[U-Boot-Users] [PATCH 00/18] avr32 patches for 1.3.4
The 18 patches posted as followups to this mail are avr32-related changes I intend to get merged before the end of this merge window. Please review -- I'm going to push all of it into master in a couple of days unless I hear any complaints.
Note to any out-of-tree board maintainers: You need to pay special attention to patches 5 and 12 and update your linker script the same way as is done for ATSTK1000 and ATNGW100. Basically you need to * Add "*(.exception.text)" to the beginning of the .text section * Remove everything related to the .flashprog section
You can try out everything by pulling the "for-1.3.4" branch of
git://git.denx.de/u-boot-avr32.git for-1.3.4
Shortlog and diffstat for the whole series follows. David Brownell (2): avr32: stk1002 and ngw100 convergence avr32: Disable the AP7000 internal watchdog on startup
Haavard Skinnemoen (16): avr32: Use correct condition around macb clock accessors avr32: Remove unneeded .flashprog section from NGW100 ldscript avr32: Get rid of the .flashprog section avr32: Add support for the ATSTK1006 board avr32: Clean up the HMATRIX code avr32: Remove unused file cpu/at32ap/pm.c avr32: Use new-style Makefile for the at32ap platform avr32: Rename pm_init() as clk_init() and make SoC-specific avr32: Put memset in its own section avr32: Use the same entry point for reset and exception handling avr32: Do stricter stack checking in the exception handler avr32: Rework SDRAM initialization code atmel_usart: Support fractional baud rate dividers avr32: Fix two warnings in atmel_mci.c avr32: Fix wrong error flags in atmel_mci driver avr32: Compile atmel_mci.o conditionally
MAINTAINERS | 1 + MAKEALL | 1 + Makefile | 3 + board/atmel/atngw100/atngw100.c | 27 ++- board/atmel/atngw100/u-boot.lds | 9 +- board/atmel/atstk1000/atstk1000.c | 54 +++++- board/atmel/atstk1000/flash.c | 6 +- board/atmel/atstk1000/u-boot.lds | 9 +- cpu/at32ap/Makefile | 20 ++- cpu/at32ap/at32ap700x/Makefile | 2 +- cpu/at32ap/at32ap700x/clk.c | 68 +++++++ cpu/at32ap/{ => at32ap700x}/sm.h | 0 cpu/at32ap/atmel_mci.c | 12 +- cpu/at32ap/cpu.c | 50 +----- cpu/at32ap/entry.S | 64 ------- cpu/at32ap/exception.c | 3 +- cpu/at32ap/hsdramc.c | 102 ++++------- cpu/at32ap/pm.c | 42 ----- cpu/at32ap/start.S | 129 ++++++++++++- drivers/serial/atmel_usart.c | 14 ++- drivers/serial/atmel_usart.h | 2 + include/asm-avr32/arch-at32ap700x/clk.h | 4 +- include/asm-avr32/arch-at32ap700x/hmatrix.h | 61 ++++++ include/asm-avr32/arch-at32ap700x/hmatrix2.h | 232 ------------------------ include/asm-avr32/arch-at32ap700x/memory-map.h | 20 ++ include/asm-avr32/hmatrix-common.h | 131 +++++++++++++ include/asm-avr32/sdram.h | 27 +++- include/asm-avr32/sections.h | 7 - include/configs/atngw100.h | 26 +-- include/configs/atstk1002.h | 19 +- include/configs/atstk1003.h | 15 +- include/configs/atstk1004.h | 16 +- include/configs/{atstk1002.h => atstk1006.h} | 21 +- lib_avr32/memset.S | 2 +- 34 files changed, 632 insertions(+), 567 deletions(-) create mode 100644 cpu/at32ap/at32ap700x/clk.c rename cpu/at32ap/{ => at32ap700x}/sm.h (100%) delete mode 100644 cpu/at32ap/entry.S delete mode 100644 cpu/at32ap/pm.c create mode 100644 include/asm-avr32/arch-at32ap700x/hmatrix.h delete mode 100644 include/asm-avr32/arch-at32ap700x/hmatrix2.h create mode 100644 include/asm-avr32/hmatrix-common.h copy include/configs/{atstk1002.h => atstk1006.h} (92%)
Make STK1002 and NGW100 boards act more alike: - STK boards can use as many arguments as NGW - STK boards don't need to manage FPGAs either - NGW commands should match STK ones
Also spell U-Boot right in prompts for STK1002 and NGW100.
Signed-off-by: David Brownell dbrownell@users.sourceforge.net [haavard.skinnemoen@atmel.com: update STK100[34] as well] Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- include/configs/atngw100.h | 5 ++++- include/configs/atstk1002.h | 6 +++--- include/configs/atstk1003.h | 2 +- include/configs/atstk1004.h | 2 +- 4 files changed, 9 insertions(+), 6 deletions(-)
diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 5aad043..313298a 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -112,8 +112,11 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC + +#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_XIMG
#define CONFIG_ATMEL_USART 1 #define CONFIG_MACB 1 @@ -164,7 +167,7 @@ #define CFG_BOOTPARAMS_LEN (16 * 1024)
/* Other configuration settings that shouldn't have to change all that often */ -#define CFG_PROMPT "Uboot> " +#define CFG_PROMPT "U-Boot> " #define CFG_CBSIZE 256 #define CFG_MAXARGS 16 #define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 95aeab6..f652b28 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -139,9 +139,9 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC -#define CONFIG_CMD_REGINFO
#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_FPGA #undef CONFIG_CMD_SETGETDCR #undef CONFIG_CMD_XIMG
@@ -189,9 +189,9 @@ #define CFG_BOOTPARAMS_LEN (16 * 1024)
/* Other configuration settings that shouldn't have to change all that often */ -#define CFG_PROMPT "Uboot> " +#define CFG_PROMPT "U-Boot> " #define CFG_CBSIZE 256 -#define CFG_MAXARGS 8 +#define CFG_MAXARGS 16 #define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) #define CFG_LONGHELP 1
diff --git a/include/configs/atstk1003.h b/include/configs/atstk1003.h index 194788b..2d981cc 100644 --- a/include/configs/atstk1003.h +++ b/include/configs/atstk1003.h @@ -171,7 +171,7 @@ #define CFG_BOOTPARAMS_LEN (16 * 1024)
/* Other configuration settings that shouldn't have to change all that often */ -#define CFG_PROMPT "Uboot> " +#define CFG_PROMPT "U-Boot> " #define CFG_CBSIZE 256 #define CFG_MAXARGS 16 #define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) diff --git a/include/configs/atstk1004.h b/include/configs/atstk1004.h index b81fc21..235c1cc 100644 --- a/include/configs/atstk1004.h +++ b/include/configs/atstk1004.h @@ -172,7 +172,7 @@ #define CFG_BOOTPARAMS_LEN (16 * 1024)
This patch forces the watchdog off in all cases. That will at least get rid of the constant reboot cycle, though it won't let the watchdog actually run in the new kernels: its probe() comes up with a polite warning.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- cpu/at32ap/cpu.c | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/cpu/at32ap/cpu.c b/cpu/at32ap/cpu.c index 311466b..4542e67 100644 --- a/cpu/at32ap/cpu.c +++ b/cpu/at32ap/cpu.c @@ -86,6 +86,10 @@ int cpu_init(void) extern void _evba(void); char *p;
+ /* in case of soft resets, disable watchdog */ + sm_writel(WDT_CTRL, SM_BF(KEY, 0x55)); + sm_writel(WDT_CTRL, SM_BF(KEY, 0xaa)); + gd->cpu_hz = CFG_OSC0_HZ;
/* TODO: Move somewhere else, but needs to be run before we
get_macb_pclk_rate() and get_macb_hclk_rate() should be available when the chip has a MACB controller, not when it has a USART.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- include/asm-avr32/arch-at32ap700x/clk.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/asm-avr32/arch-at32ap700x/clk.h b/include/asm-avr32/arch-at32ap700x/clk.h index 385319a..309fda5 100644 --- a/include/asm-avr32/arch-at32ap700x/clk.h +++ b/include/asm-avr32/arch-at32ap700x/clk.h @@ -58,7 +58,7 @@ static inline unsigned long get_usart_clk_rate(unsigned int dev_id) return get_pba_clk_rate(); } #endif -#ifdef AT32AP700x_CHIP_HAS_USART +#ifdef AT32AP700x_CHIP_HAS_MACB static inline unsigned long get_macb_pclk_rate(unsigned int dev_id) { return get_pbb_clk_rate();
The .flashprog section was only needed back when we were running directly from flash, and it's even more useless on NGW100 since it uses the CFI flash driver which never used this workaround in the first place.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- board/atmel/atngw100/u-boot.lds | 8 -------- 1 files changed, 0 insertions(+), 8 deletions(-)
diff --git a/board/atmel/atngw100/u-boot.lds b/board/atmel/atngw100/u-boot.lds index 34e347a..3c878d8 100644 --- a/board/atmel/atngw100/u-boot.lds +++ b/board/atmel/atngw100/u-boot.lds @@ -32,14 +32,6 @@ SECTIONS *(.text) *(.text.*) } - - . = ALIGN(32); - __flashprog_start = .; - .flashprog : { - *(.flashprog) - } - . = ALIGN(32); - __flashprog_end = .; _etext = .;
.rodata : {
The .flashprog section was only needed back when we were running directly from flash. Remove it on STK1000, and get rid of all the associated code and annotations.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- board/atmel/atstk1000/flash.c | 6 +++--- board/atmel/atstk1000/u-boot.lds | 8 -------- cpu/at32ap/cpu.c | 6 ------ include/asm-avr32/sections.h | 7 ------- 4 files changed, 3 insertions(+), 24 deletions(-)
diff --git a/board/atmel/atstk1000/flash.c b/board/atmel/atstk1000/flash.c index 4047825..12537f3 100644 --- a/board/atmel/atstk1000/flash.c +++ b/board/atmel/atstk1000/flash.c @@ -30,7 +30,7 @@ DECLARE_GLOBAL_DATA_PTR;
flash_info_t flash_info[1];
-static void __flashprog flash_identify(uint16_t *flash, flash_info_t *info) +static void flash_identify(uint16_t *flash, flash_info_t *info) { unsigned long flags;
@@ -76,7 +76,7 @@ void flash_print_info(flash_info_t *info) info->size >> 10, info->sector_count); }
