[U-Boot] [PATCH] ARM: zynq: Add support for the topic-miamilite system-on-module
The topic-miamilite SoM contains a Zynq xc7z010 SoC, 1GB DDR3L RAM, 64MB dual-parallel QSPI NOR flash and clock sources.
Signed-off-by: Mike Looijmans mike.looijmans@topic.nl --- arch/arm/dts/Makefile | 1 + arch/arm/dts/zynq-topic-miamilite.dts | 17 ++ .../topic/zynq/zynq-topic-miamilite/ps7_init_gpl.c | 227 +++++++++++++++++++++ board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt | 61 ++++++ configs/topic_miamilite_defconfig | 52 +++++ include/configs/topic_miamilite.h | 2 + 6 files changed, 360 insertions(+) create mode 100644 arch/arm/dts/zynq-topic-miamilite.dts create mode 100644 board/topic/zynq/zynq-topic-miamilite/ps7_init_gpl.c create mode 100644 board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt create mode 100644 configs/topic_miamilite_defconfig create mode 100644 include/configs/topic_miamilite.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 2b1a4e9..8745f04 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -122,6 +122,7 @@ dtb-$(CONFIG_ARCH_ZYNQ) += zynq-zc702.dtb \ zynq-microzed.dtb \ zynq-picozed.dtb \ zynq-topic-miami.dtb \ + zynq-topic-miamilite.dtb \ zynq-topic-miamiplus.dtb \ zynq-zc770-xm010.dtb \ zynq-zc770-xm011.dtb \ diff --git a/arch/arm/dts/zynq-topic-miamilite.dts b/arch/arm/dts/zynq-topic-miamilite.dts new file mode 100644 index 0000000..f88cb4b --- /dev/null +++ b/arch/arm/dts/zynq-topic-miamilite.dts @@ -0,0 +1,17 @@ +/* + * Topic Miami Lite board DTS + * + * Copyright (C) 2017 Topic Embedded Products + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include "zynq-topic-miami.dts" + +/ { + model = "Topic Miami Lite Zynq Board"; + compatible = "topic,miamilite", "xlnx,zynq-7000"; +}; + +&qspi { + is-dual = <1>; +}; diff --git a/board/topic/zynq/zynq-topic-miamilite/ps7_init_gpl.c b/board/topic/zynq/zynq-topic-miamilite/ps7_init_gpl.c new file mode 100644 index 0000000..ec0cc7d --- /dev/null +++ b/board/topic/zynq/zynq-topic-miamilite/ps7_init_gpl.c @@ -0,0 +1,227 @@ +/* + * (c) Copyright 2010-2014 Xilinx, Inc. All rights reserved. + * (c) Copyright 2016 Topic Embedded Products. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "../ps7_init_gpl.h" + +static unsigned long ps7_pll_init_data_3_0[] = { + EMIT_MASKWRITE(0xF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000110, 0x003FFFF0U, 0x000FA220U), + EMIT_MASKWRITE(0xF8000100, 0x0007F000U, 0x00028000U), + EMIT_MASKWRITE(0xF8000100, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0xF8000100, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF8000100, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0xF800010C, 0x00000001U), + EMIT_MASKWRITE(0xF8000100, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0xF8000120, 0x1F003F30U, 0x1F000200U), + EMIT_MASKWRITE(0xF8000114, 0x003FFFF0U, 0x0012C220U), + EMIT_MASKWRITE(0xF8000104, 0x0007F000U, 0x00020000U), + EMIT_MASKWRITE(0xF8000104, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0xF8000104, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF8000104, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0xF800010C, 0x00000002U), + EMIT_MASKWRITE(0xF8000104, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0xF8000124, 0xFFF00003U, 0x0C200003U), + EMIT_MASKWRITE(0xF8000118, 0x003FFFF0U, 0x00113220U), + EMIT_MASKWRITE(0xF8000108, 0x0007F000U, 0x00024000U), + EMIT_MASKWRITE(0xF8000108, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0xF8000108, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF8000108, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0xF800010C, 0x00000004U), + EMIT_MASKWRITE(0xF8000108, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0xF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +static unsigned long ps7_clock_init_data_3_0[] = { + EMIT_MASKWRITE(0xF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000128, 0x03F03F01U, 0x00302301U), + EMIT_MASKWRITE(0xF8000138, 0x00000011U, 0x00000011U), + EMIT_MASKWRITE(0xF800013C, 0x00000011U, 0x00000011U), + EMIT_MASKWRITE(0xF8000140, 0x03F03F71U, 0x00100141U), + EMIT_MASKWRITE(0xF8000144, 0x03F03F71U, 0x00100141U), + EMIT_MASKWRITE(0xF8000148, 0x00003F31U, 0x00000C01U), + EMIT_MASKWRITE(0xF800014C, 0x00003F31U, 0x00000601U), + EMIT_MASKWRITE(0xF8000150, 0x00003F33U, 0x00001803U), + EMIT_MASKWRITE(0xF8000154, 0x00003F33U, 0x00000C03U), + EMIT_MASKWRITE(0xF8000158, 0x00003F33U, 0x00000601U), + EMIT_MASKWRITE(0xF8000168, 0x00003F31U, 0x00000601U), + EMIT_MASKWRITE(0xF8000170, 0x03F03F30U, 0x00100C00U), + EMIT_MASKWRITE(0xF8000180, 0x03F03F30U, 0x00100C00U), + EMIT_MASKWRITE(0xF8000190, 0x03F03F30U, 0x00100600U), + EMIT_MASKWRITE(0xF80001A0, 0x03F03F30U, 0x00101800U), + EMIT_MASKWRITE(0xF80001C4, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF800012C, 0x01FFCCCDU, 0x01FC4C4DU), + EMIT_MASKWRITE(0xF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +static unsigned long ps7_ddr_init_data_3_0[] = { + EMIT_MASKWRITE(0xF8006000, 0x0001FFFFU, 0x00000080U), + EMIT_MASKWRITE(0xF8006004, 0x0007FFFFU, 0x00001081U), + EMIT_MASKWRITE(0xF8006008, 0x03FFFFFFU, 0x03C0780FU), + EMIT_MASKWRITE(0xF800600C, 0x03FFFFFFU, 0x02001001U), + EMIT_MASKWRITE(0xF8006010, 0x03FFFFFFU, 0x00014001U), + EMIT_MASKWRITE(0xF8006014, 0x001FFFFFU, 0x0004281AU), + EMIT_MASKWRITE(0xF8006018, 0xF7FFFFFFU, 0x44E458D2U), + EMIT_MASKWRITE(0xF800601C, 