[U-Boot] [PULL] Please pull u-boot-imx
Hi Tom,
this contains the last fixes sent on Friday. There are still concerns last Bryan's patch: imx: hab: Convert DCD non-NULL error to warning
This is still under discussion (and it is not part of my PR).
The following changes since commit 2e5c42c630c4c550abf9d8da8cc11d8a7928ab0a:
Merge git://git.denx.de/u-boot-imx (2018-03-09 13:29:58 -0500)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 6d7403bf72b5ea46497fe8222d0303cb79563379:
doc: mxc_hab: Update i.MX HAB documentation (2018-03-11 16:00:21 +0100)
---------------------------------------------------------------- Breno Lima (2): doc: mxc_hab: Move HAB related info to the appropriate doc doc: mxc_hab: Update i.MX HAB documentation
Bryan O'Donoghue (2): imx: hab: Fix usage of packed attribute imx: hab: Make usage of packed attribute consistent
Jagan Teki (2): ARM: dts: imx6qdl-icore-rqs: Sync usdhc4 node from Linux ARM: dts: imx6dl-icore-rqs: Fix to include correct dtsi
arch/arm/dts/imx6dl-icore-rqs.dts | 2 +- arch/arm/dts/imx6qdl-icore-rqs.dtsi | 37 +++++++++++++++++++++++++++++- arch/arm/include/asm/mach-imx/hab.h | 5 ++-- doc/README.imx6 | 48 --------------------------------------- doc/README.mxc_hab | 97 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++--------------------- 5 files changed, 111 insertions(+), 78 deletions(-)
On Sun, Mar 11, 2018 at 04:07:29PM +0100, Stefano Babic wrote:
Hi Tom,
Stefano Babic
