[PATCH v3 00/19] i.MXRT1050 add LCDIF support
This patchset add support for LCDIF on i.MXRT1050 evk. This requires PLL5 to be setup, mxsfb needs to use display_timing to retrieve if Lcd has inverted PIXCLOCK from dts.
With this patchset applied we temporary loose DCache support until it will get implemented, since a function in mxsfb.c is needed for setting cache behaviour. Anyway this way Lcd will show the console same way as serial does.
Also I've moved private sunxi_ctfb_mode_to_display_timing() to videomodes since I need it for mxfsb.c too, then having a unified function to convert from ctfb_mode to display_timing.
Changes: V1->V2: * moved hard-coded LCDIF's parent clock from clk-imxrt1050.c to imxrt1050-evk.dts * reworded some commit log V2->V3: * added comment to describe what is a ctfb in videomodes
Giulio Benetti (19): clk: imx: pllv3: add enable_bit clk: imx: clk-imxrt1050: fix typo in clock name "video:" clk: imx: clk-imxrt1050: setup PLL5 for video in non-SPL clk: imx: clk-imxrt1050: add set_parent() callback videomodes: add helper function to convert from ctfb to display_timing sunxi: display: use common video_ctfb_mode_to_display_timing() video: mxsfb: add support for DM CLK video: mxsfb: add support for i.MXRT video: mxsfb: refactor for using display_timings video: mxsfb: enable setting HSYNC negative polarity video: mxsfb: enable setting VSYNC negative polarity video: mxsfb: enable setting PIXDATA on negative edge video: mxsfb: enable setting ENABLE negative polarity imxrt1050_evk: add 16bpp video support if video layer enabled ARM: dts: i.mxrt1050: add lcdif node ARM: dts: imxrt1050: allow this dtsi file to be compiled in Linux arch: arm: dts: imxrt1050-evk: add lcdif node configs: imxrt1050-evk: enable video support/console configs: imxrt1050-evk: temporary disable DCACHE
arch/arm/dts/imxrt1050-evk.dts | 60 ++++++++++++++ arch/arm/dts/imxrt1050.dtsi | 14 +++- arch/arm/include/asm/arch-imxrt/imx-regs.h | 6 ++ arch/arm/include/asm/mach-imx/regs-lcdif.h | 6 +- configs/imxrt1050-evk_defconfig | 6 ++ drivers/clk/imx/clk-imxrt1050.c | 30 ++++++- drivers/clk/imx/clk-pllv3.c | 9 +++ drivers/video/mxsfb.c | 94 ++++++++++++++-------- drivers/video/sunxi/sunxi_display.c | 33 +------- drivers/video/videomodes.c | 29 +++++++ drivers/video/videomodes.h | 11 +++ include/configs/imxrt1050-evk.h | 15 ++++ 12 files changed, 242 insertions(+), 71 deletions(-)
pllv3 PLLs have powerdown/up bits but enable bits too. Specifically "enable bit" enable the pll output, so when dis/enabling pll by setting/clearing power_bit we must also set/clear enable_bit.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de --- drivers/clk/imx/clk-pllv3.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/clk/imx/clk-pllv3.c b/drivers/clk/imx/clk-pllv3.c index 525442debf..b4a9d587e1 100644 --- a/drivers/clk/imx/clk-pllv3.c +++ b/drivers/clk/imx/clk-pllv3.c @@ -25,6 +25,7 @@ #define PLL_DENOM_OFFSET 0x20
#define BM_PLL_POWER (0x1 << 12) +#define BM_PLL_ENABLE (0x1 << 13) #define BM_PLL_LOCK (0x1 << 31)
struct clk_pllv3 { @@ -32,6 +33,7 @@ struct clk_pllv3 { void __iomem *base; u32 power_bit; bool powerup_set; + u32 enable_bit; u32 div_mask; u32 div_shift; }; @@ -83,6 +85,9 @@ static int clk_pllv3_generic_enable(struct clk *clk) val |= pll->power_bit; else val &= ~pll->power_bit; + + val |= pll->enable_bit; + writel(val, pll->base);
return 0; @@ -98,6 +103,9 @@ static int clk_pllv3_generic_disable(struct clk *clk) val &= ~pll->power_bit; else val |= pll->power_bit; + + val &= ~pll->enable_bit; + writel(val, pll->base);
return 0; @@ -238,6 +246,7 @@ struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name, return ERR_PTR(-ENOMEM);
pll->power_bit = BM_PLL_POWER; + pll->enable_bit = BM_PLL_ENABLE;
switch (type) { case IMX_PLLV3_GENERIC:
pllv3 PLLs have powerdown/up bits but enable bits too. Specifically "enable bit" enable the pll output, so when dis/enabling pll by setting/clearing power_bit we must also set/clear enable_bit. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de
