[PATCH v3 00/30] x86: Allow Coral to boot into Chrome OS
This series adds various minor features and tweaks to allow Coral to boot into Chrome OS from U-Boot.
It relies on three other series which have been recently sent:
- smbios (u-boot-dm/smbios-working) - bootm (u-boot-dm/bootm-working) - misca (u-boot-dm/misca-working)
This should provide a solid base for using ACPI on other Intel Apollo Lake (APL) devices.
Changes in v3: - Add a macro to read gd->acpi_ctx to allow use of IS_ENABLED() - Move the bloblist types into this patch - Avoid build error when gd->acpi_ctx is not available - Correct printf specifier for debug lines
Changes in v2: - Rename update_fixed_mtrss() to update_fixed_mtrrs() - Add comments to enable_pm_timer_emulation() and cpu_mca_configure() - Convert spaces to tabs for consistency - Use log_err() to report error - Rename struct chromeos_acpi to struct chromeos_acpi_gnvs - Fix comment style - Define CONFIG_CHROMEOS_VBOOT in the Kconfig too - Correct a bisect build error - Drop patch "Store the FADT so we can avoid searching for it" - Drop patch "Move ROM_TABLE_ADDR into the C file"
Simon Glass (30): Add an assembly guard around linux/bitops.h x86: apl: Add core init for the SoC x86: Add a layout for Chrome OS verified boot x86: Add support for private files x86: Allow writing tables to fail x86: acpi: Store the ACPI context in global_data x86: Don't bother clearing global NVS x86: coral: Drop the duplicate PCIe settings x86: Add SMBIOS info for Coral x86: coral: Correct max98357 file x86: Use if instead of #ifdef in write_tables() x86: Allow putting some tables in the bloblist x86: nhlt: Correct output of bytes and 16-bit data x86: nhlt: Fix a few bugs in the table generation x86: Show the interrupt pointer with 'irqinfo' x86: sound: Correct error handling acpi: Correct reset handling in acpi_device_add_power_res() x86: acpi: Allow the SSDT to be empty x86: acpi: Put the generated code first in DSDT acpi: Don't reset the tables with every new generation x86: Define the Chrome OS GNVS region x86: Use CONFIG_CHROMEOS_VBOOT for verified boot x86: Set up Chrome OS to boot into developer mode x86: Boot coral into Chrome OS by default x86: fsp: Convert fsp_dram to use log_debug() x86: Silence some logging statements x86: acpi: Include the TPMv1 table only if needed x86: acpi: Don't show the UART address by default x86: pinctrl: Silence the warning when a pin is not found x86: fsp: Adjust calculations for MTRR range and DRAM top
arch/x86/cpu/apollolake/acpi.c | 25 ++++- arch/x86/cpu/apollolake/cpu.c | 84 +++++++++++++++++ arch/x86/cpu/apollolake/cpu_common.c | 25 +++++ arch/x86/cpu/apollolake/cpu_spl.c | 20 ---- arch/x86/cpu/apollolake/fsp_s.c | 8 +- arch/x86/cpu/cpu.c | 9 +- arch/x86/cpu/i386/interrupt.c | 14 +-- arch/x86/cpu/intel_common/acpi.c | 1 - arch/x86/cpu/intel_common/cpu.c | 19 ++++ arch/x86/cpu/intel_common/intel_opregion.c | 2 +- arch/x86/cpu/intel_common/itss.c | 8 +- arch/x86/dts/chromebook_coral.dts | 12 ++- arch/x86/dts/chromebook_samus.dts | 2 +- arch/x86/dts/u-boot.dtsi | 4 + arch/x86/include/asm/acpi/vbnv_layout.h | 38 ++++++++ arch/x86/include/asm/arch-apollolake/cpu.h | 14 +++ arch/x86/include/asm/cpu_common.h | 9 ++ arch/x86/include/asm/intel_gnvs.h | 54 ++++++++++- arch/x86/include/asm/interrupt.h | 17 ++++ arch/x86/include/asm/msr-index.h | 20 +++- arch/x86/include/asm/tables.h | 4 +- arch/x86/lib/acpi_nhlt.c | 19 +++- arch/x86/lib/acpi_table.c | 78 ++++++++++------ arch/x86/lib/fsp/fsp_dram.c | 35 ++++--- arch/x86/lib/fsp/fsp_graphics.c | 2 +- arch/x86/lib/fsp2/fsp_dram.c | 8 +- arch/x86/lib/interrupts.c | 3 + arch/x86/lib/tables.c | 86 +++++++++++++----- arch/x86/lib/tpl.c | 2 +- .../max98357-render-2ch-48khz-24b.dat | Bin 0 -> 116 bytes common/Kconfig.boot | 17 ++++ configs/chromebook_coral_defconfig | 11 ++- drivers/core/acpi.c | 10 +- drivers/pinctrl/intel/pinctrl.c | 2 +- drivers/sound/da7219.c | 4 +- drivers/sound/max98357a.c | 2 +- include/acpi/acpi_table.h | 10 ++ include/asm-generic/global_data.h | 13 +++ include/bloblist.h | 2 + include/configs/chromebook_coral.h | 9 +- include/dm/acpi.h | 9 ++ include/linux/bitops.h | 4 +- lib/Kconfig | 9 ++ lib/acpi/acpi_device.c | 2 +- lib/acpi/acpi_table.c | 4 +- test/dm/acpi.c | 4 + 46 files changed, 595 insertions(+), 139 deletions(-) create mode 100644 arch/x86/include/asm/acpi/vbnv_layout.h
This file can be included by any header but it includes C code. Guard it to avoid errors when compiling ASL, etc.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
(no changes since v1)
include/linux/bitops.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/linux/bitops.h b/include/linux/bitops.h index 6b509dce58a..16f28993f5e 100644 --- a/include/linux/bitops.h +++ b/include/linux/bitops.h @@ -1,7 +1,7 @@ #ifndef _LINUX_BITOPS_H #define _LINUX_BITOPS_H
-#ifndef USE_HOSTCC +#if !defined(USE_HOSTCC) && !defined(__ASSEMBLY__)
#include <asm/types.h> #include <asm-generic/bitsperlong.h> @@ -218,6 +218,6 @@ static inline void generic_clear_bit(int nr, volatile unsigned long *addr) *p &= ~mask; }
-#endif /* !USE_HOSTCC */ +#endif /* !USE_HOSTCC && !__ASSEMBLY__ */
#endif
Set up MSRs required for Apollo Lake. This enables Linux to use the timers correctly. Also write the fixed MSRs for this platform.
(no changes since v2)
arch/x86/cpu/apollolake/cpu.c | 84 ++++++++++++++++++++++ arch/x86/cpu/apollolake/cpu_common.c | 25 +++++++ arch/x86/cpu/apollolake/cpu_spl.c | 20 ------ arch/x86/cpu/intel_common/cpu.c | 19 +++++ arch/x86/include/asm/arch-apollolake/cpu.h | 14 ++++ arch/x86/include/asm/cpu_common.h | 9 +++ arch/x86/include/asm/msr-index.h | 20 +++++- 7 files changed, 170 insertions(+), 21 deletions(-)
diff --git a/arch/x86/cpu/apollolake/cpu.c b/arch/x86/cpu/apollolake/cpu.c index a4c9c96cfdc..d37f91d1ce1 100644 --- a/arch/x86/cpu/apollolake/cpu.c +++ b/arch/x86/cpu/apollolake/cpu.c @@ -13,6 +13,9 @@ #include <asm/cpu_x86.h> #include <asm/intel_acpi.h> #include <asm/msr.h> +#include <asm/mtrr.h> +#include <asm/arch/cpu.h> +#include <asm/arch/iomap.h> #include <dm/acpi.h>
#define CSTATE_RES(address_space, width, offset, address) \ @@ -86,6 +89,86 @@ static int acpi_cpu_fill_ssdt(const struct udevice *dev, struct acpi_ctx *ctx) return 0; }
+static void update_fixed_mtrrs(void) +{ + native_write_msr(MTRR_FIX_64K_00000_MSR, + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); + native_write_msr(MTRR_FIX_16K_80000_MSR, + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); + native_write_msr(MTRR_FIX_4K_E0000_MSR, + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); + native_write_msr(MTRR_FIX_4K_E8000_MSR, + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); + native_write_msr(MTRR_FIX_4K_F0000_MSR, + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); + native_write_msr(MTRR_FIX_4K_F8000_MSR, + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); +} + +static void setup_core_msrs(void) +{ + wrmsrl(MSR_PMG_CST_CONFIG_CONTROL, + PKG_C_STATE_LIMIT_C2_MASK | CORE_C_STATE_LIMIT_C10_MASK | + IO_MWAIT_REDIRECT_MASK | CST_CFG_LOCK_MASK); + /* Power Management I/O base address for I/O trapping to C-states */ + wrmsrl(MSR_PMG_IO_CAPTURE_ADR, ACPI_PMIO_CST_REG | + (PMG_IO_BASE_CST_RNG_BLK_SIZE << 16)); + /* Disable C1E */ + msr_clrsetbits_64(MSR_POWER_CTL, 0x2, 0); + /* Disable support for MONITOR and MWAIT instructions */ + msr_clrsetbits_64(MSR_IA32_MISC_ENABLE, MISC_ENABLE_MWAIT, 0); + /* + * Enable and Lock the Advanced Encryption Standard (AES-NI) + * feature register + */ + msr_clrsetbits_64(MSR_FEATURE_CONFIG, FEATURE_CONFIG_RESERVED_MASK, + FEATURE_CONFIG_LOCK); + + update_fixed_mtrrs(); +} + +static int soc_core_init(void) +{ + struct udevice *pmc; + int ret; + + /* Clear out pending MCEs */ + cpu_mca_configure(); + + /* Set core MSRs */ + setup_core_msrs(); + /* + * Enable ACPI PM timer emulation, which also lets microcode know + * location of ACPI_BASE_ADDRESS. This also enables other features + * implemented in microcode. + */ + ret = uclass_first_device_err(UCLASS_ACPI_PMC, &pmc); + if (ret) + return log_msg_ret("PMC", ret); + enable_pm_timer_emulation(pmc); + + return 0; +} + +static int cpu_apl_probe(struct udevice *dev) +{ + if (gd->flags & GD_FLG_RELOC) { + int ret; + + ret = soc_core_init(); + if (ret) + return log_ret(ret); + } + + return 0; +} + struct acpi_ops apl_cpu_acpi_ops = { .fill_ssdt = acpi_cpu_fill_ssdt, }; @@ -107,6 +190,7 @@ U_BOOT_DRIVER(intel_apl_cpu) = { .id = UCLASS_CPU, .of_match = cpu_x86_apl_ids, .bind = cpu_x86_bind, + .probe = cpu_apl_probe, .ops = &cpu_x86_apl_ops, ACPI_OPS_PTR(&apl_cpu_acpi_ops) .flags = DM_FLAG_PRE_RELOC, diff --git a/arch/x86/cpu/apollolake/cpu_common.c b/arch/x86/cpu/apollolake/cpu_common.c index ba6bda37bc5..63f6999b024 100644 --- a/arch/x86/cpu/apollolake/cpu_common.c +++ b/arch/x86/cpu/apollolake/cpu_common.c @@ -4,8 +4,13 @@ */