0xFFFFFFFFU, 0x720238E5U), + EMIT_MASKWRITE(0xF8006020, 0x7FDFFFFCU, 0x270872D0U), + EMIT_MASKWRITE(0xF8006024, 0x0FFFFFC3U, 0x00000000U), + EMIT_MASKWRITE(0xF8006028, 0x00003FFFU, 0x00002007U), + EMIT_MASKWRITE(0xF800602C, 0xFFFFFFFFU, 0x00000008U), + EMIT_MASKWRITE(0xF8006030, 0xFFFFFFFFU, 0x00040930U), + EMIT_MASKWRITE(0xF8006034, 0x13FF3FFFU, 0x000116D4U), + EMIT_MASKWRITE(0xF8006038, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0xF800603C, 0x000FFFFFU, 0x00000777U), + EMIT_MASKWRITE(0xF8006040, 0xFFFFFFFFU, 0xFFF00000U), + EMIT_MASKWRITE(0xF8006044, 0x0FFFFFFFU, 0x0F666666U), + EMIT_MASKWRITE(0xF8006048, 0x0003F03FU, 0x0003C008U), + EMIT_MASKWRITE(0xF8006050, 0xFF0F8FFFU, 0x77010800U), + EMIT_MASKWRITE(0xF8006058, 0x00010000U, 0x00000000U), + EMIT_MASKWRITE(0xF800605C, 0x0000FFFFU, 0x00005003U), + EMIT_MASKWRITE(0xF8006060, 0x000017FFU, 0x0000003EU), + EMIT_MASKWRITE(0xF8006064, 0x00021FE0U, 0x00020000U), + EMIT_MASKWRITE(0xF8006068, 0x03FFFFFFU, 0x00284141U), + EMIT_MASKWRITE(0xF800606C, 0x0000FFFFU, 0x00001610U), + EMIT_MASKWRITE(0xF8006078, 0x03FFFFFFU, 0x00466111U), + EMIT_MASKWRITE(0xF800607C, 0x000FFFFFU, 0x00032222U), + EMIT_MASKWRITE(0xF80060A4, 0xFFFFFFFFU, 0x10200802U), + EMIT_MASKWRITE(0xF80060A8, 0x0FFFFFFFU, 0x0690CB73U), + EMIT_MASKWRITE(0xF80060AC, 0x000001FFU, 0x000001FEU), + EMIT_MASKWRITE(0xF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU), + EMIT_MASKWRITE(0xF80060B4, 0x00000200U, 0x00000200U), + EMIT_MASKWRITE(0xF80060B8, 0x01FFFFFFU, 0x00200066U), + EMIT_MASKWRITE(0xF80060C4, 0x00000003U, 0x00000003U), + EMIT_MASKWRITE(0xF80060C4, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0xF80060C8, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0xF80060DC, 0x00000001U, 0x00000000U), + EMIT_MASKWRITE(0xF80060F0, 0x0000FFFFU, 0x00000000U), + EMIT_MASKWRITE(0xF80060F4, 0x0000000FU, 0x00000008U), + EMIT_MASKWRITE(0xF8006114, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0xF8006118, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0xF800611C, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0xF8006120, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0xF8006124, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0xF800612C, 0x000FFFFFU, 0x0003482CU), + EMIT_MASKWRITE(0xF8006130, 0x000FFFFFU, 0x00033032U), + EMIT_MASKWRITE(0xF8006134, 0x000FFFFFU, 0x0002E81FU), + EMIT_MASKWRITE(0xF8006138, 0x000FFFFFU, 0x0002F81AU), + EMIT_MASKWRITE(0xF8006140, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0xF8006144, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0xF8006148, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0xF800614C, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0xF8006154, 0x000FFFFFU, 0x000000ACU), + EMIT_MASKWRITE(0xF8006158, 0x000FFFFFU, 0x000000B2U), + EMIT_MASKWRITE(0xF800615C, 0x000FFFFFU, 0x0000009FU), + EMIT_MASKWRITE(0xF8006160, 0x000FFFFFU, 0x0000009AU), + EMIT_MASKWRITE(0xF8006168, 0x001FFFFFU, 0x00000127U), + EMIT_MASKWRITE(0xF800616C, 0x001FFFFFU, 0x00000121U), + EMIT_MASKWRITE(0xF8006170, 0x001FFFFFU, 0x0000010FU), + EMIT_MASKWRITE(0xF8006174, 0x001FFFFFU, 0x00000113U), + EMIT_MASKWRITE(0xF800617C, 0x000FFFFFU, 0x000000ECU), + EMIT_MASKWRITE(0xF8006180, 0x000FFFFFU, 0x000000F2U), + EMIT_MASKWRITE(0xF8006184, 0x000FFFFFU, 0x000000DFU), + EMIT_MASKWRITE(0xF8006188, 0x000FFFFFU, 0x000000DAU), + EMIT_MASKWRITE(0xF8006190, 0xFFFFFFFFU, 0x1002E080U), + EMIT_MASKWRITE(0xF8006194, 0x000FFFFFU, 0x0001FC82U), + EMIT_MASKWRITE(0xF8006204, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0xF8006208, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF800620C, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006210, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006214, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006218, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF800621C, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006220, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006224, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF80062A8, 0x00000FF5U, 0x00000000U), + EMIT_MASKWRITE(0xF80062AC, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0xF80062B0, 0x003FFFFFU, 0x00005125U), + EMIT_MASKWRITE(0xF80062B4, 0x0003FFFFU, 0x000012A8U), + EMIT_MASKPOLL(0xF8000B74, 0x00002000U), + EMIT_MASKWRITE(0xF8006000, 0x0001FFFFU, 0x00000081U), + EMIT_MASKPOLL(0xF8006054, 0x00000007U), + EMIT_EXIT(), +}; + +static unsigned long ps7_mio_init_data_3_0[] = { + EMIT_MASKWRITE(0xF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000B40, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0xF8000B44, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0xF8000B48, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0xF8000B4C, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0xF8000B50, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0xF8000B54, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0xF8000B58, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0xF8000B5C, 0xFFFFFFFFU, 0x0018C61CU), + EMIT_MASKWRITE(0xF8000B60, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0xF8000B64, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0xF8000B68, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0xF8000B6C, 0x00007FFFU, 0x00000E60U), + EMIT_MASKWRITE(0xF8000B70, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF8000B70, 