[U-Boot] [PATCH 1/1] fat: FAT sector offsets overflow on large disks and/or FAT partitions
This patch fixes several issues where sector offsets can overflow due to being limited to 16-bits. There are many cases which can cause an overflow, including large FAT32 partitions and partitions that start at a sufficiently large offset on the storage device.
Numerous issues were observed and fixed when a 64GB FAT32 filesystem was accessed due to truncation.
Signed-off-by: Aaron Williams aaron.williams@caviumnetworks.com --- include/fat.h | 10 +++++----- 1 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/include/fat.h b/include/fat.h index 4c92442..7215628 100644 --- a/include/fat.h +++ b/include/fat.h @@ -178,12 +178,12 @@ typedef struct dir_slot { typedef struct { __u8 *fatbuf; /* Current FAT buffer */ int fatsize; /* Size of FAT in bits */ - __u16 fatlength; /* Length of FAT in sectors */ - __u16 fat_sect; /* Starting sector of the FAT */ - __u16 rootdir_sect; /* Start sector of root directory */ - __u16 sect_size; /* Size of sectors in bytes */ + __u32 fat_sect; /* Starting sector of the FAT */ + __u32 rootdir_sect; /* Start sector of root directory */ + __u32 fatlength; /* Length of FAT in sectors */ __u16 clust_size; /* Size of clusters in sectors */ - short data_begin; /* The sector of the first cluster, can be negative */ + __u16 sect_size; /* Size of sectors in bytes */ + int data_begin; /* The sector of the first cluster, can be negative */ int fatbufnum; /* Used by get_fatent, init to -1 */ } fsdata;
Any comments on this patch?
} fsdata;
Hello,
On Wed, 02 May 2012 19:17:41 -0700 Aaron Williams Aaron.Williams@cavium.com wrote:
For large FAT32 partitions only changing of fatlength, rootdir_sect and data_begin is needed to avoid overflows. Changing of fat_sect shouldn't be needed.
What do you mean exactly by "partitions starting at a sufficiently large offset on the storage device"? How do you create such partition? I've tested with a 210 GB FAT32 partition as the fourth primary partition on a 2 TB disk. This partition is the last partition on the disk, so its offset is sufficiently large. For this test only fatlength, rootdir_sect and data_begin was changed to __u32 and int and I do not see issues when listing or loading the files from this partition.
} fsdata;
The patch is probably corrupted by your mailer, it doesn't apply.
Thanks, Anatolij
Hi Anatolij,
On 05/12/2012 08:41 AM, Anatolij Gustschin wrote:
Hello,
You are correct about fat_sect, I misread the code and changed that one as well. I don't think it really matters since another changing it back to a __u16 won't save any space in the data structure on most platforms.
It looks like the corruption problems I was seeing were due to the fact that the file I was reading was after a number of very large files in a 64GB FAT32 partition and I ran into overflows. The partition location shouldn't have any impact unless we're talking about 2+TB drives, in which case I expect there will be numerous other things that will break.
} fsdata;
Thanks, Anatolij
Unfortunately our outbound Exchange mail server tends to "fix" mail formatting making patch submission rather difficult. I'll see what I can do to try and bypass it.
-Aaron
From: Aaron Williams aaron.williams@caviumnetworks.com
This patch fixes several issues where sector offsets can overflow due to being limited to 16-bits. The cases where an overflow can happen when accessing large FAT32 partitions are:
- length of FAT in sectors - start sector of root directory - the sector of the first cluster
These issues were observed when reading files from a 64GB FAT32 filesystem.
Signed-off-by: Aaron Williams aaron.williams@caviumnetworks.com Tested-by: Anatolij Gustschin agust@denx.de Signed-off-by: Anatolij Gustschin agust@denx.de --- include/fat.h | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/fat.h b/include/fat.h index 4c92442..f1b4a0d 100644 --- a/include/fat.h +++ b/include/fat.h @@ -178,12 +178,12 @@ typedef struct dir_slot { typedef struct { __u8 *fatbuf; /* Current FAT buffer */ int fatsize; /* Size of FAT in bits */ - __u16 fatlength; /* Length of FAT in sectors */ + __u32 fatlength; /* Length of FAT in sectors */ __u16 fat_sect; /* Starting sector of the FAT */ - __u16 rootdir_sect; /* Start sector of root directory */ + __u32 rootdir_sect; /* Start sector of root directory */ __u16 sect_size; /* Size of sectors in bytes */ __u16 clust_size; /* Size of clusters in sectors */ - short data_begin; /* The sector of the first cluster, can be negative */ + int data_begin; /* The sector of the first cluster, can be negative */ int fatbufnum; /* Used by get_fatent, init to -1 */ } fsdata;
Dear Anatolij Gustschin,
Applied, thanks.
Aaron Williams
Anatolij Gustschin