-int __flashprog flash_erase(flash_info_t *info, int s_first, int s_last) +int flash_erase(flash_info_t *info, int s_first, int s_last) { unsigned long flags; unsigned long start_time; @@ -154,7 +154,7 @@ int __flashprog flash_erase(flash_info_t *info, int s_first, int s_last) return ERR_OK; }
-int __flashprog write_buff(flash_info_t *info, uchar *src, +int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong count) { unsigned long flags; diff --git a/board/atmel/atstk1000/u-boot.lds b/board/atmel/atstk1000/u-boot.lds index 247812e..f63bc4f 100644 --- a/board/atmel/atstk1000/u-boot.lds +++ b/board/atmel/atstk1000/u-boot.lds @@ -32,14 +32,6 @@ SECTIONS *(.text) *(.text.*) } - - . = ALIGN(32); - __flashprog_start = .; - .flashprog : { - *(.flashprog) - } - . = ALIGN(32); - __flashprog_end = .; _etext = .;
.rodata : { diff --git a/cpu/at32ap/cpu.c b/cpu/at32ap/cpu.c index 4542e67..a7a66cc 100644 --- a/cpu/at32ap/cpu.c +++ b/cpu/at32ap/cpu.c @@ -84,7 +84,6 @@ static void pm_init(void) int cpu_init(void) { extern void _evba(void); - char *p;
/* in case of soft resets, disable watchdog */ sm_writel(WDT_CTRL, SM_BF(KEY, 0x55)); @@ -104,11 +103,6 @@ int cpu_init(void) sysreg_write(EVBA, (unsigned long)&_evba); asm volatile("csrf %0" : : "i"(SYSREG_EM_OFFSET));
- /* Lock everything that mess with the flash in the icache */ - for (p = __flashprog_start; p <= (__flashprog_end + CFG_ICACHE_LINESZ); - p += CFG_ICACHE_LINESZ) - asm volatile("cache %0, 0x02" : "=m"(*p) :: "memory"); - return 0; }
diff --git a/include/asm-avr32/sections.h b/include/asm-avr32/sections.h index 75373ab..fe819b2 100644 --- a/include/asm-avr32/sections.h +++ b/include/asm-avr32/sections.h @@ -25,15 +25,8 @@ /* References to section boundaries */
extern char _text[], _etext[]; -extern char __flashprog_start[], __flashprog_end[]; extern char _data[], __data_lma[], _edata[], __edata_lma[]; extern char __got_start[], __got_lma[], __got_end[]; extern char _end[];
-/* - * Everything in .flashprog will be locked in the icache so it doesn't - * get disturbed when executing flash commands. - */ -#define __flashprog __attribute__((section(".flashprog"), __noinline__)) - #endif /* __ASM_AVR32_SECTIONS_H */
This is a replacement for ATSTK1002 with 64MB SDRAM and NAND flash on board. It's currently in production and will be available soon.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- MAINTAINERS | 1 + MAKEALL | 1 + Makefile | 3 + board/atmel/atstk1000/atstk1000.c | 20 ++++ include/configs/atstk1006.h | 202 +++++++++++++++++++++++++++++++++++++ 5 files changed, 227 insertions(+), 0 deletions(-) create mode 100644 include/configs/atstk1006.h
diff --git a/MAINTAINERS b/MAINTAINERS index ac7572c..2d8fd58 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -695,6 +695,7 @@ Haavard Skinnemoen hskinnemoen@atmel.com ATSTK1002 AT32AP7000 ATSTK1003 AT32AP7001 ATSTK1004 AT32AP7002 + ATSTK1006 AT32AP7000 ATNGW100 AT32AP7000
######################################################################### diff --git a/MAKEALL b/MAKEALL index 0674069..f40de23 100755 --- a/MAKEALL +++ b/MAKEALL @@ -697,6 +697,7 @@ LIST_avr32=" \ atstk1002 \ atstk1003 \ atstk1004 \ + atstk1006 \ atngw100 \ "
diff --git a/Makefile b/Makefile index 3401203..154e592 100644 --- a/Makefile +++ b/Makefile @@ -2879,6 +2879,9 @@ atstk1003_config : unconfig atstk1004_config : unconfig @$(MKCONFIG) $(@:_config=) avr32 at32ap atstk1000 atmel at32ap700x
+atstk1006_config : unconfig + @$(MKCONFIG) $(@:_config=) avr32 at32ap atstk1000 atmel at32ap700x + atngw100_config : unconfig @$(MKCONFIG) $(@:_config=) avr32 at32ap atngw100 atmel at32ap700x
diff --git a/board/atmel/atstk1000/atstk1000.c b/board/atmel/atstk1000/atstk1000.c index 28f64c4..d3580a1 100644 --- a/board/atmel/atstk1000/atstk1000.c +++ b/board/atmel/atstk1000/atstk1000.c @@ -29,6 +29,25 @@
+#ifdef CONFIG_ATSTK1006 +/* Dual MT48LC16M16A2-7E on daughterboard */ +static const struct sdram_info sdram = { + .phys_addr = CFG_SDRAM_BASE, + .row_bits = 13, + .col_bits = 9, + .bank_bits = 2, + .cas = 2, + .twr = 2, + .trc = 7, + .trp = 2, + .trcd = 2, + .tras = 4, + .txsr = 7, + /* 7.81 us */ + .refresh_period = (781 * (SDRAMC_BUS_HZ / 1000)) / 100000, +}; +#else +/* MT48LC2M32B2-5 on motherboard */ static const struct sdram_info sdram = { .phys_addr = CFG_SDRAM_BASE, .row_bits = 11, @@ -44,6 +63,7 @@ static const struct sdram_info sdram = { /* 15.6 us */ .refresh_period = (156 * (SDRAMC_BUS_HZ / 1000)) / 10000, }; +#endif
int board_early_init_f(void) { diff --git a/include/configs/atstk1006.h b/include/configs/atstk1006.h new file mode 100644 index 0000000..2f9da4b --- /dev/null +++ b/include/configs/atstk1006.h @@ -0,0 +1,202 @@ +/* + * Copyright (C) 2005-2006 Atmel Corporation + * + * Configuration settings for the ATSTK1002 CPU daughterboard + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_AVR32 1 +#define CONFIG_AT32AP 1 +#define CONFIG_AT32AP7000 1 +#define CONFIG_ATSTK1006 1 +#define CONFIG_ATSTK1000 1 + +#define CONFIG_ATSTK1000_EXT_FLASH 1 + +/* + * Timer clock frequency. We're using the CPU-internal COUNT register + * for this, so this is equivalent to the CPU core clock frequency + */ +#define CFG_HZ 1000 + +/* + * Set up the PLL to run at 140 MHz, the CPU to run at the PLL + * frequency, the HSB and PBB at 1/2, and the PBA to run at 1/4 the + * PLL frequency. + * (CFG_OSC0_HZ * CFG_PLL0_MUL) / CFG_PLL0_DIV = PLL MHz + */ +#define CONFIG_PLL 1 +#define CFG_POWER_MANAGER 1 +#define CFG_OSC0_HZ 20000000 +#define CFG_PLL0_DIV 1 +#define CFG_PLL0_MUL 7 +#define CFG_PLL0_SUPPRESS_CYCLES 16 +/* + * Set the CPU running at: + * PLL / (2^CFG_CLKDIV_CPU) = CPU MHz + */ +#define CFG_CLKDIV_CPU 0 +/* + * Set the HSB running at: + * PLL / (2^CFG_CLKDIV_HSB) = HSB MHz + */ +#define CFG_CLKDIV_HSB 1 +/* + * Set the PBA running at: + * PLL / (2^CFG_CLKDIV_PBA) = PBA MHz + */ +#define CFG_CLKDIV_PBA 2 +/* + * Set the PBB running at: + * PLL / (2^CFG_CLKDIV_PBB) = PBB MHz + */ +#define CFG_CLKDIV_PBB 1 + +/* + * The PLLOPT register controls the PLL like this: + * icp = PLLOPT<2> + * ivco = PLLOPT<1:0> + * + * We want icp=1 (default) and ivco=0 (80-160 MHz) or ivco=2 (150-240MHz). + */ +#define CFG_PLL0_OPT 0x04 + +#undef CONFIG_USART0 +#define CONFIG_USART1 1 +#undef CONFIG_USART2 +#undef CONFIG_USART3 + +/* User serviceable stuff */ +#define CONFIG_DOS_PARTITION 1 + +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_STACKSIZE (2048) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTARGS \ + "console=ttyS0 root=mtd3 fbmem=2400k" + +#define CONFIG_BOOTCOMMAND \ + "fsload; bootm $(fileaddr)" + +/* + * Only interrupt autoboot if <space> is pressed. Otherwise, garbage + * data on the serial line may interrupt the boot sequence. + */ +#define CONFIG_BOOTDELAY 1 +#define CONFIG_AUTOBOOT 1 +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT \ + "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_DELAY_STR "d" +#define CONFIG_AUTOBOOT_STOP_STR " " + +/* + * After booting the board for the first time, new ethernet addresses + * should be generated and assigned to the environment variables + * "ethaddr" and "eth1addr". This is normally done during production. + */ +#define CONFIG_OVERWRITE_ETHADDR_ONCE 1 +#define CONFIG_NET_MULTI 1 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_BOOTP_GATEWAY + + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MMC +#define CONFIG_CMD_REGINFO + +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_XIMG + +#define CONFIG_ATMEL_USART 1 +#define CONFIG_MACB 1 +#define CONFIG_PIO2 1 +#define CFG_NR_PIOS 5 +#define CFG_HSDRAMC 1 +#define CONFIG_MMC 1 + +#define CFG_DCACHE_LINESZ 32 +#define CFG_ICACHE_LINESZ 32 + +#define CONFIG_NR_DRAM_BANKS 1 + +/* External flash on STK1000 */ +#if 0 +#define CFG_FLASH_CFI 1 +#define CFG_FLASH_CFI_DRIVER 1 +#endif + +#define CFG_FLASH_BASE 0x00000000 +#define CFG_FLASH_SIZE 0x800000 +#define CFG_MAX_FLASH_BANKS 1 +#define CFG_MAX_FLASH_SECT 135 + +#define CFG_MONITOR_BASE CFG_FLASH_BASE + +#define CFG_INTRAM_BASE 0x24000000 +#define CFG_INTRAM_SIZE 0x8000 + +#define CFG_SDRAM_BASE 0x10000000 + +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_SIZE 65536 +#define CFG_ENV_ADDR (CFG_FLASH_BASE + CFG_FLASH_SIZE - CFG_ENV_SIZE) + +#define CFG_INIT_SP_ADDR (CFG_INTRAM_BASE + CFG_INTRAM_SIZE) + +#define CFG_MALLOC_LEN (256*1024) +#define CFG_DMA_ALLOC_LEN (16384) + +/* Allow 4MB for the kernel run-time image */ +#define CFG_LOAD_ADDR (CFG_SDRAM_BASE + 0x00400000) +#define CFG_BOOTPARAMS_LEN (16 * 1024) + +/* Other configuration settings that shouldn't have to change all that often */ +#define CFG_PROMPT "Uboot> " +#define CFG_CBSIZE 256 +#define CFG_MAXARGS 16 +#define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) +#define CFG_LONGHELP 1 + +#define CFG_MEMTEST_START CFG_SDRAM_BASE +#define CFG_MEMTEST_END (CFG_MEMTEST_START + 0x3f00000) +#define CFG_BAUDRATE_TABLE { 115200, 38400, 19200, 9600, 2400 } + +#endif /* __CONFIG_H */
Rework the HMATRIX configuration interface so that it becomes easier to configure the HMATRIX for boards with special needs, and add new parts.
