[PATCH v8] board: kontron: pitx-imx8m: Add Kontron pitx-imx8m board support
The Kontron pitx-imx8m is an NXP i.MX8MQ based board in the pITX form factor.
The used dts is a copy of the one from linux kernel v5.16.
Signed-off-by: Heiko Thiery heiko.thiery@gmail.com --- v8: - use only one commit for board support including linux upstream dts - this includes the board dts from linux v5.16 - use common imx8mq-u-boot.dtsi - save environment boot device dependent - if boot from eMMC: save to eMMC boot partion 1 - if boot from SD: save to SD card partion 0 - get rid of unneeded off-on-delay-us for req_usdhc2_vmmc node
v7: - add external blob entry for HDMI firmware
v6: - increase PHY_ANEG_TIMEOUT - spl: print boot source on startup - spl: remove PMIC output - enable CONFIG_CMD_TIME
v5: - save env in eMMC boot partition 0
v4: update board integration
- migrate to IMX_CONFIG - convert config options to Kconfig - CONFIG_POWER_I2C - CONFIG_SPL_POWER_I2C - CONFIG_POWER_LEGACY - CONFIG_SYS_LOAD_ADDR - CONFIG_SYS_I2C_MXC - CONFIG_SYS_I2C_LEGACY - CONFIG_SYS_I2C_MXC_I2C1 - CONFIG_SYS_I2C_MXC_I2C2 - CONFIG_SYS_I2C_MXC_I2C3 - CONFIG_SYS_LOAD_ADDR - CONFIG_MXC_GPIO
v3: - enable EFI capsule support - add update FIT image creation to binman config - change env offset to fit into eMMC boot partition
v2: - add support for 2/4GB variant - enable config options - CONFIG_CMD_GPT - CONFIG_DM_ETH_PHY - CONFIG_EFI_SET_TIME - add pxefile_addr_r env variable
arch/arm/dts/Makefile | 3 +- .../dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi | 12 + arch/arm/dts/imx8mq-kontron-pitx-imx8m.dts | 612 ++++++ arch/arm/mach-imx/imx8m/Kconfig | 7 + board/kontron/pitx_imx8m/Kconfig | 15 + board/kontron/pitx_imx8m/MAINTAINERS | 7 + board/kontron/pitx_imx8m/Makefile | 8 + board/kontron/pitx_imx8m/lpddr4_timing_2gb.c | 1853 +++++++++++++++++ board/kontron/pitx_imx8m/lpddr4_timing_4gb.c | 1853 +++++++++++++++++ board/kontron/pitx_imx8m/pitx_imx8m.c | 163 ++ board/kontron/pitx_imx8m/spl.c | 327 +++ configs/kontron_pitx_imx8m_defconfig | 85 + doc/board/kontron/index.rst | 1 + doc/board/kontron/pitx-imx8m.rst | 67 + include/configs/kontron_pitx_imx8m.h | 111 + 15 files changed, 5123 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mq-kontron-pitx-imx8m.dts create mode 100644 board/kontron/pitx_imx8m/Kconfig create mode 100644 board/kontron/pitx_imx8m/MAINTAINERS create mode 100644 board/kontron/pitx_imx8m/Makefile create mode 100644 board/kontron/pitx_imx8m/lpddr4_timing_2gb.c create mode 100644 board/kontron/pitx_imx8m/lpddr4_timing_4gb.c create mode 100644 board/kontron/pitx_imx8m/pitx_imx8m.c create mode 100644 board/kontron/pitx_imx8m/spl.c create mode 100644 configs/kontron_pitx_imx8m_defconfig create mode 100644 doc/board/kontron/pitx-imx8m.rst create mode 100644 include/configs/kontron_pitx_imx8m.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index aeaec7136f..fd8d490f81 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -912,7 +912,8 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mq-phanbell.dtb \ imx8mp-evk.dtb \ imx8mp-phyboard-pollux-rdk.dtb \ - imx8mq-pico-pi.dtb + imx8mq-pico-pi.dtb \ + imx8mq-kontron-pitx-imx8m.dtb
dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb \ imxrt1020-evk.dtb diff --git a/arch/arm/dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi b/arch/arm/dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi new file mode 100644 index 0000000000..6f9c81462e --- /dev/null +++ b/arch/arm/dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) + +#include "imx8mq-u-boot.dtsi" + +&usdhc1 { + mmc-hs400-1_8v; +}; + +&usdhc2 { + sd-uhs-sdr104; + sd-uhs-ddr50; +}; diff --git a/arch/arm/dts/imx8mq-kontron-pitx-imx8m.dts b/arch/arm/dts/imx8mq-kontron-pitx-imx8m.dts new file mode 100644 index 0000000000..e8fbf0ec6d --- /dev/null +++ b/arch/arm/dts/imx8mq-kontron-pitx-imx8m.dts @@ -0,0 +1,612 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree File for the Kontron pitx-imx8m board. + * + * Copyright (C) 2021 Heiko Thiery heiko.thiery@gmail.com + */ + +/dts-v1/; + +#include "imx8mq.dtsi" +#include <dt-bindings/net/ti-dp83867.h> + +/ { + model = "Kontron pITX-imx8m"; + compatible = "kontron,pitx-imx8m", "fsl,imx8mq"; + + aliases { + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + mmc0 = &usdhc1; + mmc1 = &usdhc2; + serial0 = &uart1; + serial1 = &uart2; + serial2 = &uart3; + spi0 = &qspi0; + spi1 = &ecspi2; + }; + + chosen { + stdout-path = "serial2:115200n8"; + }; + + pcie0_refclk: pcie0-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <100000000>; + }; + + pcie1_refclk: pcie1-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <100000000>; + }; + + reg_usdhc2_vmmc: regulator-usdhc2-vmmc { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usdhc2>; + regulator-name = "V_3V3_SD"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; +}; + +&ecspi2 { + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi2 &pinctrl_ecspi2_cs>; + cs-gpios = <&gpio5 13 GPIO_ACTIVE_LOW>; + status = "okay"; + + tpm@0 { + compatible = "infineon,slb9670"; + reg = <0>; + spi-max-frequency = <43000000>; + }; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>; + ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_75_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + reset-gpios = <&gpio1 11 GPIO_ACTIVE_LOW>; + reset-assert-us = <10>; + reset-deassert-us = <280>; + }; + }; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + pmic@8 { + compatible = "fsl,pfuze100"; + fsl,pfuze-support-disable-sw; + reg = <0x8>; + + regulators { + sw1a_reg: sw1ab { + regulator-name = "V_0V9_GPU"; + regulator-min-microvolt = <825000>; + regulator-max-microvolt = <1100000>; + }; + + sw1c_reg: sw1c { + regulator-name = "V_0V9_VPU"; + regulator-min-microvolt = <825000>; + regulator-max-microvolt = <1100000>; + }; + + sw2_reg: sw2 { + regulator-name = "V_1V1_NVCC_DRAM"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + }; + + sw3a_reg: sw3ab { + regulator-name = "V_1V0_DRAM"; + regulator-min-microvolt = <825000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + }; + + sw4_reg: sw4 { + regulator-name = "V_1V8_S0"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + swbst_reg: swbst { + regulator-name = "NC"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + }; + + snvs_reg: vsnvs { + regulator-name = "V_0V9_SNVS"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-name = "V_0V55_VREF_DDR"; + regulator-always-on; + }; + + vgen1_reg: vgen1 { + regulator-name = "V_1V5_CSI"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen2_reg: vgen2 { + regulator-name = "V_0V9_PHY"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <975000>; + regulator-always-on; + }; + + vgen3_reg: vgen3 { + regulator-name = "V_1V8_PHY"; + regulator-min-microvolt = <1675000>; + regulator-max-microvolt = <1975000>; + regulator-always-on; + }; + + vgen4_reg: vgen4 { + regulator-name = "V_1V8_VDDA"; + regulator-min-microvolt = <1625000>; + regulator-max-microvolt = <1875000>; + regulator-always-on; + }; + + vgen5_reg: vgen5 { + regulator-name = "V_3V3_PHY"; + regulator-min-microvolt = <3075000>; + regulator-max-microvolt = <3625000>; + regulator-always-on; + }; + + vgen6_reg: vgen6 { + regulator-name = "V_2V8_CAM"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; + + fan-controller@1b { + compatible = "maxim,max6650"; + reg = <0x1b>; + maxim,fan-microvolt = <5000000>; + }; + + rtc@32 { + compatible = "microcrystal,rv8803"; + reg = <0x32>; + }; + + sensor@4b { + compatible = "national,lm75b"; + reg = <0x4b>; + }; + + eeprom@51 { + compatible = "atmel,24c32"; + reg = <0x51>; + pagesize = <32>; + }; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&i2c3 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; +}; + +/* M.2 B-key slot */ +&pcie0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcie0>; + reset-gpio = <&gpio1 9 GPIO_ACTIVE_LOW>; + clocks = <&clk IMX8MQ_CLK_PCIE1_ROOT>, + <&clk IMX8MQ_CLK_PCIE1_AUX>, + <&clk IMX8MQ_CLK_PCIE1_PHY>, + <&pcie0_refclk>; + clock-names = "pcie", "pcie_aux", "pcie_phy", "pcie_bus"; + status = "okay"; +}; + +/* Intel Ethernet Controller I210/I211 */ +&pcie1 { + clocks = <&clk IMX8MQ_CLK_PCIE2_ROOT>, + <&clk IMX8MQ_CLK_PCIE2_AUX>, + <&clk IMX8MQ_CLK_PCIE2_PHY>, + <&pcie1_refclk>; + clock-names = "pcie", "pcie_aux", "pcie_phy", "pcie_bus"; + fsl,max-link-speed = <1>; + status = "okay"; +}; + +&pgc_gpu { + power-supply = <&sw1a_reg>; +}; + +&pgc_vpu { + power-supply = <&sw1c_reg>; +}; + +&qspi0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_qspi>; + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <4>; + m25p,fast-read; + spi-max-frequency = <50000000>; + }; +}; + +&snvs_pwrkey { + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + assigned-clocks = <&clk IMX8MQ_CLK_UART1>; + assigned-clock-parents = <&clk IMX8MQ_SYS1_PLL_80M>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + assigned-clocks = <&clk IMX8MQ_CLK_UART2>; + assigned-clock-parents = <&clk IMX8MQ_SYS1_PLL_80M>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + fsl,uart-has-rtscts; + assigned-clocks = <&clk IMX8MQ_CLK_UART3>; + assigned-clock-parents = <&clk IMX8MQ_SYS1_PLL_80M>; + status = "okay"; +}; + +&usb3_phy0 { + status = "okay"; +}; + +&usb3_phy1 { + status = "okay"; +}; + +&usb_dwc3_0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0>; + dr_mode = "otg"; + hnp-disable; + srp-disable; + adp-disable; + maximum-speed = "high-speed"; + status = "okay"; +}; + +&usb_dwc3_1 { + dr_mode = "host"; + status = "okay"; +}; + +&usdhc1 { + assigned-clocks = <&clk IMX8MQ_CLK_USDHC1>; + assigned-clock-rates = <400000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + vqmmc-supply = <&sw4_reg>; + bus-width = <8>; + non-removable; + no-sd; + no-sdio; + status = "okay"; +}; + +&usdhc2 { + assigned-clocks = <&clk IMX8MQ_CLK_USDHC2>; + assigned-clock-rates = <200000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + bus-width = <4>; + cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio2 20 GPIO_ACTIVE_HIGH>; + vmmc-supply = <®_usdhc2_vmmc>; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + pinctrl_hog: hoggrp { + fsl,pins = < + MX8MQ_IOMUXC_NAND_CE1_B_GPIO3_IO2 0x19 /* TPM Reset */ + MX8MQ_IOMUXC_NAND_CE3_B_GPIO3_IO4 0x19 /* USB2 Hub Reset */ + >; + }; + + pinctrl_gpio: gpiogrp { + fsl,pins = < + MX8MQ_IOMUXC_NAND_CLE_GPIO3_IO5 0x19 /* GPIO0 */ + MX8MQ_IOMUXC_NAND_RE_B_GPIO3_IO15 0x19 /* GPIO1 */ + MX8MQ_IOMUXC_NAND_WE_B_GPIO3_IO17 0x19 /* GPIO2 */ + MX8MQ_IOMUXC_NAND_WP_B_GPIO3_IO18 0x19 /* GPIO3 */ + MX8MQ_IOMUXC_NAND_READY_B_GPIO3_IO16 0x19 /* GPIO4 */ + MX8MQ_IOMUXC_NAND_DATA04_GPIO3_IO10 0x19 /* GPIO5 */ + MX8MQ_IOMUXC_NAND_DATA05_GPIO3_IO11 0x19 /* GPIO6 */ + MX8MQ_IOMUXC_NAND_DATA06_GPIO3_IO12 0x19 /* GPIO7 */ + >; + }; + + pinctrl_pcie0: pcie0grp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x16 /* PCIE_PERST */ + MX8MQ_IOMUXC_UART4_TXD_GPIO5_IO29 0x16 /* W_DISABLE */ + >; + }; + + pinctrl_reg_usdhc2: regusdhc2gpiogrp { + fsl,pins = < + MX8MQ_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 + >; + }; + + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MQ_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MQ_IOMUXC_ENET_MDIO_ENET1_MDIO 0x23 + MX8MQ_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MQ_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MQ_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MQ_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MQ_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MQ_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MQ_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MQ_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MQ_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MQ_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MQ_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MQ_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MQ_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x16 + MX8MQ_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x16 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C1_SCL_I2C1_SCL 0x4000007f + MX8MQ_IOMUXC_I2C1_SDA_I2C1_SDA 0x4000007f + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C2_SCL_I2C2_SCL 0x4000007f + MX8MQ_IOMUXC_I2C2_SDA_I2C2_SDA 0x4000007f + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C3_SCL_I2C3_SCL 0x4000007f + MX8MQ_IOMUXC_I2C3_SDA_I2C3_SDA 0x4000007f + >; + }; + + pinctrl_qspi: qspigrp { + fsl,pins = < + MX8MQ_IOMUXC_NAND_ALE_QSPI_A_SCLK 0x82 + MX8MQ_IOMUXC_NAND_CE0_B_QSPI_A_SS0_B 0x82 + MX8MQ_IOMUXC_NAND_DATA00_QSPI_A_DATA0 