Best regards, Stefano Babic
"video:" must be "video", ":" is a typo.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de --- drivers/clk/imx/clk-imxrt1050.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/imx/clk-imxrt1050.c b/drivers/clk/imx/clk-imxrt1050.c index 44ca52c013..e33d426363 100644 --- a/drivers/clk/imx/clk-imxrt1050.c +++ b/drivers/clk/imx/clk-imxrt1050.c @@ -90,7 +90,7 @@ static const char *const usdhc_sels[] = { "pll2_pfd2_396m", "pll2_pfd0_352m", }; static const char *const lpuart_sels[] = { "pll3_80m", "osc", }; static const char *const semc_alt_sels[] = { "pll2_pfd2_396m", "pll3_pfd1_664_62m", }; static const char *const semc_sels[] = { "periph_sel", "semc_alt_sel", }; -static const char *const lcdif_sels[] = { "pll2_sys", "pll3_pfd3_454_74m", "pll5_video:", "pll2_pfd0_352m", "pll2_pfd1_594m", "pll3_pfd1_664_62m"}; +static const char *const lcdif_sels[] = { "pll2_sys", "pll3_pfd3_454_74m", "pll5_video", "pll2_pfd0_352m", "pll2_pfd1_594m", "pll3_pfd1_664_62m"};
static int imxrt1050_clk_probe(struct udevice *dev) {
"video:" must be "video", ":" is a typo. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de
mxsfb needs PLL5 as source, so let's setup it at its default frequency specified in RM(650Mhz).
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de --- V1->V2: * removed LCDIF set_parent() since it's setup in dts file(suggested by Fabio) --- drivers/clk/imx/clk-imxrt1050.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/imx/clk-imxrt1050.c b/drivers/clk/imx/clk-imxrt1050.c index e33d426363..bb12644605 100644 --- a/drivers/clk/imx/clk-imxrt1050.c +++ b/drivers/clk/imx/clk-imxrt1050.c @@ -238,9 +238,9 @@ static int imxrt1050_clk_probe(struct udevice *dev) clk_dm(IMXRT1050_CLK_LCDIF, imx_clk_gate2("lcdif", "lcdif_podf", base + 0x70, 28));
-#ifdef CONFIG_SPL_BUILD struct clk *clk, *clk1;
+#ifdef CONFIG_SPL_BUILD /* bypass pll1 before setting its rate */ clk_get_by_id(IMXRT1050_CLK_PLL1_REF_SEL, &clk); clk_get_by_id(IMXRT1050_CLK_PLL1_BYPASS, &clk1); @@ -271,7 +271,14 @@ static int imxrt1050_clk_probe(struct udevice *dev)
clk_get_by_id(IMXRT1050_CLK_PLL3_BYPASS, &clk1); clk_set_parent(clk1, clk); +#else + /* Set PLL5 for LCDIF to its default 650Mhz */ + clk_get_by_id(IMXRT1050_CLK_PLL5_VIDEO, &clk); + clk_enable(clk); + clk_set_rate(clk, 650000000UL);
+ clk_get_by_id(IMXRT1050_CLK_PLL5_BYPASS, &clk1); + clk_set_parent(clk1, clk); #endif
mxsfb needs PLL5 as source, so let's setup it at its default frequency specified in RM(650Mhz). Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de
Need to add set_parent() callback to allow dts assigned-clock-parents to work so let's add it accordingly.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- V1->V2: * introduce patch to allow clock's parent setting in dts to work --- drivers/clk/imx/clk-imxrt1050.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/drivers/clk/imx/clk-imxrt1050.c b/drivers/clk/imx/clk-imxrt1050.c index bb12644605..329f4580c5 100644 --- a/drivers/clk/imx/clk-imxrt1050.c +++ b/drivers/clk/imx/clk-imxrt1050.c @@ -71,11 +71,30 @@ static int imxrt1050_clk_enable(struct clk *clk) return __imxrt1050_clk_enable(clk, 1); }
+static int imxrt1050_clk_set_parent(struct clk *clk, struct clk *parent) +{ + struct clk *c, *cp; + int ret; + + debug("%s(#%lu), parent: %lu\n", __func__, clk->id, parent->id); + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + ret = clk_get_by_id(parent->id, &cp); + if (ret) + return ret; + + return clk_set_parent(c, cp); +} + static struct clk_ops imxrt1050_clk_ops = { .set_rate = imxrt1050_clk_set_rate, .get_rate = imxrt1050_clk_get_rate, .enable = imxrt1050_clk_enable, .disable = imxrt1050_clk_disable, + .set_parent = imxrt1050_clk_set_parent, };
static const char * const pll_ref_sels[] = {"osc", "dummy", };
Need to add set_parent() callback to allow dts assigned-clock-parents to work so let's add it accordingly. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
This function converts from "struct ctf_res_modes" to "struct display_timing".