0x00000021U, 0x00000020U), + EMIT_MASKWRITE(0xF8000B70, 0x07FEFFFFU, 0x00000823U), + EMIT_MASKWRITE(0xF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +static unsigned long ps7_peripherals_init_data_3_0[] = { + EMIT_MASKWRITE(0xF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000B48, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0xF8000B4C, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0xF8000B50, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0xF8000B54, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0xF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_MASKWRITE(0xE0001034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0xE0001018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0xE0001000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0xE0001004, 0x000003FFU, 0x00000020U), + EMIT_MASKWRITE(0xE0000034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0xE0000018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0xE0000000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0xE0000004, 0x000003FFU, 0x00000020U), + EMIT_MASKWRITE(0xE000D000, 0x000800FFU, 0x000800C1U), + EMIT_MASKWRITE(0xF8007000, 0x20000000U, 0x00000000U), + EMIT_MASKDELAY(0xF8F00200, 1), + EMIT_MASKDELAY(0xF8F00200, 1), + EMIT_MASKDELAY(0xF8F00200, 1), + EMIT_EXIT(), +}; + +static unsigned long ps7_post_config_3_0[] = { + EMIT_MASKWRITE(0xF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000900, 0x0000000FU, 0x0000000FU), + EMIT_MASKWRITE(0xF8000240, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0xF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +int ps7_init(void) +{ + int ret; + + ret = ps7_config(ps7_mio_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + ret = ps7_config(ps7_pll_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + ret = ps7_config(ps7_clock_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + ret = ps7_config(ps7_ddr_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + ret = ps7_config(ps7_peripherals_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + + return PS7_INIT_SUCCESS; +} + +int ps7_post_config(void) +{ + return ps7_config(ps7_post_config_3_0); +} diff --git a/board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt b/board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt new file mode 100644 index 0000000..db6e642 --- /dev/null +++ b/board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt @@ -0,0 +1,61 @@ +0xF8000120 0x1F000200 // ARM_CLK_CTRL - divisor = 2 433 MHz (?) +0xf8000700 0x202 +0xf8000704 0x202 +0xf8000708 0x202 +0xf800070c 0x202 +0xf8000710 0x202 +0xf8000714 0x202 +0xf8000718 0x202 +0xf800071c 0x200 +0xf8000720 0x202 +0xf8000724 0x202 +0xf8000728 0x202 +0xf800072c 0x202 +0xf8000730 0x202 +0xf8000734 0x202 +0xf8000738 0x12e1 +0xf800073c 0x12e0 +0xf8000740 0x1200 +0xf8000744 0x1200 +0xf8000748 0x1200 +0xf800074c 0x1200 +0xf8000750 0x1200 +0xf8000754 0x1200 +0xf8000758 0x1200 +0xf800075c 0x1200 +0xf8000760 0x1200 +0xf8000764 0x200 +0xf8000768 0x1200 +0xf800076c 0x200 +0xf8000770 0x304 +0xf8000774 0x305 +0xf8000778 0x304 +0xf800077c 0x305 +0xf8000780 0x304 +0xf8000784 0x304 +0xf8000788 0x304 +0xf800078c 0x304 +0xf8000790 0x305 +0xf8000794 0x304 +0xf8000798 0x304 +0xf800079c 0x304 +0xf80007a0 0x380 +0xf80007a4 0x380 +0xf80007a8 0x380 +0xf80007ac 0x380 +0xf80007b0 0x380 +0xf80007b4 0x380 +0xf80007b8 0x1200 +0xf80007bc 0x1200 +0xf80007c0 0x1240 +0xf80007c4 0x1240 +0xf80007c8 0x1240 +0xf80007cc 0x1240 +0xf80007d0 0x1200 +0xf80007d4 0x1200 +0xf8000830 0x380037 +0xf8000834 0x3a0039 +0xF800014C 0x00000621 // LQSPI_CLK_CTRL - ARMPLL/6 (200 MHz) +0xE000D000 0x800238C1 // QSPI config - divide-by-2 +0xE000D038 0x00000020 // QSPI loopback - internal, 0 delay +0xE000D0A0 0xE2FF06EB // LQSPI_CFG - Quad read, dual flash diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig new file mode 100644 index 0000000..8959fa6 --- /dev/null +++ b/configs/topic_miamilite_defconfig @@ -0,0 +1,52 @@ +CONFIG_ARM=y +CONFIG_SYS_VENDOR="topic" +CONFIG_SYS_CONFIG_NAME="topic_miamilite" +CONFIG_ARCH_ZYNQ=y +CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_BOOT_INIT_FILE="board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt" +CONFIG_DEFAULT_DEVICE_TREE="zynq-topic-miamilite" +CONFIG_BOOTDELAY=0 +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="zynq-uboot> " +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_EMBED=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DFU_RAM=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ZYNQ=y +CONFIG_DEBUG_UART_BASE=0xe0000000 +CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_ZYNQ_QSPI=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="Xilinx" +CONFIG_G_DNL_VENDOR_NUM=0x03fd +CONFIG_G_DNL_PRODUCT_NUM=0x0300 diff --git a/include/configs/topic_miamilite.h b/include/configs/topic_miamilite.h new file mode 100644 index 0000000..46ca6bd --- /dev/null +++ b/include/configs/topic_miamilite.h @@ -0,0 +1,2 @@ +#include "topic_miami.h" +#define CONFIG_SF_DUAL_FLASH
- zynq-topic-miamilite.dtb \ zynq-topic-miamiplus.dtb \ zynq-zc770-xm010.dtb \ zynq-zc770-xm011.dtb \
- Topic Miami Lite board DTS
- Copyright (C) 2017 Topic Embedded Products
- model = "Topic Miami Lite Zynq Board";
- compatible = "topic,miamilite", "xlnx,zynq-7000";
+&qspi {
- is-dual = <1>;
- (c) Copyright 2010-2014 Xilinx, Inc. All rights reserved.
