[GIT PULL] Raspberry Pi updates for v2020.04
Hi Tom,
Please take into account the following commits for RPi boards.
It includes support for DFU on RPi4 as well as network support on that board.
You can find the CI output here: https://gitlab.denx.de/u-boot/custodians/u-boot-raspberrypi/pipelines/2065 and here https://travis-ci.org/mbgg/u-boot/builds/645395557
Regarding the DFU series [0] I didn't took the first two patches as I understand that you wanted to see a test for the FAT bug fixed.
Regards, Matthias
[0] https://patchwork.ozlabs.org/user/todo/uboot/?series=145985
The following changes since commit b00c3c995bf2293e32cd2be3cb4be7eb39c4ac26:
Prepare v2020.04-rc1 (2020-01-28 16:59:30 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-raspberrypi.git tags/rpi-next-2020.04
for you to fetch changes up to 095c6eba9d02688e7a1c3cd2093f826d05fe961f:
rpi4: Enable GENET Ethernet controller (2020-01-29 18:30:33 +0100)
---------------------------------------------------------------- - DFU support file operations lager then the default max size - add dfu support to dwc2 for bcm2835 - enable DFU for RPi4 - Fix RPi4 memory map to include the genet device - add driver for the genet ethernet device - enable network support in RPi4 config
---------------------------------------------------------------- Amit Singh Tomar (3): net: Add support for Broadcom GENETv5 Ethernet controller rpi4: Update memory map to accommodate scb devices rpi4: Enable GENET Ethernet controller
Marek Szyprowski (4): dfu: mmc: rearrange the code dfu: mmc: remove file size limit for io operations usb: dwc2_udc_otg: add bcm2835 SoC (Raspberry Pi4) support config: enable DFU over USB on Raspberry Pi4 boards
arch/arm/mach-bcm283x/init.c | 6 +- configs/rpi_4_32b_defconfig | 14 + configs/rpi_4_defconfig | 14 + configs/rpi_arm64_defconfig | 1 + drivers/dfu/dfu_mmc.c | 93 ++-- drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/bcmgenet.c | 729 +++++++++++++++++++++++++++++ drivers/usb/gadget/dwc2_udc_otg.c | 2 + drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 12 +- include/configs/rpi.h | 20 + 11 files changed, 854 insertions(+), 45 deletions(-) create mode 100644 drivers/net/bcmgenet.c
On Wed, Feb 05, 2020 at 10:33:18AM +0100, Matthias Brugger wrote:
Hi Tom,
Regards, Matthias
Matthias Brugger
