[PATCH v1] arm: dts: rockchip: rk3128: bulk convert gpios to their constant counterparts
Bulk convert rk3128 DT gpios to their constant counterparts.
sed -i -f script.sed rk3128.dtsi sed -i -f script.sed rk3128-evb.dts
/rockchip,pins *=/bcheck b # to end of script :append-next-line N :check /^[^;]*$/bappend-next-line s/<RK_GPIO([0-9]) /<\1 /g s/<([^ ][^ ]* *)0 /<\1RK_PA0 /g s/<([^ ][^ ]* *)1 /<\1RK_PA1 /g s/<([^ ][^ ]* *)2 /<\1RK_PA2 /g s/<([^ ][^ ]* *)3 /<\1RK_PA3 /g s/<([^ ][^ ]* *)4 /<\1RK_PA4 /g s/<([^ ][^ ]* *)5 /<\1RK_PA5 /g s/<([^ ][^ ]* *)6 /<\1RK_PA6 /g s/<([^ ][^ ]* *)7 /<\1RK_PA7 /g s/<([^ ][^ ]* *)8 /<\1RK_PB0 /g s/<([^ ][^ ]* *)9 /<\1RK_PB1 /g s/<([^ ][^ ]* *)10 /<\1RK_PB2 /g s/<([^ ][^ ]* *)11 /<\1RK_PB3 /g s/<([^ ][^ ]* *)12 /<\1RK_PB4 /g s/<([^ ][^ ]* *)13 /<\1RK_PB5 /g s/<([^ ][^ ]* *)14 /<\1RK_PB6 /g s/<([^ ][^ ]* *)15 /<\1RK_PB7 /g s/<([^ ][^ ]* *)16 /<\1RK_PC0 /g s/<([^ ][^ ]* *)17 /<\1RK_PC1 /g s/<([^ ][^ ]* *)18 /<\1RK_PC2 /g s/<([^ ][^ ]* *)19 /<\1RK_PC3 /g s/<([^ ][^ ]* *)20 /<\1RK_PC4 /g s/<([^ ][^ ]* *)21 /<\1RK_PC5 /g s/<([^ ][^ ]* *)22 /<\1RK_PC6 /g s/<([^ ][^ ]* *)23 /<\1RK_PC7 /g s/<([^ ][^ ]* *)24 /<\1RK_PD0 /g s/<([^ ][^ ]* *)25 /<\1RK_PD1 /g s/<([^ ][^ ]* *)26 /<\1RK_PD2 /g s/<([^ ][^ ]* *)27 /<\1RK_PD3 /g s/<([^ ][^ ]* *)28 /<\1RK_PD4 /g s/<([^ ][^ ]* *)29 /<\1RK_PD5 /g s/<([^ ][^ ]* *)30 /<\1RK_PD6 /g s/<([^ ][^ ]* *)31 /<\1RK_PD7 /g s/<([^ ][^ ]* *[^ ][^ ]* *)0 /<\1RK_FUNC_GPIO /g s/<([^ ][^ ]* *[^ ][^ ]* *)RK_FUNC_([1-9]) /<\1\2 /g
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/dts/rk3128-evb.dts | 4 +- arch/arm/dts/rk3128.dtsi | 86 ++++++++++++++++++------------------- 2 files changed, 45 insertions(+), 45 deletions(-)
diff --git a/arch/arm/dts/rk3128-evb.dts b/arch/arm/dts/rk3128-evb.dts index 2fb2b0da..a407ac2d 100644 --- a/arch/arm/dts/rk3128-evb.dts +++ b/arch/arm/dts/rk3128-evb.dts @@ -82,13 +82,13 @@ &pinctrl { usb_otg { otg_vbus_drv: host-vbus-drv { - rockchip,pins = <0 26 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
usb_host { host_vbus_drv: host-vbus-drv { - rockchip,pins = <2 23 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>; }; }; }; diff --git a/arch/arm/dts/rk3128.dtsi b/arch/arm/dts/rk3128.dtsi index 5d2499c1..62fd5343 100644 --- a/arch/arm/dts/rk3128.dtsi +++ b/arch/arm/dts/rk3128.dtsi @@ -618,85 +618,85 @@ */
emmc_clk: emmc-clk { - rockchip,pins = <2 7 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <2 RK_PA7 2 &pcfg_pull_none>; };
emmc_cmd: emmc-cmd { - rockchip,pins = <2 4 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <2 RK_PA4 2 &pcfg_pull_none>; };
emmc_pwren: emmc-pwren { - rockchip,pins = <2 5 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <2 RK_PA5 2 &pcfg_pull_none>; };
emmc_bus8: emmc-bus8 { - rockchip,pins = <1 24 RK_FUNC_2 &pcfg_pull_none>, - <1 25 RK_FUNC_2 &pcfg_pull_none>, - <1 26 RK_FUNC_2 &pcfg_pull_none>, - <1 27 RK_FUNC_2 &pcfg_pull_none>, - <1 28 RK_FUNC_2 &pcfg_pull_none>, - <1 29 RK_FUNC_2 &pcfg_pull_none>, - <1 30 RK_FUNC_2 &pcfg_pull_none>, - <1 31 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PD0 2 &pcfg_pull_none>, + <1 RK_PD1 2 &pcfg_pull_none>, + <1 RK_PD2 2 &pcfg_pull_none>, + <1 RK_PD3 2 &pcfg_pull_none>, + <1 RK_PD4 2 &pcfg_pull_none>, + <1 RK_PD5 2 &pcfg_pull_none>, + <1 RK_PD6 2 &pcfg_pull_none>, + <1 RK_PD7 2 &pcfg_pull_none>; }; };
nandc{ nandc_ale:nandc-ale { - rockchip,pins = <0 18 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PC2 1 &pcfg_pull_none>; };
nandc_cle:nandc-cle { - rockchip,pins = <0 18 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PC2 1 &pcfg_pull_none>; };
