014 +#define ZYNQMP_MMIO_WRITE 0xC2000013 + +static int invoke_smc(u32 pm_api_id, u32 arg0, u32 arg1, u32 arg2, u32 arg3, + u32 *ret_payload) +{ + /* + * Added SIP service call Function Identifier + * Make sure to stay in x0 register + */ + struct pt_regs regs; + + regs.regs[0] = pm_api_id; + regs.regs[1] = ((u64)arg1 << 32) | arg0; + regs.regs[2] = ((u64)arg3 << 32) | arg2; + + smc_call(®s); + + if (ret_payload != NULL) { + ret_payload[0] = (u32)regs.regs[0]; + ret_payload[1] = upper_32_bits(regs.regs[0]); + ret_payload[2] = (u32)regs.regs[1]; + ret_payload[3] = upper_32_bits(regs.regs[1]); + ret_payload[4] = (u32)regs.regs[2]; + } + + return regs.regs[0]; +} + +int zynqmp_mmio_write(const u32 address, + const u32 mask, + const u32 value) +{ + return invoke_smc(ZYNQMP_MMIO_WRITE, address, mask, value, 0, NULL); +} + +int zynqmp_mmio_read(const u32 address, u32 *value) +{ + u32 ret_payload[PAYLOAD_ARG_CNT]; + u32 ret; + + if (!value) + return -EINVAL; + + ret = invoke_smc(ZYNQMP_MMIO_READ, address, 0, 0, 0, ret_payload); + *value = ret_payload[1]; + + return ret; +} diff --git a/arch/arm/include/asm/arch-zynqmp/sys_proto.h b/arch/arm/include/asm/arch-zynqmp/sys_proto.h index 8c54fce..446e89c 100644 --- a/arch/arm/include/asm/arch-zynqmp/sys_proto.h +++ b/arch/arm/include/asm/arch-zynqmp/sys_proto.h @@ -23,4 +23,7 @@ void psu_init(void);
void handoff_setup(void);
+int zynqmp_mmio_write(const u32 address, const u32 mask, const u32 value); +int zynqmp_mmio_read(const u32 address, u32 *value); + #endif /* _ASM_ARCH_SYS_PROTO_H */
Deine private structure arasan_sdhci_priv instead of sdhci_host as private. This allows us in adding more private data as required for usage in driver.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mmc/zynq_sdhci.c | 19 +++++++++++++++---- 1 file changed, 15 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 3da1385..2c1561c 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -22,13 +22,20 @@ struct arasan_sdhci_plat { struct mmc mmc; };
+struct arasan_sdhci_priv { + struct sdhci_host *host; +}; + static int arasan_sdhci_probe(struct udevice *dev) { struct arasan_sdhci_plat *plat = dev_get_platdata(dev); struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); - struct sdhci_host *host = dev_get_priv(dev); + struct arasan_sdhci_priv *priv = dev_get_priv(dev); + struct sdhci_host *host; int ret;
+ host = priv->host; + host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_BROKEN_R1B;
@@ -50,10 +57,14 @@ static int arasan_sdhci_probe(struct udevice *dev)
static int arasan_sdhci_ofdata_to_platdata(struct udevice *dev) { - struct sdhci_host *host = dev_get_priv(dev); + struct arasan_sdhci_priv *priv = dev_get_priv(dev); + + priv->host = calloc(1, sizeof(struct sdhci_host)); + if (priv->host == NULL) + return -1;
- host->name = dev->name; - host->ioaddr = (void *)dev_get_addr(dev); + priv->host->name = dev->name; + priv->host->ioaddr = (void *)dev_get_addr(dev);
return 0; }
Add SD3.0 support for ZynqMP, this support needs a platform specific tuning and tap delays for UHS modes of SD3.0 and this patch takes care of it.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- board/xilinx/zynqmp/Makefile | 1 + board/xilinx/zynqmp/tap_delays.c | 249 +++++++++++++++++++++++++++++++++++++++ drivers/mmc/zynq_sdhci.c | 142 +++++++++++++++++++++- include/zynqmp_tap_delay.h | 20 ++++ 4 files changed, 411 insertions(+), 1 deletion(-) create mode 100644 board/xilinx/zynqmp/tap_delays.c create mode 100644 include/zynqmp_tap_delay.h