#include <common.h> +#include <dm.h> +#include <log.h> #include <asm/cpu_common.h> #include <asm/msr.h> +#include <asm/arch/cpu.h> +#include <asm/arch/iomap.h> +#include <power/acpi_pmc.h>
void cpu_flush_l1d_to_l2(void) { @@ -15,3 +20,23 @@ void cpu_flush_l1d_to_l2(void) msr.lo |= FLUSH_DL1_L2; msr_write(MSR_POWER_MISC, msr); } + +void enable_pm_timer_emulation(const struct udevice *pmc) +{ + struct acpi_pmc_upriv *upriv = dev_get_uclass_priv(pmc); + msr_t msr; + + /* + * The derived frequency is calculated as follows: + * (CTC_FREQ * msr[63:32]) >> 32 = target frequency. + * + * Back-solve the multiplier so the 3.579545MHz ACPI timer frequency is + * used. + */ + msr.hi = (3579545ULL << 32) / CTC_FREQ; + + /* Set PM1 timer IO port and enable */ + msr.lo = EMULATE_PM_TMR_EN | (upriv->acpi_base + R_ACPI_PM1_TMR); + debug("PM timer %x %x\n", msr.hi, msr.lo); + msr_write(MSR_EMULATE_PM_TIMER, msr); +} diff --git a/arch/x86/cpu/apollolake/cpu_spl.c b/arch/x86/cpu/apollolake/cpu_spl.c index 9f32f2e27e1..fafe4dbc0a0 100644 --- a/arch/x86/cpu/apollolake/cpu_spl.c +++ b/arch/x86/cpu/apollolake/cpu_spl.c @@ -114,26 +114,6 @@ static int fast_spi_cache_bios_region(void) return 0; }
-static void enable_pm_timer_emulation(struct udevice *pmc) -{ - struct acpi_pmc_upriv *upriv = dev_get_uclass_priv(pmc); - msr_t msr; - - /* - * The derived frequency is calculated as follows: - * (CTC_FREQ * msr[63:32]) >> 32 = target frequency. - * - * Back-solve the multiplier so the 3.579545MHz ACPI timer frequency is - * used. - */ - msr.hi = (3579545ULL << 32) / CTC_FREQ; - - /* Set PM1 timer IO port and enable */ - msr.lo = EMULATE_PM_TMR_EN | (upriv->acpi_base + R_ACPI_PM1_TMR); - debug("PM timer %x %x\n", msr.hi, msr.lo); - msr_write(MSR_EMULATE_PM_TIMER, msr); -} - static void google_chromeec_ioport_range(uint *out_basep, uint *out_sizep) { uint base; diff --git a/arch/x86/cpu/intel_common/cpu.c b/arch/x86/cpu/intel_common/cpu.c index 39aa0f63c65..a51bf86f7ab 100644 --- a/arch/x86/cpu/intel_common/cpu.c +++ b/arch/x86/cpu/intel_common/cpu.c @@ -306,3 +306,22 @@ int cpu_get_cores_per_package(void)
return cores; } + +void cpu_mca_configure(void) +{ + msr_t msr; + int i; + int num_banks; + + msr = msr_read(MSR_IA32_MCG_CAP); + num_banks = msr.lo & 0xff; + msr.lo = 0; + msr.hi = 0; + for (i = 0; i < num_banks; i++) { + /* Clear the machine check status */ + msr_write(MSR_IA32_MC0_STATUS + (i * 4), msr); + /* Initialise machine checks */ + msr_write(MSR_IA32_MC0_CTL + i * 4, + (msr_t) {.lo = 0xffffffff, .hi = 0xffffffff}); + } +} diff --git a/arch/x86/include/asm/arch-apollolake/cpu.h b/arch/x86/include/asm/arch-apollolake/cpu.h index 5e906c5e7d7..67d48c61098 100644 --- a/arch/x86/include/asm/arch-apollolake/cpu.h +++ b/arch/x86/include/asm/arch-apollolake/cpu.h @@ -15,6 +15,20 @@ #ifndef __ASSEMBLY__ /* Flush L1D to L2 */ void cpu_flush_l1d_to_l2(void); + +/** + * Enable emulation of the PM timer + * + * Some legacy OSes cannot tolerate the ACPI timer stoping during idle states, + * and this results in higher power consumption. ACPI timer emulation allows + * disabling of the ACPI Timer (PM1_TMR) to have no impact on the system, with + * the exception that TMR_STS will not be set on an overflow condition. All + * aligned 32-bit reads from the ACPI Timer port are valid and will behave as if + * the ACPI timer remains enabled. + * + * @pmc: PMC device + */ +void enable_pm_timer_emulation(const struct udevice *pmc); #endif
#endif /* _ASM_ARCH_CPU_H */ diff --git a/arch/x86/include/asm/cpu_common.h b/arch/x86/include/asm/cpu_common.h index 48f56c2aad9..2a5779a8e1a 100644 --- a/arch/x86/include/asm/cpu_common.h +++ b/arch/x86/include/asm/cpu_common.h @@ -184,4 +184,13 @@ int cpu_get_max_turbo_ratio(void); */ int cpu_get_cores_per_package(void);
+/** + * cpu_mca_configure() - Set up machine-check exceptions ready for use + * + * These allow the SoC to report errors while running. See here for details: + * + * https://www.intel.com/content/dam/www/public/us/en/documents/white-papers/ma... + */ +void cpu_mca_configure(void); + #endif diff --git a/arch/x86/include/asm/msr-index.h b/arch/x86/include/asm/msr-index.h index 94e6b18e21c..c49b4225ac2 100644 --- a/arch/x86/include/asm/msr-index.h +++ b/arch/x86/include/asm/msr-index.h @@ -68,7 +68,18 @@ #define MSR_BSEL_CR_OVERCLOCK_CONTROL 0x000000cd #define MSR_PLATFORM_INFO 0x000000ce #define MSR_PMG_CST_CONFIG_CONTROL 0x000000e2 -#define SINGLE_PCTL (1 << 11) +/* Set MSR_PMG_CST_CONFIG_CONTROL[3:0] for Package C-State limit */ +#define PKG_C_STATE_LIMIT_C2_MASK BIT(1) +/* Set MSR_PMG_CST_CONFIG_CONTROL[7:4] for Core C-State limit*/ +#define CORE_C_STATE_LIMIT_C10_MASK 0x70 +/* Set MSR_PMG_CST_CONFIG_CONTROL[10] to IO redirect to MWAIT */ +#define IO_MWAIT_REDIRECT_MASK BIT(10) +/* Set MSR_PMG_CST_CONFIG_CONTROL[15] to lock CST_CFG [0-15] bits */ +#define CST_CFG_LOCK_MASK BIT(15) +#define SINGLE_PCTL BIT(11) + +/* ACPI PMIO Offset to C-state register */ +#define ACPI_PMIO_CST_REG (ACPI_BASE_ADDRESS + 0x14)
#define MSR_MTRRcap 0x000000fe #define MSR_IA32_BBL_CR_CTL 0x00000119 @@ -83,6 +94,10 @@ #define EMULATE_PM_TMR_EN (1 << 16) #define EMULATE_DELAY_VALUE 0x13
+#define MSR_FEATURE_CONFIG 0x13c +#define FEATURE_CONFIG_RESERVED_MASK 0x3ULL +#define FEATURE_CONFIG_LOCK (1 << 0) + #define MSR_IA32_SYSENTER_CS 0x00000174 #define MSR_IA32_SYSENTER_ESP 0x00000175 #define MSR_IA32_SYSENTER_EIP 0x00000176 @@ -453,6 +468,9 @@ #define MSR_AMD_PERF_CTL 0xc0010062
#define MSR_PMG_CST_CONFIG_CTL 0x000000e2 +/* CST Range (R/W) IO port block size */ +#define PMG_IO_BASE_CST_RNG_BLK_SIZE 0x5 + #define MSR_PMG_IO_CAPTURE_ADR 0x000000e4 #define MSR_IA32_MPERF 0x000000e7 #define MSR_IA32_APERF 0x000000e8
Add definitions for part of the vboot context used with verified boot.
Changes in v2: - Convert spaces to tabs for consistency
arch/x86/include/asm/acpi/vbnv_layout.h | 38 +++++++++++++++++++++++++ 1 file changed, 38 insertions(+) create mode 100644 arch/x86/include/asm/acpi/vbnv_layout.h
diff --git a/arch/x86/include/asm/acpi/vbnv_layout.h b/arch/x86/include/asm/acpi/vbnv_layout.h new file mode 100644 index 00000000000..89065524d37 --- /dev/null +++ b/arch/x86/include/asm/acpi/vbnv_layout.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2020 Google LLC + */ + +#ifndef __ASM_ACPI_VBNV_LAYOUT_H__ +#define __ASM_ACPI_VBNV_LAYOUT_H__ + +#define VBOOT_VBNV_BLOCK_SIZE 16 /* Size of NV storage block in bytes */ + +/* Constants for NV storage, for use with ACPI */ +#define HEADER_OFFSET 0 +#define HEADER_MASK 0xc0 +#define HEADER_SIGNATURE 0x40 +#define HEADER_FIRMWARE_SETTINGS_RESET 0x20 +#define HEADER_KERNEL_SETTINGS_RESET 0x10 + +#define BOOT_OFFSET 1 +#define BOOT_DEBUG_RESET_MODE 0x80 +#define BOOT_DISABLE_DEV_REQUEST 0x40 +#define BOOT_DISPLAY_REQUEST 0x20 +#define BOOT_TRY_B_COUNT_MASK 0x0f + +#define RECOVERY_OFFSET 2 +#define LOCALIZATION_OFFSET 3 + +#define DEV_FLAGS_OFFSET 4 +#define DEV_BOOT_USB_MASK 0x01 +#define DEV_BOOT_SIGNED_ONLY_MASK 0x02 +#define DEV_ENABLE_UDC 0x40 + +#define MISC_FLAGS_OFFSET 8 +#define MISC_FLAGS_BATTERY_CUTOFF_MASK 0x08 + +#define KERNEL_FIELD_OFFSET 11 +#define CRC_OFFSET 15 + +#endif /* __ASM_ACPI_VBNV_LAYOUT_H__ */
Some boards need to include binary data into the image for use during the boot process. Add a node for these.
An example is the audio-codec configuration used by some audio drivers on Intel platforms. If no private files are provided, they will be omitted.
arch/x86/dts/u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/x86/dts/u-boot.dtsi b/arch/x86/dts/u-boot.dtsi index 90badcc15c9..bf92f45f2d3 100644 --- a/arch/x86/dts/u-boot.dtsi +++ b/arch/x86/dts/u-boot.dtsi @@ -138,6 +138,10 @@ filename = CONFIG_FSP_FILE_S; }; #endif + private_files: private-files { + type = "files"; + pattern = "*.dat"; + }; #ifdef CONFIG_HAVE_CMC intel-cmc { filename = CONFIG_CMC_FILE;
At present write_tables() can fail but does not report this problem to its caller. Fix this by changing the return type.
