[U-Boot-Users] [PATCH 02/30] common/cmd_[i-n]*: Remove obsolete references to CONFIG_COMMANDS.
Signed-off-by: Jon Loeliger jdl@freescale.com --- common/cmd_i2c.c | 10 +++++----- common/cmd_ide.c | 4 ++-- common/cmd_immap.c | 2 +- common/cmd_itest.c | 4 ++-- common/cmd_jffs2.c | 14 +++++++------- common/cmd_load.c | 20 ++++++++++---------- common/cmd_mem.c | 15 +++++---------- common/cmd_mfsl.c | 2 +- common/cmd_mii.c | 2 +- common/cmd_misc.c | 6 +++--- common/cmd_mmc.c | 2 +- common/cmd_nand.c | 23 +++++++++-------------- common/cmd_net.c | 16 ++++++++-------- common/cmd_nvedit.c | 18 +++++------------- 14 files changed, 60 insertions(+), 78 deletions(-)
diff --git a/common/cmd_i2c.c b/common/cmd_i2c.c index b9d9d33..6aeeb84 100644 --- a/common/cmd_i2c.c +++ b/common/cmd_i2c.c @@ -86,7 +86,7 @@ #include <i2c.h> #include <asm/byteorder.h>
-#if (CONFIG_COMMANDS & CFG_CMD_I2C) || defined(CONFIG_CMD_I2C) +#if defined(CONFIG_CMD_I2C)
/* Display values from last command. @@ -657,7 +657,7 @@ int do_i2c_loop(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) * The SDRAM command is separately configured because many * (most?) embedded boards don't use SDRAM DIMMs. */ -#if (CONFIG_COMMANDS & CFG_CMD_SDRAM) || defined(CONFIG_CMD_SDRAM) +#if defined(CONFIG_CMD_SDRAM)
/* * Syntax: @@ -938,7 +938,7 @@ int do_i2c(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) return do_i2c_probe(cmdtp, flag, --argc, ++argv); if (!strncmp(argv[1], "lo", 2)) return do_i2c_loop(cmdtp, flag, --argc, ++argv); -#if (CONFIG_COMMANDS & CFG_CMD_SDRAM) || defined(CONFIG_CMD_SDRAM) +#if defined(CONFIG_CMD_SDRAM) if (!strncmp(argv[1], "sd", 2)) return do_sdram(cmdtp, flag, --argc, ++argv); #endif /* CFG_CMD_SDRAM */ @@ -965,7 +965,7 @@ U_BOOT_CMD( "i2c crc32 chip address[.0, .1, .2] count - compute CRC32 checksum\n" "i2c probe - show devices on the I2C bus\n" "i2c loop chip address[.0, .1, .2] [# of objects] - looping read of device\n" -#if (CONFIG_COMMANDS & CFG_CMD_SDRAM) || defined(CONFIG_CMD_SDRAM) +#if defined(CONFIG_CMD_SDRAM) "i2c sdram chip - print SDRAM configuration information\n" #endif /* CFG_CMD_SDRAM */ ); @@ -1016,7 +1016,7 @@ U_BOOT_CMD( " - loop, reading a set of addresses\n" );
-#if (CONFIG_COMMANDS & CFG_CMD_SDRAM) || defined(CONFIG_CMD_SDRAM) +#if defined(CONFIG_CMD_SDRAM) U_BOOT_CMD( isdram, 2, 1, do_sdram, "isdram - print SDRAM configuration information\n", diff --git a/common/cmd_ide.c b/common/cmd_ide.c index 461a4bc..d74f2da 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -78,7 +78,7 @@ DECLARE_GLOBAL_DATA_PTR; # define SYNC /* nothing */ #endif
-#if (CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) +#if defined(CONFIG_CMD_IDE)
#ifdef CONFIG_IDE_8xx_DIRECT /* Timings for IDE Interface @@ -2080,4 +2080,4 @@ U_BOOT_CMD( "loadAddr dev:part\n" );
-#endif /* CONFIG_COMMANDS & CFG_CMD_IDE */ +#endif diff --git a/common/cmd_immap.c b/common/cmd_immap.c index 477c742..e211b16 100644 --- a/common/cmd_immap.c +++ b/common/cmd_immap.c @@ -28,7 +28,7 @@ #include <common.h> #include <command.h>