- (c) Copyright 2016 Topic Embedded Products.
- EMIT_MASKWRITE(0xF8000008, 0x0000FFFFU, 0x0000DF0DU),
- EMIT_MASKWRITE(0xF8000110, 0x003FFFF0U, 0x000FA220U),
- EMIT_MASKWRITE(0xF8000100, 0x0007F000U, 0x00028000U),
- EMIT_MASKWRITE(0xF8000100, 0x00000010U, 0x00000010U),
- EMIT_MASKWRITE(0xF8000100, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0xF8000100, 0x00000001U, 0x00000000U),
- EMIT_MASKPOLL(0xF800010C, 0x00000001U),
- EMIT_MASKWRITE(0xF8000100, 0x00000010U, 0x00000000U),
- EMIT_MASKWRITE(0xF8000120, 0x1F003F30U, 0x1F000200U),
- EMIT_MASKWRITE(0xF8000114, 0x003FFFF0U, 0x0012C220U),
- EMIT_MASKWRITE(0xF8000104, 0x0007F000U, 0x00020000U),
- EMIT_MASKWRITE(0xF8000104, 0x00000010U, 0x00000010U),
- EMIT_MASKWRITE(0xF8000104, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0xF8000104, 0x00000001U, 0x00000000U),
- EMIT_MASKPOLL(0xF800010C, 0x00000002U),
- EMIT_MASKWRITE(0xF8000104, 0x00000010U, 0x00000000U),
- EMIT_MASKWRITE(0xF8000124, 0xFFF00003U, 0x0C200003U),
- EMIT_MASKWRITE(0xF8000118, 0x003FFFF0U, 0x00113220U),
- EMIT_MASKWRITE(0xF8000108, 0x0007F000U, 0x00024000U),
- EMIT_MASKWRITE(0xF8000108, 0x00000010U, 0x00000010U),
- EMIT_MASKWRITE(0xF8000108, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0xF8000108, 0x00000001U, 0x00000000U),
- EMIT_MASKPOLL(0xF800010C, 0x00000004U),
- EMIT_MASKWRITE(0xF8000108, 0x00000010U, 0x00000000U),
- EMIT_MASKWRITE(0xF8000004, 0x0000FFFFU, 0x0000767BU),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0xF8000128, 0x03F03F01U, 0x00302301U),
- EMIT_MASKWRITE(0xF8000138, 0x00000011U, 0x00000011U),
- EMIT_MASKWRITE(0xF800013C, 0x00000011U, 0x00000011U),
- EMIT_MASKWRITE(0xF8000140, 0x03F03F71U, 0x00100141U),
- EMIT_MASKWRITE(0xF8000144, 0x03F03F71U, 0x00100141U),
- EMIT_MASKWRITE(0xF8000148, 0x00003F31U, 0x00000C01U),
- EMIT_MASKWRITE(0xF800014C, 0x00003F31U, 0x00000601U),
- EMIT_MASKWRITE(0xF8000150, 0x00003F33U, 0x00001803U),
- EMIT_MASKWRITE(0xF8000154, 0x00003F33U, 0x00000C03U),
- EMIT_MASKWRITE(0xF8000158, 0x00003F33U, 0x00000601U),
- EMIT_MASKWRITE(0xF8000168, 0x00003F31U, 0x00000601U),
- EMIT_MASKWRITE(0xF8000170, 0x03F03F30U, 0x00100C00U),
- EMIT_MASKWRITE(0xF8000180, 0x03F03F30U, 0x00100C00U),
- EMIT_MASKWRITE(0xF8000190, 0x03F03F30U, 0x00100600U),
- EMIT_MASKWRITE(0xF80001A0, 0x03F03F30U, 0x00101800U),
- EMIT_MASKWRITE(0xF80001C4, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0xF800012C, 0x01FFCCCDU, 0x01FC4C4DU),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0xF8006000, 0x0001FFFFU, 0x00000080U),
- EMIT_MASKWRITE(0xF8006004, 0x0007FFFFU, 0x00001081U),
- EMIT_MASKWRITE(0xF8006008, 0x03FFFFFFU, 0x03C0780FU),
- EMIT_MASKWRITE(0xF800600C, 0x03FFFFFFU, 0x02001001U),
- EMIT_MASKWRITE(0xF8006010, 0x03FFFFFFU, 0x00014001U),
- EMIT_MASKWRITE(0xF8006014, 0x001FFFFFU, 0x0004281AU),
- EMIT_MASKWRITE(0xF8006018, 0xF7FFFFFFU, 0x44E458D2U),
- EMIT_MASKWRITE(0xF800601C, 0xFFFFFFFFU, 0x720238E5U),
- EMIT_MASKWRITE(0xF8006020, 0x7FDFFFFCU, 0x270872D0U),
- EMIT_MASKWRITE(0xF8006024, 0x0FFFFFC3U, 0x00000000U),
- EMIT_MASKWRITE(0xF8006028, 0x00003FFFU, 0x00002007U),
- EMIT_MASKWRITE(0xF800602C, 0xFFFFFFFFU, 0x00000008U),
- EMIT_MASKWRITE(0xF8006030, 0xFFFFFFFFU, 0x00040930U),
- EMIT_MASKWRITE(0xF8006034, 0x13FF3FFFU, 0x000116D4U),
- EMIT_MASKWRITE(0xF8006038, 0x00000003U, 0x00000000U),
- EMIT_MASKWRITE(0xF800603C, 0x000FFFFFU, 0x00000777U),
- EMIT_MASKWRITE(0xF8006040, 0xFFFFFFFFU, 0xFFF00000U),
- EMIT_MASKWRITE(0xF8006044, 0x0FFFFFFFU, 0x0F666666U),
- EMIT_MASKWRITE(0xF8006048, 0x0003F03FU, 0x0003C008U),
- EMIT_MASKWRITE(0xF8006050, 0xFF0F8FFFU, 0x77010800U),
- EMIT_MASKWRITE(0xF8006058, 0x00010000U, 0x00000000U),
- EMIT_MASKWRITE(0xF800605C, 0x0000FFFFU, 0x00005003U),
- EMIT_MASKWRITE(0xF8006060, 0x000017FFU, 0x0000003EU),
- EMIT_MASKWRITE(0xF8006064, 0x00021FE0U, 0x00020000U),
- EMIT_MASKWRITE(0xF8006068, 0x03FFFFFFU, 0x00284141U),
- EMIT_MASKWRITE(0xF800606C, 0x0000FFFFU, 0x00001610U),
- EMIT_MASKWRITE(0xF8006078, 0x03FFFFFFU, 0x00466111U),
- EMIT_MASKWRITE(0xF800607C, 0x000FFFFFU, 0x00032222U),
- EMIT_MASKWRITE(0xF80060A4, 0xFFFFFFFFU, 0x10200802U),
- EMIT_MASKWRITE(0xF80060A8, 0x0FFFFFFFU, 0x0690CB73U),
- EMIT_MASKWRITE(0xF80060AC, 0x000001FFU, 0x000001FEU),
- EMIT_MASKWRITE(0xF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU),
- EMIT_MASKWRITE(0xF80060B4, 0x00000200U, 0x00000200U),
- EMIT_MASKWRITE(0xF80060B8, 0x01FFFFFFU, 0x00200066U),
- EMIT_MASKWRITE(0xF80060C4, 0x00000003U, 0x00000003U),
- EMIT_MASKWRITE(0xF80060C4, 0x00000003U, 0x00000000U),
- EMIT_MASKWRITE(0xF80060C8, 0x000000FFU, 0x00000000U),
- EMIT_MASKWRITE(0xF80060DC, 0x00000001U, 0x00000000U),
- EMIT_MASKWRITE(0xF80060F0, 0x0000FFFFU, 0x00000000U),
- EMIT_MASKWRITE(0xF80060F4, 0x0000000FU, 0x00000008U),
- EMIT_MASKWRITE(0xF8006114, 0x000000FFU, 0x00000000U),
- EMIT_MASKWRITE(0xF8006118, 0x7FFFFFCFU, 0x40000001U),
- EMIT_MASKWRITE(0xF800611C, 0x7FFFFFCFU, 0x40000001U),
- EMIT_MASKWRITE(0xF8006120, 0x7FFFFFCFU, 0x40000001U),
- EMIT_MASKWRITE(0xF8006124, 0x7FFFFFCFU, 0x40000001U),
- EMIT_MASKWRITE(0xF800612C, 0x000FFFFFU, 0x0003482CU),
- EMIT_MASKWRITE(0xF8006130, 0x000FFFFFU, 0x00033032U),
- EMIT_MASKWRITE(0xF8006134, 0x000FFFFFU, 0x0002E81FU),
- EMIT_MASKWRITE(0xF8006138, 0x000FFFFFU, 0x0002F81AU),
- EMIT_MASKWRITE(0xF8006140, 0x000FFFFFU, 0x00000035U),
- EMIT_MASKWRITE(0xF8006144, 0x000FFFFFU, 0x00000035U),