The HMATRIX header file has been split into a general, chip-independent part with register definitions, etc. and a chip-specific part with SFR bitfield definitions and master/slave identifiers.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- board/atmel/atngw100/atngw100.c | 6 +- board/atmel/atstk1000/atstk1000.c | 6 +- include/asm-avr32/arch-at32ap700x/hmatrix.h | 61 +++++++ include/asm-avr32/arch-at32ap700x/hmatrix2.h | 232 -------------------------- include/asm-avr32/hmatrix-common.h | 131 +++++++++++++++ 5 files changed, 198 insertions(+), 238 deletions(-) create mode 100644 include/asm-avr32/arch-at32ap700x/hmatrix.h delete mode 100644 include/asm-avr32/arch-at32ap700x/hmatrix2.h create mode 100644 include/asm-avr32/hmatrix-common.h
diff --git a/board/atmel/atngw100/atngw100.c b/board/atmel/atngw100/atngw100.c index 1ccbe2c..3ff6f0f 100644 --- a/board/atmel/atngw100/atngw100.c +++ b/board/atmel/atngw100/atngw100.c @@ -25,7 +25,7 @@ #include <asm/sdram.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> -#include <asm/arch/hmatrix2.h> +#include <asm/arch/hmatrix.h>
@@ -47,8 +47,8 @@ static const struct sdram_info sdram = {
int board_early_init_f(void) { - /* Set the SDRAM_ENABLE bit in the HEBI SFR */ - hmatrix2_writel(SFR4, 1 << 1); + /* Enable SDRAM in the EBI mux */ + hmatrix_slave_write(EBI, SFR, HMATRIX_BIT(EBI_SDRAM_ENABLE));
gpio_enable_ebi(); gpio_enable_usart1(); diff --git a/board/atmel/atstk1000/atstk1000.c b/board/atmel/atstk1000/atstk1000.c index d3580a1..52fec65 100644 --- a/board/atmel/atstk1000/atstk1000.c +++ b/board/atmel/atstk1000/atstk1000.c @@ -25,7 +25,7 @@ #include <asm/sdram.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> -#include <asm/arch/hmatrix2.h> +#include <asm/arch/hmatrix.h>
@@ -67,8 +67,8 @@ static const struct sdram_info sdram = {
gpio_enable_ebi(); gpio_enable_usart1(); diff --git a/include/asm-avr32/arch-at32ap700x/hmatrix.h b/include/asm-avr32/arch-at32ap700x/hmatrix.h new file mode 100644 index 0000000..d6b6263 --- /dev/null +++ b/include/asm-avr32/arch-at32ap700x/hmatrix.h @@ -0,0 +1,61 @@ +/* + * Copyright (C) 2008 Atmel Corporation + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __ASM_AVR32_ARCH_HMATRIX_H__ +#define __ASM_AVR32_ARCH_HMATRIX_H__ + +#include <asm/hmatrix-common.h> + +/* Bitfields in SFR4 (EBI) */ +#define HMATRIX_EBI_SDRAM_ENABLE_OFFSET 1 +#define HMATRIX_EBI_SDRAM_ENABLE_SIZE 1 +#define HMATRIX_EBI_NAND_ENABLE_OFFSET 3 +#define HMATRIX_EBI_NAND_ENABLE_SIZE 1 +#define HMATRIX_EBI_CF0_ENABLE_OFFSET 4 +#define HMATRIX_EBI_CF0_ENABLE_SIZE 1 +#define HMATRIX_EBI_CF1_ENABLE_OFFSET 5 +#define HMATRIX_EBI_CF1_ENABLE_SIZE 1 +#define HMATRIX_EBI_PULLUP_DISABLE_OFFSET 8 +#define HMATRIX_EBI_PULLUP_DISABLE_SIZE 1 + +/* HSB masters */ +#define HMATRIX_MASTER_CPU_DCACHE 0 +#define HMATRIX_MASTER_CPU_ICACHE 1 +#define HMATRIX_MASTER_PDC 2 +#define HMATRIX_MASTER_ISI 3 +#define HMATRIX_MASTER_USBA 4 +#define HMATRIX_MASTER_LCDC 5 +#define HMATRIX_MASTER_MACB0 6 +#define HMATRIX_MASTER_MACB1 7 +#define HMATRIX_MASTER_DMACA_M0 8 +#define HMATRIX_MASTER_DMACA_M1 9 + +/* HSB slaves */ +#define HMATRIX_SLAVE_SRAM0 0 +#define HMATRIX_SLAVE_SRAM1 1 +#define HMATRIX_SLAVE_PBA 2 +#define HMATRIX_SLAVE_PBB 3 +#define HMATRIX_SLAVE_EBI 4 +#define HMATRIX_SLAVE_USBA 5 +#define HMATRIX_SLAVE_LCDC 6 +#define HMATRIX_SLAVE_DMACA 7 + +#endif /* __ASM_AVR32_ARCH_HMATRIX_H__ */ diff --git a/include/asm-avr32/arch-at32ap700x/hmatrix2.h b/include/asm-avr32/arch-at32ap700x/hmatrix2.h deleted file mode 100644 index b0e787a..0000000 --- a/include/asm-avr32/arch-at32ap700x/hmatrix2.h +++ /dev/null @@ -1,232 +0,0 @@ -/* - * Register definition for the High-speed Bus Matrix - */ -#ifndef __ASM_AVR32_HMATRIX2_H__ -#define __ASM_AVR32_HMATRIX2_H__ - -/* HMATRIX2 register offsets */ -#define HMATRIX2_MCFG0 0x0000 -#define HMATRIX2_MCFG1 0x0004 -#define HMATRIX2_MCFG2 0x0008 -#define HMATRIX2_MCFG3 0x000c -#define HMATRIX2_MCFG4 0x0010 -#define HMATRIX2_MCFG5 0x0014 -#define HMATRIX2_MCFG6 0x0018 -#define HMATRIX2_MCFG7 0x001c -#define HMATRIX2_MCFG8 0x0020 -#define HMATRIX2_MCFG9 0x0024 -#define HMATRIX2_MCFG10 0x0028 -#define HMATRIX2_MCFG11 0x002c -#define HMATRIX2_MCFG12 0x0030 -#define HMATRIX2_MCFG13 0x0034 -#define HMATRIX2_MCFG14 0x0038 -#define HMATRIX2_MCFG15 0x003c -#define HMATRIX2_SCFG0 0x0040 -#define HMATRIX2_SCFG1 0x0044 -#define HMATRIX2_SCFG2 0x0048 -#define HMATRIX2_SCFG3 0x004c -#define HMATRIX2_SCFG4 0x0050 -#define HMATRIX2_SCFG5 0x0054 -#define HMATRIX2_SCFG6 0x0058 -#define HMATRIX2_SCFG7 0x005c -#define HMATRIX2_SCFG8 0x0060 -#define HMATRIX2_SCFG9 0x0064 -#define HMATRIX2_SCFG10 0x0068 -#define HMATRIX2_SCFG11 0x006c -#define HMATRIX2_SCFG12 0x0070 -#define HMATRIX2_SCFG13 0x0074 -#define HMATRIX2_SCFG14 0x0078 -#define HMATRIX2_SCFG15 0x007c -#define HMATRIX2_PRAS0 0x0080 -#define HMATRIX2_PRBS0 0x0084 -#define HMATRIX2_PRAS1 0x0088 -#define HMATRIX2_PRBS1 0x008c -#define HMATRIX2_PRAS2 0x0090 -#define HMATRIX2_PRBS2 0x0094 -#define HMATRIX2_PRAS3 0x0098 -#define HMATRIX2_PRBS3 0x009c -#define HMATRIX2_PRAS4 0x00a0 -#define HMATRIX2_PRBS4 0x00a4 -#define HMATRIX2_PRAS5 0x00a8 -#define HMATRIX2_PRBS5 0x00ac -#define HMATRIX2_PRAS6 0x00b0 -#define HMATRIX2_PRBS6 0x00b4 -#define HMATRIX2_PRAS7 0x00b8 -#define HMATRIX2_PRBS7 0x00bc -#define HMATRIX2_PRAS8 0x00c0 -#define HMATRIX2_PRBS8 0x00c4 -#define HMATRIX2_PRAS9 0x00c8 -#define HMATRIX2_PRBS9 0x00cc -#define HMATRIX2_PRAS10 0x00d0 -#define HMATRIX2_PRBS10 0x00d4 -#define HMATRIX2_PRAS11 0x00d8 -#define HMATRIX2_PRBS11 0x00dc -#define HMATRIX2_PRAS12 0x00e0 -#define HMATRIX2_PRBS12 0x00e4 -#define HMATRIX2_PRAS13 0x00e8 -#define HMATRIX2_PRBS13 0x00ec -#define HMATRIX2_PRAS14 0x00f0 -#define HMATRIX2_PRBS14 0x00f4 -#define HMATRIX2_PRAS15 0x00f8 -#define HMATRIX2_PRBS15 0x00fc -#define HMATRIX2_MRCR 0x0100 -#define HMATRIX2_SFR0 0x0110 -#define HMATRIX2_SFR1 0x0114 -#define HMATRIX2_SFR2 0x0118 -#define HMATRIX2_SFR3 0x011c -#define HMATRIX2_SFR4 0x0120 -#define HMATRIX2_SFR5 0x0124 -#define HMATRIX2_SFR6 0x0128 -#define HMATRIX2_SFR7 0x012c -#define HMATRIX2_SFR8 0x0130 -#define HMATRIX2_SFR9 0x0134 -#define HMATRIX2_SFR10 0x0138 -#define HMATRIX2_SFR11 0x013c -#define HMATRIX2_SFR12 0x0140 -#define HMATRIX2_SFR13 0x0144 -#define HMATRIX2_SFR14 0x0148 -#define HMATRIX2_SFR15 0x014c -#define HMATRIX2_VERSION 0x01fc - -/* Bitfields in MCFG0 */ -#define HMATRIX2_ULBT_OFFSET 0 -#define HMATRIX2_ULBT_SIZE 3 - -/* Bitfields in SCFG0 */ -#define HMATRIX2_SLOT_CYCLE_OFFSET 0 -#define HMATRIX2_SLOT_CYCLE_SIZE 8 -#define HMATRIX2_DEFMSTR_TYPE_OFFSET 16 -#define HMATRIX2_DEFMSTR_TYPE_SIZE 2 -#define HMATRIX2_FIXED_DEFMSTR_OFFSET 18 -#define HMATRIX2_FIXED_DEFMSTR_SIZE 4 -#define HMATRIX2_ARBT_OFFSET 24 -#define HMATRIX2_ARBT_SIZE 2 - -/* Bitfields in PRAS0 */ -#define HMATRIX2_M0PR_OFFSET 0 -#define HMATRIX2_M0PR_SIZE 4 -#define HMATRIX2_M1PR_OFFSET 4 -#define HMATRIX2_M1PR_SIZE 4 -#define HMATRIX2_M2PR_OFFSET 8 -#define HMATRIX2_M2PR_SIZE 4 -#define HMATRIX2_M3PR_OFFSET 12 -#define HMATRIX2_M3PR_SIZE 4 -#define HMATRIX2_M4PR_OFFSET 16 -#define HMATRIX2_M4PR_SIZE 4 -#define HMATRIX2_M5PR_OFFSET 20 -#define HMATRIX2_M5PR_SIZE 4 -#define HMATRIX2_M6PR_OFFSET 24 -#define HMATRIX2_M6PR_SIZE 4 -#define HMATRIX2_M7PR_OFFSET 28 -#define HMATRIX2_M7PR_SIZE 4 - -/* Bitfields in PRBS0 */ -#define HMATRIX2_M8PR_OFFSET 0 -#define HMATRIX2_M8PR_SIZE 4 -#define HMATRIX2_M9PR_OFFSET 4 -#define HMATRIX2_M9PR_SIZE 4 -#define HMATRIX2_M10PR_OFFSET 8 -#define HMATRIX2_M10PR_SIZE 4 -#define HMATRIX2_M11PR_OFFSET 12 -#define HMATRIX2_M11PR_SIZE 4 -#define HMATRIX2_M12PR_OFFSET 16 -#define HMATRIX2_M12PR_SIZE 4 -#define HMATRIX2_M13PR_OFFSET 20 -#define HMATRIX2_M13PR_SIZE 4 -#define HMATRIX2_M14PR_OFFSET 24 -#define HMATRIX2_M14PR_SIZE 4 -#define HMATRIX2_M15PR_OFFSET 28 -#define HMATRIX2_M15PR_SIZE 4 - -/* Bitfields in MRCR */ -#define HMATRIX2_RBC0_OFFSET 0 -#define HMATRIX2_RBC0_SIZE 1 -#define HMATRIX2_RBC1_OFFSET 1 -#define HMATRIX2_RBC1_SIZE 1 -#define HMATRIX2_RBC2_OFFSET 2 -#define HMATRIX2_RBC2_SIZE 1 -#define HMATRIX2_RBC3_OFFSET 3 -#define HMATRIX2_RBC3_SIZE 1 -#define HMATRIX2_RBC4_OFFSET 4 -#define HMATRIX2_RBC4_SIZE 1 -#define HMATRIX2_RBC5_OFFSET 5 -#define HMATRIX2_RBC5_SIZE 1 -#define HMATRIX2_RBC6_OFFSET 6 -#define HMATRIX2_RBC6_SIZE 1 -#define HMATRIX2_RBC7_OFFSET 7 -#define HMATRIX2_RBC7_SIZE 1 -#define HMATRIX2_RBC8_OFFSET 8 -#define HMATRIX2_RBC8_SIZE 1 -#define HMATRIX2_RBC9_OFFSET 9 -#define HMATRIX2_RBC9_SIZE 1 -#define HMATRIX2_RBC10_OFFSET 10 -#define HMATRIX2_RBC10_SIZE 1 -#define HMATRIX2_RBC11_OFFSET 11 -#define HMATRIX2_RBC11_SIZE 1 -#define HMATRIX2_RBC12_OFFSET 12 -#define HMATRIX2_RBC12_SIZE 1 -#define HMATRIX2_RBC13_OFFSET 13 -#define HMATRIX2_RBC13_SIZE 1 -#define HMATRIX2_RBC14_OFFSET 14 -#define HMATRIX2_RBC14_SIZE 1 -#define HMATRIX2_RBC15_OFFSET 15 -#define HMATRIX2_RBC15_SIZE 1 - -/* Bitfields in SFR0 */ -#define HMATRIX2_SFR_OFFSET 0 -#define HMATRIX2_SFR_SIZE 32 - -/* Bitfields in SFR4 */ -#define HMATRIX2_CS1A_OFFSET 1 -#define HMATRIX2_CS1A_SIZE 1 -#define HMATRIX2_CS3A_OFFSET 3 -#define HMATRIX2_CS3A_SIZE 1 -#define HMATRIX2_CS4A_OFFSET 4 -#define HMATRIX2_CS4A_SIZE 1 -#define HMATRIX2_CS5A_OFFSET 5 -#define HMATRIX2_CS5A_SIZE 1 -#define HMATRIX2_DBPUC_OFFSET 8 -#define HMATRIX2_DBPUC_SIZE 1 - -/* Bitfields in VERSION */ -#define HMATRIX2_VERSION_OFFSET 0 -#define HMATRIX2_VERSION_SIZE 12 -#define HMATRIX2_MFN_OFFSET 16 -#define HMATRIX2_MFN_SIZE 3 - -/* Constants for ULBT */ -#define HMATRIX2_ULBT_INFINITE 0 -#define HMATRIX2_ULBT_SINGLE 1 -#define HMATRIX2_ULBT_FOUR_BEAT 2 -#define HMATRIX2_ULBT_SIXTEEN_BEAT 4 - -/* Constants for DEFMSTR_TYPE */ -#define HMATRIX2_DEFMSTR_TYPE_NO_DEFAULT 0 -#define HMATRIX2_DEFMSTR_TYPE_LAST_DEFAULT 1 -#define HMATRIX2_DEFMSTR_TYPE_FIXED_DEFAULT 2 - -/* Constants for ARBT */ -#define HMATRIX2_ARBT_ROUND_ROBIN 