0x82 + MX8MQ_IOMUXC_NAND_DATA01_QSPI_A_DATA1 0x82 + MX8MQ_IOMUXC_NAND_DATA02_QSPI_A_DATA2 0x82 + MX8MQ_IOMUXC_NAND_DATA03_QSPI_A_DATA3 0x82 + >; + }; + + pinctrl_ecspi2: ecspi2grp { + fsl,pins = < + MX8MQ_IOMUXC_ECSPI2_MOSI_ECSPI2_MOSI 0x19 + MX8MQ_IOMUXC_ECSPI2_MISO_ECSPI2_MISO 0x19 + MX8MQ_IOMUXC_ECSPI2_SCLK_ECSPI2_SCLK 0x19 + >; + }; + + pinctrl_ecspi2_cs: ecspi2csgrp { + fsl,pins = < + MX8MQ_IOMUXC_ECSPI2_SS0_GPIO5_IO13 0x19 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX8MQ_IOMUXC_UART1_TXD_UART1_DCE_TX 0x49 + MX8MQ_IOMUXC_UART1_RXD_UART1_DCE_RX 0x49 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MQ_IOMUXC_UART2_TXD_UART2_DCE_TX 0x49 + MX8MQ_IOMUXC_UART2_RXD_UART2_DCE_RX 0x49 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX8MQ_IOMUXC_UART3_TXD_UART3_DCE_TX 0x49 + MX8MQ_IOMUXC_UART3_RXD_UART3_DCE_RX 0x49 + MX8MQ_IOMUXC_ECSPI1_SS0_UART3_DCE_RTS_B 0x49 + MX8MQ_IOMUXC_ECSPI1_MISO_UART3_DCE_CTS_B 0x49 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x83 + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xc3 + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xc3 + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xc3 + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xc3 + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xc3 + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xc3 + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xc3 + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xc3 + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xc3 + MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x83 + MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1-100grp { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x8d + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xcd + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xcd + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xcd + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xcd + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xcd + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xcd + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xcd + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xcd + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xcd + MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x8d + MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1-200grp { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x9f + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xdf + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xdf + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xdf + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xdf + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xdf + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xdf + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xdf + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xdf + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xdf + MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x9f + MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2gpiogrp { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CD_B_GPIO2_IO12 0x41 + MX8MQ_IOMUXC_SD2_WP_GPIO2_IO20 0x19 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x83 + MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xc3 + MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xc3 + MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xc3 + MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xc3 + MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xc3 + MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2-100grp { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x8d + MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xcd + MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xcd + MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xcd + MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xcd + MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xcd + MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2-200grp { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x9f + MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xdf + MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xdf + MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xdf + MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xdf + MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xdf + MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usb0: usb0grp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO12_USB1_OTG_PWR 0x19 + MX8MQ_IOMUXC_GPIO1_IO13_USB1_OTG_OC 0x19 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 + >; + }; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index d6a869068a..217c939b3c 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -112,6 +112,12 @@ config TARGET_PICO_IMX8MQ select IMX8MQ select IMX8M_LPDDR4
+config TARGET_KONTRON_PITX_IMX8M + bool "Support Kontron pITX-imx8m" + select BINMAN + select IMX8MQ + select IMX8M_LPDDR4 + config TARGET_VERDIN_IMX8MM bool "Support Toradex Verdin iMX8M Mini module" select BINMAN @@ -172,6 +178,7 @@ source "board/freescale/imx8mn_evk/Kconfig" source "board/freescale/imx8mp_evk/Kconfig" source "board/gateworks/venice/Kconfig" source "board/google/imx8mq_phanbell/Kconfig" +source "board/kontron/pitx_imx8m/Kconfig" source "board/kontron/sl-mx8mm/Kconfig" source "board/phytec/phycore_imx8mm/Kconfig" source "board/phytec/phycore_imx8mp/Kconfig" diff --git a/board/kontron/pitx_imx8m/Kconfig b/board/kontron/pitx_imx8m/Kconfig new file mode 100644 index 0000000000..ca1cec761a --- /dev/null +++ b/board/kontron/pitx_imx8m/Kconfig @@ -0,0 +1,15 @@ +if TARGET_KONTRON_PITX_IMX8M + +config SYS_BOARD + default "pitx_imx8m" + +config SYS_VENDOR + default "kontron" + +config SYS_CONFIG_NAME + default "kontron_pitx_imx8m" + +config IMX_CONFIG + default "arch/arm/mach-imx/imx8m/imximage.cfg" + +endif diff --git a/board/kontron/pitx_imx8m/MAINTAINERS b/board/kontron/pitx_imx8m/MAINTAINERS new file mode 100644 index 0000000000..aad84528e3 --- /dev/null +++ b/board/kontron/pitx_imx8m/MAINTAINERS @@ -0,0 +1,7 @@ +Kontron pITX-imx8m Board +M: Heiko Thiery heiko.thiery@gmail.com +S: Maintained +F: arch/arm/dts/imx8mq-kontron-pitx-imx8m* +F: board/kontron/pitx_imx8m/* +F: include/configs/kontron_pitx_imx8m.h +F: configs/kontron_pitx_imx8m_defconfig diff --git a/board/kontron/pitx_imx8m/Makefile b/board/kontron/pitx_imx8m/Makefile new file mode 100644 index 0000000000..904c480281 --- /dev/null +++ b/board/kontron/pitx_imx8m/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += pitx_imx8m.