[U-Boot] [PATCH 0/4] ls102xa: HYP/non-sec: for ls102xa.
Xiubo Li (4): ARM: HYP/non-sec: add the pen address byte reverting support. ARM: HYP/non-sec: Fix the ARCH Timer frequency setting. ls102xa: HYP/non-sec: support for ls102xa boards ARM: ls102xa: allow all device accessable in non-secure state
arch/arm/cpu/armv7/ls102xa/cpu.c | 15 +++ arch/arm/cpu/armv7/nonsec_virt.S | 7 +- arch/arm/include/asm/arch-ls102xa/config.h | 3 + arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 3 + arch/arm/include/asm/arch-ls102xa/ns_access.h | 117 ++++++++++++++++++++++ board/freescale/common/Makefile | 2 + board/freescale/common/ns_access.c | 32 ++++++ board/freescale/ls1021aqds/ls1021aqds.c | 88 ++++++++++++++++ board/freescale/ls1021atwr/ls1021atwr.c | 87 ++++++++++++++++ include/configs/ls1021aqds.h | 8 ++ include/configs/ls1021atwr.h | 8 ++ include/configs/sun7i.h | 1 + 12 files changed, 369 insertions(+), 2 deletions(-) create mode 100644 arch/arm/include/asm/arch-ls102xa/ns_access.h create mode 100644 board/freescale/common/ns_access.c
For some SoCs, the pen address may has different endianness with the CPUs, so this need the byte revertion for it,
Signed-off-by: Xiubo Li Li.Xiubo@freescale.com --- arch/arm/cpu/armv7/nonsec_virt.S | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/cpu/armv7/nonsec_virt.S b/arch/arm/cpu/armv7/nonsec_virt.S index 745670e..2683dac 100644 --- a/arch/arm/cpu/armv7/nonsec_virt.S +++ b/arch/arm/cpu/armv7/nonsec_virt.S @@ -191,6 +191,9 @@ ENTRY(smp_waitloop) wfi ldr r1, =CONFIG_SMP_PEN_ADDR @ load start address ldr r1, [r1] +#ifdef CONFIG_SOC_BIG_ENDIAN + rev r1, r1 +#endif cmp r0, r1 @ make sure we dont execute this code beq smp_waitloop @ again (due to a spurious wakeup) mov r0, r1
For some SoCs, the CONFIG_SYS_CLK_FREQ maybe won't equal the ARCH Timer's frequency.
Here using the CONFIG_TIMER_CLK_FREQ instead if the ARCH Timer's frequency need to config here.
Signed-off-by: Xiubo Li Li.Xiubo@freescale.com --- arch/arm/cpu/armv7/nonsec_virt.S | 4 ++-- include/configs/sun7i.h | 1 + 2 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/nonsec_virt.S b/arch/arm/cpu/armv7/nonsec_virt.S index 2683dac..8b446bc 100644 --- a/arch/arm/cpu/armv7/nonsec_virt.S +++ b/arch/arm/cpu/armv7/nonsec_virt.S @@ -169,11 +169,11 @@ ENTRY(_nonsec_init) * we do this here instead. * But first check if we have the generic timer. */ -#ifdef CONFIG_SYS_CLK_FREQ +#ifdef CONFIG_TIMER_CLK_FREQ mrc p15, 0, r0, c0, c1, 1 @ read ID_PFR1 and r0, r0, #CPUID_ARM_GENTIMER_MASK @ mask arch timer bits cmp r0, #(1 << CPUID_ARM_GENTIMER_SHIFT) - ldreq r1, =CONFIG_SYS_CLK_FREQ + ldreq r1, =CONFIG_TIMER_CLK_FREQ mcreq p15, 0, r1, c14, c0, 0 @ write CNTFRQ #endif
diff --git a/include/configs/sun7i.h b/include/configs/sun7i.h index a902b84..6e201f2f 100644 --- a/include/configs/sun7i.h +++ b/include/configs/sun7i.h @@ -35,6 +35,7 @@ #define CONFIG_ARMV7_PSCI_NR_CPUS 2 #define CONFIG_ARMV7_SECURE_BASE SUNXI_SRAM_B_BASE #define CONFIG_SYS_CLK_FREQ 24000000 +#define CONFIG_SYS_TIMER_CLK_FREQ CONFIG_SYS_CLK_FREQ
/* * Include common sunxi configuration where most the settings are
Enable hypervisors utilizing the ARMv7 virtualization extension on the LS1021A-QDS/TWR boards with the A7 core tile, we add the required configuration variable. Also we define the board specific smp_set_cpu_boot_addr() function to set the start address for secondary cores in the LS1021A specific manner.