0 -#define HMATRIX2_ARBT_FIXED_PRIORITY 1 - -/* Bit manipulation macros */ -#define HMATRIX2_BIT(name) \ - (1 << HMATRIX2_##name##_OFFSET) -#define HMATRIX2_BF(name,value) \ - (((value) & ((1 << HMATRIX2_##name##_SIZE) - 1)) \ - << HMATRIX2_##name##_OFFSET) -#define HMATRIX2_BFEXT(name,value) \ - (((value) >> HMATRIX2_##name##_OFFSET) \ - & ((1 << HMATRIX2_##name##_SIZE) - 1)) -#define HMATRIX2_BFINS(name,value,old) \ - (((old) & ~(((1 << HMATRIX2_##name##_SIZE) - 1) \ - << HMATRIX2_##name##_OFFSET)) \ - | HMATRIX2_BF(name,value)) - -/* Register access macros */ -#define hmatrix2_readl(reg) \ - readl((void *)HMATRIX_BASE + HMATRIX2_##reg) -#define hmatrix2_writel(reg,value) \ - writel((value), (void *)HMATRIX_BASE + HMATRIX2_##reg) - -#endif /* __ASM_AVR32_HMATRIX2_H__ */ diff --git a/include/asm-avr32/hmatrix-common.h b/include/asm-avr32/hmatrix-common.h new file mode 100644 index 0000000..4b7e610 --- /dev/null +++ b/include/asm-avr32/hmatrix-common.h @@ -0,0 +1,131 @@ +/* + * Copyright (C) 2008 Atmel Corporation + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __ASM_AVR32_HMATRIX_COMMON_H__ +#define __ASM_AVR32_HMATRIX_COMMON_H__ + +/* HMATRIX register offsets */ +struct hmatrix_regs { + u32 MCFG[16]; + u32 SCFG[16]; + struct { + u32 A; + u32 B; + } PRS[16]; + u32 MRCR; + u32 __reserved[3]; + u32 SFR[16]; +}; + +/* Bitfields in MCFG */ +#define HMATRIX_ULBT_OFFSET 0 +#define HMATRIX_ULBT_SIZE 3 + +/* Bitfields in SCFG */ +#define HMATRIX_SLOT_CYCLE_OFFSET 0 +#define HMATRIX_SLOT_CYCLE_SIZE 8 +#define HMATRIX_DEFMSTR_TYPE_OFFSET 16 +#define HMATRIX_DEFMSTR_TYPE_SIZE 2 +#define HMATRIX_FIXED_DEFMSTR_OFFSET 18 +#define HMATRIX_FIXED_DEFMSTR_SIZE 4 +#define HMATRIX_ARBT_OFFSET 24 +#define HMATRIX_ARBT_SIZE 1 + +/* Bitfields in PRS.A */ +#define HMATRIX_M0PR_OFFSET 0 +#define HMATRIX_M0PR_SIZE 4 +#define HMATRIX_M1PR_OFFSET 4 +#define HMATRIX_M1PR_SIZE 4 +#define HMATRIX_M2PR_OFFSET 8 +#define HMATRIX_M2PR_SIZE 4 +#define HMATRIX_M3PR_OFFSET 12 +#define HMATRIX_M3PR_SIZE 4 +#define HMATRIX_M4PR_OFFSET 16 +#define HMATRIX_M4PR_SIZE 4 +#define HMATRIX_M5PR_OFFSET 20 +#define HMATRIX_M5PR_SIZE 4 +#define HMATRIX_M6PR_OFFSET 24 +#define HMATRIX_M6PR_SIZE 4 +#define HMATRIX_M7PR_OFFSET 28 +#define HMATRIX_M7PR_SIZE 4 + +/* Bitfields in PRS.B */ +#define HMATRIX_M8PR_OFFSET 0 +#define HMATRIX_M8PR_SIZE 4 +#define HMATRIX_M9PR_OFFSET 4 +#define HMATRIX_M9PR_SIZE 4 +#define HMATRIX_M10PR_OFFSET 8 +#define HMATRIX_M10PR_SIZE 4 +#define HMATRIX_M11PR_OFFSET 12 +#define HMATRIX_M11PR_SIZE 4 +#define HMATRIX_M12PR_OFFSET 16 +#define HMATRIX_M12PR_SIZE 4 +#define HMATRIX_M13PR_OFFSET 20 +#define HMATRIX_M13PR_SIZE 4 +#define HMATRIX_M14PR_OFFSET 24 +#define HMATRIX_M14PR_SIZE 4 +#define HMATRIX_M15PR_OFFSET 28 +#define HMATRIX_M15PR_SIZE 4 + +/* Constants for ULBT */ +#define HMATRIX_ULBT_INFINITE 0 +#define HMATRIX_ULBT_SINGLE 1 +#define HMATRIX_ULBT_FOUR_BEAT 2 +#define HMATRIX_ULBT_EIGHT_BEAT 3 +#define HMATRIX_ULBT_SIXTEEN_BEAT 4 + +/* Constants for DEFMSTR_TYPE */ +#define HMATRIX_DEFMSTR_TYPE_NO_DEFAULT 0 +#define HMATRIX_DEFMSTR_TYPE_LAST_DEFAULT 1 +#define HMATRIX_DEFMSTR_TYPE_FIXED_DEFAULT 2 + +/* Constants for ARBT */ +#define HMATRIX_ARBT_ROUND_ROBIN 0 +#define HMATRIX_ARBT_FIXED_PRIORITY 1 + +/* Bit manipulation macros */ +#define HMATRIX_BIT(name) \ + (1 << HMATRIX_##name##_OFFSET) +#define HMATRIX_BF(name,value) \ + (((value) & ((1 << HMATRIX_##name##_SIZE) - 1)) \ + << HMATRIX_##name##_OFFSET) +#define HMATRIX_BFEXT(name,value) \ + (((value) >> HMATRIX_##name##_OFFSET) \ + & ((1 << HMATRIX_##name##_SIZE) - 1)) +#define HMATRIX_BFINS(name,value,old) \ + (((old) & ~(((1 << HMATRIX_##name##_SIZE) - 1) \ + << HMATRIX_##name##_OFFSET)) \ + | HMATRIX_BF(name,value)) + +/* Register access macros */ +#define __hmatrix_reg(reg) \ + (((volatile struct hmatrix_regs *)HMATRIX_BASE)->reg) +#define hmatrix_read(reg) \ + (__hmatrix_reg(reg)) +#define hmatrix_write(reg, value) \ + do { __hmatrix_reg(reg) = (value); } while (0) + +#define hmatrix_slave_read(slave, reg) \ + hmatrix_read(reg[HMATRIX_SLAVE_##slave]) +#define hmatrix_slave_write(slave, reg, value) \ + hmatrix_write(reg[HMATRIX_SLAVE_##slave], value) + +#endif /* __ASM_AVR32_HMATRIX_COMMON_H__ */
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- cpu/at32ap/pm.c | 42 ------------------------------------------ 1 files changed, 0 insertions(+), 42 deletions(-) delete mode 100644 cpu/at32ap/pm.c
diff --git a/cpu/at32ap/pm.c b/cpu/at32ap/pm.c deleted file mode 100644 index c78d547..0000000 --- a/cpu/at32ap/pm.c +++ /dev/null @@ -1,42 +0,0 @@ -/* - * Copyright (C) 2006 Atmel Corporation - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#include <common.h> - -#ifdef CFG_POWER_MANAGER -#include <asm/errno.h> -#include <asm/io.h> - -#include <asm/arch/memory-map.h> - -#include "sm.h" - - -#ifdef CONFIG_PLL -#define MAIN_CLK_RATE ((CFG_OSC0_HZ / CFG_PLL0_DIV) * CFG_PLL0_MUL) -#else -#define MAIN_CLK_RATE (CFG_OSC0_HZ) -#endif - -DECLARE_GLOBAL_DATA_PTR; - - -#endif /* CFG_POWER_MANAGER */
This makes it easier to avoid compiling certain files later.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- cpu/at32ap/Makefile | 21 ++++++++++++++------- 1 files changed, 14 insertions(+), 7 deletions(-)
diff --git a/cpu/at32ap/Makefile b/cpu/at32ap/Makefile index f69b1f3..8e384c7 100644 --- a/cpu/at32ap/Makefile +++ b/cpu/at32ap/Makefile @@ -27,13 +27,20 @@ include $(TOPDIR)/config.mk
LIB := $(obj)lib$(CPU).a
-START := start.o -SOBJS := entry.o -COBJS := cpu.o hsdramc.o exception.o cache.o -COBJS += interrupts.o pio.o atmel_mci.o -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) +START-y += start.o + +SOBJS-y += entry.o +COBJS-y += cpu.o +COBJS-y += hsdramc.o +COBJS-y += exception.o +COBJS-y += cache.o +COBJS-y += interrupts.o +COBJS-y += pio.o +COBJS-y += atmel_mci.o + +SRCS := $(START-y:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) +START := $(addprefix $(obj),$(START-y))
all: $(obj).depend $(START) $(LIB)
pm_init() was always more about clock initialization than anything else. Dealing with PLLs, clock gating and such is also inherently SoC-specific, so move it into a SoC-specific directory.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- cpu/at32ap/at32ap700x/Makefile | 2 +- cpu/at32ap/at32ap700x/clk.c | 68 +++++++++++++++++++++++++++++++ cpu/at32ap/{ => at32ap700x}/sm.h | 0 cpu/at32ap/cpu.c | 48 ++------------------- include/asm-avr32/arch-at32ap700x/clk.h | 2 + 5 files changed, 76 insertions(+), 44 deletions(-) create mode 100644 cpu/at32ap/at32ap700x/clk.c rename cpu/at32ap/{ => at32ap700x}/sm.h (100%)
diff --git a/cpu/at32ap/at32ap700x/Makefile b/cpu/at32ap/at32ap700x/Makefile index d276712..7404235 100644 --- a/cpu/at32ap/at32ap700x/Makefile +++ b/cpu/at32ap/at32ap700x/Makefile @@ -24,7 +24,7 @@ include $(TOPDIR)/config.mk
LIB := $(obj)lib$(SOC).a
-COBJS := gpio.o +COBJS := gpio.o clk.o SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS))
diff --git a/cpu/at32ap/at32ap700x/clk.c b/cpu/at32ap/at32ap700x/clk.c new file mode 100644 index 0000000..b3aa034 --- /dev/null +++ b/cpu/at32ap/at32ap700x/clk.c @@ -0,0 +1,68 @@ +/* + * Copyright (C) 2005-2008 Atmel Corporation + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> + +#include <asm/io.h> + +#include <asm/arch/clk.h> +#include <asm/arch/memory-map.h> + +#include "sm.h" + +void clk_init(void) +{ + uint32_t cksel; + + /* in case of soft resets, disable watchdog */ + sm_writel(WDT_CTRL, SM_BF(KEY, 0x55)); + sm_writel(WDT_CTRL, SM_BF(KEY, 0xaa)); + +#ifdef CONFIG_PLL + /* Initialize the PLL */ + sm_writel(PM_PLL0, (SM_BF(PLLCOUNT, CFG_PLL0_SUPPRESS_CYCLES) + | SM_BF(PLLMUL, CFG_PLL0_MUL - 1) + | SM_BF(PLLDIV, CFG_PLL0_DIV - 1) + | SM_BF(PLLOPT, CFG_PLL0_OPT) + | SM_BF(PLLOSC, 0) + | SM_BIT(PLLEN))); + + /* Wait for lock */ + while (!(sm_readl(PM_ISR) & SM_BIT(LOCK0))) ; +#endif + + /* Set up clocks for the CPU and all peripheral buses */ + cksel = 0; + if (CFG_CLKDIV_CPU) + cksel |= SM_BIT(CPUDIV) | SM_BF(CPUSEL, CFG_CLKDIV_CPU - 1); + if (CFG_CLKDIV_HSB) + cksel |= SM_BIT(HSBDIV) | SM_BF(HSBSEL, CFG_CLKDIV_HSB - 1); + if (CFG_CLKDIV_PBA) + cksel |= SM_BIT(PBADIV) | SM_BF(PBASEL, CFG_CLKDIV_PBA - 1); + if (CFG_CLKDIV_PBB) + cksel |= SM_BIT(PBBDIV) | SM_BF(PBBSEL, CFG_CLKDIV_PBB - 1); + sm_writel(PM_CKSEL, cksel); + +#ifdef CONFIG_PLL + /* Use PLL0 as main clock */ + sm_writel(PM_MCCTRL, SM_BIT(PLLSEL)); +#endif +} diff --git a/cpu/at32ap/sm.h b/cpu/at32ap/at32ap700x/sm.h similarity index 100% rename from cpu/at32ap/sm.h rename to cpu/at32ap/at32ap700x/sm.h diff --git a/cpu/at32ap/cpu.c b/cpu/at32ap/cpu.c index a7a66cc..0ba8361 100644 --- a/cpu/at32ap/cpu.c +++ b/cpu/at32ap/cpu.c @@ -30,7 +30,6 @@ #include <asm/arch/memory-map.h>
#include "hsmc3.h" -#include "sm.h"
/* Sanity checks */ #if (CFG_CLKDIV_CPU > CFG_CLKDIV_HSB) \ @@ -44,51 +43,10 @@
-static void pm_init(void) -{ - uint32_t cksel; - -#ifdef CONFIG_PLL - /* Initialize the PLL */ - sm_writel(PM_PLL0, (SM_BF(PLLCOUNT, CFG_PLL0_SUPPRESS_CYCLES) - | SM_BF(PLLMUL, CFG_PLL0_MUL - 1) - | SM_BF(PLLDIV, CFG_PLL0_DIV - 1) - | SM_BF(PLLOPT, CFG_PLL0_OPT) - | SM_BF(PLLOSC, 0) - | SM_BIT(PLLEN))); - - /* Wait for lock */ - while (!(sm_readl(PM_ISR) & SM_BIT(LOCK0))) ; -#endif - - /* Set up clocks for the CPU and all peripheral buses */ - cksel = 0; - if (CFG_CLKDIV_CPU) - cksel |= SM_BIT(CPUDIV) | SM_BF(CPUSEL, CFG_CLKDIV_CPU - 1); - if (CFG_CLKDIV_HSB) - cksel |= SM_BIT(HSBDIV) | SM_BF(HSBSEL, CFG_CLKDIV_HSB - 1); - if (CFG_CLKDIV_PBA) - cksel |= SM_BIT(PBADIV) | SM_BF(PBASEL, CFG_CLKDIV_PBA - 1); - if (CFG_CLKDIV_PBB) - cksel |= SM_BIT(PBBDIV) | SM_BF(PBBSEL, CFG_CLKDIV_PBB - 1); - sm_writel(PM_CKSEL, cksel); - - gd->cpu_hz = get_cpu_clk_rate(); - -#ifdef CONFIG_PLL - /* Use PLL0 as main clock */ - sm_writel(PM_MCCTRL, SM_BIT(PLLSEL)); -#endif -} - int cpu_init(void) { extern void _evba(void);