diff --git a/board/xilinx/zynqmp/Makefile b/board/xilinx/zynqmp/Makefile index 9d69d65..2bf0375 100644 --- a/board/xilinx/zynqmp/Makefile +++ b/board/xilinx/zynqmp/Makefile @@ -20,6 +20,7 @@ $(warning Put custom psu_init_gpl.c/h to board/xilinx/zynqmp/custom_hw_platform/ endif endif
+obj-$(CONFIG_ZYNQ_SDHCI) += tap_delays.o obj-$(CONFIG_SPL_BUILD) += $(init-objs)
# Suppress "warning: function declaration isn't a prototype" diff --git a/board/xilinx/zynqmp/tap_delays.c b/board/xilinx/zynqmp/tap_delays.c new file mode 100644 index 0000000..d57587e --- /dev/null +++ b/board/xilinx/zynqmp/tap_delays.c @@ -0,0 +1,249 @@ +/* + * Xilinx ZynqMP SoC Tap Delay Programming + * + * Copyright (C) 2016 Xilinx, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/sys_proto.h> + +#define SD_DLL_CTRL 0xFF180358 +#define SD_ITAP_DLY 0xFF180314 +#define SD_OTAP_DLY 0xFF180318 +#define SD0_DLL_RST_MASK 0x00000004 +#define SD0_DLL_RST 0x00000004 +#define SD1_DLL_RST_MASK 0x00040000 +#define SD1_DLL_RST 0x00040000 +#define SD0_ITAPCHGWIN_MASK 0x00000200 +#define SD0_ITAPCHGWIN 0x00000200 +#define SD1_ITAPCHGWIN_MASK 0x02000000 +#define SD1_ITAPCHGWIN 0x02000000 +#define SD0_ITAPDLYENA_MASK 0x00000100 +#define SD0_ITAPDLYENA 0x00000100 +#define SD1_ITAPDLYENA_MASK 0x01000000 +#define SD1_ITAPDLYENA 0x01000000 +#define SD0_ITAPDLYSEL_MASK 0x000000FF +#define SD0_ITAPDLYSEL_HSD 0x00000015 +#define SD0_ITAPDLYSEL_SD_DDR50 0x0000003D +#define SD0_ITAPDLYSEL_MMC_DDR50 0x00000012 + +#define SD1_ITAPDLYSEL_MASK 0x00FF0000 +#define SD1_ITAPDLYSEL_HSD 0x00150000 +#define SD1_ITAPDLYSEL_SD_DDR50 0x003D0000 +#define SD1_ITAPDLYSEL_MMC_DDR50 0x00120000 + +#define SD0_OTAPDLYENA_MASK 0x00000040 +#define SD0_OTAPDLYENA 0x00000040 +#define SD1_OTAPDLYENA_MASK 0x00400000 +#define SD1_OTAPDLYENA 0x00400000 +#define SD0_OTAPDLYSEL_MASK 0x0000003F +#define SD0_OTAPDLYSEL_MMC_HSD 0x00000006 +#define SD0_OTAPDLYSEL_SD_HSD 0x00000005 +#define SD0_OTAPDLYSEL_SDR50 0x00000003 +#define SD0_OTAPDLYSEL_SDR104_B0 0x00000003 +#define SD0_OTAPDLYSEL_SDR104_B2 0x00000002 +#define SD0_OTAPDLYSEL_SD_DDR50 0x00000004 +#define SD0_OTAPDLYSEL_MMC_DDR50 0x00000006 + +#define SD1_OTAPDLYSEL_MASK 0x003F0000 +#define SD1_OTAPDLYSEL_MMC_HSD 0x00060000 +#define SD1_OTAPDLYSEL_SD_HSD 0x00050000 +#define SD1_OTAPDLYSEL_SDR50 0x00030000 +#define SD1_OTAPDLYSEL_SDR104_B0 0x00030000 +#define SD1_OTAPDLYSEL_SDR104_B2 0x00020000 +#define SD1_OTAPDLYSEL_SD_DDR50 0x00040000 +#define SD1_OTAPDLYSEL_MMC_DDR50 0x00060000 + +#define MMC_BANK2 0x2 + +#define MMC_TIMING_UHS_SDR25 1 +#define MMC_TIMING_UHS_SDR50 2 +#define MMC_TIMING_UHS_SDR104 3 +#define MMC_TIMING_UHS_DDR50 4 +#define MMC_TIMING_MMC_HS200 5 +#define MMC_TIMING_SD_HS 6 +#define MMC_TIMING_MMC_DDR52 7 +#define MMC_TIMING_MMC_HS 8 + +void zynqmp_dll_reset(u8 deviceid) +{ + /* Issue DLL Reset */ + if (deviceid == 0) + zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, + SD0_DLL_RST); + else + zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, + SD1_DLL_RST); + + mdelay(1); + + /* Release DLL Reset */ + if (deviceid == 0) + zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, 0x0); + else + zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, 0x0); +} + +static void arasan_zynqmp_tap_sdr104(u8 deviceid, u8 timing, u8 bank) +{ + if (deviceid == 0) { + /* Program OTAP */ + zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYENA_MASK, + SD0_OTAPDLYENA); + if (bank == MMC_BANK2) + zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, + SD0_OTAPDLYSEL_SDR104_B2); + else + zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, + SD0_OTAPDLYSEL_SDR104_B0); + } else { + /* Program OTAP */ + zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYENA_MASK, + SD1_OTAPDLYENA); + if (bank == MMC_BANK2) + zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, + SD1_OTAPDLYSEL_SDR104_B2); + else + zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, + SD1_OTAPDLYSEL_SDR104_B0); + } +} + +static void arasan_zynqmp_tap_hs(u8 deviceid, u8 timing, u8 bank) +{ + if (deviceid == 0) { + /* Program ITAP */ + zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN_MASK, + SD0_ITAPCHGWIN); + zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYENA_MASK, + SD0_ITAPDLYENA); + zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYSEL_MASK, + SD0_ITAPDLYSEL_HSD); + zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN_MASK, 0x0); + /* Program OTAP */ + zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYENA_MASK, + SD0_OTAPDLYENA); + if (timing == MMC_TIMING_MMC_HS) + zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, + SD0_OTAPDLYSEL_MMC_HSD); + else + zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, + SD0_OTAPDLYSEL_SD_HSD); + } else { + /* Program ITAP */ + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN_MASK, + SD1_ITAPCHGWIN); + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYENA_MASK, + SD1_ITAPDLYENA); + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYSEL_MASK, + SD1_ITAPDLYSEL_HSD); + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN_MASK, 0x0); + /* Program OTAP */ + zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYENA_MASK, + SD1_OTAPDLYENA); + if (timing == MMC_TIMING_MMC_HS) + zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, + SD1_OTAPDLYSEL_MMC_HSD); + else + zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, + SD1_OTAPDLYSEL_SD_HSD); + } +} + +static void arasan_zynqmp_tap_ddr50(u8 deviceid, u8 timing, u8 bank) +{ + if (deviceid == 0) { + /* Program ITAP */ + zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN_MASK, + SD0_ITAPCHGWIN); + zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYENA_MASK, + SD0_ITAPDLYENA); + if (timing == MMC_TIMING_UHS_DDR50) + zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYSEL_MASK, + SD0_ITAPDLYSEL_SD_DDR50); + else + zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYSEL_MASK, + SD0_ITAPDLYSEL_MMC_DDR50); + zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN_MASK, 0x0); + /* Program OTAP */ + zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYENA_MASK, + SD0_OTAPDLYENA); + if (timing == MMC_TIMING_UHS_DDR50) + zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, + SD0_OTAPDLYSEL_SD_DDR50); + else + zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, + SD0_OTAPDLYSEL_MMC_DDR50); + } else { + /* Program ITAP */ + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN_MASK, + SD1_ITAPCHGWIN); + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYENA_MASK, + SD1_ITAPDLYENA); + if (timing == MMC_TIMING_UHS_DDR50) + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYSEL_MASK, + SD1_ITAPDLYSEL_SD_DDR50); + else + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYSEL_MASK, + SD1_ITAPDLYSEL_MMC_DDR50); + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN_MASK, 0x0); + /* Program OTAP */ + zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYENA_MASK, + SD1_OTAPDLYENA); + if (timing == MMC_TIMING_UHS_DDR50) + zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, + SD1_OTAPDLYSEL_SD_DDR50); + else + zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, + SD1_OTAPDLYSEL_MMC_DDR50); + } +} + +static void arasan_zynqmp_tap_sdr50(u8 deviceid, u8 timing, u8 bank) +{ + if (deviceid == 0) { + /* Program OTAP */ + zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYENA_MASK, + SD0_OTAPDLYENA); + zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, + SD0_OTAPDLYSEL_SDR50); + } else { + /* Program OTAP */ + zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYENA_MASK, + SD1_OTAPDLYENA); + zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, + SD1_OTAPDLYSEL_SDR50); + } +} + +void arasan_zynqmp_set_tapdelay(u8 deviceid, u8 timing, u8 bank) +{ + if (deviceid == 0) + zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, + SD0_DLL_RST); + else + zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, + SD1_DLL_RST); + + switch (timing) { + case MMC_TIMING_UHS_SDR25: + arasan_zynqmp_tap_hs(deviceid, timing, bank); + break; + case MMC_TIMING_UHS_SDR50: + arasan_zynqmp_tap_sdr50(deviceid, timing, bank); + break; + case MMC_TIMING_UHS_SDR104: + arasan_zynqmp_tap_sdr104(deviceid, timing, bank); + break; + case MMC_TIMING_UHS_DDR50: + arasan_zynqmp_tap_ddr50(deviceid, timing, bank); + break; + } + + if (deviceid == 0) + zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, 0x0); + else + zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, 0x0); +} diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 2c1561c..e1377cd 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -12,11 +12,18 @@ #include <libfdt.h> #include <malloc.h> #include <sdhci.h> +#include <mmc.h> +#include <asm/arch/hardware.h> +#include <asm/io.h> +#include <zynqmp_tap_delay.h> +#include "mmc_private.h"
#ifndef CONFIG_ZYNQ_SDHCI_MIN_FREQ # define CONFIG_ZYNQ_SDHCI_MIN_FREQ 0 #endif
+DECLARE_GLOBAL_DATA_PTR; + struct arasan_sdhci_plat { struct mmc_config cfg; struct mmc mmc; @@ -24,8 +31,131 @@ struct arasan_sdhci_plat {
struct arasan_sdhci_priv { struct sdhci_host *host; + u8 deviceid; + u8 bank; };
+#if defined(CONFIG_ARCH_ZYNQMP) +static void arasan_zynqmp_dll_reset(struct sdhci_host *host, u8 deviceid) +{ + u16 clk; + unsigned long timeout; + + clk = sdhci_readw(host, SDHCI_CLOCK_CONTROL); + clk &= ~(SDHCI_CLOCK_CARD_EN); + sdhci_writew(host, clk, SDHCI_CLOCK_CONTROL); + + /* Issue DLL Reset */ + zynqmp_dll_reset(deviceid); + + /* Wait max 20 ms */ + timeout = 100; + while (!((clk = sdhci_readw(host, SDHCI_CLOCK_CONTROL)) + & SDHCI_CLOCK_INT_STABLE)) { + if (timeout == 0) { + dev_err(mmc_dev(host->mmc), + ": Internal clock never stabilised.