Changes in v2: - Use log_err() to report error
arch/x86/cpu/cpu.c | 9 ++++++++- arch/x86/include/asm/tables.h | 4 +++- arch/x86/lib/tables.c | 5 ++++- 3 files changed, 15 insertions(+), 3 deletions(-)
diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index f8692753963..71351262f66 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -18,6 +18,8 @@ * src/arch/x86/lib/cpu.c */
+#define LOG_CATEGORY UCLASS_CPU + #include <common.h> #include <bootstage.h> #include <command.h> @@ -200,6 +202,7 @@ __weak void board_final_cleanup(void) int last_stage_init(void) { struct acpi_fadt __maybe_unused *fadt; + int ret;
board_final_init();
@@ -210,7 +213,11 @@ int last_stage_init(void) acpi_resume(fadt); }
- write_tables(); + ret = write_tables(); + if (ret) { + log_err("Failed to write tables\n"); + return log_msg_ret("table", ret); + }
if (IS_ENABLED(CONFIG_GENERATE_ACPI_TABLE)) { fadt = acpi_find_fadt(); diff --git a/arch/x86/include/asm/tables.h b/arch/x86/include/asm/tables.h index f7c72ed3db0..bf66e79018e 100644 --- a/arch/x86/include/asm/tables.h +++ b/arch/x86/include/asm/tables.h @@ -49,8 +49,10 @@ void table_fill_string(char *dest, const char *src, size_t n, char pad); * This writes x86 configuration tables, including PIRQ routing table, * Multi-Processor table and ACPI table. Whether a specific type of * configuration table is written is controlled by a Kconfig option. + * + * @return 0 if OK, -ENOSPC if table too large */ -void write_tables(void); +int write_tables(void);
/** * write_pirq_routing_table() - Write PIRQ routing table diff --git a/arch/x86/lib/tables.c b/arch/x86/lib/tables.c index 7bad5dd3032..7099866a78a 100644 --- a/arch/x86/lib/tables.c +++ b/arch/x86/lib/tables.c @@ -64,7 +64,7 @@ void table_fill_string(char *dest, const char *src, size_t n, char pad) dest[i] = pad; }
-void write_tables(void) +int write_tables(void) { u32 rom_table_start = ROM_TABLE_ADDR; u32 rom_table_end; @@ -91,6 +91,7 @@ void write_tables(void) cfg_tables[i].size = table_size; } else { printf("%d: no memory for configuration tables\n", i); + return -ENOSPC; } #endif
@@ -105,4 +106,6 @@ void write_tables(void) write_coreboot_table(CB_TABLE_ADDR, cfg_tables); #endif debug("- done writing tables\n"); + + return 0; }
At present we create the ACPI context but then drop it after generation of tables is complete. This is annoying because we have to then search for tables later.
To fix this, allocate the context and store it in global_data.
arch/x86/lib/acpi_table.c | 7 ++++++- include/asm-generic/global_data.h | 13 +++++++++++++ 2 files changed, 19 insertions(+), 1 deletion(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 6d405b09fde..f0f342d8935 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -494,7 +494,7 @@ void acpi_create_ssdt(struct acpi_ctx *ctx, struct acpi_table_header *ssdt, */ ulong write_acpi_tables(ulong start_addr) { - struct acpi_ctx sctx, *ctx = &sctx; + struct acpi_ctx *ctx; struct acpi_facs *facs; struct acpi_table_header *dsdt; struct acpi_fadt *fadt; @@ -509,6 +509,11 @@ ulong write_acpi_tables(ulong start_addr) int ret; int i;
+ ctx = calloc(1, sizeof(*ctx)); + if (!ctx) + return log_msg_ret("mem", -ENOMEM); + gd->acpi_ctx = ctx; + start = map_sysmem(start_addr, 0);
debug("ACPI: Writing ACPI tables at %lx\n", start_addr); diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index f3920437968..87d827d0f43 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -24,6 +24,7 @@ #include <membuff.h> #include <linux/list.h>
+struct acpi_ctx; struct driver_rt;
typedef struct global_data gd_t; @@ -420,6 +421,12 @@ struct global_data { */ struct udevice *watchdog_dev; #endif +#ifdef CONFIG_GENERATE_ACPI_TABLE + /** + * @acpi_ctx: ACPI context pointer + */ + struct acpi_ctx *acpi_ctx; +#endif };
/** @@ -452,6 +459,12 @@ struct global_data { #define gd_dm_driver_rt() NULL #endif
+#ifdef CONFIG_GENERATE_ACPI_TABLE +#define gd_acpi_ctx() gd->acpi_ctx +#else +#define gd_acpi_ctx() NULL +#endif + /** * enum gd_flags - global data flags *
The bloblist guarantees that blobs are zeroed so there is no need to do an additional memset(). Drop it.
arch/x86/cpu/intel_common/acpi.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/x86/cpu/intel_common/acpi.c b/arch/x86/cpu/intel_common/acpi.c index 4496bbfd999..6a3456f4760 100644 --- a/arch/x86/cpu/intel_common/acpi.c +++ b/arch/x86/cpu/intel_common/acpi.c @@ -202,7 +202,6 @@ int southbridge_inject_dsdt(const struct udevice *dev, struct acpi_ctx *ctx) (void **)&gnvs); if (ret) return log_msg_ret("bloblist", ret); - memset(gnvs, '\0', sizeof(*gnvs));
ret = acpi_create_gnvs(gnvs); if (ret)
These settings are included twice. The second lot are correct, so drop the others.
Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Wolfgang Wallner wolfgang.wallner@br-automation.com Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/dts/chromebook_coral.dts | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/x86/dts/chromebook_coral.dts b/arch/x86/dts/chromebook_coral.dts index 893a59b1620..8801b58bb54 100644 --- a/arch/x86/dts/chromebook_coral.dts +++ b/arch/x86/dts/chromebook_coral.dts @@ -718,8 +718,6 @@
fsps,ish-enable = <0>; fsps,enable-sata = <0>; - fsps,pcie-root-port-en = [00 00 00 00 00 01]; - fsps,pcie-rp-hot-plug = [00 00 00 00 00 01]; fsps,i2c6-enable = <I2CX_ENABLE_DISABLED>; fsps,i2c7-enable = <I2CX_ENABLE_DISABLED>; fsps,hsuart3-enable = <HSUARTX_ENABLE_DISABLED>;
This is required by Chrome OS so that the audio and other unibuild features work correctly. Add it.
arch/x86/dts/chromebook_coral.dts | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/x86/dts/chromebook_coral.dts b/arch/x86/dts/chromebook_coral.dts index 8801b58bb54..92f70b13dd7 100644 --- a/arch/x86/dts/chromebook_coral.dts +++ b/arch/x86/dts/chromebook_coral.dts @@ -54,6 +54,14 @@ recovery-gpios = <&gpio_nw (-1) GPIO_ACTIVE_LOW>; write-protect-gpios = <&gpio_nw GPIO_75 GPIO_ACTIVE_HIGH>; phase-enforce-gpios = <&gpio_n GPIO_10 GPIO_ACTIVE_HIGH>; + smbios { + manufacturer = "Google"; + product = "Coral"; + version = "rev2"; + serial = "123456789"; + sku = "sku3"; + family = "Google_Coral"; + }; };
config {
This somehow ended up as an empty file. Fix it.
.../max98357-render-2ch-48khz-24b.dat | Bin 0 -> 116 bytes 1 file changed, 0 insertions(+), 0 deletions(-)
diff --git a/board/google/chromebook_coral/max98357-render-2ch-48khz-24b.dat b/board/google/chromebook_coral/max98357-render-2ch-48khz-24b.dat index e69de29bb2d1d6434b8b29ae775ad8c2e48c5391..b0b5b9ba648c4546f98e15e42356a5fc4af6bb27 100644 GIT binary patch literal 116 zcmZQzU|?WnWOx?=qy_%}|BnyXGahJUU??~MR0;$VT+Bccgqa+G1PJi6vnv28CMf>T R&%gk}Aix2{5<r{+!~hE!AMpSH
literal 0 HcmV?d00001
Use if() to remove the extra build path in this code.
arch/x86/lib/tables.c | 38 +++++++++++++++++++------------------- 1 file changed, 19 insertions(+), 19 deletions(-)
diff --git a/arch/x86/lib/tables.c b/arch/x86/lib/tables.c index 7099866a78a..f7b71c5cd13 100644 --- a/arch/x86/lib/tables.c +++ b/arch/x86/lib/tables.c @@ -68,10 +68,8 @@ int write_tables(void) { u32 rom_table_start = ROM_TABLE_ADDR; u32 rom_table_end; -#ifdef CONFIG_SEABIOS u32 high_table, table_size; struct memory_area cfg_tables[ARRAY_SIZE(table_list) + 1]; -#endif int i;
debug("Writing tables to %x:\n", rom_table_start); @@ -81,30 +79,32 @@ int write_tables(void) rom_table_end = table->write(rom_table_start); rom_table_end = ALIGN(rom_table_end, ROM_TABLE_ALIGN);
-#ifdef CONFIG_SEABIOS - table_size = rom_table_end - rom_table_start; - high_table = (u32)high_table_malloc(table_size); - if (high_table) { - table->write(high_table); - - cfg_tables[i].start = high_table; - cfg_tables[i].size = table_size; - } else { - printf("%d: no memory for configuration tables\n", i); - return -ENOSPC; + if (IS_ENABLED(CONFIG_SEABIOS)) { + table_size = rom_table_end - rom_table_start; + high_table = (u32)(ulong)high_table_malloc(table_size); + if (high_table) { + table->write(high_table); + + cfg_tables[i].start = high_table; + cfg_tables[i].size = table_size; + } else { + printf("%d: no memory for configuration tables\n", + i); + return -ENOSPC; + } } -#endif
debug("- wrote '%s' to %x, end %x\n", table->name, rom_table_start, rom_table_end); rom_table_start = rom_table_end; }
-#ifdef CONFIG_SEABIOS - /* make sure the last item is zero */ - cfg_tables[i].size = 0; - write_coreboot_table(CB_TABLE_ADDR, cfg_tables); -#endif + if (IS_ENABLED(CONFIG_SEABIOS)) { + /* make sure the last item is zero */ + cfg_tables[i].size = 0; + write_coreboot_table(CB_TABLE_ADDR, cfg_tables); + } + debug("- done writing tables\n");
At present all tables are placed starting at address f0000 in memory, and can be up to 64KB in size. If the tables are very large, this may not provide enough space.
Also if the tables point to other tables (such as console log or a ramoops area) then we must allocate other memory anyway.
The bloblist is a nice place to put these tables since it is contiguous, which makes it easy to reserve this memory for linux using the 820 tables.
Add an option to put some of the tables in the bloblist. For SMBIOS and ACPI, create suitable pointers from the f0000 region to the new location of the tables.
