[U-Boot] [PATCH v2 1/3] rk3399: orangepi: Enable TPL
Enable TPL for OrangePI rk3399 board.
Reviewed-by: Kever Yang kever.yang@rock-chips.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - rebase on master
configs/orangepi-rk3399_defconfig | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig index 0f5edef429..82ec24205e 100644 --- a/configs/orangepi-rk3399_defconfig +++ b/configs/orangepi-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_ROCKCHIP_RK3399=y -CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x50000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 @@ -14,9 +14,9 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-orangepi.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff8c2000 CONFIG_SPL_STACK_R=y -CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_TPL=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y @@ -56,4 +56,5 @@ CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USE_TINY_PRINTF=y +CONFIG_SPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y
Enable TPL for NanoPC T4, NanoPI M4 boards.
configs/nanopc-t4-rk3399_defconfig | 7 ++++--- configs/nanopi-m4-rk3399_defconfig | 7 ++++--- 2 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/configs/nanopc-t4-rk3399_defconfig b/configs/nanopc-t4-rk3399_defconfig index 37df3f34bc..7863e45db9 100644 --- a/configs/nanopc-t4-rk3399_defconfig +++ b/configs/nanopc-t4-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_ROCKCHIP_RK3399=y -CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x50000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 @@ -14,9 +14,9 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopc-t4.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff8c2000 CONFIG_SPL_STACK_R=y -CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_TPL=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y @@ -56,4 +56,5 @@ CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USE_TINY_PRINTF=y +CONFIG_SPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y diff --git a/configs/nanopi-m4-rk3399_defconfig b/configs/nanopi-m4-rk3399_defconfig index 68fd9ff79b..8b9237c5ed 100644 --- a/configs/nanopi-m4-rk3399_defconfig +++ b/configs/nanopi-m4-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_ROCKCHIP_RK3399=y -CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x50000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 @@ -14,9 +14,9 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-m4.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff8c2000 CONFIG_SPL_STACK_R=y -CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_TPL=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y @@ -56,4 +56,5 @@ CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USE_TINY_PRINTF=y +CONFIG_SPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y
This patch add documentation for TPL build and flashing steps for rk3399 boards.
Add full boot log for future reference.
doc/README.rockchip | 51 ++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 50 insertions(+), 1 deletion(-)
diff --git a/doc/README.rockchip b/doc/README.rockchip index ca4d6473b0..264f7e4994 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -173,7 +173,10 @@ For example: => make u-boot.itb
(Get spl/u-boot-spl-dtb.bin, u-boot.itb images and some boards would get - spl/u-boot-spl.bin since it doesn't enable CONFIG_SPL_OF_CONTROL) + spl/u-boot-spl.bin since it doesn't enable CONFIG_SPL_OF_CONTROL + + If TPL enabled on the target, get tpl/u-boot-tpl-dtb.bin or tpl/u-boot-tpl.bin + if CONFIG_TPL_OF_CONTROL not enabled)
Writing to the board with USB ============================= @@ -455,6 +458,52 @@ Net: eth0: ethernet@fe300000 Hit any key to stop autoboot: 0 =>
+Option 3: Package the image with TPL: + + - Prefix rk3399 header to TPL image + + => cd /path/to/u-boot + => ./tools/mkimage -n rk3399 -T rksd -d tpl/u-boot-tpl-dtb.bin out + + - Concatinate tpl with spl + + => cd /path/to/u-boot + => cat ./spl/u-boot-spl-dtb.bin >> out + + - Write tpl+spl at 64th sector + + => sudo dd if=out of=/dev/sdc seek=64 + + - Write U-Boot proper at 16384 sector + + => sudo dd if=u-boot.itb of=/dev/sdc seek=16384 + => sync + +Put this SD (or micro-SD) card into your board and reset it. You should see +something like: + +U-Boot TPL board init +Trying to boot from BOOTROM +Returning to boot ROM... + +U-Boot SPL board init +Trying to boot from MMC1 + + +U-Boot 2019.07-rc1-00241-g5b3244767a (May 08 2019 - 10:51:06 +0530) + +Model: Orange Pi RK3399 Board +DRAM: 2 GiB +MMC: dwmmc@fe310000: 2, dwmmc@fe320000: 1, sdhci@fe330000: 0 +Loading Environment from MMC... OK +In: serial@ff1a0000 +Out: serial@ff1a0000 +Err: serial@ff1a0000 +Model: Orange Pi RK3399 Board +Net: eth0: ethernet@fe300000 +Hit any key to stop autoboot: 0 +=> + Using fastboot on rk3288 ======================== - Write GPT partition layout to mmc device which fastboot want to use it to
Jagan Teki
