[U-Boot] [PATCH] ARM: provide a valid exception stack address for startup code
Create exception stack in IRAM if available to facilitate debugging of pre-relocation code by catching exceptions rather than stopping dead.
Signed-off-by: Lothar Waßmann LW@KARO-electronics.de --- arch/arm/lib/vectors.S | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/arm/lib/vectors.S b/arch/arm/lib/vectors.S index f53b1e9..1019091 100644 --- a/arch/arm/lib/vectors.S +++ b/arch/arm/lib/vectors.S @@ -117,7 +117,6 @@ data_abort: not_used: irq: fiq: - 1: bl 1b /* hang and never return */
@@ -126,7 +125,11 @@ fiq: /* IRQ stack memory (calculated at run-time) + 8 bytes */ .globl IRQ_STACK_START_IN IRQ_STACK_START_IN: +#ifdef IRAM_BASE_ADDR + .word IRAM_BASE_ADDR + 0x20 +#else .word 0x0badc0de +#endif
@ @ IRQ stack frame.
But please see below.
What is this?
@ @ IRQ stack frame. -- 2.1.4
What is this?
Ooops. An unintentionally deleted empty line. Should I resend the patch, or can you fix it up when applying?
Lothar Waßmann
+Tom
What is this?
Probably the latter, but it's up to the custodian.
Lothar Waßmann