Changes in v3: - Move the bloblist types into this patch - Avoid build error when gd->acpi_ctx is not available
arch/x86/lib/tables.c | 47 ++++++++++++++++++++++++++++++++++++--- include/acpi/acpi_table.h | 10 +++++++++ include/bloblist.h | 2 ++ lib/Kconfig | 9 ++++++++ lib/acpi/acpi_table.c | 4 ++-- 5 files changed, 67 insertions(+), 5 deletions(-)
diff --git a/arch/x86/lib/tables.c b/arch/x86/lib/tables.c index f7b71c5cd13..8dc07868c1f 100644 --- a/arch/x86/lib/tables.c +++ b/arch/x86/lib/tables.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <bloblist.h> #include <log.h> #include <malloc.h> #include <smbios.h> @@ -26,10 +27,16 @@ typedef ulong (*table_write)(ulong addr); * * @name: Name of table (for debugging) * @write: Function to call to write this table + * @tag: Bloblist tag if using CONFIG_BLOBLIST_TABLES + * @size: Maximum table size + * @align: Table alignment in bytes */ struct table_info { const char *name; table_write write; + enum bloblist_tag_t tag; + int size; + int align; };
static struct table_info table_list[] = { @@ -43,10 +50,10 @@ static struct table_info table_list[] = { { "mp", write_mp_table, }, #endif #ifdef CONFIG_GENERATE_ACPI_TABLE - { "acpi", write_acpi_tables, }, + { "acpi", write_acpi_tables, BLOBLISTT_ACPI_TABLES, 0x10000, 0x1000}, #endif #ifdef CONFIG_GENERATE_SMBIOS_TABLE - { "smbios", write_smbios_table, }, + { "smbios", write_smbios_table, BLOBLISTT_SMBIOS_TABLES, 0x1000, 0x100}, #endif };
@@ -66,16 +73,25 @@ void table_fill_string(char *dest, const char *src, size_t n, char pad)
int write_tables(void) { - u32 rom_table_start = ROM_TABLE_ADDR; + u32 rom_table_start; u32 rom_table_end; u32 high_table, table_size; struct memory_area cfg_tables[ARRAY_SIZE(table_list) + 1]; int i;
+ rom_table_start = ROM_TABLE_ADDR; + debug("Writing tables to %x:\n", rom_table_start); for (i = 0; i < ARRAY_SIZE(table_list); i++) { const struct table_info *table = &table_list[i]; + int size = table->size ? : CONFIG_ROM_TABLE_SIZE;
+ if (IS_ENABLED(CONFIG_BLOBLIST_TABLES) && table->tag) { + rom_table_start = (ulong)bloblist_add(table->tag, size, + table->align); + if (!rom_table_start) + return log_msg_ret("bloblist", -ENOBUFS); + } rom_table_end = table->write(rom_table_start); rom_table_end = ALIGN(rom_table_end, ROM_TABLE_ALIGN);
@@ -96,6 +112,11 @@ int write_tables(void)
debug("- wrote '%s' to %x, end %x\n", table->name, rom_table_start, rom_table_end); + if (rom_table_end - rom_table_start > size) { + log_err("Out of space for configuration tables: need %x, have %x\n", + rom_table_end - rom_table_start, size); + return log_msg_ret("bloblist", -ENOSPC); + } rom_table_start = rom_table_end; }
@@ -105,6 +126,26 @@ int write_tables(void) write_coreboot_table(CB_TABLE_ADDR, cfg_tables); }
+ if (IS_ENABLED(CONFIG_BLOBLIST_TABLES)) { + void *ptr = (void *)CONFIG_ROM_TABLE_ADDR; + + /* Write an RSDP pointing to the tables */ + if (IS_ENABLED(CONFIG_GENERATE_ACPI_TABLE)) { + struct acpi_ctx *ctx = gd_acpi_ctx(); + + acpi_write_rsdp(ptr, ctx->rsdt, ctx->xsdt); + ptr += ALIGN(sizeof(struct acpi_rsdp), 16); + } + if (IS_ENABLED(CONFIG_GENERATE_SMBIOS_TABLE)) { + void *smbios; + + smbios = bloblist_find(BLOBLISTT_SMBIOS_TABLES, 0); + if (!smbios) + return log_msg_ret("smbios", -ENOENT); + memcpy(ptr, smbios, sizeof(struct smbios_entry)); + } + } + debug("- done writing tables\n");
return 0; diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index abbca6530db..a28eb71f4d7 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -688,6 +688,16 @@ int acpi_add_table(struct acpi_ctx *ctx, void *table); */ void acpi_setup_base_tables(struct acpi_ctx *ctx, void *start);
+/** + * acpi_write_rsdp() - Write out an RSDP indicating where the ACPI tables are + * + * @rsdp: Address to write RSDP + * @rsdt: Address of RSDT + * @xsdt: Address of XSDT + */ +void acpi_write_rsdp(struct acpi_rsdp *rsdp, struct acpi_rsdt *rsdt, + struct acpi_xsdt *xsdt); + #endif /* !__ACPI__*/
#include <asm/acpi_table.h> diff --git a/include/bloblist.h b/include/bloblist.h index 2b4b6696897..8cdce61187a 100644 --- a/include/bloblist.h +++ b/include/bloblist.h @@ -36,6 +36,8 @@ enum bloblist_tag_t { BLOBLISTT_INTEL_VBT, /* Intel Video-BIOS table */ BLOBLISTT_TPM2_TCG_LOG, /* TPM v2 log space */ BLOBLISTT_TCPA_LOG, /* TPM log space */ + BLOBLISTT_ACPI_TABLES, /* ACPI tables for x86 */ + BLOBLISTT_SMBIOS_TABLES, /* SMBIOS tables for x86 */
BLOBLISTT_COUNT }; diff --git a/lib/Kconfig b/lib/Kconfig index dc4143fc128..9d40ddd5098 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -637,6 +637,15 @@ config FDT_FIXUP_PARTITIONS menu "System tables" depends on (!EFI && !SYS_COREBOOT) || (ARM && EFI_LOADER)
+config BLOBLIST_TABLES + bool "Put tables in a bloblist" + depends on X86 + help + Normally tables are placed at address 0xf0000 and can be up to 64KB + long. With this option, tables are instead placed in the bloblist + with a pointer from 0xf0000. The size can then be larger and the + tables can be placed high in memory. + config GENERATE_SMBIOS_TABLE bool "Generate an SMBIOS (System Management BIOS) table" default y diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 908d8903893..a0f0961be5b 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -183,8 +183,8 @@ int acpi_add_table(struct acpi_ctx *ctx, void *table) return 0; }
-static void acpi_write_rsdp(struct acpi_rsdp *rsdp, struct acpi_rsdt *rsdt, - struct acpi_xsdt *xsdt) +void acpi_write_rsdp(struct acpi_rsdp *rsdp, struct acpi_rsdt *rsdt, + struct acpi_xsdt *xsdt) { memset(rsdp, 0, sizeof(struct acpi_rsdp));
At present these functions are incorrect. Fix them and add some logging and checking to avoid future problems.
Changes in v3: - Correct printf specifier for debug lines
arch/x86/lib/acpi_nhlt.c | 13 ++++++++++--- 1 file changed, 10 insertions(+), 3 deletions(-)
diff --git a/arch/x86/lib/acpi_nhlt.c b/arch/x86/lib/acpi_nhlt.c index c64dd9c0081..1c1ea27c8f6 100644 --- a/arch/x86/lib/acpi_nhlt.c +++ b/arch/x86/lib/acpi_nhlt.c @@ -285,25 +285,26 @@ static void nhlt_free_resources(struct nhlt *nhlt) }
struct cursor { + u8 *start; u8 *buf; };
static void ser8(struct cursor *cur, uint val) { *cur->buf = val; - cur->buf += sizeof(val); + cur->buf += sizeof(u8); }
static void ser16(struct cursor *cur, uint val) { put_unaligned_le16(val, cur->buf); - cur->buf += sizeof(val); + cur->buf += sizeof(u16); }
static void ser32(struct cursor *cur, uint val) { put_unaligned_le32(val, cur->buf); - cur->buf += sizeof(val); + cur->buf += sizeof(u32); }
static void serblob(struct cursor *cur, void *from, size_t sz) @@ -315,12 +316,14 @@ static void serblob(struct cursor *cur, void *from, size_t sz) static void serialise_specific_config(struct nhlt_specific_config *cfg, struct cursor *cur) { + log_debug("%zx\n", cur->buf - cur->start); ser32(cur, cfg->size); serblob(cur, cfg->capabilities, cfg->size); }
static void serialise_waveform(struct nhlt_waveform *wave, struct cursor *cur) { + log_debug("%zx\n", cur->buf - cur->start); ser16(cur, wave->tag); ser16(cur, wave->num_channels); ser32(cur, wave->samples_per_second); @@ -338,6 +341,7 @@ static void serialise_waveform(struct nhlt_waveform *wave, struct cursor *cur)
static void serialise_format(struct nhlt_format *fmt, struct cursor *cur) { + log_debug("%zx\n", cur->buf - cur->start); serialise_waveform(&fmt->waveform, cur); serialise_specific_config(&fmt->config, cur); } @@ -346,6 +350,7 @@ static void serialise_endpoint(struct nhlt_endpoint *endp, struct cursor *cur) { int i;
+ log_debug("%zx\n", cur->buf - cur->start); ser32(cur, endp->length); ser8(cur, endp->link_type); ser8(cur, endp->instance_id); @@ -405,10 +410,12 @@ int nhlt_serialise_oem_overrides(struct acpi_ctx *ctx, struct nhlt *nhlt, header->oem_revision = oem_revision;
cur.buf = (void *)(header + 1); + cur.start = (void *)header; nhlt_serialise_endpoints(nhlt, &cur);
header->checksum = table_compute_checksum(header, sz); nhlt_free_resources(nhlt); + assert(cur.buf - cur.start == sz);
ret = acpi_add_table(ctx, ctx->current); if (ret)
At present these tables do not have the correct header, and there is an occasional incorrect value due to uninited data. Fix these bugs.
arch/x86/lib/acpi_nhlt.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/x86/lib/acpi_nhlt.c b/arch/x86/lib/acpi_nhlt.c index 1c1ea27c8f6..0e8e669c7d8 100644 --- a/arch/x86/lib/acpi_nhlt.c +++ b/arch/x86/lib/acpi_nhlt.c @@ -68,6 +68,7 @@ struct nhlt_endpoint *nhlt_add_endpoint(struct nhlt *nhlt, int link_type, endp->device_type = device_type; endp->direction = dir; endp->virtual_bus_id = DEFAULT_VIRTUAL_BUS_ID; + endp->num_formats = 0;
nhlt->num_endpoints++;
@@ -395,7 +396,7 @@ int nhlt_serialise_oem_overrides(struct acpi_ctx *ctx, struct nhlt *nhlt, /* Create header */ header = (void *)ctx->current; memset(header, '\0', sizeof(struct acpi_table_header)); - acpi_fill_header(header, "NHLT"); + memcpy(header->signature, "NHLT", 4); header->length = sz; header->revision = acpi_get_table_revision(ACPITAB_NHLT);
@@ -408,6 +409,7 @@ int nhlt_serialise_oem_overrides(struct acpi_ctx *ctx, struct nhlt *nhlt, memcpy(header->oem_table_id, oem_table_id, oem_table_id_len); } header->oem_revision = oem_revision; + memcpy(header->aslc_id, ASLC_ID, 4);
cur.buf = (void *)(header + 1); cur.start = (void *)header;
It is useful for this command to show the address of the interrupt table. Add support for this.