-#if ((CONFIG_COMMANDS & CFG_CMD_IMMAP) || defined(CONFIG_CMD_IMMAP)) && \ +#if defined(CONFIG_CMD_IMMAP) && \ (defined(CONFIG_8xx) || defined(CONFIG_8260))
#if defined(CONFIG_8xx) diff --git a/common/cmd_itest.c b/common/cmd_itest.c index 24129aa..8e20517 100644 --- a/common/cmd_itest.c +++ b/common/cmd_itest.c @@ -32,7 +32,7 @@ #include <config.h> #include <command.h>
-#if (CONFIG_COMMANDS & CFG_CMD_ITEST) || defined(CONFIG_CMD_ITEST) +#if defined(CONFIG_CMD_ITEST)
#define EQ 0 #define NE 1 @@ -197,4 +197,4 @@ U_BOOT_CMD( "itest\t- return true/false on integer compare\n", "[.b, .w, .l, .s] [*]value1 <op> [*]value2\n" ); -#endif /* CONFIG_COMMANDS & CFG_CMD_ITEST */ +#endif diff --git a/common/cmd_jffs2.c b/common/cmd_jffs2.c index 8a882ab..777607a 100644 --- a/common/cmd_jffs2.c +++ b/common/cmd_jffs2.c @@ -94,18 +94,18 @@ #include <linux/list.h> #include <linux/ctype.h>
-#if (CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2) +#if defined(CONFIG_CMD_JFFS2)
#include <cramfs/cramfs_fs.h>
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND) +#if defined(CONFIG_CMD_NAND) #ifdef CFG_NAND_LEGACY #include <linux/mtd/nand_legacy.h> #else /* !CFG_NAND_LEGACY */ #include <linux/mtd/nand.h> #include <nand.h> #endif /* !CFG_NAND_LEGACY */ -#endif /* (CONFIG_COMMANDS & CFG_CMD_NAND) */ +#endif /* enable/disable debugging messages */ #define DEBUG_JFFS #undef DEBUG_JFFS @@ -321,7 +321,7 @@ static void current_save(void) */ static int part_validate_nor(struct mtdids *id, struct part_info *part) { -#if (CONFIG_COMMANDS & CFG_CMD_FLASH) || defined(CONFIG_CMD_FLASH) +#if defined(CONFIG_CMD_FLASH) /* info for FLASH chips */ extern flash_info_t flash_info[]; flash_info_t *flash; @@ -370,7 +370,7 @@ static int part_validate_nor(struct mtdids *id, struct part_info *part) */ static int part_validate_nand(struct mtdids *id, struct part_info *part) { -#if defined(CONFIG_JFFS2_NAND) && ((CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND)) +#if defined(CONFIG_JFFS2_NAND) && defined(CONFIG_CMD_NAND) /* info for NAND chips */ nand_info_t *nand;
@@ -719,7 +719,7 @@ static int part_parse(const char *const partdef, const char **ret, struct part_i static int device_validate(u8 type, u8 num, u32 *size) { if (type == MTD_DEV_TYPE_NOR) { -#if (CONFIG_COMMANDS & CFG_CMD_FLASH) || defined(CONFIG_CMD_FLASH) +#if defined(CONFIG_CMD_FLASH) if (num < CFG_MAX_FLASH_BANKS) { extern flash_info_t flash_info[]; *size = flash_info[num].size; @@ -733,7 +733,7 @@ static int device_validate(u8 type, u8 num, u32 *size) printf("support for FLASH devices not present\n"); #endif } else if (type == MTD_DEV_TYPE_NAND) { -#if defined(CONFIG_JFFS2_NAND) && ((CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND)) +#if defined(CONFIG_JFFS2_NAND) && defined(CONFIG_CMD_NAND) if (num < CFG_MAX_NAND_DEVICE) { #ifndef CFG_NAND_LEGACY *size = nand_info[num].size; diff --git a/common/cmd_load.c b/common/cmd_load.c index 0456f75..d3d2681 100644 --- a/common/cmd_load.c +++ b/common/cmd_load.c @@ -33,14 +33,14 @@
