[PATCH v4 0/6] FWU: Add support for mtd backed feature on DeveloperBox
Introduce support for mtd backed storage for FWU feature and enable it on Synquacer platform based DeveloperBox.
This revision is rebased onto patchset that trims the FWU api https://lore.kernel.org/u-boot/20230306231747.1888513-1-jassisinghbrar@gmail...
Changes since v3: * Fix and Update documentation to also build optee for FWU FIP image. * Fixed checkpatch warnings * Made local functions static. * Split config changes to a separate patch * Fix authorship of three patches.
Jassi Brar (3): dt: fwu: developerbox: enable fwu banks and mdata regions configs: move to new flash layout and boot flow fwu: DeveloperBox: add support for FWU
Masami Hiramatsu (3): FWU: Add FWU metadata access driver for MTD storage regions FWU: mtd: Add helper functions for accessing FWU metadata tools: Add mkfwumdata tool for FWU metadata image
.../synquacer-sc2a11-developerbox-u-boot.dtsi | 49 ++- board/socionext/developerbox/Makefile | 1 + board/socionext/developerbox/developerbox.c | 8 + board/socionext/developerbox/fwu_plat.c | 57 +++ configs/synquacer_developerbox_defconfig | 12 +- doc/board/socionext/developerbox.rst | 155 +++++++- drivers/fwu-mdata/Kconfig | 15 + drivers/fwu-mdata/Makefile | 1 + drivers/fwu-mdata/raw_mtd.c | 272 ++++++++++++++ include/configs/synquacer.h | 10 + include/fwu.h | 34 ++ lib/fwu_updates/Makefile | 1 + lib/fwu_updates/fwu_mtd.c | 164 +++++++++ tools/Kconfig | 9 + tools/Makefile | 4 + tools/mkfwumdata.c | 334 ++++++++++++++++++ 16 files changed, 1115 insertions(+), 11 deletions(-) create mode 100644 board/socionext/developerbox/fwu_plat.c create mode 100644 drivers/fwu-mdata/raw_mtd.c create mode 100644 lib/fwu_updates/fwu_mtd.c create mode 100644 tools/mkfwumdata.c
In the FWU Multi Bank Update feature, the information about the updatable images is stored as part of the metadata, on a separate region. Add a driver for reading from and writing to the metadata when the updatable images and the metadata are stored on a raw MTD region.
Signed-off-by: Masami Hiramatsu masami.hiramatsu@linaro.org Signed-off-by: Jassi Brar jaswinder.singh@linaro.org --- drivers/fwu-mdata/Kconfig | 15 ++ drivers/fwu-mdata/Makefile | 1 + drivers/fwu-mdata/raw_mtd.c | 272 ++++++++++++++++++++++++++++++++++++ 3 files changed, 288 insertions(+) create mode 100644 drivers/fwu-mdata/raw_mtd.c
diff --git a/drivers/fwu-mdata/Kconfig b/drivers/fwu-mdata/Kconfig index 36c4479a59..42736a5e43 100644 --- a/drivers/fwu-mdata/Kconfig +++ b/drivers/fwu-mdata/Kconfig @@ -6,6 +6,11 @@ config FWU_MDATA FWU Metadata partitions reside on the same storage device which contains the other FWU updatable firmware images.
+choice + prompt "Storage Layout Scheme" + depends on FWU_MDATA + default FWU_MDATA_GPT_BLK + config FWU_MDATA_GPT_BLK bool "FWU Metadata access for GPT partitioned Block devices" select PARTITION_TYPE_GUID @@ -14,3 +19,13 @@ config FWU_MDATA_GPT_BLK help Enable support for accessing FWU Metadata on GPT partitioned block devices. + +config FWU_MDATA_MTD + bool "Raw MTD devices" + depends on MTD + help + Enable support for accessing FWU Metadata on non-partitioned + (or non-GPT partitioned, e.g. partition nodes in devicetree) + MTD devices. + +endchoice diff --git a/drivers/fwu-mdata/Makefile b/drivers/fwu-mdata/Makefile index 3fee64c10c..06c49747ba 100644 --- a/drivers/fwu-mdata/Makefile +++ b/drivers/fwu-mdata/Makefile @@ -6,3 +6,4 @@
obj-$(CONFIG_FWU_MDATA) += fwu-mdata-uclass.o obj-$(CONFIG_FWU_MDATA_GPT_BLK) += gpt_blk.o +obj-$(CONFIG_FWU_MDATA_MTD) += raw_mtd.o diff --git a/drivers/fwu-mdata/raw_mtd.c b/drivers/fwu-mdata/raw_mtd.c new file mode 100644 index 0000000000..4b1a10073a --- /dev/null +++ b/drivers/fwu-mdata/raw_mtd.c @@ -0,0 +1,272 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2023, Linaro Limited + */ + +#define LOG_CATEGORY UCLASS_FWU_MDATA + +#include <fwu.h> +#include <fwu_mdata.h> +#include <memalign.h> + +#include <linux/errno.h> +#include <linux/types.h> + +/* Internal helper structure to move data around */ +struct fwu_mdata_mtd_priv { + struct mtd_info *mtd; + char pri_label[50]; + char sec_label[50]; + u32 pri_offset; + u32 sec_offset; +}; + +enum fwu_mtd_op { + FWU_MTD_READ, + FWU_MTD_WRITE, +}; + +extern struct fwu_mtd_image_info fwu_mtd_images[]; + +static bool mtd_is_aligned_with_block_size(struct mtd_info *mtd, u64 size) +{ + return !do_div(size, mtd->erasesize); +} + +static int mtd_io_data(struct mtd_info *mtd, u32 offs, u32 size, void *data, + enum fwu_mtd_op op) +{ + struct mtd_oob_ops io_op = {}; + u64 lock_offs, lock_len; + size_t len; + void *buf; + int ret; + + if (!mtd_is_aligned_with_block_size(mtd, offs)) { + log_err("Offset unaligned with a block (0x%x)\n", mtd->erasesize); + return -EINVAL; + } + + lock_offs = offs; + /* This will expand erase size to align with the block size */ + lock_len = round_up(size, mtd->erasesize); + + ret = mtd_unlock(mtd, lock_offs, lock_len); + if (ret && ret != -EOPNOTSUPP) + return ret; + + if (op == FWU_MTD_WRITE) { + struct erase_info erase_op = {}; + + erase_op.mtd = mtd; + erase_op.addr = lock_offs; + erase_op.len = lock_len; + erase_op.scrub = 0; + + ret = mtd_erase(mtd, &erase_op); + if (ret) + goto lock; + } + + /* Also, expand the write size to align with the write size */ + len = round_up(size, mtd->writesize); + + buf = memalign(ARCH_DMA_MINALIGN, len); + if (!buf) { + ret = -ENOMEM; + goto lock; + } + memset(buf, 0xff, len); + + io_op.mode = MTD_OPS_AUTO_OOB; + io_op.len = len; + io_op.ooblen = 0; + io_op.datbuf = buf; + io_op.oobbuf = NULL; + + if (op == FWU_MTD_WRITE) { + memcpy(buf, data, size); + ret = mtd_write_oob(mtd, offs, &io_op); + } else { + ret = mtd_read_oob(mtd, offs, &io_op); + if (!ret) + memcpy(data, buf, size); + } + free(buf); + +lock: + mtd_lock(mtd, lock_offs, lock_len); + + return ret; +} + +static int fwu_mtd_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary) +{ + struct fwu_mdata_mtd_priv *mtd_priv = dev_get_priv(dev); + struct mtd_info *mtd = mtd_priv->mtd; + u32 offs = primary ? mtd_priv->pri_offset : mtd_priv->sec_offset; + + return mtd_io_data(mtd, offs, sizeof(struct fwu_mdata), mdata, FWU_MTD_READ); +} + +static int fwu_mtd_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary) +{ + struct fwu_mdata_mtd_priv *mtd_priv = dev_get_priv(dev); + struct mtd_info *mtd = mtd_priv->mtd; + u32 offs = primary ? mtd_priv->pri_offset : mtd_priv->sec_offset; + + return mtd_io_data(mtd, offs, sizeof(struct fwu_mdata), mdata, FWU_MTD_WRITE); +} + +static int flash_partition_offset(struct udevice *dev, const char *part_name, fdt_addr_t *offset) +{ + ofnode node, parts_node; + fdt_addr_t size = 0; + + parts_node = ofnode_by_compatible(dev_ofnode(dev), "fixed-partitions"); + node = ofnode_by_prop_value(parts_node, "label", part_name, strlen(part_name) + 1); + if (!ofnode_valid(node)) { + log_err("Warning: Failed to find partition by label <%s>\n", part_name); + return -ENOENT; + } + + *offset = ofnode_get_addr_size_index_notrans(node, 0, &size); + + return (int)size; +} + +static int fwu_mdata_mtd_of_to_plat(struct udevice *dev) +{ + struct fwu_mdata_mtd_priv *mtd_priv = dev_get_priv(dev); + const fdt32_t *phandle_p = NULL; + struct udevice *mtd_dev; + struct mtd_info *mtd; + const char *label; + fdt_addr_t offset; + int ret, size; + u32 phandle; + ofnode bank; + int off_img; + + /* Find the FWU mdata storage device */ + phandle_p = ofnode_get_property(dev_ofnode(dev), + "fwu-mdata-store", &size); + if (!phandle_p) { + log_err("FWU meta data store not defined in device-tree\n"); + return -ENOENT; + } + + phandle = fdt32_to_cpu(*phandle_p); + + ret = device_get_global_by_ofnode(ofnode_get_by_phandle(phandle), + &mtd_dev); + if (ret) { + log_err("FWU: failed to get mtd device\n"); + return ret; + } + + mtd_probe_devices(); + + mtd_for_each_device(mtd) { + if (mtd->dev == mtd_dev) { + mtd_priv->mtd = mtd; + log_debug("Found the FWU mdata mtd device %s\n", mtd->name); + break; + } + } + if (!mtd_priv->mtd) { + log_err("Failed to find mtd device by fwu-mdata-store\n"); + return -ENODEV; + } + + /* Get the offset of primary and seconday mdata */ + ret = ofnode_read_string_index(dev_ofnode(dev), "mdata-parts", 0, &label); + if (ret) + return ret; + strcpy(mtd_priv->pri_label, label); + + ret = flash_partition_offset(mtd_dev, mtd_priv->pri_label, &offset); + if (ret <= 0) + return ret; + mtd_priv->pri_offset = offset; + + ret = ofnode_read_string_index(dev_ofnode(dev), "mdata-parts", 1, &label); + if (ret) + return ret; + strcpy(mtd_priv->sec_label, label); + + ret = flash_partition_offset(mtd_dev, mtd_priv->sec_label, &offset); + if (ret <= 0) + return ret; + mtd_priv->sec_offset = offset; + + off_img = 0; + + ofnode_for_each_subnode(bank, dev_ofnode(dev)) { + int bank_num, bank_offset, bank_size; + const char *bank_name; + ofnode image; + + ofnode_read_u32(bank, "id", &bank_num); + bank_name = ofnode_read_string(bank, "label"); + bank_size = flash_partition_offset(mtd_dev, bank_name, &offset); + if (bank_size <= 0) + return bank_size; + bank_offset = offset; + log_debug("Bank%d: %s [0x%x - 0x%x]\n", + bank_num, bank_name, bank_offset, bank_offset + bank_size); + + ofnode_for_each_subnode(image, bank) { + int image_num, image_offset, image_size; + const char *uuid; + + if (off_img == CONFIG_FWU_NUM_BANKS * + CONFIG_FWU_NUM_IMAGES_PER_BANK) { + log_err("DT provides images more than configured!\n"); + break; + } + + uuid = ofnode_read_string(image, "uuid"); + ofnode_read_u32(image, "id", &image_num); + ofnode_read_u32(image, "offset", &image_offset); + ofnode_read_u32(image, "size", &image_size); + + fwu_mtd_images[off_img].start = bank_offset + image_offset; + fwu_mtd_images[off_img].size = image_size; + fwu_mtd_images[off_img].bank_num = bank_num; + fwu_mtd_images[off_img].image_num = image_num; + strcpy(fwu_mtd_images[off_img].uuidbuf, uuid); + log_debug("\tImage%d: %s @0x%x\n\n", + image_num, uuid, bank_offset + image_offset); + off_img++; + } + } + + return 0; +} + +static int fwu_mdata_mtd_probe(struct udevice *dev) +{ + /* Ensure the metadata can be read. */ + return fwu_get_mdata(NULL); +} + +static struct fwu_mdata_ops fwu_mtd_ops = { + .read_mdata = fwu_mtd_read_mdata, + .write_mdata = fwu_mtd_write_mdata, +}; + +static const struct udevice_id fwu_mdata_ids[] = { + { .compatible = "u-boot,fwu-mdata-mtd" }, + { } +}; + +U_BOOT_DRIVER(fwu_mdata_mtd) = { + .name = "fwu-mdata-mtd", + .id = UCLASS_FWU_MDATA, + .of_match = fwu_mdata_ids, + .ops = &fwu_mtd_ops, + .probe = fwu_mdata_mtd_probe, + .of_to_plat = fwu_mdata_mtd_of_to_plat, + .priv_auto = sizeof(struct fwu_mdata_mtd_priv), +};
+choice
- prompt "Storage Layout Scheme"
- depends on FWU_MDATA
- default FWU_MDATA_GPT_BLK
- config FWU_MDATA_GPT_BLK bool "FWU Metadata access for GPT partitioned Block devices" select PARTITION_TYPE_GUID
- bool "Raw MTD devices"
- depends on MTD
- help
MTD devices.
Just a note: Did you choose GPL-2.0+ by purpose? Or it is just c&p?
- Copyright (c) 2023, Linaro Limited
- struct mtd_info *mtd;
- char pri_label[50];
- char sec_label[50];
- u32 pri_offset;
- u32 sec_offset;
+enum fwu_mtd_op {
- FWU_MTD_READ,
- FWU_MTD_WRITE,
if there is a need to share it. It should go to header.
And fwu_mtd_images[] is not defined when only this patch is applied. It means order of patches is not right. 1/6 and 2/6 should be swapped
- return !do_div(size, mtd->erasesize);
enum fwu_mtd_op op)
- struct mtd_oob_ops io_op = {};
- u64 lock_offs, lock_len;
- size_t len;
- void *buf;
- int ret;
- if (!mtd_is_aligned_with_block_size(mtd, offs)) {
return -EINVAL;
- lock_offs = offs;
- /* This will expand erase size to align with the block size */
- lock_len = round_up(size, mtd->erasesize);
- ret = mtd_unlock(mtd, lock_offs, lock_len);
- if (ret && ret != -EOPNOTSUPP)
return ret;
- if (op == FWU_MTD_WRITE) {
erase_op.mtd = mtd;
erase_op.scrub = 0;
if (ret)
goto lock;
- /* Also, expand the write size to align with the write size */
- len = round_up(size, mtd->writesize);
- buf = memalign(ARCH_DMA_MINALIGN, len);
- if (!buf) {
ret = -ENOMEM;
goto lock;
- memset(buf, 0xff, len);
- io_op.mode = MTD_OPS_AUTO_OOB;
- io_op.len = len;
- io_op.ooblen = 0;
- io_op.datbuf = buf;
- io_op.oobbuf = NULL;
- } else {
if (!ret)
- free(buf);
+lock:
- mtd_lock(mtd, lock_offs, lock_len);
- return ret;
- struct fwu_mdata_mtd_priv *mtd_priv = dev_get_priv(dev);
- struct mtd_info *mtd = mtd_priv->mtd;
- u32 offs = primary ? mtd_priv->pri_offset : mtd_priv->sec_offset;
- return mtd_io_data(mtd, offs, sizeof(struct fwu_mdata), mdata, FWU_MTD_READ);
- return mtd_io_data(mtd, offs, sizeof(struct fwu_mdata), mdata, FWU_MTD_WRITE);
- ofnode node, parts_node;
- fdt_addr_t size = 0;
- parts_node = ofnode_by_compatible(dev_ofnode(dev), "fixed-partitions");
- node = ofnode_by_prop_value(parts_node, "label", part_name, strlen(part_name) + 1);
- if (!ofnode_valid(node)) {
return -ENOENT;
- *offset = ofnode_get_addr_size_index_notrans(node, 0, &size);
- return (int)size;
- const fdt32_t *phandle_p = NULL;
- struct udevice *mtd_dev;
- const char *label;
- fdt_addr_t offset;
- int ret, size;
- u32 phandle;
- ofnode bank;
- int off_img;
- /* Find the FWU mdata storage device */
- phandle_p = ofnode_get_property(dev_ofnode(dev),
- if (!phandle_p) {
return -ENOENT;
- phandle = fdt32_to_cpu(*phandle_p);
- ret = device_get_global_by_ofnode(ofnode_get_by_phandle(phandle),
&mtd_dev);
- if (ret) {
return ret;
- mtd_probe_devices();
- mtd_for_each_device(mtd) {
break;
- if (!mtd_priv->mtd) {
return -ENODEV;
- /* Get the offset of primary and seconday mdata */
typo
- ret = ofnode_read_string_index(dev_ofnode(dev), "mdata-parts", 0, &label);
- if (ret)
return ret;
- strcpy(mtd_priv->pri_label, label);
- ret = flash_partition_offset(mtd_dev, mtd_priv->pri_label, &offset);
- if (ret <= 0)
return ret;
- mtd_priv->pri_offset = offset;
- ret = ofnode_read_string_index(dev_ofnode(dev), "mdata-parts", 1, &label);
- if (ret)
return ret;
- strcpy(mtd_priv->sec_label, label);
- ret = flash_partition_offset(mtd_dev, mtd_priv->sec_label, &offset);
- if (ret <= 0)
return ret;
- mtd_priv->sec_offset = offset;
- off_img = 0;
- ofnode_for_each_subnode(bank, dev_ofnode(dev)) {
ofnode image;
if (bank_size <= 0)
return bank_size;
const char *uuid;
break;
off_img++;
- /* Ensure the metadata can be read. */
- return fwu_get_mdata(NULL);
- .read_mdata = fwu_mtd_read_mdata,
- .write_mdata = fwu_mtd_write_mdata,
- { .compatible = "u-boot,fwu-mdata-mtd" },
As I said this DT binding should be approved first to make sure that we don't need to fix DT binding in future. Just simply do it right from the begining.
Thanks, Michal
just c&p. though isn't that the same as GPL-2.0-or-later ?
include/fwu,h would be the header. Which is supposed to be very global, and doesn't seem very appropriate to mention private data shared between a driver and helper library. If people still insist, I will make the change.
I think 1 and 2 should be merged rather.
return -ENODEV;
typo
ok
Yes, I will cc Rob in the next submission (I only forgot last time). However, let us note that fwu-mdata-gpt.yaml isn't blessed either. I am not sure if there is any reason for the fwu node to even be in the dts for kernel. But sure it is good to have it eyeballed by the DT gods.
cheers.
license choice is up to you. We normally use just gpl-2.0.
no issue with it.
return -ENODEV;
typo
ok
It doesn't really go to kernel. Simon pushed options node directly to dt-schema https://github.com/devicetree-org/dt-schema/blob/main/dtschema/schemas/optio... And that would be also location for this node too.
Thanks, Michal
I think more than "we", the subsystem dictates licensing. All FWU code is under GPL-2.0-or-later.
Yes, but I have resend the already existisng bindings in uboot. My patch only modified them. Not a big problem.
-j
HI Jassi, Michal
Based on the discussion we had on the dt bindings, I am personally ok with the notion of having those defined internally until we can prove it makes sense for the to be sent to the dt-schema.
