[PATCH v6 00/11] An effort to bring DT bindings compliance within U-Boot
Changes in v6: -------------- - v6_dt: https://github.com/b49020/u-boot/tree/v6_dt - Patch #3: Incorporate fix for sandbox CI failure. - Patch #6: Incorporate shell script comments from Marek. - Patch #8: Incorporate documentation review comments from Paul.
Changes in v5: -------------- - Rebased on tip of master (050a9b981d6a835133521b599be3ae189ce70f41) - Created v5_dt branch for testing purposes: https://github.com/b49020/u-boot/tree/v5_dt - Patch #6: Added support to cherry-pick fixes in subtree update script. Also, used https:// instead of git://. - Patch #7: Fixed inappropriate documentation update. - Patch #8: Document how to cherry-pick fixes from devicetree-rebasing tree.
Changes in v4: -------------- - Switched subtree to be imported as dts/upstream sub-directory rather than devicetree-rebasing sub-directory to better suite U-Boot directory structure. - Since we now have v6.7-dts tag available now, so switch subtree to that from its beginning. - Patch #2: Incorporate build fix to adjust Bindings Makefile rules to old U-Boot Kbuild infrastructure. - Patch #3: Incorporate fix to resolve rk3399 migration issue reported by Simon. - Patch #4: New patch to reuse upstream DT includes by U-Boot as per Brian's use-case for TI K3 SoCs. - Patch #5: Added a note to OF_UPSTREAM Kconfig option. - Patch #6: New patch to add script dts/update-dts-subtree.sh as per Rob's comments. - Patch #7: Separate patch to align documentation to use Kconfig symbols instead. - Patch #8: Clarify subtree uprev schedule as a separate documentation section. Also, fixed documentation typos. - Patch #9: Added commit description.
Changes in v3: -------------- - Patch #4: Minor commit message update - Patch #5: Replace CONFIG_* with Kconfig options - Patch #7: Dropped Makefile portion and enabled OF_UPSTREAM for SoC instead. - Patch #1, #3, #6 and #8: Picked up review tags
Changes in v2: -------------- - Patch #1: excluded gitab CI config check and added commit description. - Patch #3: s/UBOOT_DTSI_LOC/u_boot_dtsi_loc/ - Patch #4: s/DEVICE_TREE_LOC/dt_dir/ and s/U-boot/U-Boot/ - Patch #5: s/U-boot/U-Boot/ - Patch #6 and #7: Picked up review tags
Prerequisite ------------
This patch series requires devicetree-rebasing git repo to be added as a subtree to the main U-Boot repo via:
$ git subtree add --prefix dts/upstream \ https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... \ v6.7-dts --squash
Background ----------
This effort started while I was reviewing patch series corresponding to Qcom platforms [1] which was about to import modified devicetree source files from Linux kernel. I suppose keeping devicetree files sync with Linux kernel without any DT bindings schema validation has been a pain for U-Boot SoC/platform maintainers. There has been past discussions about a single DT repo but that hasn't come up and Linux kernel remained the place where DT source files as well as bindings are placed and maintained.
However, Linux kernel DT maintainers proposed [2] for U-Boot to rather use devicetree-rebasing repo [3] which is a forked copy from Linux kernel for DT source files as well as bindings. It is tagged at every Linux kernel major release or intermideate release candidates. So here I have tried to reuse that to bring DT bingings compliance as well as a standard way to maintain a regular sync of DT source files with Linux kernel.
In order to maintain devicetree files sync, U-Boot will maintains a Git subtree for devicetee-rebasing repo as `dts/upstream` sub-directory. U-Boot will regularly sync `dts/upstream/` subtree whenever the next window opens with the next available kernel major release. `dts/update-dts-subtree.sh` script provides a wrapper around git subtree pull command, usage from the top level U-Boot source tree, run:
$ ./dts/update-dts-subtree.sh pull <devicetree-rebasing-release-tag>
If required it is also possible to cherry-pick fixes from devicetree-rebasing tree prior to next sync, usage:
$ ./dts/update-dts-subtree.sh pick <devicetree-rebasing-commit-id>
The RFC/prototype for this series has been discussed with Linux DT maintainers as well as U-Boot maintainers here [4]. Now we would like to reach out to wider U-Boot community to seek feedback.
[1] https://lore.kernel.org/all/CAFA6WYMLUD9cnkr=R0Uur+1UeTMkKjM2zDdMJtXb3nmrLk+... [2] https://lore.kernel.org/all/CAL_JsqKEjv2tSGmT+0ZiO7_qbBfhTycbGnhJhYpKDFzfO9j... [3] https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... [4] https://github.com/u-boot/u-boot/pull/451
Changes -------
Traditionally, U-Boot placed copies of devicetree source files from Linux kernel into `arch/<arch>/dts/<name>.dts` which can be selected via setting "<name>" when prompted for `DEFAULT_DEVICE_TREE` by Kconfig.
SoC/board maintainers are encouraged to migrate to use synced copies from `dts/upstream/src/<arch>/<vendor>`. To do that enable `OF_UPSTREAM` for the SoC being used via Kconfig and set up "<vendor>/<name>" when prompted for `DEFAULT_DEVICE_TREE` by Kconfig.
An example have been shown for Amlogic meson-gxbb SoC and corresponding derived boards via patch #10 and #11.
Devicetree bindings schema checks ---------------------------------
With devicetee-rebasing Git subtree, the devicetree bindings are also regularly synced with Linux kernel as `dts/upstream/Bindings/` sub-directory. This allows U-Boot to run devicetree bindings schema checks which will bring compliance to U-Boot core/drivers regarding usage of devicetree.
Dependencies ------------
The DT schema project must be installed in order to validate the DT schema binding documents and validate DTS files using the DT schema. The DT schema project can be installed with pip:
$ pip3 install dtschema
Note that 'dtschema' installation requires 'swig' and Python development files installed first. On Debian/Ubuntu systems:
$ apt install swig python3-dev
Several executables (dt-doc-validate, dt-mk-schema, dt-validate) will be installed. Ensure they are in your PATH (~/.local/bin by default).
Recommended is also to install yamllint (used by dtschema when present).
$ apt install yamllint
Running checks --------------
In order to perform validation of DTB files, use the ``dtbs_check`` target:
$ make dtbs_check
It is also possible to run checks with a subset of matching schema files by setting the ``DT_SCHEMA_FILES`` variable to 1 or more specific schema files or patterns (partial match of a fixed string). Each file or pattern should be separated by ':'.
$ make dtbs_check DT_SCHEMA_FILES=trivial-devices.yaml:rtc.yaml $ make dtbs_check DT_SCHEMA_FILES=/gpio/ $ make dtbs_check DT_SCHEMA_FILES=trivial-devices.yaml
Sumit Garg (11): CI: Exclude devicetree-rebasing subtree for CONFIG checks Makefile: Add support for DT bindings schema checks scripts/Makefile.lib: Statically define *-u-boot.dtsi files location Makefile: Allow upstream DT subtree to provide DT includes dts: Add alternative location for upstream DTB builds dts: Add script to uprev dts/upstream subtree doc: devicetree: Align documentation to use Kconfig options doc: devicetree: Updates for devicetree-rebasing subtree MAINTAINERS: Add myself as devicetree-rebasing maintainer dts: meson-gxbb: Switch to using upstream DT dts: meson-gxbb: Drop redundant devicetree files
.azure-pipelines.yml | 3 +- .gitlab-ci.yml | 3 +- MAINTAINERS | 5 + Makefile | 23 +- arch/arm/dts/Makefile | 8 - arch/arm/dts/meson-gxbb-kii-pro.dts | 140 ---- arch/arm/dts/meson-gxbb-nanopi-k2.dts | 426 ------------ arch/arm/dts/meson-gxbb-odroidc2.dts | 414 ----------- arch/arm/dts/meson-gxbb-p200.dts | 100 --- arch/arm/dts/meson-gxbb-p201.dts | 26 - arch/arm/dts/meson-gxbb-p20x.dtsi | 250 ------- arch/arm/dts/meson-gxbb-wetek-hub.dts | 58 -- arch/arm/dts/meson-gxbb-wetek-play2.dts | 119 ---- arch/arm/dts/meson-gxbb-wetek.dtsi | 292 -------- arch/arm/dts/meson-gxbb.dtsi | 870 ------------------------ arch/arm/mach-meson/Kconfig | 1 + configs/nanopi-k2_defconfig | 2 +- configs/odroid-c2_defconfig | 2 +- configs/p200_defconfig | 2 +- configs/p201_defconfig | 2 +- configs/videostrong-kii-pro_defconfig | 2 +- configs/wetek-hub_defconfig | 2 +- configs/wetek-play2_defconfig | 2 +- doc/develop/devicetree/control.rst | 159 +++-- dts/Kconfig | 16 + dts/Makefile | 17 +- dts/update-dts-subtree.sh | 48 ++ dts/upstream/Bindings/Makefile | 6 +- dts/upstream/src/arm64/Makefile | 14 + scripts/Makefile.lib | 50 +- 30 files changed, 283 insertions(+), 2779 deletions(-) delete mode 100644 arch/arm/dts/meson-gxbb-kii-pro.dts delete mode 100644 arch/arm/dts/meson-gxbb-nanopi-k2.dts delete mode 100644 arch/arm/dts/meson-gxbb-odroidc2.dts delete mode 100644 arch/arm/dts/meson-gxbb-p200.dts delete mode 100644 arch/arm/dts/meson-gxbb-p201.dts delete mode 100644 arch/arm/dts/meson-gxbb-p20x.dtsi delete mode 100644 arch/arm/dts/meson-gxbb-wetek-hub.dts delete mode 100644 arch/arm/dts/meson-gxbb-wetek-play2.dts delete mode 100644 arch/arm/dts/meson-gxbb-wetek.dtsi delete mode 100644 arch/arm/dts/meson-gxbb.dtsi create mode 100755 dts/update-dts-subtree.sh create mode 100644 dts/upstream/src/arm64/Makefile
Since devicetree-rebasing is an external repo with its own coding style, exclude it from Azure and gitlab CI CONFIG checks.
Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Sumit Garg sumit.garg@linaro.org ---
Changes in v6: - None
Changes in v5: - None
Changes in v4: - Switched subtree to be imported as dts/upstream sub-directory rather than devicetree-rebasing sub-directory to better suite U-Boot directory structure.
Changes in v3: - Picked up review tags
Changes in v2: - excluded gitab CI config check and added commit description.
.azure-pipelines.yml | 3 ++- .gitlab-ci.yml | 3 ++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index e2646783ee62..1d73215afbae 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -65,7 +65,8 @@ stages: # have no matches. - script: git grep -E '^#[[:blank:]]*(define|undef)[[:blank:]]*CONFIG_' :^doc/ :^arch/arm/dts/ :^scripts/kconfig/lkc.h - :^include/linux/kconfig.h :^tools/ && exit 1 || exit 0 + :^include/linux/kconfig.h :^tools/ :^dts/upstream/ && + exit 1 || exit 0
- job: docs displayName: 'Build documentation' diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 278a2e2bbf31..8bfbadd6c89f 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -161,7 +161,8 @@ check for new CONFIG symbols outside Kconfig: # have no matches. - git grep -E '^#[[:blank:]]*(define|undef)[[:blank:]]*CONFIG_' :^doc/ :^arch/arm/dts/ :^scripts/kconfig/lkc.h - :^include/linux/kconfig.h :^tools/ && exit 1 || exit 0 + :^include/linux/kconfig.h :^tools/ :^dts/upstream/ && + exit 1 || exit 0
# build documentation docs:
This adds the build infrastructure for checking DT binding schema documents and validating dtb files using the binding schema. Here we use devicetree-rebasing subtree to provide the DT bindings. Along with that adapt dts/upstream/Bindings/Makefile to align with old U-Boot Kbuild infrastructure.
Dependency: -----------
The DT schema project must be installed in order to validate the DT schema binding documents and validate DTS files using the DT schema. The DT schema project can be installed with pip::
Note that 'dtschema' installation requires 'swig' and Python development files installed first. On Debian/Ubuntu systems::
Testing: --------
Build dts files and check using DT binding schema: $ make dtbs_check
Optionally, DT_SCHEMA_FILES can be passed in with a schema file(s) to use for validation. This makes it easier to find and fix errors generated by a specific schema.
Note, at this point dtbs_check is an optional build target as there are many warnings generated due to custom DT properties used by many platforms in u-boot. It is expected with these checks that compliance with DT bindings to take place. Once that's done it can be added to CI builds to remain compliant with DT bindings.
Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org Signed-off-by: Sumit Garg sumit.garg@linaro.org ---
Changes in v4: - Switched subtree to be imported as dts/upstream sub-directory rather than devicetree-rebasing sub-directory to better suite U-Boot directory structure. - Incorporate build fix to adjust Bindings Makefile rules to old U-Boot Kbuild infrastructure.
Changes in v3: - None
Changes in v2: - None
Makefile | 20 ++++++++++++++++++-- dts/upstream/Bindings/Makefile | 6 +++--- scripts/Makefile.lib | 17 +++++++++++++++-- 3 files changed, 36 insertions(+), 7 deletions(-)
diff --git a/Makefile b/Makefile index 3b5db90df6f9..9604a4c517e5 100644 --- a/Makefile +++ b/Makefile @@ -1158,12 +1158,28 @@ endif @# disabling OF_BOARD. $(call cmd,ofcheck,$(KCONFIG_CONFIG))
-PHONY += dtbs +PHONY += dtbs dtbs_check dtbs: dts/dt.dtb @: -dts/dt.dtb: u-boot +dts/dt.dtb: dtbs_prepare u-boot $(Q)$(MAKE) $(build)=dts dtbs
+dtbs_prepare: prepare3 + +ifneq ($(filter dtbs_check, $(MAKECMDGOALS)),) +export CHECK_DTBS=y +endif + +ifneq ($(CHECK_DTBS),) +dtbs_prepare: dt_binding_check +endif + +dtbs_check: dt_binding_check dtbs + +DT_BINDING_DIR := dts/upstream/Bindings +dt_binding_check: scripts_dtc + $(Q)$(MAKE) $(build)=$(DT_BINDING_DIR) $(DT_BINDING_DIR)/processed-schema.json + quiet_cmd_copy = COPY $@ cmd_copy = cp $< $@
diff --git a/dts/upstream/Bindings/Makefile b/dts/upstream/Bindings/Makefile index 3e886194b043..e799963a599d 100644 --- a/dts/upstream/Bindings/Makefile +++ b/dts/upstream/Bindings/Makefile @@ -47,9 +47,9 @@ quiet_cmd_mk_schema = SCHEMA $@ rm -f $$f
define rule_chkdt - $(if $(DT_SCHEMA_LINT),$(call cmd,yamllint),) - $(call cmd,chk_bindings) - $(call cmd,mk_schema) + $(if $(DT_SCHEMA_LINT),$(call echo-cmd,yamllint) $(cmd_yamllint),); \ + $(call echo-cmd,chk_bindings) $(cmd_chk_bindings); \ + $(call echo-cmd,mk_schema) $(cmd_mk_schema) endef
DT_DOCS = $(patsubst $(srctree)/%,%,$(shell $(find_all_cmd))) diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 1ca84195c997..f82b3169e874 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -356,8 +356,21 @@ endif
dtsi_include_list_deps = $(addprefix $(obj)/,$(subst $(quote),,$(dtsi_include_list)))
-$(obj)/%.dtb: $(src)/%.dts $(DTC) $(dtsi_include_list_deps) FORCE - $(call if_changed_dep,dtc) +ifneq ($(CHECK_DTBS),) +DT_CHECKER ?= dt-validate +DT_CHECKER_FLAGS ?= $(if $(DT_SCHEMA_FILES),-l $(DT_SCHEMA_FILES),-m) +DT_BINDING_DIR := dts/upstream/Bindings +DT_TMP_SCHEMA := $(objtree)/$(DT_BINDING_DIR)/processed-schema.json + +quiet_cmd_dtb = DTC_CHK $@ + cmd_dtb = $(cmd_dtc) ; $(DT_CHECKER) $(DT_CHECKER_FLAGS) -u $(srctree)/$(DT_BINDING_DIR) -p $(DT_TMP_SCHEMA) $@ || true +else +quiet_cmd_dtb = $(quiet_cmd_dtc) + cmd_dtb = $(cmd_dtc) +endif + +$(obj)/%.dtb: $(src)/%.dts $(DTC) $(dtsi_include_list_deps) $(DT_TMP_SCHEMA) FORCE + $(call if_changed_dep,dtb)
pre-tmp = $(subst $(comma),_,$(dot-target).pre.tmp) dtc-tmp = $(subst $(comma),_,$(dot-target).dts.tmp)
Allow u-boot to build DTB from a different directory tree such that *-u-boot.dtsi files can be included from a common location. Currently that location is arch/$(ARCH)/dts/, so statically define that common location.
This is needed for platform owners to start building DTB files from devicetree-rebasing directory but still being able to include *-u-boot.dtsi files.
Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Signed-off-by: Sumit Garg sumit.garg@linaro.org ---
Changes in v6: - Incorporate fix for sandbox CI failure.
Changes in v4: - Incorporate fix to resolve rk3399 migration issue reported by Simon.
Changes in v2: - s/UBOOT_DTSI_LOC/u_boot_dtsi_loc/
scripts/Makefile.lib | 30 +++++++++++++++++------------- 1 file changed, 17 insertions(+), 13 deletions(-)
diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index f82b3169e874..9e38d75443c9 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -159,18 +159,20 @@ cpp_flags = -Wp,-MD,$(depfile) $(NOSTDINC_FLAGS) $(UBOOTINCLUDE) \ ld_flags = $(KBUILD_LDFLAGS) $(ldflags-y) $(LDFLAGS_$(@F))
# Try these files in order to find the U-Boot-specific .dtsi include file -u_boot_dtsi_options = $(strip $(wildcard $(dir $<)$(basename $(notdir $<))-u-boot.dtsi) \ - $(wildcard $(dir $<)$(subst $",,$(CONFIG_SYS_SOC))-u-boot.dtsi) \ - $(wildcard $(dir $<)$(subst $",,$(CONFIG_SYS_CPU))-u-boot.dtsi) \ - $(wildcard $(dir $<)$(subst $",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi) \ - $(wildcard $(dir $<)u-boot.dtsi)) +u_boot_dtsi_loc = $(srctree)/arch/$(ARCH)/dts/ + +u_boot_dtsi_options = $(strip $(wildcard $(u_boot_dtsi_loc)$(basename $(notdir $<))-u-boot.dtsi) \ + $(wildcard $(u_boot_dtsi_loc)$(subst $",,$(CONFIG_SYS_SOC))-u-boot.dtsi) \ + $(wildcard $(u_boot_dtsi_loc)$(subst $",,$(CONFIG_SYS_CPU))-u-boot.dtsi) \ + $(wildcard $(u_boot_dtsi_loc)$(subst $",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi) \ + $(wildcard $(u_boot_dtsi_loc)u-boot.dtsi))
u_boot_dtsi_options_raw = $(warning Automatic .dtsi inclusion: options: \ - $(dir $<)$(basename $(notdir $<))-u-boot.dtsi \ - $(dir $<)$(subst $",,$(CONFIG_SYS_SOC))-u-boot.dtsi \ - $(dir $<)$(subst $",,$(CONFIG_SYS_CPU))-u-boot.dtsi \ - $(dir $<)$(subst $",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi \ - $(dir $<)u-boot.dtsi ... \ + $(u_boot_dtsi_loc)$(basename $(notdir $<))-u-boot.dtsi \ + $(u_boot_dtsi_loc)$(subst $",,$(CONFIG_SYS_SOC))-u-boot.dtsi \ + $(u_boot_dtsi_loc)$(subst $",,$(CONFIG_SYS_CPU))-u-boot.dtsi \ + $(u_boot_dtsi_loc)$(subst $",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi \ + $(u_boot_dtsi_loc)u-boot.dtsi ... \ found: $(if $(u_boot_dtsi_options),"$(u_boot_dtsi_options)",nothing!))
# Uncomment for debugging @@ -190,6 +192,7 @@ dtsi_include_list += $(CONFIG_DEVICE_TREE_INCLUDES) dtc_cpp_flags = -Wp,-MD,$(depfile).pre.tmp -nostdinc \ $(UBOOTINCLUDE) \ -I$(dir $<) \ + -I$(u_boot_dtsi_loc) \ -I$(srctree)/arch/$(ARCH)/dts/include \ -I$(srctree)/include \ -D__ASSEMBLY__ \ @@ -328,7 +331,7 @@ cmd_dtc = mkdir -p $(dir ${dtc-tmp}) ; \ echo '$(pound)include "$(f)"' >> $(pre-tmp);) \ $(HOSTCC) -E $(dtc_cpp_flags) -x assembler-with-cpp -o $(dtc-tmp) $(pre-tmp) ; \ $(DTC) -O dtb -o $@ -b 0 \ - -i $(dir $<) $(DTC_FLAGS) \ + -i $(dir $<) -i $(u_boot_dtsi_loc) $(DTC_FLAGS) \ -d $(depfile).dtc.tmp $(dtc-tmp) || \ (echo "Check $(shell pwd)/$(pre-tmp) for errors" && false) \ ; \ @@ -350,12 +353,13 @@ capsule_esl_input_file=$(srctree)/lib/efi_loader/capsule_esl.dtsi.in capsule_esl_dtsi = .capsule_esl.dtsi capsule_esl_path=$(abspath $(srctree)/$(subst $(quote),,$(CONFIG_EFI_CAPSULE_ESL_FILE)))
+dtsi_include_list_deps := $(addprefix $(u_boot_dtsi_loc),$(subst $(quote),,$(dtsi_include_list))) + ifdef CONFIG_EFI_CAPSULE_AUTHENTICATE dtsi_include_list += $(capsule_esl_dtsi) +dtsi_include_list_deps += $(obj)/$(capsule_esl_dtsi) endif
-dtsi_include_list_deps = $(addprefix $(obj)/,$(subst $(quote),,$(dtsi_include_list))) - ifneq ($(CHECK_DTBS),) DT_CHECKER ?= dt-validate DT_CHECKER_FLAGS ?= $(if $(DT_SCHEMA_FILES),-l $(DT_SCHEMA_FILES),-m)
Allow platforms to reuse DT headers and dtsi includes directly form upstream DT subtree which will be frequently synced with Linux kernel. This will further allow us to drop corresponding DT includes copy from U-Boot tree.
Also, since the DT includes from upstream DT subtree are done after DT includes from U-Boot tree, so it shouldn't cause any conflicts.
Tested-by: Bryan Brattlof bb@ti.com Signed-off-by: Sumit Garg sumit.garg@linaro.org ---
Changes in v4: - New patch to reuse upstream DT includes by U-Boot as per Brian's use-case for TI K3 SoCs.
Makefile | 3 ++- scripts/Makefile.lib | 5 +++++ 2 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 9604a4c517e5..0f0c7f30d271 100644 --- a/Makefile +++ b/Makefile @@ -835,7 +835,8 @@ UBOOTINCLUDE := \ -I$(srctree)/arch/arm/thumb1/include), \ -I$(srctree)/arch/arm/thumb1/include)) \ -I$(srctree)/arch/$(ARCH)/include \ - -include $(srctree)/include/linux/kconfig.h + -include $(srctree)/include/linux/kconfig.h \ + -I$(srctree)/dts/upstream/include
NOSTDINC_FLAGS += -nostdinc -isystem $(shell $(CC) -print-file-name=include)
diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 9e38d75443c9..12857316c582 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -189,12 +189,17 @@ dtsi_include_list = $(strip $(u_boot_dtsi_options_debug) \ dtsi_include_list += $(CONFIG_DEVICE_TREE_INCLUDES)
# Modified for U-Boot +upstream_dtsi_include = $(addprefix -I, $(srctree)/dts/upstream/src/ \ + $(sort $(dir $(wildcard $(srctree)/dts/upstream/src/$(ARCH)/*/*))) \ + $(if (CONFIG_ARM64), \ + $(sort $(dir $(wildcard $(srctree)/dts/upstream/src/arm64/*/*))))) dtc_cpp_flags = -Wp,-MD,$(depfile).pre.tmp -nostdinc \ $(UBOOTINCLUDE) \ -I$(dir $<) \ -I$(u_boot_dtsi_loc) \ -I$(srctree)/arch/$(ARCH)/dts/include \ -I$(srctree)/include \ + $(upstream_dtsi_include) \ -D__ASSEMBLY__ \ -undef -D__DTS__
Allow platform owners to mirror devicetree files from devitree-rebasing directory into dts/upstream/src/$(ARCH) (special case for arm64). Then build then along with any *-u-boot.dtsi file present in arch/$(ARCH)/dts directory. Also add a new Makefile for arm64.
This will help easy migration for platforms which currently are compliant with upstream Linux kernel devicetree files.
Changes in v4: - Switched subtree to be imported as dts/upstream sub-directory rather than devicetree-rebasing sub-directory to better suite U-Boot directory structure. - Added a note to OF_UPSTREAM Kconfig option.
Changes in v3: - Minor commit message update
Changes in v2: - s/DEVICE_TREE_LOC/dt_dir/ and s/U-boot/U-Boot/
dts/Kconfig | 16 ++++++++++++++++ dts/Makefile | 17 ++++++++++++++--- dts/upstream/src/arm64/Makefile | 14 ++++++++++++++ 3 files changed, 44 insertions(+), 3 deletions(-) create mode 100644 dts/upstream/src/arm64/Makefile
diff --git a/dts/Kconfig b/dts/Kconfig index 00c0aeff893b..09789d3e18b3 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -85,6 +85,22 @@ config OF_LIVE enables a live tree which is available after relocation, and can be adjusted as needed.
+config OF_UPSTREAM + bool "Enable use of devicetree imported from Linux kernel release" + help + Traditionally, U-Boot platforms used to have their custom devicetree + files or copy devicetree files from Linux kernel which are hard to + maintain and can usually get out-of-sync from Linux kernel. This + option enables platforms to migrate to devicetree-rebasing repo where + a regular sync will be maintained every major Linux kernel release + cycle. However, platforms can still have some custom u-boot specific + bits maintained as part of *-u-boot.dtsi files. + + Note: This option should be set in Kconfig, for the SoC as a whole. + However, newer boards whose devicetree source files haven't landed in + the dts/upstream subtree, they can override this option to have the + DT build from existing U-Boot tree location instead. + choice prompt "Provider of DTB for DT control" depends on OF_CONTROL diff --git a/dts/Makefile b/dts/Makefile index 3437e54033db..d6c2c9daf31d 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -10,10 +10,20 @@ ifeq ($(DEVICE_TREE),) DEVICE_TREE := unset endif
+ifeq ($(CONFIG_OF_UPSTREAM),y) +ifeq ($(CONFIG_ARM64),y) +dt_dir := dts/upstream/src/arm64 +else +dt_dir := dts/upstream/src/$(ARCH) +endif +else +dt_dir := arch/$(ARCH)/dts +endif + ifneq ($(EXT_DTB),) DTB := $(EXT_DTB) else -DTB := arch/$(ARCH)/dts/$(DEVICE_TREE).dtb +DTB := $(dt_dir)/$(DEVICE_TREE).dtb endif
$(obj)/dt-$(SPL_NAME).dtb: dts/dt.dtb $(objtree)/tools/fdtgrep FORCE @@ -41,7 +51,7 @@ $(DTB): arch-dtbs
PHONY += arch-dtbs arch-dtbs: - $(Q)$(MAKE) $(build)=arch/$(ARCH)/dts dtbs + $(Q)$(MAKE) $(build)=$(dt_dir) dtbs
ifeq ($(CONFIG_SPL_BUILD),y) obj-$(CONFIG_OF_EMBED) := dt-spl.dtb.o @@ -65,4 +75,5 @@ clean-files := dt.dtb.S # Let clean descend into dts directories subdir- += ../arch/arc/dts ../arch/arm/dts ../arch/m68k/dts ../arch/microblaze/dts \ ../arch/mips/dts ../arch/nios2/dts ../arch/powerpc/dts ../arch/riscv/dts \ - ../arch/sandbox/dts ../arch/sh/dts ../arch/x86/dts ../arch/xtensa/dts + ../arch/sandbox/dts ../arch/sh/dts ../arch/x86/dts ../arch/xtensa/dts \ + ./upstream/src/arm64 ./upstream/src/$(ARCH) diff --git a/dts/upstream/src/arm64/Makefile b/dts/upstream/src/arm64/Makefile new file mode 100644 index 000000000000..9a8f6aa35846 --- /dev/null +++ b/dts/upstream/src/arm64/Makefile @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: GPL-2.0+ + +include $(srctree)/scripts/Makefile.dts + +targets += $(dtb-y) + +# Add any required device tree compiler flags here +DTC_FLAGS += -a 0x8 + +PHONY += dtbs +dtbs: $(addprefix $(obj)/, $(dtb-y)) + @: + +clean-files := */*.dtb */*.dtbo
dts/update-dts-subtree.sh is just a wrapper around git subtree commands. Usage from the top level U-Boot source tree, run:
$ ./dts/update-dts-subtree.sh pull <release-tag> $ ./dts/update-dts-subtree.sh pick <commit-id>
Changes in v6: - Incorporate shell script comments from Marek.
Changes in v5: - Added support to cherry-pick fixes in subtree update script. Also, used https:// instead of git://.
Changes in v4: - New patch to add script dts/update-dts-subtree.sh as per Rob's comments.
dts/update-dts-subtree.sh | 48 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+) create mode 100755 dts/update-dts-subtree.sh
diff --git a/dts/update-dts-subtree.sh b/dts/update-dts-subtree.sh new file mode 100755 index 000000000000..a57b78a41d34 --- /dev/null +++ b/dts/update-dts-subtree.sh @@ -0,0 +1,48 @@ +#!/bin/sh +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright 2024 Linaro Ltd. +# +# Usage: from the top level U-Boot source tree, run: +# $ ./dts/update-dts-subtree.sh pull <release-tag> +# $ ./dts/update-dts-subtree.sh pick <commit-id> +# +# The script will pull changes from devicetree-rebasing repo into U-Boot +# as a subtree located as <U-Boot>/dts/upstream sub-directory. It will +# automatically create a squash/merge commit listing the commits imported. + +set -e + +merge_commit_msg=$(cat << EOF +Subtree merge tag '$2' of devicetree-rebasing repo [1] into dts/upstream + +[1] https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... +EOF +) + +remote_add_and_fetch() { + if ! git remote get-url devicetree-rebasing 2>/dev/null + then + echo "Warning: Script automatically adds new git remote via:" + echo " git remote add devicetree-rebasing \" + echo " https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi..." + git remote add devicetree-rebasing \ + https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... + fi + git fetch devicetree-rebasing master +} + +if [ "$1" = "pull" ] +then + remote_add_and_fetch + git subtree pull --prefix dts/upstream devicetree-rebasing \ + "$2" --squash -m "${merge_commit_msg}" +elif [ "$1" = "pick" ] +then + remote_add_and_fetch + git cherry-pick -x --strategy=subtree -Xsubtree=dts/upstream/ "$2" +else + echo "usage: $0 <op> <ref>" + echo " <op> pull or pick" + echo " <ref> release tag [pull] or commit id [pick]" +fi
Since U-Boot switched away from manual CONFIG_* defines to Kconfig options, align devicetree documentation accordingly.
Changes in v5: - Fixed inappropriate documentation update.
Changes in v4: - Separate patch to align documentation to use Kconfig symbols instead.
doc/develop/devicetree/control.rst | 48 ++++++++++++++---------------- 1 file changed, 22 insertions(+), 26 deletions(-)
diff --git a/doc/develop/devicetree/control.rst b/doc/develop/devicetree/control.rst index 11c92d440f4d..9a0cb90336df 100644 --- a/doc/develop/devicetree/control.rst +++ b/doc/develop/devicetree/control.rst @@ -29,7 +29,7 @@ a number of similar boards with different peripherals, you can describe the features of each board in the devicetree file, and have a single generic source base.
-To enable this feature, add CONFIG_OF_CONTROL to your board config file. +To enable this feature, select `OF_CONTROL` via Kconfig.
What is a Flattened Devicetree? @@ -81,12 +81,8 @@ Failing that, you could write one from scratch yourself! Configuration -------------
-Use:: - - #define CONFIG_DEFAULT_DEVICE_TREE "<name>" - -to set the filename of the devicetree source. Then put your devicetree -file into:: +Set up "<name>" when prompted for `DEFAULT_DEVICE_TREE` by Kconfig. Then put +your devicetree file into::
@@ -94,24 +90,24 @@ This should include your CPU or SOC's devicetree file, placed in `arch/<arch>/dts`, and then make any adjustments required using a u-boot-dtsi file for your board.
-If CONFIG_OF_EMBED is defined, then it will be picked up and built into +If `OF_EMBED` is selected by Kconfig, then it will be picked up and built into the U-Boot image (including u-boot.bin). This is suitable for debugging and development only and is not recommended for production devices.
-If CONFIG_OF_SEPARATE is defined, then it will be built and placed in +If `OF_SEPARATE` is selected by Kconfig, then it will be built and placed in a u-boot.dtb file alongside u-boot-nodtb.bin with the combined result placed -in u-boot.bin so you can still just flash u-boot.bin onto your board. If you are -using CONFIG_SPL_FRAMEWORK, then u-boot.img will be built to include the device -tree binary. +in u-boot.bin so you can still just flash u-boot.bin onto your board. If Kconfig +option `SPL_FRAMEWORK` is enabled, then u-boot.img will be built to include the +device tree binary.
-If CONFIG_OF_BOARD is defined, a board-specific routine will provide the +If `OF_BOARD` is selected by Kconfig, a board-specific routine will provide the devicetree at runtime, for example if an earlier bootloader stage creates it and passes it to U-Boot.