\n"); + return; + } + timeout--; + udelay(1000); + } + + clk |= SDHCI_CLOCK_CARD_EN; + sdhci_writew(host, clk, SDHCI_CLOCK_CONTROL); +} + +static int arasan_sdhci_execute_tuning(struct mmc *mmc, u8 opcode) +{ + struct mmc_cmd cmd; + struct mmc_data data; + u32 ctrl; + struct sdhci_host *host; + struct arasan_sdhci_priv *priv = dev_get_priv(mmc->dev); + u8 tuning_loop_counter = 40; + u8 deviceid; + + debug("%s\n", __func__); + + host = priv->host; + deviceid = priv->deviceid; + + ctrl = sdhci_readw(host, SDHCI_HOST_CTRL2); + ctrl |= SDHCI_CTRL_EXEC_TUNING; + sdhci_writew(host, ctrl, SDHCI_HOST_CTRL2); + + mdelay(1); + + arasan_zynqmp_dll_reset(host, deviceid); + + sdhci_writel(host, SDHCI_INT_DATA_AVAIL, SDHCI_INT_ENABLE); + sdhci_writel(host, SDHCI_INT_DATA_AVAIL, SDHCI_SIGNAL_ENABLE); + + do { + cmd.cmdidx = opcode; + cmd.resp_type = MMC_RSP_R1; + cmd.cmdarg = 0; + + data.blocksize = 64; + data.blocks = 1; + data.flags = MMC_DATA_READ; + + if (tuning_loop_counter-- == 0) + break; + + if (cmd.cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200 && + mmc->bus_width == 8) + data.blocksize = 128; + + sdhci_writew(host, SDHCI_MAKE_BLKSZ(SDHCI_DEFAULT_BOUNDARY_ARG, + data.blocksize), + SDHCI_BLOCK_SIZE); + sdhci_writew(host, data.blocks, SDHCI_BLOCK_COUNT); + sdhci_writew(host, SDHCI_TRNS_READ, SDHCI_TRANSFER_MODE); + + mmc_send_cmd(mmc, &cmd, NULL); + ctrl = sdhci_readw(host, SDHCI_HOST_CTRL2); + + if (cmd.cmdidx == MMC_CMD_SEND_TUNING_BLOCK) + udelay(1); + + } while (ctrl & SDHCI_CTRL_EXEC_TUNING); + + if (tuning_loop_counter < 0) { + ctrl &= ~SDHCI_CTRL_TUNED_CLK; + sdhci_writel(host, ctrl, SDHCI_HOST_CTRL2); + } + + if (!(ctrl & SDHCI_CTRL_TUNED_CLK)) { + debug("%s:Tuning failed\n", __func__); + return -1; + } else { + udelay(1); + arasan_zynqmp_dll_reset(host, deviceid); + } + + /* Enable only interrupts served by the SD controller */ + sdhci_writel(host, SDHCI_INT_DATA_MASK | SDHCI_INT_CMD_MASK, + SDHCI_INT_ENABLE); + /* Mask all sdhci interrupt sources */ + sdhci_writel(host, 0x0, SDHCI_SIGNAL_ENABLE); + + return 0; +} + +static void arasan_sdhci_set_tapdelay(struct sdhci_host *host, u8 uhsmode) +{ + struct arasan_sdhci_priv *priv = dev_get_priv(host->mmc->dev); + + debug("%s, %d:%d, mode:%d\n", __func__, priv->deviceid, priv->bank, + uhsmode); + if ((uhsmode >= MMC_TIMING_UHS_SDR25) && + (uhsmode <= MMC_TIMING_UHS_DDR50)) + arasan_zynqmp_set_tapdelay(priv->deviceid, uhsmode, + priv->bank); +} +#endif + static int arasan_sdhci_probe(struct udevice *dev) { struct arasan_sdhci_plat *plat = dev_get_platdata(dev); @@ -52,6 +182,11 @@ static int arasan_sdhci_probe(struct udevice *dev) host->mmc->dev = dev; upriv->mmc = host->mmc;
+#if defined(CONFIG_ARCH_ZYNQMP) + host->ops->set_delay = arasan_sdhci_set_tapdelay; + host->ops->platform_execute_tuning = arasan_sdhci_execute_tuning; +#endif + return sdhci_probe(dev); }
@@ -66,6 +201,11 @@ static int arasan_sdhci_ofdata_to_platdata(struct udevice *dev) priv->host->name = dev->name; priv->host->ioaddr = (void *)dev_get_addr(dev);
+ priv->deviceid = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "xlnx,device_id", -1); + priv->bank = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "xlnx,mio_bank", -1); + return 0; }
