[U-Boot] [PATCH V2] imx: mkimage: avoid stop CI when required files not exists
Introduce a new script to check whether file exists and use that check in Makefile to avoid break CI system.
The script return 1 when the required files not exists, return 0 when files exists. The script will ignore check to u-boot-dtb.bin, because if there is something wrong to generate u-boot-dtb.bin, there must be some code error.
Signed-off-by: Peng Fan peng.fan@nxp.com ---
V2: refine scripts according to Anatolij's suggest. Add a check to u-boot-dtb.cfgout when assign DEPFILE_EXISTS CI build: https://travis-ci.org/MrVan/u-boot/builds/446043677
arch/arm/mach-imx/Makefile | 10 ++++++++-- tools/imx_cntr_image.sh | 29 +++++++++++++++++++++++++++++ 2 files changed, 37 insertions(+), 2 deletions(-) create mode 100755 tools/imx_cntr_image.sh
diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index 2d79c71371..72fe23a2b9 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -86,9 +86,13 @@ IMX_CONFIG = $(CONFIG_IMX_CONFIG:"%"=%) $(Q)mkdir -p $(dir $@) $(call if_changed_dep,cpp_cfg)
-IMAGE_TYPE = imximage ifeq ($(CONFIG_ARCH_IMX8), y) -IMAGE_TYPE = imx8image +CNTR_DEPFILES := $(srctree)/tools/imx_cntr_image.sh +IMAGE_TYPE := imx8image +DEPFILE_EXISTS := $(shell if [ -f u-boot-dtb.cfgout ]; then $(CNTR_DEPFILES) u-boot-dtb.cfgout; echo $$?; fi) +else +IMAGE_TYPE := imximage +DEPFILE_EXISTS := 0 endif
MKIMAGEFLAGS_u-boot.imx = -n $(filter-out $(PLUGIN).bin $< $(PHONY),$^) \ @@ -104,8 +108,10 @@ MKIMAGEFLAGS_u-boot-dtb.imx = -n $(filter-out $(PLUGIN).bin $< $(PHONY),$^) \ u-boot-dtb.imx: MKIMAGEOUTPUT = u-boot-dtb.imx.log
u-boot-dtb.imx: u-boot-dtb.bin u-boot-dtb.cfgout $(PLUGIN).bin FORCE +ifeq ($(DEPFILE_EXISTS),0) $(call if_changed,mkimage) endif +endif
MKIMAGEFLAGS_SPL = -n $(filter-out $(PLUGIN).bin $< $(PHONY),$^) \ -T $(IMAGE_TYPE) -e $(CONFIG_SPL_TEXT_BASE) diff --git a/tools/imx_cntr_image.sh b/tools/imx_cntr_image.sh new file mode 100755 index 0000000000..4c629e8694 --- /dev/null +++ b/tools/imx_cntr_image.sh @@ -0,0 +1,29 @@ +#!/bin/sh +# SPDX-License-Identifier: GPL-2.0+ +# +# script to check whether the file exists in imximage.cfg for i.MX8 +# +# usage: $0 <imximage.cfg> + +file=$1 + +blobs=`awk '/^APPEND/ {print $2} /^IMAGE/ || /^DATA/ {print $3}' $file` +for f in $blobs; do + tmp=$srctree/$f + if [ $f == "u-boot-dtb.bin" ]; then + continue + fi + + if [ -f $f ]; then + continue + fi + + if [ ! -f $tmp ]; then + echo "WARNING '$tmp' not found, resulting binary is not-functional" >&2 + exit 1 + fi + + sed -in "s;$f;$tmp;" $file +done + +exit 0
On Thu, 25 Oct 2018 08:32:40 +0000 Peng Fan peng.fan@nxp.com wrote: ...
+file=$1
If we want to skip checking for u-boot-dtb.bin, then better drop DATA pattern matching. This should be okay since we have only one DATA field and it is for u-boot-dtb.bin.
Please use blobs=`awk '/^APPEND/ {print $2} /^IMAGE/ {print $3}'`
- tmp=$srctree/$f
- if [ $f == "u-boot-dtb.bin" ]; then
continue
- fi
and drop the above string check.
- if [ -f $f ]; then
continue
- fi
- if [ ! -f $tmp ]; then
exit 1
- fi
- sed -in "s;$f;$tmp;" $file
+done
+exit 0
-- Anatolij
Anatolij Gustschin
Peng Fan