-If CONFIG_BLOBLIST is defined, the devicetree may come from a bloblist passed -from a previous stage, if present. +If `BLOBLIST` is selected by Kconfig, the devicetree may come from a bloblist +passed from a previous stage, if present.
-If CONFIG_SANDBOX is defined, then it will be read from a file on +If `SANDBOX` is selected by Kconfig, then it will be read from a file on startup. Use the -d flag to U-Boot to specify the file to read, -D for the default and -T for the test devicetree, used to run sandbox unit tests.
@@ -145,7 +141,7 @@ Build: After the board configuration is done, fdt supported u-boot can be built in two ways:
-# build the default dts which is defined from CONFIG_DEFAULT_DEVICE_TREE:: +# build the default dts which is selected by DEFAULT_DEVICE_TREE Kconfig::
$ make
@@ -198,8 +194,8 @@ As mentioned above, the U-Boot build system automatically includes a `*-u-boot.dtsi` file, if found, containing U-Boot specific quirks. However, some data, such as the mentioned public keys, are not appropriate for upstream U-Boot but are better kept and maintained -outside the U-Boot repository. You can use CONFIG_DEVICE_TREE_INCLUDES -to specify a list of .dtsi files that will also be included when +outside the U-Boot repository. You can use `DEVICE_TREE_INCLUDES` Kconfig +option to specify a list of .dtsi files that will also be included when building .dtb files.
@@ -213,14 +209,14 @@ The full devicetree is available to U-Boot proper, but normally only a subset 'SPL Support' in doc/driver-model/design.rst for more details.
-Using several DTBs in the SPL (CONFIG_SPL_MULTI_DTB) ----------------------------------------------------- +Using several DTBs in the SPL (SPL_MULTI_DTB_FIT Kconfig option) +---------------------------------------------------------------- In some rare cases it is desirable to let SPL be able to select one DTB among many. This usually not very useful as the DTB for the SPL is small and usually fits several platforms. However the DTB sometimes include information that do work on several platforms (like IO tuning parameters). -In this case it is possible to use CONFIG_SPL_MULTI_DTB. This option appends to -the SPL a FIT image containing several DTBs listed in SPL_OF_LIST. +In this case it is possible to use SPL_MULTI_DTB_FIT Kconfig option. This option +appends to the SPL a FIT image containing several DTBs listed in SPL_OF_LIST. board_fit_config_name_match() is called to select the right DTB.
If board_fit_config_name_match() relies on DM (DM driver to access an EEPROM @@ -247,10 +243,10 @@ architectures.
It is important to understand that the fdt only selects options available in the platform / drivers. It cannot add new drivers (yet). So -you must still have the CONFIG option to enable the driver. For example, -you need to define CONFIG_SYS_NS16550 to bring in the NS16550 driver, +you must still have the Kconfig option to enable the driver. For example, +you need to enable SYS_NS16550 Kconfig option to bring in the NS16550 driver, but can use the fdt to specific the UART clock, peripheral address, etc. -In very broad terms, the CONFIG options in general control *what* driver +In very broad terms, the Kconfig options in general control *what* driver files are pulled in, and the fdt controls *how* those files work.
History
Encourage SoC/board maintainers to migrate to using devicetree-rebasing subtree and maintain a regular sync with Linux kernel devicetree files and bindings.
Along with that add documentation regarding how to run DT bindings schema checks.
Changes in v6: - Incorporate documentation review comments from Paul.
Changes in v5: - Document how to cherry-pick fixes from devicetree-rebasing tree.
Changes in v4: - Switched subtree to be imported as dts/upstream sub-directory rather than devicetree-rebasing sub-directory to better suite U-Boot directory structure. - Since we now have v6.7-dts tag available now, so switch subtree to that from its beginning. - Clarify subtree uprev schedule as a separate documentation section. Also, fixed documentation typos.
Changes in v3: - Replace CONFIG_* with Kconfig options
Changes in v2: - s/U-boot/U-Boot/
doc/develop/devicetree/control.rst | 115 ++++++++++++++++++++++++----- 1 file changed, 95 insertions(+), 20 deletions(-)
diff --git a/doc/develop/devicetree/control.rst b/doc/develop/devicetree/control.rst index 9a0cb90336df..c94d84192b71 100644 --- a/doc/develop/devicetree/control.rst +++ b/doc/develop/devicetree/control.rst @@ -1,5 +1,6 @@ .. SPDX-License-Identifier: GPL-2.0+ .. sectionauthor:: Copyright 2011 The Chromium OS Authors +.. Copyright 2023-2024 Linaro Ltd.
Devicetree Control in U-Boot ============================ @@ -22,12 +23,11 @@ for three reasons: hierarchical format - It is fairly efficient to read incrementally
-The arch/<arch>/dts directories contains a Makefile for building the devicetree -blob and embedding it in the U-Boot image. This is useful since it allows -U-Boot to configure itself according to what it finds there. If you have -a number of similar boards with different peripherals, you can describe -the features of each board in the devicetree file, and have a single -generic source base. +The U-Boot Makefile infrastructure allows for building the devicetree blob +and embedding it in the U-Boot image. This is useful since it allows U-Boot +to configure itself according to what it finds there. If you have a number +of similar boards with different peripherals, you can describe the features +of each board in the devicetree file, and have a single generic source base.
@@ -68,8 +68,16 @@ a binary file. U-Boot adds its own `fdtgrep` for creating subsets of the file. Where do I get a devicetree file for my board? ----------------------------------------------
-You may find that the Linux kernel has a suitable file. Look in the -kernel source in arch/<arch>/boot/dts. +The devicetree files and devicetree bindings are maintained as part of the Linux +kernel git repository. Traditionally, U-Boot placed copies of devicetree source +files from the Linux kernel into `arch/<arch>/dts/<name>.dts`. However, this +required each board maintainer to manually keep their devicetree in sync with +the Linux kernel and often led to divergence between these copies. + +U-Boot rather maintains a Git subtree as `dts/upstream/` sub-directory. It is +regularly synced with the Linux kernel and hence no need for manual devicetree +sync. You may find that the `dts/upstream/` already has a suitable devicetree +file for your board. Look in `dts/upstream/src/<arch>/<vendor>`.
If not you might find other boards with suitable files that you can modify to your needs. Look in the board directories for files with a @@ -78,17 +86,39 @@ modify to your needs. Look in the board directories for files with a Failing that, you could write one from scratch yourself!
+Resyncing with devicetree-rebasing +---------------------------------- + +The devicetee-rebasing repository (dtrepo_) maintains a fork cum mirror copy of +devicetree files along with the bindings synced at every Linux kernel major +release or intermediate release candidates. The U-Boot maintainers regularly +sync the `dts/upstream/` subtree from the devicetree-rebasing repo whenever +the next branch opens (refer: :doc:`../release_cycle`) with the latest mainline +Linux kernel release. To sync the `dts/upstream/` subtree, run:: + + ./dts/update-dts-subtree.sh pull <devicetree-rebasing-release-tag> + +If required it is also possible to cherry-pick fixes from the +devicetree-rebasing repository prior to next sync, usage:: + + ./dts/update-dts-subtree.sh pick <devicetree-rebasing-commit-id> + + Configuration -------------
-Set up "<name>" when prompted for `DEFAULT_DEVICE_TREE` by Kconfig. Then put -your devicetree file into:: +SoC/board maintainers are encouraged to migrate to use synced copies from +`dts/upstream/src/<arch>/<vendor>`. To do that add `imply OF_UPSTREAM` for the +SoC being used via Kconfig and set `DEFAULT_DEVICE_TREE=<vendor>/<name>` when +prompted by Kconfig.
- arch/<arch>/dts/<name>.dts +However, if `dts/upstream/` hasn't yet received devicetree source file for your +newly added board support then you can add corresponding devicetree source file +as `arch/<arch>/dts/<name>.dts`. To select that add `# CONFIG_OF_UPSTREAM is not +set` and set `DEFAULT_DEVICE_TREE=<name>` when prompted by Kconfig.
-This should include your CPU or SOC's devicetree file, placed in -`arch/<arch>/dts`, and then make any adjustments required using a u-boot-dtsi -file for your board. +This should include your CPU or SoC's devicetree file. On top of that any U-Boot +specific tweaks (see: dttweaks_) can be made for your board.
If `OF_EMBED` is selected by Kconfig, then it will be picked up and built into the U-Boot image (including u-boot.bin). This is suitable for debugging @@ -155,8 +185,9 @@ ways: Adding tweaks for U-Boot ------------------------
-It is strongly recommended that devicetree files in U-Boot are an exact copy of -those in Linux, so that it is easy to sync them up from time to time. +With `dts/upstream` Git subtree, it is ensured that devicetree files in U-Boot +are an exact copy of those in Linux kernel available under +`dts/upstream/src/<arch>/<vendor>`.
U-Boot is of course a very different project from Linux, e.g. it operates under much more restrictive memory and code-size constraints. Where Linux may use a @@ -169,8 +200,8 @@ constraints are even more extreme and the devicetree is shrunk to remove unwanted nodes, or even turned into C code to avoid access overhead.
U-Boot automatically looks for and includes a file with updates to the standard -devicetree for your board, searching for them in the same directory as the -main file, in this order:: +devicetree for your board, searching for them in `arch/<arch>/dts/` in this +order::
<orig_filename>-u-boot.dtsi <CONFIG_SYS_SOC>-u-boot.dtsi @@ -199,6 +230,48 @@ option to specify a list of .dtsi files that will also be included when building .dtb files.
+Devicetree bindings schema checks +--------------------------------- + +With devicetee-rebasing Git subtree, the devicetree bindings are also regularly +synced with Linux kernel as `dts/upstream/Bindings/` sub-directory. This +allows U-Boot to run devicetree bindings schema checks which will bring +compliance to U-Boot core/drivers regarding usage of devicetree. + +Dependencies +~~~~~~~~~~~~ + +The DT schema project must be installed in order to validate the DT schema +binding documents and validate DTS files using the DT schema. For installation +instructions, refer to the DT schema project page (dtschema_). + +Several executables (dt-doc-validate, dt-mk-schema, dt-validate) will be +installed. Ensure they are in your PATH (~/.local/bin by default). + +You should also install yamllint (used by dtschema when present). On Debian/ +Ubuntu systems:: + + apt install yamllint + +Running checks +~~~~~~~~~~~~~~ + +In order to perform validation of DTB files, use the ``dtbs_check`` target:: + + make dtbs_check + +It is also possible to run checks with a subset of matching schema files by +setting the ``DT_SCHEMA_FILES`` variable to 1 or more specific schema files or +patterns (partial match of a fixed string). Each file or pattern should be +separated by ':'. + +:: + + make dtbs_check DT_SCHEMA_FILES=trivial-devices.yaml:rtc.yaml + make dtbs_check DT_SCHEMA_FILES=/gpio/ + make dtbs_check DT_SCHEMA_FILES=trivial-devices.yaml + + Relocation, SPL and TPL -----------------------
@@ -260,8 +333,10 @@ used it before Linux (e.g. snow). The two projects developed in parallel and there are still some differences in the bindings for certain boards. While there has been discussion of having a separate repository for devicetree files, in practice the Linux kernel Git repository has become the place where -these are stored, with U-Boot taking copies and adding tweaks with u-boot.dtsi -files. +these are stored, with U-Boot taking copies via devicetree-rebasing repo +(see: dtrepo_) and adding tweaks with u-boot.dtsi files.
.. _dtspec: https://www.devicetree.org/specifications/ .. _dtlist: https://www.spinics.net/lists/devicetree-compiler/ +.. _dtrepo: https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... +.. _dtschema: https://github.com/devicetree-org/dt-schema/tree/main
Hi Sumit,
Changes in v6:
I have just a couple of tidy up suggestions for the links in this document - these let us avoid short reference names like `dtrepo` or `dttweaks` appearing in the document itself where they interrupt the flow of the text. For each one I've just wrote out what I think the line above should be, I hope that makes sense.
The `devicetree-rebasing repository`_ maintains a fork cum mirror copy of
- ./dts/update-dts-subtree.sh pull <devicetree-rebasing-release-tag>
- ./dts/update-dts-subtree.sh pick <devicetree-rebasing-commit-id>
Configuration
specific tweaks (see: :ref:`dttweaks`) can be made for your board.
instructions, refer to the `DT schema project page`_.
- apt install yamllint
- make dtbs_check
- make dtbs_check DT_SCHEMA_FILES=trivial-devices.yaml:rtc.yaml
- make dtbs_check DT_SCHEMA_FILES=/gpio/
these are stored, with U-Boot taking copies via the `devicetree-rebasing repository`_
.. _devicetree-rebasing repository: https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi...
.. _DT schema project page: https://github.com/devicetree-org/dt-schema/tree/main
Thanks,
Hi Paul,
On Wed, 28 Feb 2024 at 03:08, Paul Barker paul.barker.ct@bp.renesas.com wrote:
Hi Sumit,
Changes in v6:
Although these are following the same pattern as `dtspec` and `dtlist` , your suggestion sounds reasonable. However, I would just like to avoid sending a newer version just for these since this patch-set is already a dependency for others [1] [2].
If you agree then I can send a follow up patch to get rid of all the short reference names in this document.
[1] https://patchwork.ozlabs.org/project/uboot/list/?series=396399 [2] https://patchwork.ozlabs.org/project/uboot/list/?series=396742
-Sumit
Configuration
- make dtbs_check
Thanks,
-- Paul Barker
On 28/02/2024 09:20, Sumit Garg wrote:
Hi Paul,
Hi Sumit,
Changes in v6:
Please go ahead and fix this as a follow up patch. I don't see any reason to hold up this series.
Add myself as devicetree-rebasing maintainer.
Changes in v4: - Switched subtree to be imported as dts/upstream sub-directory rather than devicetree-rebasing sub-directory to better suite U-Boot directory structure. - Added commit description.
Changes in v2: - Picked up review tags
MAINTAINERS | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 0b08ca192397..6541ab2b3a87 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -989,6 +989,11 @@ F: cmd/cyclic.c F: common/cyclic.c F: include/cyclic.h
+DEVICETREE REBASING SUBTREE +M: Sumit Garg sumit.garg@linaro.org +S: Maintained +F: dts/upstream/ + DFU M: Lukasz Majewski lukma@denx.de M: Mattijs Korpershoek mkorpershoek@baylibre.com
Although there were still some variations in board DTS files based on meson-gxbb SoC but I think those were minor differences from upstream and shouldn't impact boot on these devices.
So enable OF_UPSTREAM to use upstream DT and add amlogic/ prefix to the DEFAULT_DEVICE_TREE. And thereby directly build DTB from dts/upstream/src/ including *-u-boot.dtsi files from arch/$(ARCH)/dts/ directory.
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Sumit Garg sumit.garg@linaro.org ---
Changes in v4: - Picked up review tag
Changes in v3: - Dropped Makefile portion and enabled OF_UPSTREAM for SoC instead.
arch/arm/mach-meson/Kconfig | 1 + configs/nanopi-k2_defconfig | 2 +- configs/odroid-c2_defconfig | 2 +- configs/p200_defconfig | 2 +- configs/p201_defconfig | 2 +- configs/videostrong-kii-pro_defconfig | 2 +- configs/wetek-hub_defconfig | 2 +- configs/wetek-play2_defconfig | 2 +- 8 files changed, 8 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-meson/Kconfig b/arch/arm/mach-meson/Kconfig index d6c890580617..8ddb59161a0d 100644 --- a/arch/arm/mach-meson/Kconfig +++ b/arch/arm/mach-meson/Kconfig @@ -25,6 +25,7 @@ choice config MESON_GXBB bool "GXBB" select MESON_GX + imply OF_UPSTREAM help Select this if your SoC is an S905
diff --git a/configs/nanopi-k2_defconfig b/configs/nanopi-k2_defconfig index 41dbf7981f8b..2e1c756bf7a8 100644 --- a/configs/nanopi-k2_defconfig +++ b/configs/nanopi-k2_defconfig @@ -6,7 +6,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-nanopi-k2" +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-nanopi-k2" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 5f9f323e06ea..ce5eaec3cd2a 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -6,7 +6,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-odroidc2" +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-odroidc2" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/configs/p200_defconfig b/configs/p200_defconfig index cd579ef5f142..b69460347954 100644 --- a/configs/p200_defconfig +++ b/configs/p200_defconfig @@ -6,7 +6,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-p200" +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-p200" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/configs/p201_defconfig b/configs/p201_defconfig index b2f0a0ccdb4a..dcc1454be16c 100644 --- a/configs/p201_defconfig +++ b/configs/p201_defconfig @@ -7,7 +7,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-p201" +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-p201" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/configs/videostrong-kii-pro_defconfig b/configs/videostrong-kii-pro_defconfig index 3eda8f14a21b..7a5af234471f 100644 --- a/configs/videostrong-kii-pro_defconfig +++ b/configs/videostrong-kii-pro_defconfig @@ -6,7 +6,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-kii-pro" +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-kii-pro" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/configs/wetek-hub_defconfig b/configs/wetek-hub_defconfig index fd92b041e739..85cff73f50f7 100644 --- a/configs/wetek-hub_defconfig +++ b/configs/wetek-hub_defconfig @@ -6,7 +6,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-wetek-hub" +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-wetek-hub" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0 diff --git a/configs/wetek-play2_defconfig b/configs/wetek-play2_defconfig index b887419a6bab..efdf820165b5 100644 --- a/configs/wetek-play2_defconfig +++ b/configs/wetek-play2_defconfig @@ -6,7 +6,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-wetek-play2" +CONFIG_DEFAULT_DEVICE_TREE="amlogic/meson-gxbb-wetek-play2" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_DEBUG_UART_BASE=0xc81004c0
Since meson-gxbb based boards switched to using upstream DT, so drop redundant files from arch/arm/dts directory. Only *-u-boot.dtsi files kept in arch/arm/dts directory for these boards.
