[RFCv1] doc: develop: Describe using CONFIG vs CFG for values
Document how and when to use CONFIG or CFG namespace for options. There are times where Kconfig is not a great fit for our needs, so we want to use the CFG namespace instead.
Signed-off-by: Tom Rini trini@konsulko.com --- RFCv1: - This is essentially my idea on how to better handle the problem of CONFIG values that just don't fit in Kconfig because it makes much more sense to define them statically for a given SoC or calculate them from other values, and so on. One example here would be to revert c7fad78ec0ee ("Convert CONFIG_SYS_BR0_PRELIM et al to Kconfig") and re-name these to CFG_SYS_.. instead. Another big example here would be a global search-and-replace of 's/CONFIG_HPS_/CFG_HPS_/g' as that's all tool-generated. Not all CONFIG_SYS_ options would get this as boolean choices are well handled in Kconfig, and that may not be clear enough in what I wrote here? --- doc/develop/build_configuration.rst | 36 +++++++++++++++++++++++++++++ doc/develop/index.rst | 1 + 2 files changed, 37 insertions(+) create mode 100644 doc/develop/build_configuration.rst
diff --git a/doc/develop/build_configuration.rst b/doc/develop/build_configuration.rst new file mode 100644 index 000000000000..541ce528b36a --- /dev/null +++ b/doc/develop/build_configuration.rst @@ -0,0 +1,36 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Using CONFIG or CFG to configure the build +========================================== + +There are two namespaces used to control the build-time configuration of +U-Boot, ``CONFIG`` and ``CFG``. These are used when it is either not possible +or not practical to make a run-time determination about some functionality of +the hardware or a required software feature or similar. Each of these has their +own places where they are better suited than the other for use. + +The first of these, ``CONFIG``` is managed in the `Kconfig language +https://www.kernel.org/doc/html/latest/kbuild/kconfig-language.html`_ that is +most commonly associated with the Linux kernel and the Kconfig files found +throughout our sources. Adding options to this namespace is the preferred way of +exposing new configuration options as there are a number of ways for both users +and system integrators to manage and change these options. Some common examples +here are to enable a specific command within U-Boot or even a whole subsystem +such as NAND flash or network connectivity. + +The second of these, ``CFG`` is implemented directly as C preprocessor values or +macros, depending on what they are in turn describing. The nature of U-Boot +means that while we have some functionality that is very reasonable to expose to +the end user to enable or disable we have other places where we need to describe +things such as register locations or values, memory map ranges and so on. When +practical, we should be getting these values from the :doc:`device tree +<devicetree/control>`. However, there are cases where this is either not +practical due to when we need the information and may not have a device tree yet +or due to legacy reasons code has not been rewritten. As this information tends +to be specific to a given SoC (or family of SoCs) or if board specific something +that is mandated by the physical design rather than truly user configurable, it +is acceptable to ``#define`` these values in the ``CFG`` namespace. It is +strongly encouraged to place these in the architecture header files, if they are +generic to a given SoC, or under the board directory if board specific. Placing +them under the board.h file in the *include/configs/* directory should be seen +as a last resort. diff --git a/doc/develop/index.rst b/doc/develop/index.rst index 73741ceb6a2f..c8ec7c210d35 100644 --- a/doc/develop/index.rst +++ b/doc/develop/index.rst @@ -9,6 +9,7 @@ General .. toctree:: :maxdepth: 1
+ build_configuration codingstyle designprinciples process
RFCv1:
In README is also written:
* Configuration _OPTIONS_: These are selectable by the user and have names beginning with "CONFIG_".
* Configuration _SETTINGS_: These depend on the hardware etc. and should not be meddled with if you don't know what you're doing; they have names beginning with "CONFIG_SYS_".
So based on this statement, proposed CFG_* options should be of second category - not selectable by user - right?
And this reminds me, that CONFIG_SYS_* option in Kconfig should also not be possible to select / change by user or in user's defconfig. This can be achieved in Kconfig by _not_ specifying short description (after "bool" or "hex" keyword). So maybe this should be also fixed? Or at least do not introduce new Kconfig options with SYS_* which can be changed?
