[PATCH] arm: dts: imx8mm-venice-gw7902: add LTE modem gpios
Add missing LTE_PWR# and LTE_RST gpio pinmux.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/dts/imx8mm-venice-gw7902.dts | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/dts/imx8mm-venice-gw7902.dts b/arch/arm/dts/imx8mm-venice-gw7902.dts index 407ab4592b4c..8e8d0d34c237 100644 --- a/arch/arm/dts/imx8mm-venice-gw7902.dts +++ b/arch/arm/dts/imx8mm-venice-gw7902.dts @@ -742,6 +742,9 @@ MX8MM_IOMUXC_GPIO1_IO13_GPIO1_IO13 0x40000041 /* M2_RESET */ MX8MM_IOMUXC_NAND_DATA01_GPIO3_IO7 0x40000119 /* M2_OFF# */ MX8MM_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x40000159 /* M2_WDIS# */ + MX8MM_IOMUXC_SAI1_TXD6_GPIO4_IO18 0x40000041 /* LTE_INT */ + MX8MM_IOMUXC_SAI1_TXD5_GPIO4_IO17 0x40000041 /* LTE_RST# */ + MX8MM_IOMUXC_SAI1_TXD4_GPIO4_IO16 0x40000041 /* LTE_PWR */ MX8MM_IOMUXC_SAI1_TXD2_GPIO4_IO14 0x40000041 /* AMP GPIO1 */ MX8MM_IOMUXC_SAI1_TXD0_GPIO4_IO12 0x40000041 /* AMP GPIO2 */ MX8MM_IOMUXC_SAI1_TXC_GPIO4_IO11 0x40000041 /* AMP GPIO3 */
If this not diverge from Linux dts,
Acked-by: Peng Fan peng.fan@nxp.com
Add missing LTE_PWR# and LTE_RST gpio pinmux. Signed-off-by: Tim Harvey tharvey@gateworks.com Acked-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Peng Fan
sbabic@denx.de
Tim Harvey