arch/x86/cpu/i386/interrupt.c | 14 +++++++------- arch/x86/include/asm/interrupt.h | 17 +++++++++++++++++ arch/x86/lib/interrupts.c | 3 +++ 3 files changed, 27 insertions(+), 7 deletions(-)
diff --git a/arch/x86/cpu/i386/interrupt.c b/arch/x86/cpu/i386/interrupt.c index c0c4bc95fd9..d85f84b29a7 100644 --- a/arch/x86/cpu/i386/interrupt.c +++ b/arch/x86/cpu/i386/interrupt.c @@ -180,16 +180,11 @@ struct idt_entry { u16 base_high; } __packed;
-struct desc_ptr { - unsigned short size; - unsigned long address; -} __packed; - struct idt_entry idt[256] __aligned(16);
-struct desc_ptr idt_ptr; +struct idt_ptr idt_ptr;
-static inline void load_idt(const struct desc_ptr *dtr) +static inline void load_idt(const struct idt_ptr *dtr) { asm volatile("cs lidt %0" : : "m" (*dtr)); } @@ -232,6 +227,11 @@ int cpu_init_interrupts(void) return 0; }
+void interrupt_read_idt(struct idt_ptr *ptr) +{ + asm volatile("sidt %0" : : "m" (*ptr)); +} + void *x86_get_idt(void) { return &idt_ptr; diff --git a/arch/x86/include/asm/interrupt.h b/arch/x86/include/asm/interrupt.h index fdeb8571132..e23fb2c8e72 100644 --- a/arch/x86/include/asm/interrupt.h +++ b/arch/x86/include/asm/interrupt.h @@ -38,6 +38,16 @@ enum x86_exception { EXC_VE };
+/** + * struct idt_ptr - Holds the IDT (Interrupt Descriptor Table) + * + * @size: Size of IDT in bytes + */ +struct idt_ptr { + unsigned short size; + unsigned long address; +} __packed; + /* arch/x86/cpu/interrupts.c */ void set_vector(u8 intnum, void *routine);
@@ -61,4 +71,11 @@ void configure_irq_trigger(int int_num, bool is_level_triggered);
void *x86_get_idt(void);
+/** + * interrupt_read_idt() - Read the IDT + * + * @ptr: Place to put IDT contents + */ +void interrupt_read_idt(struct idt_ptr *ptr); + #endif diff --git a/arch/x86/lib/interrupts.c b/arch/x86/lib/interrupts.c index a81e4291105..ff52959ed28 100644 --- a/arch/x86/lib/interrupts.c +++ b/arch/x86/lib/interrupts.c @@ -131,8 +131,11 @@ void do_irq(int hw_irq) int do_irqinfo(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { #if !CONFIG_IS_ENABLED(X86_64) + struct idt_ptr ptr; int irq;
+ interrupt_read_idt(&ptr); + printf("IDT at %lx, size %x\n", ptr.address, ptr.size); printf("Spurious IRQ: %u, last unknown IRQ: %d\n", spurious_irq_cnt, spurious_irq);
A few functions have changed to return pin numbers or I2C addresses. The error checking for some of the callers is therefore wrong. Fix them.
drivers/sound/da7219.c | 4 ++-- drivers/sound/max98357a.c | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/sound/da7219.c b/drivers/sound/da7219.c index 6bc1ad0036e..8d674bcb4fa 100644 --- a/drivers/sound/da7219.c +++ b/drivers/sound/da7219.c @@ -54,13 +54,13 @@ static int da7219_acpi_fill_ssdt(const struct udevice *dev, acpigen_write_name(ctx, "_CRS"); acpigen_write_resourcetemplate_header(ctx); ret = acpi_device_write_i2c_dev(ctx, dev); - if (ret) + if (ret < 0) return log_msg_ret("i2c", ret);
/* Use either Interrupt() or GpioInt() */ ret = acpi_device_write_interrupt_or_gpio(ctx, (struct udevice *)dev, "req-gpios"); - if (ret) + if (ret < 0) return log_msg_ret("irq_gpio", ret); acpigen_write_resourcetemplate_footer(ctx);
diff --git a/drivers/sound/max98357a.c b/drivers/sound/max98357a.c index 827262d235c..b3d27a3616e 100644 --- a/drivers/sound/max98357a.c +++ b/drivers/sound/max98357a.c @@ -69,7 +69,7 @@ static int max98357a_acpi_fill_ssdt(const struct udevice *dev, acpigen_write_name(ctx, "_CRS"); acpigen_write_resourcetemplate_header(ctx); ret = acpi_device_write_gpio_desc(ctx, &priv->sdmode_gpio); - if (ret) + if (ret < 0) return log_msg_ret("gpio", ret); acpigen_write_resourcetemplate_footer(ctx);
If there is no reset line, this still emits ACPI code for the reset GPIO. Fix it by updating the check.
lib/acpi/acpi_device.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/acpi/acpi_device.c b/lib/acpi/acpi_device.c index 95dfac583fc..c3439a59883 100644 --- a/lib/acpi/acpi_device.c +++ b/lib/acpi/acpi_device.c @@ -422,7 +422,7 @@ int acpi_device_add_power_res(struct acpi_ctx *ctx, u32 tx_state_val,
/* Method (_ON, 0, Serialized) */ acpigen_write_method_serialized(ctx, "_ON", 0); - if (reset_gpio) { + if (has_reset) { ret = acpigen_set_enable_tx_gpio(ctx, tx_state_val, dw0_read, dw0_write, &reset, true); if (ret)
If there is nothing in the SSDT we should not include it in the tables. Update the implementation to check this.
arch/x86/lib/acpi_table.c | 22 +++++++++++++++------- 1 file changed, 15 insertions(+), 7 deletions(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index f0f342d8935..c5c5c6e6794 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -470,8 +470,9 @@ static void acpi_create_spcr(struct acpi_spcr *spcr) header->checksum = table_compute_checksum((void *)spcr, header->length); }
-void acpi_create_ssdt(struct acpi_ctx *ctx, struct acpi_table_header *ssdt, - const char *oem_table_id) +static int acpi_create_ssdt(struct acpi_ctx *ctx, + struct acpi_table_header *ssdt, + const char *oem_table_id) { memset((void *)ssdt, '\0', sizeof(struct acpi_table_header));
@@ -484,9 +485,19 @@ void acpi_create_ssdt(struct acpi_ctx *ctx, struct acpi_table_header *ssdt,
acpi_fill_ssdt(ctx);
- /* (Re)calculate length and checksum. */ + /* (Re)calculate length and checksum */ ssdt->length = ctx->current - (void *)ssdt; ssdt->checksum = table_compute_checksum((void *)ssdt, ssdt->length); + log_debug("SSDT at %p, length %x\n", ssdt, ssdt->length); + + /* Drop the table if it is empty */ + if (ssdt->length == sizeof(struct acpi_table_header)) { + ctx->current = ssdt; + return -ENOENT; + } + acpi_align(ctx); + + return 0; }
/* @@ -596,11 +607,8 @@ ulong write_acpi_tables(ulong start_addr)
debug("ACPI: * SSDT\n"); ssdt = (struct acpi_table_header *)ctx->current; - acpi_create_ssdt(ctx, ssdt, OEM_TABLE_ID); - if (ssdt->length > sizeof(struct acpi_table_header)) { - acpi_inc_align(ctx, ssdt->length); + if (!acpi_create_ssdt(ctx, ssdt, OEM_TABLE_ID)) acpi_add_table(ctx, ssdt); - }
debug("ACPI: * MCFG\n"); mcfg = ctx->current;
The current implementation for DSDT tables is not correct for the case where there is generated code, as the length ends up being incorrect. Also, we want the generated code to go first in the table.
Rewrite this piece to correct these problems.
arch/x86/lib/acpi_table.c | 27 ++++++++++++++++++--------- 1 file changed, 18 insertions(+), 9 deletions(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index c5c5c6e6794..423df5cbf9b 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -505,6 +505,7 @@ static int acpi_create_ssdt(struct acpi_ctx *ctx, */ ulong write_acpi_tables(ulong start_addr) { + const int thl = sizeof(struct acpi_table_header); struct acpi_ctx *ctx; struct acpi_facs *facs; struct acpi_table_header *dsdt; @@ -516,6 +517,7 @@ ulong write_acpi_tables(ulong start_addr) struct acpi_csrt *csrt; struct acpi_spcr *spcr; void *start; + int aml_len; ulong addr; int ret; int i; @@ -541,21 +543,28 @@ ulong write_acpi_tables(ulong start_addr) dsdt = ctx->current;
/* Put the table header first */ - memcpy(dsdt, &AmlCode, sizeof(struct acpi_table_header)); - acpi_inc(ctx, sizeof(struct acpi_table_header)); + memcpy(dsdt, &AmlCode, thl); + acpi_inc(ctx, thl); + log_debug("DSDT starts at %p, hdr ends at %p\n", dsdt, ctx->current);
/* If the table is not empty, allow devices to inject things */ - if (dsdt->length >= sizeof(struct acpi_table_header)) - acpi_inject_dsdt(ctx); + aml_len = dsdt->length - thl; + if (aml_len) { + void *base = ctx->current;
- /* Copy in the AML code itself if any (after the header) */ - memcpy(ctx->current, - (char *)&AmlCode + sizeof(struct acpi_table_header), - dsdt->length - sizeof(struct acpi_table_header)); + acpi_inject_dsdt(ctx); + log_debug("Added %x bytes from inject_dsdt, now at %p\n", + ctx->current - base, ctx->current); + log_debug("Copy AML code size %x to %p\n", aml_len, + ctx->current); + memcpy(ctx->current, AmlCode + thl, aml_len); + acpi_inc(ctx, aml_len); + }
- acpi_inc(ctx, dsdt->length - sizeof(struct acpi_table_header)); dsdt->length = ctx->current - (void *)dsdt; acpi_align(ctx); + log_debug("Updated DSDT length to %x, total %x\n", dsdt->length, + ctx->current - (void *)dsdt);
if (!IS_ENABLED(CONFIG_ACPI_GNVS_EXTERNAL)) { /* Pack GNVS into the ACPI table area */
At present if SSDT and DSDT code is created, only the latter is retained for examination by the 'acpi items' command. Fix this by only resetting the list when explicitly requested.
