[U-Boot] [PATCH] ARM: socfpga: Fix broken implementation and enhancing boot header
Fixing the broken implementation caused by the patch commit:ce62e57fc57177352a02b76dace0173bd13404b6, ARM: boot0 hook: remove macro, include whole header file. This patch also enhances boot header to contain more special data.
Signed-off-by: Chee, Tien Fong tien.fong.chee@intel.com --- arch/arm/mach-socfpga/include/mach/boot0.h | 30 ++++++++++++++++-------------- 1 file changed, 16 insertions(+), 14 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/boot0.h b/arch/arm/mach-socfpga/include/mach/boot0.h index aaada31..877866a 100644 --- a/arch/arm/mach-socfpga/include/mach/boot0.h +++ b/arch/arm/mach-socfpga/include/mach/boot0.h @@ -8,21 +8,23 @@ #define __BOOT0_H
#ifdef CONFIG_SPL_BUILD -#define ARM_SOC_BOOT0_HOOK \ - .balignl 64,0xf33db33f; \ - \ - .word 0x1337c0d3; /* SoCFPGA preloader validation word */ \ - .word 0xc01df00d; /* Version, flags, length */ \ - .word 0xcafec0d3; /* Checksum, zero-pad */ \ - nop; \ - \ - b reset; /* SoCFPGA jumps here */ \ - nop; \ - nop; \ - nop; -#else -#define ARM_SOC_BOOT0_HOOK + .balignl 64,0xf33db33f; + + /* Start of header offset */ + .word 0x1337c0d3; /* SoCFPGA preloader validation word(4B) */ + .word 0xc01df00d; /* Header length(2B),flags(1B),version(1B) */ +#ifndef CONFIG_TARGET_SOCFPGA_GEN5 + .word 0xcafec0d3; /* Program length(4B) */ + .word 0xf00dcafe; /* Program entry offset(4B),relative to */ + /* the start of program header */ #endif + .word 0xfeedface; /* Simple checksum(2B),spare offset(2B) */ + nop;
+ b reset; /* SoCFPGA jumps here */ + nop; + nop; + nop; +#endif
#endif /* __BOOT0_H */
See section 2) here [1] , in particular the part about referencing commits and the Fixes: tag .
[1] https://www.kernel.org/doc/html/latest/process/submitting-patches.html
This should be a separate patch then.
- nop; \
- nop; \
- nop; \
- nop;
- /* Start of header offset */
- .word 0x1337c0d3; /* SoCFPGA preloader validation word(4B) */
- .word 0xc01df00d; /* Header length(2B),flags(1B),version(1B) */
- .word 0xcafec0d3; /* Program length(4B) */
- .word 0xf00dcafe; /* Program entry offset(4B),relative to */
#endif
nop;
nop;
nop;
nop;
[1] https://www.kernel.org/doc/html/latest/process/submitting-patches .html
okay. Thanks.
diff --git a/arch/arm/mach-socfpga/include/mach/boot0.h b/arch/arm/mach-socfpga/include/mach/boot0.h index aaada31..877866a 100644 --- a/arch/arm/mach-socfpga/include/mach/boot0.h +++ b/arch/arm/mach-socfpga/include/mach/boot0.h @@ -8,21 +8,23 @@ #define __BOOT0_H #ifdef CONFIG_SPL_BUILD -#define ARM_SOC_BOOT0_HOOK \
- nop; \
- nop; \
- nop; \
- nop;
word(4B) */
#endif
- .word 0xfeedface; /* Simple checksum(2B),spare
offset(2B) */
- nop;
- nop;
- nop;
- nop;
+#endif #endif /* __BOOT0_H */
Chee, Tien Fong