-#if (CONFIG_COMMANDS & CFG_CMD_LOADB) || defined(CONFIG_CMD_LOADB) +#if defined(CONFIG_CMD_LOADB) static ulong load_serial_ymodem (ulong offset); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_LOADS) || defined(CONFIG_CMD_LOADS) +#if defined(CONFIG_CMD_LOADS) static ulong load_serial (ulong offset); static int read_record (char *buf, ulong len); -# if (CONFIG_COMMANDS & CFG_CMD_SAVES) || defined(CONFIG_CMD_SAVES) +# if defined(CONFIG_CMD_SAVES) static int save_serial (ulong offset, ulong size); static int write_record (char *buf); # endif /* CFG_CMD_SAVES */ @@ -50,7 +50,7 @@ static int do_echo = 1;
-#if (CONFIG_COMMANDS & CFG_CMD_LOADS) || defined(CONFIG_CMD_LOADS) +#if defined(CONFIG_CMD_LOADS) int do_load_serial (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { ulong offset = 0; @@ -253,7 +253,7 @@ read_record (char *buf, ulong len) return (p - buf); }
-#if (CONFIG_COMMANDS & CFG_CMD_SAVES) || defined(CONFIG_CMD_SAVES) +#if defined(CONFIG_CMD_SAVES)
int do_save_serial (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { @@ -404,7 +404,7 @@ write_record (char *buf) #endif /* CFG_CMD_LOADS */
-#if (CONFIG_COMMANDS & CFG_CMD_LOADB) || defined(CONFIG_CMD_LOADB) +#if defined(CONFIG_CMD_LOADB) /* * loadb command (load binary) included */ @@ -1042,7 +1042,7 @@ static ulong load_serial_ymodem (ulong offset)
#ifdef CFG_LOADS_BAUD_CHANGE U_BOOT_CMD( @@ -1067,7 +1067,7 @@ U_BOOT_CMD( */
-#if (CONFIG_COMMANDS & CFG_CMD_SAVES) || defined(CONFIG_CMD_SAVES) +#if defined(CONFIG_CMD_SAVES) #ifdef CFG_LOADS_BAUD_CHANGE U_BOOT_CMD( saves, 4, 0, do_save_serial, @@ -1088,7 +1088,7 @@ U_BOOT_CMD( #endif /* CFG_CMD_LOADS */
-#if (CONFIG_COMMANDS & CFG_CMD_LOADB) || defined(CONFIG_CMD_LOADB) +#if defined(CONFIG_CMD_LOADB) U_BOOT_CMD( loadb, 3, 0, do_load_serial_bin, "loadb - load binary file over serial line (kermit mode)\n", @@ -1109,7 +1109,7 @@ U_BOOT_CMD(
-#if (CONFIG_COMMANDS & CFG_CMD_HWFLOW) || defined(CONFIG_CMD_HWFLOW) +#if defined(CONFIG_CMD_HWFLOW) int do_hwflow (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { extern int hwflow_onoff(int); diff --git a/common/cmd_mem.c b/common/cmd_mem.c index b547974..001dfa2 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -29,19 +29,14 @@
#include <common.h> #include <command.h> -#if (CONFIG_COMMANDS & CFG_CMD_MMC) || defined(CONFIG_CMD_MMC) +#if defined(CONFIG_CMD_MMC) #include <mmc.h> #endif #ifdef CONFIG_HAS_DATAFLASH #include <dataflash.h> #endif
-#if (CONFIG_COMMANDS & (CFG_CMD_MEMORY | \ - CFG_CMD_I2C | \ - CFG_CMD_ITEST | \ - CFG_CMD_PCI | \ - CMD_CMD_PORTIO ) ) \ - || defined(CONFIG_CMD_MEMORY) \ +#if defined(CONFIG_CMD_MEMORY) \ || defined(CONFIG_CMD_I2C) \ || defined(CONFIG_CMD_ITEST) \ || defined(CONFIG_CMD_PCI) \ @@ -70,7 +65,7 @@ int cmd_get_data_size(char* arg, int default_size) } #endif
-#if (CONFIG_COMMANDS & CFG_CMD_MEMORY) || defined(CONFIG_CMD_MEMORY) +#if defined(CONFIG_CMD_MEMORY)
#ifdef CMD_MEM_DEBUG #define PRINTF(fmt,args...) printf (fmt ,##args) @@ -409,7 +404,7 @@ int do_mem_cp ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) } #endif