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_2gb.o lpddr4_timing_4gb.o +endif diff --git a/board/kontron/pitx_imx8m/lpddr4_timing_2gb.c b/board/kontron/pitx_imx8m/lpddr4_timing_2gb.c new file mode 100644 index 0000000000..b4647b9847 --- /dev/null +++ b/board/kontron/pitx_imx8m/lpddr4_timing_2gb.c @@ -0,0 +1,1853 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa1080020 }, + { 0x3d400028, 0x0 }, + { 0x3d400020, 0x202 }, + { 0x3d400024, 0x3e800 }, + { 0x3d400064, 0x1800e0 }, + { 0x3d4000d0, 0xc003061c }, + { 0x3d4000d4, 0x9e0000 }, + { 0x3d4000dc, 0xd4002d }, + { 0x3d4000e0, 0x310008 }, + { 0x3d4000e8, 0x66004a }, + { 0x3d4000ec, 0x16004a }, + { 0x3d400100, 0x1a200624 }, + { 0x3d400104, 0x60636 }, + { 0x3d40010c, 0xc0c000 }, + { 0x3d400110, 0x10040a10 }, + { 0x3d400114, 0x2040c0c }, + { 0x3d400118, 0x1010007 }, + { 0x3d40011c, 0x401 }, + { 0x3d400130, 0x20600 }, + { 0x3d400134, 0xc100002 }, + { 0x3d400138, 0xe6 }, + { 0x3d400144, 0xa00050 }, + { 0x3d400180, 0xc3200018 }, + { 0x3d400184, 0x28061a8 }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x497820a }, + { 0x3d400194, 0x80303 }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001b4, 0x170a }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0x639 }, + { 0x3d400108, 0x70e1617 }, + { 0x3d400200, 0x1f }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d402020, 0x0 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0x3001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004a }, + { 0x3d4020ec, 0x16004a }, + { 0x3d402100, 0xa040005 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0xc0640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d403020, 0x0 }, + { 0x3d403024, 0x1f40 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004a }, + { 0x3d4030ec, 0x16004a }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0xc0190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d400244, 0x0 }, + { 0x3d400250, 0x29001505 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x5900575b }, + { 0x3d400264, 0x90000096 }, + { 0x3d40026c, 0x1000012c }, + { 0x3d400300, 0x16 }, + { 0x3d400304, 0x0 }, + { 0x3d40030c, 0x0 }, + { 0x3d400320, 0x1 }, + { 0x3d40036c, 0x11 }, + { 0x3d400400, 0x111 }, + { 0x3d400404, 0x10f3 }, + { 0x3d400408, 0x72ff }, + { 0x3d400490, 0x1 }, + { 0x3d400494, 0xe00 }, + { 0x3d400498, 0x62ffff }, + { 0x3d40049c, 0xe00 }, + { 0x3d4004a0, 0xffff }, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x2 }, + { 0x100a1, 0x3 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x1 }, + { 0x100a4, 0x5 }, + { 0x100a5, 0x7 }, + { 0x100a6, 0x6 }, + { 0x100a7, 0x4 }, + { 0x110a0, 0x2 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x3 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x6 }, + { 0x110a5, 0x7 }, + { 0x110a6, 0x4 }, + { 0x110a7, 0x5 }, + { 0x120a0, 0x4 }, + { 0x120a1, 0x5 }, + { 0x120a2, 0x7 }, + { 0x120a3, 0x6 }, + { 0x120a4, 0x1 }, + { 0x120a5, 0x3 }, + { 0x120a6, 0x2 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x4 }, + { 0x130a1, 0x5 }, + { 0x130a2, 0x7 }, + { 0x130a3, 0x6 }, + { 0x130a4, 0x2 }, + { 0x130a5, 0x1 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x3 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x120024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x220024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x12049, 0xeba }, + { 0x12149, 0xeba }, + { 0x13049, 0xeba }, + { 0x13149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x112049, 0xeba }, + { 0x112149, 0xeba }, + { 0x113049, 0xeba }, + { 0x113149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x212049, 0xeba }, + { 0x212149, 0xeba }, + { 0x213049, 0xeba }, + { 0x213149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x320 }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0xdc }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0xdc }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0xdc }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x200c7, 0x80 }, + { 0x1200c7, 0x80 }, + { 0x2200c7, 0x80 }, + { 0x200ca, 0x106 }, + { 0x1200ca, 0x106 }, + { 0x2200ca, 0x106 }, + { 0x20110, 0x2 }, + { 0x20111, 0x3 }, + { 0x20112, 0x4 }, + { 0x20113, 0x5 }, + { 0x20114, 0x0 }, + { 0x20115, 0x1 }, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xf }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x630 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x630 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x630 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x630 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x630 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x630 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x630 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x630 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x630 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x630 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x630 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x630 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xa }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x2 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0x10 }, + { 0x900a5, 0x10 }, + { 0x900a6, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x623 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x623 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a7, 0x0 }, + { 0x900a8, 0x790 }, + { 0x900a9, 0x11a }, + { 0x900aa, 0x8 }, + { 0x900ab, 0x7aa }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x10 }, + { 0x900ae, 0x7b2 }, + { 0x900af, 0x2a }, + { 0x900b0, 0x0 }, + { 0x900b1, 0x7c8 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x0 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xc }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x0 }, + { 0x90169, 0x8 }, + { 0x9016a, 0x8 }, + { 0x9016b, 0x448 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0xf }, + { 0x9016e, 0x7c0 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x0 }, + { 0x90171, 0xe8 }, + { 