@@ -89,6 +229,6 @@ U_BOOT_DRIVER(arasan_sdhci_drv) = { .ops = &sdhci_ops, .bind = arasan_sdhci_bind, .probe = arasan_sdhci_probe, - .priv_auto_alloc_size = sizeof(struct sdhci_host), + .priv_auto_alloc_size = sizeof(struct arasan_sdhci_priv), .platdata_auto_alloc_size = sizeof(struct arasan_sdhci_plat), }; diff --git a/include/zynqmp_tap_delay.h b/include/zynqmp_tap_delay.h new file mode 100644 index 0000000..14cff9d --- /dev/null +++ b/include/zynqmp_tap_delay.h @@ -0,0 +1,20 @@ +/* + * Xilinx ZynqMP SoC Tap Delay Programming + * + * Copyright (C) 2016 Xilinx, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ZYNQMP_TAP_DELAY_H__ +#define __ZYNQMP_TAP_DELAY_H__ + +#ifdef CONFIG_ARCH_ZYNQMP +void zynqmp_dll_reset(u8 deviceid); +void arasan_zynqmp_set_tapdelay(u8 device_id, u8 uhsmode, u8 bank); +#else +inline void zynqmp_dll_reset(u8 deviceid) {} +inline void arasan_zynqmp_set_tapdelay(u8 device_id, u8 uhsmode, u8 bank) {} +#endif + +#endif
Add quirk if voltage switching to 1.8v is broken, in this case no UHS modes were supported
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mmc/sdhci.c | 3 ++- include/sdhci.h | 1 + 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index a2fcf18..4f29ba1 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -749,7 +749,8 @@ int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, SDHCI_CLOCK_MUL_SHIFT; }
- if (!(cfg->voltages & MMC_VDD_165_195)) + if (!(cfg->voltages & MMC_VDD_165_195) || + (host->quirks & SDHCI_QUIRK_NO_1_8_V)) caps_1 &= ~(SDHCI_SUPPORT_SDR104 | SDHCI_SUPPORT_SDR50 | SDHCI_SUPPORT_DDR50);
diff --git a/include/sdhci.h b/include/sdhci.h index c00beb8..037a2d3 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -228,6 +228,7 @@ #define SDHCI_QUIRK_BROKEN_VOLTAGE (1 << 4) #define SDHCI_QUIRK_WAIT_SEND_CMD (1 << 6) #define SDHCI_QUIRK_USE_WIDE8 (1 << 8) +#define SDHCI_QUIRK_NO_1_8_V (1 << 9)
/* to make gcc happy */ struct sdhci_host;
Update quirk if 1.8 voltage switching is not supported on boards by reading the property "no-1-8-v" from device tree.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mmc/zynq_sdhci.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index e1377cd..124a908 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -33,6 +33,7 @@ struct arasan_sdhci_priv { struct sdhci_host *host; u8 deviceid; u8 bank; + u8 no_1p8; };
#if defined(CONFIG_ARCH_ZYNQMP) @@ -173,6 +174,9 @@ static int arasan_sdhci_probe(struct udevice *dev) host->quirks |= SDHCI_QUIRK_NO_HISPD_BIT; #endif
+ if (priv->no_1p8) + host->quirks |= SDHCI_QUIRK_NO_1_8_V; + ret = sdhci_setup_cfg(&plat->cfg, host, CONFIG_ZYNQ_SDHCI_MAX_FREQ, CONFIG_ZYNQ_SDHCI_MIN_FREQ); host->mmc = &plat->mmc; @@ -205,6 +209,10 @@ static int arasan_sdhci_ofdata_to_platdata(struct udevice *dev) "xlnx,device_id", -1); priv->bank = fdtdec_get_int(gd->fdt_blob, dev->of_offset, "xlnx,mio_bank", -1); + if (fdt_get_property(gd->fdt_blob, dev->of_offset, "no-1-8-v", NULL)) + priv->no_1p8 = 1; + else + priv->no_1p8 = 0;
return 0; }
Add support for eMMC HS200 mode by reading card type from ext_csd and then by switching to HS200 timing mode.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mmc/mmc.c | 24 ++++++++++++++++++------ drivers/mmc/sdhci.c | 18 +++++++++++++----- include/mmc.h | 8 ++++++++ 3 files changed, 39 insertions(+), 11 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index d4ea0c2..7e18a38 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -619,9 +619,16 @@ static int mmc_change_freq(struct mmc *mmc) if (err) return err;
- cardtype = ext_csd[EXT_CSD_CARD_TYPE] & 0xf; + cardtype = ext_csd[EXT_CSD_CARD_TYPE] & 0x3f;