-#if (CONFIG_COMMANDS & CFG_CMD_MMC) || defined(CONFIG_CMD_MMC) +#if defined(CONFIG_CMD_MMC) if (mmc2info(dest)) { int rc;
@@ -1155,7 +1150,7 @@ int do_mem_crc (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) #endif /* CONFIG_CRC32_VERIFY */
/**************************************************/ -#if (CONFIG_COMMANDS & CFG_CMD_MEMORY) || defined(CONFIG_CMD_MEMORY) +#if defined(CONFIG_CMD_MEMORY) U_BOOT_CMD( md, 3, 1, do_mem_md, "md - memory display\n", diff --git a/common/cmd_mfsl.c b/common/cmd_mfsl.c index 5dcfc94..b143dc2 100644 --- a/common/cmd_mfsl.c +++ b/common/cmd_mfsl.c @@ -30,7 +30,7 @@ #include <config.h> #include <command.h>
-#if (CONFIG_COMMANDS & CFG_CMD_MFSL) || defined(CONFIG_CMD_MFSL) +#if defined(CONFIG_CMD_MFSL) #include <asm/asm.h>
int do_frd (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) diff --git a/common/cmd_mii.c b/common/cmd_mii.c index bfeef79..120b8e8 100644 --- a/common/cmd_mii.c +++ b/common/cmd_mii.c @@ -28,7 +28,7 @@ #include <common.h> #include <command.h>
-#if (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_CMD_MII) #include <miiphy.h>
#ifdef CONFIG_TERSE_MII diff --git a/common/cmd_misc.c b/common/cmd_misc.c index c554013..4d5a2ff 100644 --- a/common/cmd_misc.c +++ b/common/cmd_misc.c @@ -27,7 +27,7 @@ #include <common.h> #include <command.h>
-#if (CONFIG_COMMANDS & CFG_CMD_MISC) || defined(CONFIG_CMD_MISC) +#if defined(CONFIG_CMD_MISC)
int do_sleep (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { @@ -52,7 +52,7 @@ int do_sleep (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) }
/* Implemented in $(CPU)/interrupts.c */ -#if (CONFIG_COMMANDS & CFG_CMD_IRQ) || defined(CONFIG_CMD_IRQ) +#if defined(CONFIG_CMD_IRQ) int do_irqinfo (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]);
U_BOOT_CMD( @@ -60,7 +60,7 @@ U_BOOT_CMD( "irqinfo - print information about IRQs\n", NULL ); -#endif /* CONFIG_COMMANDS & CFG_CMD_IRQ */ +#endif
U_BOOT_CMD( sleep , 2, 1, do_sleep, diff --git a/common/cmd_mmc.c b/common/cmd_mmc.c index 7abaa98..c772e9b 100644 --- a/common/cmd_mmc.c +++ b/common/cmd_mmc.c @@ -24,7 +24,7 @@ #include <common.h> #include <command.h>
#include <mmc.h>
diff --git a/common/cmd_nand.c b/common/cmd_nand.c index 63a68eb..d584445 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -19,7 +19,7 @@ */ #include <common.h>
#include <command.h> #include <watchdog.h> @@ -36,8 +36,7 @@ #include <jffs2/jffs2.h> #include <nand.h>
-#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) \ - && defined(CONFIG_JFFS2_CMDLINE) +#if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE)
/* parition handling routines */ int mtdparts_init(void); @@ -105,8 +104,7 @@ static int arg_off_size(int argc, char *argv[], nand_info_t *nand, ulong *off, ulong *size) { int idx = nand_curr_device; -#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) \ - && defined(CONFIG_JFFS2_CMDLINE) +#if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) struct mtd_device *dev; struct part_info *part; u8 pnum; @@ -154,8 +152,7 @@ arg_off_size(int argc, char *argv[], nand_info_t *nand, ulong *off, ulong *size) *size = nand->size - *off; }
