[U-Boot] [PATCH] p1020rdb-pd: platform support
Signed-off-by: Jerry Huang Chang-Ming.Huang@freescale.com Signed-off-by: Haijun Zhang Haijun.Zhang@freescale.com CC: Scott Wood scottwood@freescale.com CC: Sun Yusong-R58495 yorksun@freescale.com --- board/freescale/p1_p2_rdb_pc/ddr.c | 2 +- board/freescale/p1_p2_rdb_pc/tlb.c | 2 +- boards.cfg | 4 ++++ include/configs/p1_p2_rdb_pc.h | 48 ++++++++++++++++++++++++++++++++++++-- 4 files changed, 52 insertions(+), 4 deletions(-)
diff --git a/board/freescale/p1_p2_rdb_pc/ddr.c b/board/freescale/p1_p2_rdb_pc/ddr.c index 9355536..262fd36 100644 --- a/board/freescale/p1_p2_rdb_pc/ddr.c +++ b/board/freescale/p1_p2_rdb_pc/ddr.c @@ -80,7 +80,7 @@ dimm_params_t ddr_raw_timing = { .refresh_rate_ps = 7800000, .tFAW_ps = 30000, }; -#elif defined(CONFIG_P1020MBG) +#elif (defined(CONFIG_P1020MBG) || defined(CONFIG_P1020RDB_PD)) /* Micron MT41J512M8_187E */ dimm_params_t ddr_raw_timing = { .n_ranks = 2, diff --git a/board/freescale/p1_p2_rdb_pc/tlb.c b/board/freescale/p1_p2_rdb_pc/tlb.c index 3e4dffd..e19002f 100644 --- a/board/freescale/p1_p2_rdb_pc/tlb.c +++ b/board/freescale/p1_p2_rdb_pc/tlb.c @@ -110,7 +110,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, 0, 0, 8, BOOKE_PAGESZ_1G, 1),
-#ifdef CONFIG_P1020MBG +#if defined(CONFIG_P1020MBG) || defined(CONFIG_P1020RDB_PD) /* 2G DDR on P1020MBG, map the second 1G */ SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000, CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000, diff --git a/boards.cfg b/boards.cfg index 35f38f3..aefff92 100644 --- a/boards.cfg +++ b/boards.cfg @@ -768,6 +768,10 @@ P1020RDB-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freesca P1020RDB-PC_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB,SPIFLASH P1020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,SDCARD P1020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,SPIFLASH +P1020RDB-PD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PD +P1020RDB-PD_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PD,NAND +P1020RDB-PD_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PD,SDCARD +P1020RDB-PD_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PD,SPIFLASH P1020UTM-PC powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020UTM P1020UTM-PC_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020UTM,36BIT P1020UTM-PC_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020UTM,36BIT,SDCARD diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 964bfcd..36aad8c 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -66,6 +66,35 @@ #define CONFIG_SYS_L2_SIZE (256 << 10) #endif
+/* + * P1020RDB-PD board has user selectable switches for evaluating different + * frequency and boot options for the P1020 device. The table that + * follow describe the available options. The front six binary number was in + * accordance with SW3[1:6]. + * 111101 533 533 267 667 NOR Core0 boot; Core1 hold-off + * 101101 667 667 333 667 NOR Core0 boot; Core1 hold-off + * 011001 800 800 400 667 NOR Core0 boot; Core1 hold-off + * 001001 800 800 400 667 SD/MMC Core0 boot; Core1 hold-off + * 001101 800 800 400 667 SPI Core0 boot; Core1 hold-off + * 010001 800 800 400 667 NAND Core0 boot; Core1 hold-off + * 011101 800 800 400 667 PCIe-2 Core0 boot; Core1 hold-off + */ +#if defined(CONFIG_P1020RDB_PD) +#define CONFIG_BOARDNAME "P1020RDB-PD" +#define CONFIG_NAND_FSL_ELBC +#define CONFIG_P1020 +#define CONFIG_SPI_FLASH +#define CONFIG_VSC7385_ENET +#define CONFIG_SLIC +#define __SW_BOOT_MASK 0x03 +#define __SW_BOOT_NOR 0x64 +#define __SW_BOOT_SPI 0x34 +#define __SW_BOOT_SD 0x24 +#define __SW_BOOT_NAND 0x44 +#define __SW_BOOT_PCIE 0x74 +#define CONFIG_SYS_L2_SIZE (256 << 10) +#endif + #if defined(CONFIG_P1021RDB) #define CONFIG_BOARDNAME "P1021RDB-PC" #define CONFIG_NAND_FSL_ELBC @@ -274,7 +303,7 @@ #define SPD_EEPROM_ADDRESS 0x52 #undef CONFIG_FSL_DDR_INTERACTIVE
-#ifdef CONFIG_P1020MBG +#if (defined(CONFIG_P1020MBG) || defined(CONFIG_P1020RDB_PD)) #define CONFIG_SYS_SDRAM_SIZE_LAW LAW_SIZE_2G #define CONFIG_CHIP_SELECTS_PER_CTRL 2 #else @@ -345,7 +374,7 @@ /* * Local Bus Definitions */ -#if defined(CONFIG_P1020MBG) +#if (defined(CONFIG_P1020MBG) || defined(CONFIG_P1020RDB_PD)) #define CONFIG_SYS_MAX_FLASH_SECT 512 /* 64M */ #define CONFIG_SYS_FLASH_BASE 0xec000000 #elif defined(CONFIG_P1020UTM) @@ -396,13 +425,27 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE #define CONFIG_CMD_NAND +#if defined(CONFIG_P1020RDB_PD) +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +#else #define CONFIG_SYS_NAND_BLOCK_SIZE (16 * 1024) +#endif
#define CONFIG_SYS_NAND_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V) /* valid */ +#if defined(CONFIG_P1020RDB_PD) +#define CONFIG_SYS_NAND_OR_PRELIM (OR_AM_32KB \ + | OR_FCM_PGS /* Large Page*/ \ + | OR_FCM_CSCT \ + | OR_FCM_CST \ + | OR_FCM_CHT \ + | OR_FCM_SCY_1 \ + | OR_FCM_TRLX \ + | OR_FCM_EHTR) +#else #define CONFIG_SYS_NAND_OR_PRELIM (OR_AM_32KB /* small page */ \ | OR_FCM_CSCT \ | OR_FCM_CST \ @@ -410,6 +453,7 @@ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ | OR_FCM_EHTR) +#endif #endif /* CONFIG_NAND_FSL_ELBC */
#define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */
Haijun.Zhang
