[U-Boot] [PATCH] arm: exynos: Squash bogus warnings in pinmux
Squash these warnings in pinmux.c found with GCC 4.8:
/arch/arm/cpu/armv7/exynos/pinmux.c: In function 'exynos_pinmux_config': /arch/arm/cpu/armv7/exynos/pinmux.c:687:28: warning: 'count' may be used uninitialized in this function [-Wmaybe-uninitialized] for (i = start; i < start + count; i++) { ^ /arch/arm/cpu/armv7/exynos/pinmux.c:663:16: note: 'count' was declared here int i, start, count; ^ /arch/arm/cpu/armv7/exynos/pinmux.c:687:28: warning: 'start' may be used uninitialized in this function [-Wmaybe-uninitialized] for (i = start; i < start + count; i++) { ^ /arch/arm/cpu/armv7/exynos/pinmux.c:663:9: note: 'start' was declared here int i, start, count; ^ /arch/arm/cpu/armv7/exynos/pinmux.c:689:19: warning: 'bank' may be used uninitialized in this function [-Wmaybe-uninitialized] s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); ^ /arch/arm/cpu/armv7/exynos/pinmux.c:662:24: note: 'bank' was declared here struct s5p_gpio_bank *bank; ^ /arch/arm/cpu/armv7/exynos/pinmux.c: In function 'exynos_pinmux_config': /arch/arm/cpu/armv7/exynos/pinmux.c:687:28: warning: 'count' may be used uninitialized in this function [-Wmaybe-uninitialized] for (i = start; i < start + count; i++) { ^ /arch/arm/cpu/armv7/exynos/pinmux.c:663:16: note: 'count' was declared here int i, start, count; ^ /arch/arm/cpu/armv7/exynos/pinmux.c:687:28: warning: 'start' may be used uninitialized in this function [-Wmaybe-uninitialized] for (i = start; i < start + count; i++) { ^ /arch/arm/cpu/armv7/exynos/pinmux.c:663:9: note: 'start' was declared here int i, start, count; ^ /arch/arm/cpu/armv7/exynos/pinmux.c:689:19: warning: 'bank' may be used uninitialized in this function [-Wmaybe-uninitialized] s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); ^ /arch/arm/cpu/armv7/exynos/pinmux.c:662:24: note: 'bank' was declared here struct s5p_gpio_bank *bank; ^
Note that the warning is bogus, the function can never be called with invalid 'peripheral' argument. GCC just cannot analyze this.
Signed-off-by: Marek Vasut marex@denx.de Cc: Naveen Krishna Chatradhi ch.naveen@samsung.com Cc: Akshay Saraswat akshay.s@samsung.com Cc: Rajeshwari S Shinde rajeshwari.s@samsung.com Cc: Simon Glass sjg@chromium.org Cc: Minkyu Kang mk7.kang@samsung.com Cc: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/exynos/pinmux.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 645c497..61759a4 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -39,6 +39,9 @@ static void exynos5_uart_config(int peripheral) start = 4; count = 2; break; + default: + debug("%s: invalid peripheral %d", __func__, peripheral); + return; } for (i = start; i < start + count; i++) { s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); @@ -74,6 +77,9 @@ static void exynos5420_uart_config(int peripheral) start = 4; count = 2; break; + default: + debug("%s: invalid peripheral %d", __func__, peripheral); + return; }
for (i = start; i < start + count; i++) { @@ -110,6 +116,9 @@ static int exynos5_mmc_config(int peripheral, int flags) bank = &gpio1->c4; bank_ext = NULL; break; + default: + debug("%s: invalid peripheral %d", __func__, peripheral); + return -1; } if ((flags & PINMUX_FLAG_8BIT_MODE) && !bank_ext) { debug("SDMMC device %d does not support 8bit mode", @@ -683,6 +692,9 @@ static void exynos4_uart_config(int peripheral) start = 4; count = 2; break; + default: + debug("%s: invalid peripheral %d", __func__, peripheral); + return; } for (i = start; i < start + count; i++) { s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE);
Hi Marek,
Thanks Marek, great to get that annoyance fixed.