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- V2->V3: * comment function prototype and make it clear what ctfb is --- drivers/video/videomodes.c | 29 +++++++++++++++++++++++++++++ drivers/video/videomodes.h | 11 +++++++++++ 2 files changed, 40 insertions(+)
diff --git a/drivers/video/videomodes.c b/drivers/video/videomodes.c index ac25b45f81..89003eea72 100644 --- a/drivers/video/videomodes.c +++ b/drivers/video/videomodes.c @@ -444,3 +444,32 @@ int video_edid_dtd_to_ctfb_res_modes(struct edid_detailed_timing *t,
return 0; } + +void video_ctfb_mode_to_display_timing(const struct ctfb_res_modes *mode, + struct display_timing *timing) +{ + timing->pixelclock.typ = mode->pixclock_khz * 1000; + + timing->hactive.typ = mode->xres; + timing->hfront_porch.typ = mode->right_margin; + timing->hback_porch.typ = mode->left_margin; + timing->hsync_len.typ = mode->hsync_len; + + timing->vactive.typ = mode->yres; + timing->vfront_porch.typ = mode->lower_margin; + timing->vback_porch.typ = mode->upper_margin; + timing->vsync_len.typ = mode->vsync_len; + + timing->flags = 0; + + if (mode->sync & FB_SYNC_HOR_HIGH_ACT) + timing->flags |= DISPLAY_FLAGS_HSYNC_HIGH; + else + timing->flags |= DISPLAY_FLAGS_HSYNC_LOW; + if (mode->sync & FB_SYNC_VERT_HIGH_ACT) + timing->flags |= DISPLAY_FLAGS_VSYNC_HIGH; + else + timing->flags |= DISPLAY_FLAGS_VSYNC_LOW; + if (mode->vmode == FB_VMODE_INTERLACED) + timing->flags |= DISPLAY_FLAGS_INTERLACED; +} diff --git a/drivers/video/videomodes.h b/drivers/video/videomodes.h index 29a3db4ae3..aefe4ef94a 100644 --- a/drivers/video/videomodes.h +++ b/drivers/video/videomodes.h @@ -92,3 +92,14 @@ int video_get_option_int(const char *options, const char *name, int def);
int video_edid_dtd_to_ctfb_res_modes(struct edid_detailed_timing *t, struct ctfb_res_modes *mode); +/** + * video_ctfb_mode_to_display_timing() - Convert a ctfb(Cathode Tube Frame + * Buffer)_res_modes struct to a + * display_timing struct. + * + * @mode: Input ctfb_res_modes structure pointer to be converted + * from + * @timing: Output display_timing structure pointer to be converted to + */ +void video_ctfb_mode_to_display_timing(const struct ctfb_res_modes *mode, + struct display_timing *timing);
On Wed, 8 Apr 2020 17:10:11 +0200 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
Reviewed-by: Anatolij Gustschin agust@denx.de
-- Anatolij
This function converts from "struct ctf_res_modes" to "struct display_timing". Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Anatolij Gustschin agust@denx.de
Since video_ctfb_mode_to_display_timing() has been implemented by moving sunxi_ctfb_mode_to_display_timing() to video_modes.c and it's meant to be used by other video subsystem, let's use it instead of local sunxi_ctfb_mode_to_display_timing().
