[U-Boot] Undefined reference to `boot_relocate_fdt'
His I'm trying to build u-boot for a xupv2p board, but with the newest version this is appearing during the make : * $make xupv2p_config $make*
-Map u-boot.map -o u-boot common/libcommon.a(cmd_bootm.o): In function `do_bootm_subcommand': /home/juanwalker/software/projects/u-boot/common/cmd_bootm.c:505: undefined reference to `boot_relocate_fdt' make: *** [u-boot] Error 1
Hi Juan,
That is odd. It works for me on a PowerPC target (I don't have microblaze support set up). Your config has CONFIG_LIBFDT enabled, which is why do_bootm_subcommand is calling boot_relocate_fdt. I don't see any obvious reason why boot_relocate_fdt isn't in your build (it is defined in common/image.c and enabled by CONFIG_LIBFDT).
One thing you could do is to save your make output into a log file make > make.log and then find the line that compiles image.c (it likely will be the *second* time, the first time is making host tools). Cut and paste it onto the command line (in the common/ subdirectory) BUT CHANGE the flags at the end of the gcc command from: -c -o image.o image.c to: -C -E -o image.pp image.c This stops after running the preprocessor and puts the result in "image.pp". Maybe you can get a clue what happened to your boot_relocate_fdt() from that???
Best regards, gvb
Hi Juan,
this change arise with some new patches. Latest v2008.10 release is OK. I will track it where is the problem. Currently FDT support for microblaze is not in the repo. Just disable libfdt (comment #define CONFIG_OF_LIBFDT) in config files(ml401.h, xupv2p.h).
Thanks, Michal
Jerry Van Baren
Juan Pablo Gómez
Michal Simek