-#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) \ - && defined(CONFIG_JFFS2_CMDLINE) +#if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) out: #endif printf("device %d ", idx); @@ -537,8 +534,7 @@ int do_nandboot(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) char *boot_device = NULL; int idx; ulong addr, offset = 0; -#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) \ - && defined(CONFIG_JFFS2_CMDLINE) +#if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) struct mtd_device *dev; struct part_info *part; u8 pnum; @@ -582,8 +578,7 @@ int do_nandboot(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) offset = simple_strtoul(argv[3], NULL, 16); break; default: -#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) \ - && defined(CONFIG_JFFS2_CMDLINE) +#if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) usage: #endif printf("Usage:\n%s\n", cmdtp->usage); @@ -612,7 +607,7 @@ U_BOOT_CMD(nboot, 4, 1, do_nandboot, "nboot - boot from NAND device\n", "[partition] | [[[loadAddr] dev] offset]\n");
#else /* CFG_NAND_LEGACY */ /* @@ -632,7 +627,7 @@ U_BOOT_CMD(nboot, 4, 1, do_nandboot, # define SHOW_BOOT_PROGRESS(arg) #endif
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND) +#if defined(CONFIG_CMD_NAND) #include <linux/mtd/nand_legacy.h> #if 0 #include <linux/mtd/nand_ids.h> @@ -990,6 +985,6 @@ U_BOOT_CMD( "loadAddr dev\n" );
#endif /* CFG_NAND_LEGACY */ diff --git a/common/cmd_net.c b/common/cmd_net.c index ad9a7dc..da55f14 100644 --- a/common/cmd_net.c +++ b/common/cmd_net.c @@ -28,7 +28,7 @@ #include <command.h> #include <net.h>
-#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) +#if defined(CONFIG_CMD_NET)
extern int do_bootm (cmd_tbl_t *, int, int, char *[]); @@ -68,7 +68,7 @@ U_BOOT_CMD( "[loadAddress] [bootfilename]\n" );
-#if (CONFIG_COMMANDS & CFG_CMD_DHCP) || defined(CONFIG_CMD_DHCP) +#if defined(CONFIG_CMD_DHCP) int do_dhcp (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { return netboot_common(DHCP, cmdtp, argc, argv); @@ -81,7 +81,7 @@ U_BOOT_CMD( ); #endif /* CFG_CMD_DHCP */
-#if (CONFIG_COMMANDS & CFG_CMD_NFS) || defined(CONFIG_CMD_NFS) +#if defined(CONFIG_CMD_NFS) int do_nfs (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { return netboot_common(NFS, cmdtp, argc, argv); @@ -137,14 +137,14 @@ static void netboot_update_env (void) if (NetOurNISDomain[0]) setenv ("domain", NetOurNISDomain);
-#if ((CONFIG_COMMANDS & CFG_CMD_SNTP) || defined(CONFIG_CMD_SNTP)) \ +#if defined(CONFIG_CMD_SNTP) \ && (CONFIG_BOOTP_MASK & CONFIG_BOOTP_TIMEOFFSET) if (NetTimeOffset) { sprintf (tmp, "%d", NetTimeOffset); setenv ("timeoffset", tmp); } #endif -#if ((CONFIG_COMMANDS & CFG_CMD_SNTP) || defined(CONFIG_CMD_SNTP)) \ +#if defined(CONFIG_CMD_SNTP) \ && (CONFIG_BOOTP_MASK & CONFIG_BOOTP_NTPSERVER) if (NetNtpServerIP) { ip_to_string (NetNtpServerIP, tmp); @@ -222,7 +222,7 @@ netboot_common (proto_t proto, cmd_tbl_t *cmdtp, int argc, char *argv[]) return rcode; }