- EMIT_MASKWRITE(0xF8006148, 0x000FFFFFU, 0x00000035U),
- EMIT_MASKWRITE(0xF800614C, 0x000FFFFFU, 0x00000035U),
- EMIT_MASKWRITE(0xF8006154, 0x000FFFFFU, 0x000000ACU),
- EMIT_MASKWRITE(0xF8006158, 0x000FFFFFU, 0x000000B2U),
- EMIT_MASKWRITE(0xF800615C, 0x000FFFFFU, 0x0000009FU),
- EMIT_MASKWRITE(0xF8006160, 0x000FFFFFU, 0x0000009AU),
- EMIT_MASKWRITE(0xF8006168, 0x001FFFFFU, 0x00000127U),
- EMIT_MASKWRITE(0xF800616C, 0x001FFFFFU, 0x00000121U),
- EMIT_MASKWRITE(0xF8006170, 0x001FFFFFU, 0x0000010FU),
- EMIT_MASKWRITE(0xF8006174, 0x001FFFFFU, 0x00000113U),
- EMIT_MASKWRITE(0xF800617C, 0x000FFFFFU, 0x000000ECU),
- EMIT_MASKWRITE(0xF8006180, 0x000FFFFFU, 0x000000F2U),
- EMIT_MASKWRITE(0xF8006184, 0x000FFFFFU, 0x000000DFU),
- EMIT_MASKWRITE(0xF8006188, 0x000FFFFFU, 0x000000DAU),
- EMIT_MASKWRITE(0xF8006190, 0xFFFFFFFFU, 0x1002E080U),
- EMIT_MASKWRITE(0xF8006194, 0x000FFFFFU, 0x0001FC82U),
- EMIT_MASKWRITE(0xF8006204, 0xFFFFFFFFU, 0x00000000U),
- EMIT_MASKWRITE(0xF8006208, 0x000703FFU, 0x000003FFU),
- EMIT_MASKWRITE(0xF800620C, 0x000703FFU, 0x000003FFU),
- EMIT_MASKWRITE(0xF8006210, 0x000703FFU, 0x000003FFU),
- EMIT_MASKWRITE(0xF8006214, 0x000703FFU, 0x000003FFU),
- EMIT_MASKWRITE(0xF8006218, 0x000F03FFU, 0x000003FFU),
- EMIT_MASKWRITE(0xF800621C, 0x000F03FFU, 0x000003FFU),
- EMIT_MASKWRITE(0xF8006220, 0x000F03FFU, 0x000003FFU),
- EMIT_MASKWRITE(0xF8006224, 0x000F03FFU, 0x000003FFU),
- EMIT_MASKWRITE(0xF80062A8, 0x00000FF5U, 0x00000000U),
- EMIT_MASKWRITE(0xF80062AC, 0xFFFFFFFFU, 0x00000000U),
- EMIT_MASKWRITE(0xF80062B0, 0x003FFFFFU, 0x00005125U),
- EMIT_MASKWRITE(0xF80062B4, 0x0003FFFFU, 0x000012A8U),
- EMIT_MASKPOLL(0xF8000B74, 0x00002000U),
- EMIT_MASKWRITE(0xF8006000, 0x0001FFFFU, 0x00000081U),
- EMIT_MASKPOLL(0xF8006054, 0x00000007U),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0xF8000B40, 0x00000FFFU, 0x00000600U),
- EMIT_MASKWRITE(0xF8000B44, 0x00000FFFU, 0x00000600U),
- EMIT_MASKWRITE(0xF8000B48, 0x00000FFFU, 0x00000672U),
- EMIT_MASKWRITE(0xF8000B4C, 0x00000FFFU, 0x00000672U),
- EMIT_MASKWRITE(0xF8000B50, 0x00000FFFU, 0x00000674U),
- EMIT_MASKWRITE(0xF8000B54, 0x00000FFFU, 0x00000674U),
- EMIT_MASKWRITE(0xF8000B58, 0x00000FFFU, 0x00000600U),
- EMIT_MASKWRITE(0xF8000B5C, 0xFFFFFFFFU, 0x0018C61CU),
- EMIT_MASKWRITE(0xF8000B60, 0xFFFFFFFFU, 0x00F9861CU),
- EMIT_MASKWRITE(0xF8000B64, 0xFFFFFFFFU, 0x00F9861CU),
- EMIT_MASKWRITE(0xF8000B68, 0xFFFFFFFFU, 0x00F9861CU),
- EMIT_MASKWRITE(0xF8000B6C, 0x00007FFFU, 0x00000E60U),
- EMIT_MASKWRITE(0xF8000B70, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0xF8000B70, 0x00000021U, 0x00000020U),
- EMIT_MASKWRITE(0xF8000B70, 0x07FEFFFFU, 0x00000823U),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0xF8000B48, 0x00000180U, 0x00000180U),
- EMIT_MASKWRITE(0xF8000B4C, 0x00000180U, 0x00000180U),
- EMIT_MASKWRITE(0xF8000B50, 0x00000180U, 0x00000180U),
- EMIT_MASKWRITE(0xF8000B54, 0x00000180U, 0x00000180U),
- EMIT_MASKWRITE(0xE0001034, 0x000000FFU, 0x00000006U),
- EMIT_MASKWRITE(0xE0001018, 0x0000FFFFU, 0x0000007CU),
- EMIT_MASKWRITE(0xE0001000, 0x000001FFU, 0x00000017U),
- EMIT_MASKWRITE(0xE0001004, 0x000003FFU, 0x00000020U),
- EMIT_MASKWRITE(0xE0000034, 0x000000FFU, 0x00000006U),
- EMIT_MASKWRITE(0xE0000018, 0x0000FFFFU, 0x0000007CU),
- EMIT_MASKWRITE(0xE0000000, 0x000001FFU, 0x00000017U),
- EMIT_MASKWRITE(0xE0000004, 0x000003FFU, 0x00000020U),
- EMIT_MASKWRITE(0xE000D000, 0x000800FFU, 0x000800C1U),
- EMIT_MASKWRITE(0xF8007000, 0x20000000U, 0x00000000U),
- EMIT_MASKDELAY(0xF8F00200, 1),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0xF8000900, 0x0000000FU, 0x0000000FU),
- EMIT_MASKWRITE(0xF8000240, 0xFFFFFFFFU, 0x00000000U),
- EMIT_EXIT(),
- int ret;
- ret = ps7_config(ps7_mio_init_data_3_0);
- if (ret != PS7_INIT_SUCCESS)
return ret;
- ret = ps7_config(ps7_pll_init_data_3_0);
return ret;
- ret = ps7_config(ps7_clock_init_data_3_0);
return ret;
- ret = ps7_config(ps7_ddr_init_data_3_0);
return ret;
- ret = ps7_config(ps7_peripherals_init_data_3_0);
return ret;
- return PS7_INIT_SUCCESS;
- return ps7_config(ps7_post_config_3_0);
Isn't it easier to define this in Kconfig and just select it? All configs are on the way to Kconfig anyway.
Thanks, Michal
+&qspi {
- is-dual = <1>;
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- int ret;
return ret;
return ret;
return ret;
return ret;
return ret;
Probably, yes, but this appears to be the current state. I did a grep on the keywork and strangely only the two topic boards mention it. Apparently no other boards use dual-qspu flash?
I'd propose making the move to Kconfig a separate patch. This patch can be rebased on that.
Kind regards,
Mike Looijmans System Expert
TOPIC Products Materiaalweg 4, NL-5681 RJ Best Postbus 440, NL-5680 AK Best Telefoon: +31 (0) 499 33 69 79 E-mail: mike.looijmans@topicproducts.com Website: www.topicproducts.com
Please consider the environment before printing this e-mail
Join our presentation at Electronics & Applications 2017: FPGA for real-time data processing, subject “Hardware platform for industrial ultrasound steel plate Inspection” Topic Embedded Systems - Herman Kuster, 1st June 10 AM
Visit http://eabeurs.nl/author/612884/ for more information
+&qspi {
- is-dual = <1>;
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- int ret;
return ret;
return ret;
return ret;
return ret;
return ret;
Not a problem.