In the future we need to strip those from U-Boot, before we hand over the DR to the OS, but this is a problem that already exists regardless of this patchset.
Jassi, Michal had some review comments. Are you going to send a v5 with those fixed?
Thanks /Ilias
-j
Hi Ilias,
On 5/19/23 14:21, Ilias Apalodimas wrote:
HI Jassi, Michal
We created this patch for dt-schema and if there is no comment I will be sending it to Rob to get merge.
lore.kernel.org/r/ca0715934133dbce6a5a3fd91483e0af92ea8ac6.1683815597.git.michal.simek@amd.com
As I said I am fine with having it in u-boot tree only but that node has to be removed to pass certification. It means I would expect that we will solve it together not later on because it will catch us very quickly. If you have code in EFI to do that it, let's just do it together to be able to pass IR2.0 requirements without waiting for another patch.
Thanks, Michal
On Fri, May 19, 2023 at 02:45:26PM +0200, Michal Simek wrote:
Hi Ilias,
HI Jassi, Michal
So I think in sum, I think the path today is to see if Rob will accept that patch and if not, either rework based on feedback or if the feedback is "this is U-Boot centric atm, not appropriate" we'll go with the path of removing nodes before the OS gets the tree, which I think is a generic enough bit of framework that we'll need regardless, for 2.0.
Add helper functions needed for accessing the FWU metadata which contains information on the updatable images.
Signed-off-by: Masami Hiramatsu masami.hiramatsu@linaro.org Signed-off-by: Jassi Brar jaswinder.singh@linaro.org --- include/fwu.h | 34 ++++++++ lib/fwu_updates/Makefile | 1 + lib/fwu_updates/fwu_mtd.c | 164 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 199 insertions(+) create mode 100644 lib/fwu_updates/fwu_mtd.c
diff --git a/include/fwu.h b/include/fwu.h index 33b4d0b3db..117f51c4f5 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -8,6 +8,8 @@
#include <blk.h> #include <efi.h> +#include <mtd.h> +#include <uuid.h>
@@ -18,6 +20,12 @@ struct fwu_mdata_gpt_blk_priv { struct udevice *blk_dev; };
+struct fwu_mtd_image_info { + u32 start, size; + int bank_num, image_num; + char uuidbuf[UUID_STR_LEN + 1]; +}; + struct fwu_mdata_ops { /** * read_mdata() - Populate the asked FWU metadata copy @@ -251,4 +259,30 @@ u8 fwu_empty_capsule_checks_pass(void); */ int fwu_trial_state_ctr_start(void);
+/** + * fwu_gen_alt_info_from_mtd() - Parse dfu_alt_info from metadata in mtd + * @buf: Buffer into which the dfu_alt_info is filled + * @len: Maximum characters that can be written in buf + * @mtd: Pointer to underlying MTD device + * + * Parse dfu_alt_info from metadata in mtd. Used for setting the env. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_gen_alt_info_from_mtd(char *buf, size_t len, struct mtd_info *mtd); + +/** + * fwu_mtd_get_alt_num() - Mapping of fwu_plat_get_alt_num for MTD device + * @image_guid: Image GUID for which DFU alt number needs to be retrieved + * @alt_num: Pointer to the alt_num + * @mtd_dev: Name of mtd device instance + * + * To map fwu_plat_get_alt_num onto mtd based metadata implementation. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_mtd_get_alt_num(efi_guid_t *image_id, u8 *alt_num, const char *mtd_dev); + #endif /* _FWU_H_ */ diff --git a/lib/fwu_updates/Makefile b/lib/fwu_updates/Makefile index 1993088e5b..c9e3c06b48 100644 --- a/lib/fwu_updates/Makefile +++ b/lib/fwu_updates/Makefile @@ -5,3 +5,4 @@
obj-$(CONFIG_FWU_MULTI_BANK_UPDATE) += fwu.o obj-$(CONFIG_FWU_MDATA_GPT_BLK) += fwu_gpt.o +obj-$(CONFIG_FWU_MDATA_MTD) += fwu_mtd.o diff --git a/lib/fwu_updates/fwu_mtd.c b/lib/fwu_updates/fwu_mtd.c new file mode 100644 index 0000000000..c1d04e574b --- /dev/null +++ b/lib/fwu_updates/fwu_mtd.c @@ -0,0 +1,164 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2023, Linaro Limited + */ + +#include <dm.h> +#include <dfu.h> +#include <fwu.h> +#include <fwu_mdata.h> +#include <log.h> +#include <malloc.h> +#include <mtd.h> +#include <uuid.h> +#include <vsprintf.h> + +#include <dm/ofnode.h> + +struct fwu_mtd_image_info +fwu_mtd_images[CONFIG_FWU_NUM_BANKS * CONFIG_FWU_NUM_IMAGES_PER_BANK]; + +static struct fwu_mtd_image_info *mtd_img_by_uuid(const char *uuidbuf) +{ + int num_images = sizeof(fwu_mtd_images) / sizeof(struct fwu_mtd_image_info); + + for (int i = 0; i < num_images; i++) + if (!strcmp(uuidbuf, fwu_mtd_images[i].uuidbuf)) + return &fwu_mtd_images[i]; + + return NULL; +} + +int fwu_mtd_get_alt_num(efi_guid_t *image_id, u8 *alt_num, + const char *mtd_dev) +{ + int i, nalt; + int ret = -1; + struct mtd_info *mtd; + struct dfu_entity *dfu; + fdt_addr_t offset, size = 0; + char uuidbuf[UUID_STR_LEN + 1]; + struct fwu_mtd_image_info *mtd_img_info; + + mtd_probe_devices(); + mtd = get_mtd_device_nm(mtd_dev); + + uuid_bin_to_str(image_id->b, uuidbuf, UUID_STR_FORMAT_STD); + + mtd_img_info = mtd_img_by_uuid(uuidbuf); + if (!mtd_img_info) { + log_err("%s: Not found partition for image %s\n", __func__, uuidbuf); + return -ENOENT; + } + offset = mtd_img_info->start; + size = mtd_img_info->size; + + dfu_init_env_entities(NULL, NULL); + + nalt = 0; + list_for_each_entry(dfu, &dfu_list, list) + nalt++; + + if (!nalt) { + log_warning("No entities in dfu_alt_info\n"); + dfu_free_entities(); + return -ENOENT; + } + + for (i = 0; i < nalt; i++) { + dfu = dfu_get_entity(i); + + /* Only MTD RAW access */ + if (!dfu || dfu->dev_type != DFU_DEV_MTD || + dfu->layout != DFU_RAW_ADDR || + dfu->data.mtd.start != offset || + dfu->data.mtd.size != size) + continue; + + *alt_num = dfu->alt; + ret = 0; + break; + } + + dfu_free_entities(); + + log_debug("%s: %s -> %d\n", __func__, uuidbuf, *alt_num); + return ret; +} + +static int gen_image_alt_info(char *buf, size_t len, int sidx, + struct fwu_image_entry *img, struct mtd_info *mtd) +{ + int i; + char *p = buf, *end = buf + len; + + p += snprintf(p, end - p, "mtd %s", mtd->name); + if (end < p) { + log_err("%s:%d Run out of buffer\n", __func__, __LINE__); + return -E2BIG; + } + + /* + * List the image banks in the FWU mdata and search the corresponding + * partition based on partition's uuid. + */ + for (i = 0; i < CONFIG_FWU_NUM_BANKS; i++) { + struct fwu_mtd_image_info *mtd_img_info; + struct fwu_image_bank_info *bank; + char uuidbuf[UUID_STR_LEN + 1]; + u32 offset, size; + + /* Query a partition by image UUID */ + bank = &img->img_bank_info[i]; + uuid_bin_to_str(bank->image_uuid.b, uuidbuf, UUID_STR_FORMAT_STD); + + mtd_img_info = mtd_img_by_uuid(uuidbuf); + if (!mtd_img_info) { + log_err("%s: Not found partition for image %s\n", __func__, uuidbuf); + break; + } + + offset = mtd_img_info->start; + size = mtd_img_info->size; + + p += snprintf(p, end - p, "%sbank%d raw %x %x", + i == 0 ? "=" : ";", i, offset, size); + if (end < p) { + log_err("%s:%d Run out of buffer\n", __func__, __LINE__); + return -E2BIG; + } + } + + if (i == CONFIG_FWU_NUM_BANKS) + return 0; + + return -ENOENT; +} + +int fwu_gen_alt_info_from_mtd(char *buf, size_t len, struct mtd_info *mtd) +{ + struct fwu_mdata mdata; + int i, l, ret; + + ret = fwu_get_mdata(&mdata); + if (ret < 0) { + log_err("Failed to get the FWU mdata.\n"); + return ret; + } + + for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) { + ret = gen_image_alt_info(buf, len, i * CONFIG_FWU_NUM_BANKS, + &mdata.img_entry[i], mtd); + if (ret) + break; + + l = strlen(buf); + /* Replace the last ';' with '&' if there is another image. */ + if (i != CONFIG_FWU_NUM_IMAGES_PER_BANK - 1 && l) + buf[l - 1] = '&'; + len -= l; + buf += l; + } + + return ret; +}
- u32 start, size;
- int bank_num, image_num;
- char uuidbuf[UUID_STR_LEN + 1];
- struct fwu_mdata_ops { /**
- read_mdata() - Populate the asked FWU metadata copy
- fwu_gen_alt_info_from_mtd() - Parse dfu_alt_info from metadata in mtd
- @buf: Buffer into which the dfu_alt_info is filled
- @len: Maximum characters that can be written in buf
- @mtd: Pointer to underlying MTD device
- Parse dfu_alt_info from metadata in mtd. Used for setting the env.
- Return: 0 if OK, -ve on error
nit: remove this line above.
- fwu_mtd_get_alt_num() - Mapping of fwu_plat_get_alt_num for MTD device
- @image_guid: Image GUID for which DFU alt number needs to be retrieved
it doesn't match with parameter below.