arch/x86/lib/acpi_table.c | 1 + drivers/core/acpi.c | 10 ++++++---- include/dm/acpi.h | 9 +++++++++ test/dm/acpi.c | 4 ++++ 4 files changed, 20 insertions(+), 4 deletions(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 423df5cbf9b..66cff822dc2 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -531,6 +531,7 @@ ulong write_acpi_tables(ulong start_addr)
+ acpi_reset_items(); acpi_setup_base_tables(ctx, start);
debug("ACPI: * FACS\n"); diff --git a/drivers/core/acpi.c b/drivers/core/acpi.c index 7fe93992b5f..63a791f335e 100644 --- a/drivers/core/acpi.c +++ b/drivers/core/acpi.c @@ -268,8 +268,7 @@ int acpi_recurse_method(struct acpi_ctx *ctx, struct udevice *parent, if (func) { void *start = ctx->current;
- log_debug("\n"); - log_debug("- %s %p\n", parent->name, func); + log_debug("- method %d, %s %p\n", method, parent->name, func); ret = device_ofdata_to_platdata(parent); if (ret) return log_msg_ret("ofdata", ret); @@ -299,7 +298,6 @@ int acpi_fill_ssdt(struct acpi_ctx *ctx) int ret;
log_debug("Writing SSDT tables\n"); - item_count = 0; ret = acpi_recurse_method(ctx, dm_root(), METHOD_FILL_SSDT, TYPE_SSDT); log_debug("Writing SSDT finished, err=%d\n", ret); ret = sort_acpi_item_type(ctx, start, TYPE_SSDT); @@ -315,7 +313,6 @@ int acpi_inject_dsdt(struct acpi_ctx *ctx) int ret;
log_debug("Writing DSDT tables\n"); - item_count = 0; ret = acpi_recurse_method(ctx, dm_root(), METHOD_INJECT_DSDT, TYPE_DSDT); log_debug("Writing DSDT finished, err=%d\n", ret); @@ -326,6 +323,11 @@ int acpi_inject_dsdt(struct acpi_ctx *ctx) return ret; }
+void acpi_reset_items(void) +{ + item_count = 0; +} + int acpi_write_dev_tables(struct acpi_ctx *ctx) { int ret; diff --git a/include/dm/acpi.h b/include/dm/acpi.h index e8b0336f6d8..e6951b6a25d 100644 --- a/include/dm/acpi.h +++ b/include/dm/acpi.h @@ -226,6 +226,15 @@ void acpi_dump_items(enum acpi_dump_option option); */ int acpi_get_path(const struct udevice *dev, char *out_path, int maxlen);
+/** + * acpi_reset_items() - Reset the list of ACPI items to empty + * + * This list keeps track of DSDT and SSDT items that are generated + * programmatically. The 'acpi items' command shows the list. Use this function + * to empty the list, before writing new items. + */ +void acpi_reset_items(void); + #endif /* __ACPI__ */
#endif diff --git a/test/dm/acpi.c b/test/dm/acpi.c index 1f252a8d454..f5eddac10d0 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -477,6 +477,7 @@ static int dm_test_acpi_fill_ssdt(struct unit_test_state *uts) buf = malloc(BUF_SIZE); ut_assertnonnull(buf);
+ acpi_reset_items(); ctx.current = buf; buf[4] = 'z'; /* sentinel */ ut_assertok(acpi_fill_ssdt(&ctx)); @@ -507,6 +508,7 @@ static int dm_test_acpi_inject_dsdt(struct unit_test_state *uts) buf = malloc(BUF_SIZE); ut_assertnonnull(buf);
+ acpi_reset_items(); ctx.current = buf; buf[4] = 'z'; /* sentinel */ ut_assertok(acpi_inject_dsdt(&ctx)); @@ -537,6 +539,7 @@ static int dm_test_acpi_cmd_items(struct unit_test_state *uts) buf = malloc(BUF_SIZE); ut_assertnonnull(buf);
+ acpi_reset_items(); ctx.current = buf; ut_assertok(acpi_fill_ssdt(&ctx)); console_record_reset(); @@ -545,6 +548,7 @@ static int dm_test_acpi_cmd_items(struct unit_test_state *uts) ut_assert_nextline("dev 'acpi-test2', type 1, size 2"); ut_assert_console_end();
+ acpi_reset_items(); ctx.current = buf; ut_assertok(acpi_inject_dsdt(&ctx)); console_record_reset();
It is not possible to boot Chrome OS properly without passing some basic information from U-Boot. This applies even if verified boot is not being used. Add a structure definition for this.
Changes in v2: - Rename struct chromeos_acpi to struct chromeos_acpi_gnvs - Fix comment style
arch/x86/include/asm/intel_gnvs.h | 51 ++++++++++++++++++++++++++++++- 1 file changed, 50 insertions(+), 1 deletion(-)
diff --git a/arch/x86/include/asm/intel_gnvs.h b/arch/x86/include/asm/intel_gnvs.h index c1e9d65779f..632307427cd 100644 --- a/arch/x86/include/asm/intel_gnvs.h +++ b/arch/x86/include/asm/intel_gnvs.h @@ -9,6 +9,55 @@ #ifndef _INTEL_GNVS_H_ #define _INTEL_GNVS_H_
+/* + * The chromeos_acpi portion of ACPI GNVS is assumed to live from offset + * 0x100 - 0x1000. When defining acpi_global_nvs, use check_member + * to ensure that it is properly aligned: + * + * check_member(acpi_global_nvs, chromeos, GNVS_CHROMEOS_ACPI_OFFSET); + */ +#define GNVS_CHROMEOS_ACPI_OFFSET 0x100 + +enum { + CHSW_RECOVERY_X86 = BIT(1), + CHSW_RECOVERY_EC = BIT(2), + CHSW_DEVELOPER_SWITCH = BIT(5), + CHSW_FIRMWARE_WP = BIT(9), +}; + +enum { + FIRMWARE_TYPE_AUTO_DETECT = -1, + FIRMWARE_TYPE_RECOVERY = 0, + FIRMWARE_TYPE_NORMAL = 1, + FIRMWARE_TYPE_DEVELOPER = 2, + FIRMWARE_TYPE_NETBOOT = 3, + FIRMWARE_TYPE_LEGACY = 4, +}; + +struct __packed chromeos_acpi_gnvs { + /* ChromeOS-specific */ + u32 boot_reason; /* 00 boot reason */ + u32 active_main_fw; /* 04 (0=recovery, 1=A, 2=B) */ + u32 activeec_fw; /* 08 (0=RO, 1=RW) */ + u16 switches; /* 0c CHSW */ + u8 vbt4[256]; /* 0e HWID */ + u8 vbt5[64]; /* 10e FWID */ + u8 vbt6[64]; /* 14e FRID - 275 */ + u32 main_fw_type; /* 18e (2 = developer mode) */ + u32 vbt8; /* 192 recovery reason */ + u32 vbt9; /* 196 fmap base address */ + u8 vdat[3072]; /* 19a VDAT space filled by verified boot */ + u32 vbt10; /* d9a smbios bios version */ + u32 mehh[8]; /* d9e management engine hash */ + u32 ramoops_base; /* dbe ramoops base address */ + u32 ramoops_len; /* dc2 ramoops length */ + u32 vpd_ro_base; /* dc6 pointer to RO_VPD */ + u32 vpd_ro_size; /* dca size of RO_VPD */ + u32 vpd_rw_base; /* dce pointer to RW_VPD */ + u32 vpd_rw_size; /* dd2 size of RW_VPD */ + u8 pad[298]; /* dd6-eff */ +}; + struct __packed acpi_global_nvs { /* Miscellaneous */ u8 pcnt; /* 0x00 - Processor Count */ @@ -31,7 +80,7 @@ struct __packed acpi_global_nvs { u8 unused1[0x100 - 0x3d]; /* Pad out to 256 bytes */ #ifdef CONFIG_CHROMEOS /* ChromeOS-specific (0x100 - 0xfff) */ - struct chromeos_acpi chromeos; + struct chromeos_acpi_gnvs chromeos; #else u8 unused2[0x1000 - 0x100]; /* Pad out to 4096 bytes */ #endif
At present CONFIG_CHROMEOS is used to determine whether verified boot is in use. The code to implement that is not in U-Boot mainline.
However, it is useful to be able to boot a Chromebook in developer mode in U-Boot mainline without needing the verified boot code.
To allow this, use CONFIG_CHROMEOS_VBOOT to indicate that verified boot should be used, and CONFIG_CHROMEOS to indicate that the board supports Chrome OS. That allows us to define CONFIG_CHROMEOS on coral.
Changes in v2: - Define CONFIG_CHROMEOS_VBOOT in the Kconfig too - Correct a bisect build error
arch/x86/cpu/apollolake/acpi.c | 3 ++- arch/x86/dts/chromebook_coral.dts | 2 +- arch/x86/dts/chromebook_samus.dts | 2 +- arch/x86/include/asm/intel_gnvs.h | 3 --- arch/x86/lib/tpl.c | 2 +- common/Kconfig.boot | 17 +++++++++++++++++ configs/chromebook_coral_defconfig | 1 + 7 files changed, 23 insertions(+), 7 deletions(-)
diff --git a/arch/x86/cpu/apollolake/acpi.c b/arch/x86/cpu/apollolake/acpi.c index 69b544f0d98..5af8a181b1e 100644 --- a/arch/x86/cpu/apollolake/acpi.c +++ b/arch/x86/cpu/apollolake/acpi.c @@ -75,7 +75,8 @@ int acpi_create_gnvs(struct acpi_global_nvs *gnvs)
/* TODO(sjg@chromium.org): Add the console log to gnvs->cbmc */
-#ifdef CONFIG_CHROMEOS +/* Disable this code until a later patch */ +#if 0 /* Initialise Verified Boot data */ chromeos_init_acpi(&gnvs->chromeos); gnvs->chromeos.vbt2 = ACTIVE_ECFW_RO; diff --git a/arch/x86/dts/chromebook_coral.dts b/arch/x86/dts/chromebook_coral.dts index 92f70b13dd7..43f4b33da1b 100644 --- a/arch/x86/dts/chromebook_coral.dts +++ b/arch/x86/dts/chromebook_coral.dts @@ -9,7 +9,7 @@ /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi"
-#ifdef CONFIG_CHROMEOS +#ifdef CONFIG_CHROMEOS_VBOOT #include "chromeos-x86.dtsi" #include "flashmap-x86-ro.dtsi" #include "flashmap-16mb-rw.dtsi" diff --git a/arch/x86/dts/chromebook_samus.dts b/arch/x86/dts/chromebook_samus.dts index 772ea5c91be..d8e04a66985 100644 --- a/arch/x86/dts/chromebook_samus.dts +++ b/arch/x86/dts/chromebook_samus.dts @@ -9,7 +9,7 @@ /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi"
-#ifdef CONFIG_CHROMEOS +#ifdef CONFIG_CHROMEOS_VBOOT #include "chromeos-x86.dtsi" #include "flashmap-x86-ro.dtsi" #include "flashmap-8mb-rw.dtsi" diff --git a/arch/x86/include/asm/intel_gnvs.h b/arch/x86/include/asm/intel_gnvs.h index 632307427cd..7f9f101371c 100644 --- a/arch/x86/include/asm/intel_gnvs.h +++ b/arch/x86/include/asm/intel_gnvs.h @@ -85,9 +85,6 @@ struct __packed acpi_global_nvs { u8 unused2[0x1000 - 0x100]; /* Pad out to 4096 bytes */ #endif }; - -#ifdef CONFIG_CHROMEOS check_member(acpi_global_nvs, chromeos, GNVS_CHROMEOS_ACPI_OFFSET); -#endif
#endif /* _INTEL_GNVS_H_ */ diff --git a/arch/x86/lib/tpl.c b/arch/x86/lib/tpl.c index 6f7eb43a172..15b0212d190 100644 --- a/arch/x86/lib/tpl.c +++ b/arch/x86/lib/tpl.c @@ -75,7 +75,7 @@ void board_init_f_r(void)
u32 spl_boot_device(void) { - return IS_ENABLED(CONFIG_CHROMEOS) ? BOOT_DEVICE_CROS_VBOOT : + return IS_ENABLED(CONFIG_CHROMEOS_VBOOT) ? BOOT_DEVICE_CROS_VBOOT : BOOT_DEVICE_SPI_MMAP; }
diff --git a/common/Kconfig.boot b/common/Kconfig.boot index 522f5f3d6a4..3f6d9c1a258 100644 --- a/common/Kconfig.boot +++ b/common/Kconfig.boot @@ -343,6 +343,23 @@ config ARCH_FIXUP_FDT_MEMORY used for booting OS with different memory setup where the part of the memory location should be used for different purpose.
