[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Albert,
please pull from u-boot-imx.
The following changes since commit 06194b6b65f701a9d6ef2d9b4123c4afe57d8783:
da850: add new config file for AM18xx (2011-11-10 16:30:41 +0100)
are available in the git repository at: git://www.denx.de/git/u-boot-imx.git master
Fabio Estevam (5): qong: Use generic function for configuring GPR register mx31: Remove duplicate definition for GPR register mx31: Use proper IO accessor for GPR register mx31: Fix checkpatch warnings in generic.c m28evk: Fix comment about the number of RAM banks
Marek Vasut (20): iMX28: Initial support for iMX28 CPU iMX28: Add SSP MMC driver FEC: Add support for iMX28 quirks iMX28: Add PINMUX control iMX28: Add I2C bus driver iMX28: Add GPIO control iMX28: Add SPI driver iMX28: Add APBH DMA driver iMX28: Add GPMI NAND driver iMX28: Add driver for internal RTC iMX28: Add image header generator tool iMX28: Add u-boot.sb target to Makefile iMX28: Add support for DENX M28EVK board M28: Add MMC SPL M28: Add doc/README.m28 documentation iMX28: Fix ARM vector handling M28: Add memory detection into SPL iMX28: Add USB and USB PHY register definitions iMX28: Add USB HOST driver M28EVK: Enable USB HOST support
Stefano Babic (1): MX25: zmx25: GCC4.6 fix build warnings
.gitignore | 1 + MAINTAINERS | 1 + Makefile | 5 + arch/arm/cpu/arm1136/mx31/generic.c | 11 +- arch/arm/cpu/arm926ejs/mx28/Makefile | 46 + arch/arm/cpu/arm926ejs/mx28/clock.c | 355 +++++++ arch/arm/cpu/arm926ejs/mx28/iomux.c | 109 +++ arch/arm/cpu/arm926ejs/mx28/mx28.c | 221 +++++ arch/arm/cpu/arm926ejs/mx28/timer.c | 141 +++ arch/arm/include/asm/arch-mx28/clock.h | 61 ++ arch/arm/include/asm/arch-mx28/dma.h | 170 ++++ arch/arm/include/asm/arch-mx28/gpio.h | 32 + arch/arm/include/asm/arch-mx28/imx-regs.h | 39 + arch/arm/include/asm/arch-mx28/iomux-mx28.h | 537 +++++++++++ arch/arm/include/asm/arch-mx28/iomux.h | 168 ++++ arch/arm/include/asm/arch-mx28/regs-apbh.h | 466 +++++++++ arch/arm/include/asm/arch-mx28/regs-base.h | 88 ++ arch/arm/include/asm/arch-mx28/regs-bch.h | 230 +++++ arch/arm/include/asm/arch-mx28/regs-clkctrl.h | 312 ++++++ arch/arm/include/asm/arch-mx28/regs-common.h | 66 ++ arch/arm/include/asm/arch-mx28/regs-gpmi.h | 222 +++++ arch/arm/include/asm/arch-mx28/regs-i2c.h | 207 ++++ arch/arm/include/asm/arch-mx28/regs-ocotp.h | 173 ++++ arch/arm/include/asm/arch-mx28/regs-pinctrl.h | 1284 +++++++++++++++++++++++++ arch/arm/include/asm/arch-mx28/regs-power.h | 413 ++++++++ arch/arm/include/asm/arch-mx28/regs-rtc.h | 147 +++ arch/arm/include/asm/arch-mx28/regs-ssp.h | 349 +++++++ arch/arm/include/asm/arch-mx28/regs-timrot.h | 171 ++++ arch/arm/include/asm/arch-mx28/regs-usb.h | 178 ++++ arch/arm/include/asm/arch-mx28/regs-usbphy.h | 151 +++ arch/arm/include/asm/arch-mx28/sys_proto.h | 32 + arch/arm/include/asm/arch-mx31/imx-regs.h | 7 +- board/davedenx/qong/qong.c | 2 +- board/denx/m28evk/Makefile | 56 ++ board/denx/m28evk/m28_init.h | 41 + board/denx/m28evk/m28evk.c | 216 +++++ board/denx/m28evk/mem_init.c | 240 +++++ board/denx/m28evk/mmc_boot.c | 273 ++++++ board/denx/m28evk/power_init.c | 913 ++++++++++++++++++ board/denx/m28evk/start.S | 234 +++++ board/denx/m28evk/u-boot-spl.lds | 87 ++ board/denx/m28evk/u-boot.bd | 14 + board/syteco/zmx25/zmx25.c | 2 - boards.cfg | 1 + doc/README.m28 | 223 +++++ drivers/dma/Makefile | 1 + drivers/dma/apbh_dma.c | 691 +++++++++++++ drivers/gpio/Makefile | 1 + drivers/gpio/mxs_gpio.c | 136 +++ drivers/i2c/Makefile | 1 + drivers/i2c/mxs_i2c.c | 246 +++++ drivers/mmc/Makefile | 1 + drivers/mmc/mxsmmc.c | 351 +++++++ drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/mxs_nand.c | 1118 +++++++++++++++++++++ drivers/net/fec_mxc.c | 44 +- drivers/rtc/Makefile | 1 + drivers/rtc/mxsrtc.c | 86 ++ drivers/spi/Makefile | 1 + drivers/spi/mxs_spi.c | 186 ++++ drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-mxs.c | 154 +++ include/configs/m28evk.h | 303 ++++++ tools/.gitignore | 1 + tools/Makefile | 6 + tools/mxsboot.c | 684 +++++++++++++ 66 files changed, 12697 insertions(+), 12 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/mx28/Makefile create mode 100644 arch/arm/cpu/arm926ejs/mx28/clock.c create mode 100644 arch/arm/cpu/arm926ejs/mx28/iomux.c create mode 100644 arch/arm/cpu/arm926ejs/mx28/mx28.c create mode 100644 arch/arm/cpu/arm926ejs/mx28/timer.c create mode 100644 arch/arm/include/asm/arch-mx28/clock.h create mode 100644 arch/arm/include/asm/arch-mx28/dma.h create mode 100644 arch/arm/include/asm/arch-mx28/gpio.h create mode 100644 arch/arm/include/asm/arch-mx28/imx-regs.h create mode 100644 arch/arm/include/asm/arch-mx28/iomux-mx28.h create mode 100644 arch/arm/include/asm/arch-mx28/iomux.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-apbh.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-base.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-bch.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-clkctrl.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-common.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-gpmi.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-i2c.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-ocotp.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-pinctrl.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-power.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-rtc.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-ssp.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-timrot.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-usb.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-usbphy.h create mode 100644 arch/arm/include/asm/arch-mx28/sys_proto.h create mode 100644 board/denx/m28evk/Makefile create mode 100644 board/denx/m28evk/m28_init.h create mode 100644 board/denx/m28evk/m28evk.c create mode 100644 board/denx/m28evk/mem_init.c create mode 100644 board/denx/m28evk/mmc_boot.c create mode 100644 board/denx/m28evk/power_init.c create mode 100644 board/denx/m28evk/start.S create mode 100644 board/denx/m28evk/u-boot-spl.lds create mode 100644 board/denx/m28evk/u-boot.bd create mode 100644 doc/README.m28 create mode 100644 drivers/dma/apbh_dma.c create mode 100644 drivers/gpio/mxs_gpio.c create mode 100644 drivers/i2c/mxs_i2c.c create mode 100644 drivers/mmc/mxsmmc.c create mode 100644 drivers/mtd/nand/mxs_nand.c create mode 100644 drivers/rtc/mxsrtc.c create mode 100644 drivers/spi/mxs_spi.c create mode 100644 drivers/usb/host/ehci-mxs.c create mode 100644 include/configs/m28evk.h create mode 100644 tools/mxsboot.c
Hi Stefano,
Le 11/11/2011 11:40, Stefano Babic a écrit :
Hi Albert,
Applied to u-boot-arm/master, thanks.
Amicalement,
Albert ARIBAUD
Stefano Babic