- @alt_num: Pointer to the alt_num
- @mtd_dev: Name of mtd device instance
- To map fwu_plat_get_alt_num onto mtd based metadata implementation.
./scripts/kernel-doc -v -man include/fwu.h 1>/dev/null
include/fwu.h:276: info: Scanning doc for fwu_mtd_get_alt_num include/fwu.h:286: warning: Function parameter or member 'image_id' not described in 'fwu_mtd_get_alt_num' include/fwu.h:286: warning: Excess function parameter 'image_guid' description in 'fwu_mtd_get_alt_num'
(In general this file has other kernel-doc issues which should be fixed too)
- #endif /* _FWU_H_ */
- int num_images = sizeof(fwu_mtd_images) / sizeof(struct fwu_mtd_image_info);
include/linux/kernel.h:55:#define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0]))
- for (int i = 0; i < num_images; i++)
- return NULL;
- int i, nalt;
- int ret = -1;
nit: can be on the same line.
- struct dfu_entity *dfu;
- fdt_addr_t offset, size = 0;
- struct fwu_mtd_image_info *mtd_img_info;
nit: reverse christmas tree order
- mtd = get_mtd_device_nm(mtd_dev);
you are getting link but you are not using it anywhere. You should check return value or remove this call completely.
- uuid_bin_to_str(image_id->b, uuidbuf, UUID_STR_FORMAT_STD);
- mtd_img_info = mtd_img_by_uuid(uuidbuf);
- if (!mtd_img_info) {
return -ENOENT;
nit: newline
- offset = mtd_img_info->start;
- size = mtd_img_info->size;
- dfu_init_env_entities(NULL, NULL);
worth to check return value here.
M
ok
ok
ok
ok
of course. thanks.
int i, nalt;
int ret = -1;
ok
ok
This should go. thanks.
return -ENOENT;
nit: newline
ok
ok, though it would also cleanly fail immediately after this call when it find empty dfu_list.
Thanks.
Add 'mkfwumdata' tool to generate FWU metadata image for the meta-data partition to be used in A/B Update imeplementation.
Signed-off-by: Masami Hiramatsu masami.hiramatsu@linaro.org Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Signed-off-by: Jassi Brar jaswinder.singh@linaro.org --- tools/Kconfig | 9 ++ tools/Makefile | 4 + tools/mkfwumdata.c | 334 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 347 insertions(+) create mode 100644 tools/mkfwumdata.c
diff --git a/tools/Kconfig b/tools/Kconfig index 539708f277..6e23f44d55 100644 --- a/tools/Kconfig +++ b/tools/Kconfig @@ -157,4 +157,13 @@ config LUT_SEQUENCE help Look Up Table Sequence
+config TOOLS_MKFWUMDATA + bool "Build mkfwumdata command" + default y if FWU_MULTI_BANK_UPDATE + help + This command allows users to create a raw image of the FWU + metadata for initial installation of the FWU multi bank + update on the board. The installation method depends on + the platform. + endmenu diff --git a/tools/Makefile b/tools/Makefile index e13effbb66..80eee71505 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -247,6 +247,10 @@ HOSTLDLIBS_mkeficapsule += \ $(shell pkg-config --libs uuid 2> /dev/null || echo "-luuid") hostprogs-$(CONFIG_TOOLS_MKEFICAPSULE) += mkeficapsule
+mkfwumdata-objs := mkfwumdata.o lib/crc32.o +HOSTLDLIBS_mkfwumdata += -luuid +hostprogs-$(CONFIG_TOOLS_MKFWUMDATA) += mkfwumdata + # We build some files with extra pedantic flags to try to minimize things # that won't build on some weird host compiler -- though there are lots of # exceptions for files that aren't complaint. diff --git a/tools/mkfwumdata.c b/tools/mkfwumdata.c new file mode 100644 index 0000000000..43dabf3b72 --- /dev/null +++ b/tools/mkfwumdata.c @@ -0,0 +1,334 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2023, Linaro Limited + */ + +#include <errno.h> +#include <getopt.h> +#include <limits.h> +#include <stdio.h> +#include <stdint.h> +#include <stdlib.h> +#include <string.h> +#include <u-boot/crc.h> +#include <unistd.h> +#include <uuid/uuid.h> + +/* This will dynamically allocate the fwu_mdata */ +#define CONFIG_FWU_NUM_BANKS 0 +#define CONFIG_FWU_NUM_IMAGES_PER_BANK 0 + +/* Since we can not include fwu.h, redefine version here. */ +#define FWU_MDATA_VERSION 1 + +typedef uint8_t u8; +typedef int16_t s16; +typedef uint16_t u16; +typedef uint32_t u32; +typedef uint64_t u64; + +#include <fwu_mdata.h> + +/* TODO: Endianness conversion may be required for some arch. */ + +static const char *opts_short = "b:i:a:p:gh"; + +static struct option options[] = { + {"banks", required_argument, NULL, 'b'}, + {"images", required_argument, NULL, 'i'}, + {"guid", required_argument, NULL, 'g'}, + {"active-bank", required_argument, NULL, 'a'}, + {"previous-bank", required_argument, NULL, 'p'}, + {"help", no_argument, NULL, 'h'}, + {NULL, 0, NULL, 0}, +}; + +static void print_usage(void) +{ + fprintf(stderr, "Usage: mkfwumdata [options] <UUIDs list> <output file>\n"); + fprintf(stderr, "Options:\n" + "\t-i, --images <num> Number of images\n" + "\t-b, --banks <num> Number of banks\n" + "\t-a, --active-bank <num> Active bank\n" + "\t-p, --previous-bank <num> Previous active bank\n" + "\t-g, --guid Use GUID instead of UUID\n" + "\t-h, --help print a help message\n" + ); + fprintf(stderr, " UUIDs list syntax:\n" + "\t <location uuid>,<image type uuid>,<images uuid list>\n" + "\t images uuid list syntax:\n" + "\t img_uuid_00,img_uuid_01...img_uuid_0b,\n" + "\t img_uuid_10,img_uuid_11...img_uuid_1b,\n" + "\t ...,\n" + "\t img_uuid_i0,img_uuid_i1...img_uuid_ib,\n" + "\t where 'b' and 'i' are number of banks and number\n" + "\t of images in a bank respectively.\n" + ); +} + +struct fwu_mdata_object { + size_t images; + size_t banks; + size_t size; + struct fwu_mdata *mdata; +}; + +static int previous_bank, active_bank; +static bool __use_guid; + +static struct fwu_mdata_object *fwu_alloc_mdata(size_t images, size_t banks) +{ + struct fwu_mdata_object *mobj; + + mobj = calloc(1, sizeof(*mobj)); + if (!mobj) + return NULL; + + mobj->size = sizeof(struct fwu_mdata) + + (sizeof(struct fwu_image_entry) + + sizeof(struct fwu_image_bank_info) * banks) * images; + mobj->images = images; + mobj->banks = banks; + + mobj->mdata = calloc(1, mobj->size); + if (!mobj->mdata) { + free(mobj); + return NULL; + } + + return mobj; +} + +static struct fwu_image_entry * +fwu_get_image(struct fwu_mdata_object *mobj, size_t idx) +{ + size_t offset; + + offset = sizeof(struct fwu_mdata) + + (sizeof(struct fwu_image_entry) + + sizeof(struct fwu_image_bank_info) * mobj->banks) * idx; + + return (struct fwu_image_entry *)((char *)mobj->mdata + offset); +} + +static struct fwu_image_bank_info * +fwu_get_bank(struct fwu_mdata_object *mobj, size_t img_idx, size_t bnk_idx) +{ + size_t offset; + + offset = sizeof(struct fwu_mdata) + + (sizeof(struct fwu_image_entry) + + sizeof(struct fwu_image_bank_info) * mobj->banks) * img_idx + + sizeof(struct fwu_image_entry) + + sizeof(struct fwu_image_bank_info) * bnk_idx; + + return (struct fwu_image_bank_info *)((char *)mobj->mdata + offset); +} + +/** + * convert_uuid_to_guid() - convert UUID to GUID + * @buf: UUID binary + * + * UUID and GUID have the same data structure, but their binary + * formats are different due to the endianness. See lib/uuid.c. + * Since uuid_parse() can handle only UUID, this function must + * be called to get correct data for GUID when parsing a string. + * + * The correct data will be returned in @buf. + */ +static void convert_uuid_to_guid(unsigned char *buf) +{ + unsigned char c; + + c = buf[0]; + buf[0] = buf[3]; + buf[3] = c; + c = buf[1]; + buf[1] = buf[2]; + buf[2] = c; + + c = buf[4]; + buf[4] = buf[5]; + buf[5] = c; + + c = buf[6]; + buf[6] = buf[7]; + buf[7] = c; +} + +static int uuid_guid_parse(char *uuidstr, unsigned char *uuid) +{ + int ret; + + ret = uuid_parse(uuidstr, uuid); + if (ret < 0) + return ret; + + if (__use_guid) + convert_uuid_to_guid(uuid); + + return ret; +} + +static int +fwu_parse_fill_image_uuid(struct fwu_mdata_object *mobj, + size_t idx, char *uuids) +{ + struct fwu_image_entry *image = fwu_get_image(mobj, idx); + struct fwu_image_bank_info *bank; + char *p = uuids, *uuid; + int i; + + if (!image) + return -ENOENT; + + /* Image location UUID */ + uuid = strsep(&p, ","); + if (!uuid) + return -EINVAL; + + if (strcmp(uuid, "0") && + uuid_guid_parse(uuid, (unsigned char *)&image->location_uuid) < 0) + return -EINVAL; + + /* Image type UUID */ + uuid = strsep(&p, ","); + if (!uuid) + return -EINVAL; + + if (uuid_guid_parse(uuid, (unsigned char *)&image->image_type_uuid) < 0) + return -EINVAL; + + /* Fill bank image-UUID */ + for (i = 0; i < mobj->banks; i++) { + bank = fwu_get_bank(mobj, idx, i); + if (!bank) + return -ENOENT; + bank->accepted = 1; + uuid = strsep(&p, ","); + if (!uuid) + return -EINVAL; + + if (strcmp(uuid, "0") && + uuid_guid_parse(uuid, (unsigned char *)&bank->image_uuid) < 0) + return -EINVAL; + } + return 0; +} + +/* Caller must ensure that @uuids[] has @mobj->images entries. */ +static int fwu_parse_fill_uuids(struct fwu_mdata_object *mobj, char *uuids[]) +{ + struct fwu_mdata *mdata = mobj->mdata; + int i, ret; + + mdata->version = FWU_MDATA_VERSION; + mdata->active_index = active_bank; + mdata->previous_active_index = previous_bank; + + for (i = 0; i < mobj->images; i++) { + ret = fwu_parse_fill_image_uuid(mobj, i, uuids[i]); + if (ret < 0) + return ret; + } + + mdata->crc32 = crc32(0, (const unsigned char *)&mdata->version, + mobj->size - sizeof(uint32_t)); + + return 0; +} + +static int +fwu_make_mdata(size_t images, size_t banks, char *uuids[], char *output) +{ + struct fwu_mdata_object *mobj; + FILE *file; + int ret; + + mobj = fwu_alloc_mdata(images, banks); + if (!mobj) + return -ENOMEM; + + ret = fwu_parse_fill_uuids(mobj, uuids); + if (ret < 0) + goto done_make; + + file = fopen(output, "w"); + if (!file) { + ret = -errno; + goto done_make; + } + + ret = fwrite(mobj->mdata, mobj->size, 1, file); + if (ret != mobj->size) + ret = -errno; + else + ret = 0; + + fclose(file); + +done_make: + free(mobj->mdata); + free(mobj); + + return ret; +} + +int main(int argc, char *argv[]) +{ + unsigned long banks = 0, images = 0; + int c, ret; + + /* Explicitly initialize defaults */ + active_bank = 0; + __use_guid = false; + previous_bank = INT_MAX; + + do { + c = getopt_long(argc, argv, opts_short, options, NULL); + switch (c) { + case 'h': + print_usage(); + return 0; + case 'b': + banks = strtoul(optarg, NULL, 0); + break; + case 'i': + images = strtoul(optarg, NULL, 0); + break; + case 'g': + __use_guid = true; + break; + case 'p': + previous_bank = strtoul(optarg, NULL, 0); + break; + case 'a': + active_bank = strtoul(optarg, NULL, 0); + break; + } + } while (c != -1); + + if (!banks || !images) { + fprintf(stderr, "Error: The number of banks and images must not be 0.\n"); + return -EINVAL; + } + + /* This command takes UUIDs * images and output file. */ + if (optind + images + 1 != argc) { + fprintf(stderr, "Error: UUID list or output file is not specified or too much.\n"); + print_usage(); + return -ERANGE; + } + + if (previous_bank == INT_MAX) { + /* set to the earlier bank in round-robin scheme */ + previous_bank = active_bank > 0 ? active_bank - 1 : banks - 1; + } + + ret = fwu_make_mdata(images, banks, argv + optind, argv[argc - 1]); + if (ret < 0) + fprintf(stderr, "Error: Failed to parse and write image: %s\n", + strerror(-ret)); + + return ret; +}
- bool "Build mkfwumdata command"
- default y if FWU_MULTI_BANK_UPDATE
- help
the platform.
- endmenu
- # We build some files with extra pedantic flags to try to minimize things # that won't build on some weird host compiler -- though there are lots of # exceptions for files that aren't complaint.
These two are completely unused.
Thanks, Michal
these are necessary for include/fwu_mdata.h that comes later.
cheers.
If that's come later, add it later.
M
Can you please actually look at the code to see the underlying constraint?
-j
Ok. I misunderstand your comment.
You have it there because of #include <fwu_mdata.h> and using macros there. Can you just allocated that structures at run time instead of statically defined them via array? That would clean that design and also fix checkpatch issue.
Thanks, Michal
$ ./scripts/checkpatch.pl -f tools/mkfwumdata.c ERROR: All CONFIG symbols are managed by Kconfig #18: FILE: tools/mkfwumdata.c:18: +#define CONFIG_FWU_NUM_BANKS 0
ERROR: All CONFIG symbols are managed by Kconfig #19: FILE: tools/mkfwumdata.c:19: +#define CONFIG_FWU_NUM_IMAGES_PER_BANK 0
total: 2 errors, 0 warnings, 0 checks, 334 lines checked
I can't see how dynamically allocating an array of packed structures inside an array of packed structures , makes the design any cleaner.
I think this is a valid case where we can ignore the checkpatch warning because we know what we are doing.
-jassi
> + > +/* This will dynamically allocate the fwu_mdata */ > +#define CONFIG_FWU_NUM_BANKS 0 > +#define CONFIG_FWU_NUM_IMAGES_PER_BANK 0
It is not marked as __packed and based on what you are saying it should be marked like that.
I will let maintainer, who will merge this code, to decide on this. I would at least make that comment much bigger to explain it better that you are doing it because you don't want to redefine structures from fwu_mdata.h.
Thanks, Michal
>> + >> +/* This will dynamically allocate the fwu_mdata */ >> +#define CONFIG_FWU_NUM_BANKS 0 >> +#define CONFIG_FWU_NUM_IMAGES_PER_BANK 0 > > These two are completely unused. > these are necessary for include/fwu_mdata.h that comes later.
Those structures already existed before my patchset. And I definitely remember they were suggested to be marked as packed but were not. So now you have to read to code to understand what they are.
you mean redeclare, right? That is what the two define's do effectively.
-j
Can you please look at putting this in binman instead, since we would rather not have another tool with no tests.
Must I do that? I have no history with binman and it seems the mkfwumdata.c would need to be rewritten in python?
regards.
I think it is about calling this utility from python not about rewriting it to python.
M
Yes that's the question. If this tool is for creating firmware updates, then how are they created? I would expect binman to handle this when U-Boot is built. Then you can build in some tests in binman perhaps?
How does one know what parameters to pass? Is the documentation for this tool elsewhere? Where are the tests?
It is also unfortunate that this seems to be inventing yet another format (I recall that FIP was invented at one point also), when it could use FIT.
The FWU meta-data format is specified in a standards document created by ARM and not tied to u-boot. U-Boot may not necessarily be the bootloader using the output of mkfwumdata. The u-boot/tools/ is more like a welcoming host.
Ideally mkfwumdata should be a reference implementation, also created by ARM. But it is trivial enough that nobody thought there could be any confusion about the format, I guess.
In the latest submission I also created a man-page for it.
I am open to learning what could be tested and how.
Hopefully it won't be that bad of a predicament after my explanation above.
cheers.
Hi Jassi,
OK
Good
Well normally we would have a binman test which uses the tool to create an image, then checks that it works. See ftest.py for some examples.
Am 27. März 2023 23:16:10 MESZ schrieb jassisinghbrar@gmail.com:
For each command line tool there should be a man-page.
- help
the platform.
Does the update work without UEFI? UEFI requires low endianness.
- {"banks", required_argument, NULL, 'b'},
- {"images", required_argument, NULL, 'i'},
- {"guid", required_argument, NULL, 'g'},
- {"active-bank", required_argument, NULL, 'a'},
- {"previous-bank", required_argument, NULL, 'p'},
- {"help", no_argument, NULL, 'h'},
- {NULL, 0, NULL, 0},
- fprintf(stderr, "Usage: mkfwumdata [options] <UUIDs list> <output file>\n");
- fprintf(stderr, "Options:\n"
I would not know what this means.
Why can't you supply that single GUID in the position of the UUIDs parameter?
Best regards
Heinrich
- fprintf(stderr, " UUIDs list syntax:\n"
"\t ...,\n"
- size_t images;
- size_t banks;
- size_t size;
- struct fwu_mdata *mdata;
- struct fwu_mdata_object *mobj;
- mobj = calloc(1, sizeof(*mobj));
- if (!mobj)
return NULL;
- mobj->size = sizeof(struct fwu_mdata) +
- mobj->images = images;
- mobj->banks = banks;
- mobj->mdata = calloc(1, mobj->size);
- if (!mobj->mdata) {
free(mobj);
return NULL;
- return mobj;
- size_t offset;
- offset = sizeof(struct fwu_mdata) +
- return (struct fwu_image_entry *)((char *)mobj->mdata + offset);
- size_t offset;
- return (struct fwu_image_bank_info *)((char *)mobj->mdata + offset);
- convert_uuid_to_guid() - convert UUID to GUID
- @buf: UUID binary
- UUID and GUID have the same data structure, but their binary
- formats are different due to the endianness. See lib/uuid.c.
- Since uuid_parse() can handle only UUID, this function must
- be called to get correct data for GUID when parsing a string.
- The correct data will be returned in @buf.