-#if (CONFIG_COMMANDS & CFG_CMD_PING) || defined(CONFIG_CMD_PING) +#if defined(CONFIG_CMD_PING) int do_ping (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { if (argc < 2) @@ -251,7 +251,7 @@ U_BOOT_CMD( ); #endif /* CFG_CMD_PING */
-#if (CONFIG_COMMANDS & CFG_CMD_CDP) || defined(CONFIG_CMD_CDP) +#if defined(CONFIG_CMD_CDP)
static void cdp_update_env(void) { @@ -294,7 +294,7 @@ U_BOOT_CMD( ); #endif /* CFG_CMD_CDP */
-#if (CONFIG_COMMANDS & CFG_CMD_SNTP) || defined(CONFIG_CMD_SNTP) +#if defined(CONFIG_CMD_SNTP) int do_sntp (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { char *toff; diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 27e46db..68a2dc8 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -46,7 +46,7 @@ #include <serial.h> #include <linux/stddef.h> #include <asm/byteorder.h> -#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) +#if defined(CONFIG_CMD_NET) #include <net.h> #endif
@@ -367,7 +367,7 @@ int _do_setenv (int flag, int argc, char *argv[]) load_addr = simple_strtoul(argv[2], NULL, 16); return 0; } -#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) +#if defined(CONFIG_CMD_NET) if (strcmp(argv[1],"bootfile") == 0) { copy_filename (BootFile, argv[2], sizeof(BootFile)); return 0; @@ -411,7 +411,7 @@ int do_setenv ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) * Prompt for environment variable */
-#if (CONFIG_COMMANDS & CFG_CMD_ASKENV) || defined(CONFIG_CMD_ASKENV) +#if defined(CONFIG_CMD_ASKENV) int do_askenv ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { extern char console_buffer[CFG_CBSIZE]; @@ -539,10 +539,6 @@ int getenv_r (char *name, char *buf, unsigned len) }
#if defined(CFG_ENV_IS_IN_NVRAM) || defined(CFG_ENV_IS_IN_EEPROM) || \ - ((CONFIG_COMMANDS & (CFG_CMD_ENV|CFG_CMD_FLASH)) == \ - (CFG_CMD_ENV|CFG_CMD_FLASH)) || \ - ((CONFIG_COMMANDS & (CFG_CMD_ENV|CFG_CMD_NAND)) == \ - (CFG_CMD_ENV|CFG_CMD_NAND)) \ || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_FLASH)) \ || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_NAND)) int do_saveenv (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -599,10 +595,6 @@ U_BOOT_CMD( );
#if defined(CFG_ENV_IS_IN_NVRAM) || defined(CFG_ENV_IS_IN_EEPROM) || \ - ((CONFIG_COMMANDS & (CFG_CMD_ENV|CFG_CMD_FLASH)) == \ - (CFG_CMD_ENV|CFG_CMD_FLASH)) || \ - ((CONFIG_COMMANDS & (CFG_CMD_ENV|CFG_CMD_NAND)) == \ - (CFG_CMD_ENV|CFG_CMD_NAND)) \ || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_FLASH)) \ || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_NAND)) U_BOOT_CMD( @@ -613,7 +605,7 @@ U_BOOT_CMD(
#endif /* CFG_CMD_ENV */
U_BOOT_CMD( askenv, CFG_MAXARGS, 1, do_askenv, @@ -630,7 +622,7 @@ U_BOOT_CMD( ); #endif /* CFG_CMD_ASKENV */
-#if (CONFIG_COMMANDS & CFG_CMD_RUN) || defined(CONFIG_CMD_RUN) +#if defined(CONFIG_CMD_RUN) int do_run (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); U_BOOT_CMD( run, CFG_MAXARGS, 1, do_run,
Jon Loeliger