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/video/sunxi/sunxi_display.c | 33 ++--------------------------- 1 file changed, 2 insertions(+), 31 deletions(-)
diff --git a/drivers/video/sunxi/sunxi_display.c b/drivers/video/sunxi/sunxi_display.c index 31f0aa7ddc..a6a62c83ef 100644 --- a/drivers/video/sunxi/sunxi_display.c +++ b/drivers/video/sunxi/sunxi_display.c @@ -615,35 +615,6 @@ static void sunxi_lcdc_backlight_enable(void) gpio_direction_output(pin, PWM_ON); }
-static void sunxi_ctfb_mode_to_display_timing(const struct ctfb_res_modes *mode, - struct display_timing *timing) -{ - timing->pixelclock.typ = mode->pixclock_khz * 1000; - - timing->hactive.typ = mode->xres; - timing->hfront_porch.typ = mode->right_margin; - timing->hback_porch.typ = mode->left_margin; - timing->hsync_len.typ = mode->hsync_len; - - timing->vactive.typ = mode->yres; - timing->vfront_porch.typ = mode->lower_margin; - timing->vback_porch.typ = mode->upper_margin; - timing->vsync_len.typ = mode->vsync_len; - - timing->flags = 0; - - if (mode->sync & FB_SYNC_HOR_HIGH_ACT) - timing->flags |= DISPLAY_FLAGS_HSYNC_HIGH; - else - timing->flags |= DISPLAY_FLAGS_HSYNC_LOW; - if (mode->sync & FB_SYNC_VERT_HIGH_ACT) - timing->flags |= DISPLAY_FLAGS_VSYNC_HIGH; - else - timing->flags |= DISPLAY_FLAGS_VSYNC_LOW; - if (mode->vmode == FB_VMODE_INTERLACED) - timing->flags |= DISPLAY_FLAGS_INTERLACED; -} - static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode, bool for_ext_vga_dac) { @@ -673,7 +644,7 @@ static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode, lcdc_pll_set(ccm, 0, mode->pixclock_khz, &clk_div, &clk_double, sunxi_is_composite());
- sunxi_ctfb_mode_to_display_timing(mode, &timing); + video_ctfb_mode_to_display_timing(mode, &timing); lcdc_tcon0_mode_set(lcdc, &timing, clk_div, for_ext_vga_dac, sunxi_display.depth, CONFIG_VIDEO_LCD_DCLK_PHASE); } @@ -689,7 +660,7 @@ static void sunxi_lcdc_tcon1_mode_set(const struct ctfb_res_modes *mode, (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; struct display_timing timing;
- sunxi_ctfb_mode_to_display_timing(mode, &timing); + video_ctfb_mode_to_display_timing(mode, &timing); lcdc_tcon1_mode_set(lcdc, &timing, use_portd_hvsync, sunxi_is_composite());
On Wed, 8 Apr 2020 17:10:12 +0200 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
-- Anatolij
Since video_ctfb_mode_to_display_timing() has been implemented by moving sunxi_ctfb_mode_to_display_timing() to video_modes.c and it's meant to be used by other video subsystem, let's use it instead of local sunxi_ctfb_mode_to_display_timing(). Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Anatolij Gustschin agust@denx.de
Allow using DM CLK instead of mxs_set_lcdclk() so we can avoid to implement a special function to set lcd clock on i.MXRT.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/video/mxsfb.c | 30 +++++++++++++++++++++++++----- 1 file changed, 25 insertions(+), 5 deletions(-)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 585af3d571..f21f8247d9 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -5,6 +5,7 @@ * Copyright (C) 2011-2013 Marek Vasut marex@denx.de */ #include <common.h> +#include <clk.h> #include <dm.h> #include <env.h> #include <dm/device_compat.h> @@ -52,14 +53,32 @@ __weak void mxsfb_system_setup(void) * le:89,ri:164,up:23,lo:10,hs:10,vs:10,sync:0,vmode:0 */
-static void mxs_lcd_init(u32 fb_addr, struct ctfb_res_modes *mode, int bpp) +static void mxs_lcd_init(struct udevice *dev, u32 fb_addr, + struct ctfb_res_modes *mode, int bpp) { struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; uint32_t word_len = 0, bus_width = 0; uint8_t valid_data = 0;
+#if CONFIG_IS_ENABLED(CLK) + struct clk per_clk; + int ret; + + ret = clk_get_by_name(dev, "per", &per_clk); + if (ret) { + dev_err(dev, "Failed to get mxs clk: %d\n", ret); + return; + } + + ret = clk_set_rate(&per_clk, PS2KHZ(mode->pixclock) * 1000); + if (ret < 0) { + dev_err(dev, "Failed to set mxs clk: %d\n", ret); + return; + } +#else /* Kick in the LCDIF clock */ mxs_set_lcdclk(MXS_LCDIF_BASE, PS2KHZ(mode->pixclock)); +#endif
/* Restart the LCDIF block */ mxs_reset_block(®s->hw_lcdif_ctrl_reg); @@ -135,10 +154,11 @@ static void mxs_lcd_init(u32 fb_addr, struct ctfb_res_modes *mode, int bpp) writel(LCDIF_CTRL_RUN, ®s->hw_lcdif_ctrl_set); }
-static int mxs_probe_common(struct ctfb_res_modes *mode, int bpp, u32 fb) +static int mxs_probe_common(struct udevice *dev, struct ctfb_res_modes *mode, + int bpp, u32 fb) { /* Start framebuffer */ - mxs_lcd_init(fb, mode, bpp); + mxs_lcd_init(dev, fb, mode, bpp);
#ifdef CONFIG_VIDEO_MXS_MODE_SYSTEM /* @@ -260,7 +280,7 @@ void *video_hw_init(void)
printf("%s\n", panel.modeIdent);
- ret = mxs_probe_common(&mode, bpp, (u32)fb); + ret = mxs_probe_common(NULL, &mode, bpp, (u32)fb); if (ret) goto dealloc_fb;
@@ -337,7 +357,7 @@ static int mxs_video_probe(struct udevice *dev) mode.vsync_len = timings.vsync_len.typ; mode.pixclock = HZ2PS(timings.pixelclock.typ);
- ret = mxs_probe_common(&mode, bpp, plat->base); + ret = mxs_probe_common(dev, &mode, bpp, plat->base); if (ret) return ret;
On Wed, 8 Apr 2020 17:10:13 +0200 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
-- Anatolij
Allow using DM CLK instead of mxs_set_lcdclk() so we can avoid to implement a special function to set lcd clock on i.MXRT. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Anatolij Gustschin agust@denx.de
Add support for i.MXRT by adding CONFIG_IMXRT in register structure and adding .compatible = "fsl,imxrt-lcdif".
