[U-Boot] [PATCH] Convert CONFIG_SPI to Kconfig
This converts the following to Kconfig: CONFIG_SPI
Signed-off-by: Adam Ford aford173@gmail.com --- configs/cm_t335_defconfig | 1 + configs/devkit8000_defconfig | 1 + drivers/spi/Kconfig | 8 ++++++-- include/configs/alt.h | 1 - include/configs/blanche.h | 1 - include/configs/brppt1.h | 1 - include/configs/cl-som-imx7.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/cm_t335.h | 1 - include/configs/da850evm.h | 1 - include/configs/devkit8000.h | 1 - include/configs/ea20.h | 1 - include/configs/gose.h | 1 - include/configs/koelsch.h | 1 - include/configs/lager.h | 1 - include/configs/legoev3.h | 1 - include/configs/microblaze-generic.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/ot1200.h | 1 - include/configs/porter.h | 1 - include/configs/rk3036_common.h | 1 - include/configs/rk3128_common.h | 1 - include/configs/rk3188_common.h | 1 - include/configs/rk3288_common.h | 1 - include/configs/rk3328_common.h | 1 - include/configs/rut.h | 2 -- include/configs/siemens-am33x-common.h | 1 - include/configs/silk.h | 1 - include/configs/stout.h | 1 - include/configs/taurus.h | 1 - include/configs/ti_armv7_common.h | 1 - include/configs/x86-common.h | 1 - scripts/config_whitelist.txt | 1 - 33 files changed, 8 insertions(+), 33 deletions(-)
diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 608c25a..be2d1f0 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -56,5 +56,6 @@ CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_PHYLIB=y CONFIG_SYS_NS16550=y +# CONFIG_SPI is not set CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 2e97a88..3ea7f98 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -36,4 +36,5 @@ CONFIG_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_SYS_NS16550=y +# CONFIG_SPI is not set CONFIG_OF_LIBFDT=y diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 494639f..c33501c 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -1,4 +1,8 @@ -menu "SPI Support" +menuconfig SPI + bool "SPI Support" + default y + +if SPI
config DM_SPI bool "Enable Driver Model for SPI drivers" @@ -236,4 +240,4 @@ config OMAP3_SPI (McSPI). This driver be used to access SPI chips on platforms embedding this OMAP3 McSPI IP core.
-endmenu # menu "SPI Support" +endif # menu "SPI Support" diff --git a/include/configs/alt.h b/include/configs/alt.h index 35518da..e606a49 100644 --- a/include/configs/alt.h +++ b/include/configs/alt.h @@ -39,7 +39,6 @@ /* SCIF */
/* FLASH */ -#define CONFIG_SPI #define CONFIG_SH_QSPI #define CONFIG_SPI_FLASH_QUAD
diff --git a/include/configs/blanche.h b/include/configs/blanche.h index ce7c716..867cdb3 100755 --- a/include/configs/blanche.h +++ b/include/configs/blanche.h @@ -40,7 +40,6 @@ /* FLASH */ #if !defined(CONFIG_MTD_NOR_FLASH) #define CONFIG_SYS_TEXT_BASE 0x40000000 -#define CONFIG_SPI #define CONFIG_SH_QSPI #define CONFIG_SH_QSPI_BASE 0xE6B10000 #else diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 2dadcae..1f73130 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -220,7 +220,6 @@ MMCARGS
#if defined(CONFIG_SPI_BOOT) /* McSPI IP block */ -#define CONFIG_SPI #define CONFIG_SF_DEFAULT_SPEED 24000000
#define CONFIG_SPL_SPI_LOAD diff --git a/include/configs/cl-som-imx7.h b/include/configs/cl-som-imx7.h index 14c4712..33add17 100644 --- a/include/configs/cl-som-imx7.h +++ b/include/configs/cl-som-imx7.h @@ -147,7 +147,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* SPI Flash support */ -#define CONFIG_SPI #define CONFIG_MXC_SPI #define CONFIG_SF_DEFAULT_BUS 0 #define CONFIG_SF_DEFAULT_CS 0 diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 5195610..e0fbffd 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -161,7 +161,6 @@ #define CONFIG_PREBOOT "usb start;sf probe"
/* SPI */ -#define CONFIG_SPI #define CONFIG_MXC_SPI
/* NAND */ diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index d6ebdcd..d78236f 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -15,7 +15,6 @@
#include <configs/ti_am335x_common.h>
-#undef CONFIG_SPI #undef CONFIG_BOOTCOUNT_LIMIT #undef CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC
diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 4364649..1a8d132 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -149,7 +149,6 @@ #define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) #define CONFIG_CONS_INDEX 1 /* use UART0 for console */
-#define CONFIG_SPI #define CONFIG_DAVINCI_SPI #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI1_CLKID) #ifdef CONFIG_SPL_BUILD diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 5f47c0f..fc6d656 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -59,7 +59,6 @@ #undef CONFIG_DM9000_DEBUG
/* SPI */ -#undef CONFIG_SPI
/* I2C */
diff --git a/include/configs/ea20.h b/include/configs/ea20.h index c5e6e9e..35358bf 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -60,7 +60,6 @@ #define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) #define CONFIG_CONS_INDEX 1 /* use UART0 for console */
-#define CONFIG_SPI #define CONFIG_DAVINCI_SPI #define CONFIG_SYS_SPI_BASE DAVINCI_SPI1_BASE #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI1_CLKID) diff --git a/include/configs/gose.h b/include/configs/gose.h index 610ba1a..0dbacb6 100644 --- a/include/configs/gose.h +++ b/include/configs/gose.h @@ -40,7 +40,6 @@ /* SCIF */
/* SH Ether */ diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index b9214d2..c65a3e7 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -40,7 +40,6 @@ /* SCIF */
