[PATCH] rockchip: rk3588-toybrick-x0: Migrate to OF_UPSTREAM
The device tree for Rockchip Toybrick TB-RK3588X has been merged into dts/upstream with devicetree-rebasing v6.10-dts, migrate board to OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3588-toybrick-x0.dts | 688 ---------------------------- configs/toybrick-rk3588_defconfig | 3 +- 2 files changed, 1 insertion(+), 690 deletions(-) delete mode 100644 arch/arm/dts/rk3588-toybrick-x0.dts
diff --git a/arch/arm/dts/rk3588-toybrick-x0.dts b/arch/arm/dts/rk3588-toybrick-x0.dts deleted file mode 100644 index 9090c5c99f2a..000000000000 --- a/arch/arm/dts/rk3588-toybrick-x0.dts +++ /dev/null @@ -1,688 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2024 Rockchip Electronics Co., Ltd. - * - */ - -/dts-v1/; - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include "rk3588.dtsi" - -/ { - model = "Rockchip Toybrick TB-RK3588X Board"; - compatible = "rockchip,rk3588-toybrick-x0", "rockchip,rk3588"; - - aliases { - mmc0 = &sdhci; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - adc-keys { - compatible = "adc-keys"; - io-channels = <&saradc 1>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <1800000>; - poll-interval = <100>; - - button-vol-up { - label = "Volume Up"; - linux,code = <KEY_VOLUMEUP>; - press-threshold-microvolt = <17000>; - }; - - button-vol-down { - label = "Volume Down"; - linux,code = <KEY_VOLUMEDOWN>; - press-threshold-microvolt = <417000>; - }; - - button-menu { - label = "Menu"; - linux,code = <KEY_MENU>; - press-threshold-microvolt = <890000>; - }; - - button-escape { - label = "Escape"; - linux,code = <KEY_ESC>; - press-threshold-microvolt = <1235000>; - }; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - power-supply = <&vcc12v_dcin>; - pwms = <&pwm2 0 25000 0>; - }; - - pcie20_avdd0v85: pcie20-avdd0v85-regulator { - compatible = "regulator-fixed"; - regulator-name = "pcie20_avdd0v85"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <850000>; - vin-supply = <&vdd_0v85_s0>; - }; - - pcie20_avdd1v8: pcie20-avdd1v8-regulator { - compatible = "regulator-fixed"; - regulator-name = "pcie20_avdd1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&avcc_1v8_s0>; - }; - - pcie30_avdd0v75: pcie30-avdd0v75-regulator { - compatible = "regulator-fixed"; - regulator-name = "pcie30_avdd0v75"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <750000>; - vin-supply = <&avdd_0v75_s0>; - }; - - pcie30_avdd1v8: pcie30-avdd1v8-regulator { - compatible = "regulator-fixed"; - regulator-name = "pcie30_avdd1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&avcc_1v8_s0>; - }; - - vcc12v_dcin: vcc12v-dcin-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_dcin"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - vcc5v0_host: vcc5v0-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en>; - regulator-name = "vcc5v0_host"; - regulator-boot-on; - regulator-always-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usb>; - }; - - vcc5v0_sys: vcc5v0-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - vcc5v0_usbdcin: vcc5v0-usbdcin-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usbdcin"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - vcc5v0_usb: vcc5v0-usb-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usbdcin>; - }; - - vcc_1v1_nldo_s3: vcc-1v1-nldo-s3-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_1v1_nldo_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1100000>; - regulator-max-microvolt = <1100000>; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&combphy0_ps { - status = "okay"; -}; - -&combphy2_psu { - status = "okay"; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_big0_s0>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_big0_s0>; -}; - -&cpu_b2 { - cpu-supply = <&vdd_cpu_big1_s0>; -}; - -&cpu_b3 { - cpu-supply = <&vdd_cpu_big1_s0>; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_lit_s0>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_lit_s0>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_lit_s0>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_lit_s0>; -}; - -&gmac0 { - clock_in_out = "output"; - phy-handle = <&rgmii_phy>; - phy-mode = "rgmii-rxid"; - pinctrl-0 = <&gmac0_miim - &gmac0_tx_bus2 - &gmac0_rx_bus2 - &gmac0_rgmii_clk - &gmac0_rgmii_bus>; - pinctrl-names = "default"; - rx_delay = <0x00>; - tx_delay = <0x43>; - status = "okay"; -}; - -&i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c0m2_xfer>; - status = "okay"; - - vdd_cpu_big0_s0: regulator@42 { - compatible = "rockchip,rk8602"; - reg = <0x42>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu_big0_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <550000>; - regulator-max-microvolt = <1050000>; - regulator-ramp-delay = <2300>; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_big1_s0: regulator@43 { - compatible = "rockchip,rk8603", "rockchip,rk8602"; - reg = <0x43>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu_big1_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <550000>; - regulator-max-microvolt = <1050000>; - regulator-ramp-delay = <2300>; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c2 { - status = "okay"; - - hym8563: rtc@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - #clock-cells = <0>; - clock-output-names = "hym8563"; - interrupt-parent = <&gpio0>; - interrupts = <RK_PD4 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&hym8563_int>; - wakeup-source; - }; -}; - -&mdio0 { - rgmii_phy: ethernet-phy@1 { - /* RTL8211F */ - compatible = "ethernet-phy-id001c.c916"; - reg = <0x1>; - pinctrl-names = "default"; - pinctrl-0 = <&rtl8211f_rst>; - reset-assert-us = <20000>; - reset-deassert-us = <100000>; - reset-gpios = <&gpio4 RK_PB3 GPIO_ACTIVE_LOW>; - }; -}; - -&pinctrl { - rtl8211f { - rtl8211f_rst: rtl8211f-rst { - rockchip,pins = <4 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - }; - - hym8563 { - hym8563_int: hym8563-int { - rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb { - vcc5v0_host_en: vcc5v0-host-en { - rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm2 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcc_1v8_s0>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs400-1_8v; - mmc-hs400-enhanced-strobe; - no-sdio; - no-sd; - non-removable; - status = "okay"; -}; - -&spi2 { - assigned-clocks = <&cru CLK_SPI2>; - assigned-clock-rates = <200000000>; - num-cs = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&spi2m2_cs0 &spi2m2_pins>; - status = "okay"; - - pmic@0 { - compatible = "rockchip,rk806"; - reg = <0x0>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&gpio0>; - interrupts = <7 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, - <&rk806_dvs2_null>, <&rk806_dvs3_null>; - spi-max-frequency = <1000000>; - system-power-controller; - - vcc1-supply = <&vcc5v0_sys>; - vcc2-supply = <&vcc5v0_sys>; - vcc3-supply = <&vcc5v0_sys>; - vcc4-supply = <&vcc5v0_sys>; - vcc5-supply = <&vcc5v0_sys>; - vcc6-supply = <&vcc5v0_sys>; - vcc7-supply = <&vcc5v0_sys>; - vcc8-supply = <&vcc5v0_sys>; - vcc9-supply = <&vcc5v0_sys>; - vcc10-supply = <&vcc5v0_sys>; - vcc11-supply = <&vcc_2v0_pldo_s3>; - vcc12-supply = <&vcc5v0_sys>; - vcc13-supply = <&vcc_1v1_nldo_s3>; - vcc14-supply = <&vcc_1v1_nldo_s3>; - vcca-supply = <&vcc5v0_sys>; - - rk806_dvs1_null: dvs1-null-pins { - pins = "gpio_pwrctrl1"; - function = "pin_fun0"; - }; - - rk806_dvs2_null: dvs2-null-pins { - pins = "gpio_pwrctrl2"; - function = "pin_fun0"; - }; - - rk806_dvs3_null: dvs3-null-pins { - pins = "gpio_pwrctrl3"; - function = "pin_fun0"; - }; - - regulators { - vdd_gpu_s0: vdd_gpu_mem_s0: dcdc-reg1 { - regulator-name = "vdd_gpu_s0"; - regulator-boot-on; - regulator-enable-ramp-delay = <400>; - regulator-min-microvolt = <550000>; - regulator-max-microvolt = <950000>; - regulator-ramp-delay = <12500>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_lit_s0: vdd_cpu_lit_mem_s0: dcdc-reg2 { - regulator-name = "vdd_cpu_lit_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <550000>; - regulator-max-microvolt = <950000>; - regulator-ramp-delay = <12500>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_log_s0: dcdc-reg3 { - regulator-name = "vdd_log_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <675000>; - regulator-max-microvolt = <750000>; - regulator-ramp-delay = <12500>; - - regulator-state-mem { - regulator-off-in-suspend; - regulator-suspend-microvolt = <750000>; - }; - }; - - vdd_vdenc_s0: vdd_vdenc_mem_s0: dcdc-reg4 { - regulator-name = "vdd_vdenc_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <550000>; - regulator-max-microvolt = <950000>; - regulator-init-microvolt = <750000>; - regulator-ramp-delay = <12500>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_ddr_s0: dcdc-reg5 { - regulator-name = "vdd_ddr_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <675000>; - regulator-max-microvolt = <900000>; - regulator-ramp-delay = <12500>; - - regulator-state-mem { - regulator-off-in-suspend; - regulator-suspend-microvolt = <850000>; - }; - }; - - vdd2_ddr_s3: dcdc-reg6 { - regulator-name = "vdd2_ddr_s3"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_2v0_pldo_s3: dcdc-reg7 { - regulator-name = "vdd_2v0_pldo_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <2000000>; - regulator-max-microvolt = <2000000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <2000000>; - }; - }; - - vcc_3v3_s3: dcdc-reg8 { - regulator-name = "vcc_3v3_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vddq_ddr_s0: dcdc-reg9 { - regulator-name = "vddq_ddr_s0"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v8_s3: dcdc-reg10 { - regulator-name = "vcc_1v8_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - avcc_1v8_s0: pldo-reg1 { - regulator-name = "avcc_1v8_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v8_s0: pldo-reg2 { - regulator-name = "vcc_1v8_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - avdd_1v2_s0: pldo-reg3 { - regulator-name = "avdd_1v2_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v3_s0: pldo-reg4 { - regulator-name = "vcc_3v3_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd_s0: pldo-reg5 { - regulator-name = "vccio_sd_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - pldo6_s3: pldo-reg6 { - regulator-name = "pldo6_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdd_0v75_s3: nldo-reg1 { - regulator-name = "vdd_0v75_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <750000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <750000>; - }; - }; - - vdd_ddr_pll_s0: nldo-reg2 { - regulator-name = "vdd_ddr_pll_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <850000>; - - regulator-state-mem { - regulator-off-in-suspend; - regulator-suspend-microvolt = <850000>; - }; - }; - - avdd_0v75_s0: nldo-reg3 { - regulator-name = "avdd_0v75_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <837500>; - regulator-max-microvolt = <837500>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_0v85_s0: nldo-reg4 { - regulator-name = "vdd_0v85_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <850000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_0v75_s0: nldo-reg5 { - regulator-name = "vdd_0v75_s0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <750000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; -}; - -&u2phy2 { - status = "okay"; -}; - -&u2phy2_host { - phy-supply = <&vcc5v0_host>; - status = "okay"; -}; - -&u2phy3 { - status = "okay"; -}; - -&u2phy3_host { - phy-supply = <&vcc5v0_host>; - status = "okay"; -}; - -&uart2 { - pinctrl-0 = <&uart2m0_xfer>; - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; diff --git a/configs/toybrick-rk3588_defconfig b/configs/toybrick-rk3588_defconfig index 5a190357e454..12a076aeeae0 100644 --- a/configs/toybrick-rk3588_defconfig +++ b/configs/toybrick-rk3588_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3588-toybrick-x0" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588-toybrick-x0" CONFIG_ROCKCHIP_RK3588=y CONFIG_SPL_SERIAL=y CONFIG_TARGET_TOYBRICK_RK3588=y @@ -31,7 +31,6 @@ CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y -# CONFIG_OF_UPSTREAM is not set CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM_SEQ_ALIAS=y
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- Copyright (c) 2024 Rockchip Electronics Co., Ltd.
-/dts-v1/;
- aliases {
mmc0 = &sdhci;
- chosen {
- adc-keys {
button-vol-up {
button-vol-down {
button-menu {
label = "Menu";
button-escape {
label = "Escape";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&combphy0_ps {
- status = "okay";
-&combphy2_psu {
- status = "okay";
-&cpu_b0 {
-&cpu_b1 {
-&cpu_b2 {
-&cpu_b3 {
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&gmac0 {
&gmac0_tx_bus2
&gmac0_rx_bus2
&gmac0_rgmii_clk
&gmac0_rgmii_bus>;
- status = "okay";
-&i2c0 {
- status = "okay";
reg = <0x42>;
regulator-boot-on;
reg = <0x43>;
regulator-boot-on;
-&i2c2 {
- status = "okay";
- hym8563: rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
wakeup-source;
-&mdio0 {
/* RTL8211F */
reg = <0x1>;
-&pinctrl {
- rtl8211f {
- hym8563 {
- usb {
-&pwm2 {
- status = "okay";
-&saradc {
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- no-sdio;
- no-sd;
- non-removable;
- status = "okay";
-&spi2 {
- num-cs = <1>;
- status = "okay";
- pmic@0 {
reg = <0x0>;
gpio-controller;
#gpio-cells = <2>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&u2phy2 {
- status = "okay";
-&u2phy2_host {
- status = "okay";
-&u2phy3 {
- status = "okay";
-&u2phy3_host {
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
Jonas Karlman
Kever Yang