0x90172, 0x109 }, + { 0x90173, 0x47 }, + { 0x90174, 0x630 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0x618 }, + { 0x90178, 0x109 }, + { 0x90179, 0x8 }, + { 0x9017a, 0xe0 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x0 }, + { 0x9017d, 0x7c8 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x8 }, + { 0x90180, 0x8140 }, + { 0x90181, 0x10c }, + { 0x90182, 0x0 }, + { 0x90183, 0x1 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x4 }, + { 0x90187, 0x8 }, + { 0x90188, 0x8 }, + { 0x90189, 0x7c8 }, + { 0x9018a, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2a }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x64 }, + { 0x2000c, 0xc8 }, + { 0x2000d, 0x7d0 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x60 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x120010, 0x5a }, + { 0x120011, 0x3 }, + { 0x220010, 0x5a }, + { 0x220011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x2003a, 0x2 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing_2gb = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 400, 100, }, +}; + diff --git a/board/kontron/pitx_imx8m/lpddr4_timing_4gb.c b/board/kontron/pitx_imx8m/lpddr4_timing_4gb.c new file mode 100644 index 0000000000..fd7173bff1 --- /dev/null +++ b/board/kontron/pitx_imx8m/lpddr4_timing_4gb.c @@ -0,0 +1,1853 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa3080020 }, + { 0x3d400028, 0x0 }, + { 0x3d400020, 0x202 }, + { 0x3d400024, 0x3e800 }, + { 0x3d400064, 0x1800e0 }, + { 0x3d4000d0, 0xc003061c }, + { 0x3d4000d4, 0x9e0000 }, + { 0x3d4000dc, 0xd4002d }, + { 0x3d4000e0, 0x310008 }, + { 0x3d4000e8, 0x66004a }, + { 0x3d4000ec, 0x16004a }, + { 0x3d400100, 0x1a200624 }, + { 0x3d400104, 0x60636 }, + { 0x3d40010c, 0xc0c000 }, + { 0x3d400110, 0x10040a10 }, + { 0x3d400114, 0x2040c0c }, + { 0x3d400118, 0x1010007 }, + { 0x3d40011c, 0x401 }, + { 0x3d400130, 0x20600 }, + { 0x3d400134, 0xc100002 }, + { 0x3d400138, 0xe6 }, + { 0x3d400144, 0xa00050 }, + { 0x3d400180, 0xc3200018 }, + { 0x3d400184, 0x28061a8 }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x497820a }, + { 0x3d400194, 0x80303 }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001b4, 0x170a }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0x639 }, + { 0x3d400108, 0x70e1617 }, + { 0x3d400200, 0x17 }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d402020, 0x0 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0x3001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004a }, + { 0x3d4020ec, 0x16004a }, + { 0x3d402100, 0xa040005 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0xc0640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d403020, 0x0 }, + { 0x3d403024, 0x1f40 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004a }, + { 0x3d4030ec, 0x16004a }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0xc0190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d400244, 0x0 }, + { 0x3d400250, 0x29001505 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x5900575b }, + { 0x3d400264, 0x90000096 }, + { 0x3d40026c, 0x1000012c }, + { 0x3d400300, 0x16 }, + { 0x3d400304, 0x0 }, + { 0x3d40030c, 0x0 }, + { 0x3d400320, 0x1 }, + { 0x3d40036c, 0x11 }, + { 0x3d400400, 0x111 }, + { 0x3d400404, 0x10f3 }, + { 0x3d400408, 0x72ff }, + { 0x3d400490, 0x1 }, + { 0x3d400494, 0xe00 }, + { 0x3d400498, 0x62ffff }, + { 0x3d40049c, 0xe00 }, + { 0x3d4004a0, 0xffff }, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x2 }, + { 0x100a1, 0x3 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x1 }, + { 0x100a4, 0x5 }, + { 0x100a5, 0x7 }, + { 0x100a6, 0x6 }, + { 0x100a7, 0x4 }, + { 0x110a0, 0x2 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x3 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x6 }, + { 0x110a5, 0x7 }, + { 0x110a6, 0x4 }, + { 0x110a7, 0x5 }, + { 0x120a0, 0x4 }, + { 0x120a1, 0x5 }, + { 0x120a2, 0x7 }, + { 0x120a3, 0x6 }, + { 0x120a4, 0x1 }, + { 0x120a5, 0x3 }, + { 0x120a6, 0x2 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x4 }, + { 0x130a1, 0x5 }, + { 0x130a2, 0x7 }, + { 0x130a3, 0x6 }, + { 0x130a4, 0x2 }, + { 0x130a5, 0x1 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x3 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x120024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x220024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x12049, 0xeba }, + { 0x12149, 0xeba }, + { 0x13049, 0xeba }, + { 0x13149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x112049, 0xeba }, + { 0x112149, 0xeba }, + { 0x113049, 0xeba }, + { 0x113149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x212049, 0xeba }, + { 0x212149, 0xeba }, + { 0x213049, 0xeba }, + { 0x213149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x320 }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0xdc }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0xdc }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0xdc }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x200c7, 0x80 }, + { 0x1200c7, 0x80 }, + { 0x2200c7, 0x80 }, + { 0x200ca, 0x106 }, + { 0x1200ca, 0x106 }, + { 0x2200ca, 0x106 }, + { 0x20110, 0x2 }, + { 0x20111, 0x3 }, + { 0x20112, 0x4 }, + { 0x20113, 0x5 }, + { 0x20114, 0x0 }, + { 0x20115, 0x1 }, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x310 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x310 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xf }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x630 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x630 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x630 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x630 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x630 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x630 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x630 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x630 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x630 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x630 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x630 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x630 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xa }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x2 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0x10 }, + { 0x900a5, 0x10 }, + { 