[U-Boot] [PATCH] configs: am335x_boneblack: Bring back missed bootcmd
Commit b6251db8c3f0 ("Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMAND") removed CONFIG_BOOTCOMMAND option from include/configs/am335x_evm.h file. But that option wasn't added to defconfig files for BeagleBone Black board.
Because of this we can't boot Linux from SD card using just "run bootcmd", getting next error:
** File not found /boot/undefined **
That's because "fdtfile" variable has "undefined" value by default, and "bootcmd" doesn't call "run findfdt" command, which assigns "fdtfile" to correct device tree file for current board name (obtained from EEPROM).
So we are forced to either call "run findfdt" command manually, or assign manually "fdtfile=am335x-boneblack.dtb" (e.g. in uEnv.txt file).
Bring back CONFIG_BOOTCOMMAND to BBB defconfigs so that we can boot Linux rootfs from SD card automatically without any addition actions.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- configs/am335x_boneblack_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index 55e0ebd69c..50093cd662 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -5,6 +5,7 @@ CONFIG_AM33XX=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" +CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index fe5b9e7622..aa9fb9739e 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -8,6 +8,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" +CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y
Sam Protsenko