- err = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, EXT_CSD_HS_TIMING, 1); + if (cardtype & EXT_CSD_CARD_TYPE_HS200) + err = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, + EXT_CSD_HS_TIMING, + EXT_CSD_HS_TIMING_HS200); + else + err = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, + EXT_CSD_HS_TIMING, + EXT_CSD_HS_TIMING_HIGH_SPEED);
if (err) return err; @@ -636,8 +643,10 @@ static int mmc_change_freq(struct mmc *mmc) if (!ext_csd[EXT_CSD_HS_TIMING]) return 0;
- /* High Speed is set, there are two types: 52MHz and 26MHz */ - if (cardtype & EXT_CSD_CARD_TYPE_52) { + /* High Speed is set, there are three types: 200MHZ, 52MHz and 26MHz */ + if (cardtype & EXT_CSD_CARD_TYPE_HS200) { + mmc->card_caps |= MMC_MODE_HS200; + } else if (cardtype & EXT_CSD_CARD_TYPE_52) { if (cardtype & EXT_CSD_CARD_TYPE_DDR_1_8V) mmc->card_caps |= MMC_MODE_DDR_52MHz; mmc->card_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS; @@ -1659,7 +1668,9 @@ static int mmc_startup(struct mmc *mmc) if (err) return err;
- if (mmc->card_caps & MMC_MODE_HS) { + if (mmc->card_caps & MMC_MODE_HS200) { + mmc->tran_speed = 200000000; + } else if (mmc->card_caps & MMC_MODE_HS) { if (mmc->card_caps & MMC_MODE_HS_52MHz) mmc->tran_speed = 52000000; else @@ -1670,7 +1681,8 @@ static int mmc_startup(struct mmc *mmc) mmc_set_clock(mmc, mmc->tran_speed);
if ((mmc->card_caps & (MMC_MODE_UHS_SDR50 | - MMC_MODE_UHS_SDR104)) && + MMC_MODE_UHS_SDR104 | + MMC_MODE_HS200)) && (mmc->cfg->host_caps & MMC_MODE_NEEDS_TUNING)) { err = mmc_execute_tuning(mmc); if (err) diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 4f29ba1..6496bdb 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -157,7 +157,8 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, /* We shouldn't wait for data inihibit for stop commands, even though they might use busy signaling */ if ((cmd->cmdidx == MMC_CMD_STOP_TRANSMISSION) || - (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK)) + (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK) || + (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200)) mask &= ~SDHCI_DATA_INHIBIT;
while (sdhci_readl(host, SDHCI_PRESENT_STATE) & mask) { @@ -179,7 +180,8 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, mask = SDHCI_INT_RESPONSE;
/* only buffer read ready interrupt whil tuning */ - if (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK) + if ((cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK) || + (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200)) mask = SDHCI_INT_DATA_AVAIL;
if (!(cmd->resp_type & MMC_RSP_PRESENT)) @@ -197,7 +199,8 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, flags |= SDHCI_CMD_CRC; if (cmd->resp_type & MMC_RSP_OPCODE) flags |= SDHCI_CMD_INDEX; - if (data || (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK)) + if (data || (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK) || + (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200)) flags |= SDHCI_CMD_DATA;
/* Set Transfer mode regarding to data flag */ @@ -407,8 +410,13 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) if (clock == 0) return 0;
- if (mmc->is_uhs && host->ops->set_delay) - host->ops->set_delay(host, mmc->uhsmode); + if (((mmc->card_caps & MMC_MODE_HS200) || mmc->is_uhs) && + host->ops->set_delay) { + if (mmc->is_uhs) + host->ops->set_delay(host, mmc->uhsmode); + else + host->ops->set_delay(host, MMC_TIMING_HS200); + }