0x900a6, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x623 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x623 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a7, 0x0 }, + { 0x900a8, 0x790 }, + { 0x900a9, 0x11a }, + { 0x900aa, 0x8 }, + { 0x900ab, 0x7aa }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x10 }, + { 0x900ae, 0x7b2 }, + { 0x900af, 0x2a }, + { 0x900b0, 0x0 }, + { 0x900b1, 0x7c8 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x0 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xc }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x0 }, + { 0x90169, 0x8 }, + { 0x9016a, 0x8 }, + { 0x9016b, 0x448 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0xf }, + { 0x9016e, 0x7c0 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x0 }, + { 0x90171, 0xe8 }, + { 0x90172, 0x109 }, + { 0x90173, 0x47 }, + { 0x90174, 0x630 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0x618 }, + { 0x90178, 0x109 }, + { 0x90179, 0x8 }, + { 0x9017a, 0xe0 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x0 }, + { 0x9017d, 0x7c8 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x8 }, + { 0x90180, 0x8140 }, + { 0x90181, 0x10c }, + { 0x90182, 0x0 }, + { 0x90183, 0x1 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x4 }, + { 0x90187, 0x8 }, + { 0x90188, 0x8 }, + { 0x90189, 0x7c8 }, + { 0x9018a, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2a }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x64 }, + { 0x2000c, 0xc8 }, + { 0x2000d, 0x7d0 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x60 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x120010, 0x5a }, + { 0x120011, 0x3 }, + { 0x220010, 0x5a }, + { 0x220011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x2003a, 0x2 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing_4gb = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 400, 100, }, +}; + diff --git a/board/kontron/pitx_imx8m/pitx_imx8m.c b/board/kontron/pitx_imx8m/pitx_imx8m.c new file mode 100644 index 0000000000..8536efcd7b --- /dev/null +++ b/board/kontron/pitx_imx8m/pitx_imx8m.c @@ -0,0 +1,163 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <init.h> +#include <mmc.h> +#include <miiphy.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm-generic/gpio.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/iomux-v3.h> +#include <linux/delay.h> + + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) + +static iomux_v3_cfg_t const wdog_pads[] = { + IMX8MQ_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; + +static iomux_v3_cfg_t const uart_pads[] = { + IMX8MQ_PAD_UART3_RXD__UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_UART3_TXD__UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_ECSPI1_SS0__UART3_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_ECSPI1_MISO__UART3_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + set_wdog_reset(wdog); + + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + + return 0; +} + +int board_phys_sdram_size(phys_size_t *memsize) +{ + /* + * Get real memory size by testing available memory in a + * given range starting at i.MX8M DRAM1 base address 0x40000000. + */ + *memsize = get_ram_size((long *)0x40000000, 0x100000000ULL); + debug("Memsize: %d MiB\n", (int)(*memsize >> 20)); + + return 0; +} + + +#ifdef CONFIG_FEC_MXC +#define FEC_RST_PAD IMX_GPIO_NR(1, 11) +static iomux_v3_cfg_t const fec1_rst_pads[] = { + IMX8MQ_PAD_GPIO1_IO11__GPIO1_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_fec(void) +{ + imx_iomux_v3_setup_multiple_pads(fec1_rst_pads, + ARRAY_SIZE(fec1_rst_pads)); +} + +static int setup_fec(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + setup_iomux_fec(); + + /* Use 125M anatop REF_CLK1 for ENET1, not from external */ + clrsetbits_le32(&gpr->gpr[1], BIT(13) | BIT(17), 0); + return set_clk_enet(ENET_125MHZ); +} + +int board_phy_config(struct phy_device *phydev) +{ + unsigned int val; + + /* enable rgmii rxc skew and phy mode select to RGMII copper */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + /* + * Set LED configuration register 1: + * LED2_SEL: 0b1011 (link established, blink on activity) + */ + val = phy_read(phydev, MDIO_DEVAD_NONE, 0x18); + val &= 0xf0ff; + phy_write(phydev, MDIO_DEVAD_NONE, 0x18, val | (0xb << 8)); + + if (phydev->drv->config) + phydev->drv->config(phydev); + return 0; +} +#endif + +int board_init(void) +{ +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + +#if defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_DWC3) + init_usb_clk(); +#endif + + return 0; +} + +#ifdef CONFIG_MISC_INIT_R +#define TPM_RESET IMX_GPIO_NR(3, 2) +#define USBHUB_RESET IMX_GPIO_NR(3, 4) + +static void reset_device_by_gpio(const char *label, int pin, int delay_ms) +{ + gpio_request(pin, label); + gpio_direction_output(pin, 0); + mdelay(delay_ms); + gpio_direction_output(pin, 1); +} + +int misc_init_r(void) +{ + /* + * reset TPM chip (Infineon SLB9670) as required by datasheet + * (60ms minimum Reset Inactive Time, 70ms implemented) + */ + reset_device_by_gpio("tpm_reset", TPM_RESET, 70); + + /* + * reset USB hub as required by datasheet + * (3ms minimum reset duration, 10ms implemented) + */ + reset_device_by_gpio("usbhub_reset", USBHUB_RESET, 10); + + return 0; +} +#endif + +int board_mmc_get_env_dev(int devno) +{ + return devno; +} + +uint mmc_get_env_part(struct mmc *mmc) +{ + /* part 1 for eMMC, part 1 for SD card */ + return (mmc_get_env_dev() == 0) ? 1 : 0; +} + +int board_late_init(void) +{ + return 0; +} diff --git a/board/kontron/pitx_imx8m/spl.c b/board/kontron/pitx_imx8m/spl.c new file mode 100644 index 0000000000..ddf20d5e23 --- /dev/null +++ b/board/kontron/pitx_imx8m/spl.c @@ -0,0 +1,327 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <errno.h> +#include <fsl_esdhc_imx.h> +#include <hang.h> +#include <init.h> +#include <log.h> +#include <spl.h> +#include <asm/arch/ddr.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clock.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <linux/delay.