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/include/asm/arch-imxrt/imx-regs.h | 6 ++++++ arch/arm/include/asm/mach-imx/regs-lcdif.h | 6 +++--- drivers/video/mxsfb.c | 1 + 3 files changed, 10 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-imxrt/imx-regs.h b/arch/arm/include/asm/arch-imxrt/imx-regs.h index 4f1d439f6f..44c95dcd11 100644 --- a/arch/arm/include/asm/arch-imxrt/imx-regs.h +++ b/arch/arm/include/asm/arch-imxrt/imx-regs.h @@ -17,4 +17,10 @@
#define ANATOP_BASE_ADDR 0x400d8000
+#define MXS_LCDIF_BASE 0x402b8000 + +#if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) +#include <asm/mach-imx/regs-lcdif.h> +#endif + #endif /* __ASM_ARCH_IMX_REGS_H__ */ diff --git a/arch/arm/include/asm/mach-imx/regs-lcdif.h b/arch/arm/include/asm/mach-imx/regs-lcdif.h index b4c430a35c..5874638796 100644 --- a/arch/arm/include/asm/mach-imx/regs-lcdif.h +++ b/arch/arm/include/asm/mach-imx/regs-lcdif.h @@ -22,7 +22,7 @@ struct mxs_lcdif_regs { defined(CONFIG_MX6SL) || defined(CONFIG_MX6SLL) || \ defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) || \ defined(CONFIG_MX7) || defined(CONFIG_MX7ULP) || \ - defined(CONFIG_IMX8M) + defined(CONFIG_IMX8M) || defined(CONFIG_IMXRT) mxs_reg_32(hw_lcdif_ctrl2) /* 0x20 */ #endif mxs_reg_32(hw_lcdif_transfer_count) /* 0x20/0x30 */ @@ -49,7 +49,7 @@ struct mxs_lcdif_regs { mxs_reg_32(hw_lcdif_csc_coeffctrl2) /* 0x130 */ mxs_reg_32(hw_lcdif_csc_coeffctrl3) /* 0x140 */ mxs_reg_32(hw_lcdif_csc_coeffctrl4) /* 0x150 */ - mxs_reg_32(hw_lcdif_csc_offset) /* 0x160 */ + mxs_reg_32(hw_lcdif_csc_offset) /* 0x160 */ mxs_reg_32(hw_lcdif_csc_limit) /* 0x170 */
#if defined(CONFIG_MX23) @@ -61,7 +61,7 @@ struct mxs_lcdif_regs { defined(CONFIG_MX6SL) || defined(CONFIG_MX6SLL) || \ defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) || \ defined(CONFIG_MX7) || defined(CONFIG_MX7ULP) || \ - defined(CONFIG_IMX8M) + defined(CONFIG_IMX8M) || defined(CONFIG_IMXRT) mxs_reg_32(hw_lcdif_crc_stat) /* 0x1a0 */ #endif mxs_reg_32(hw_lcdif_lcdif_stat) /* 0x1d0/0x1b0 */ diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index f21f8247d9..6826ba3d1b 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -440,6 +440,7 @@ static const struct udevice_id mxs_video_ids[] = { { .compatible = "fsl,imx23-lcdif" }, { .compatible = "fsl,imx28-lcdif" }, { .compatible = "fsl,imx7ulp-lcdif" }, + { .compatible = "fsl,imxrt-lcdif" }, { /* sentinel */ } };
On Wed, 8 Apr 2020 17:10:14 +0200 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
-- Anatolij
Add support for i.MXRT by adding CONFIG_IMXRT in register structure and adding .compatible = "fsl,imxrt-lcdif". Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Anatolij Gustschin agust@denx.de
struct display_timings provides more informations such clock and DE polarity, so let's refactor the code to use struct display_timings instead of struct ctfb_res_modes, so we'll become able to get clock and DE polarity settings and set register according to them in the next patch.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/video/mxsfb.c | 54 ++++++++++++++++++------------------------- 1 file changed, 23 insertions(+), 31 deletions(-)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 6826ba3d1b..cdd6dfaced 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -54,7 +54,7 @@ __weak void mxsfb_system_setup(void) */
static void mxs_lcd_init(struct udevice *dev, u32 fb_addr, - struct ctfb_res_modes *mode, int bpp) + struct display_timing *timings, int bpp) { struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; uint32_t word_len = 0, bus_width = 0; @@ -70,14 +70,14 @@ static void mxs_lcd_init(struct udevice *dev, u32 fb_addr, return; }