Signed-off-by: Xiubo Li Li.Xiubo@freescale.com --- arch/arm/cpu/armv7/ls102xa/cpu.c | 15 +++++++++++++++ arch/arm/include/asm/arch-ls102xa/config.h | 2 ++ arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 3 +++ include/configs/ls1021aqds.h | 7 +++++++ include/configs/ls1021atwr.h | 7 +++++++ 5 files changed, 34 insertions(+)
diff --git a/arch/arm/cpu/armv7/ls102xa/cpu.c b/arch/arm/cpu/armv7/ls102xa/cpu.c index b7dde45..0034bad 100644 --- a/arch/arm/cpu/armv7/ls102xa/cpu.c +++ b/arch/arm/cpu/armv7/ls102xa/cpu.c @@ -101,3 +101,18 @@ int cpu_eth_init(bd_t *bis)
return 0; } + +#if defined(CONFIG_ARMV7_NONSEC) || defined(CONFIG_ARMV7_VIRT) +/* Setting the address at which secondary cores start from.*/ +void smp_set_core_boot_addr(unsigned long addr, int corenr) +{ + uint32_t base = CONFIG_SYS_FSL_GUTS_ADDR; + uint32_t scratchwr_base = base + CCSR_SCRATCHRW1_OFFSET; + uint32_t brr_base = base + CCSR_BRR_OFFSET; + /* After setting the secondary cores start address, just release + * them to boot. + */ + out_be32(scratchwr_base, addr); + out_be32(brr_base, 0x2); +} +#endif diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index ed78c33..4856388 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -11,6 +11,8 @@
#define OCRAM_BASE_ADDR 0x10000000 #define OCRAM_SIZE 0x00020000 +#define OCRAM_BASE_S_ADDR 0x10010000 +#define OCRAM_S_SIZE 0x00010000
#define CONFIG_SYS_IMMR 0x01000000
diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index 7995fe2..0bac353 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -17,6 +17,9 @@ #define SOC_VER_LS1021 0x11 #define SOC_VER_LS1022 0x12
+#define CCSR_BRR_OFFSET 0xe4 +#define CCSR_SCRATCHRW1_OFFSET 0x200 + #define RCWSR0_SYS_PLL_RAT_SHIFT 25 #define RCWSR0_SYS_PLL_RAT_MASK 0x1f #define RCWSR0_MEM_PLL_RAT_SHIFT 16 diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 657e3b6..b922e58 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -324,6 +324,13 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMDLINE_EDITING #define CONFIG_CMD_IMLS
+#define CONFIG_ARMV7_NONSEC +#define CONFIG_ARMV7_VIRT +#define CONFIG_SOC_BIG_ENDIAN +#define CONFIG_SMP_PEN_ADDR 0x01ee0200 +#define CONFIG_TIMER_CLK_FREQ 12500000 +#define CONFIG_ARMV7_SECURE_BASE OCRAM_BASE_S_ADDR + #define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 128
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 45b2272..8c30831 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -227,6 +227,13 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_CMD_IMLS
The Central Security Unit (CSU) allows secure world software to change the default access control policies of peripherals/bus slaves, determining which bus masters may access them. This allows peripherals to be separated into distinct security domains. Combined with SMMU configuration of the system masters privileges, these features provide protection against indirect unauthorized access to data.
For now we configure all the peripheral access permissions as R/W.