- /* in case of soft resets, disable watchdog */ - sm_writel(WDT_CTRL, SM_BF(KEY, 0x55)); - sm_writel(WDT_CTRL, SM_BF(KEY, 0xaa)); - gd->cpu_hz = CFG_OSC0_HZ;
/* TODO: Move somewhere else, but needs to be run before we @@ -98,8 +56,12 @@ int cpu_init(void) hsmc3_writel(PULSE0, 0x0b0a0906); hsmc3_writel(SETUP0, 0x00010002);
- pm_init(); + clk_init(); + + /* Update the CPU speed according to the PLL configuration */ + gd->cpu_hz = get_cpu_clk_rate();
+ /* Set up the exception handler table and enable exceptions */ sysreg_write(EVBA, (unsigned long)&_evba); asm volatile("csrf %0" : : "i"(SYSREG_EM_OFFSET));
diff --git a/include/asm-avr32/arch-at32ap700x/clk.h b/include/asm-avr32/arch-at32ap700x/clk.h index 309fda5..4a1dd33 100644 --- a/include/asm-avr32/arch-at32ap700x/clk.h +++ b/include/asm-avr32/arch-at32ap700x/clk.h @@ -75,6 +75,8 @@ static inline unsigned long get_mci_clk_rate(void) } #endif
+extern void clk_init(void); + /* Board code may need the SDRAM base clock as a compile-time constant */ #define SDRAMC_BUS_HZ (MAIN_CLK_RATE >> CFG_CLKDIV_HSB)
All C code is compiled with -ffunction-sections -fdata-sections. Assembly functions should get their own sections as well so that everything looks consistent.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- lib_avr32/memset.S | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/lib_avr32/memset.S b/lib_avr32/memset.S index dc3b09b..79e3c67 100644 --- a/lib_avr32/memset.S +++ b/lib_avr32/memset.S @@ -27,7 +27,7 @@ * * Returns b in r12 */ - .text + .section .text.memset, "ax", @progbits
.global memset .type memset, @function
Since the reset vector is always aligned to a very large boundary, we can save a couple of KB worth of alignment padding by placing the exception vectors at the same address.
Deciding which one it is is easy: If we're handling an exception, the CPU is in Exception mode. If we're starting up after reset, the CPU is in Supervisor mode. So this adds a very minimal overhead to the reset path (only executed once) and the exception handling path (normally never executed at all.)
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- board/atmel/atngw100/u-boot.lds | 1 + board/atmel/atstk1000/u-boot.lds | 1 + cpu/at32ap/Makefile | 1 - cpu/at32ap/entry.S | 64 ------------------- cpu/at32ap/start.S | 129 +++++++++++++++++++++++++++++++++++--- 5 files changed, 122 insertions(+), 74 deletions(-) delete mode 100644 cpu/at32ap/entry.S
diff --git a/board/atmel/atngw100/u-boot.lds b/board/atmel/atngw100/u-boot.lds index 3c878d8..e736adf 100644 --- a/board/atmel/atngw100/u-boot.lds +++ b/board/atmel/atngw100/u-boot.lds @@ -29,6 +29,7 @@ SECTIONS . = 0; _text = .; .text : { + *(.exception.text) *(.text) *(.text.*) } diff --git a/board/atmel/atstk1000/u-boot.lds b/board/atmel/atstk1000/u-boot.lds index f63bc4f..0d3b19c 100644 --- a/board/atmel/atstk1000/u-boot.lds +++ b/board/atmel/atstk1000/u-boot.lds @@ -29,6 +29,7 @@ SECTIONS . = 0; _text = .; .text : { + *(.exception.text) *(.text) *(.text.*) } diff --git a/cpu/at32ap/Makefile b/cpu/at32ap/Makefile index 8e384c7..29f9c0d 100644 --- a/cpu/at32ap/Makefile +++ b/cpu/at32ap/Makefile @@ -29,7 +29,6 @@ LIB := $(obj)lib$(CPU).a
START-y += start.o
-SOBJS-y += entry.o COBJS-y += cpu.o COBJS-y += hsdramc.o COBJS-y += exception.o diff --git a/cpu/at32ap/entry.S b/cpu/at32ap/entry.S deleted file mode 100644 index a6fc688..0000000 --- a/cpu/at32ap/entry.S +++ /dev/null @@ -1,64 +0,0 @@ -/* - * Copyright (C) 2004-2006 Atmel Corporation - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#include <asm/sysreg.h> -#include <asm/ptrace.h> - - .section .text.exception,"ax" - .global _evba - .type _evba,@function - .align 10 -_evba: - .irp x,0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16 - .align 2 - rjmp unknown_exception - .endr - - .global timer_interrupt_handler - .type timer_interrupt_handler,@function - .align 2 -timer_interrupt_handler: - /* - * Increment timer_overflow and re-write COMPARE with 0xffffffff. - * - * We're running at interrupt level 3, so we don't need to save - * r8-r12 or lr to the stack. - */ - lda.w r8, timer_overflow - ld.w r9, r8[0] - mov r10, -1 - mtsr SYSREG_COMPARE, r10 - sub r9, -1 - st.w r8[0], r9 - rete - - .type unknown_exception, @function -unknown_exception: - pushm r0-r12 - sub r8, sp, REG_R12 - REG_R0 - 4 - mov r9, lr - mfsr r10, SYSREG_RAR_EX - mfsr r11, SYSREG_RSR_EX - pushm r8-r11 - mfsr r12, SYSREG_ECR - mov r11, sp - rcall do_unknown_exception -1: rjmp 1b diff --git a/cpu/at32ap/start.S b/cpu/at32ap/start.S index ab8c2b7..907e9b1 100644 --- a/cpu/at32ap/start.S +++ b/cpu/at32ap/start.S @@ -1,5 +1,5 @@ /* - * Copyright (C) 2005-2006 Atmel Corporation + * Copyright (C) 2005-2008 Atmel Corporation * * See file CREDITS for list of people who contributed to this * project. @@ -20,12 +20,9 @@ * MA 02111-1307 USA */ #include <config.h> +#include <asm/ptrace.h> #include <asm/sysreg.h>
-#ifndef PART_SPECIFIC_BOOTSTRAP -# define PART_SPECIFIC_BOOTSTRAP -#endif - #define SYSREG_MMUCR_I_OFFSET 2 #define SYSREG_MMUCR_S_OFFSET 4
@@ -34,11 +31,115 @@ | SYSREG_BIT(FE) | SYSREG_BIT(RE) \ | SYSREG_BIT(IBE) | SYSREG_BIT(IEE))
- .text + /* + * To save some space, we use the same entry point for + * exceptions and reset. This avoids lots of alignment padding + * since the reset vector is always suitably aligned. + */ + .section .exception.text, "ax", @progbits .global _start + .global _evba + .type _start, @function + .type _evba, @function _start: - PART_SPECIFIC_BOOTSTRAP + .size _start, 0 +_evba: + .org 0x00 + rjmp unknown_exception /* Unrecoverable exception */ + .org 0x04 + rjmp unknown_exception /* TLB multiple hit */ + .org 0x08 + rjmp unknown_exception /* Bus error data fetch */ + .org 0x0c + rjmp unknown_exception /* Bus error instruction fetch */ + .org 0x10 + rjmp unknown_exception /* NMI */ + .org 0x14 + rjmp unknown_exception /* Instruction address */ + .org 0x18 + rjmp unknown_exception /* ITLB protection */ + .org 0x1c + rjmp unknown_exception /* Breakpoint */ + .org 0x20 + rjmp unknown_exception /* Illegal opcode */ + .org 0x24 + rjmp unknown_exception /* Unimplemented instruction */ + .org 0x28 + rjmp unknown_exception /* Privilege violation */ + .org 0x2c + rjmp unknown_exception /* Floating-point */ + .org 0x30 + rjmp unknown_exception /* Coprocessor absent */ + .org 0x34 + rjmp unknown_exception /* Data Address (read) */ + .org 0x38 + rjmp unknown_exception /* Data Address (write) */ + .org 0x3c + rjmp unknown_exception /* DTLB Protection (read) */ + .org 0x40 + rjmp unknown_exception /* DTLB Protection (write) */ + .org 0x44 + rjmp unknown_exception /* DTLB Modified */ + + .org 0x50 + rjmp unknown_exception /* ITLB Miss */ + .org 0x60 + rjmp unknown_exception /* DTLB Miss (read) */ + .org 0x70 + rjmp unknown_exception /* DTLB Miss (write) */ + + .size _evba, . - _evba + + .align 2 + .type unknown_exception, @function +unknown_exception: + /* Figure out whether we're handling an exception (Exception + * mode) or just booting (Supervisor mode). */ + csrfcz SYSREG_M1_OFFSET + brcc at32ap_cpu_bootstrap + + /* This is an exception. Complain. */ + pushm r0-r12 + sub r8, sp, REG_R12 - REG_R0 - 4 + mov r9, lr + mfsr r10, SYSREG_RAR_EX + mfsr r11, SYSREG_RSR_EX + pushm r8-r11 + mfsr r12, SYSREG_ECR + mov r11, sp + rcall do_unknown_exception +1: rjmp 1b + + /* The COUNT/COMPARE timer interrupt handler */ + .global timer_interrupt_handler + .type timer_interrupt_handler,@function + .align 2 +timer_interrupt_handler: + /* + * Increment timer_overflow and re-write COMPARE with 0xffffffff. + * + * We're running at interrupt level 3, so we don't need to save + * r8-r12 or lr to the stack. + */ + lda.w r8, timer_overflow + ld.w r9, r8[0] + mov r10, -1 + mtsr SYSREG_COMPARE, r10 + sub r9, -1 + st.w r8[0], r9 + rete
+ /* + * CPU bootstrap after reset is handled here. SoC code may + * override this in case they need to initialize oscillators, + * etc. + */ + .section .text.at32ap_cpu_bootstrap, "ax", @progbits + .global at32ap_cpu_bootstrap + .weak at32ap_cpu_bootstrap + .type at32ap_cpu_bootstrap, @function + .align 2 +at32ap_cpu_bootstrap: /* Reset the Status Register */ mov r0, lo(SR_INIT) orh r0, hi(SR_INIT) @@ -66,9 +167,16 @@ _start: lddpc pc, 1f
.align 2 -1: .long 2f +1: .long at32ap_low_level_init + .size _start, . - _start
-2: lddpc sp, sp_init + /* Common CPU bootstrap code after oscillator/cache/etc. init */ + .section .text.avr32ap_low_level_init, "ax", @progbits + .global at32ap_low_level_init + .type at32ap_low_level_init, @function + .align 2 +at32ap_low_level_init: + lddpc sp, sp_init
/* Initialize the GOT pointer */ lddpc r6, got_init @@ -90,6 +198,7 @@ got_init: * Relocate the u-boot image into RAM and continue from there. * Does not return. */ + .section .text.relocate_code,"ax",@progbits .global relocate_code .type relocate_code,@function relocate_code: @@ -162,3 +271,5 @@ in_ram: .align 2 got_init_reloc: .long 3b - _GLOBAL_OFFSET_TABLE_ + + .size relocate_code, . - relocate_code
Don't do a stack dump if the stack pointer is outside the memory area reserved for stack.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- cpu/at32ap/exception.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/cpu/at32ap/exception.c b/cpu/at32ap/exception.c index 0672685..dc9c300 100644 --- a/cpu/at32ap/exception.c +++ b/cpu/at32ap/exception.c @@ -111,7 +111,8 @@ void do_unknown_exception(unsigned int ecr, struct pt_regs *regs) printf("CPU Mode: %s\n", cpu_modes[mode]);
/* Avoid exception loops */ - if (regs->sp < CFG_SDRAM_BASE || regs->sp >= gd->stack_end) + if (regs->sp < (gd->stack_end - CONFIG_STACKSIZE) + || regs->sp >= gd->stack_end) printf("\nStack pointer seems bogus, won't do stack dump\n"); else dump_mem("\nStack: ", regs->sp, gd->stack_end);
This cleans up the SDRAM initialization and related code a bit, and allows faster booting.