- unsigned char c;
- c = buf[0];
- buf[0] = buf[3];
- buf[3] = c;
- c = buf[1];
- buf[1] = buf[2];
- buf[2] = c;
- c = buf[4];
- buf[4] = buf[5];
- buf[5] = c;
- c = buf[6];
- buf[6] = buf[7];
- buf[7] = c;
- int ret;
- ret = uuid_parse(uuidstr, uuid);
- if (ret < 0)
return ret;
- if (__use_guid)
- return ret;
- struct fwu_image_entry *image = fwu_get_image(mobj, idx);
- struct fwu_image_bank_info *bank;
- char *p = uuids, *uuid;
- int i;
- if (!image)
return -ENOENT;
- /* Image location UUID */
- uuid = strsep(&p, ",");
- if (!uuid)
return -EINVAL;
- if (strcmp(uuid, "0") &&
return -EINVAL;
- /* Image type UUID */
- if (!uuid)
return -EINVAL;
- if (uuid_guid_parse(uuid, (unsigned char *)&image->image_type_uuid) < 0)
return -EINVAL;
- /* Fill bank image-UUID */
- for (i = 0; i < mobj->banks; i++) {
if (!bank)
return -ENOENT;
bank->accepted = 1;
if (!uuid)
return -EINVAL;
return -EINVAL;
- struct fwu_mdata *mdata = mobj->mdata;
- int i, ret;
- mdata->version = FWU_MDATA_VERSION;
- mdata->active_index = active_bank;
- mdata->previous_active_index = previous_bank;
- for (i = 0; i < mobj->images; i++) {
if (ret < 0)
return ret;
- mdata->crc32 = crc32(0, (const unsigned char *)&mdata->version,
- FILE *file;
- int ret;
- mobj = fwu_alloc_mdata(images, banks);
- if (!mobj)
return -ENOMEM;
- ret = fwu_parse_fill_uuids(mobj, uuids);
- if (ret < 0)
goto done_make;
- file = fopen(output, "w");
- if (!file) {
ret = -errno;
goto done_make;
- ret = fwrite(mobj->mdata, mobj->size, 1, file);
- if (ret != mobj->size)
ret = -errno;
- else
ret = 0;
- fclose(file);
+done_make:
- free(mobj->mdata);
- free(mobj);
- return ret;
- unsigned long banks = 0, images = 0;
- int c, ret;
- /* Explicitly initialize defaults */
- active_bank = 0;
- __use_guid = false;
- previous_bank = INT_MAX;
- do {
switch (c) {
case 'h':
print_usage();
case 'b':
break;
case 'i':
break;
case 'g':
__use_guid = true;
break;
case 'p':
break;
case 'a':
break;
- } while (c != -1);
- if (!banks || !images) {
return -EINVAL;
- /* This command takes UUIDs * images and output file. */
- if (optind + images + 1 != argc) {
print_usage();
return -ERANGE;
- if (previous_bank == INT_MAX) {
- ret = fwu_make_mdata(images, banks, argv + optind, argv[argc - 1]);
- if (ret < 0)
strerror(-ret));
- return ret;
ok
Not sure what you mean. This only creates a meta-data image that goes into some offset in mtd.
I guess the original authors wanted to have one explicitly specify what's going on, rather than 'hacking' around (?)
thanks
Specify Bank-0/1 and fwu metadata mtd regions.
Signed-off-by: Jassi Brar jaswinder.singh@linaro.org --- .../synquacer-sc2a11-developerbox-u-boot.dtsi | 49 +++++++++++++++++-- 1 file changed, 46 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/synquacer-sc2a11-developerbox-u-boot.dtsi b/arch/arm/dts/synquacer-sc2a11-developerbox-u-boot.dtsi index 9f9837b33b..9957646a46 100644 --- a/arch/arm/dts/synquacer-sc2a11-developerbox-u-boot.dtsi +++ b/arch/arm/dts/synquacer-sc2a11-developerbox-u-boot.dtsi @@ -21,7 +21,7 @@ #size-cells = <0>; status = "okay";
- flash@0 { + flash0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; @@ -74,8 +74,24 @@ };
partition@500000 { - label = "Ex-OPTEE"; - reg = <0x500000 0x200000>; + label = "MDATA-Pri"; + reg = <0x500000 0x1000>; + }; + + partition@530000 { + label = "MDATA-Sec"; + reg = <0x530000 0x1000>; + }; + + /* FWU Multi bank update partitions */ + partition@600000 { + label = "FIP-Bank0"; + reg = <0x600000 0x400000>; + }; + + partition@a00000 { + label = "FIP-Bank1"; + reg = <0xa00000 0x400000>; }; }; }; @@ -102,6 +118,33 @@ optee { status = "okay"; }; + + fwu-mdata { + compatible = "u-boot,fwu-mdata-mtd"; + fwu-mdata-store = <&flash0>; + mdata-parts = "MDATA-Pri", "MDATA-Sec"; + + fwu-bank0 { + id = <0>; + label = "FIP-Bank0"; + fwu-image0 { + id = <0>; + offset = <0x0>; + size = <0x400000>; + uuid = "5a66a702-99fd-4fef-a392-c26e261a2828"; + }; + }; + fwu-bank1 { + id = <1>; + label = "FIP-Bank1"; + fwu-image0 { + id = <0>; + offset = <0x0>; + size = <0x400000>; + uuid = "a8f868a1-6e5c-4757-878d-ce63375ef2c0"; + }; + }; + }; }; };
flash@0 {
partition@500000 {
label = "Ex-OPTEE";
partition@530000 {
partition@600000 {
partition@a00000 {
};reg = <0xa00000 0x400000>; }; };
fwu-mdata {
As I discussed this with Ilias today. This should be approved or this DT won't pass yaml checking for SR certification. That's why this should get to schema to be able to widely use.
Thanks, Michal
Towards enabling FWU and supporting new firmware layout in NOR flash, make u-boot PIC and adjust uboot env offset in flash.
Signed-off-by: Jassi Brar jaswinder.singh@linaro.org --- configs/synquacer_developerbox_defconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/configs/synquacer_developerbox_defconfig b/configs/synquacer_developerbox_defconfig index 08f19a90cb..09e12b739b 100644 --- a/configs/synquacer_developerbox_defconfig +++ b/configs/synquacer_developerbox_defconfig @@ -1,12 +1,12 @@ CONFIG_ARM=y CONFIG_ARCH_SYNQUACER=y -CONFIG_TEXT_BASE=0x08200000 +CONFIG_POSITION_INDEPENDENT=y CONFIG_SYS_MALLOC_LEN=0x1000000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xe0000000 CONFIG_ENV_SIZE=0x30000 -CONFIG_ENV_OFFSET=0x300000 +CONFIG_ENV_OFFSET=0x580000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="synquacer-sc2a11-developerbox"
Add code to support FWU_MULTI_BANK_UPDATE. The platform does not have gpt-partition storage for Banks and MetaData, rather it used SPI-NOR backed mtd regions for the purpose.
Signed-off-by: Jassi Brar jaswinder.singh@linaro.org --- board/socionext/developerbox/Makefile | 1 + board/socionext/developerbox/developerbox.c | 8 + board/socionext/developerbox/fwu_plat.c | 57 +++++++ configs/synquacer_developerbox_defconfig | 8 + doc/board/socionext/developerbox.rst | 155 +++++++++++++++++++- include/configs/synquacer.h | 10 ++ 6 files changed, 233 insertions(+), 6 deletions(-) create mode 100644 board/socionext/developerbox/fwu_plat.c
diff --git a/board/socionext/developerbox/Makefile b/board/socionext/developerbox/Makefile index 4a46de995a..1acd067a7e 100644 --- a/board/socionext/developerbox/Makefile +++ b/board/socionext/developerbox/Makefile @@ -7,3 +7,4 @@ #
obj-y := developerbox.o +obj-$(CONFIG_FWU_MDATA_MTD) += fwu_plat.o diff --git a/board/socionext/developerbox/developerbox.c b/board/socionext/developerbox/developerbox.c index 16e14d4f7f..ce2cccf4f0 100644 --- a/board/socionext/developerbox/developerbox.c +++ b/board/socionext/developerbox/developerbox.c @@ -20,6 +20,13 @@
#if IS_ENABLED(CONFIG_EFI_HAVE_CAPSULE_SUPPORT) struct efi_fw_image fw_images[] = { +#if CONFIG_IS_ENABLED(FWU_MULTI_BANK_UPDATE) + { + .image_type_id = DEVELOPERBOX_FIP_IMAGE_GUID, + .fw_name = u"DEVELOPERBOX-FIP", + .image_index = 1, + }, +#else { .image_type_id = DEVELOPERBOX_UBOOT_IMAGE_GUID, .fw_name = u"DEVELOPERBOX-UBOOT", @@ -35,6 +42,7 @@ struct efi_fw_image fw_images[] = { .fw_name = u"DEVELOPERBOX-OPTEE", .image_index = 3, }, +#endif };
struct efi_capsule_update_info update_info = { diff --git a/board/socionext/developerbox/fwu_plat.c b/board/socionext/developerbox/fwu_plat.c new file mode 100644 index 0000000000..29b258f86c --- /dev/null +++ b/board/socionext/developerbox/fwu_plat.c @@ -0,0 +1,57 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2023, Linaro Limited + */ + +#include <efi_loader.h> +#include <fwu.h> +#include <fwu_mdata.h> +#include <memalign.h> +#include <mtd.h> + +#define DFU_ALT_BUF_LEN 256 + +/* Generate dfu_alt_info from partitions */ +void set_dfu_alt_info(char *interface, char *devstr) +{ + int ret; + struct mtd_info *mtd; + + ALLOC_CACHE_ALIGN_BUFFER(char, buf, DFU_ALT_BUF_LEN); + memset(buf, 0, sizeof(buf)); + + mtd_probe_devices(); + + mtd = get_mtd_device_nm("nor1"); + if (IS_ERR_OR_NULL(mtd)) + return; + + ret = fwu_gen_alt_info_from_mtd(buf, DFU_ALT_BUF_LEN, mtd); + if (ret < 0) { + log_err("Error: Failed to generate dfu_alt_info. (%d)\n", ret); + return; + } + log_debug("Make dfu_alt_info: '%s'\n", buf); + + env_set("dfu_alt_info", buf); +} + +int fwu_plat_get_alt_num(struct udevice __always_unused *dev, + efi_guid_t *image_id, u8 *alt_num) +{ + return fwu_mtd_get_alt_num(image_id, alt_num, "nor1"); +} + +void fwu_plat_get_bootidx(uint *boot_idx) +{ + int ret; + u32 active_idx; + u32 *bootidx = boot_idx; + + ret = fwu_get_active_index(&active_idx); + + if (ret < 0) + *bootidx = -1; + + *bootidx = active_idx; +} diff --git a/configs/synquacer_developerbox_defconfig b/configs/synquacer_developerbox_defconfig index 09e12b739b..d09684153a 100644 --- a/configs/synquacer_developerbox_defconfig +++ b/configs/synquacer_developerbox_defconfig @@ -97,3 +97,11 @@ CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_IGNORE_OSINDICATIONS=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_SECURE_BOOT=y +CONFIG_FWU_MULTI_BANK_UPDATE=y +CONFIG_FWU_MDATA=y +CONFIG_FWU_MDATA_MTD=y +CONFIG_FWU_NUM_BANKS=2 +CONFIG_FWU_NUM_IMAGES_PER_BANK=1 +CONFIG_CMD_FWU_METADATA=y +CONFIG_TOOLS_MKFWUMDATA=y diff --git a/doc/board/socionext/developerbox.rst b/doc/board/socionext/developerbox.rst index 2d943c23be..908d3a7e6f 100644 --- a/doc/board/socionext/developerbox.rst +++ b/doc/board/socionext/developerbox.rst @@ -57,14 +57,20 @@ Installation
You can install the SNI_NOR_UBOOT.fd via NOR flash writer.