+config CHROMEOS + bool "Support booting Chrome OS" + help + Chrome OS requires U-Boot to set up a table indicating the boot mode + (e.g. Developer mode) and a few other things. Enable this if you are + booting on a Chromebook to avoid getting an error about an invalid + firmware ID. + +config CHROMEOS_VBOOT + bool "Support Chrome OS verified boot" + help + This is intended to enable the full Chrome OS verified boot support + in U-Boot. It is not actually implemented in the U-Boot source code + at present, so this option is always set to 'n'. It allows + distinguishing between booting Chrome OS in a basic way (developer + mode) and a full boot. + endmenu # Boot images
menu "Boot timing" diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index d934eeb8866..e1907a0b7bc 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -21,6 +21,7 @@ CONFIG_INTEL_CAR_CQOS=y CONFIG_X86_OFFSET_U_BOOT=0xffd00000 CONFIG_X86_OFFSET_SPL=0xffe80000 CONFIG_INTEL_GENERIC_WIFI=y +CONFIG_CHROMEOS=y CONFIG_BOOTSTAGE=y CONFIG_SPL_BOOTSTAGE=y CONFIG_TPL_BOOTSTAGE=y
Set up a few fields necessarily to make Chrome OS boot without showing a firmware error.
arch/x86/cpu/apollolake/acpi.c | 26 ++++++++++++++++++++------ 1 file changed, 20 insertions(+), 6 deletions(-)
diff --git a/arch/x86/cpu/apollolake/acpi.c b/arch/x86/cpu/apollolake/acpi.c index 5af8a181b1e..fd21c0b4968 100644 --- a/arch/x86/cpu/apollolake/acpi.c +++ b/arch/x86/cpu/apollolake/acpi.c @@ -65,6 +65,21 @@ int arch_write_sci_irq_select(uint scis) return 0; }
+/** + * chromeos_init_acpi() - Initialise basic data to boot Chrome OS + * + * This tells Chrome OS to boot in developer mode + * + * @cros: Structure to initialise + */ +static void chromeos_init_acpi(struct chromeos_acpi_gnvs *cros) +{ + cros->active_main_fw = 1; + cros->active_main_fw = 1; /* A */ + cros->switches = CHSW_DEVELOPER_SWITCH; + cros->main_fw_type = 2; /* Developer */ +} + int acpi_create_gnvs(struct acpi_global_nvs *gnvs) { struct udevice *cpu; @@ -75,12 +90,9 @@ int acpi_create_gnvs(struct acpi_global_nvs *gnvs)
-/* Disable this code until a later patch */ -#if 0 - /* Initialise Verified Boot data */ - chromeos_init_acpi(&gnvs->chromeos); - gnvs->chromeos.vbt2 = ACTIVE_ECFW_RO; -#endif + if (IS_ENABLED(CONFIG_CHROMEOS)) + chromeos_init_acpi(&gnvs->chromeos); + /* Set unknown wake source */ gnvs->pm1i = ~0ULL;
@@ -93,6 +105,8 @@ int acpi_create_gnvs(struct acpi_global_nvs *gnvs) gnvs->pcnt = ret; }
+ gnvs->dpte = 1; + return 0; }
Add a script to boot Chrome OS from the internal MMC. This involved adding a few commands and options.
configs/chromebook_coral_defconfig | 10 +++++++--- include/configs/chromebook_coral.h | 9 ++++++++- 2 files changed, 15 insertions(+), 4 deletions(-)
diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index e1907a0b7bc..d960793d9a9 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -29,8 +29,10 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_SPL_BOOTSTAGE_RECORD_COUNT=10 CONFIG_BOOTSTAGE_STASH=y CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=ttyS2,115200n8 cros_legacy loglevel=9 init=/sbin/init oops=panic panic=-1 root=PARTUUID=35c775e7-3735-d745-93e5-d9e0238f7ed0/PARTNROFF=1 rootwait rw noinitrd vt.global_cursor_default=0 add_efi_memmap boot=local noresume noswap i915.modeset=1 nmi_watchdog=panic,lapic disablevmx=off" +CONFIG_BOOTARGS="" +CONFIG_BOOTARGS_SUBST=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_LOGF_FUNC=y CONFIG_SPL_LOG=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_LAST_STAGE_INIT=y @@ -55,11 +57,11 @@ CONFIG_CMD_READ=y CONFIG_CMD_SATA=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_TPM=y +CONFIG_CMD_CBFS=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y @@ -72,7 +74,6 @@ CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ENV_OVERWRITE=y -# CONFIG_NET is not set CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y @@ -106,10 +107,13 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_COPY=y +CONFIG_FS_CBFS=y CONFIG_SPL_FS_CBFS=y +CONFIG_FAT_WRITE=y # CONFIG_SPL_USE_TINY_PRINTF is not set CONFIG_TPL_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_TPM=y # CONFIG_GZIP is not set +CONFIG_BLOBLIST_TABLES=y # CONFIG_EFI_LOADER is not set diff --git a/include/configs/chromebook_coral.h b/include/configs/chromebook_coral.h index a63c3c9eea8..d4d32758e99 100644 --- a/include/configs/chromebook_coral.h +++ b/include/configs/chromebook_coral.h @@ -11,7 +11,14 @@ #define __CONFIG_H
#define CONFIG_BOOTCOMMAND \ - "fatload mmc 1:c 1000000 syslinux/vmlinuz.A; zboot 1000000" + "tpm init; tpm startup TPM2_SU_CLEAR; " \ + "read mmc 2:2 100000 0 80; setexpr loader *001004f0; " \ + "setexpr size *00100518; setexpr blocks $size / 200; " \ + "read mmc 2:2 100000 80 $blocks; setexpr setup $loader - 1000; " \ + "setexpr cmdline $loader - 2000; " \ + "part uuid mmc 2:2 uuid; setenv bootargs_U $uuid; " \ + "zboot start 100000 0 0 0 $setup $cmdline; " \ + "zboot load; zboot setup; zboot dump; zboot go"
#include <configs/x86-common.h> #include <configs/x86-chromebook.h>
Use log_debug() instead of debug() in this file, to enable the extra features.
arch/x86/lib/fsp2/fsp_dram.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/x86/lib/fsp2/fsp_dram.c b/arch/x86/lib/fsp2/fsp_dram.c index c9f6402e6a4..a95fdc46c1b 100644 --- a/arch/x86/lib/fsp2/fsp_dram.c +++ b/arch/x86/lib/fsp2/fsp_dram.c @@ -4,6 +4,8 @@ * Written by Simon Glass sjg@chromium.org */
+#define LOG_CATEGORY LOGC_ARCH + #include <common.h> #include <handoff.h> #include <init.h> @@ -35,7 +37,7 @@ int dram_init(void) ret = fsp_memory_init(s3wake, IS_ENABLED(CONFIG_APL_BOOT_FROM_FAST_SPI_FLASH)); if (ret) { - debug("Memory init failed (err=%x)\n", ret); + log_debug("Memory init failed (err=%x)\n", ret); return ret; }
@@ -60,7 +62,7 @@ int dram_init(void) struct spl_handoff *ho = gd->spl_handoff;
if (!ho) { - debug("No SPL handoff found\n"); + log_debug("No SPL handoff found\n"); return -ESTRPIPE; } gd->ram_size = ho->ram_size; @@ -82,6 +84,8 @@ ulong board_get_usable_ram_top(ulong total_size) #if CONFIG_IS_ENABLED(HANDOFF) struct spl_handoff *ho = gd->spl_handoff;
+ log_debug("usable_ram_top = %lx\n", ho->arch.usable_ram_top); + return ho->arch.usable_ram_top; #endif
Quite a few log_info() calls are included in the x86 code which should use log_debug() instead. Convert them to reduce unwanted output.