- build_configuration codingstyle designprinciples process
-- 2.25.1
This change looks good. But I'm not sure how to correctly do it. It would be nice to see example, e.g. how to handle it for revert of c7fad78ec0ee ("Convert CONFIG_SYS_BR0_PRELIM et al to Kconfig"). Those are board specific options which are exported and required by both u-boot drivers and u-boot arch/cpu code.
RFCv1:
Ah yes, I forgot to see if the README had anything here. I'll remove and incorporate in RFCv2.
Right.
There is a lot of possible follow-up cleanup work to do, yes. I gave one example of an unmigration that should be done, but there's certainly more. I'll try and make it clearer in RFCv2 about when it is appropriate to add CONFIG settings but that aren't configurable.
[snip]
I'll probably just start with a revert + sed, and leave further clean-up to whomever has more time and interest on the legacy platforms, for that specific example. For all of the SYS_INIT_SP_ADDR as another example, I'll probably go with renaming to CFG_SYS_INIT_SP_ADDR and CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR being select'd and CONFIG_CUSTOM_SYS_INIT_SP_ADDR becoming CFG_SYS_INIT_SP_ADDR directly, and in board.h until someone has the time and desire to further rectify something that really shouldn't be board, but rather SoC (and adjusted based on further options) specific.
Am 28. Juli 2022 15:20:46 MESZ schrieb Tom Rini trini@konsulko.com:
RFCv1:
I would prefer to have numbered list of priorities:
Get property 1) by runtime probing if the U-Boot binary supports multiple boards 2) from Kconfig CONFIG value 3) from DT at runtime 4) from SoC specific CFG constant value 5) from board specific CFG constant value
I am not sure about the sequence of 2 and 3. We don't want to replace defconfig by DT. But we wouldn't want register addresses in Kconfig either. So this needs mire elaboration.
Best regards
Heinrich
RFCv1:
Get property
- by runtime probing if the U-Boot binary supports multiple boards
- from Kconfig CONFIG value
- from DT at runtime
- from SoC specific CFG constant value
- from board specific CFG constant value
I've rewritten things a bit so far to try and be clearer on CONFIG vs CFG. Maybe I should rename it to system_configuration.rst and try and talk more about when to get something at run-time?
Am 28. Juli 2022 19:53:34 MESZ schrieb Tom Rini trini@konsulko.com:
RFCv1:
Get property
Such a broadened scope would be helpful for future developers.
Best regards
Heinrich
Hi Tom,
RFCv1:
I worry that CFG is confusing as it is too similar to CONFIG. Could we have an entirely different prefix, e.g. SYS_? Also, why is a prefix needed?
I have certainly seen things that are named CONFIG_... but are really just SoC values. If they are addresses they should be in the devicetree, but perhaps for early code in SPL that is not practical.
Re the revert, why? Are you worried that we are bloating Kconfig too much with all these internal SoC settings?
What is the policy on using such things for a board? I would very much like to avoid board-specific #defines like this.
Is your hope to drop all remaining ad-hoc CONFIGs in this way?
On Sat, Jul 30, 2022 at 07:27:31PM -0600, Simon Glass wrote:
Hi Tom,
RFCv1:
We need a prefix here for consistency. I don't want to use just SYS_ here as that's not always used for some of the values to be converted.
I tried to elaborate on this more in the later revs of the document. But yes, we have some legacy code that's just not going to get a massive rewrite to use device tree more, but also has an active enough user base that we aren't just going to drop it. So long as it's not going to make life harder in the rest of the code base, this feels like a good enough compromise.
As Pali explained in other threads, there was a problem with the values in that commit, prior to conversion. But turning the series of ORs and shifts into a single magic value made it much harder to see and address. Yes, if it was written to pull from the device tree, it would have been easier to read and fix there. But no one is going to rewrite all of the core PowerPC code.
The policy is better laid out in later revs of the document I think.
A large chunk, yes. I'm auditing CONFIG_SYS_* still, but there's probably going a few hundred symbols that just get resolved this way.
Hi Tom,
Hi Tom,
RFCv1:
We could add it. I feel that people new to the code base will find it confusing that we have CONFIG and CFG.
OK I see.
OK.
Pali Rohár