- ret = clk_set_rate(&per_clk, PS2KHZ(mode->pixclock) * 1000); + ret = clk_set_rate(&per_clk, timings->pixelclock.typ); if (ret < 0) { dev_err(dev, "Failed to set mxs clk: %d\n", ret); return; } #else /* Kick in the LCDIF clock */ - mxs_set_lcdclk(MXS_LCDIF_BASE, PS2KHZ(mode->pixclock)); + mxs_set_lcdclk(MXS_LCDIF_BASE, timings->pixelclock.typ / 1000); #endif
/* Restart the LCDIF block */ @@ -115,25 +115,25 @@ static void mxs_lcd_init(struct udevice *dev, u32 fb_addr,
mxsfb_system_setup();
- writel((mode->yres << LCDIF_TRANSFER_COUNT_V_COUNT_OFFSET) | mode->xres, - ®s->hw_lcdif_transfer_count); + writel((timings->vactive.typ << LCDIF_TRANSFER_COUNT_V_COUNT_OFFSET) | + timings->hactive.typ, ®s->hw_lcdif_transfer_count);
writel(LCDIF_VDCTRL0_ENABLE_PRESENT | LCDIF_VDCTRL0_ENABLE_POL | LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT | - mode->vsync_len, ®s->hw_lcdif_vdctrl0); - writel(mode->upper_margin + mode->lower_margin + - mode->vsync_len + mode->yres, + timings->vsync_len.typ, ®s->hw_lcdif_vdctrl0); + writel(timings->vback_porch.typ + timings->vfront_porch.typ + + timings->vsync_len.typ + timings->vactive.typ, ®s->hw_lcdif_vdctrl1); - writel((mode->hsync_len << LCDIF_VDCTRL2_HSYNC_PULSE_WIDTH_OFFSET) | - (mode->left_margin + mode->right_margin + - mode->hsync_len + mode->xres), + writel((timings->hsync_len.typ << LCDIF_VDCTRL2_HSYNC_PULSE_WIDTH_OFFSET) | + (timings->hback_porch.typ + timings->hfront_porch.typ + + timings->hsync_len.typ + timings->hactive.typ), ®s->hw_lcdif_vdctrl2); - writel(((mode->left_margin + mode->hsync_len) << + writel(((timings->hback_porch.typ + timings->hsync_len.typ) << LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_OFFSET) | - (mode->upper_margin + mode->vsync_len), + (timings->vback_porch.typ + timings->vsync_len.typ), ®s->hw_lcdif_vdctrl3); - writel((0 << LCDIF_VDCTRL4_DOTCLK_DLY_SEL_OFFSET) | mode->xres, + writel((0 << LCDIF_VDCTRL4_DOTCLK_DLY_SEL_OFFSET) | timings->hactive.typ, ®s->hw_lcdif_vdctrl4);
writel(fb_addr, ®s->hw_lcdif_cur_buf); @@ -154,11 +154,11 @@ static void mxs_lcd_init(struct udevice *dev, u32 fb_addr, writel(LCDIF_CTRL_RUN, ®s->hw_lcdif_ctrl_set); }
-static int mxs_probe_common(struct udevice *dev, struct ctfb_res_modes *mode, +static int mxs_probe_common(struct udevice *dev, struct display_timing *timings, int bpp, u32 fb) { /* Start framebuffer */ - mxs_lcd_init(dev, fb, mode, bpp); + mxs_lcd_init(dev, fb, timings, bpp);
#ifdef CONFIG_VIDEO_MXS_MODE_SYSTEM /* @@ -224,6 +224,7 @@ void *video_hw_init(void) char *penv; void *fb = NULL; struct ctfb_res_modes mode; + struct display_timing timings;
puts("Video: ");
@@ -280,7 +281,9 @@ void *video_hw_init(void)
- ret = mxs_probe_common(NULL, &mode, bpp, (u32)fb); + video_ctfb_mode_to_display_timing(&mode, &timings); + + ret = mxs_probe_common(NULL, &timings, bpp, (u32)fb); if (ret) goto dealloc_fb;
@@ -334,7 +337,6 @@ static int mxs_video_probe(struct udevice *dev) struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); struct video_priv *uc_priv = dev_get_uclass_priv(dev);
- struct ctfb_res_modes mode; struct display_timing timings; u32 bpp = 0; u32 fb_start, fb_end; @@ -347,17 +349,7 @@ static int mxs_video_probe(struct udevice *dev) if (ret) return ret;
- mode.xres = timings.hactive.typ; - mode.yres = timings.vactive.typ; - mode.left_margin = timings.hback_porch.typ; - mode.right_margin = timings.hfront_porch.typ; - mode.upper_margin = timings.vback_porch.typ; - mode.lower_margin = timings.vfront_porch.typ; - mode.hsync_len = timings.hsync_len.typ; - mode.vsync_len = timings.vsync_len.typ; - mode.pixclock = HZ2PS(timings.pixelclock.typ); - - ret = mxs_probe_common(dev, &mode, bpp, plat->base); + ret = mxs_probe_common(dev, &timings, bpp, plat->base); if (ret) return ret;