Signed-off-by: Xiubo Li Li.Xiubo@freescale.com --- arch/arm/include/asm/arch-ls102xa/config.h | 1 + arch/arm/include/asm/arch-ls102xa/ns_access.h | 117 ++++++++++++++++++++++++++ board/freescale/common/Makefile | 2 + board/freescale/common/ns_access.c | 32 +++++++ board/freescale/ls1021aqds/ls1021aqds.c | 88 +++++++++++++++++++ board/freescale/ls1021atwr/ls1021atwr.c | 87 +++++++++++++++++++ include/configs/ls1021aqds.h | 1 + include/configs/ls1021atwr.h | 1 + 8 files changed, 329 insertions(+) create mode 100644 arch/arm/include/asm/arch-ls102xa/ns_access.h create mode 100644 board/freescale/common/ns_access.c
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 4856388..0754296 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -18,6 +18,7 @@
#define CONFIG_SYS_FSL_DDR_ADDR (CONFIG_SYS_IMMR + 0x00080000) #define CONFIG_SYS_CCI400_ADDR (CONFIG_SYS_IMMR + 0x00180000) +#define CONFIG_SYS_FSL_CSU_ADDR (CONFIG_SYS_IMMR + 0x00510000) #define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x00530000) #define CONFIG_SYS_FSL_ESDHC_ADDR (CONFIG_SYS_IMMR + 0x00560000) #define CONFIG_SYS_FSL_SCFG_ADDR (CONFIG_SYS_IMMR + 0x00570000) diff --git a/arch/arm/include/asm/arch-ls102xa/ns_access.h b/arch/arm/include/asm/arch-ls102xa/ns_access.h new file mode 100644 index 0000000..37fa93c --- /dev/null +++ b/arch/arm/include/asm/arch-ls102xa/ns_access.h @@ -0,0 +1,117 @@ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __FSL_NS_ACCESS_H_ +#define __FSL_NS_ACCESS_H_ + +enum csu_cslx_access { + CSU_NS_SUP_R = 0x08, + CSU_NS_SUP_W = 0x80, + CSU_NS_SUP_RW = 0x88, + CSU_NS_USER_R = 0x04, + CSU_NS_USER_W = 0x40, + CSU_NS_USER_RW = 0x44, + CSU_S_SUP_R = 0x02, + CSU_S_SUP_W = 0x20, + CSU_S_SUP_RW = 0x22, + CSU_S_USER_R = 0x01, + CSU_S_USER_W = 0x10, + CSU_S_USER_RW = 0x11, + CSU_ALL_RW = 0xff, +}; + +enum csu_cslx_ind { + CSU_CSLX_PCIE2_IO = 0, + CSU_CSLX_PCIE1_IO, + CSU_CSLX_MG2TPR_IP, + CSU_CSLX_IFC_MEM, + CSU_CSLX_OCRAM, + CSU_CSLX_GIC, + CSU_CSLX_PCIE1, + CSU_CSLX_OCRAM2, + CSU_CSLX_QSPI_MEM, + CSU_CSLX_PCIE2, + CSU_CSLX_SATA, + CSU_CSLX_USB3, + CSU_CSLX_SERDES = 32, + CSU_CSLX_QDMA, + CSU_CSLX_LPUART2, + CSU_CSLX_LPUART1, + CSU_CSLX_LPUART4, + CSU_CSLX_LPUART3, + CSU_CSLX_LPUART6, + CSU_CSLX_LPUART5, + CSU_CSLX_DSPI2 = 40, + CSU_CSLX_DSPI1, + CSU_CSLX_QSPI, + CSU_CSLX_ESDHC, + CSU_CSLX_2D_ACE, + CSU_CSLX_IFC, + CSU_CSLX_I2C1, + CSU_CSLX_USB2, + CSU_CSLX_I2C3, + CSU_CSLX_I2C2, + CSU_CSLX_DUART2 = 50, + CSU_CSLX_DUART1, + CSU_CSLX_WDT2, + CSU_CSLX_WDT1, + CSU_CSLX_EDMA, + CSU_CSLX_SYS_CNT, + CSU_CSLX_DMA_MUX2, + CSU_CSLX_DMA_MUX1, + CSU_CSLX_DDR, + CSU_CSLX_QUICC, + CSU_CSLX_DCFG_CCU_RCPM = 60, + CSU_CSLX_SECURE_BOOTROM, + CSU_CSLX_SFP, + CSU_CSLX_TMU, + CSU_CSLX_SECURE_MONITOR, + CSU_CSLX_RESERVED0, + CSU_CSLX_ETSEC1, + CSU_CSLX_SEC5_5, + CSU_CSLX_ETSEC3, + CSU_CSLX_ETSEC2, + CSU_CSLX_GPIO2 = 70, + CSU_CSLX_GPIO1, + CSU_CSLX_GPIO4, + CSU_CSLX_GPIO3, + CSU_CSLX_PLATFORM_CONT, + CSU_CSLX_CSU, + CSU_CSLX_ASRC, + CSU_CSLX_SPDIF, + CSU_CSLX_FLEXCAN2, + CSU_CSLX_FLEXCAN1, + CSU_CSLX_FLEXCAN4 = 80, + CSU_CSLX_FLEXCAN3, + CSU_CSLX_SAI2, + CSU_CSLX_SAI1, + CSU_CSLX_SAI4, + CSU_CSLX_SAI3, + CSU_CSLX_FTM2, + CSU_CSLX_FTM1, + CSU_CSLX_FTM4, + CSU_CSLX_FTM3, + CSU_CSLX_FTM6 = 90, + CSU_CSLX_FTM5, + CSU_CSLX_FTM8, + CSU_CSLX_FTM7, + CSU_CSLX_COP_DCSR, + CSU_CSLX_EPU, + CSU_CSLX_GDI, + CSU_CSLX_DDI, + CSU_CSLX_RESERVED1, + CSU_CSLX_USB3_PHY = 117, + CSU_CSLX_RESERVED2, +}; + +struct csu_ns_dev { + unsigned long ind; + uint32_t val; +}; + +void enable_devices_ns_access(struct csu_ns_dev *ns_dev, uint32_t num); + +#endif diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 32b5a3b..7296bbb 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -60,4 +60,6 @@ obj-$(CONFIG_P3041DS) += p_corenet/ obj-$(CONFIG_P4080DS) += p_corenet/ obj-$(CONFIG_P5020DS) += p_corenet/ obj-$(CONFIG_P5040DS) += p_corenet/ + +obj-$(CONFIG_LS102XA_NS_ACESS) += ns_access.o endif diff --git a/board/freescale/common/ns_access.c b/board/freescale/common/ns_access.c new file mode 100644 index 0000000..62ba380 --- /dev/null +++ b/board/freescale/common/ns_access.c @@ -0,0 +1,32 @@ +/* + * Copyright 2014 Freescale Semiconductor + * + * Xiubo Li Li.Xiubo@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/ns_access.h> + +void enable_devices_ns_access(struct csu_ns_dev *ns_dev, uint32_t num) +{ + u32 *base = (u32 *)CONFIG_SYS_FSL_CSU_ADDR; + u32 *reg; + uint32_t val; + int i; + + for (i = 0; i < num; i++) { + reg = base + ns_dev[i].ind / 2; + val = in_be32(reg); + if (ns_dev[i].ind % 2 == 0) { + val &= 0x0000ffff; + val |= ns_dev[i].val << 16; + } else { + val &= 0xffff0000; + val |= ns_dev[i].val; + } + out_be32(reg, val); + } +} diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 12e83f7..ebadafb 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -8,6 +8,7 @@ #include <i2c.h> #include <asm/io.h> #include <asm/arch/immap_ls102xa.h> +#include <asm/arch/ns_access.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> #include <mmc.h> @@ -213,6 +214,90 @@ int config_serdes_mux(void) return 0; }