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org Signed-off-by: Sumit Garg sumit.garg@linaro.org ---
Changes in v4: - None
arch/arm/dts/Makefile | 8 - arch/arm/dts/meson-gxbb-kii-pro.dts | 140 ---- arch/arm/dts/meson-gxbb-nanopi-k2.dts | 426 ------------ arch/arm/dts/meson-gxbb-odroidc2.dts | 414 ----------- arch/arm/dts/meson-gxbb-p200.dts | 100 --- arch/arm/dts/meson-gxbb-p201.dts | 26 - arch/arm/dts/meson-gxbb-p20x.dtsi | 250 ------- arch/arm/dts/meson-gxbb-wetek-hub.dts | 58 -- arch/arm/dts/meson-gxbb-wetek-play2.dts | 119 ---- arch/arm/dts/meson-gxbb-wetek.dtsi | 292 -------- arch/arm/dts/meson-gxbb.dtsi | 870 ------------------------ 11 files changed, 2703 deletions(-) delete mode 100644 arch/arm/dts/meson-gxbb-kii-pro.dts delete mode 100644 arch/arm/dts/meson-gxbb-nanopi-k2.dts delete mode 100644 arch/arm/dts/meson-gxbb-odroidc2.dts delete mode 100644 arch/arm/dts/meson-gxbb-p200.dts delete mode 100644 arch/arm/dts/meson-gxbb-p201.dts delete mode 100644 arch/arm/dts/meson-gxbb-p20x.dtsi delete mode 100644 arch/arm/dts/meson-gxbb-wetek-hub.dts delete mode 100644 arch/arm/dts/meson-gxbb-wetek-play2.dts delete mode 100644 arch/arm/dts/meson-gxbb-wetek.dtsi delete mode 100644 arch/arm/dts/meson-gxbb.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d9725030d5a0..7c2681eb9377 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -216,14 +216,6 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-a1-ad401.dtb \ meson-axg-s400.dtb \ meson-axg-jethome-jethub-j100.dtb \ - meson-gxbb-kii-pro.dtb \ - meson-gxbb-nanopi-k2.dtb \ - meson-gxbb-odroidc2.dtb \ - meson-gxbb-nanopi-k2.dtb \ - meson-gxbb-p200.dtb \ - meson-gxbb-p201.dtb \ - meson-gxbb-wetek-hub.dtb \ - meson-gxbb-wetek-play2.dtb \ meson-gxl-s805x-libretech-ac.dtb \ meson-gxl-s905d-libretech-pc.dtb \ meson-gxl-s905w-jethome-jethub-j80.dtb \ diff --git a/arch/arm/dts/meson-gxbb-kii-pro.dts b/arch/arm/dts/meson-gxbb-kii-pro.dts deleted file mode 100644 index e238f1f10124..000000000000 --- a/arch/arm/dts/meson-gxbb-kii-pro.dts +++ /dev/null @@ -1,140 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Mohammad Rasim mohammad.rasim96@gmail.com - */ - -/dts-v1/; - -#include "meson-gxbb-p20x.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/sound/meson-aiu.h> - -/ { - compatible = "videostrong,kii-pro", "amlogic,meson-gxbb"; - model = "Videostrong KII Pro"; - - spdif_dit: audio-codec-0 { - #sound-dai-cells = <0>; - compatible = "linux,spdif-dit"; - status = "okay"; - sound-name-prefix = "DIT"; - }; - - leds { - compatible = "gpio-leds"; - led { - gpios = <&gpio_ao GPIOAO_13 GPIO_ACTIVE_LOW>; - color = <LED_COLOR_ID_RED>; - function = LED_FUNCTION_STATUS; - default-state = "off"; - }; - }; - - gpio-keys-polled { - compatible = "gpio-keys-polled"; - poll-interval = <20>; - - button-reset { - label = "reset"; - linux,code = <KEY_POWER>; - gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>; - }; - }; - - sound { - compatible = "amlogic,gx-sound-card"; - model = "KII-PRO"; - assigned-clocks = <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>, - <&clkc CLKID_MPLL2>; - assigned-clock-parents = <0>, <0>, <0>; - assigned-clock-rates = <294912000>, - <270950400>, - <393216000>; - - dai-link-0 { - sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; - }; - - dai-link-1 { - sound-dai = <&aiu AIU_CPU CPU_SPDIF_FIFO>; - }; - - dai-link-2 { - sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; - dai-format = "i2s"; - mclk-fs = <256>; - - codec-0 { - sound-dai = <&aiu AIU_HDMI CTRL_I2S>; - }; - }; - - dai-link-3 { - sound-dai = <&aiu AIU_CPU CPU_SPDIF_ENCODER>; - - codec-0 { - sound-dai = <&spdif_dit>; - }; - }; - - dai-link-4 { - sound-dai = <&aiu AIU_HDMI CTRL_OUT>; - - codec-0 { - sound-dai = <&hdmi_tx>; - }; - }; - }; -}; - -&aiu { - status = "okay"; - pinctrl-0 = <&spdif_out_y_pins>; - pinctrl-names = "default"; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_rmii_pins>; - pinctrl-names = "default"; - - phy-handle = <ð_phy0>; - phy-mode = "rmii"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - eth_phy0: ethernet-phy@0 { - /* IC Plus IP101GR (0x02430c54) */ - reg = <0>; - reset-assert-us = <10000>; - reset-deassert-us = <10000>; - reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; - }; - }; -}; - -&ir { - linux,rc-map-name = "rc-videostrong-kii-pro"; -}; - -&uart_A { - status = "okay"; - pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>; - pinctrl-names = "default"; - uart-has-rtscts; - - bluetooth { - compatible = "brcm,bcm4335a0"; - shutdown-gpios = <&gpio GPIOX_20 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio GPIOX_21 GPIO_ACTIVE_HIGH>; - max-speed = <2000000>; - clocks = <&wifi32k>; - clock-names = "lpo"; - }; -}; diff --git a/arch/arm/dts/meson-gxbb-nanopi-k2.dts b/arch/arm/dts/meson-gxbb-nanopi-k2.dts deleted file mode 100644 index 7d94160f5802..000000000000 --- a/arch/arm/dts/meson-gxbb-nanopi-k2.dts +++ /dev/null @@ -1,426 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 Andreas Färber - */ - -/dts-v1/; - -#include "meson-gxbb.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/sound/meson-aiu.h> - -/ { - compatible = "friendlyarm,nanopi-k2", "amlogic,meson-gxbb"; - model = "FriendlyARM NanoPi K2"; - - aliases { - serial0 = &uart_AO; - ethernet0 = ðmac; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x80000000>; - }; - - leds { - compatible = "gpio-leds"; - - led-stat { - label = "nanopi-k2:blue:stat"; - gpios = <&gpio_ao GPIOAO_13 GPIO_ACTIVE_HIGH>; - default-state = "on"; - panic-indicator; - }; - }; - - vdd_5v: regulator-vdd-5v { - compatible = "regulator-fixed"; - regulator-name = "VDD_5V"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vddio_ao18: regulator-vddio-ao18 { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_AO18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vddio_ao3v3: regulator-vddio-ao3v3 { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_AO3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vddio_tf: regulator-vddio-tf { - compatible = "regulator-gpio"; - - regulator-name = "VDDIO_TF"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_HIGH>; - gpios-states = <0>; - - states = <3300000 0>, - <1800000 1>; - - regulator-settling-time-up-us = <100>; - regulator-settling-time-down-us = <5000>; - }; - - wifi_32k: wifi-32k { - compatible = "pwm-clock"; - #clock-cells = <0>; - clock-frequency = <32768>; - pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - reset-gpios = <&gpio GPIOX_6 GPIO_ACTIVE_LOW>; - clocks = <&wifi_32k>; - clock-names = "ext_clock"; - }; - - vcc1v8: regulator-vcc1v8 { - compatible = "regulator-fixed"; - regulator-name = "VCC1.8V"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vcc3v3: regulator-vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "VCC3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; - }; - - /* CVBS is available on CON1 pin 36, disabled by default */ - cvbs-connector { - compatible = "composite-video-connector"; - status = "disabled"; - - port { - cvbs_connector_in: endpoint { - remote-endpoint = <&cvbs_vdac_out>; - }; - }; - }; - - hdmi-connector { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&hdmi_tx_tmds_out>; - }; - }; - }; - - sound { - compatible = "amlogic,gx-sound-card"; - model = "NANOPI-K2"; - assigned-clocks = <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>, - <&clkc CLKID_MPLL2>; - assigned-clock-parents = <0>, <0>, <0>; - assigned-clock-rates = <294912000>, - <270950400>, - <393216000>; - status = "okay"; - - dai-link-0 { - sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; - }; - - dai-link-1 { - sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; - dai-format = "i2s"; - mclk-fs = <256>; - - codec-0 { - sound-dai = <&aiu AIU_HDMI CTRL_I2S>; - }; - }; - - dai-link-2 { - sound-dai = <&aiu AIU_HDMI CTRL_OUT>; - - codec-0 { - sound-dai = <&hdmi_tx>; - }; - }; - }; -}; - -&aiu { - status = "okay"; -}; - -&cec_AO { - status = "okay"; - pinctrl-0 = <&ao_cec_pins>; - pinctrl-names = "default"; - hdmi-phandle = <&hdmi_tx>; -}; - -&cvbs_vdac_port { - cvbs_vdac_out: endpoint { - remote-endpoint = <&cvbs_connector_in>; - }; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_rgmii_pins>; - pinctrl-names = "default"; - - phy-handle = <ð_phy0>; - phy-mode = "rgmii"; - - amlogic,tx-delay-ns = <2>; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - eth_phy0: ethernet-phy@0 { - /* Realtek RTL8211F (0x001cc916) */ - reg = <0>; - - reset-assert-us = <10000>; - reset-deassert-us = <80000>; - reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; - - interrupt-parent = <&gpio_intc>; - /* MAC_INTR on GPIOZ_15 */ - interrupts = <29 IRQ_TYPE_LEVEL_LOW>; - }; - }; -}; - -&hdmi_tx { - status = "okay"; - pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; - pinctrl-names = "default"; -}; - -&hdmi_tx_tmds_port { - hdmi_tx_tmds_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; -}; - -&ir { - status = "okay"; - pinctrl-0 = <&remote_input_ao_pins>; - pinctrl-names = "default"; -}; - -&gpio_ao { - gpio-line-names = "UART TX", "UART RX", "Power Control", "Power Key In", - "VCCK En", "CON1 Header Pin31", - "I2S Header Pin6", "IR In", "I2S Header Pin7", - "I2S Header Pin3", "I2S Header Pin4", - "I2S Header Pin5", "HDMI CEC", "SYS LED", - /* GPIO_TEST_N */ - ""; -}; - -&gpio { - gpio-line-names = /* Bank GPIOZ */ - "Eth MDIO", "Eth MDC", "Eth RGMII RX Clk", - "Eth RX DV", "Eth RX D0", "Eth RX D1", "Eth RX D2", - "Eth RX D3", "Eth RGMII TX Clk", "Eth TX En", - "Eth TX D0", "Eth TX D1", "Eth TX D2", "Eth TX D3", - "Eth PHY nRESET", "Eth PHY Intc", - /* Bank GPIOH */ - "HDMI HPD", "HDMI DDC SDA", "HDMI DDC SCL", - "CON1 Header Pin33", - /* Bank BOOT */ - "eMMC D0", "eMMC D1", "eMMC D2", "eMMC D3", "eMMC D4", - "eMMC D5", "eMMC D6", "eMMC D7", "eMMC Clk", - "eMMC Reset", "eMMC CMD", - "", "", "", "", "eMMC DS", - "", "", - /* Bank CARD */ - "SDCard D1", "SDCard D0", "SDCard CLK", "SDCard CMD", - "SDCard D3", "SDCard D2", "SDCard Det", - /* Bank GPIODV */ - "", "", "", "", "", "", "", "", "", "", "", "", "", - "", "", "", "", "", "", "", "", "", "", "", - "I2C A SDA", "I2C A SCK", "I2C B SDA", "I2C B SCK", - "VDDEE Regulator", "VCCK Regulator", - /* Bank GPIOY */ - "CON1 Header Pin7", "CON1 Header Pin11", - "CON1 Header Pin13", "CON1 Header Pin15", - "CON1 Header Pin18", "CON1 Header Pin19", - "CON1 Header Pin22", "CON1 Header Pin21", - "CON1 Header Pin24", "CON1 Header Pin23", - "CON1 Header Pin26", "CON1 Header Pin29", - "CON1 Header Pin32", "CON1 Header Pin8", - "CON1 Header Pin10", "CON1 Header Pin16", - "CON1 Header Pin12", - /* Bank GPIOX */ - "WIFI SDIO D0", "WIFI SDIO D1", "WIFI SDIO D2", - "WIFI SDIO D3", "WIFI SDIO CLK", "WIFI SDIO CMD", - "WIFI Power Enable", "WIFI WAKE HOST", - "Bluetooth PCM DOUT", "Bluetooth PCM DIN", - "Bluetooth PCM SYNC", "Bluetooth PCM CLK", - "Bluetooth UART TX", "Bluetooth UART RX", - "Bluetooth UART CTS", "Bluetooth UART RTS", - "", "", "", "WIFI 32K", "Bluetooth Enable", - "Bluetooth WAKE HOST", "", - /* Bank GPIOCLK */ - "", "CON1 Header Pin35", "", ""; -}; - -&pwm_ef { - status = "okay"; - pinctrl-0 = <&pwm_e_pins>; - pinctrl-names = "default"; - clocks = <&clkc CLKID_FCLK_DIV4>; - clock-names = "clkin0"; -}; - -&saradc { - status = "okay"; - vref-supply = <&vddio_ao18>; -}; - -/* SDIO */ -&sd_emmc_a { - status = "okay"; - pinctrl-0 = <&sdio_pins>, <&sdio_irq_pins>; - pinctrl-1 = <&sdio_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - #address-cells = <1>; - #size-cells = <0>; - - bus-width = <4>; - cap-sd-highspeed; - max-frequency = <50000000>; - - non-removable; - disable-wp; - - /* WiFi firmware requires power to be kept while in suspend */ - keep-power-in-suspend; - - mmc-pwrseq = <&sdio_pwrseq>; - - vmmc-supply = <&vddio_ao3v3>; - vqmmc-supply = <&vddio_ao18>; - - brcmf: wifi@1 { - compatible = "brcm,bcm4329-fmac"; - reg = <1>; - }; -}; - -/* SD */ -&sd_emmc_b { - status = "okay"; - pinctrl-0 = <&sdcard_pins>; - pinctrl-1 = <&sdcard_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <4>; - cap-sd-highspeed; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-ddr50; - max-frequency = <100000000>; - disable-wp; - - cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>; - - vmmc-supply = <&vddio_ao3v3>; - vqmmc-supply = <&vddio_tf>; -}; - -/* eMMC */ -&sd_emmc_c { - status = "disabled"; - pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; - pinctrl-1 = <&emmc_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <8>; - max-frequency = <200000000>; - non-removable; - disable-wp; - cap-mmc-highspeed; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - - mmc-pwrseq = <&emmc_pwrseq>; - vmmc-supply = <&vcc3v3>; - vqmmc-supply = <&vcc1v8>; -}; - -/* DBG_UART */ -&uart_AO { - status = "okay"; - pinctrl-0 = <&uart_ao_a_pins>; - pinctrl-names = "default"; -}; - -/* Bluetooth on AP6212 */ -&uart_A { - status = "okay"; - pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>; - pinctrl-names = "default"; - uart-has-rtscts; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - clocks = <&wifi_32k>; - clock-names = "lpo"; - vbat-supply = <&vddio_ao3v3>; - vddio-supply = <&vddio_ao18>; - host-wakeup-gpios = <&gpio GPIOX_21 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio GPIOX_20 GPIO_ACTIVE_HIGH>; - }; -}; - -/* 40-pin CON1 */ -&uart_C { - status = "disabled"; - pinctrl-0 = <&uart_c_pins>; - pinctrl-names = "default"; -}; - -&usb0_phy { - status = "okay"; - phy-supply = <&vdd_5v>; -}; - -&usb1_phy { - status = "okay"; -}; - -&usb0 { - status = "okay"; -}; - -&usb1 { - status = "okay"; -}; diff --git a/arch/arm/dts/meson-gxbb-odroidc2.dts b/arch/arm/dts/meson-gxbb-odroidc2.dts deleted file mode 100644 index 01356437a077..000000000000 --- a/arch/arm/dts/meson-gxbb-odroidc2.dts +++ /dev/null @@ -1,414 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Andreas Färber - * Copyright (c) 2016 BayLibre, Inc. - * Author: Kevin Hilman khilman@kernel.org - */ - -/dts-v1/; - -#include "meson-gxbb.