@@ -378,8 +370,8 @@ static int mxs_video_probe(struct udevice *dev) return -EINVAL; }
- uc_priv->xsize = mode.xres; - uc_priv->ysize = mode.yres; + uc_priv->xsize = timings.hactive.typ; + uc_priv->ysize = timings.vactive.typ;
/* Enable dcache for the frame buffer */ fb_start = plat->base & ~(MMU_SECTION_SIZE - 1);
On Wed, 8 Apr 2020 17:10:15 +0200 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
-- Anatolij
struct display_timings provides more informations such clock and DE polarity, so let's refactor the code to use struct display_timings instead of struct ctfb_res_modes, so we'll become able to get clock and DE polarity settings and set register according to them in the next patch. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Anatolij Gustschin agust@denx.de
HSYNC signal can now be flipped according to display_flags bitmaks by writing its bitmask on vdctrl0 register.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/video/mxsfb.c | 14 ++++++++++---- 1 file changed, 10 insertions(+), 4 deletions(-)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index cdd6dfaced..9912cf3d82 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -57,8 +57,10 @@ static void mxs_lcd_init(struct udevice *dev, u32 fb_addr, struct display_timing *timings, int bpp) { struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; + const enum display_flags flags = timings->flags; uint32_t word_len = 0, bus_width = 0; uint8_t valid_data = 0; + uint32_t vdctrl0;
#if CONFIG_IS_ENABLED(CLK) struct clk per_clk; @@ -118,10 +120,14 @@ static void mxs_lcd_init(struct udevice *dev, u32 fb_addr, writel((timings->vactive.typ << LCDIF_TRANSFER_COUNT_V_COUNT_OFFSET) | timings->hactive.typ, ®s->hw_lcdif_transfer_count);
- writel(LCDIF_VDCTRL0_ENABLE_PRESENT | LCDIF_VDCTRL0_ENABLE_POL | - LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT | - LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT | - timings->vsync_len.typ, ®s->hw_lcdif_vdctrl0); + vdctrl0 = LCDIF_VDCTRL0_ENABLE_PRESENT | LCDIF_VDCTRL0_ENABLE_POL | + LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT | + LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT | + timings->vsync_len.typ; + + if(flags & DISPLAY_FLAGS_HSYNC_HIGH) + vdctrl0 |= LCDIF_VDCTRL0_HSYNC_POL; + writel(vdctrl0, ®s->hw_lcdif_vdctrl0); writel(timings->vback_porch.typ + timings->vfront_porch.typ + timings->vsync_len.typ + timings->vactive.typ, ®s->hw_lcdif_vdctrl1);
On Wed, 8 Apr 2020 17:10:16 +0200 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
-- Anatolij
HSYNC signal can now be flipped according to display_flags bitmaks by writing its bitmask on vdctrl0 register. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Anatolij Gustschin agust@denx.de
VSYNC signal can now be flipped by writing its bitmask on vdctrl0 register.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/video/mxsfb.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 9912cf3d82..4d33e24e1a 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -127,6 +127,8 @@ static void mxs_lcd_init(struct udevice *dev, u32 fb_addr,
if(flags & DISPLAY_FLAGS_HSYNC_HIGH) vdctrl0 |= LCDIF_VDCTRL0_HSYNC_POL; + if(flags & DISPLAY_FLAGS_VSYNC_HIGH) + vdctrl0 |= LCDIF_VDCTRL0_VSYNC_POL; writel(vdctrl0, ®s->hw_lcdif_vdctrl0); writel(timings->vback_porch.typ + timings->vfront_porch.typ + timings->vsync_len.typ + timings->vactive.typ,
On Wed, 8 Apr 2020 17:10:17 +0200 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
-- Anatolij
VSYNC signal can now be flipped by writing its bitmask on vdctrl0 register. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Anatolij Gustschin agust@denx.de
DOTCLK signal can now be flipped by writing its bitmask on vdctrl0 register.