* Add definitions for EBI and internal SRAM to asm/arch/memory-map.h * Remove memory test from sdram_init() and make caller responsible for verifying the SDRAM and determining its size. * Remove base_address member from struct sdram_config (was sdram_info) * Add data_bits member to struct sdram_config and kill CFG_SDRAM_16BIT * Add support for a common STK1000 hack: 16MB SDRAM instead of 8.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- board/atmel/atngw100/atngw100.c | 21 ++++- board/atmel/atstk1000/atstk1000.c | 42 ++++++++--- cpu/at32ap/hsdramc.c | 102 +++++++++--------------- include/asm-avr32/arch-at32ap700x/memory-map.h | 20 +++++ include/asm-avr32/sdram.h | 27 +++++- include/configs/atngw100.h | 21 ++--- include/configs/atstk1002.h | 13 ++-- include/configs/atstk1003.h | 13 ++-- include/configs/atstk1004.h | 14 ++-- include/configs/atstk1006.h | 13 ++-- 10 files changed, 166 insertions(+), 120 deletions(-)
diff --git a/board/atmel/atngw100/atngw100.c b/board/atmel/atngw100/atngw100.c index 3ff6f0f..c649855 100644 --- a/board/atmel/atngw100/atngw100.c +++ b/board/atmel/atngw100/atngw100.c @@ -29,8 +29,8 @@
-static const struct sdram_info sdram = { - .phys_addr = CFG_SDRAM_BASE, +static const struct sdram_config sdram_config = { + .data_bits = SDRAM_DATA_16BIT, .row_bits = 13, .col_bits = 9, .bank_bits = 2, @@ -66,7 +66,22 @@ int board_early_init_f(void)
long int initdram(int board_type) { - return sdram_init(&sdram); + unsigned long expected_size; + unsigned long actual_size; + void *sdram_base; + + sdram_base = map_physmem(EBI_SDRAM_BASE, EBI_SDRAM_SIZE, MAP_NOCACHE); + + expected_size = sdram_init(sdram_base, &sdram_config); + actual_size = get_ram_size(sdram_base, expected_size); + + unmap_physmem(sdram_base, EBI_SDRAM_SIZE); + + if (expected_size != actual_size) + printf("Warning: Only %u of %u MiB SDRAM is working\n", + actual_size >> 20, expected_size >> 20); + + return actual_size; }
void board_init_info(void) diff --git a/board/atmel/atstk1000/atstk1000.c b/board/atmel/atstk1000/atstk1000.c index 52fec65..33bdba6 100644 --- a/board/atmel/atstk1000/atstk1000.c +++ b/board/atmel/atstk1000/atstk1000.c @@ -29,10 +29,10 @@
-#ifdef CONFIG_ATSTK1006 -/* Dual MT48LC16M16A2-7E on daughterboard */ -static const struct sdram_info sdram = { - .phys_addr = CFG_SDRAM_BASE, +static const struct sdram_config sdram_config = { +#if defined(CONFIG_ATSTK1006) + /* Dual MT48LC16M16A2-7E (64 MB) on daughterboard */ + .data_bits = SDRAM_DATA_32BIT, .row_bits = 13, .col_bits = 9, .bank_bits = 2, @@ -45,12 +45,19 @@ static const struct sdram_info sdram = { .txsr = 7, /* 7.81 us */ .refresh_period = (781 * (SDRAMC_BUS_HZ / 1000)) / 100000, -}; #else -/* MT48LC2M32B2-5 on motherboard */ -static const struct sdram_info sdram = { - .phys_addr = CFG_SDRAM_BASE, + /* MT48LC2M32B2P-5 (8 MB) on motherboard */ +#ifdef CONFIG_ATSTK1004 + .data_bits = SDRAM_DATA_16BIT, +#else + .data_bits = SDRAM_DATA_32BIT, +#endif +#ifdef CONFIG_ATSTK1000_16MB_SDRAM + /* MT48LC4M32B2P-6 (16 MB) on mod'ed motherboard */ + .row_bits = 12, +#else .row_bits = 11, +#endif .col_bits = 8, .bank_bits = 2, .cas = 3, @@ -62,8 +69,8 @@ static const struct sdram_info sdram = { .txsr = 5, /* 15.6 us */ .refresh_period = (156 * (SDRAMC_BUS_HZ / 1000)) / 10000, -}; #endif +};
int board_early_init_f(void) { @@ -85,7 +92,22 @@ int board_early_init_f(void)
void board_init_info(void) diff --git a/cpu/at32ap/hsdramc.c b/cpu/at32ap/hsdramc.c index 1fcfe75..992612b 100644 --- a/cpu/at32ap/hsdramc.c +++ b/cpu/at32ap/hsdramc.c @@ -30,39 +30,32 @@
#include "hsdramc1.h"
-unsigned long sdram_init(const struct sdram_info *info) +unsigned long sdram_init(void *sdram_base, const struct sdram_config *config) { - unsigned long *sdram = (unsigned long *)uncached(info->phys_addr); unsigned long sdram_size; - unsigned long tmp; - unsigned long bus_hz; + uint32_t cfgreg; unsigned int i;
- if (!info->refresh_period) - panic("ERROR: SDRAM refresh period == 0. " - "Please update the board code\n"); - - tmp = (HSDRAMC1_BF(NC, info->col_bits - 8) - | HSDRAMC1_BF(NR, info->row_bits - 11) - | HSDRAMC1_BF(NB, info->bank_bits - 1) - | HSDRAMC1_BF(CAS, info->cas) - | HSDRAMC1_BF(TWR, info->twr) - | HSDRAMC1_BF(TRC, info->trc) - | HSDRAMC1_BF(TRP, info->trp) - | HSDRAMC1_BF(TRCD, info->trcd) - | HSDRAMC1_BF(TRAS, info->tras) - | HSDRAMC1_BF(TXSR, info->txsr)); - -#ifdef CFG_SDRAM_16BIT - tmp |= HSDRAMC1_BIT(DBW); - sdram_size = 1 << (info->row_bits + info->col_bits - + info->bank_bits + 1); -#else - sdram_size = 1 << (info->row_bits + info->col_bits - + info->bank_bits + 2); -#endif - - hsdramc1_writel(CR, tmp); + cfgreg = (HSDRAMC1_BF(NC, config->col_bits - 8) + | HSDRAMC1_BF(NR, config->row_bits - 11) + | HSDRAMC1_BF(NB, config->bank_bits - 1) + | HSDRAMC1_BF(CAS, config->cas) + | HSDRAMC1_BF(TWR, config->twr) + | HSDRAMC1_BF(TRC, config->trc) + | HSDRAMC1_BF(TRP, config->trp) + | HSDRAMC1_BF(TRCD, config->trcd) + | HSDRAMC1_BF(TRAS, config->tras) + | HSDRAMC1_BF(TXSR, config->txsr)); + + if (config->data_bits == SDRAM_DATA_16BIT) + cfgreg |= HSDRAMC1_BIT(DBW); + + hsdramc1_writel(CR, cfgreg); + + /* Send a NOP to turn on the clock (necessary on some chips) */ + hsdramc1_writel(MR, HSDRAMC1_MODE_NOP); + hsdramc1_readl(MR); + writel(0, sdram_base);
/* * Initialization sequence for SDRAM, from the data sheet: @@ -77,7 +70,7 @@ unsigned long sdram_init(const struct sdram_info *info) */ hsdramc1_writel(MR, HSDRAMC1_MODE_BANKS_PRECHARGE); hsdramc1_readl(MR); - writel(0, sdram); + writel(0, sdram_base);
/* * 3. Eight auto-refresh (CBR) cycles are provided @@ -85,58 +78,41 @@ unsigned long sdram_init(const struct sdram_info *info) hsdramc1_writel(MR, HSDRAMC1_MODE_AUTO_REFRESH); hsdramc1_readl(MR); for (i = 0; i < 8; i++) - writel(0, sdram); + writel(0, sdram_base);
/* * 4. A mode register set (MRS) cycle is issued to program * SDRAM parameters, in particular CAS latency and burst * length. * - * CAS from info struct, burst length 1, serial burst type + * The address will be chosen by the SDRAMC automatically; we + * just have to make sure BA[1:0] are set to 0. */ hsdramc1_writel(MR, HSDRAMC1_MODE_LOAD_MODE); hsdramc1_readl(MR); - writel(0, sdram + (info->cas << 4)); + writel(0, sdram_base);
/* - * 5. A Normal Mode command is provided, 3 clocks after tMRD - * is met. - * - * From the timing diagram, it looks like tMRD is 3 - * cycles...try a dummy read from the peripheral bus. + * 5. The application must go into Normal Mode, setting Mode + * to 0 in the Mode Register and performing a write access + * at any location in the SDRAM. */ - hsdramc1_readl(MR); hsdramc1_writel(MR, HSDRAMC1_MODE_NORMAL); hsdramc1_readl(MR); - writel(0, sdram); + writel(0, sdram_base);
/* * 6. Write refresh rate into SDRAMC refresh timer count * register (refresh rate = timing between refresh cycles). - * - * 15.6 us is a typical value for a burst of length one */ - bus_hz = get_sdram_clk_rate(); - hsdramc1_writel(TR, info->refresh_period); - - printf("SDRAM: %u MB at address 0x%08lx\n", - sdram_size >> 20, info->phys_addr); - - printf("Testing SDRAM..."); - for (i = 0; i < sdram_size / 4; i++) - sdram[i] = i; - - for (i = 0; i < sdram_size / 4; i++) { - tmp = sdram[i]; - if (tmp != i) { - printf("FAILED at address 0x%08lx\n", - info->phys_addr + i * 4); - printf("SDRAM: read 0x%lx, expected 0x%lx\n", tmp, i); - return 0; - } - } - - puts("OK\n"); + hsdramc1_writel(TR, config->refresh_period); + + if (config->data_bits == SDRAM_DATA_16BIT) + sdram_size = 1 << (config->row_bits + config->col_bits + + config->bank_bits + 1); + else + sdram_size = 1 << (config->row_bits + config->col_bits + + config->bank_bits + 2);
return sdram_size; } diff --git a/include/asm-avr32/arch-at32ap700x/memory-map.h b/include/asm-avr32/arch-at32ap700x/memory-map.h index 5513e88..6592c03 100644 --- a/include/asm-avr32/arch-at32ap700x/memory-map.h +++ b/include/asm-avr32/arch-at32ap700x/memory-map.h @@ -22,6 +22,26 @@ #ifndef __AT32AP7000_MEMORY_MAP_H__ #define __AT32AP7000_MEMORY_MAP_H__
+/* Internal and external memories */ +#define EBI_SRAM_CS0_BASE 0x00000000 +#define EBI_SRAM_CS0_SIZE 0x04000000 +#define EBI_SRAM_CS4_BASE 0x04000000 +#define EBI_SRAM_CS4_SIZE 0x04000000 +#define EBI_SRAM_CS2_BASE 0x08000000 +#define EBI_SRAM_CS2_SIZE 0x04000000 +#define EBI_SRAM_CS3_BASE 0x0c000000 +#define EBI_SRAM_CS3_SIZE 0x04000000 +#define EBI_SRAM_CS1_BASE 0x10000000 +#define EBI_SRAM_CS1_SIZE 0x10000000 +#define EBI_SRAM_CS5_BASE 0x20000000 +#define EBI_SRAM_CS5_SIZE 0x04000000 + +#define EBI_SDRAM_BASE EBI_SRAM_CS1_BASE +#define EBI_SDRAM_SIZE EBI_SRAM_CS1_SIZE + +#define INTERNAL_SRAM_BASE 0x24000000 +#define INTERNAL_SRAM_SIZE 0x00008000 + /* Devices on the High Speed Bus (HSB) */ #define LCDC_BASE 0xFF000000 #define DMAC_BASE 0xFF200000 diff --git a/include/asm-avr32/sdram.h b/include/asm-avr32/sdram.h index 833af6e..7bdefc1 100644 --- a/include/asm-avr32/sdram.h +++ b/include/asm-avr32/sdram.h @@ -22,15 +22,32 @@ #ifndef __ASM_AVR32_SDRAM_H #define __ASM_AVR32_SDRAM_H