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> + +extern struct dram_timing_info dram_timing_2gb; +extern struct dram_timing_info dram_timing_4gb; + +DECLARE_GLOBAL_DATA_PTR; + +int pfuze_mode_init(struct pmic *p, u32 mode) +{ + unsigned char offset, i, switch_num; + u32 id; + int ret; + + pmic_reg_read(p, PFUZE100_DEVICEID, &id); + id = id & 0xf; + + if (id == 0) { + switch_num = 6; + offset = PFUZE100_SW1CMODE; + } else if (id == 1) { + switch_num = 4; + offset = PFUZE100_SW2MODE; + } else { + printf("Not supported, id=%d\n", id); + return -EINVAL; + } + + ret = pmic_reg_write(p, PFUZE100_SW1ABMODE, mode); + if (ret < 0) { + printf("Set SW1AB mode error!\n"); + return ret; + } + + for (i = 0; i < switch_num - 1; i++) { + ret = pmic_reg_write(p, offset + i * SWITCH_SIZE, mode); + if (ret < 0) { + printf("Set switch 0x%x mode error!\n", + offset + i * SWITCH_SIZE); + return ret; + } + } + + return ret; +} + +/* + * BRD_REV1 BRD_REV0 + * 0 0 n/a + * 0 1 n/a + * 1 0 2GB LPDDR4 + * 1 1 4GB LPDDR4 + */ + +#define BRD_REV0 IMX_GPIO_NR(5, 0) +#define BRD_REV1 IMX_GPIO_NR(5, 1) + +static iomux_v3_cfg_t const brdrev_pads[] = { + IMX8MQ_PAD_SAI3_TXC__GPIO5_IO0 | MUX_PAD_CTRL(PAD_CTL_PUE), + IMX8MQ_PAD_SAI3_TXD__GPIO5_IO1 | MUX_PAD_CTRL(PAD_CTL_PUE), + IMX8MQ_PAD_SAI3_MCLK__GPIO5_IO2 | MUX_PAD_CTRL(PAD_CTL_PUE), +}; + +static void spl_dram_init(void) +{ + struct dram_timing_info *dram_timing; + int variant = 0, size; + + imx_iomux_v3_setup_multiple_pads(brdrev_pads, ARRAY_SIZE(brdrev_pads)); + + gpio_request(BRD_REV0, "BRD_REV0"); + gpio_direction_input(BRD_REV0); + gpio_request(BRD_REV1, "BRD_REV1"); + gpio_direction_input(BRD_REV1); + + variant |= !!gpio_get_value(BRD_REV0) << 0; + variant |= !!gpio_get_value(BRD_REV1) << 1; + + switch(variant) { + case 2: + dram_timing = &dram_timing_2gb; + size = 2; + break; + case 3: + dram_timing = &dram_timing_4gb; + size = 4; + break; + default: + printf("Unknown DDR type (%d)\n", variant); + return; + }; + + /* ddr init */ + ddr_init(dram_timing); +} + +#define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +static struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = IMX8MQ_PAD_I2C1_SCL__I2C1_SCL | PC, + .gpio_mode = IMX8MQ_PAD_I2C1_SCL__GPIO5_IO14 | PC, + .gp = IMX_GPIO_NR(5, 14), + }, + .sda = { + .i2c_mode = IMX8MQ_PAD_I2C1_SDA__I2C1_SDA | PC, + .gpio_mode = IMX8MQ_PAD_I2C1_SDA__GPIO5_IO15 | PC, + .gp = IMX_GPIO_NR(5, 15), + }, +}; + +#define USDHC2_CD_GPIO IMX_GPIO_NR(2, 12) +#define USDHC1_PWR_GPIO IMX_GPIO_NR(2, 10) +#define USDHC2_PWR_GPIO IMX_GPIO_NR(2, 19) + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = 1; + break; + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + return ret; + } + + return 1; +} + +#define USDHC_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | \ + PAD_CTL_FSEL2) +#define USDHC_GPIO_PAD_CTRL (PAD_CTL_PUE | PAD_CTL_DSE1) + +static iomux_v3_cfg_t const usdhc1_pads[] = { + IMX8MQ_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA4__USDHC1_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA5__USDHC1_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA6__USDHC1_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA7__USDHC1_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_RESET_B__GPIO2_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc2_pads[] = { + IMX8MQ_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_DATA0__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_DATA1__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_DATA2__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0x16 */ + IMX8MQ_PAD_SD2_DATA3__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_CD_B__GPIO2_IO12 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL), + IMX8MQ_PAD_SD2_RESET_B__GPIO2_IO19 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL), +}; + +static struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC1_BASE_ADDR, 0, 8}, + {USDHC2_BASE_ADDR, 0, 4}, +}; + +int board_mmc_init(struct bd_info *bis) +{ + int i, ret; + /* + * According to the board_mmc_init() the following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc1 USDHC2 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + init_clk_usdhc(0); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(USDHC1_CLK_ROOT); + imx_iomux_v3_setup_multiple_pads(usdhc1_pads, + ARRAY_SIZE(usdhc1_pads)); + gpio_request(USDHC1_PWR_GPIO, "usdhc1_reset"); + gpio_direction_output(USDHC1_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC1_PWR_GPIO, 1); + break; + case 1: + init_clk_usdhc(1); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(USDHC2_CLK_ROOT); + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, + ARRAY_SIZE(usdhc2_pads)); + gpio_request(USDHC2_PWR_GPIO, "usdhc2_reset"); + gpio_direction_output(USDHC2_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC2_PWR_GPIO, 1); + break; + default: + printf("Warning: you configured more USDHC controllers " + "(%d) than supported by the board\n", i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) + return ret; + } + + return 0; +} + +#if CONFIG_IS_ENABLED(POWER_LEGACY) +#define I2C_PMIC 0 +int power_init_board(void) +{ + struct pmic *p; + int ret; + unsigned int reg; + + ret = power_pfuze100_init(I2C_PMIC); + if (ret) + return -ENODEV; + + p = pmic_get("PFUZE100"); + ret = pmic_probe(p); + if (ret) + return -ENODEV; + + pmic_reg_read(p, PFUZE100_SW3AVOL, ®); + if ((reg & 0x3f) != 0x18) { + reg &= ~0x3f; + reg |= 0x18; + pmic_reg_write(p, PFUZE100_SW3AVOL, reg); + } + + ret = pfuze_mode_init(p, APS_PFM); + if (ret < 0) + return ret; + + /* set SW3A standby mode to off */ + pmic_reg_read(p, PFUZE100_SW3AMODE, ®); + reg &= ~0xf; + reg |= APS_OFF; + pmic_reg_write(p, PFUZE100_SW3AMODE, reg); + + return 0; +} +#endif + +void spl_board_init(void) +{ + u32 boot_device = spl_boot_device(); + + if (boot_device == BOOT_DEVICE_MMC1) { + puts("Booting from eMMC"); + } else if (boot_device == BOOT_DEVICE_MMC2) { + puts("Booting from SD card"); + } else { + puts("Unknown boot source"); + } +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +void board_init_f(ulong dummy) +{ + int ret; + + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); + + arch_cpu_init(); + + init_uart_clk(2); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_init(); + if (ret) { + debug("spl_init() failed: %d\n", ret); + hang(); + } + + enable_tzc380(); + + setup_i2c(0, 100000, 0x7f, &i2c_pad_info1); + + power_init_board(); + + spl_dram_init(); + + board_init_r(NULL, 0); +} diff --git a/configs/kontron_pitx_imx8m_defconfig