Hi
Acked-by: Rajeshwari S Shinde rajeshwari.s@samsung.com
Regards, Rajeshwari
On Tue, Mar 11, 2014 at 12:56 AM, Simon Glass sjg@chromium.org wrote:
Hi Marek,
Regards, Simon _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Simon, Marek,
Hi Marek,
Fix for this issue has been already posted :-) (one week ago)
http://patchwork.ozlabs.org/patch/327065/
But I don't mind if Marek's patch will be applied directly by Tom before v2014.04 is released :-)
On Wednesday, March 12, 2014 at 08:51:56 AM, Lukasz Majewski wrote:
Hi Simon, Marek,
Hi Marek,
Aren't you missing the exynos5_mmc_config() in your patch ? Otherwise, I don't mind either way and I'd prefer if your patch (which came in earlier) was applied of course (unless you are missing the _mmc_config).
Hi Marek,
Hi Simon, Marek,
Hi Marek,
Yes, my work miss it. Lets apply your patch and be happy with "clean" build results from gcc 4.8 :-).
On Wednesday, March 12, 2014 at 01:21:15 PM, Lukasz Majewski wrote:
Hi Marek,
Hi Simon, Marek,
Hi Marek,
Roger that.
Hi Marek,
Hi Simon, Marek,
Hi Marek,
Roger that.
applied to u-boot-samsung.
Lukasz, your patch will abandon because of this patch.
Thanks, Minkyu Kang.
Hi Minkyu,
Hi Marek,
Hi Simon, Marek,
Hi Marek,
On 10 March 2014 13:04, Marek Vasut marex@denx.de wrote: > Squash these warnings in pinmux.c found with GCC 4.8: > > /arch/arm/cpu/armv7/exynos/pinmux.c: In function > 'exynos_pinmux_config': /arch/arm/cpu/armv7/exynos/pinmux.c:687:28: > warning: 'count' may be used uninitialized in this function > [-Wmaybe-uninitialized] for (i = start; i < start + count; i++) > { ^ /arch/arm/cpu/armv7/exynos/pinmux.c:663:16: note: 'count' > was declared here int i, start, count; > > ^ > > /arch/arm/cpu/armv7/exynos/pinmux.c:687:28: warning: 'start' > may be used uninitialized in this function > [-Wmaybe-uninitialized] for (i = start; i < start + count; i++) > { ^ /arch/arm/cpu/armv7/exynos/pinmux.c:663:9: note: 'start' > was declared here int i, start, count; > > ^ > > /arch/arm/cpu/armv7/exynos/pinmux.c:689:19: warning: 'bank' may > be used uninitialized in this function [-Wmaybe-uninitialized] > s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); ^ > /arch/arm/cpu/armv7/exynos/pinmux.c:662:24: note: 'bank' was > declared here struct s5p_gpio_bank *bank; > > ^ > > /arch/arm/cpu/armv7/exynos/pinmux.c: In function > 'exynos_pinmux_config': /arch/arm/cpu/armv7/exynos/pinmux.c:687:28: > warning: 'count' may be used uninitialized in this function > [-Wmaybe-uninitialized] for (i = start; i < start + count; i++) > { ^ /arch/arm/cpu/armv7/exynos/pinmux.c:663:16: note: 'count' > was declared here int i, start, count; > > ^ > > /arch/arm/cpu/armv7/exynos/pinmux.c:687:28: warning: 'start' > may be used uninitialized in this function > [-Wmaybe-uninitialized] for (i = start; i < start + count; i++) > { ^ /arch/arm/cpu/armv7/exynos/pinmux.c:663:9: note: 'start' > was declared here int i, start, count; > > ^ > > /arch/arm/cpu/armv7/exynos/pinmux.c:689:19: warning: 'bank' may > be used uninitialized in this function [-Wmaybe-uninitialized] > s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); ^ > /arch/arm/cpu/armv7/exynos/pinmux.c:662:24: note: 'bank' was > declared here struct s5p_gpio_bank *bank; > > ^ > > Note that the warning is bogus, the function can never be > called with invalid 'peripheral' argument. GCC just cannot > analyze this. > > Signed-off-by: Marek Vasut marex@denx.de > Cc: Naveen Krishna Chatradhi ch.naveen@samsung.com > Cc: Akshay Saraswat akshay.s@samsung.com > Cc: Rajeshwari S Shinde rajeshwari.s@samsung.com > Cc: Simon Glass sjg@chromium.org > Cc: Minkyu Kang mk7.kang@samsung.com > Cc: Tom Rini trini@ti.com
Roger that.
OK, no problem for me :-)
participants (5)
Lukasz Majewski
Minkyu Kang
Rajeshwari Birje