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/sound/meson-aiu.h> - -/ { - compatible = "hardkernel,odroid-c2", "amlogic,meson-gxbb"; - model = "Hardkernel ODROID-C2"; - - aliases { - serial0 = &uart_AO; - ethernet0 = ðmac; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x80000000>; - }; - - usb_otg_pwr: regulator-usb-pwrs { - compatible = "regulator-fixed"; - - regulator-name = "USB_OTG_PWR"; - - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - - /* - * signal name from schematics: PWREN - */ - gpio = <&gpio_ao GPIOAO_5 GPIO_ACTIVE_HIGH>; - enable-active-high; - /* - * signal name from schematics: USB_POWER - */ - vin-supply = <&p5v0>; - }; - - leds { - compatible = "gpio-leds"; - led-blue { - label = "c2:blue:alive"; - gpios = <&gpio_ao GPIOAO_13 GPIO_ACTIVE_LOW>; - linux,default-trigger = "heartbeat"; - default-state = "off"; - }; - }; - - p5v0: regulator-p5v0 { - compatible = "regulator-fixed"; - - regulator-name = "P5V0"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - }; - - hdmi_p5v0: regulator-hdmi_p5v0 { - compatible = "regulator-fixed"; - regulator-name = "HDMI_P5V0"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - /* AP2331SA-7 */ - vin-supply = <&p5v0>; - }; - - tflash_vdd: regulator-tflash_vdd { - compatible = "regulator-fixed"; - - regulator-name = "TFLASH_VDD"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - /* - * signal name from schematics: TFLASH_VDD_EN - */ - gpio = <&gpio GPIOY_12 GPIO_ACTIVE_HIGH>; - enable-active-high; - /* U16 RT9179GB */ - vin-supply = <&vddio_ao3v3>; - }; - - tf_io: gpio-regulator-tf_io { - compatible = "regulator-gpio"; - - regulator-name = "TF_IO"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - /* - * signal name from schematics: TF_3V3N_1V8_EN - */ - gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>; - gpios-states = <0>; - - states = <3300000 0>, - <1800000 1>; - /* U12/U13 RT9179GB */ - vin-supply = <&vddio_ao3v3>; - }; - - vcc1v8: regulator-vcc1v8 { - compatible = "regulator-fixed"; - regulator-name = "VCC1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - /* U18 RT9179GB */ - vin-supply = <&vddio_ao3v3>; - }; - - vcc3v3: regulator-vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "VCC3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vddio_ao1v8: regulator-vddio-ao1v8 { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_AO1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - /* U17 RT9179GB */ - vin-supply = <&p5v0>; - }; - - vddio_ao3v3: regulator-vddio-ao3v3 { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_AO3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - /* U11 MP2161GJ-C499 */ - vin-supply = <&p5v0>; - }; - - ddr3_1v5: regulator-ddr3_1v5 { - compatible = "regulator-fixed"; - regulator-name = "DDR3_1V5"; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-always-on; - /* U15 MP2161GJ-C499 */ - vin-supply = <&p5v0>; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; - }; - - hdmi-connector { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&hdmi_tx_tmds_out>; - }; - }; - }; - - sound { - compatible = "amlogic,gx-sound-card"; - model = "ODROID-C2"; - assigned-clocks = <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>, - <&clkc CLKID_MPLL2>; - assigned-clock-parents = <0>, <0>, <0>; - assigned-clock-rates = <294912000>, - <270950400>, - <393216000>; - status = "okay"; - - dai-link-0 { - sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; - }; - - dai-link-1 { - sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; - dai-format = "i2s"; - mclk-fs = <256>; - - codec-0 { - sound-dai = <&aiu AIU_HDMI CTRL_I2S>; - }; - }; - - dai-link-2 { - sound-dai = <&aiu AIU_HDMI CTRL_OUT>; - - codec-0 { - sound-dai = <&hdmi_tx>; - }; - }; - }; -}; - -&aiu { - status = "okay"; -}; - -&cec_AO { - status = "okay"; - pinctrl-0 = <&ao_cec_pins>; - pinctrl-names = "default"; - hdmi-phandle = <&hdmi_tx>; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_rgmii_pins>; - pinctrl-names = "default"; - phy-handle = <ð_phy0>; - phy-mode = "rgmii"; - - amlogic,tx-delay-ns = <2>; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - eth_phy0: ethernet-phy@0 { - /* Realtek RTL8211F (0x001cc916) */ - reg = <0>; - - reset-assert-us = <10000>; - reset-deassert-us = <80000>; - reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; - - interrupt-parent = <&gpio_intc>; - /* MAC_INTR on GPIOZ_15 */ - interrupts = <29 IRQ_TYPE_LEVEL_LOW>; - }; - }; -}; - -&hdmi_tx { - status = "okay"; - pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; - pinctrl-names = "default"; - hdmi-supply = <&hdmi_p5v0>; -}; - -&hdmi_tx_tmds_port { - hdmi_tx_tmds_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; -}; - -&i2c_A { - status = "okay"; - pinctrl-0 = <&i2c_a_pins>; - pinctrl-names = "default"; -}; - -&ir { - status = "okay"; - pinctrl-0 = <&remote_input_ao_pins>; - pinctrl-names = "default"; - linux,rc-map-name = "rc-odroid"; -}; - -&gpio_ao { - gpio-line-names = "UART TX", "UART RX", "VCCK En", "TF 3V3/1V8 En", - "USB HUB nRESET", "USB OTG Power En", - "J7 Header Pin2", "IR In", "J7 Header Pin4", - "J7 Header Pin6", "J7 Header Pin5", "J7 Header Pin7", - "HDMI CEC", "SYS LED", - /* GPIO_TEST_N */ - ""; -}; - -&gpio { - gpio-line-names = /* Bank GPIOZ */ - "Eth MDIO", "Eth MDC", "Eth RGMII RX Clk", - "Eth RX DV", "Eth RX D0", "Eth RX D1", "Eth RX D2", - "Eth RX D3", "Eth RGMII TX Clk", "Eth TX En", - "Eth TX D0", "Eth TX D1", "Eth TX D2", "Eth TX D3", - "Eth PHY nRESET", "Eth PHY Intc", - /* Bank GPIOH */ - "HDMI HPD", "HDMI DDC SDA", "HDMI DDC SCL", "", - /* Bank BOOT */ - "eMMC D0", "eMMC D1", "eMMC D2", "eMMC D3", "eMMC D4", - "eMMC D5", "eMMC D6", "eMMC D7", "eMMC Clk", - "eMMC Reset", "eMMC CMD", - "", "", "", "", "", "", "", - /* Bank CARD */ - "SDCard D1", "SDCard D0", "SDCard CLK", "SDCard CMD", - "SDCard D3", "SDCard D2", "SDCard Det", - /* Bank GPIODV */ - "", "", "", "", "", "", "", "", "", "", "", "", "", - "", "", "", "", "", "", "", "", "", "", "", - "I2C A SDA", "I2C A SCK", "I2C B SDA", "I2C B SCK", - "PWM D", "PWM B", - /* Bank GPIOY */ - "Revision Bit0", "Revision Bit1", "", - "J2 Header Pin35", "", "", "", "J2 Header Pin36", - "J2 Header Pin31", "", "", "", "TF VDD En", - "J2 Header Pin32", "J2 Header Pin26", "", "", - /* Bank GPIOX */ - "J2 Header Pin29", "J2 Header Pin24", - "J2 Header Pin23", "J2 Header Pin22", - "J2 Header Pin21", "J2 Header Pin18", - "J2 Header Pin33", "J2 Header Pin19", - "J2 Header Pin16", "J2 Header Pin15", - "J2 Header Pin12", "J2 Header Pin13", - "J2 Header Pin8", "J2 Header Pin10", - "", "", "", "", "", - "J2 Header Pin11", "", "J2 Header Pin7", "", - /* Bank GPIOCLK */ - "", "", "", ""; -}; - -&saradc { - status = "okay"; - vref-supply = <&vcc1v8>; -}; - -&scpi_clocks { - status = "disabled"; -}; - -/* SD */ -&sd_emmc_b { - status = "okay"; - pinctrl-0 = <&sdcard_pins>; - pinctrl-1 = <&sdcard_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <4>; - cap-sd-highspeed; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-ddr50; - max-frequency = <100000000>; - disable-wp; - - cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>; - - vmmc-supply = <&tflash_vdd>; - vqmmc-supply = <&tf_io>; -}; - -/* eMMC */ -&sd_emmc_c { - status = "okay"; - pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; - pinctrl-1 = <&emmc_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <8>; - max-frequency = <200000000>; - non-removable; - disable-wp; - cap-mmc-highspeed; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - - mmc-pwrseq = <&emmc_pwrseq>; - vmmc-supply = <&vcc3v3>; - vqmmc-supply = <&vcc1v8>; -}; - -&uart_AO { - status = "okay"; - pinctrl-0 = <&uart_ao_a_pins>; - pinctrl-names = "default"; -}; - -&usb0_phy { - status = "disabled"; - phy-supply = <&usb_otg_pwr>; -}; - -&usb1_phy { - status = "okay"; - phy-supply = <&usb_otg_pwr>; -}; - -&usb0 { - status = "disabled"; -}; - -&usb1 { - dr_mode = "host"; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - hub@1 { - /* Genesys Logic GL852G USB 2.0 hub */ - compatible = "usb5e3,610"; - reg = <1>; - vdd-supply = <&p5v0>; - reset-gpio = <&gpio_ao GPIOAO_4 GPIO_ACTIVE_LOW>; - }; -}; diff --git a/arch/arm/dts/meson-gxbb-p200.dts b/arch/arm/dts/meson-gxbb-p200.dts deleted file mode 100644 index 3c93d1898b40..000000000000 --- a/arch/arm/dts/meson-gxbb-p200.dts +++ /dev/null @@ -1,100 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Andreas Färber - * Copyright (c) 2016 BayLibre, Inc. - * Author: Kevin Hilman khilman@kernel.org - */ - -/dts-v1/; - -#include "meson-gxbb-p20x.dtsi" -#include <dt-bindings/input/input.h> - -/ { - compatible = "amlogic,p200", "amlogic,meson-gxbb"; - model = "Amlogic Meson GXBB P200 Development Board"; - - avdd18_usb_adc: regulator-avdd18_usb_adc { - compatible = "regulator-fixed"; - regulator-name = "AVDD18_USB_ADC"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - adc_keys { - compatible = "adc-keys"; - io-channels = <&saradc 0>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <1800000>; - - button-home { - label = "Home"; - linux,code = <KEY_HOME>; - press-threshold-microvolt = <900000>; /* 50% */ - }; - - button-esc { - label = "Esc"; - linux,code = <KEY_ESC>; - press-threshold-microvolt = <684000>; /* 38% */ - }; - - button-up { - label = "Volume Up"; - linux,code = <KEY_VOLUMEUP>; - press-threshold-microvolt = <468000>; /* 26% */ - }; - - button-down { - label = "Volume Down"; - linux,code = <KEY_VOLUMEDOWN>; - press-threshold-microvolt = <252000>; /* 14% */ - }; - - button-menu { - label = "Menu"; - linux,code = <KEY_MENU>; - press-threshold-microvolt = <0>; /* 0% */ - }; - }; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_rgmii_pins>; - pinctrl-names = "default"; - phy-handle = <ð_phy0>; - phy-mode = "rgmii"; - - amlogic,tx-delay-ns = <2>; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - eth_phy0: ethernet-phy@3 { - /* Micrel KSZ9031 (0x00221620) */ - reg = <3>; - - reset-assert-us = <10000>; - reset-deassert-us = <30000>; - reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; - - interrupt-parent = <&gpio_intc>; - /* MAC_INTR on GPIOZ_15 */ - interrupts = <29 IRQ_TYPE_LEVEL_LOW>; - }; - }; -}; - -&i2c_B { - status = "okay"; - pinctrl-0 = <&i2c_b_pins>; - pinctrl-names = "default"; -}; - -&saradc { - status = "okay"; - vref-supply = <&avdd18_usb_adc>; -}; diff --git a/arch/arm/dts/meson-gxbb-p201.dts b/arch/arm/dts/meson-gxbb-p201.dts deleted file mode 100644 index 150a82f3b2d7..000000000000 --- a/arch/arm/dts/meson-gxbb-p201.dts +++ /dev/null @@ -1,26 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Andreas Färber - * Copyright (c) 2016 BayLibre, Inc. - * Author: Kevin Hilman khilman@kernel.org - */ - -/dts-v1/; - -#include "meson-gxbb-p20x.dtsi" - -/ { - compatible = "amlogic,p201", "amlogic,meson-gxbb"; - model = "Amlogic Meson GXBB P201 Development Board"; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_rmii_pins>; - pinctrl-names = "default"; - phy-mode = "rmii"; - - snps,reset-gpio = <&gpio GPIOZ_14 0>; - snps,reset-delays-us = <0>, <10000>, <1000000>; - snps,reset-active-low; -}; diff --git a/arch/arm/dts/meson-gxbb-p20x.dtsi b/arch/arm/dts/meson-gxbb-p20x.dtsi deleted file mode 100644 index e803a466fe4e..000000000000 --- a/arch/arm/dts/meson-gxbb-p20x.dtsi +++ /dev/null @@ -1,250 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Andreas Färber - * Copyright (c) 2016 BayLibre, Inc. - * Author: Kevin Hilman khilman@kernel.org - */ - -#include "meson-gxbb.dtsi" - -/ { - aliases { - serial0 = &uart_AO; - ethernet0 = ðmac; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x40000000>; - }; - - usb_pwr: regulator-usb-pwrs { - compatible = "regulator-fixed"; - - regulator-name = "USB_PWR"; - - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - - /* signal name in schematic: USB_PWR_EN */ - gpio = <&gpio GPIODV_24 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vddio_card: gpio-regulator { - compatible = "regulator-gpio"; - - regulator-name = "VDDIO_CARD"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio_ao GPIOAO_5 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - - /* Based on P200 schematics, signal CARD_1.8V/3.3V_CTR */ - states = <1800000 0>, - <3300000 1>; - - regulator-settling-time-up-us = <10000>; - regulator-settling-time-down-us = <150000>; - }; - - vddio_boot: regulator-vddio_boot { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_BOOT"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vddao_3v3: regulator-vddao_3v3 { - compatible = "regulator-fixed"; - regulator-name = "VDDAO_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vcc_3v3: regulator-vcc_3v3 { - compatible = "regulator-fixed"; - regulator-name = "VCC_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; - }; - - wifi32k: wifi32k { - compatible = "pwm-clock"; - #clock-cells = <0>; - clock-frequency = <32768>; - pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - reset-gpios = <&gpio GPIOX_6 GPIO_ACTIVE_LOW>; - clocks = <&wifi32k>; - clock-names = "ext_clock"; - }; - - cvbs_connector: cvbs-connector { - compatible = "composite-video-connector"; - - port { - cvbs_connector_in: endpoint { - remote-endpoint = <&cvbs_vdac_out>; - }; - }; - }; - - hdmi-connector { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&hdmi_tx_tmds_out>; - }; - }; - }; -}; - -&cec_AO { - status = "okay"; - pinctrl-0 = <&ao_cec_pins>; - pinctrl-names = "default"; - hdmi-phandle = <&hdmi_tx>; -}; - -&cvbs_vdac_port { - cvbs_vdac_out: endpoint { - remote-endpoint = <&cvbs_connector_in>; - }; -}; - -&hdmi_tx { - status = "okay"; - pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; - pinctrl-names = "default"; -}; - -&hdmi_tx_tmds_port { - hdmi_tx_tmds_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; -}; - -&ir { - status = "okay"; - pinctrl-0 = <&remote_input_ao_pins>; - pinctrl-names = "default"; -}; - -&pwm_ef { - status = "okay"; - pinctrl-0 = <&pwm_e_pins>; - pinctrl-names = "default"; - clocks = <&clkc CLKID_FCLK_DIV4>; - clock-names = "clkin0"; -}; - -/* Wireless SDIO Module */ -&sd_emmc_a { - status = "okay"; - pinctrl-0 = <&sdio_pins>; - pinctrl-1 = <&sdio_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - #address-cells = <1>; - #size-cells = <0>; - - bus-width = <4>; - cap-sd-highspeed; - max-frequency = <50000000>; - - non-removable; - disable-wp; - - /* WiFi firmware requires power to be kept while in suspend */ - keep-power-in-suspend; - - mmc-pwrseq = <&sdio_pwrseq>; - - vmmc-supply = <&vddao_3v3>; - vqmmc-supply = <&vddio_boot>; - - brcmf: wifi@1 { - reg = <1>; - compatible = "brcm,bcm4329-fmac"; - }; -}; - -/* SD card */ -&sd_emmc_b { - status = "okay"; - pinctrl-0 = <&sdcard_pins>; - pinctrl-1 = <&sdcard_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <4>; - cap-sd-highspeed; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - max-frequency = <100000000>; - disable-wp; - - cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>; - - vmmc-supply = <&vddao_3v3>; - vqmmc-supply = <&vddio_card>; -}; - -/* eMMC */ -&sd_emmc_c { - status = "okay"; - pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; - pinctrl-1 = <&emmc_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <8>; - cap-mmc-highspeed; - max-frequency = <200000000>; - non-removable; - disable-wp; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - - mmc-pwrseq = <&emmc_pwrseq>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vddio_boot>; -}; - -/* This UART is brought out to the DB9 connector */ -&uart_AO { - status = "okay"; - pinctrl-0 = <&uart_ao_a_pins>; - pinctrl-names = "default"; -}; - -&usb0_phy { - status = "okay"; - phy-supply = <&usb_pwr>; -}; - -&usb1_phy { - status = "okay"; -}; - -&usb0 { - status = "okay"; -}; - -&usb1 { - status = "okay"; -}; diff --git a/arch/arm/dts/meson-gxbb-wetek-hub.dts b/arch/arm/dts/meson-gxbb-wetek-hub.dts deleted file mode 100644 index 58733017eda8..000000000000 --- a/arch/arm/dts/meson-gxbb-wetek-hub.dts +++ /dev/null @@ -1,58 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 BayLibre, Inc. - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -/dts-v1/; - -#include "meson-gxbb-wetek.dtsi" -#include <dt-bindings/sound/meson-aiu.h> - -/ { - compatible = "wetek,hub", "amlogic,meson-gxbb"; - model = "WeTek Hub"; - - sound { - compatible = "amlogic,gx-sound-card"; - model = "WETEK-HUB"; - assigned-clocks = <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>, - <&clkc CLKID_MPLL2>; - assigned-clock-parents = <0>, <0>, <0>; - assigned-clock-rates = <294912000>, - <270950400>, - <393216000>; - status = "okay"; - - dai-link-0 { - sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; - }; - - dai-link-1 { - sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; - dai-format = "i2s"; - mclk-fs = <256>; - - codec-0 { - sound-dai = <&aiu AIU_HDMI CTRL_I2S>; - }; - }; - - dai-link-2 { - sound-dai = <&aiu AIU_HDMI CTRL_OUT>; - - codec-0 { - sound-dai = <&hdmi_tx>; - }; - }; - }; -}; - -&aiu { - status = "okay"; -}; - -&ir { - linux,rc-map-name = "rc-wetek-hub"; -}; diff --git a/arch/arm/dts/meson-gxbb-wetek-play2.dts b/arch/arm/dts/meson-gxbb-wetek-play2.dts deleted file mode 100644 index 505ffcd8eb76..000000000000 --- a/arch/arm/dts/meson-gxbb-wetek-play2.dts +++ /dev/null @@ -1,119 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 BayLibre, Inc. - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -/dts-v1/; - -#include "meson-gxbb-wetek.dtsi" -#include <dt-bindings/input/input.h> -#include <dt-bindings/sound/meson-aiu.h> - -/ { - compatible = "wetek,play2", "amlogic,meson-gxbb"; - model = "WeTek Play 2"; - - spdif_dit: audio-codec-0 { - #sound-dai-cells = <0>; - compatible = "linux,spdif-dit"; - status = "okay"; - sound-name-prefix = "DIT"; - }; - - leds { - led-wifi { - label = "wetek-play:wifi-status"; - gpios = <&gpio GPIODV_26 GPIO_ACTIVE_HIGH>; - default-state = "off"; - }; - - led-ethernet { - label = "wetek-play:ethernet-status"; - gpios = <&gpio GPIODV_27 GPIO_ACTIVE_HIGH>; - default-state = "off"; - }; - }; - - gpio-keys-polled { - compatible = "gpio-keys-polled"; - poll-interval = <100>; - - button { - label = "reset"; - linux,code = <KEY_RESTART>; - gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_LOW>; - }; - }; - - sound { - compatible = "amlogic,gx-sound-card"; - model = "WETEK-PLAY2"; - assigned-clocks = <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>, - <&clkc CLKID_MPLL2>; - assigned-clock-parents = <0>, <0>, <0>; - assigned-clock-rates = <294912000>, - <270950400>, - <393216000>; - status = "okay"; - - dai-link-0 { - sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; - }; - - dai-link-1 { - sound-dai = <&aiu AIU_CPU CPU_SPDIF_FIFO>; - }; - - dai-link-2 { - sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; - dai-format = "i2s"; - mclk-fs = <256>; - - codec-0 { - sound-dai = <&aiu AIU_HDMI CTRL_I2S>; - }; - }; - - dai-link-3 { - sound-dai = <&aiu AIU_CPU CPU_SPDIF_ENCODER>; - - codec-0 { - sound-dai = <&spdif_dit>; - }; - }; - - dai-link-4 { - sound-dai = <&aiu AIU_HDMI CTRL_OUT>; - - codec-0 { - sound-dai = <&hdmi_tx>; - }; - }; - }; -}; - -&aiu { - status = "okay"; - pinctrl-0 = <&spdif_out_y_pins>; - pinctrl-names = "default"; -}; - -&i2c_A { - status = "okay"; - pinctrl-0 = <&i2c_a_pins>; - pinctrl-names = "default"; -}; - -&usb1_phy { - status = "okay"; -}; - -&usb1 { - status = "okay"; -}; - -&ir { - linux,rc-map-name = "rc-wetek-play2"; -}; diff --git a/arch/arm/dts/meson-gxbb-wetek.dtsi b/arch/arm/dts/meson-gxbb-wetek.dtsi deleted file mode 100644 index 94dafb955301..000000000000 --- a/arch/arm/dts/meson-gxbb-wetek.dtsi +++ /dev/null @@ -1,292 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Andreas Färber - * Copyright (c) 2016 BayLibre, Inc. - * Author: Kevin Hilman khilman@kernel.org - */ - -#include "meson-gxbb.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> - -/ { - aliases { - serial0 = &uart_AO; - ethernet0 = ðmac; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x40000000>; - }; - - leds { - compatible = "gpio-leds"; - - led-power { - /* red in suspend or power-off */ - color = <LED_COLOR_ID_BLUE>; - function = LED_FUNCTION_POWER; - gpios = <&gpio_ao GPIOAO_13 GPIO_ACTIVE_HIGH>; - default-state = "on"; - panic-indicator; - }; - }; - - usb_pwr: regulator-usb-pwrs { - compatible = "regulator-fixed"; - - regulator-name = "USB_PWR"; - - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - - gpio = <&gpio GPIODV_24 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vddio_boot: regulator-vddio_boot { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_BOOT"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vddao_3v3: regulator-vddao_3v3 { - compatible = "regulator-fixed"; - regulator-name = "VDDAO_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vddio_ao18: regulator-vddio_ao18 { - compatible = "regulator-fixed"; - regulator-name = "VDDIO_AO18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vcc_3v3: regulator-vcc_3v3 { - compatible = "regulator-fixed"; - regulator-name = "VCC_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; - }; - - wifi32k: wifi32k { - compatible = "pwm-clock"; - #clock-cells = <0>; - clock-frequency = <32768>; - pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - reset-gpios = <&gpio GPIOX_6 GPIO_ACTIVE_LOW>; - clocks = <&wifi32k>; - clock-names = "ext_clock"; - }; - - cvbs-connector { - compatible = "composite-video-connector"; - - port { - cvbs_connector_in: endpoint { - remote-endpoint = <&cvbs_vdac_out>; - }; - }; - }; - - hdmi-connector { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&hdmi_tx_tmds_out>; - }; - }; - }; -}; - -&cec_AO { - status = "okay"; - pinctrl-0 = <&ao_cec_pins>; - pinctrl-names = "default"; - hdmi-phandle = <&hdmi_tx>; -}; - -&cvbs_vdac_port { - cvbs_vdac_out: endpoint { - remote-endpoint = <&cvbs_connector_in>; - }; -}; - -ðmac { - status = "okay"; - pinctrl-0 = <ð_rgmii_pins>; - pinctrl-names = "default"; - - phy-handle = <ð_phy0>; - phy-mode = "rgmii"; - - amlogic,tx-delay-ns = <2>; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - eth_phy0: ethernet-phy@0 { - /* Realtek RTL8211F (0x001cc916) */ - reg = <0>; - - reset-assert-us = <10000>; - reset-deassert-us = <80000>; - reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; - - interrupt-parent = <&gpio_intc>; - /* MAC_INTR on GPIOZ_15 */ - interrupts = <29 IRQ_TYPE_LEVEL_LOW>; - }; - }; -}; - -&hdmi_tx { - status = "okay"; - pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; - pinctrl-names = "default"; - hdmi-supply = <&vddio_ao18>; -}; - -&hdmi_tx_tmds_port { - hdmi_tx_tmds_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; -}; - -&ir { - status = "okay"; - pinctrl-0 = <&remote_input_ao_pins>; - pinctrl-names = "default"; -}; - -&pwm_ef { - status = "okay"; - pinctrl-0 = <&pwm_e_pins>; - pinctrl-names = "default"; - clocks = <&clkc CLKID_FCLK_DIV4>; - clock-names = "clkin0"; -}; - -&saradc { - status = "okay"; - vref-supply = <&vddio_ao18>; -}; - -/* Wireless SDIO Module */ -&sd_emmc_a { - status = "okay"; - pinctrl-0 = <&sdio_pins>; - pinctrl-1 = <&sdio_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - #address-cells = <1>; - #size-cells = <0>; - - bus-width = <4>; - cap-sd-highspeed; - max-frequency = <50000000>; - - non-removable; - disable-wp; - - /* WiFi firmware requires power to be kept while in suspend */ - keep-power-in-suspend; - - mmc-pwrseq = <&sdio_pwrseq>; - - vmmc-supply = <&vddao_3v3>; - vqmmc-supply = <&vddio_boot>; - - brcmf: wifi@1 { - reg = <1>; - compatible = "brcm,bcm4329-fmac"; - }; -}; - -/* SD card */ -&sd_emmc_b { - status = "okay"; - pinctrl-0 = <&sdcard_pins>; - pinctrl-1 = <&sdcard_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <4>; - cap-sd-highspeed; - max-frequency = <50000000>; - disable-wp; - - cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>; - - vmmc-supply = <&vddao_3v3>; - vqmmc-supply = <&vcc_3v3>; -}; - -/* eMMC */ -&sd_emmc_c { - status = "okay"; - pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; - pinctrl-1 = <&emmc_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <8>; - cap-mmc-highspeed; - max-frequency = <200000000>; - non-removable; - disable-wp; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - - mmc-pwrseq = <&emmc_pwrseq>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vddio_boot>; -}; - -/* This is connected to the Bluetooth module: */ -&uart_A { - status = "okay"; - pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>; - pinctrl-names = "default"; - uart-has-rtscts; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - shutdown-gpios = <&gpio GPIOX_20 GPIO_ACTIVE_HIGH>; - }; -}; - -/* This UART is brought out to the DB9 connector */ -&uart_AO { - status = "okay"; - pinctrl-0 = <&uart_ao_a_pins>; - pinctrl-names = "default"; -}; - -&usb0_phy { - status = "okay"; - phy-supply = <&usb_pwr>; -}; - -&usb0 { - status = "okay"; -}; diff --git a/arch/arm/dts/meson-gxbb.dtsi b/arch/arm/dts/meson-gxbb.dtsi deleted file mode 100644 index 12ef6e81c8bd..000000000000 --- a/arch/arm/dts/meson-gxbb.dtsi +++ /dev/null @@ -1,870 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Andreas Färber - */ - -#include "meson-gx.dtsi" -#include "meson-gx-mali450.dtsi" -#include <dt-bindings/gpio/meson-gxbb-gpio.h> -#include <dt-bindings/reset/amlogic,meson-gxbb-reset.h> -#include <dt-bindings/clock/gxbb-clkc.h> -#include <dt-bindings/clock/gxbb-aoclkc.h> -#include <dt-bindings/reset/gxbb-aoclkc.h> - -/ { - compatible = "amlogic,meson-gxbb"; - - soc { - usb0_phy: phy@c0000000 { - compatible = "amlogic,meson-gxbb-usb2-phy"; - #phy-cells = <0>; - reg = <0x0 0xc0000000 0x0 0x20>; - resets = <&reset RESET_USB_OTG>; - clocks = <&clkc CLKID_USB>, <&clkc CLKID_USB0>; - clock-names = "usb_general", "usb"; - status = "disabled"; - }; - - usb1_phy: phy@c0000020 { - compatible = "amlogic,meson-gxbb-usb2-phy"; - #phy-cells = <0>; - reg = <0x0 0xc0000020 0x0 0x20>; - resets = <&reset RESET_USB_OTG>; - clocks = <&clkc CLKID_USB>, <&clkc CLKID_USB1>; - clock-names = "usb_general", "usb"; - status = "disabled"; - }; - - usb0: usb@c9000000 { - compatible = "amlogic,meson-gxbb-usb", "snps,dwc2"; - reg = <0x0 0xc9000000 0x0 0x40000>; - interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clkc CLKID_USB0_DDR_BRIDGE>; - clock-names = "otg"; - phys = <&usb0_phy>; - phy-names = "usb2-phy"; - dr_mode = "host"; - status = "disabled"; - }; - - usb1: usb@c9100000 { - compatible = "amlogic,meson-gxbb-usb", "snps,dwc2"; - reg = <0x0 0xc9100000 0x0 0x40000>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clkc CLKID_USB1_DDR_BRIDGE>; - clock-names = "otg"; - phys = <&usb1_phy>; - phy-names = "usb2-phy"; - dr_mode = "host"; - status = "disabled"; - }; - }; -}; - -&aiu { - compatible = "amlogic,aiu-gxbb", "amlogic,aiu"; - clocks = <&clkc CLKID_AIU_GLUE>, - <&clkc CLKID_I2S_OUT>, - <&clkc CLKID_AOCLK_GATE>, - <&clkc CLKID_CTS_AMCLK>, - <&clkc CLKID_MIXER_IFACE>, - <&clkc CLKID_IEC958>, - <&clkc CLKID_IEC958_GATE>, - <&clkc CLKID_CTS_MCLK_I958>, - <&clkc CLKID_CTS_I958>; - clock-names = "pclk", - "i2s_pclk", - "i2s_aoclk", - "i2s_mclk", - "i2s_mixer", - "spdif_pclk", - "spdif_aoclk", - "spdif_mclk", - "spdif_mclk_sel"; - resets = <&reset RESET_AIU>; -}; - -&aobus { - pinctrl_aobus: pinctrl@14 { - compatible = "amlogic,meson-gxbb-aobus-pinctrl"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - gpio_ao: bank@14 { - reg = <0x0 0x00014 0x0 0x8>, - <0x0 0x0002c 0x0 0x4>, - <0x0 0x00024 0x0 0x8>; - reg-names = "mux", "pull", "gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pinctrl_aobus 0 0 14>; - }; - - uart_ao_a_pins: uart_ao_a { - mux { - groups = "uart_tx_ao_a", "uart_rx_ao_a"; - function = "uart_ao"; - bias-disable; - }; - }; - - uart_ao_a_cts_rts_pins: uart_ao_a_cts_rts { - mux { - groups = "uart_cts_ao_a", - "uart_rts_ao_a"; - function = "uart_ao"; - bias-disable; - }; - }; - - uart_ao_b_pins: uart_ao_b { - mux { - groups = "uart_tx_ao_b", "uart_rx_ao_b"; - function = "uart_ao_b"; - bias-disable; - }; - }; - - uart_ao_b_cts_rts_pins: uart_ao_b_cts_rts { - mux { - groups = "uart_cts_ao_b", - "uart_rts_ao_b"; - function = "uart_ao_b"; - bias-disable; - }; - }; - - remote_input_ao_pins: remote_input_ao { - mux { - groups = "remote_input_ao"; - function = "remote_input_ao"; - bias-disable; - }; - }; - - i2c_ao_pins: i2c_ao { - mux { - groups = "i2c_sck_ao", - "i2c_sda_ao"; - function = "i2c_ao"; - bias-disable; - }; - }; - - pwm_ao_a_3_pins: pwm_ao_a_3 { - mux { - groups = "pwm_ao_a_3"; - function = "pwm_ao_a_3"; - bias-disable; - }; - }; - - pwm_ao_a_6_pins: pwm_ao_a_6 { - mux { - groups = "pwm_ao_a_6"; - function = "pwm_ao_a_6"; - bias-disable; - }; - }; - - pwm_ao_a_12_pins: pwm_ao_a_12 { - mux { - groups = "pwm_ao_a_12"; - function = "pwm_ao_a_12"; - bias-disable; - }; - }; - - pwm_ao_b_pins: pwm_ao_b { - mux { - groups = "pwm_ao_b"; - function = "pwm_ao_b"; - bias-disable; - }; - }; - - i2s_am_clk_pins: i2s_am_clk { - mux { - groups = "i2s_am_clk"; - function = "i2s_out_ao"; - bias-disable; - }; - }; - - i2s_out_ao_clk_pins: i2s_out_ao_clk { - mux { - groups = "i2s_out_ao_clk"; - function = "i2s_out_ao"; - bias-disable; - }; - }; - - i2s_out_lr_clk_pins: i2s_out_lr_clk { - mux { - groups = "i2s_out_lr_clk"; - function = "i2s_out_ao"; - bias-disable; - }; - }; - - i2s_out_ch01_ao_pins: i2s_out_ch01_ao { - mux { - groups = "i2s_out_ch01_ao"; - function = "i2s_out_ao"; - bias-disable; - }; - }; - - i2s_out_ch23_ao_pins: i2s_out_ch23_ao { - mux { - groups = "i2s_out_ch23_ao"; - function = "i2s_out_ao"; - bias-disable; - }; - }; - - i2s_out_ch45_ao_pins: i2s_out_ch45_ao { - mux { - groups = "i2s_out_ch45_ao"; - function = "i2s_out_ao"; - bias-disable; - }; - }; - - spdif_out_ao_6_pins: spdif_out_ao_6 { - mux { - groups = "spdif_out_ao_6"; - function = "spdif_out_ao"; - }; - }; - - spdif_out_ao_13_pins: spdif_out_ao_13 { - mux { - groups = "spdif_out_ao_13"; - function = "spdif_out_ao"; - bias-disable; - }; - }; - - ao_cec_pins: ao_cec { - mux { - groups = "ao_cec"; - function = "cec_ao"; - bias-disable; - }; - }; - - ee_cec_pins: ee_cec { - mux { - groups = "ee_cec"; - function = "cec_ao"; - bias-disable; - }; - }; - }; -}; - -&cbus { - spifc: spi@8c80 { - compatible = "amlogic,meson-gxbb-spifc"; - reg = <0x0 0x08c80 0x0 0x80>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&clkc CLKID_SPI>; - status = "disabled"; - }; -}; - -&cec_AO { - clocks = <&clkc_AO CLKID_AO_CEC_32K>; - clock-names = "core"; -}; - -&clkc_AO { - compatible = "amlogic,meson-gxbb-aoclkc", "amlogic,meson-gx-aoclkc"; - clocks = <&xtal>, <&clkc CLKID_CLK81>; - clock-names = "xtal", "mpeg-clk"; -}; - -&efuse { - clocks = <&clkc CLKID_EFUSE>; -}; - -ðmac { - clocks = <&clkc CLKID_ETH>, - <&clkc CLKID_FCLK_DIV2>, - <&clkc CLKID_MPLL2>, - <&clkc CLKID_FCLK_DIV2>; - clock-names = "stmmaceth", "clkin0", "clkin1", "timing-adjustment"; -}; - -&gpio_intc { - compatible = "amlogic,meson-gxbb-gpio-intc", - "amlogic,meson-gpio-intc"; - status = "okay"; -}; - -&hdmi_tx { - compatible = "amlogic,meson-gxbb-dw-hdmi", "amlogic,meson-gx-dw-hdmi"; - resets = <&reset RESET_HDMITX_CAPB3>, - <&reset RESET_HDMI_SYSTEM_RESET>, - <&reset RESET_HDMI_TX>; - reset-names = "hdmitx_apb", "hdmitx", "hdmitx_phy"; - clocks = <&clkc CLKID_HDMI_PCLK>, - <&clkc CLKID_CLK81>, - <&clkc CLKID_GCLK_VENCI_INT0>; - clock-names = "isfr", "iahb", "venci"; -}; - -&sysctrl { - clkc: clock-controller { - compatible = "amlogic,gxbb-clkc"; - #clock-cells = <1>; - clocks = <&xtal>; - clock-names = "xtal"; - }; -}; - -&hwrng { - clocks = <&clkc CLKID_RNG0>; - clock-names = "core"; -}; - -&i2c_A { - clocks = <&clkc CLKID_I2C>; -}; - -&i2c_AO { - clocks = <&clkc CLKID_AO_I2C>; -}; - -&i2c_B { - clocks = <&clkc CLKID_I2C>; -}; - -&i2c_C { - clocks = <&clkc CLKID_I2C>; -}; - -&mali { - compatible = "amlogic,meson-gxbb-mali", "arm,mali-450"; - - clocks = <&clkc CLKID_CLK81>, <&clkc CLKID_MALI>; - clock-names = "bus", "core"; - - assigned-clocks = <&clkc CLKID_GP0_PLL>; - assigned-clock-rates = <744000000>; -}; - -&periphs { - pinctrl_periphs: pinctrl@4b0 { - compatible = "amlogic,meson-gxbb-periphs-pinctrl"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - gpio: bank@4b0 { - reg = <0x0 0x004b0 0x0 0x28>, - <0x0 0x004e8 0x0 0x14>, - <0x0 0x00520 0x0 0x14>, - <0x0 0x00430 0x0 0x40>; - reg-names = "mux", "pull", "pull-enable", "gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pinctrl_periphs 0 0 119>; - }; - - emmc_pins: emmc { - mux-0 { - groups = "emmc_nand_d07", - "emmc_cmd"; - function = "emmc"; - bias-pull-up; - }; - - mux-1 { - groups = "emmc_clk"; - function = "emmc"; - bias-disable; - }; - }; - - emmc_ds_pins: emmc-ds { - mux { - groups = "emmc_ds"; - function = "emmc"; - bias-pull-down; - }; - }; - - emmc_clk_gate_pins: emmc_clk_gate { - mux { - groups = "BOOT_8"; - function = "gpio_periphs"; - bias-pull-down; - }; - }; - - nor_pins: nor { - mux { - groups = "nor_d", - "nor_q", - "nor_c", - "nor_cs"; - function = "nor"; - bias-disable; - }; - }; - - spi_pins: spi-pins { - mux { - groups = "spi_miso", - "spi_mosi", - "spi_sclk"; - function = "spi"; - bias-disable; - }; - }; - - spi_idle_high_pins: spi-idle-high-pins { - mux { - groups = "spi_sclk"; - bias-pull-up; - }; - }; - - spi_idle_low_pins: spi-idle-low-pins { - mux { - groups = "spi_sclk"; - bias-pull-down; - }; - }; - - spi_ss0_pins: spi-ss0 { - mux { - groups = "spi_ss0"; - function = "spi"; - bias-disable; - }; - }; - - sdcard_pins: sdcard { - mux-0 { - groups = "sdcard_d0", - "sdcard_d1", - "sdcard_d2", - "sdcard_d3", - "sdcard_cmd"; - function = "sdcard"; - bias-pull-up; - }; - - mux-1 { - groups = "sdcard_clk"; - function = "sdcard"; - bias-disable; - }; - }; - - sdcard_clk_gate_pins: sdcard_clk_gate { - mux { - groups = "CARD_2"; - function = "gpio_periphs"; - bias-pull-down; - }; - }; - - sdio_pins: sdio { - mux-0 { - groups = "sdio_d0", - "sdio_d1", - "sdio_d2", - "sdio_d3", - "sdio_cmd"; - function = "sdio"; - bias-pull-up; - }; - - mux-1 { - groups = "sdio_clk"; - function = "sdio"; - bias-disable; - }; - }; - - sdio_clk_gate_pins: sdio_clk_gate { - mux { - groups = "GPIOX_4"; - function = "gpio_periphs"; - bias-pull-down; - }; - }; - - sdio_irq_pins: sdio_irq { - mux { - groups = "sdio_irq"; - function = "sdio"; - bias-disable; - }; - }; - - uart_a_pins: uart_a { - mux { - groups = "uart_tx_a", - "uart_rx_a"; - function = "uart_a"; - bias-disable; - }; - }; - - uart_a_cts_rts_pins: uart_a_cts_rts { - mux { - groups = "uart_cts_a", - "uart_rts_a"; - function = "uart_a"; - bias-disable; - }; - }; - - uart_b_pins: uart_b { - mux { - groups = "uart_tx_b", - "uart_rx_b"; - function = "uart_b"; - bias-disable; - }; - }; - - uart_b_cts_rts_pins: uart_b_cts_rts { - mux { - groups = "uart_cts_b", - "uart_rts_b"; - function = "uart_b"; - bias-disable; - }; - }; - - uart_c_pins: uart_c { - mux { - groups = "uart_tx_c", - "uart_rx_c"; - function = "uart_c"; - bias-disable; - }; - }; - - uart_c_cts_rts_pins: uart_c_cts_rts { - mux { - groups = "uart_cts_c", - "uart_rts_c"; - function = "uart_c"; - bias-disable; - }; - }; - - i2c_a_pins: i2c_a { - mux { - groups = "i2c_sck_a", - "i2c_sda_a"; - function = "i2c_a"; - bias-disable; - }; - }; - - i2c_b_pins: i2c_b { - mux { - groups = "i2c_sck_b", - "i2c_sda_b"; - function = "i2c_b"; - bias-disable; - }; - }; - - i2c_c_pins: i2c_c { - mux { - groups = "i2c_sck_c", - "i2c_sda_c"; - function = "i2c_c"; - bias-disable; - }; - }; - - eth_rgmii_pins: eth-rgmii { - mux { - groups = "eth_mdio", - "eth_mdc", - "eth_clk_rx_clk", - "eth_rx_dv", - "eth_rxd0", - "eth_rxd1", - "eth_rxd2", - "eth_rxd3", - "eth_rgmii_tx_clk", - "eth_tx_en", - "eth_txd0", - "eth_txd1", - "eth_txd2", - "eth_txd3"; - function = "eth"; - bias-disable; - }; - }; - - eth_rmii_pins: eth-rmii { - mux { - groups = "eth_mdio", - "eth_mdc", - "eth_clk_rx_clk", - "eth_rx_dv", - "eth_rxd0", - "eth_rxd1", - "eth_tx_en", - "eth_txd0", - "eth_txd1"; - function = "eth"; - bias-disable; - }; - }; - - pwm_a_x_pins: pwm_a_x { - mux { - groups = "pwm_a_x"; - function = "pwm_a_x"; - bias-disable; - }; - }; - - pwm_a_y_pins: pwm_a_y { - mux { - groups = "pwm_a_y"; - function = "pwm_a_y"; - bias-disable; - }; - }; - - pwm_b_pins: pwm_b { - mux { - groups = "pwm_b"; - function = "pwm_b"; - bias-disable; - }; - }; - - pwm_d_pins: pwm_d { - mux { - groups = "pwm_d"; - function = "pwm_d"; - bias-disable; - }; - }; - - pwm_e_pins: pwm_e { - mux { - groups = "pwm_e"; - function = "pwm_e"; - bias-disable; - }; - }; - - pwm_f_x_pins: pwm_f_x { - mux { - groups = "pwm_f_x"; - function = "pwm_f_x"; - bias-disable; - }; - }; - - pwm_f_y_pins: pwm_f_y { - mux { - groups = "pwm_f_y"; - function = "pwm_f_y"; - bias-disable; - }; - }; - - hdmi_hpd_pins: hdmi_hpd { - mux { - groups = "hdmi_hpd"; - function = "hdmi_hpd"; - bias-disable; - }; - }; - - hdmi_i2c_pins: hdmi_i2c { - mux { - groups = "hdmi_sda", "hdmi_scl"; - function = "hdmi_i2c"; - bias-disable; - }; - }; - - i2sout_ch23_y_pins: i2sout_ch23_y { - mux { - groups = "i2sout_ch23_y"; - function = "i2s_out"; - bias-disable; - }; - }; - - i2sout_ch45_y_pins: i2sout_ch45_y { - mux { - groups = "i2sout_ch45_y"; - function = "i2s_out"; - bias-disable; - }; - }; - - i2sout_ch67_y_pins: i2sout_ch67_y { - mux { - groups = "i2sout_ch67_y"; - function = "i2s_out"; - bias-disable; - }; - }; - - spdif_out_y_pins: spdif_out_y { - mux { - groups = "spdif_out_y"; - function = "spdif_out"; - bias-disable; - }; - }; - }; -}; - -&pwrc { - resets = <&reset RESET_VIU>, - <&reset RESET_VENC>, - <&reset RESET_VCBUS>, - <&reset RESET_BT656>, - <&reset RESET_DVIN_RESET>, - <&reset RESET_RDMA>, - <&reset RESET_VENCI>, - <&reset RESET_VENCP>, - <&reset RESET_VDAC>, - <&reset RESET_VDI6>, - <&reset RESET_VENCL>, - <&reset RESET_VID_LOCK>; - reset-names = "viu", "venc", "vcbus", "bt656", - "dvin", "rdma", "venci", "vencp", - "vdac", "vdi6", "vencl", "vid_lock"; - clocks = <&clkc CLKID_VPU>, - <&clkc CLKID_VAPB>; - clock-names = "vpu", "vapb"; - /* - * VPU clocking is provided by two identical clock paths - * VPU_0 and VPU_1 muxed to a single clock by a glitch - * free mux to safely change frequency while running. - * Same for VAPB but with a final gate after the glitch free mux. - */ - assigned-clocks = <&clkc CLKID_VPU_0_SEL>, - <&clkc CLKID_VPU_0>, - <&clkc CLKID_VPU>, /* Glitch free mux */ - <&clkc CLKID_VAPB_0_SEL>, - <&clkc CLKID_VAPB_0>, - <&clkc CLKID_VAPB_SEL>; /* Glitch free mux */ - assigned-clock-parents = <&clkc CLKID_FCLK_DIV3>, - <0>, /* Do Nothing */ - <&clkc CLKID_VPU_0>, - <&clkc CLKID_FCLK_DIV4>, - <0>, /* Do Nothing */ - <&clkc CLKID_VAPB_0>; - assigned-clock-rates = <0>, /* Do Nothing */ - <666666666>, - <0>, /* Do Nothing */ - <0>, /* Do Nothing */ - <250000000>, - <0>; /* Do Nothing */ -}; - -&saradc { - compatible = "amlogic,meson-gxbb-saradc", "amlogic,meson-saradc"; - clocks = <&xtal>, - <&clkc CLKID_SAR_ADC>, - <&clkc CLKID_SAR_ADC_CLK>, - <&clkc CLKID_SAR_ADC_SEL>; - clock-names = "clkin", "core", "adc_clk", "adc_sel"; -}; - -&sd_emmc_a { - clocks = <&clkc CLKID_SD_EMMC_A>, - <&clkc CLKID_SD_EMMC_A_CLK0>, - <&clkc CLKID_FCLK_DIV2>; - clock-names = "core", "clkin0", "clkin1"; - resets = <&reset RESET_SD_EMMC_A>; -}; - -&sd_emmc_b { - clocks = <&clkc CLKID_SD_EMMC_B>, - <&clkc CLKID_SD_EMMC_B_CLK0>, - <&clkc CLKID_FCLK_DIV2>; - clock-names = "core", "clkin0", "clkin1"; - resets = <&reset RESET_SD_EMMC_B>; -}; - -&sd_emmc_c { - clocks = <&clkc CLKID_SD_EMMC_C>, - <&clkc CLKID_SD_EMMC_C_CLK0>, - <&clkc CLKID_FCLK_DIV2>; - clock-names = "core", "clkin0", "clkin1"; - resets = <&reset RESET_SD_EMMC_C>; -}; - -&simplefb_hdmi { - clocks = <&clkc CLKID_HDMI_PCLK>, - <&clkc CLKID_CLK81>, - <&clkc CLKID_GCLK_VENCI_INT0>; -}; - -&spicc { - clocks = <&clkc CLKID_SPICC>; - clock-names = "core"; - resets = <&reset RESET_PERIPHS_SPICC>; - num-cs = <1>; -}; - -&spifc { - clocks = <&clkc CLKID_SPI>; -}; - -&uart_A { - clocks = <&xtal>, <&clkc CLKID_UART0>, <&xtal>; - clock-names = "xtal", "pclk", "baud"; -}; - -&uart_AO { - clocks = <&xtal>, <&clkc_AO CLKID_AO_UART1>, <&xtal>; - clock-names = "xtal", "pclk", "baud"; -}; - -&uart_AO_B { - clocks = <&xtal>, <&clkc_AO CLKID_AO_UART2>, <&xtal>; - clock-names = "xtal", "pclk", "baud"; -}; - -&uart_B { - clocks = <&xtal>, <&clkc CLKID_UART1>, <&xtal>; - clock-names = "xtal", "pclk", "baud"; -}; - -&uart_C { - clocks = <&xtal>, <&clkc CLKID_UART2>, <&xtal>; - clock-names = "xtal", "pclk", "baud"; -}; - -&vpu { - compatible = "amlogic,meson-gxbb-vpu", "amlogic,meson-gx-vpu"; - power-domains = <&pwrc PWRC_GXBB_VPU_ID>; -}; - -&vdec { - compatible = "amlogic,gxbb-vdec", "amlogic,gx-vdec"; - clocks = <&clkc CLKID_DOS_PARSER>, - <&clkc CLKID_DOS>, - <&clkc CLKID_VDEC_1>, - <&clkc CLKID_VDEC_HEVC>; - clock-names = "dos_parser", "dos", "vdec_1", "vdec_hevc"; - resets = <&reset RESET_PARSER>; - reset-names = "esparser"; -};
Hi Tom,
On Thu, 22 Feb 2024 at 15:06, Sumit Garg sumit.garg@linaro.org wrote:
Changes in v6:
- v6_dt: https://github.com/b49020/u-boot/tree/v6_dt
- Patch #3: Incorporate fix for sandbox CI failure.