nandc_wrn:nandc-wrn { - rockchip,pins = <0 18 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PC2 1 &pcfg_pull_none>; };
nandc_rdn:nandc-rdn { - rockchip,pins = <0 18 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PC2 1 &pcfg_pull_none>; };
nandc_rdy:nandc-rdy { - rockchip,pins = <0 18 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PC2 1 &pcfg_pull_none>; };
nandc_cs0:nandc-cs0 { - rockchip,pins = <0 18 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PC2 1 &pcfg_pull_none>; };
nandc_data: nandc-data { - rockchip,pins = <0 18 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PC2 1 &pcfg_pull_none>; }; };
uart0 { uart0_xfer: uart0-xfer { - rockchip,pins = <0 16 RK_FUNC_1 &pcfg_pull_none>, - <0 17 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PC0 1 &pcfg_pull_none>, + <0 RK_PC1 1 &pcfg_pull_none>; };
uart0_cts: uart0-cts { - rockchip,pins = <0 18 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PC2 1 &pcfg_pull_none>; };
uart0_rts: uart0-rts { - rockchip,pins = <0 19 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PC3 1 &pcfg_pull_none>; }; };
uart1 { uart1_xfer: uart1-xfer { - rockchip,pins = <2 22 RK_FUNC_1 &pcfg_pull_none>, - <2 23 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PC6 1 &pcfg_pull_none>, + <2 RK_PC7 1 &pcfg_pull_none>; }; };
uart2 { uart2_xfer: uart2-xfer { - rockchip,pins = <1 18 RK_FUNC_2 &pcfg_pull_none>, - <1 19 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PC2 2 &pcfg_pull_none>, + <1 RK_PC3 2 &pcfg_pull_none>; }; };
@@ -727,75 +727,75 @@
pwm0 { pwm0_pin: pwm0-pin { - rockchip,pins = <0 0 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA0 2 &pcfg_pull_none>; }; };
pwm1 { pwm1_pin: pwm1-pin { - rockchip,pins = <0 1 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA1 2 &pcfg_pull_none>; }; };
pwm2 { pwm2_pin: pwm2-pin { - rockchip,pins = <0 1 2 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA1 2 &pcfg_pull_none>; }; };
pwm3 { pwm3_pin: pwm3-pin { - rockchip,pins = <0 27 1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PD3 1 &pcfg_pull_none>; }; };
i2c0 { i2c0_xfer: i2c0-xfer { - rockchip,pins = <0 0 RK_FUNC_1 &pcfg_pull_none>, - <0 1 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA0 1 &pcfg_pull_none>, + <0 RK_PA1 1 &pcfg_pull_none>; }; };
i2c1 { i2c1_xfer: i2c1-xfer { - rockchip,pins = <0 2 RK_FUNC_1 &pcfg_pull_none>, - <0 3 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA2 1 &pcfg_pull_none>, + <0 RK_PA3 1 &pcfg_pull_none>; }; };
i2c2 { i2c2_xfer: i2c2-xfer { - rockchip,pins = <2 20 3 &pcfg_pull_none>, - <2 21 3 &pcfg_pull_none>; + rockchip,pins = <2 RK_PC4 3 &pcfg_pull_none>, + <2 RK_PC5 3 &pcfg_pull_none>; }; };
i2c3 { i2c3_xfer: i2c3-xfer { - rockchip,pins = <0 6 RK_FUNC_1 &pcfg_pull_none>, - <0 7 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA6 1 &pcfg_pull_none>, + <0 RK_PA7 1 &pcfg_pull_none>; }; };
spi0 { spi0_txd_mux0:spi0-txd-mux0 { - rockchip,pins = <2 4 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <2 RK_PA4 2 &pcfg_pull_none>; };
spi0_rxd_mux0:spi0-rxd-mux0 { - rockchip,pins = <2 4 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <2 RK_PA4 2 &pcfg_pull_none>; };
spi0_clk_mux0:spi0-clk-mux0 { - rockchip,pins = <2 4 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <2 RK_PA4 2 &pcfg_pull_none>; };
spi0_cs0_mux0:spi0-cs0-mux0 { - rockchip,pins = <2 4 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <2 RK_PA4 2 &pcfg_pull_none>; };
spi0_cs1_mux0:spi0-cs1-mux0 { - rockchip,pins = <2 4 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <2 RK_PA4 2 &pcfg_pull_none>; }; };
Johan Jonker