if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) { /* diff --git a/include/mmc.h b/include/mmc.h index 56395ee..e0b5510 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -223,6 +223,13 @@ #define EXT_CSD_CARD_TYPE_DDR_1_2V (1 << 3) #define EXT_CSD_CARD_TYPE_DDR_52 (EXT_CSD_CARD_TYPE_DDR_1_8V \ | EXT_CSD_CARD_TYPE_DDR_1_2V) +#define EXT_CSD_CARD_TYPE_HS200_1_8V (1 << 4) +#define EXT_CSD_CARD_TYPE_HS200_1_2V (1 << 5) +#define EXT_CSD_CARD_TYPE_HS200 (EXT_CSD_CARD_TYPE_HS200_1_8V \ + | EXT_CSD_CARD_TYPE_HS200_1_2V) + +#define EXT_CSD_HS_TIMING_HIGH_SPEED 1 +#define EXT_CSD_HS_TIMING_HS200 2
#define EXT_CSD_BUS_WIDTH_1 0 /* Card is in 1 bit mode */ #define EXT_CSD_BUS_WIDTH_4 1 /* Card is in 4 bit mode */ @@ -293,6 +300,7 @@ #define MMC_TIMING_UHS_SDR50 2 #define MMC_TIMING_UHS_SDR104 3 #define MMC_TIMING_UHS_DDR50 4 +#define MMC_TIMING_HS200 5 #define MMC_TIMING_HS 1
Sets the tapdelays for eMMC HS200 mode support for ZynqMP as tapdelays needs to be programmed for it to work
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- board/xilinx/zynqmp/tap_delays.c | 1 + drivers/mmc/zynq_sdhci.c | 2 +- 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/board/xilinx/zynqmp/tap_delays.c b/board/xilinx/zynqmp/tap_delays.c index d57587e..aa0825a 100644 --- a/board/xilinx/zynqmp/tap_delays.c +++ b/board/xilinx/zynqmp/tap_delays.c @@ -235,6 +235,7 @@ void arasan_zynqmp_set_tapdelay(u8 deviceid, u8 timing, u8 bank) arasan_zynqmp_tap_sdr50(deviceid, timing, bank); break; case MMC_TIMING_UHS_SDR104: + case MMC_TIMING_MMC_HS200: arasan_zynqmp_tap_sdr104(deviceid, timing, bank); break; case MMC_TIMING_UHS_DDR50: diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 124a908..4799e9a 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -151,7 +151,7 @@ static void arasan_sdhci_set_tapdelay(struct sdhci_host *host, u8 uhsmode) debug("%s, %d:%d, mode:%d\n", __func__, priv->deviceid, priv->bank, uhsmode); if ((uhsmode >= MMC_TIMING_UHS_SDR25) && - (uhsmode <= MMC_TIMING_UHS_DDR50)) + (uhsmode <= MMC_TIMING_HS200)) arasan_zynqmp_set_tapdelay(priv->deviceid, uhsmode, priv->bank); }
Split the patches as mmc side and sdhci side..after that, i will review each patches.
And did you consider about accessing to boot partition? As i know, boot partition can't support HS200.
Best Regards, Jaehoon Chung
Hi Jaehoon,
-----Original Message----- From: Jaehoon Chung [mailto:jh80.chung@samsung.com] Sent: Thursday, January 19, 2017 10:30 AM To: Siva Durga Prasad Paladugu sivadur@xilinx.com; u-boot@lists.denx.de Cc: afleming@gmail.com; Michal Simek michals@xilinx.com; Siva Durga Prasad Paladugu sivadur@xilinx.com Subject: Re: [U-Boot] [PATCH 00/12] Add support for SD3.0 and eMMC HS200
Do you mean to split changes of mmc.c and sdhci.c separately? if so, will do that.
No, didn't consider that yet.
Regards, Siva
Hi Siva,
On 01/19/2017 02:47 PM, Siva Durga Prasad Paladugu wrote:
Hi Jaehoon,
Yes. If you can do that, it's helpful to me for reviewing. :)
Maybe..It needs to consider about this case..because we can access to boot partition with boot command. I think it's not difficult. When switch the partition, checking the speed mode and if mode is HS200, switch to DDR50 or SDR50..etc.
Anyway, Thanks for working this. I will wait for your next patches.
Regards, Siva
Jaehoon Chung
Michal Simek