/* SH Ether */ diff --git a/include/configs/lager.h b/include/configs/lager.h index 291b03c..2e7585d 100644 --- a/include/configs/lager.h +++ b/include/configs/lager.h @@ -40,7 +40,6 @@ /* SCIF */
/* SPI */ -#define CONFIG_SPI #define CONFIG_SH_QSPI
/* SH Ether */ diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index c27373c..9ddb0d0 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -123,7 +123,6 @@ #define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) #define CONFIG_CONS_INDEX 1 /* use UART0 for console */
-#define CONFIG_SPI #define CONFIG_DAVINCI_SPI #define CONFIG_SYS_SPI_BASE DAVINCI_SPI0_BASE #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI0_CLKID) diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 41e6790..a19c629 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -109,7 +109,6 @@
#ifdef SPIFLASH # define CONFIG_SYS_SPI_BASE XILINX_SPI_FLASH_BASEADDR -# define CONFIG_SPI 1 # define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 # define CONFIG_SF_DEFAULT_SPEED XILINX_SPI_FLASH_MAX_FREQ # define CONFIG_SF_DEFAULT_CS XILINX_SPI_FLASH_CS diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 5dba7d2..c57db72 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -128,7 +128,6 @@ #define CONFIG_CONS_INDEX 1 /* use UART0 for console */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
-#define CONFIG_SPI #define CONFIG_DAVINCI_SPI #define CONFIG_SYS_SPI_BASE DAVINCI_SPI1_BASE #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI1_CLKID) diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 051416e..c36e7c1 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -20,7 +20,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
/* SF Configs */ -#define CONFIG_SPI #define CONFIG_MXC_SPI #define CONFIG_SF_DEFAULT_BUS 2 #define CONFIG_SF_DEFAULT_CS 0 diff --git a/include/configs/porter.h b/include/configs/porter.h index 451d9dd..c00a40d 100644 --- a/include/configs/porter.h +++ b/include/configs/porter.h @@ -40,7 +40,6 @@ /* SCIF */
diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 3a2bf33..e20460b 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -39,7 +39,6 @@ #define SDRAM_MAX_SIZE (CONFIG_NR_DRAM_BANKS * SDRAM_BANK_SIZE)
#define CONFIG_SPI_FLASH -#define CONFIG_SPI #define CONFIG_SPI_FLASH_GIGADEVICE #define CONFIG_SF_DEFAULT_SPEED 20000000
diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index e915a56..19a2e15 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -42,7 +42,6 @@ #define SDRAM_MAX_SIZE 0x80000000
#define CONFIG_SPI_FLASH -#define CONFIG_SPI #define CONFIG_SF_DEFAULT_SPEED 20000000 #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1 diff --git a/include/configs/rk3188_common.h b/include/configs/rk3188_common.h index 0cb0762..1e14aec 100644 --- a/include/configs/rk3188_common.h +++ b/include/configs/rk3188_common.h @@ -53,7 +53,6 @@ #define SDRAM_MAX_SIZE 0x80000000
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index e2f070f..d5e7ad8 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -53,7 +53,6 @@ #define SDRAM_MAX_SIZE 0xfe000000
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index af55632..5ef7df5 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -37,7 +37,6 @@ #define SDRAM_MAX_SIZE 0xff000000
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/rut.h b/include/configs/rut.h index 71078e9..b4b82de 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -118,8 +118,6 @@ #define CONFIG_VIDEO_BMP_LOGO #define DA8XX_LCD_CNTL_BASE LCD_CNTL_BASE
-#define CONFIG_SPI - #define BOARD_LCD_RESET 115 /* Bank 3 pin 19 */ #define CONFIG_FORMIKE #define DISPL_PLL_SPREAD_SPECTRUM diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 78708a2..35d425f 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -67,7 +67,6 @@
#define CONFIG_SYS_LOAD_ADDR 0x81000000 /* Default load address */
-#define CONFIG_SPI #define CONFIG_MTD_DEVICE #define CONFIG_SF_DEFAULT_SPEED (75000000)
diff --git a/include/configs/silk.h b/include/configs/silk.h index 0384325..3fdab0b 100644 --- a/include/configs/silk.h +++ b/include/configs/silk.h @@ -40,7 +40,6 @@ /* SCIF */
diff --git a/include/configs/stout.h b/include/configs/stout.h index 9422c04..e3493d0 100644 --- a/include/configs/stout.h +++ b/include/configs/stout.h @@ -43,7 +43,6 @@ #define CONFIG_SCIF_A
/* SPI */ -#define CONFIG_SPI #define CONFIG_SH_QSPI #define CONFIG_SPI_FLASH_QUAD
diff --git a/include/configs/taurus.h b/include/configs/taurus.h index ce06f7b..6b644a4 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -119,7 +119,6 @@ #endif
/* SPI EEPROM */ -#define CONFIG_SPI #define CONFIG_ATMEL_SPI #define TAURUS_SPI_MASK (1 << 4) #define TAURUS_SPI_CS_PIN AT91_PIN_PA3 diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 91e1398..2840a90 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -99,7 +99,6 @@ #endif
/* GPIO block */
diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 064c546..ca72dd3 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -95,7 +95,6 @@ /*----------------------------------------------------------------------- * FLASH configuration */ -#define CONFIG_SPI
/*----------------------------------------------------------------------- * Environment configuration diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 43a4ff0..3ca51f3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2067,7 +2067,6 @@ CONFIG_SPEAR_UART48M CONFIG_SPEAR_UARTCLKMSK CONFIG_SPEAR_USBBOOT CONFIG_SPEAR_USBTTY -CONFIG_SPI CONFIG_SPI_ADDR CONFIG_SPI_BOOTING CONFIG_SPI_CS_IS_VALID
Adam Ford
