[U-Boot] [PATCH v2 1/2] sandbox: Update minor documentation changes
From: Jagannadha Sutradharudu Teki jaganna@gmail.com
- Use _defconfig instead of _config, but still _config is working. - Corrected README.sandbox path in ./README
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@gmail.com --- Changes for v2: - Fixed board path in 'board/sandbox/README.sandbox'
README | 2 +- board/sandbox/README.sandbox | 6 +++--- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/README b/README index 1e63f04..e88184b 100644 --- a/README +++ b/README @@ -272,7 +272,7 @@ board. This allows feature development which is not board- or architecture- specific to be undertaken on a native platform. The sandbox is also used to run some of U-Boot's tests.
-See board/sandbox/sandbox/README.sandbox for more details. +See board/sandbox/README.sandbox for more details.
Configuration Options: diff --git a/board/sandbox/README.sandbox b/board/sandbox/README.sandbox index 529c447..5f879f5 100644 --- a/board/sandbox/README.sandbox +++ b/board/sandbox/README.sandbox @@ -19,7 +19,7 @@ create unit tests which we can run to test this upper level code. CONFIG_SANDBOX is defined when building a native board.
The chosen vendor and board names are also 'sandbox', so there is a single -board in board/sandbox/sandbox. +board in board/sandbox.
CONFIG_SANDBOX_BIG_ENDIAN should be defined when running on big-endian machines. @@ -32,7 +32,7 @@ Basic Operation
To run sandbox U-Boot use something like:
- make sandbox_config all + make sandbox_defconfig all ./u-boot
Note: @@ -41,7 +41,7 @@ Note: build sandbox without SDL (i.e. no display/keyboard support) by removing the CONFIG_SANDBOX_SDL line in include/configs/sandbox.h or using:
- make sandbox_config all NO_SDL=1 + make sandbox_defconfig all NO_SDL=1 ./u-boot
On 31 August 2014 08:49, Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com wrote:
Thanks.
Hi Jagan,
On Sun, 31 Aug 2014 21:19:43 +0530 Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com wrote:
This is not what I meant. Please write a description that makes sense here.
(Note: The board directory is board/$(VENDOR)/$(BOARD), or board/$(BOARD) if VENDOR is not set. Sandbox dropped the vendor name, therefore the board directory is board/sandbox now.)
Best Regards Masahiro Yamada
On 31 August 2014 22:24, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hi Jagan,
Applied to u-boot-x86/misc and now in mainline.
See this for the follow-up:
Masahiro Yamada
