[U-Boot] [PATCH] ppc4xx: Fix FDT EBC mappings on Canyonlands
This patch fixes 2 problems with FDT EBC mappings on Canyonlands. First, NAND EBC mapping was missing, making Linux NAND driver unusable on this board. Second, NOR remapping code assumed that NOR is always on CS0, however when booting from NAND NOR is on CS3. --- board/amcc/canyonlands/canyonlands.c | 6 ++++-- include/configs/canyonlands.h | 2 ++ 2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/board/amcc/canyonlands/canyonlands.c b/board/amcc/canyonlands/canyonlands.c index 2b74689..cfc1023 100644 --- a/board/amcc/canyonlands/canyonlands.c +++ b/board/amcc/canyonlands/canyonlands.c @@ -575,15 +575,17 @@ int misc_init_r(void) #endif /* !defined(CONFIG_ARCHES) */
#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +extern void __ft_board_setup(void *blob, bd_t *bd); + void ft_board_setup(void *blob, bd_t *bd) { u32 val[4]; int rc;
- ft_cpu_setup(blob, bd); + __ft_board_setup(blob, bd);
/* Fixup NOR mapping */ - val[0] = 0; /* chip select number */ + val[0] = CONFIG_SYS_NOR_CS; /* chip select number */ val[1] = 0; /* always 0 */ val[2] = CONFIG_SYS_FLASH_BASE_PHYS_L; /* we fixed up this address */ val[3] = gd->bd->bi_flashsize; diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index d814012..48c5198 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -132,9 +132,11 @@ */ #if !defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) #define CONFIG_ENV_IS_IN_FLASH 1 /* use FLASH for environment vars */ +#define CONFIG_SYS_NOR_CS 0 /* NOR chip connected to CSx */ #define CONFIG_SYS_NAND_CS 3 /* NAND chip connected to CSx */ #else #define CONFIG_ENV_IS_IN_NAND 1 /* use NAND for environment vars */ +#define CONFIG_SYS_NOR_CS 3 /* NOR chip connected to CSx */ #define CONFIG_SYS_NAND_CS 0 /* NAND chip connected to CSx */ #define CONFIG_ENV_IS_EMBEDDED 1 /* use embedded environment */ #endif
You forgot you signed-off-by line here. I added it manually and pushed it into the u-boot-ppc4xx/master repo.
Thanks.
Best regards, Stefan
Felix Radensky
Stefan Roese