b/configs/kontron_pitx_imx8m_defconfig new file mode 100644 index 0000000000..aef86105c5 --- /dev/null +++ b/configs/kontron_pitx_imx8m_defconfig @@ -0,0 +1,85 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x300000 +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_SYS_MALLOC_LEN=0x600000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mq-kontron-pitx-imx8m" +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_KONTRON_PITX_IMX8M=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_FIT=y +CONFIG_SPL_FIT_PRINT=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_MISC_INIT_R=y +CONFIG_SPL_BOARD_INIT=y +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_NVEDIT_EFI=y +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_MDIO is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_HASH=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SAVED_DRAM_TIMING_BASE=0x40000000 +CONFIG_DFU_MMC=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_TI=y +CONFIG_DM_ETH=y +CONFIG_PHY=y +CONFIG_PHY_IMX8MQ_USB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_SPL_POWER_LEGACY=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_POWER_I2C=y +CONFIG_DM_RESET=y +CONFIG_DM_RTC=y +CONFIG_RTC_RV8803=y +CONFIG_MXC_UART=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_EFI_SET_TIME=y +CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_IGNORE_OSINDICATIONS=y +CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y diff --git a/doc/board/kontron/index.rst b/doc/board/kontron/index.rst index 7dfe3d9bc0..cb1906e626 100644 --- a/doc/board/kontron/index.rst +++ b/doc/board/kontron/index.rst @@ -6,6 +6,7 @@ Kontron .. toctree:: :maxdepth: 2
+ pitx-imx8m sl28 sl-mx6ul sl-mx8mm diff --git a/doc/board/kontron/pitx-imx8m.rst b/doc/board/kontron/pitx-imx8m.rst new file mode 100644 index 0000000000..1f64cbd9b2 --- /dev/null +++ b/doc/board/kontron/pitx-imx8m.rst @@ -0,0 +1,67 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Kontron pitx-imx8m +================== + +The Kontron pitx-imx8m is an embedded board with an i.MX8MQ in the pITX +form factor. + +The board has two Ethernet ports, USB, HDMI/LVDS, m.2 slot, SD card, CAN, +RS232 and much more. + +Quick Start +----------- + +- Get and build the ARM Trusted firmware binary +- Get DDR and HDMI firmware +- Build U-Boot +- Install on SD card +- Boot + +Get and build the ARM Trusted firmware binary +^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ + +Note: builddir is U-Boot build directory (source directory for in-tree builds) + +.. code-block:: bash + + $ git clone https://github.com/ARM-software/arm-trusted-firmware.git + $ git checkout v2.5 + $ make PLAT=imx8mq ARCH=aarch64 CROSS_COMPILE=aarch64-linux-gnu- bl31 + $ cp build/imx8mq/release/bl31.bin $(builddir) + +Get DDR and HDMI firmware +^^^^^^^^^^^^^^^^^^^^^^^^^ + +Note: builddir is U-Boot build directory (source directory for in-tree builds) + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.11.bin + $ chmod +x firmware-imx-8.11.bin + $ ./firmware-imx-8.11 + $ cp firmware-imx-8.11/firmware/ddr/synopsys/lpddr4*.bin $(builddir) + $ cp firmware-imx-8.11/firmware/hdmi/cadence/signed_hdmi_imx8m.bin $(builddir) + +Build U-Boot +^^^^^^^^^^^^ + +.. code-block:: bash + + $ make kontron_pitx_imx8m_defconfig + $ make CROSS_COMPILE=aarch64-linux-gnu- + +Install on SD card +^^^^^^^^^^^^^^^^^^ + + +Burn the flash.bin to SD card at an offset of 33 KiB: + +.. code-block:: bash + + $ sudo dd if=flash.bin of=/dev/sd[x] bs=1024 seek=33 + +Boot +^^^^ + +Set the boot source selection to SD card boot and power on the board. diff --git a/include/configs/kontron_pitx_imx8m.h b/include/configs/kontron_pitx_imx8m.h new file mode 100644 index 0000000000..952dbd445c --- /dev/null +++ b/include/configs/kontron_pitx_imx8m.h @@ -0,0 +1,111 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __KONTRON_PITX_IMX8M_H +#define __KONTRON_PITX_IMX8M_H + +#include <linux/sizes.h> +#include <linux/stringify.h> +#include <asm/arch/imx-regs.h> + +#define CONFIG_SYS_BOOTM_LEN (32 * SZ_1M) + +#define CONFIG_SPL_MAX_SIZE (124 * SZ_1K) +#define CONFIG_SYS_MONITOR_LEN (512 * SZ_1K) +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_WATCHDOG +#define CONFIG_SPL_DRIVERS_MISC +#define CONFIG_SPL_POWER +#define CONFIG_SPL_I2C +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_STACK 0x187FF0 +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_GPIO +#define CONFIG_SPL_MMC +#define CONFIG_SPL_BSS_START_ADDR 0x00180000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K +#define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 + +/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ +#define CONFIG_MALLOC_F_ADDR 0x182000 +/* For RAW image gives a error info not panic */ +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#undef CONFIG_DM_MMC + +#define CONFIG_POWER_PFUZE100 +#define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 +#endif + +#define CONFIG_REMAKE_ELF + +/* ENET1 Config */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_MII +#define CONFIG_ETHPRIME "FEC" + +#define CONFIG_FEC_MXC +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 0 +#define FEC_QUIRK_ENET_MAC + +#define CONFIG_PHY_GIGE +#define IMX_FEC_BASE 0x30BE0000 +#define PHY_ANEG_TIMEOUT 20000 + +#endif + +#define ENV_MEM_LAYOUT_SETTINGS \ + "kernel_addr_r=0x40880000\0" \ + "fdt_addr_r=0x43000000\0" \ + "scriptaddr=0x43500000\0" \ + "initrd_addr=0x43800000\0" \ + "pxefile_addr_r=0x43500000\0" \ + "bootm_size=0x10000000\0" \ + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) \ + func(USB, usb, 0) \ + func(DHCP, dhcp, na) \ + func(PXE, pxe, 0) + +#include <config_distro_bootcmd.h> + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "image=Image\0" \ + "console=ttymxc2,115200\0" \ + "boot_fdt=try\0" \ + "fdtfile=freescale/imx8mq-kontron-pitx-imx8m.dtb\0" \ + "dfu_alt_info=mmc 0=flash-bin raw 0x42 0x1000 mmcpart 1\0"\ + ENV_MEM_LAYOUT_SETTINGS \ + BOOTENV + + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x80000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE 0xC0000000 /* 3GB DDR */ + +#define CONFIG_MXC_UART_BASE UART3_BASE_ADDR + +#define CONFIG_IMX_BOOTAUX + +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_OF_SYSTEM_SETUP + +#endif
Heiko Thiery