-struct sdram_info { - unsigned long phys_addr; - unsigned int row_bits, col_bits, bank_bits; - unsigned int cas, twr, trc, trp, trcd, tras, txsr; +struct sdram_config { + /* Number of data bits. */ + enum { + SDRAM_DATA_16BIT, + SDRAM_DATA_32BIT, + } data_bits; + + /* Number of address bits */ + uint8_t row_bits, col_bits, bank_bits; + + /* SDRAM timings in cycles */ + uint8_t cas, twr, trc, trp, trcd, tras, txsr;
/* SDRAM refresh period in cycles */ unsigned long refresh_period; };
-extern unsigned long sdram_init(const struct sdram_info *info); +/* + * Attempt to initialize the SDRAM controller using the specified + * parameters. Return the expected size of the memory area based on + * the number of address and data bits. + * + * The caller should verify that the configuration is correct by + * running a memory test, e.g. get_ram_size(). + */ +extern unsigned long sdram_init(void *sdram_base, + const struct sdram_config *config);
#endif /* __ASM_AVR32_SDRAM_H */ diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 313298a..3fc9975 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -24,6 +24,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#include <asm/arch/memory-map.h> + #define CONFIG_AVR32 1 #define CONFIG_AT32AP 1 #define CONFIG_AT32AP7000 1 @@ -140,11 +142,9 @@
-#define CFG_INTRAM_BASE 0x24000000 -#define CFG_INTRAM_SIZE 0x8000 - -#define CFG_SDRAM_BASE 0x10000000 -#define CFG_SDRAM_16BIT 1 +#define CFG_INTRAM_BASE INTERNAL_SRAM_BASE +#define CFG_INTRAM_SIZE INTERNAL_SRAM_SIZE +#define CFG_SDRAM_BASE EBI_SDRAM_BASE
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_SIZE 65536 @@ -153,17 +153,10 @@ #define CFG_INIT_SP_ADDR (CFG_INTRAM_BASE + CFG_INTRAM_SIZE)
#define CFG_MALLOC_LEN (256*1024) -#define CFG_MALLOC_END \ - ({ \ - DECLARE_GLOBAL_DATA_PTR; \ - CFG_SDRAM_BASE + gd->sdram_size; \ - }) -#define CFG_MALLOC_START (CFG_MALLOC_END - CFG_MALLOC_LEN) - #define CFG_DMA_ALLOC_LEN (16384)
/* Allow 4MB for the kernel run-time image */ -#define CFG_LOAD_ADDR (CFG_SDRAM_BASE + 0x00400000) +#define CFG_LOAD_ADDR (EBI_SDRAM_BASE + 0x00400000) #define CFG_BOOTPARAMS_LEN (16 * 1024)
/* Other configuration settings that shouldn't have to change all that often */ @@ -173,7 +166,7 @@ #define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) #define CFG_LONGHELP 1
-#define CFG_MEMTEST_START CFG_SDRAM_BASE +#define CFG_MEMTEST_START EBI_SDRAM_BASE #define CFG_MEMTEST_END (CFG_MEMTEST_START + 0x1f00000)
#define CFG_BAUDRATE_TABLE { 115200, 38400, 19200, 9600, 2400 } diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index f652b28..ba18eb6 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -24,6 +24,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#include <asm/arch/memory-map.h> + #define CONFIG_AVR32 1 #define CONFIG_AT32AP 1 #define CONFIG_AT32AP7000 1 @@ -170,10 +172,9 @@
-#define CFG_INTRAM_BASE 0x24000000 -#define CFG_INTRAM_SIZE 0x8000 - -#define CFG_SDRAM_BASE 0x10000000 +#define CFG_INTRAM_BASE INTERNAL_SRAM_BASE +#define CFG_INTRAM_SIZE INTERNAL_SRAM_SIZE +#define CFG_SDRAM_BASE EBI_SDRAM_BASE
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_SIZE 65536 @@ -185,7 +186,7 @@ #define CFG_DMA_ALLOC_LEN (16384)
/* Other configuration settings that shouldn't have to change all that often */ @@ -195,7 +196,7 @@ #define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) #define CFG_LONGHELP 1
-#define CFG_MEMTEST_START CFG_SDRAM_BASE +#define CFG_MEMTEST_START EBI_SDRAM_BASE #define CFG_MEMTEST_END (CFG_MEMTEST_START + 0x700000) #define CFG_BAUDRATE_TABLE { 115200, 38400, 19200, 9600, 2400 }
diff --git a/include/configs/atstk1003.h b/include/configs/atstk1003.h index 2d981cc..a528ddf 100644 --- a/include/configs/atstk1003.h +++ b/include/configs/atstk1003.h @@ -24,6 +24,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#include <asm/arch/memory-map.h> + #define CONFIG_AVR32 1 #define CONFIG_AT32AP 1 #define CONFIG_AT32AP7001 1 @@ -153,10 +155,9 @@
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_SIZE 65536 @@ -167,7 +168,7 @@ #define CFG_MALLOC_LEN (256*1024)
/* Other configuration settings that shouldn't have to change all that often */ @@ -177,7 +178,7 @@ #define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) #define CFG_LONGHELP 1
diff --git a/include/configs/atstk1004.h b/include/configs/atstk1004.h index 235c1cc..fc9585e 100644 --- a/include/configs/atstk1004.h +++ b/include/configs/atstk1004.h @@ -24,6 +24,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#include <asm/arch/memory-map.h> + #define CONFIG_AVR32 1 #define CONFIG_AT32AP 1 #define CONFIG_AT32AP7002 1 @@ -153,11 +155,9 @@
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_SIZE 65536 @@ -168,7 +168,7 @@ #define CFG_MALLOC_LEN (256*1024)
/* Allow 2MB for the kernel run-time image */ -#define CFG_LOAD_ADDR (CFG_SDRAM_BASE + 0x00200000) +#define CFG_LOAD_ADDR (EBI_SDRAM_BASE + 0x00200000) #define CFG_BOOTPARAMS_LEN (16 * 1024)
/* Other configuration settings that shouldn't have to change all that often */ @@ -178,7 +178,7 @@ #define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) #define CFG_LONGHELP 1
diff --git a/include/configs/atstk1006.h b/include/configs/atstk1006.h index 2f9da4b..c3de434 100644 --- a/include/configs/atstk1006.h +++ b/include/configs/atstk1006.h @@ -24,6 +24,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CFG_MEMTEST_START CFG_SDRAM_BASE +#define CFG_MEMTEST_START EBI_SDRAM_BASE #define CFG_MEMTEST_END (CFG_MEMTEST_START + 0x3f00000) #define CFG_BAUDRATE_TABLE { 115200, 38400, 19200, 9600, 2400 }
Newer Atmel chips (post-AT91SAM9261; including AT91SAM9260 and all AVR32 chips) have a "Fractional Part" bitfield in BRGR that allows more precise baud rate generation. Use this field to make the USART work on lower clock frequencies, for example when not using the PLL, on chips that support it.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- drivers/serial/atmel_usart.c | 14 ++++++++++++-- drivers/serial/atmel_usart.h | 2 ++ 2 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index f35b997..61ed308 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -44,6 +44,8 @@ void serial_setbrg(void) { unsigned long divisor; unsigned long usart_hz; + unsigned long cd; + unsigned long fp;
/* * Master Clock @@ -51,8 +53,16 @@ void serial_setbrg(void) * 16 * CD */ usart_hz = get_usart_clk_rate(USART_ID); - divisor = (usart_hz / 16 + gd->baudrate / 2) / gd->baudrate; - usart3_writel(BRGR, USART3_BF(CD, divisor)); + divisor = ((usart_hz + 1) / 2 + gd->baudrate / 2) / gd->baudrate; +#if defined(CONFIG_AT91RM9200) || defined(CONFIG_AT91SAM9261) + /* Some chips don't support fractional dividers */ + cd = (divisor + 4) / 8; + fp = 0; +#else + cd = divisor / 8; + fp = divisor % 8; +#endif + usart3_writel(BRGR, USART3_BF(CD, cd) | USART3_BF(FP, fp)); }
int serial_init(void) diff --git a/drivers/serial/atmel_usart.h b/drivers/serial/atmel_usart.h index af3773a..82da20b 100644 --- a/drivers/serial/atmel_usart.h +++ b/drivers/serial/atmel_usart.h @@ -178,6 +178,8 @@ /* Bitfields in BRGR */ #define USART3_CD_OFFSET 0 #define USART3_CD_SIZE 16 +#define USART3_FP_OFFSET 16 +#define USART3_FP_SIZE 3
/* Bitfields in RTOR */ #define USART3_TO_OFFSET 0
The warnings are harmless but annoying. Let's fix them.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- cpu/at32ap/atmel_mci.c | 6 ++++-- 1 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/cpu/at32ap/atmel_mci.c b/cpu/at32ap/atmel_mci.c index f59dfb5..3ce9ea5 100644 --- a/cpu/at32ap/atmel_mci.c +++ b/cpu/at32ap/atmel_mci.c @@ -182,12 +182,13 @@ static int mmc_acmd(unsigned long cmd, unsigned long arg,
static unsigned long mmc_bread(int dev, unsigned long start, lbaint_t blkcnt, - unsigned long *buffer) + void *buffer) { int ret, i = 0; unsigned long resp[4]; unsigned long card_status, data; unsigned long wordcount; + u32 *p = buffer; u32 status;
if (blkcnt == 0) @@ -225,7 +226,7 @@ mmc_bread(int dev, unsigned long start, lbaint_t blkcnt, if (status & MMCI_BIT(RXRDY)) { data = mmci_readl(RDR); /* pr_debug("%x\n", data); */ - *buffer++ = data; + *p++ = data; wordcount++; } } while(wordcount < (mmc_blkdev.blksz / 4)); @@ -443,6 +444,7 @@ static void mci_set_data_timeout(struct mmc_csd *csd)
dtocyc = timeout_clks; dtomul = 0; + shift = 0; while (dtocyc > 15 && dtomul < 8) { dtomul++; shift = dtomul_to_shift[dtomul];
Make sure we check for CRC errors when sending commands that use CRC checking.
