[U-Boot] [PATCH v2 1/5] drivers: Add OSD uclass
Some devices offer a text-based OSD (on-screen display) that can be programmatically controlled (i.e. text displayed on).
Add a uclass to support such devices.
Signed-off-by: Mario Six mario.six@gdsys.cc
v1 -> v2: * Use singular case for UCLASS_VIDEO_OSD description * Expanded description of video_osd_set_mem with example * Replaced all left-over mentions of pixels with text * Renamed x and y parameters to col and row * Expaneded description of color parameter * Added general description of the OSD uclass * Expanded description of video_osd_info
--- drivers/video/Kconfig | 8 ++ drivers/video/Makefile | 2 + drivers/video/video_osd-uclass.c | 46 ++++++++++ include/dm/uclass-id.h | 1 + include/video_osd.h | 193 +++++++++++++++++++++++++++++++++++++++ 5 files changed, 250 insertions(+) create mode 100644 drivers/video/video_osd-uclass.c create mode 100644 include/video_osd.h
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 4c4d2861fe7..37be23d2fcc 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -658,4 +658,12 @@ config VIDEO_DT_SIMPLEFB The video output is initialized by U-Boot, and kept by the kernel.
+config OSD + bool "Enable OSD support" + depends on DM + default n + help + This supports drivers that provide a OSD (on-screen display), which + is a (usually text-oriented) graphics buffer to show information on + a display. endmenu diff --git a/drivers/video/Makefile b/drivers/video/Makefile index cf7ad281c3b..1889c5a5208 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -55,5 +55,7 @@ obj-${CONFIG_EXYNOS_FB} += exynos/ obj-${CONFIG_VIDEO_ROCKCHIP} += rockchip/ obj-${CONFIG_VIDEO_STM32} += stm32/
+obj-${CONFIG_OSD} += video_osd-uclass.o + obj-y += bridge/ obj-y += sunxi/ diff --git a/drivers/video/video_osd-uclass.c b/drivers/video/video_osd-uclass.c new file mode 100644 index 00000000000..ae9b6a6fa82 --- /dev/null +++ b/drivers/video/video_osd-uclass.c @@ -0,0 +1,46 @@ +/* + * (C) Copyright 2017 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <video_osd.h> + +int video_osd_get_info(struct udevice *dev, struct video_osd_info *info) +{ + struct video_osd_ops *ops = video_osd_get_ops(dev); + + return ops->get_info(dev, info); +} + +int video_osd_set_mem(struct udevice *dev, uint col, uint row, u8 *buf, + size_t buflen, uint count) +{ + struct video_osd_ops *ops = video_osd_get_ops(dev); + + return ops->set_mem(dev, col, row, buf, buflen, count); +} + +int video_osd_set_size(struct udevice *dev, uint col, uint row) +{ + struct video_osd_ops *ops = video_osd_get_ops(dev); + + return ops->set_size(dev, col, row); +} + +int video_osd_print(struct udevice *dev, uint col, uint row, ulong color, + char *text) +{ + struct video_osd_ops *ops = video_osd_get_ops(dev); + + return ops->print(dev, col, row, color, text); +} + +UCLASS_DRIVER(video_osd) = { + .id = UCLASS_VIDEO_OSD, + .name = "video_osd", + .flags = DM_UC_FLAG_SEQ_ALIAS, +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index d7f9df3583a..e42f8481bf8 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -89,6 +89,7 @@ enum uclass_id { UCLASS_VIDEO, /* Video or LCD device */ UCLASS_VIDEO_BRIDGE, /* Video bridge, e.g. DisplayPort to LVDS */ UCLASS_VIDEO_CONSOLE, /* Text console driver for video device */ + UCLASS_VIDEO_OSD, /* On-screen display */ UCLASS_WDT, /* Watchdot Timer driver */
UCLASS_COUNT, diff --git a/include/video_osd.h b/include/video_osd.h new file mode 100644 index 00000000000..c3bcd3a4fd8 --- /dev/null +++ b/include/video_osd.h @@ -0,0 +1,193 @@ +/* + * (C) Copyright 2017 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _VIDEO_OSD_H_ +#define _VIDEO_OSD_H_ + +struct video_osd_info { + /* The width of the OSD display in columns */ + uint width; + /* The height of the OSD display in rows */ + uint height; + /* The major version of the OSD device */ + uint major_version; + /* The minor version of the OSD device */ + uint minor_version; +}; + +/** + * struct video_osd_ops - driver operations for OSD uclass + * + * The OSD uclass implements support for text-oriented on-screen displays, + * which are taken to be devices that independently display a graphical + * text-based overlay over the video output of an associated display. + * + * The functions defined by the uclass support writing text to the display in + * either a generic form (by specifying a string, a driver-specific color value + * for the text, and screen coordinates in rows and columns) or a + * driver-specific form (by specifying "raw" driver-specific data to display at + * a given coordinate). + * + * Functions to read device information and set the size of the virtual OSD + * screen (in rows and columns) are also supported. + * + * Drivers should support these operations unless otherwise noted. These + * operations are intended to be used by uclass code, not directly from + * other code. + */ +struct video_osd_ops { + /** + * get_info() - Get information about a OSD instance + * + * A OSD instance may keep some internal data about itself. This + * function can be used to access this data. + * + * @dev: OSD instance to query. + * @info: Pointer to a structure that takes the information read + * from the OSD instance. + * @return 0 if OK, -ve on error. + */ + int (*get_info)(struct udevice *dev, struct video_osd_info *info); + + /** + * set_mem() - Write driver-specific text data to OSD screen + * + * The passed data are device-specific, and it's up to the driver how + * to interpret them. How the count parameter is interpreted is also + * driver-specific; most likely the given data will be written to the + * OSD count times back-to-back, which is e.g. convenient for filling + * areas of the OSD with a single character. + * + * For example a invocation of + * + * video_osd_set_mem(dev, 0, 0, "A", 1, 10); + * + * will