[U-Boot] pull request u-boot-fsl-qoriq
Dear Tom,
Please find my pull-request for u-boot-fsl-qoriq/master
https://travis-ci.org/p-priyanka-jain/u-boot/builds/609183013
Summary
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC.
Few bug fixes and updates related to SPI, hwconfig, ethernet, fsl-layerscape, pci, icid, PSCI
priyankajain
The following changes since commit d9110878895634cd9e8bf891c832d2a58b36863c:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-mpc85xx (2019-11-07 07:25:14 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriq.git HEAD
for you to fetch changes up to bef18454044e62800ece687b8d50ddd853117660:
freescale/powerpc: Rename the config CONFIG_SECURE_BOOT name (2019-11-08 16:32:08 +0530)
Laurentiu Tudor (6):
armv8: fsl-layerscape: guard caam specific defines
fsl-layerscape: fix compile error with sec fw disabled
armv8: ls2088a: add icid setup for platform devices
fsl-layerscape: add missing SATA3 and SATA4 base addresses
armv8: lx2160a: add icid setup for platform devices
armv8: ls1028a: add erratum A-050382 workaround
Mathew McBride (2):
armv8: dts: ls1088a: add PSCI binding for LS1088A
fsl-layerscape: do not use layerscape EFI reset if PSCI used
Michael Walle (4):
armv8: fsl-lsch3: convert CONFIG_TARGET_x to CONFIG_ARCH_x
armv8: fsl-layerscape: introduce fsl_board_late_init()
drivers: net: fsl_enetc: set phydev->node
drivers: net: fsl_enetc: fix RGMII configuration
Pankaj Bansal (2):
pci: layerscape: Only set EP CFG READY bit
fsl-layerscape: fix warning if no hwconfig is defined
Udit Agarwal (2):
freescale/layerscape: Rename the config CONFIG_SECURE_BOOT name
Xiaowei Bao (1):
configs: spi: Add the SPI_FLASH_BAR for ESPI
arch/arm/cpu/armv7/ls102xa/Kconfig | 4 +-
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 7 +++-
arch/arm/cpu/armv8/fsl-layerscape/Makefile | 2 +
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 6 ++-
.../arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c | 10 ++---
arch/arm/cpu/armv8/fsl-layerscape/ls1028_ids.c | 2 +
arch/arm/cpu/armv8/fsl-layerscape/ls1088_ids.c | 2 +
arch/arm/cpu/armv8/fsl-layerscape/ls2088_ids.c | 35 ++++++++++++++++
arch/arm/cpu/armv8/fsl-layerscape/lx2160_ids.c | 48 ++++++++++++++++++++++
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 10 ++++-
arch/arm/cpu/armv8/fsl-layerscape/spl.c | 2 +-
arch/arm/dts/fsl-ls1088a.dtsi | 5 +++
.../arm/include/asm/arch-fsl-layerscape/fsl_icid.h | 2 +- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 6 ++-
.../asm/arch-fsl-layerscape/stream_id_lsch3.h | 17 ++++++++
arch/powerpc/cpu/mpc85xx/Kconfig | 4 +-
arch/powerpc/cpu/mpc85xx/cpu_init.c | 8 ++--
arch/powerpc/cpu/mpc85xx/start.S | 10 ++---
arch/powerpc/cpu/mpc8xxx/law.c | 4 +-
arch/powerpc/include/asm/fsl_secure_boot.h | 4 +-
board/freescale/common/Kconfig | 2 +-
board/freescale/common/Makefile | 2 +-
board/freescale/common/p_corenet/tlb.c | 2 +-
board/freescale/ls1043ardb/ls1043ardb.c | 2 +-
board/freescale/ls1046afrwy/ls1046afrwy.c | 2 +-
board/freescale/ls1046aqds/ls1046aqds.c | 2 +-
board/freescale/ls1046ardb/ls1046ardb.c | 2 +-
board/freescale/ls2080aqds/ls2080aqds.c | 3 ++
board/freescale/ls2080ardb/ls2080ardb.c | 3 ++
board/freescale/lx2160a/lx2160a.c | 2 +
board/freescale/t104xrdb/tlb.c | 4 +-
configs/B4860QDS_SECURE_BOOT_defconfig | 2 +-
configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 2 +- configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 2 +- configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 2 +- configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 2 +-
.../BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 2 +-
.../BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 2 +-
.../BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 2 +- .../BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 2 +-
configs/C29XPCIE_NOR_SECBOOT_defconfig | 2 +-
configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 2 +-
configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 2 +-
configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 2 +-
.../P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 2 +-
configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 2 +-
configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 2 +-
configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 2 +-
configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 2 +-
configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 2 +-
.../P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 2 +-
configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 2 +-
configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 2 +-
configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 2 +-
configs/P2041RDB_SECURE_BOOT_defconfig | 2 +-
configs/P3041DS_NAND_SECURE_BOOT_defconfig | 2 +-
configs/P3041DS_SECURE_BOOT_defconfig | 2 +-
configs/P4080DS_SECURE_BOOT_defconfig | 2 +-
configs/P5020DS_NAND_SECURE_BOOT_defconfig | 2 +-
configs/P5020DS_SECURE_BOOT_defconfig | 2 +-
configs/P5040DS_NAND_SECURE_BOOT_defconfig | 2 +-
configs/P5040DS_SECURE_BOOT_defconfig | 2 +-
configs/T1023RDB_SECURE_BOOT_defconfig | 2 +-
configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 2 +-
configs/T1024QDS_SECURE_BOOT_defconfig | 2 +-
configs/T1024RDB_SECURE_BOOT_defconfig | 2 +-
configs/T1040D4RDB_SECURE_BOOT_defconfig | 2 +-
configs/T1040QDS_SECURE_BOOT_defconfig | 2 +-
configs/T1040RDB_SECURE_BOOT_defconfig | 2 +-
configs/T1042D4RDB_SECURE_BOOT_defconfig | 2 +-
configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 2 +-
configs/T1042RDB_SECURE_BOOT_defconfig | 2 +-
configs/T2080QDS_SECURE_BOOT_defconfig | 2 +-
configs/T2080RDB_SECURE_BOOT_defconfig | 2 +-
configs/T4160QDS_SECURE_BOOT_defconfig | 2 +-
configs/T4240QDS_SECURE_BOOT_defconfig | 2 +-
configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig | 2 +-
configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig | 2 +-
configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 2 +-
configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 2 +-
configs/ls1012ardb_tfa_SECURE_BOOT_defconfig | 2 +-
configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 2 +-
configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 2 +-
.../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 2 +-
configs/ls1028aqds_tfa_SECURE_BOOT_defconfig | 2 +-
configs/ls1028ardb_tfa_SECURE_BOOT_defconfig | 2 +-
configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 2 +-
configs/ls1043ardb_SECURE_BOOT_defconfig | 2 +-
configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 2 +-
configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 2 +-
configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 2 +-
configs/ls1046aqds_SECURE_BOOT_defconfig | 2 +-
configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 2 +-
configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 2 +-
configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 2 +-
configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 2 +-
configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 2 +-
configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 2 +-
.../ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 2 +-
configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 2 +-
configs/ls2080aqds_SECURE_BOOT_defconfig | 2 +-
configs/ls2080ardb_SECURE_BOOT_defconfig | 2 +-
configs/ls2088ardb_qspi_SECURE_BOOT_defconfig | 2 +-
configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 2 +-
configs/lx2160aqds_tfa_SECURE_BOOT_defconfig | 2 +-
configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 2 +-
doc/README.mpc85xx | 8 ++--
drivers/net/fsl_enetc.c | 4 ++
drivers/pci/pcie_layerscape.c | 6 ++-
drivers/spi/Kconfig | 1 +
include/configs/P1010RDB.h | 4 +-
include/configs/T104xRDB.h | 6 +--
include/configs/corenet_ds.h | 2 +-
include/configs/ls1021atwr.h | 4 +-
include/configs/ls1028a_common.h | 2 +-
include/configs/ls1043a_common.h | 8 ++--
include/configs/ls1046a_common.h | 4 +-
include/configs/ls1088a_common.h | 4 +-
include/configs/ls1088aqds.h | 6 +--
include/configs/ls2080aqds.h | 4 +-
include/fsl_sec.h | 3 +-
121 files changed, 286 insertions(+), 144 deletions(-) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls2088_ids.c
create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/lx2160_ids.c
On Mon, Nov 11, 2019 at 04:45:02AM +0000, Priyanka Jain wrote:
Dear Tom,
Summary
priyankajain
Priyanka Jain