-Flashing the U-Boot image on DeveloperBox requires a 96boards UART mezzanine or other mezzanine which can connect to LS-UART0 port. -Connect USB cable from host to the LS-UART0 and set DSW2-7 to ON, and turn the board on again. The flash writer program will be started automatically; don’t forget to turn the DSW2-7 off again after flashing. +Flashing the U-Boot image on DeveloperBox requires a 96boards UART mezzanine +or other mezzanine which can connect to LS-UART0 port. +Connect USB cable from host to the LS-UART0 and set DSW2-7 to ON, and turn the +board on again. The flash writer program will be started automatically; +don't forget to turn the DSW2-7 off again after flashing.
-*!!CAUTION!! If you failed to write the U-Boot image on wrong address, the board can be bricked. See below page if you need to recover the bricked board. See the following page for more detail* +*!!CAUTION!! If you write the U-Boot image on wrong address, the board can +be bricked. See below page if you need to recover the bricked board. See +the following page for more detail*
https://www.96boards.org/documentation/enterprise/developerbox/installation/...
-When the serial flasher is running correctly is will show the following boot messages shown via LS-UART0:: +When the serial flasher is running correctly is will show the following boot +messages shown via LS-UART0::
/*------------------------------------------*/ @@ -81,7 +87,144 @@ Once the flasher tool is running we are ready flash the UEFI image:: flash rawwrite 200000 100000
Send SPI_NOR_UBOOT.fd via XMODEM (Control-A S in minicom) <<
-*!!NOTE!! The flasher command parameter is different from the command for board recovery. U-Boot uses the offset 200000 (2-five-0, 2M in hex) and the size 100000 (1-five-0, 1M in hex).* +*!!NOTE!! The flasher command parameter is different from the command for +board recovery. U-Boot uses the offset 200000 (2-five-0, 2M in hex) and the +size 100000 (1-five-0, 1M in hex).*
-After transferring the SPI_NOR_UBOOT.fd, turn off the DSW2-7 and reset the board. +After transferring the SPI_NOR_UBOOT.fd, turn off the DSW2-7 and +reset the board.
+ +Enable FWU Multi Bank Update +============================ + +DeveloperBox supports the FWU Multi Bank Update. You *MUST* update both +*SCP firmware* and *TF-A* for this feature. This will change the layout and +the boot process but you can switch back to the normal one by changing +the DSW 1-4 off. + +Configure U-Boot +---------------- + +To enable the FWU Multi Bank Update on the DeveloperBox, you need to add +following configurations to configs/synquacer_developerbox_defconfig :: + + CONFIG_FWU_MULTI_BANK_UPDATE=y + CONFIG_FWU_MDATA=y + CONFIG_FWU_MDATA_MTD=y + CONFIG_FWU_NUM_BANKS=2 + CONFIG_FWU_NUM_IMAGES_PER_BANK=1 + CONFIG_CMD_FWU_METADATA=y + +And build it:: + + cd u-boot/ + export ARCH=arm64 + export CROSS_COMPILE=aarch64-linux-gnu- + make synquacer_developerbox_defconfig + make -j `noproc` + cd ../ + +By default, the CONFIG_FWU_NUM_BANKS and CONFIG_FWU_NUM_IMAGES_PER_BANKS are +set to 2 and 1 respectively. This uses FIP (Firmware Image Package) type image +which contains TF-A, U-Boot and OP-TEE (the OP-TEE is optional.) +You can use fiptool to compose the FIP image from those firmware images. + +Rebuild SCP firmware +-------------------- + +Rebuild SCP firmware which supports FWU Multi Bank Update as below:: + + cd SCP-firmware/ + OUT=./build/product/synquacer + ROMFW_FILE=$OUT/scp_romfw/$SCP_BUILD_MODE/bin/scp_romfw.bin + RAMFW_FILE=$OUT/scp_ramfw/$SCP_BUILD_MODE/bin/scp_ramfw.bin + ROMRAMFW_FILE=scp_romramfw_release.bin + + make CC=arm-none-eabi-gcc PRODUCT=synquacer MODE=release + tr "\000" "\377" < /dev/zero | dd of=${ROMRAMFW_FILE} bs=1 count=196608 + dd if=${ROMFW_FILE} of=${ROMRAMFW_FILE} bs=1 conv=notrunc seek=0 + dd if=${RAMFW_FILE} of=${ROMRAMFW_FILE} bs=1 seek=65536 + cd ../ + +And you can get the `scp_romramfw_release.bin` file + +Rebuild OPTEE firmware +---------------------- + +Rebuild OPTEE to use in new-layout fip as below:: + + cd optee_os/ + make -j`nproc` PLATFORM=synquacer ARCH=arm \ + CROSS_COMPILE64=aarch64-linux-gnu- CFG_ARM64_core=y \ + CFG_CRYPTO_WITH_CE=y CFG_CORE_HEAP_SIZE=524288 CFG_CORE_DYN_SHM=y \ + CFG_CORE_ARM64_PA_BITS=48 CFG_TEE_CORE_LOG_LEVEL=1 CFG_TEE_TA_LOG_LEVEL=1 + cp out/arm-plat-synquacer/core/tee-pager_v2.bin ../arm-trusted-firmware/ + +The produced `tee-pager_v2.bin` is to be used while building TF-A next. + + +Rebuild TF-A and FIP +-------------------- + +Rebuild TF-A which supports FWU Multi Bank Update as below:: + + cd arm-trusted-firmware/ + make CROSS_COMPILE=aarch64-linux-gnu- -j`nproc` PLAT=synquacer \ + TRUSTED_BOARD_BOOT=1 SPD=opteed SQ_RESET_TO_BL2=1 GENERATE_COT=1 \ + MBEDTLS_DIR=../mbedtls BL32=tee-pager_v2.bin \ + BL33=../u-boot/u-boot.bin all fip fiptool + +And make a FIP image.:: + + cp build/synquacer/release/fip.bin SPI_NOR_NEWFIP.fd + tools/fiptool/fiptool update --tb-fw build/synquacer/release/bl2.bin SPI_NOR_NEWFIP.fd + +UUIDs for the FWU Multi Bank Update +----------------------------------- + +FWU multi-bank update requires some UUIDs. The DeveloperBox platform uses +following UUIDs. + + - Location UUID for the FIP image: 17e86d77-41f9-4fd7-87ec-a55df9842de5 + - Image type UUID for the FIP image: 10c36d7d-ca52-b843-b7b9-f9d6c501d108 + - Image UUID for Bank0 : 5a66a702-99fd-4fef-a392-c26e261a2828 + - Image UUID for Bank1 : a8f868a1-6e5c-4757-878d-ce63375ef2c0 + +These UUIDs are used for making a FWU metadata image. + +u-boot$ ./tools/mkfwumdata -i 1 -b 2 \ + 17e86d77-41f9-4fd7-87ec-a55df9842de5,10c36d7d-ca52-b843-b7b9-f9d6c501d108,5a66a702-99fd-4fef-a392-c26e261a2828,a8f868a1-6e5c-4757-878d-ce63375ef2c0 \ + ../devbox-fwu-mdata.img + +Create Accept & Revert capsules + +u-boot$ ./tools/mkeficapsule -A -g 7d6dc310-52ca-43b8-b7b9-f9d6c501d108 NEWFIP_accept.Cap +u-boot$ ./tools/mkeficapsule -R NEWFIP_revert.Cap + +Install via flash writer +------------------------ + +As explained in above section, the new FIP image and the FWU metadata image +can be installed via NOR flash writer. Note that the installation offsets for +the FWU multi bank update supported firmware. + +Once the flasher tool is running we are ready flash the images.:: +Write the FIP image to the Bank-0 & 1 at 6MB and 10MB offset.:: + + flash rawwrite 600000 180000 + flash rawwrite a00000 180000 + >> Send SPI_NOR_NEWFIP.fd via XMODEM (Control-A S in minicom) << + + flash rawwrite 500000 1000 + flash rawwrite 530000 1000 + >> Send devbox-fwu-mdata.img via XMODEM (Control-A S in minicom) << + +And write the new SCP firmware.:: + + flash write cm3 + >> Send scp_romramfw_release.bin via XMODEM (Control-A S in minicom) << + +At last, turn on the DSW 3-4 on the board, and reboot. +Note that if DSW 3-4 is turned off, the DeveloperBox will boot from +the original EDK2 firmware (or non-FWU U-Boot if you already installed.) diff --git a/include/configs/synquacer.h b/include/configs/synquacer.h index 8f44c6f66a..cd7359c2f8 100644 --- a/include/configs/synquacer.h +++ b/include/configs/synquacer.h @@ -40,19 +40,29 @@
/* Since U-Boot 64bit PCIe support is limited, disable 64bit MMIO support */
+#ifdef CONFIG_FWU_MULTI_BANK_UPDATE +#define DEFAULT_DFU_ALT_INFO +#else #define DEFAULT_DFU_ALT_INFO "dfu_alt_info=" \ "mtd nor1=u-boot.bin raw 200000 100000;" \ "fip.bin raw 180000 78000;" \ "optee.bin raw 500000 100000\0" +#endif
/* GUIDs for capsule updatable firmware images */ #define DEVELOPERBOX_UBOOT_IMAGE_GUID \ EFI_GUID(0x53a92e83, 0x4ef4, 0x473a, 0x8b, 0x0d, \ 0xb5, 0xd8, 0xc7, 0xb2, 0xd6, 0x00)
+#ifdef CONFIG_FWU_MULTI_BANK_UPDATE +#define DEVELOPERBOX_FIP_IMAGE_GUID \ + EFI_GUID(0x7d6dc310, 0x52ca, 0x43b8, 0xb7, 0xb9, \ + 0xf9, 0xd6, 0xc5, 0x01, 0xd1, 0x08) +#else #define DEVELOPERBOX_FIP_IMAGE_GUID \ EFI_GUID(0x880866e9, 0x84ba, 0x4793, 0xa9, 0x08, \ 0x33, 0xe0, 0xb9, 0x16, 0xf3, 0x98) +#endif
#define DEVELOPERBOX_OPTEE_IMAGE_GUID \ EFI_GUID(0xc1b629f1, 0xce0e, 0x4894, 0x82, 0xbf, \
.image_index = 1,
- int ret;
- ALLOC_CACHE_ALIGN_BUFFER(char, buf, DFU_ALT_BUF_LEN);
- memset(buf, 0, sizeof(buf));
- mtd = get_mtd_device_nm("nor1");
- if (IS_ERR_OR_NULL(mtd))
return;
- ret = fwu_gen_alt_info_from_mtd(buf, DFU_ALT_BUF_LEN, mtd);
- if (ret < 0) {
return;
- log_debug("Make dfu_alt_info: '%s'\n", buf);
- env_set("dfu_alt_info", buf);
- return fwu_mtd_get_alt_num(image_id, alt_num, "nor1");
- int ret;
- u32 active_idx;
- u32 *bootidx = boot_idx;
- ret = fwu_get_active_index(&active_idx);
nit: remove this newline
- if (ret < 0)
*bootidx = -1;
- *bootidx = active_idx;
Is this logic here right? If fwu_get_active_index fails you setup bootidx to -1 and right after it you rewrite it to active_idx initialized in fwu_get_active_index() to mdata->active_index.