Reported-by: Gururaja Hebbar K R gururajakr@sanyo.co.in Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- cpu/at32ap/atmel_mci.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/cpu/at32ap/atmel_mci.c b/cpu/at32ap/atmel_mci.c index 3ce9ea5..226b5c0 100644 --- a/cpu/at32ap/atmel_mci.c +++ b/cpu/at32ap/atmel_mci.c @@ -139,7 +139,7 @@ mmc_cmd(unsigned long cmd, unsigned long arg,
pr_debug("mmc: status 0x%08lx\n", status);
- if (status & ERROR_FLAGS) { + if (status & error_flags) { printf("mmc: command %lu failed (status: 0x%08lx)\n", cmd, status); return -EIO;
Remove #ifdef CONFIG_MMC from the source file and use conditional compilation in the Makefile instead.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- cpu/at32ap/Makefile | 2 +- cpu/at32ap/atmel_mci.c | 4 ---- 2 files changed, 1 insertions(+), 5 deletions(-)
diff --git a/cpu/at32ap/Makefile b/cpu/at32ap/Makefile index 29f9c0d..d16c58b 100644 --- a/cpu/at32ap/Makefile +++ b/cpu/at32ap/Makefile @@ -35,7 +35,7 @@ COBJS-y += exception.o COBJS-y += cache.o COBJS-y += interrupts.o COBJS-y += pio.o -COBJS-y += atmel_mci.o +COBJS-$(CONFIG_MMC) += atmel_mci.o
SRCS := $(START-y:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) diff --git a/cpu/at32ap/atmel_mci.c b/cpu/at32ap/atmel_mci.c index 226b5c0..3795add 100644 --- a/cpu/at32ap/atmel_mci.c +++ b/cpu/at32ap/atmel_mci.c @@ -21,8 +21,6 @@ */ #include <common.h>
-#ifdef CONFIG_MMC - #include <part.h> #include <mmc.h>
@@ -548,5 +546,3 @@ int mmc2info(ulong addr) { return 0; } - -#endif /* CONFIG_MMC */
What's wrong with the current code? Why are you doing this?
-#ifdef CONFIG_MMC
1.5.5.1
Sincerely,
Ken Fuchs
Because it is the right thing to do. :-)
So that we don't gratuitously compile files that aren't even necessarily involved in the build as per configuration selections. This is all part of the longer term goal of moving to a Kconfig/Kbuild mechanism.
jdl
It is more efficient to avoid starting the C compiler instead of compiling an empty file.
Best Regards Ulf Samuelsson
If the warnings are "harmless", why are you "fixing them"?
The compiler has switches to turn off warnings, if they annoy you too much.
Does this refactoring of the code do something more than just avoid a warning or two? If not, I would reject it.
void *buffer)
if (blkcnt == 0)
*buffer++ = data;
} while(wordcount < (mmc_blkdev.blksz / 4));*p++ = data; wordcount++; }
- shift = 0; while (dtocyc > 15 && dtomul < 8) { dtomul++; shift = dtomul_to_shift[dtomul];
-- 1.5.5.1
Sincerely,
Ken Fuchs
Warnings are never completely harmless -- they make it harder to notice other warnings that point out real problems.
I'd suggest doing the opposite, and enabling -Werror. :-)
-Scott
They are "harmless" as in "doesn't actually cause any wrong behaviour". But as Scott points out, they may make warnings that indicate real problems harder to catch.
For example, if someone comes along and changes the signature of the "block_read" hook in struct block_dev_desc, I may not notice because gcc is _already_ warning about a possible mismatch.
Well, sure. But the "assignment to incompatible pointer type" is usually very good at catching real API violations, so even if it in this case catches code that is merely ugly, turning it off altogether would be the wrong thing to do IMO.
On the other hand, the "may be used uninitialized" warning tends to come up with a lot of false positives, but there's AFAIK no way to turn it off without also turning off the "is used uninitialized" warning, which is very useful.
I wouldn't call these tiny changes "refactoring". And I can't see any downsides except _maybe_ two bytes of additional .text usage.
I have to admit I wasn't sure about this one though:
While I'm no fan of adding spurious initializations just because gcc can't figure out what the code is doing well enough to prove that it is always initialized, I think that in this case, it certainly isn't obvious, and 0 is a reasonable default.
So I decided to add it anyway, just in case later changes makes the assumption invalid.
Haavard
Hmm...I think I'm gonna drop this one since it confuses the Linux driver. It tries to come up with a default baud rate by looking at the BRGR register, but it interprets the FP field as part of the divider, so it will end up at a rate that is way too low.
I'll post a patch to fix the Linux driver, but we shouldn't modify u-boot until the fix has been in mainline for a while.
Haavard
is it possible to use CFG_EXTERNAL_FLASH or something?
In the precedent patch you put U-Boot is possible to do it here too?
+#define CFG_CBSIZE 256 +#define CFG_MAXARGS 16to do it here too? +#define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) +#define CFG_LONGHELP 1
Best Regards, J.
Actually, I've been wanting to switch to the CFI driver for the STK1000 and its derivatives for a long time. However, the (obsolete) AT49BV6416 chip needs a fixup due to wrong erase region information, and there's currently no way to tell it apart from AT49BV642D, which doesn't need the fixup, since the CFI driver only reads the lower 8 bits of the device ID.
So while fixing the CFI driver isn't exactly top priority right now, this #if 0 block is very much intended as a temporary thing.
Absolutely. Nice catch.
I'm going to fold the below patch into this; there were a couple of other things that weren't in sync with patch #1 as well.
Thanks for reviewing!
Haavard
--- include/configs/atstk1006.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/atstk1006.h b/include/configs/atstk1006.h index c3de434..9fd49a5 100644 --- a/include/configs/atstk1006.h +++ b/include/configs/atstk1006.h @@ -141,9 +141,9 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC -#define CONFIG_CMD_REGINFO
#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_FPGA #undef CONFIG_CMD_SETGETDCR #undef CONFIG_CMD_XIMG
@@ -190,7 +190,7 @@ #define CFG_BOOTPARAMS_LEN (16 * 1024)
/* Other configuration settings that shouldn't have to change all that often */ -#define CFG_PROMPT "Uboot> " +#define CFG_PROMPT "U-Boot> " #define CFG_CBSIZE 256 #define CFG_MAXARGS 16 #define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16)
On 14:36 Fri 23 May , Haavard Skinnemoen wrote:
The .flashprog section was only needed back when we were running directly from flash. Remove it on STK1000, and get rid of all the associated code and annotations.
Is it possible to join patch 4 and 5 which take care of the same thing?
board/atmel/atstk1000/flash.c | 6 +++--- board/atmel/atstk1000/u-boot.lds | 8 -------- cpu/at32ap/cpu.c | 6 ------ include/asm-avr32/sections.h | 7 ------- 4 files changed, 3 insertions(+), 24 deletions(-)
Best Regards, J.
Yeah, splitting them up was silly. I'll join them.
The result is below, and I've also updated the for-1.3.4 branch. Thanks!
Haavard
From 82c2cbf8b419347d62f83b6c6eb1319e1188e8e4 Mon Sep 17 00:00:00 2001 From: Haavard Skinnemoen haavard.skinnemoen@atmel.com Date: Tue, 29 Apr 2008 12:53:05 +0200 Subject: [PATCH 04/17] avr32: Get rid of the .flashprog section
The .flashprog section was only needed back when we were running directly from flash, and it's even more useless on NGW100 since it uses the CFI flash driver which never used this workaround in the first place.
Remove it on STK1000 as well, and get rid of all the associated code and annotations.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- board/atmel/atngw100/u-boot.lds | 8 -------- board/atmel/atstk1000/flash.c | 6 +++--- board/atmel/atstk1000/u-boot.lds | 8 -------- cpu/at32ap/cpu.c | 6 ------ include/asm-avr32/sections.h | 7 ------- 5 files changed, 3 insertions(+), 32 deletions(-)
diff --git a/board/atmel/atngw100/u-boot.lds b/board/atmel/atngw100/u-boot.lds index 34e347a..3c878d8 100644 --- a/board/atmel/atngw100/u-boot.lds +++ b/board/atmel/atngw100/u-boot.lds @@ -32,14 +32,6 @@ SECTIONS *(.text) *(.text.*) } - - . = ALIGN(32); - __flashprog_start = .; - .flashprog : { - *(.flashprog) - } - . = ALIGN(32); - __flashprog_end = .; _etext = .;
.rodata : { diff --git a/board/atmel/atstk1000/flash.c b/board/atmel/atstk1000/flash.c index 4047825..12537f3 100644 --- a/board/atmel/atstk1000/flash.c +++ b/board/atmel/atstk1000/flash.c @@ -30,7 +30,7 @@ DECLARE_GLOBAL_DATA_PTR;
flash_info_t flash_info[1];
-static void __flashprog flash_identify(uint16_t *flash, flash_info_t *info) +static void flash_identify(uint16_t *flash, flash_info_t *info) { unsigned long flags;
@@ -76,7 +76,7 @@ void flash_print_info(flash_info_t *info) info->size >> 10, info->sector_count); }
-int __flashprog flash_erase(flash_info_t *info, int s_first, int s_last) +int flash_erase(flash_info_t *info, int s_first, int s_last) { unsigned long flags; unsigned long start_time; @@ -154,7 +154,7 @@ int __flashprog flash_erase(flash_info_t *info, int s_first, int s_last) return ERR_OK; }
-int __flashprog write_buff(flash_info_t *info, uchar *src, +int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong count) { unsigned long flags; diff --git a/board/atmel/atstk1000/u-boot.lds b/board/atmel/atstk1000/u-boot.lds index 247812e..f63bc4f 100644 --- a/board/atmel/atstk1000/u-boot.lds +++ b/board/atmel/atstk1000/u-boot.lds @@ -32,14 +32,6 @@ SECTIONS *(.text) *(.text.*) } - - . = ALIGN(32); - __flashprog_start = .; - .flashprog : { - *(.flashprog) - } - . = ALIGN(32); - __flashprog_end = .; _etext = .;
.rodata : { diff --git a/cpu/at32ap/cpu.c b/cpu/at32ap/cpu.c index 4542e67..a7a66cc 100644 --- a/cpu/at32ap/cpu.c +++ b/cpu/at32ap/cpu.c @@ -84,7 +84,6 @@ static void pm_init(void) int cpu_init(void) { extern void _evba(void); - char *p;
/* in case of soft resets, disable watchdog */ sm_writel(WDT_CTRL, SM_BF(KEY, 0x55)); @@ -104,11 +103,6 @@ int cpu_init(void) sysreg_write(EVBA, (unsigned long)&_evba); asm volatile("csrf %0" : : "i"(SYSREG_EM_OFFSET));
- /* Lock everything that mess with the flash in the icache */ - for (p = __flashprog_start; p <= (__flashprog_end + CFG_ICACHE_LINESZ); - p += CFG_ICACHE_LINESZ) - asm volatile("cache %0, 0x02" : "=m"(*p) :: "memory"); - return 0; }
diff --git a/include/asm-avr32/sections.h b/include/asm-avr32/sections.h index 75373ab..fe819b2 100644 --- a/include/asm-avr32/sections.h +++ b/include/asm-avr32/sections.h @@ -25,15 +25,8 @@ /* References to section boundaries */
extern char _text[], _etext[]; -extern char __flashprog_start[], __flashprog_end[]; extern char _data[], __data_lma[], _edata[], __edata_lma[]; extern char __got_start[], __got_lma[], __got_end[]; extern char _end[];
-/* - * Everything in .flashprog will be locked in the icache so it doesn't - * get disturbed when executing flash commands. - */ -#define __flashprog __attribute__((section(".flashprog"), __noinline__)) - #endif /* __ASM_AVR32_SECTIONS_H */
participants (6)
Haavard Skinnemoen
Jon Loeliger
Ken.Fuchs@bench.com
Scott Wood
Ulf Samuelsson