M
Signed-off-by: Mike Looijmans mike.looijmans@topic.nl --- v2: Move CONFIG_SF_DUAL_FLASH to defconfig
arch/arm/dts/Makefile | 1 + arch/arm/dts/zynq-topic-miamilite.dts | 17 ++ .../topic/zynq/zynq-topic-miamilite/ps7_init_gpl.c | 227 +++++++++++++++++++++ board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt | 61 ++++++ configs/topic_miamilite_defconfig | 53 +++++ 5 files changed, 359 insertions(+) create mode 100644 arch/arm/dts/zynq-topic-miamilite.dts create mode 100644 board/topic/zynq/zynq-topic-miamilite/ps7_init_gpl.c create mode 100644 board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt create mode 100644 configs/topic_miamilite_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 2b1a4e9..8745f04 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -122,6 +122,7 @@ dtb-$(CONFIG_ARCH_ZYNQ) += zynq-zc702.dtb \ zynq-microzed.dtb \ zynq-picozed.dtb \ zynq-topic-miami.dtb \ + zynq-topic-miamilite.dtb \ zynq-topic-miamiplus.dtb \ zynq-zc770-xm010.dtb \ zynq-zc770-xm011.dtb \ diff --git a/arch/arm/dts/zynq-topic-miamilite.dts b/arch/arm/dts/zynq-topic-miamilite.dts new file mode 100644 index 0000000..f88cb4b --- /dev/null +++ b/arch/arm/dts/zynq-topic-miamilite.dts @@ -0,0 +1,17 @@ +/* + * Topic Miami Lite board DTS + * + * Copyright (C) 2017 Topic Embedded Products + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include "zynq-topic-miami.dts" + +/ { + model = "Topic Miami Lite Zynq Board"; + compatible = "topic,miamilite", "xlnx,zynq-7000"; +}; + +&qspi { + is-dual = <1>; +}; diff --git a/board/topic/zynq/zynq-topic-miamilite/ps7_init_gpl.c b/board/topic/zynq/zynq-topic-miamilite/ps7_init_gpl.c new file mode 100644 index 0000000..ec0cc7d --- /dev/null +++ b/board/topic/zynq/zynq-topic-miamilite/ps7_init_gpl.c @@ -0,0 +1,227 @@ +/* + * (c) Copyright 2010-2014 Xilinx, Inc. All rights reserved. + * (c) Copyright 2016 Topic Embedded Products. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "../ps7_init_gpl.h" + +static unsigned long ps7_pll_init_data_3_0[] = { + EMIT_MASKWRITE(0xF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000110, 0x003FFFF0U, 0x000FA220U), + EMIT_MASKWRITE(0xF8000100, 0x0007F000U, 0x00028000U), + EMIT_MASKWRITE(0xF8000100, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0xF8000100, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF8000100, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0xF800010C, 0x00000001U), + EMIT_MASKWRITE(0xF8000100, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0xF8000120, 0x1F003F30U, 0x1F000200U), + EMIT_MASKWRITE(0xF8000114, 0x003FFFF0U, 0x0012C220U), + EMIT_MASKWRITE(0xF8000104, 0x0007F000U, 0x00020000U), + EMIT_MASKWRITE(0xF8000104, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0xF8000104, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF8000104, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0xF800010C, 0x00000002U), + EMIT_MASKWRITE(0xF8000104, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0xF8000124, 0xFFF00003U, 0x0C200003U), + EMIT_MASKWRITE(0xF8000118, 0x003FFFF0U, 0x00113220U), + EMIT_MASKWRITE(0xF8000108, 0x0007F000U, 0x00024000U), + EMIT_MASKWRITE(0xF8000108, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0xF8000108, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF8000108, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0xF800010C, 0x00000004U), + EMIT_MASKWRITE(0xF8000108, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0xF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +static unsigned long ps7_clock_init_data_3_0[] = { + EMIT_MASKWRITE(0xF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000128, 0x03F03F01U, 0x00302301U), + EMIT_MASKWRITE(0xF8000138, 0x00000011U, 0x00000011U), + EMIT_MASKWRITE(0xF800013C, 0x00000011U, 0x00000011U), + EMIT_MASKWRITE(0xF8000140, 0x03F03F71U, 0x00100141U), + EMIT_MASKWRITE(0xF8000144, 0x03F03F71U, 0x00100141U), + EMIT_MASKWRITE(0xF8000148, 0x00003F31U, 0x00000C01U), + EMIT_MASKWRITE(0xF800014C, 0x00003F31U, 0x00000601U), + EMIT_MASKWRITE(0xF8000150, 0x00003F33U, 0x00001803U), + EMIT_MASKWRITE(0xF8000154, 0x00003F33U, 0x00000C03U), + EMIT_MASKWRITE(0xF8000158, 0x00003F33U, 0x00000601U), + EMIT_MASKWRITE(0xF8000168, 0x00003F31U, 0x00000601U), + EMIT_MASKWRITE(0xF8000170, 0x03F03F30U, 0x00100C00U), + EMIT_MASKWRITE(0xF8000180, 0x03F03F30U, 0x00100C00U), + EMIT_MASKWRITE(0xF8000190, 0x03F03F30U, 0x00100600U), + EMIT_MASKWRITE(0xF80001A0, 0x03F03F30U, 0x00101800U), + EMIT_MASKWRITE(0xF80001C4, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF800012C, 0x01FFCCCDU, 0x01FC4C4DU), + EMIT_MASKWRITE(0xF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +static unsigned long ps7_ddr_init_data_3_0[] = { + EMIT_MASKWRITE(0xF8006000, 0x0001FFFFU, 0x00000080U), + EMIT_MASKWRITE(0xF8006004, 0x0007FFFFU, 0x00001081U), + EMIT_MASKWRITE(0xF8006008, 0x03FFFFFFU, 0x03C0780FU), + EMIT_MASKWRITE(0xF800600C, 0x03FFFFFFU, 0x02001001U), + EMIT_MASKWRITE(0xF8006010, 0x03FFFFFFU, 0x00014001U), + EMIT_MASKWRITE(0xF8006014, 0x001FFFFFU, 0x0004281AU), + EMIT_MASKWRITE(0xF8006018, 0xF7FFFFFFU, 0x44E458D2U), + EMIT_MASKWRITE(0xF800601C, 0xFFFFFFFFU, 0x720238E5U), + EMIT_MASKWRITE(0xF8006020, 0x7FDFFFFCU, 0x270872D0U), + EMIT_MASKWRITE(0xF8006024, 0x0FFFFFC3U, 0x00000000U), + EMIT_MASKWRITE(0xF8006028, 0x00003FFFU, 0x00002007U), + EMIT_MASKWRITE(0xF800602C, 0xFFFFFFFFU, 0x00000008U), + EMIT_MASKWRITE(0xF8006030, 0xFFFFFFFFU, 0x00040930U), + EMIT_MASKWRITE(0xF8006034, 0x13FF3FFFU, 0x000116D4U), + EMIT_MASKWRITE(0xF8006038, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0xF800603C, 0x000FFFFFU, 0x00000777U), + EMIT_MASKWRITE(0xF8006040, 0xFFFFFFFFU, 0xFFF00000U), + EMIT_MASKWRITE(0xF8006044, 0x0FFFFFFFU, 0x0F666666U), + EMIT_MASKWRITE(0xF8006048, 0x0003F03FU, 0x0003C008U), + EMIT_MASKWRITE(0xF8006050, 0xFF0F8FFFU, 0x77010800U), + EMIT_MASKWRITE(0xF8006058, 0x00010000U, 0x00000000U), + EMIT_MASKWRITE(0xF800605C, 0x0000FFFFU, 0x00005003U), + EMIT_MASKWRITE(0xF8006060, 0x000017FFU, 0x0000003EU), + EMIT_MASKWRITE(0xF8006064, 0x00021FE0U, 0x00020000U), + EMIT_MASKWRITE(0xF8006068, 0x03FFFFFFU, 0x00284141U), + EMIT_MASKWRITE(0xF800606C, 0x0000FFFFU, 0x00001610U), + EMIT_MASKWRITE(0xF8006078, 0x03FFFFFFU, 0x00466111U), + EMIT_MASKWRITE(0xF800607C, 0x000FFFFFU, 0x00032222U), + EMIT_MASKWRITE(0xF80060A4, 0xFFFFFFFFU, 0x10200802U), + EMIT_MASKWRITE(0xF80060A8, 0x0FFFFFFFU, 0x0690CB73U), + EMIT_MASKWRITE(0xF80060AC, 0x000001FFU, 