- Patch #6: Incorporate shell script comments from Marek.
- Patch #8: Incorporate documentation review comments from Paul.
I haven't heard any major feedback/comments for v6. So can you pick up this series for the U-Boot -next branch? As you may already be aware that it is a dependency for [1] [2] [3]. Also, we would like to move all new Qcom platforms to use upstream DT too.
[1] https://patchwork.ozlabs.org/project/uboot/list/?series=396399 [2] https://patchwork.ozlabs.org/project/uboot/list/?series=396742 [3] https://patchwork.ozlabs.org/project/uboot/list/?series=396992&state=*
-Sumit
Changes in v5:
- Rebased on tip of master (050a9b981d6a835133521b599be3ae189ce70f41)
- Created v5_dt branch for testing purposes: https://github.com/b49020/u-boot/tree/v5_dt
- Patch #6: Added support to cherry-pick fixes in subtree update script. Also, used https:// instead of git://.
- Patch #7: Fixed inappropriate documentation update.
- Patch #8: Document how to cherry-pick fixes from devicetree-rebasing tree.
Changes in v4:
- Switched subtree to be imported as dts/upstream sub-directory rather than devicetree-rebasing sub-directory to better suite U-Boot directory structure.
- Since we now have v6.7-dts tag available now, so switch subtree to that from its beginning.
- Patch #2: Incorporate build fix to adjust Bindings Makefile rules to old U-Boot Kbuild infrastructure.
- Patch #3: Incorporate fix to resolve rk3399 migration issue reported by Simon.
- Patch #4: New patch to reuse upstream DT includes by U-Boot as per Brian's use-case for TI K3 SoCs.
- Patch #5: Added a note to OF_UPSTREAM Kconfig option.
- Patch #6: New patch to add script dts/update-dts-subtree.sh as per Rob's comments.
- Patch #7: Separate patch to align documentation to use Kconfig symbols instead.
- Patch #8: Clarify subtree uprev schedule as a separate documentation section. Also, fixed documentation typos.
- Patch #9: Added commit description.
Changes in v3:
- Patch #4: Minor commit message update
- Patch #5: Replace CONFIG_* with Kconfig options
- Patch #7: Dropped Makefile portion and enabled OF_UPSTREAM for SoC instead.
- Patch #1, #3, #6 and #8: Picked up review tags
Changes in v2:
- Patch #1: excluded gitab CI config check and added commit description.
- Patch #3: s/UBOOT_DTSI_LOC/u_boot_dtsi_loc/
- Patch #4: s/DEVICE_TREE_LOC/dt_dir/ and s/U-boot/U-Boot/
- Patch #5: s/U-boot/U-Boot/
- Patch #6 and #7: Picked up review tags
Prerequisite
This patch series requires devicetree-rebasing git repo to be added as a subtree to the main U-Boot repo via:
$ git subtree add --prefix dts/upstream \ https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... \ v6.7-dts --squash
Background
This effort started while I was reviewing patch series corresponding to Qcom platforms [1] which was about to import modified devicetree source files from Linux kernel. I suppose keeping devicetree files sync with Linux kernel without any DT bindings schema validation has been a pain for U-Boot SoC/platform maintainers. There has been past discussions about a single DT repo but that hasn't come up and Linux kernel remained the place where DT source files as well as bindings are placed and maintained.
However, Linux kernel DT maintainers proposed [2] for U-Boot to rather use devicetree-rebasing repo [3] which is a forked copy from Linux kernel for DT source files as well as bindings. It is tagged at every Linux kernel major release or intermideate release candidates. So here I have tried to reuse that to bring DT bingings compliance as well as a standard way to maintain a regular sync of DT source files with Linux kernel.
In order to maintain devicetree files sync, U-Boot will maintains a Git subtree for devicetee-rebasing repo as `dts/upstream` sub-directory. U-Boot will regularly sync `dts/upstream/` subtree whenever the next window opens with the next available kernel major release. `dts/update-dts-subtree.sh` script provides a wrapper around git subtree pull command, usage from the top level U-Boot source tree, run:
$ ./dts/update-dts-subtree.sh pull <devicetree-rebasing-release-tag>
If required it is also possible to cherry-pick fixes from devicetree-rebasing tree prior to next sync, usage:
$ ./dts/update-dts-subtree.sh pick <devicetree-rebasing-commit-id>
The RFC/prototype for this series has been discussed with Linux DT maintainers as well as U-Boot maintainers here [4]. Now we would like to reach out to wider U-Boot community to seek feedback.
[1] https://lore.kernel.org/all/CAFA6WYMLUD9cnkr=R0Uur+1UeTMkKjM2zDdMJtXb3nmrLk+... [2] https://lore.kernel.org/all/CAL_JsqKEjv2tSGmT+0ZiO7_qbBfhTycbGnhJhYpKDFzfO9j... [3] https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... [4] https://github.com/u-boot/u-boot/pull/451
Changes
Traditionally, U-Boot placed copies of devicetree source files from Linux kernel into `arch/<arch>/dts/<name>.dts` which can be selected via setting "<name>" when prompted for `DEFAULT_DEVICE_TREE` by Kconfig.
SoC/board maintainers are encouraged to migrate to use synced copies from `dts/upstream/src/<arch>/<vendor>`. To do that enable `OF_UPSTREAM` for the SoC being used via Kconfig and set up "<vendor>/<name>" when prompted for `DEFAULT_DEVICE_TREE` by Kconfig.
An example have been shown for Amlogic meson-gxbb SoC and corresponding derived boards via patch #10 and #11.
Devicetree bindings schema checks
With devicetee-rebasing Git subtree, the devicetree bindings are also regularly synced with Linux kernel as `dts/upstream/Bindings/` sub-directory. This allows U-Boot to run devicetree bindings schema checks which will bring compliance to U-Boot core/drivers regarding usage of devicetree.
Dependencies
The DT schema project must be installed in order to validate the DT schema binding documents and validate DTS files using the DT schema. The DT schema project can be installed with pip:
$ pip3 install dtschema
Note that 'dtschema' installation requires 'swig' and Python development files installed first. On Debian/Ubuntu systems:
$ apt install swig python3-dev
Several executables (dt-doc-validate, dt-mk-schema, dt-validate) will be installed. Ensure they are in your PATH (~/.local/bin by default).
Recommended is also to install yamllint (used by dtschema when present).
$ apt install yamllint
Running checks
In order to perform validation of DTB files, use the ``dtbs_check`` target:
$ make dtbs_check
It is also possible to run checks with a subset of matching schema files by setting the ``DT_SCHEMA_FILES`` variable to 1 or more specific schema files or patterns (partial match of a fixed string). Each file or pattern should be separated by ':'.
$ make dtbs_check DT_SCHEMA_FILES=trivial-devices.yaml:rtc.yaml $ make dtbs_check DT_SCHEMA_FILES=/gpio/ $ make dtbs_check DT_SCHEMA_FILES=trivial-devices.yaml
Sumit Garg (11): CI: Exclude devicetree-rebasing subtree for CONFIG checks Makefile: Add support for DT bindings schema checks scripts/Makefile.lib: Statically define *-u-boot.dtsi files location Makefile: Allow upstream DT subtree to provide DT includes dts: Add alternative location for upstream DTB builds dts: Add script to uprev dts/upstream subtree doc: devicetree: Align documentation to use Kconfig options doc: devicetree: Updates for devicetree-rebasing subtree MAINTAINERS: Add myself as devicetree-rebasing maintainer dts: meson-gxbb: Switch to using upstream DT dts: meson-gxbb: Drop redundant devicetree files
.azure-pipelines.yml | 3 +- .gitlab-ci.yml | 3 +- MAINTAINERS | 5 + Makefile | 23 +- arch/arm/dts/Makefile | 8 - arch/arm/dts/meson-gxbb-kii-pro.dts | 140 ---- arch/arm/dts/meson-gxbb-nanopi-k2.dts | 426 ------------ arch/arm/dts/meson-gxbb-odroidc2.dts | 414 ----------- arch/arm/dts/meson-gxbb-p200.dts | 100 --- arch/arm/dts/meson-gxbb-p201.dts | 26 - arch/arm/dts/meson-gxbb-p20x.dtsi | 250 ------- arch/arm/dts/meson-gxbb-wetek-hub.dts | 58 -- arch/arm/dts/meson-gxbb-wetek-play2.dts | 119 ---- arch/arm/dts/meson-gxbb-wetek.dtsi | 292 -------- arch/arm/dts/meson-gxbb.dtsi | 870 ------------------------ arch/arm/mach-meson/Kconfig | 1 + configs/nanopi-k2_defconfig | 2 +- configs/odroid-c2_defconfig | 2 +- configs/p200_defconfig | 2 +- configs/p201_defconfig | 2 +- configs/videostrong-kii-pro_defconfig | 2 +- configs/wetek-hub_defconfig | 2 +- configs/wetek-play2_defconfig | 2 +- doc/develop/devicetree/control.rst | 159 +++-- dts/Kconfig | 16 + dts/Makefile | 17 +- dts/update-dts-subtree.sh | 48 ++ dts/upstream/Bindings/Makefile | 6 +- dts/upstream/src/arm64/Makefile | 14 + scripts/Makefile.lib | 50 +- 30 files changed, 283 insertions(+), 2779 deletions(-) delete mode 100644 arch/arm/dts/meson-gxbb-kii-pro.dts delete mode 100644 arch/arm/dts/meson-gxbb-nanopi-k2.dts delete mode 100644 arch/arm/dts/meson-gxbb-odroidc2.dts delete mode 100644 arch/arm/dts/meson-gxbb-p200.dts delete mode 100644 arch/arm/dts/meson-gxbb-p201.dts delete mode 100644 arch/arm/dts/meson-gxbb-p20x.dtsi delete mode 100644 arch/arm/dts/meson-gxbb-wetek-hub.dts delete mode 100644 arch/arm/dts/meson-gxbb-wetek-play2.dts delete mode 100644 arch/arm/dts/meson-gxbb-wetek.dtsi delete mode 100644 arch/arm/dts/meson-gxbb.dtsi create mode 100755 dts/update-dts-subtree.sh create mode 100644 dts/upstream/src/arm64/Makefile
-- 2.34.1
On Thu, 22 Feb 2024 15:05:56 +0530, Sumit Garg wrote:
Changes in v6:
Changes in v6:
Thanks Tom and everyone involved with the reviews. I hope we can carry forward from this effort towards a healthy devicetree story for U-Boot.
-Sumit
-- Tom
Changes in v6:
Thanks Sumit!
I'll try to submit patches for Amlogic GXL & G12A to switch to this!
Neil
-Sumit
-- Tom
Changes in v6:
Thanks Sumit!
Thanks Neil for your support to be the first volunteer for this OF_UPSTREAM switch.
-Sumit
Neil
-Sumit
-- Tom
Hi Sumit,
Changes in v6:
I am trying to use OF_UPSTREAM with imx8mp_evk_defconfig:
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 328c3e388051..29d0c5ce6485 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -8,6 +8,7 @@ config IMX8M select LTO select ROM_UNIFIED_SECTIONS select ARMV8_CRYPTO + imply OF_UPSTREAM
config IMX8MQ bool diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index 2350d2f409b7..cdf840c683c0 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -8,7 +8,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x400000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx8mp-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx8mp-evk" CONFIG_SPL_TEXT_BASE=0x920000 CONFIG_TARGET_IMX8MP_EVK=y CONFIG_SYS_MONITOR_LEN=524288
I ran "./dts/update-dts-subtree.sh pull v6.8-rc6-dts".
make mrproper make imx8mp_evk_defconfig make
The dtb is built: dts/upstream/src/arm64/freescale/imx8mp-evk.dtb
but mkimage still looks for the old path:
MKIMAGE u-boot.img ./tools/mkimage: Can't open arch/arm/dts/freescale/imx8mp-evk.dtb: No such file or directory ./tools/mkimage: failed to build FIT
Any suggestions?
Thanks
Hi Fabio,
On Fri, 1 Mar 2024 at 22:20, Fabio Estevam festevam@gmail.com wrote:
Hi Sumit,
Changes in v6:
imply OF_UPSTREAM
Any suggestions?
I think you also need Bryan's patch [1] to be incorporated as well. Give it a try and let me know if you still see any further issues.
[1] https://patchwork.ozlabs.org/project/uboot/patch/20240205-am62px-wip-rebasin...
-Sumit
Thanks
Hi Sumit,
I applied this patch, but now I get a different error:
BINMAN .binman_stamp Wrote map file './itb.map' to show errors binman: Filename 'freescale/imx8mp-evk.dtb' not found in input path (.,.,./board/freescale/imx8mp_evk,arch/arm/dts) (cwd='/home/fabio/denx/u-boot') make: *** [Makefile:1126: .binman_stamp] Error 1
On Mon, 4 Mar 2024 at 16:54, Fabio Estevam festevam@gmail.com wrote:
Hi Sumit,
I suppose the earlier reference patch wasn't complete, can you rather try its v4 [1] instead?
[1] https://patchwork.ozlabs.org/project/uboot/patch/20240304121257.3551104-1-su...
-Sumit
This one works, thanks!
Hi Sumit, Hi Tom,
I'm testing this for a Marvell Armada 385 board (Synology DS116). I'm on the next branch, but perhaps something is still missing.
diff --git a/configs/ds116_defconfig b/configs/ds116_defconfig index 02ddc0e7918..1fbedcf91cf 100644 --- a/configs/ds116_defconfig +++ b/configs/ds116_defconfig @@ -16,7 +16,7 @@ CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x7E0000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="armada-385-synology-ds116" +CONFIG_DEFAULT_DEVICE_TREE="marvell/armada-385-synology-ds116" CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0x4002c000 @@ -29,7 +29,6 @@ CONFIG_PCI=y CONFIG_DEBUG_UART=y CONFIG_AHCI=y CONFIG_BOOTSTD_FULL=y -CONFIG_BOOTSTD_DEFAULTS=y CONFIG_BOOTDELAY=10 CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -57,6 +56,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:1m(u-boot),7040k(kernel),64k(u-boot-env),-(data)" +CONFIG_OF_UPSTREAM=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y
# make ds116_defconfig
# grep -i ds116 .config CONFIG_SYS_BOARD="ds116" CONFIG_SYS_CONFIG_NAME="ds116" CONFIG_TARGET_DS116=y CONFIG_DEFAULT_DEVICE_TREE="marvell/armada-385-synology-ds116" CONFIG_IDENT_STRING="\nSynology DS116" CONFIG_SYS_PROMPT="DS116> " CONFIG_OF_LIST="marvell/armada-385-synology-ds116" CONFIG_SPL_OF_LIST="marvell/armada-385-synology-ds116"
Built it, and looks like vendor Marvell is missing during the Make file execution.
make -f ./scripts/Makefile.build obj=dts dtbs make -f ./scripts/Makefile.build obj=dts/upstream/src/arm dtbs scripts/Makefile.build:57: dts/upstream/src/arm/Makefile: No such file or directory make[2]: *** No rule to make target 'dts/upstream/src/arm/Makefile'. Stop. make[1]: *** [dts/Makefile:54: arch-dtbs] Error 2 make: *** [Makefile:1166: dts/dt.dtb] Error 2 make: *** Waiting for unfinished jobs.... make: Leaving directory '/usr/src/u-boot'
I also tried Bryan's patch like you've suggested to Fabio. But it seems Bryan's patch was already in the next branch. Did I miss something?
All the best , Tony
Hi Tony,
On Mon, 11 Mar 2024 at 09:20, Tony Dinh mibodhi@gmail.com wrote:
Hi Sumit, Hi Tom,
As you are building for the 32-bit Arm, you have to add a Makefile here [1] similar to this one [2] for arm64.
[1] https://source.denx.de/u-boot/u-boot/-/tree/next/dts/upstream/src/arm?ref_ty... [2] https://source.denx.de/u-boot/u-boot/-/blob/next/dts/upstream/src/arm64/Make...
-Sumit
All the best , Tony
Hi Sumit,
On Sun, Mar 10, 2024 at 11:24 PM Sumit Garg sumit.garg@linaro.org wrote:
Hi Tony,
Hi Sumit, Hi Tom,
Thanks! It works great with that Make file.
All the best, Tony
-Sumit
All the best , Tony
participants (6)
Fabio Estevam
Paul Barker
Sumit Garg
Tony Dinh
