[U-Boot] [PATCH] command.c: Enable auto tab for the editenv command
Enable the auto completion (with TAB) of the environment variable name after the editenv command.
Signed-off-by: Ralf Trübenbach ralf.truebenbach@men.de ---
=== modified file 'common/command.c' (properties changed: -x to +x) --- common/command.c 2009-11-22 23:06:11 +0000 +++ common/command.c 2010-04-08 15:12:44 +0000 @@ -188,6 +188,9 @@
void install_auto_complete(void) { +#if defined(CONFIG_CMD_EDITENV) + install_auto_complete_handler("editenv", var_complete); +#endif install_auto_complete_handler("printenv", var_complete); install_auto_complete_handler("setenv", var_complete); #if defined(CONFIG_CMD_RUN)
Hi Ralf,
The idea looks good, but the patch as such is not usable:
[dzu@pollux u-boot-testing (misc-fixes)]$ git am -3 -u ~/p1 Applying: command.c: Enable auto tab for the editenv command error: command.c: does not exist in index fatal: sha1 information is lacking or useless (command.c). Repository lacks necessary blobs to fall back on 3-way merge. Cannot fall back to three-way merge. Patch failed at 0001 command.c: Enable auto tab for the editenv command When you have resolved this problem run "git am -3 --resolved". If you would prefer to skip this patch, instead run "git am -3 --skip". To restore the original branch and stop patching run "git am -3 --abort". [dzu@pollux u-boot-testing (misc-fixes|AM)]$
How did you create the patch? Please follow the instructions[1] in order to make life easier for everybody.
This also looks strange - we certainly don't want execute rights on source files.
Cheers Detlev
[1] http://www.denx.de/wiki/U-Boot/Patches
Hello Detlev,
you are right (sorry). I've used Bazzar to create the patch (since we use Bazzar for version control here). I'm currently working on getting correct formatted patches (or switch to git for that).
I'll resend the patch next week.
Ralf
-----Original Message----- From: Detlev Zundel [mailto:dzu@denx.de] Sent: Friday, April 09, 2010 10:18 AM To: Trübenbach Ralf Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] command.c: Enable auto tab for the editenv command
Hi Ralf,
variable name
Cheers Detlev
-- Per Anhalter durch die Galaxis hat den gewissen Effekt, den auch eine Sendung von Monty Python auslöst; es läßt alles, was direkt danach in Radio, im Fern- sehen oder sonstwo auftaucht, absolut lächerlich wirken. Es hat dieses gewisse Etwas, das alles in einem gereinigten Licht erscheinen läßt.
- Robert Cushman
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-40 Fax: (+49)-8142-66989-80 Email: dzu@denx.de
Detlev Zundel
Ralf Trübenbach
Trübenbach Ralf