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 4d33e24e1a..648e1c22fe 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -129,6 +129,8 @@ static void mxs_lcd_init(struct udevice *dev, u32 fb_addr, vdctrl0 |= LCDIF_VDCTRL0_HSYNC_POL; if(flags & DISPLAY_FLAGS_VSYNC_HIGH) vdctrl0 |= LCDIF_VDCTRL0_VSYNC_POL; + if(flags & DISPLAY_FLAGS_PIXDATA_NEGEDGE) + vdctrl0 |= LCDIF_VDCTRL0_DOTCLK_POL; writel(vdctrl0, ®s->hw_lcdif_vdctrl0); writel(timings->vback_porch.typ + timings->vfront_porch.typ + timings->vsync_len.typ + timings->vactive.typ,
On Wed, 8 Apr 2020 17:10:18 +0200 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
-- Anatolij
DOTCLK signal can now be flipped by writing its bitmask on vdctrl0 register. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Anatolij Gustschin agust@denx.de
ENABLE signal can now be flipped by writing its bitmask on vdctrl0 register.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/video/mxsfb.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 648e1c22fe..8a5a61c9fb 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -131,6 +131,9 @@ static void mxs_lcd_init(struct udevice *dev, u32 fb_addr, vdctrl0 |= LCDIF_VDCTRL0_VSYNC_POL; if(flags & DISPLAY_FLAGS_PIXDATA_NEGEDGE) vdctrl0 |= LCDIF_VDCTRL0_DOTCLK_POL; + if(flags & DISPLAY_FLAGS_DE_HIGH) + vdctrl0 |= LCDIF_VDCTRL0_ENABLE_POL; + writel(vdctrl0, ®s->hw_lcdif_vdctrl0); writel(timings->vback_porch.typ + timings->vfront_porch.typ + timings->vsync_len.typ + timings->vactive.typ,
On Wed, 8 Apr 2020 17:10:19 +0200 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
-- Anatolij
ENABLE signal can now be flipped by writing its bitmask on vdctrl0 register. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Anatolij Gustschin agust@denx.de
i.MXRT1050 provides mxsfb compatible lcd controller, so let's enable video mxsfb driver with 16bpp depth if CONFIG_DM_VIDEO is selected since board has 16bpp only connection.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- include/configs/imxrt1050-evk.h | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/include/configs/imxrt1050-evk.h b/include/configs/imxrt1050-evk.h index cdec657fb0..3a6b972d9a 100644 --- a/include/configs/imxrt1050-evk.h +++ b/include/configs/imxrt1050-evk.h @@ -30,6 +30,21 @@
#define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC1 */
+#ifdef CONFIG_DM_VIDEO +#define CONFIG_VIDEO_MXS +#define CONFIG_VIDEO_LOGO +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_VIDEO_BMP_LOGO + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "stdin=serial\0" \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" +#endif + /* * Configuration of the external SDRAM memory */
On Wed, 8 Apr 2020 17:10:20 +0200 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
-- Anatolij
i.MXRT1050 provides mxsfb compatible lcd controller, so let's enable video mxsfb driver with 16bpp depth if CONFIG_DM_VIDEO is selected since board has 16bpp only connection. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Anatolij Gustschin agust@denx.de
Add lcdif node to SoC.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1050.dtsi | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/dts/imxrt1050.dtsi b/arch/arm/dts/imxrt1050.dtsi index b1d98e6feb..0123f4788c 100644 --- a/arch/arm/dts/imxrt1050.dtsi +++ b/arch/arm/dts/imxrt1050.dtsi @@ -13,6 +13,7 @@
/ { aliases { + display0 = &lcdif; gpio0 = &gpio1; gpio1 = &gpio2; gpio2 = &gpio3; @@ -142,5 +143,14 @@ interrupt-controller; #interrupt-cells = <2>; }; + + lcdif: lcdif@402b8000 { + compatible = "fsl,imxrt-lcdif"; + reg = <0x402b8000 0x10000>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMXRT1050_CLK_LCDIF>; + clock-names = "per"; + status = "disabled"; + }; }; };
On Wed, 8 Apr 2020 17:10:21 +0200 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
-- Anatolij
Add lcdif node to SoC. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Anatolij Gustschin agust@denx.de
Kindly ping
Hi Giulio,
On Wed, Apr 8, 2020 at 12:10 PM Giulio Benetti giulio.benetti@benettiengineering.com wrote:
Nice work!
This series looks good to me:
Reviewed-by: Fabio Estevam festevam@gmail.com
Hi Fabio,
On 4/16/20 3:26 AM, Fabio Estevam wrote:
Hi Giulio,
Nice work!
Thank you for reviewing Best regards
Anatolij Gustschin
Fabio Estevam
Giulio Benetti
sbabic@denx.de