It means why to do *bootidx = -1; at all?
doesn't look like that it was created via savedefconfig.
@@ -81,7 +87,144 @@ Once the flasher tool is running we are ready flash the UEFI image:: flash rawwrite 200000 100000 >> Send SPI_NOR_UBOOT.fd via XMODEM (Control-A S in minicom) <<
- CONFIG_FWU_MULTI_BANK_UPDATE=y
- CONFIG_FWU_MDATA=y
- CONFIG_FWU_MDATA_MTD=y
- CONFIG_FWU_NUM_BANKS=2
- CONFIG_FWU_NUM_IMAGES_PER_BANK=1
- CONFIG_CMD_FWU_METADATA=y
+And build it::
- cd u-boot/
- export ARCH=arm64
- export CROSS_COMPILE=aarch64-linux-gnu-
- make synquacer_developerbox_defconfig
- make -j `noproc`
- cd ../
- cd SCP-firmware/
- OUT=./build/product/synquacer
- ROMFW_FILE=$OUT/scp_romfw/$SCP_BUILD_MODE/bin/scp_romfw.bin
- RAMFW_FILE=$OUT/scp_ramfw/$SCP_BUILD_MODE/bin/scp_ramfw.bin
- ROMRAMFW_FILE=scp_romramfw_release.bin
- make CC=arm-none-eabi-gcc PRODUCT=synquacer MODE=release
- tr "\000" "\377" < /dev/zero | dd of=${ROMRAMFW_FILE} bs=1 count=196608
- dd if=${ROMFW_FILE} of=${ROMRAMFW_FILE} bs=1 conv=notrunc seek=0
- dd if=${RAMFW_FILE} of=${ROMRAMFW_FILE} bs=1 seek=65536
- cd ../
- cd optee_os/
- make -j`nproc` PLATFORM=synquacer ARCH=arm \
- CROSS_COMPILE64=aarch64-linux-gnu- CFG_ARM64_core=y \
- CFG_CRYPTO_WITH_CE=y CFG_CORE_HEAP_SIZE=524288 CFG_CORE_DYN_SHM=y \
- CFG_CORE_ARM64_PA_BITS=48 CFG_TEE_CORE_LOG_LEVEL=1 CFG_TEE_TA_LOG_LEVEL=1
- cp out/arm-plat-synquacer/core/tee-pager_v2.bin ../arm-trusted-firmware/
- cd arm-trusted-firmware/
- make CROSS_COMPILE=aarch64-linux-gnu- -j`nproc` PLAT=synquacer \
- cp build/synquacer/release/fip.bin SPI_NOR_NEWFIP.fd
- tools/fiptool/fiptool update --tb-fw build/synquacer/release/bl2.bin SPI_NOR_NEWFIP.fd
In past you have it listed at flash node in DT. I see you have removed it between v3 and v4 without any note about it. Is it still needed? And should it be listed in DT spec again?
Thanks, Michal
int ret;
u32 active_idx;
ok
if (ret < 0)
*bootidx = -1;
yes :) it's a silly remnant of history of changes. Actually this goes away after implementing the default/weak function.
Yes. I had some other config changes too and picked only the relevant ones together.
After the dt change, we no longer require this. But the location_uuid is a standard member of an fwu_image_entry and cmd/fwu_mdata.c always print it. So I think this should be seen as just what a platform wants some unique id to be printed for the image (?).
Thanks Michal for reviewing v4. cheers.
int ret;
u32 active_idx;
ok
if (ret < 0)
*bootidx = -1;
But this is defconfig not documentation.
I am fine with your explanation but documentation should make this clear that uuid is required by spec but not actually used by current implementation or description.
M
On 3/27/23 23:14, jassisinghbrar@gmail.com wrote:
Introduce support for mtd backed storage for FWU feature and enable it on Synquacer platform based DeveloperBox.
This revision is rebased onto patchset that trims the FWU api https://lore.kernel.org/u-boot/20230306231747.1888513-1-jassisinghbrar@gmail...
When I build it on the top of this series for our SOC I am getting
aarch64: + xilinx_zynqmp_virt +lib/fwu_updates/fwu.o: In function `fwu_boottime_checks': +build/../lib/fwu_updates/fwu.c:633: undefined reference to `fwu_plat_get_bootidx' +lib/fwu_updates/fwu.o: In function `fwu_get_image_index': +build/../lib/fwu_updates/fwu.c:381: undefined reference to `fwu_plat_get_alt_num' +make[1]: *** [Makefile:1754: u-boot] Error 139 +make[1]: *** Deleting file 'u-boot' +make: *** [Makefile:177: sub-make] Error 2
That means that I can select these options and I will get compilation error. I understand the error but if anybody can select it you should use weak functions or so to be able to get it at least build.
The series doesn't look bad but still the biggest issue remains which is that DT binding is not approved by DT guys which pretty much means that any platform which starts to use this code can't pass DT yaml checking enforced by SR 2.0.
Thanks, Michal
Changes since v3:
- Fix and Update documentation to also build optee for FWU FIP image.
- Fixed checkpatch warnings
- Made local functions static.
- Split config changes to a separate patch
- Fix authorship of three patches.
Jassi Brar (3): dt: fwu: developerbox: enable fwu banks and mdata regions configs: move to new flash layout and boot flow fwu: DeveloperBox: add support for FWU
Masami Hiramatsu (3): FWU: Add FWU metadata access driver for MTD storage regions FWU: mtd: Add helper functions for accessing FWU metadata tools: Add mkfwumdata tool for FWU metadata image
.../synquacer-sc2a11-developerbox-u-boot.dtsi | 49 ++- board/socionext/developerbox/Makefile | 1 + board/socionext/developerbox/developerbox.c | 8 + board/socionext/developerbox/fwu_plat.c | 57 +++ configs/synquacer_developerbox_defconfig | 12 +- doc/board/socionext/developerbox.rst | 155 +++++++- drivers/fwu-mdata/Kconfig | 15 + drivers/fwu-mdata/Makefile | 1 + drivers/fwu-mdata/raw_mtd.c | 272 ++++++++++++++ include/configs/synquacer.h | 10 + include/fwu.h | 34 ++ lib/fwu_updates/Makefile | 1 + lib/fwu_updates/fwu_mtd.c | 164 +++++++++ tools/Kconfig | 9 + tools/Makefile | 4 + tools/mkfwumdata.c | 334 ++++++++++++++++++ 16 files changed, 1115 insertions(+), 11 deletions(-) create mode 100644 board/socionext/developerbox/fwu_plat.c create mode 100644 drivers/fwu-mdata/raw_mtd.c create mode 100644 lib/fwu_updates/fwu_mtd.c create mode 100644 tools/mkfwumdata.c
I have played with this more and I found other things.
Ilias: mkeficapsule is accepting only guid and mkfwumdata is accepting only uuid or guids. And DT is having uuids only. I think it will be good to sync it up because you need to have both version for images generation which is a little bit painful. It should be possible to list only guids or uuids.
And it is not clear to me how u-boot is talking to boot firmware about next boot index. fwu_plat_get_bootidx() returns index which booted but I can't see any hoook to tell from u-boot to boot firmware what should be image/index to boot after capsule update.
I expect it should work like this. Boot to u-boot - let's say index 0. Run capsule update which will update index 1. Inform boot firmware to boot index 1 (this step I am missing) Call reset Boot to u-boot index 1. Apply accept capsule to confirm that image at index 1 is correct
in case of error (watchdog for example) boot to u-boot index 0 apply revert capsule and disable index 1 image.
Thanks, Michal
participants (8)
Ilias Apalodimas
Jassi Brar
Jassi Brar
Michal Simek