+static struct csu_ns_dev ns_dev[] = { + { CSU_CSLX_PCIE2_IO, CSU_ALL_RW }, + { CSU_CSLX_PCIE1_IO, CSU_ALL_RW }, + { CSU_CSLX_MG2TPR_IP, CSU_ALL_RW }, + { CSU_CSLX_IFC_MEM, CSU_ALL_RW }, + { CSU_CSLX_OCRAM, CSU_ALL_RW }, + { CSU_CSLX_GIC, CSU_ALL_RW }, + { CSU_CSLX_PCIE1, CSU_ALL_RW }, + { CSU_CSLX_OCRAM2, CSU_ALL_RW }, + { CSU_CSLX_QSPI_MEM, CSU_ALL_RW }, + { CSU_CSLX_PCIE2, CSU_ALL_RW }, + { CSU_CSLX_SATA, CSU_ALL_RW }, + { CSU_CSLX_USB3, CSU_ALL_RW }, + { CSU_CSLX_SERDES, CSU_ALL_RW }, + { CSU_CSLX_QDMA, CSU_ALL_RW }, + { CSU_CSLX_LPUART2, CSU_ALL_RW }, + { CSU_CSLX_LPUART1, CSU_ALL_RW }, + { CSU_CSLX_LPUART4, CSU_ALL_RW }, + { CSU_CSLX_LPUART3, CSU_ALL_RW }, + { CSU_CSLX_LPUART6, CSU_ALL_RW }, + { CSU_CSLX_LPUART5, CSU_ALL_RW }, + { CSU_CSLX_DSPI2, CSU_ALL_RW }, + { CSU_CSLX_DSPI1, CSU_ALL_RW }, + { CSU_CSLX_QSPI, CSU_ALL_RW }, + { CSU_CSLX_ESDHC, CSU_ALL_RW }, + { CSU_CSLX_2D_ACE, CSU_ALL_RW }, + { CSU_CSLX_IFC, CSU_ALL_RW }, + { CSU_CSLX_I2C1, CSU_ALL_RW }, + { CSU_CSLX_USB2, CSU_ALL_RW }, + { CSU_CSLX_I2C3, CSU_ALL_RW }, + { CSU_CSLX_I2C2, CSU_ALL_RW }, + { CSU_CSLX_DUART2, CSU_ALL_RW }, + { CSU_CSLX_DUART1, CSU_ALL_RW }, + { CSU_CSLX_WDT2, CSU_ALL_RW }, + { CSU_CSLX_WDT1, CSU_ALL_RW }, + { CSU_CSLX_EDMA, CSU_ALL_RW }, + { CSU_CSLX_SYS_CNT, CSU_ALL_RW }, + { CSU_CSLX_DMA_MUX2, CSU_ALL_RW }, + { CSU_CSLX_DMA_MUX1, CSU_ALL_RW }, + { CSU_CSLX_DDR, CSU_ALL_RW }, + { CSU_CSLX_QUICC, CSU_ALL_RW }, + { CSU_CSLX_DCFG_CCU_RCPM, CSU_ALL_RW }, + { CSU_CSLX_SECURE_BOOTROM, CSU_ALL_RW }, + { CSU_CSLX_SFP, CSU_ALL_RW }, + { CSU_CSLX_TMU, CSU_ALL_RW }, + { CSU_CSLX_SECURE_MONITOR, CSU_ALL_RW }, + { CSU_CSLX_RESERVED0, CSU_ALL_RW }, + { CSU_CSLX_ETSEC1, CSU_ALL_RW }, + { CSU_CSLX_SEC5_5, CSU_ALL_RW }, + { CSU_CSLX_ETSEC3, CSU_ALL_RW }, + { CSU_CSLX_ETSEC2, CSU_ALL_RW }, + { CSU_CSLX_GPIO2, CSU_ALL_RW }, + { CSU_CSLX_GPIO1, CSU_ALL_RW }, + { CSU_CSLX_GPIO4, CSU_ALL_RW }, + { CSU_CSLX_GPIO3, CSU_ALL_RW }, + { CSU_CSLX_PLATFORM_CONT, CSU_ALL_RW }, + { CSU_CSLX_CSU, CSU_ALL_RW }, + { CSU_CSLX_ASRC, CSU_ALL_RW }, + { CSU_CSLX_SPDIF, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN2, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN1, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN4, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN3, CSU_ALL_RW }, + { CSU_CSLX_SAI2, CSU_ALL_RW }, + { CSU_CSLX_SAI1, CSU_ALL_RW }, + { CSU_CSLX_SAI4, CSU_ALL_RW }, + { CSU_CSLX_SAI3, CSU_ALL_RW }, + { CSU_CSLX_FTM2, CSU_ALL_RW }, + { CSU_CSLX_FTM1, CSU_ALL_RW }, + { CSU_CSLX_FTM4, CSU_ALL_RW }, + { CSU_CSLX_FTM3, CSU_ALL_RW }, + { CSU_CSLX_FTM6, CSU_ALL_RW }, + { CSU_CSLX_FTM5, CSU_ALL_RW }, + { CSU_CSLX_FTM8, CSU_ALL_RW }, + { CSU_CSLX_FTM7, CSU_ALL_RW }, + { CSU_CSLX_COP_DCSR, CSU_ALL_RW }, + { CSU_CSLX_EPU, CSU_ALL_RW }, + { CSU_CSLX_GDI, CSU_ALL_RW }, + { CSU_CSLX_DDI, CSU_ALL_RW }, + { CSU_CSLX_RESERVED1, CSU_ALL_RW }, + { CSU_CSLX_USB3_PHY, CSU_ALL_RW }, + { CSU_CSLX_RESERVED2, CSU_ALL_RW }, +}; + int board_init(void) { struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; @@ -227,6 +312,9 @@ int board_init(void) fsl_serdes_init(); config_serdes_mux(); #endif + + enable_devices_ns_access(ns_dev, ARRAY_SIZE(ns_dev)); + return 0; }
diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index b522ff2..385cee6 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -8,6 +8,7 @@ #include <i2c.h> #include <asm/io.h> #include <asm/arch/immap_ls102xa.h> +#include <asm/arch/ns_access.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> #include <mmc.h> @@ -270,6 +271,90 @@ int board_early_init_f(void) return 0; }
+static struct csu_ns_dev ns_dev[] = { + { CSU_CSLX_PCIE2_IO, CSU_ALL_RW }, + { CSU_CSLX_PCIE1_IO, CSU_ALL_RW }, + { CSU_CSLX_MG2TPR_IP, CSU_ALL_RW }, + { CSU_CSLX_IFC_MEM, CSU_ALL_RW }, + { CSU_CSLX_OCRAM, CSU_ALL_RW }, + { CSU_CSLX_GIC, CSU_ALL_RW }, + { CSU_CSLX_PCIE1, CSU_ALL_RW }, + { CSU_CSLX_OCRAM2, CSU_ALL_RW }, + { CSU_CSLX_QSPI_MEM, CSU_ALL_RW }, + { CSU_CSLX_PCIE2, CSU_ALL_RW }, + { CSU_CSLX_SATA, CSU_ALL_RW }, + { CSU_CSLX_USB3, CSU_ALL_RW }, + { CSU_CSLX_SERDES, CSU_ALL_RW }, + { CSU_CSLX_QDMA, CSU_ALL_RW }, + { CSU_CSLX_LPUART2, CSU_ALL_RW }, + { CSU_CSLX_LPUART1, CSU_ALL_RW }, + { CSU_CSLX_LPUART4, CSU_ALL_RW }, + { CSU_CSLX_LPUART3, CSU_ALL_RW }, + { CSU_CSLX_LPUART6, CSU_ALL_RW }, + { CSU_CSLX_LPUART5, CSU_ALL_RW }, + { CSU_CSLX_DSPI2, CSU_ALL_RW }, + { CSU_CSLX_DSPI1, CSU_ALL_RW }, + { CSU_CSLX_QSPI, CSU_ALL_RW }, + { CSU_CSLX_ESDHC, CSU_ALL_RW }, + { CSU_CSLX_2D_ACE, CSU_ALL_RW }, + { CSU_CSLX_IFC, CSU_ALL_RW }, + { CSU_CSLX_I2C1, CSU_ALL_RW }, + { CSU_CSLX_USB2, CSU_ALL_RW }, + { CSU_CSLX_I2C3, CSU_ALL_RW }, + { CSU_CSLX_I2C2, CSU_ALL_RW }, + { CSU_CSLX_DUART2, CSU_ALL_RW }, + { CSU_CSLX_DUART1, CSU_ALL_RW }, + { CSU_CSLX_WDT2, CSU_ALL_RW }, + { CSU_CSLX_WDT1, CSU_ALL_RW }, + { CSU_CSLX_EDMA, CSU_ALL_RW }, + { CSU_CSLX_SYS_CNT, CSU_ALL_RW }, + { CSU_CSLX_DMA_MUX2, CSU_ALL_RW }, + { CSU_CSLX_DMA_MUX1, CSU_ALL_RW }, + { CSU_CSLX_DDR, CSU_ALL_RW }, + { CSU_CSLX_QUICC, CSU_ALL_RW }, + { CSU_CSLX_DCFG_CCU_RCPM, CSU_ALL_RW }, + { CSU_CSLX_SECURE_BOOTROM, CSU_ALL_RW }, + { CSU_CSLX_SFP, CSU_ALL_RW }, + { CSU_CSLX_TMU, CSU_ALL_RW }, + { CSU_CSLX_SECURE_MONITOR, CSU_ALL_RW }, + { CSU_CSLX_RESERVED0, CSU_ALL_RW }, + { CSU_CSLX_ETSEC1, CSU_ALL_RW }, + { CSU_CSLX_SEC5_5, CSU_ALL_RW }, + { CSU_CSLX_ETSEC3, CSU_ALL_RW }, + { CSU_CSLX_ETSEC2, CSU_ALL_RW }, + { CSU_CSLX_GPIO2, CSU_ALL_RW }, + { CSU_CSLX_GPIO1, CSU_ALL_RW }, + { CSU_CSLX_GPIO4, CSU_ALL_RW }, + { CSU_CSLX_GPIO3, CSU_ALL_RW }, + { CSU_CSLX_PLATFORM_CONT, CSU_ALL_RW }, + { CSU_CSLX_CSU, CSU_ALL_RW }, + { CSU_CSLX_ASRC, CSU_ALL_RW }, + { CSU_CSLX_SPDIF, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN2, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN1, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN4, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN3, CSU_ALL_RW }, + { CSU_CSLX_SAI2, CSU_ALL_RW }, + { CSU_CSLX_SAI1, CSU_ALL_RW }, + { CSU_CSLX_SAI4, CSU_ALL_RW }, + { CSU_CSLX_SAI3, CSU_ALL_RW }, + { CSU_CSLX_FTM2, CSU_ALL_RW }, + { CSU_CSLX_FTM1, CSU_ALL_RW }, + { CSU_CSLX_FTM4, CSU_ALL_RW }, + { CSU_CSLX_FTM3, CSU_ALL_RW }, + { CSU_CSLX_FTM6, CSU_ALL_RW }, + { CSU_CSLX_FTM5, CSU_ALL_RW }, + { CSU_CSLX_FTM8, CSU_ALL_RW }, + { CSU_CSLX_FTM7, CSU_ALL_RW }, + { CSU_CSLX_COP_DCSR, CSU_ALL_RW }, + { CSU_CSLX_EPU, CSU_ALL_RW }, + { CSU_CSLX_GDI, CSU_ALL_RW }, + { CSU_CSLX_DDI, CSU_ALL_RW }, + { CSU_CSLX_RESERVED1, CSU_ALL_RW }, + { CSU_CSLX_USB3_PHY, CSU_ALL_RW }, + { CSU_CSLX_RESERVED2, CSU_ALL_RW }, +}; + int board_init(void) { #ifndef CONFIG_SYS_FSL_NO_SERDES @@ -277,6 +362,8 @@ int board_init(void) config_serdes_mux(); #endif
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index b922e58..9663f1f 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -327,6 +327,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ARMV7_NONSEC #define CONFIG_ARMV7_VIRT #define CONFIG_SOC_BIG_ENDIAN +#define CONFIG_LS102XA_NS_ACESS #define CONFIG_SMP_PEN_ADDR 0x01ee0200 #define CONFIG_TIMER_CLK_FREQ 12500000 #define CONFIG_ARMV7_SECURE_BASE OCRAM_BASE_S_ADDR diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 8c30831..15ee2db 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -230,6 +230,7 @@ #define CONFIG_ARMV7_NONSEC #define CONFIG_ARMV7_VIRT #define CONFIG_SOC_BIG_ENDIAN +#define CONFIG_LS102XA_NS_ACESS #define CONFIG_SMP_PEN_ADDR 0x01ee0200 #define CONFIG_TIMER_CLK_FREQ 12500000 #define CONFIG_ARMV7_SECURE_BASE OCRAM_BASE_S_ADDR
Ping :)
Thanks,
BRs Xiubo
-----Original Message----- From: Xiubo Li [mailto:Li.Xiubo@freescale.com] Sent: Tuesday, September 16, 2014 10:48 AM To: albert.u.boot@aribaud.net; Wang Huan-B18965; ijc@hellion.org.uk; hdegoede@redhat.com; Kushwaha Prabhakar-B32579; Wang Huan-B18965; andre.przywara@linaro.org; marc.zyngier@arm.com; yamada.m@jp.panasonic.com; Aggrwal Poonam-B10812; Leekha Shaveta-B20052; u-boot@lists.denx.de Cc: Xiubo Li-B47053 Subject: [PATCH 0/4] ls102xa: HYP/non-sec: for ls102xa.
-- 2.1.0.27.g96db324
Hi York, Albert
Could you help me to review these patches ?
Thanks very much,
BRs Xiubo
Xiubo Li