arch/x86/cpu/apollolake/fsp_s.c | 8 ++++---- arch/x86/cpu/intel_common/intel_opregion.c | 2 +- arch/x86/cpu/intel_common/itss.c | 8 ++++---- arch/x86/lib/acpi_nhlt.c | 2 +- arch/x86/lib/fsp/fsp_graphics.c | 2 +- 5 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/arch/x86/cpu/apollolake/fsp_s.c b/arch/x86/cpu/apollolake/fsp_s.c index 715ceab6ac7..288188027a4 100644 --- a/arch/x86/cpu/apollolake/fsp_s.c +++ b/arch/x86/cpu/apollolake/fsp_s.c @@ -116,10 +116,10 @@ static int set_power_limits(struct udevice *dev)
/* Program package power limits in RAPL MSR */ msr_write(MSR_PKG_POWER_LIMIT, limit); - log_info("RAPL PL1 %d.%dW\n", tdp / power_unit, - 100 * (tdp % power_unit) / power_unit); - log_info("RAPL PL2 %d.%dW\n", pl2_val / power_unit, - 100 * (pl2_val % power_unit) / power_unit); + log_debug("RAPL PL1 %d.%dW\n", tdp / power_unit, + 100 * (tdp % power_unit) / power_unit); + log_debug("RAPL PL2 %d.%dW\n", pl2_val / power_unit, + 100 * (pl2_val % power_unit) / power_unit);
/* * Sett RAPL MMIO register for Power limits. RAPL driver is using MSR diff --git a/arch/x86/cpu/intel_common/intel_opregion.c b/arch/x86/cpu/intel_common/intel_opregion.c index c95ae04992d..1eed21d8cdf 100644 --- a/arch/x86/cpu/intel_common/intel_opregion.c +++ b/arch/x86/cpu/intel_common/intel_opregion.c @@ -42,7 +42,7 @@ static int locate_vbt(char **vbtp, int *sizep) return -EINVAL; }
- log_info("Found a VBT of %u bytes\n", size); + log_debug("Found a VBT of %u bytes\n", size); *sizep = size; *vbtp = vbt_data;
diff --git a/arch/x86/cpu/intel_common/itss.c b/arch/x86/cpu/intel_common/itss.c index 53dd09d8f54..de17b93ed43 100644 --- a/arch/x86/cpu/intel_common/itss.c +++ b/arch/x86/cpu/intel_common/itss.c @@ -67,7 +67,7 @@ static int snapshot_polarities(struct udevice *dev) reg_start = start / IRQS_PER_IPC; reg_end = DIV_ROUND_UP(end, IRQS_PER_IPC);
- log_info("ITSS IRQ Polarities snapshot %p\n", priv->irq_snapshot); + log_debug("ITSS IRQ Polarities snapshot %p\n", priv->irq_snapshot); for (i = reg_start; i < reg_end; i++) { uint reg = PCR_ITSS_IPC0_CONF + sizeof(u32) * i;
@@ -89,11 +89,11 @@ static void show_polarities(struct udevice *dev, const char *msg) { int i;
- log_info("ITSS IRQ Polarities %s:\n", msg); + log_debug("ITSS IRQ Polarities %s:\n", msg); for (i = 0; i < NUM_IPC_REGS; i++) { uint reg = PCR_ITSS_IPC0_CONF + sizeof(u32) * i;
- log_info("IPC%d: 0x%08x\n", i, pcr_read32(dev, reg)); + log_debug("IPC%d: 0x%08x\n", i, pcr_read32(dev, reg)); } }
@@ -115,7 +115,7 @@ static int restore_polarities(struct udevice *dev) sizeof(priv->irq_snapshot));
show_polarities(dev, "Before"); - log_info("priv->irq_snapshot %p\n", priv->irq_snapshot); + log_debug("priv->irq_snapshot %p\n", priv->irq_snapshot);
reg_start = start / IRQS_PER_IPC; reg_end = DIV_ROUND_UP(end, IRQS_PER_IPC); diff --git a/arch/x86/lib/acpi_nhlt.c b/arch/x86/lib/acpi_nhlt.c index 0e8e669c7d8..6c8cd83e12d 100644 --- a/arch/x86/lib/acpi_nhlt.c +++ b/arch/x86/lib/acpi_nhlt.c @@ -390,7 +390,7 @@ int nhlt_serialise_oem_overrides(struct acpi_ctx *ctx, struct nhlt *nhlt, size_t oem_table_id_len; int ret;
- log_info("ACPI: * NHLT\n"); + log_debug("ACPI: * NHLT\n"); sz = nhlt_current_size(nhlt);
/* Create header */ diff --git a/arch/x86/lib/fsp/fsp_graphics.c b/arch/x86/lib/fsp/fsp_graphics.c index 858d7942fed..6534b6690bd 100644 --- a/arch/x86/lib/fsp/fsp_graphics.c +++ b/arch/x86/lib/fsp/fsp_graphics.c @@ -139,7 +139,7 @@ static int fsp_video_acpi_write_tables(const struct udevice *dev, struct igd_opregion *opregion; int ret;
- printf("ACPI: * IGD OpRegion\n"); + log_debug("ACPI: * IGD OpRegion\n"); opregion = (struct igd_opregion *)ctx->current;
ret = intel_gma_init_igd_opregion((struct udevice *)dev, opregion);
This table is not needed if a v2 TPM is in use. Add a condition to avoid adding it when not needed.
arch/x86/lib/acpi_table.c | 19 +++++++++++-------- 1 file changed, 11 insertions(+), 8 deletions(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 66cff822dc2..9f0871c9f49 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -646,14 +646,17 @@ ulong write_acpi_tables(ulong start_addr) acpi_inc_align(ctx, madt->header.length); acpi_add_table(ctx, madt);
- debug("ACPI: * TCPA\n"); - tcpa = (struct acpi_tcpa *)ctx->current; - ret = acpi_create_tcpa(tcpa); - if (ret) { - log_warning("Failed to create TCPA table (err=%d)\n", ret); - } else { - acpi_inc_align(ctx, tcpa->header.length); - acpi_add_table(ctx, tcpa); + if (IS_ENABLED(CONFIG_TPM_V1)) { + debug("ACPI: * TCPA\n"); + tcpa = (struct acpi_tcpa *)ctx->current; + ret = acpi_create_tcpa(tcpa); + if (ret) { + log_warning("Failed to create TCPA table (err=%d)\n", + ret); + } else { + acpi_inc_align(ctx, tcpa->header.length); + acpi_add_table(ctx, tcpa); + } }
debug("ACPI: * CSRT\n");
This is useful when using Linux's earlycon since the MMIO address must be provided on some platforms, e.g.:
earlycon=uart8250,mmio32,0xddffc000,115200n8
However this is only for debugging, so don't show it by default.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
(no changes since v1)
arch/x86/lib/acpi_table.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 9f0871c9f49..4fd8dc8ad9a 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -767,7 +767,7 @@ int acpi_write_dbg2_pci_uart(struct acpi_ctx *ctx, struct udevice *dev, * 32-bits each. This is only for debugging so it is not a big deal. */ addr = dm_pci_read_bar32(dev, 0); - printf("UART addr %lx\n", (ulong)addr); + log_debug("UART addr %lx\n", (ulong)addr);
memset(&address, '\0', sizeof(address)); address.space_id = ACPI_ADDRESS_SPACE_MEMORY;
This does not necessarily indicate a problem, since some pins are optional. Let the caller show an error if necessary. Reviewed-by: Bin Meng bmeng.cn@gmail.com
drivers/pinctrl/intel/pinctrl.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/intel/pinctrl.c b/drivers/pinctrl/intel/pinctrl.c index ba21c9dcc2e..e3d24646344 100644 --- a/drivers/pinctrl/intel/pinctrl.c +++ b/drivers/pinctrl/intel/pinctrl.c @@ -154,7 +154,7 @@ static int pinctrl_get_device(uint pad, struct udevice **devp) return 0; } } - printf("pad %d not found\n", pad); + log_debug("pad %d not found\n", pad);
return -ENOTBLK; }
At present the top of available DRAM is the same as the top of the range of the low-memory MTRR.
In fact, U-Boot is allowed to use memory up until the start of the FSP reserved memory. Use that value for low_end, since it makes more memory available.
Keep the same calculation as before for mtrr_top, i.e. the top of reserved memory.
A side-effect of this change is that the E820 tables have a single entry that extends from the bottom of the memory used by U-Boot to the bottom of the FSP reserved memory. This includes the bloblist, if ACPI tables are placed there.
(no changes since v2)
Changes in v2: - Drop patch "Store the FADT so we can avoid searching for it" - Drop patch "Move ROM_TABLE_ADDR into the C file"
arch/x86/lib/fsp/fsp_dram.c | 35 ++++++++++++++++++++++------------- 1 file changed, 22 insertions(+), 13 deletions(-)
diff --git a/arch/x86/lib/fsp/fsp_dram.c b/arch/x86/lib/fsp/fsp_dram.c index a76497d4e01..3ffd40ce747 100644 --- a/arch/x86/lib/fsp/fsp_dram.c +++ b/arch/x86/lib/fsp/fsp_dram.c @@ -41,8 +41,10 @@ int fsp_scan_for_ram_size(void)
int dram_init_banksize(void) { + efi_guid_t fsp = FSP_HOB_RESOURCE_OWNER_FSP_GUID; const struct hob_header *hdr; struct hob_res_desc *res_desc; + phys_addr_t mtrr_top; phys_addr_t low_end; uint bank;
@@ -54,35 +56,42 @@ int dram_init_banksize(void) return 0; }
- low_end = 0; + low_end = 0; /* top of low memory usable by U-Boot */ + mtrr_top = 0; /* top of low memory (even if reserved) */ for (bank = 1, hdr = gd->arch.hob_list; bank < CONFIG_NR_DRAM_BANKS && !end_of_hob(hdr); hdr = get_next_hob(hdr)) { if (hdr->type != HOB_TYPE_RES_DESC) continue; res_desc = (struct hob_res_desc *)hdr; + if (!guidcmp(&res_desc->owner, &fsp)) + low_end = res_desc->phys_start; if (res_desc->type != RES_SYS_MEM && res_desc->type != RES_MEM_RESERVED) continue; if (res_desc->phys_start < (1ULL << 32)) { - low_end = max(low_end, - res_desc->phys_start + res_desc->len); - continue; + mtrr_top = max(mtrr_top, + res_desc->phys_start + res_desc->len); + } else { + gd->bd->bi_dram[bank].start = res_desc->phys_start; + gd->bd->bi_dram[bank].size = res_desc->len; + mtrr_add_request(MTRR_TYPE_WRBACK, res_desc->phys_start, + res_desc->len); + log_debug("ram %llx %llx\n", + gd->bd->bi_dram[bank].start, + gd->bd->bi_dram[bank].size); } - - gd->bd->bi_dram[bank].start = res_desc->phys_start; - gd->bd->bi_dram[bank].size = res_desc->len; - mtrr_add_request(MTRR_TYPE_WRBACK, res_desc->phys_start, - res_desc->len); - log_debug("ram %llx %llx\n", gd->bd->bi_dram[bank].start, - gd->bd->bi_dram[bank].size); }
/* Add the memory below 4GB */ gd->bd->bi_dram[0].start = 0; gd->bd->bi_dram[0].size = low_end;
- mtrr_add_request(MTRR_TYPE_WRBACK, 0, low_end); + /* + * Set up an MTRR to the top of low, reserved memory. This is necessary + * for graphics to run at full speed in U-Boot. + */ + mtrr_add_request(MTRR_TYPE_WRBACK, 0, mtrr_top);
return 0; } @@ -156,7 +165,7 @@ unsigned int install_e820_map(unsigned int max_entries, #if CONFIG_IS_ENABLED(HANDOFF) && IS_ENABLED(CONFIG_USE_HOB) int handoff_arch_save(struct spl_handoff *ho) { - ho->arch.usable_ram_top = fsp_get_usable_lowmem_top(gd->arch.hob_list); + ho->arch.usable_ram_top = gd->bd->bi_dram[0].size; ho->arch.hob_list = gd->arch.hob_list;
On Thu, Nov 5, 2020 at 12:57 AM Simon Glass sjg@chromium.org wrote:
This series adds various minor features and tweaks to allow Coral to boot into Chrome OS from U-Boot.
It relies on three other series which have been recently sent:
- smbios (u-boot-dm/smbios-working)
- bootm (u-boot-dm/bootm-working)
- misca (u-boot-dm/misca-working)
This should provide a solid base for using ACPI on other Intel Apollo Lake (APL) devices.
Changes in v3:
- Add a macro to read gd->acpi_ctx to allow use of IS_ENABLED()
series applied to u-boot-x86, thanks!
Hi Simon,
Changes in v3:
Unfortunately this series breaks qemu-x86_64 build, see: https://dev.azure.com/bmeng/GitHub/_build/results?buildId=298&view=resul...
Could you please send a fix and indicate which commit in u-boot-x86 should be fixed/squashed, etc?
Regards, Bin
Hi Bin,
On Thu, 5 Nov 2020 at 01:43, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Changes in v3:
Oh dear. Yes I sent a fix. I think I was looking at an earlier build so did not notice the problem on gitlab.
Bin Meng