0x000001FEU), + EMIT_MASKWRITE(0xF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU), + EMIT_MASKWRITE(0xF80060B4, 0x00000200U, 0x00000200U), + EMIT_MASKWRITE(0xF80060B8, 0x01FFFFFFU, 0x00200066U), + EMIT_MASKWRITE(0xF80060C4, 0x00000003U, 0x00000003U), + EMIT_MASKWRITE(0xF80060C4, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0xF80060C8, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0xF80060DC, 0x00000001U, 0x00000000U), + EMIT_MASKWRITE(0xF80060F0, 0x0000FFFFU, 0x00000000U), + EMIT_MASKWRITE(0xF80060F4, 0x0000000FU, 0x00000008U), + EMIT_MASKWRITE(0xF8006114, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0xF8006118, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0xF800611C, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0xF8006120, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0xF8006124, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0xF800612C, 0x000FFFFFU, 0x0003482CU), + EMIT_MASKWRITE(0xF8006130, 0x000FFFFFU, 0x00033032U), + EMIT_MASKWRITE(0xF8006134, 0x000FFFFFU, 0x0002E81FU), + EMIT_MASKWRITE(0xF8006138, 0x000FFFFFU, 0x0002F81AU), + EMIT_MASKWRITE(0xF8006140, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0xF8006144, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0xF8006148, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0xF800614C, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0xF8006154, 0x000FFFFFU, 0x000000ACU), + EMIT_MASKWRITE(0xF8006158, 0x000FFFFFU, 0x000000B2U), + EMIT_MASKWRITE(0xF800615C, 0x000FFFFFU, 0x0000009FU), + EMIT_MASKWRITE(0xF8006160, 0x000FFFFFU, 0x0000009AU), + EMIT_MASKWRITE(0xF8006168, 0x001FFFFFU, 0x00000127U), + EMIT_MASKWRITE(0xF800616C, 0x001FFFFFU, 0x00000121U), + EMIT_MASKWRITE(0xF8006170, 0x001FFFFFU, 0x0000010FU), + EMIT_MASKWRITE(0xF8006174, 0x001FFFFFU, 0x00000113U), + EMIT_MASKWRITE(0xF800617C, 0x000FFFFFU, 0x000000ECU), + EMIT_MASKWRITE(0xF8006180, 0x000FFFFFU, 0x000000F2U), + EMIT_MASKWRITE(0xF8006184, 0x000FFFFFU, 0x000000DFU), + EMIT_MASKWRITE(0xF8006188, 0x000FFFFFU, 0x000000DAU), + EMIT_MASKWRITE(0xF8006190, 0xFFFFFFFFU, 0x1002E080U), + EMIT_MASKWRITE(0xF8006194, 0x000FFFFFU, 0x0001FC82U), + EMIT_MASKWRITE(0xF8006204, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0xF8006208, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF800620C, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006210, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006214, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006218, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF800621C, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006220, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006224, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF80062A8, 0x00000FF5U, 0x00000000U), + EMIT_MASKWRITE(0xF80062AC, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0xF80062B0, 0x003FFFFFU, 0x00005125U), + EMIT_MASKWRITE(0xF80062B4, 0x0003FFFFU, 0x000012A8U), + EMIT_MASKPOLL(0xF8000B74, 0x00002000U), + EMIT_MASKWRITE(0xF8006000, 0x0001FFFFU, 0x00000081U), + EMIT_MASKPOLL(0xF8006054, 0x00000007U), + EMIT_EXIT(), +}; + +static unsigned long ps7_mio_init_data_3_0[] = { + EMIT_MASKWRITE(0xF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000B40, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0xF8000B44, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0xF8000B48, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0xF8000B4C, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0xF8000B50, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0xF8000B54, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0xF8000B58, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0xF8000B5C, 0xFFFFFFFFU, 0x0018C61CU), + EMIT_MASKWRITE(0xF8000B60, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0xF8000B64, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0xF8000B68, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0xF8000B6C, 0x00007FFFU, 0x00000E60U), + EMIT_MASKWRITE(0xF8000B70, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF8000B70, 0x00000021U, 0x00000020U), + EMIT_MASKWRITE(0xF8000B70, 0x07FEFFFFU, 0x00000823U), + EMIT_MASKWRITE(0xF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +static unsigned long ps7_peripherals_init_data_3_0[] = { + EMIT_MASKWRITE(0xF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000B48, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0xF8000B4C, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0xF8000B50, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0xF8000B54, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0xF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_MASKWRITE(0xE0001034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0xE0001018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0xE0001000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0xE0001004, 0x000003FFU, 0x00000020U), + EMIT_MASKWRITE(0xE0000034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0xE0000018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0xE0000000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0xE0000004, 0x000003FFU, 0x00000020U), + EMIT_MASKWRITE(0xE000D000, 0x000800FFU, 0x000800C1U), + EMIT_MASKWRITE(0xF8007000, 0x20000000U, 0x00000000U), + EMIT_MASKDELAY(0xF8F00200, 1), + EMIT_MASKDELAY(0xF8F00200, 1), + EMIT_MASKDELAY(0xF8F00200, 1), + EMIT_EXIT(), +}; + +static unsigned long ps7_post_config_3_0[] = { + EMIT_MASKWRITE(0xF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000900, 0x0000000FU, 0x0000000FU), + EMIT_MASKWRITE(0xF8000240, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0xF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +int ps7_init(void) +{ + int ret; + + ret = ps7_config(ps7_mio_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + ret = ps7_config(ps7_pll_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + ret = ps7_config(ps7_clock_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + ret = ps7_config(ps7_ddr_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + ret = ps7_config(ps7_peripherals_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + + return PS7_INIT_SUCCESS; +} + +int ps7_post_config(void) +{ + return ps7_config(ps7_post_config_3_0); +} diff --git a/board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt b/board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt new file mode 100644 index 0000000..db6e642 --- /dev/null +++ b/board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt @@ -0,0 +1,61 @@ +0xF8000120 0x1F000200 // ARM_CLK_CTRL - divisor = 2 433 MHz (?) +0xf8000700 0x202 +0xf8000704 0x202 +0xf8000708 0x202 +0xf800070c 0x202 +0xf8000710 0x202 +0xf8000714 0x202 +0xf8000718 0x202 +0xf800071c 0x200 +0xf8000720 0x202 +0xf8000724 0x202 +0xf8000728 0x202 +0xf800072c 0x202 +0xf8000730 0x202 +0xf8000734 0x202 +0xf8000738 0x12e1 +0xf800073c 0x12e0 +0xf8000740 0x1200 +0xf8000744 0x1200 +0xf8000748 0x1200 +0xf800074c 0x1200 +0xf8000750 0x1200 +0xf8000754 0x1200 +0xf8000758 0x1200 +0xf800075c 0x1200 +0xf8000760 0x1200 +0xf8000764 0x200 +0xf8000768 0x1200 +0xf800076c 0x200 +0xf8000770 0x304 +0xf8000774 0x305 +0xf8000778 0x304 +0xf800077c 0x305 +0xf8000780 0x304 +0xf8000784 0x304 +0xf8000788 0x304 +0xf800078c 0x304 +0xf8000790 0x305 +0xf8000794 0x304 +0xf8000798 0x304 +0xf800079c 0x304 +0xf80007a0 0x380 +0xf80007a4 0x380 +0xf80007a8 0x380 +0xf80007ac 0x380 +0xf80007b0 0x380 +0xf80007b4 0x380 +0xf80007b8 0x1200 +0xf80007bc 0x1200 +0xf80007c0 0x1240 +0xf80007c4 0x1240 +0xf80007c8 0x1240 +0xf80007cc 0x1240 +0xf80007d0 0x1200 +0xf80007d4 0x1200 +0xf8000830 0x380037 +0xf8000834 0x3a0039 +0xF800014C 0x00000621 // LQSPI_CLK_CTRL - ARMPLL/6 (200 MHz) +0xE000D000 0x800238C1 // QSPI config - divide-by-2 +0xE000D038 0x00000020 // QSPI loopback - internal, 0 delay +0xE000D0A0 0xE2FF06EB // LQSPI_CFG - Quad read, dual flash diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig new file mode 100644 index 0000000..a01a82a --- /dev/null +++ b/configs/topic_miamilite_defconfig @@ -0,0 +1,53 @@ +CONFIG_ARM=y +CONFIG_SYS_VENDOR="topic" +CONFIG_SYS_CONFIG_NAME="topic_miami" +CONFIG_ARCH_ZYNQ=y +CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_BOOT_INIT_FILE="board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt" +CONFIG_DEFAULT_DEVICE_TREE="zynq-topic-miamilite" +CONFIG_BOOTDELAY=0 +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="zynq-uboot> " +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_EMBED=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DFU_RAM=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_SF_DUAL_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ZYNQ=y +CONFIG_DEBUG_UART_BASE=0xe0000000 +CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_ZYNQ_QSPI=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="Xilinx" +CONFIG_G_DNL_VENDOR_NUM=0x03fd +CONFIG_G_DNL_PRODUCT_NUM=0x0300
+&qspi {
- is-dual = <1>;
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- int ret;
return ret;
return ret;
return ret;
return ret;
return ret;
Please send it as series with that SF_DUAL_FLASH one because this depends on it.
Thanks, Michal
These two patches add support for the topic-miamilite board.
v2: Rebased, no change v3: Added missing Kconfig
v2: Moved CONFIG_SF_DUAL_FLASH to defconfig v3: No change, resend as series
Move the only use of CONFIG_SF_DUAL_FLASH to defconfig. This makes the associated topic_miamiplus.h header obsolete, so remove that as well.
Signed-off-by: Mike Looijmans mike.looijmans@topic.nl --- README | 6 ------ configs/topic_miamiplus_defconfig | 3 ++- drivers/mtd/spi/Kconfig | 7 +++++++ include/configs/topic_miami.h | 1 - include/configs/topic_miamiplus.h | 2 -- scripts/config_whitelist.txt | 1 - 6 files changed, 9 insertions(+), 11 deletions(-) delete mode 100644 include/configs/topic_miamiplus.h
diff --git a/README b/README index 9d351ec..c481016 100644 --- a/README +++ b/README @@ -2639,12 +2639,6 @@ The following options need to be configured: Define this option to include a destructive SPI flash test ('sf test').
- CONFIG_SF_DUAL_FLASH Dual flash memories - - Define this option to use dual flash support where two flash - memories can be connected with a given cs line. - Currently Xilinx Zynq qspi supports these type of connections. - - SystemACE Support: CONFIG_SYSTEMACE
diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index 10762f8..535ce6d 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_SYS_VENDOR="topic" -CONFIG_SYS_CONFIG_NAME="topic_miamiplus" +CONFIG_SYS_CONFIG_NAME="topic_miami" CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_BOOT_INIT_FILE="board/topic/zynq/zynq-topic-miamiplus/ps7_regs.txt" @@ -28,6 +28,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_RAM=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_SF_DUAL_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 5ca0a71..5700859 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -42,6 +42,13 @@ config SPI_FLASH_BAR Bank/Extended address registers are used to access the flash which has size > 16MiB in 3-byte addressing.
+config SF_DUAL_FLASH + bool "SPI DUAL flash memory support" + depends on SPI_FLASH + help + Enable this option to support two flash memories connected to a single + controller. Currently Xilinx Zynq qspi supports this. + if SPI_FLASH
config SPI_FLASH_ATMEL diff --git a/include/configs/topic_miami.h b/include/configs/topic_miami.h index a289225..ee46d3a 100644 --- a/include/configs/topic_miami.h +++ b/include/configs/topic_miami.h @@ -56,7 +56,6 @@ #undef CONFIG_SF_DEFAULT_SPEED #define CONFIG_SF_DEFAULT_SPEED 108000000 #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#undef CONFIG_SF_DUAL_FLASH #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #undef CONFIG_SPI_FLASH_WINBOND #undef CONFIG_SPI_FLASH_ISSI diff --git a/include/configs/topic_miamiplus.h b/include/configs/topic_miamiplus.h deleted file mode 100644 index 46ca6bd..0000000 --- a/include/configs/topic_miamiplus.h +++ /dev/null @@ -1,2 +0,0 @@ -#include "topic_miami.h" -#define CONFIG_SF_DUAL_FLASH diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e8f49eb..642c433 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2401,7 +2401,6 @@ CONFIG_SF_DEFAULT_BUS CONFIG_SF_DEFAULT_CS CONFIG_SF_DEFAULT_MODE CONFIG_SF_DEFAULT_SPEED -CONFIG_SF_DUAL_FLASH CONFIG_SGI_IP28 CONFIG_SH4_PCI CONFIG_SH73A0
Signed-off-by: Mike Looijmans mike.looijmans@topic.nl --- arch/arm/dts/Makefile | 1 + arch/arm/dts/zynq-topic-miamilite.dts | 17 ++ .../topic/zynq/zynq-topic-miamilite/ps7_init_gpl.c | 227 +++++++++++++++++++++ board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt | 61 ++++++ configs/topic_miamilite_defconfig | 53 +++++ 5 files changed, 359 insertions(+) create mode 100644 arch/arm/dts/zynq-topic-miamilite.dts create mode 100644 board/topic/zynq/zynq-topic-miamilite/ps7_init_gpl.c create mode 100644 board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt create mode 100644 configs/topic_miamilite_defconfig
Michal Simek
Michal Simek
Mike Looijmans