write the device-specific text data "A" to the positions (0, 0) + * to (9, 0) on the OSD. + * + * Device-specific text data may, e.g. be a special encoding of glyphs + * to display and color values in binary format. + * + * @dev: OSD instance to write to. + * @col: Horizontal character coordinate to write to. + * @row Vertical character coordinate to write to. + * @buf: Array containing device-specific data to write to the + * specified coordinate on the OSD screen. + * @buflen: Length of the data in the passed buffer (in byte). + * @count: Write count many repetitions of the given text data + * @return 0 if OK, -ve on error. + */ + int (*set_mem)(struct udevice *dev, uint col, uint row, u8 *buf, + size_t buflen, uint count); + + /** + * set_size() - Set the position and dimension of the OSD's + * writeable window + * + * @dev: OSD instance to write to. + * @col The number of characters in the window's columns + * @row The number of characters in the window's rows + * @return 0 if OK, -ve on error. + */ + int (*set_size)(struct udevice *dev, uint col, uint row); + + /** + * print() - Print a string in a given color to specified coordinates + * on the OSD + * + * @dev: OSD instance to write to. + * @col The x-coordinate of the position the string should be + * written to + * @row The y-coordinate of the position the string should be + * written to + * @color: The color in which the specified string should be + * printed; the interpretation of the value is + * driver-specific, and possible values should be defined + * e.g. in a driver include file. + * @text: The string data that should be printed on the OSD + * @return 0 if OK, -ve on error. + */ + int (*print)(struct udevice *dev, uint col, uint row, ulong color, + char *text); +}; + +#define video_osd_get_ops(dev) ((struct video_osd_ops *)(dev)->driver->ops) + +/** + * video_osd_get_info() - Get information about a OSD instance + * + * A OSD instance may keep some internal data about itself. This function can + * be used to access this data. + * + * @dev: OSD instance to query. + * @info: Pointer to a structure that takes the information read from the + * OSD instance. + * @return 0 if OK, -ve on error. + */ +int video_osd_get_info(struct udevice *dev, struct video_osd_info *info); + +/** + * video_osd_set_mem() - Write text data to OSD memory + * + * The passed data are device-specific, and it's up to the driver how to + * interpret them. How the count parameter is interpreted is also + * driver-specific; most likely the given data will be written to the OSD count + * times back-to-back, which is e.g. convenient for filling areas of the OSD + * with a single character. + * + * For example a invocation of + * + * video_osd_set_mem(dev, 0, 0, "A", 1, 10); + * + * will write the device-specific text data "A" to the positions (0, 0) to (9, + * 0) on the OSD. + * + * Device-specific text data may, e.g. be a special encoding of glyphs to + * display and color values in binary format. + * + * @dev: OSD instance to write to. + * @col: Horizontal character coordinate to write to. + * @row Vertical character coordinate to write to. + * @buf: Array containing device-specific data to write to the specified + * coordinate on the OSD screen. + * @buflen: Length of the data in the passed buffer (in byte). + * @count: Write count many repetitions of the given text data + * @return 0 if OK, -ve on error. + */ +int video_osd_set_mem(struct udevice *dev, uint col, uint row, u8 *buf, + size_t buflen, uint count); + +/** + * video_osd_set_size() - Set the position and dimension of the OSD's + * writeable window + * + * @dev: OSD instance to write to. + * @col The number of characters in the window's columns + * @row The number of characters in the window's rows + * @return 0 if OK, -ve on error. + */ +int video_osd_set_size(struct udevice *dev, uint col, uint row); + +/** + * video_osd_print() - Print a string in a given color to specified coordinates + * on the OSD + * + * @dev: OSD instance to write to. + * @col The x-coordinate of the position the string should be written + * to + * @row The y-coordinate of the position the string should be written + * to + * @color: The color in which the specified string should be printed; the + * interpretation of the value is driver-specific, and possible + * values should be defined e.g. in a driver include file. + * @text: The string data that should be printed on the OSD + * @return 0 if OK, -ve on error. + */ +int video_osd_print(struct udevice *dev, uint col, uint row, ulong color, + char *text); + +#endif /* !_VIDEO_OSD_H_ */ -- 2.11.0
Add a driver for IHS OSDs on IHS FPGAs.
v1 -> v2: * Renamed x and y parameters to col and row * Removed duplicate IHS_VIDEO_OUT definition * Switched error return code of ihs_video_out_set_mem to E2BIG * Dropped blank lines between dev_read_u32_default calls * Documented members of ihs_video_out_priv * Turned printfs into debugs * Don't display OSD until something has been written to it * Made the code a bit more readable * Added binding file * Expanded documentation and help * Switched to display_enable * Switched to regmap usage (instead of fpgamap uclass) * Renamed 'dp_tx' property to 'video_tx'
--- .../video/osd/gdsys,ihs_video_out.txt | 22 ++ drivers/video/Kconfig | 9 + drivers/video/Makefile | 1 + drivers/video/ihs_video_out.c | 277 +++++++++++++++++++++ 4 files changed, 309 insertions(+) create mode 100644 doc/device-tree-bindings/video/osd/gdsys,ihs_video_out.txt create mode 100644 drivers/video/ihs_video_out.c
diff --git a/doc/device-tree-bindings/video/osd/gdsys,ihs_video_out.txt b/doc/device-tree-bindings/video/osd/gdsys,ihs_video_out.txt new file mode 100644 index 00000000000..464374613b8 --- /dev/null +++ b/doc/device-tree-bindings/video/osd/gdsys,ihs_video_out.txt @@ -0,0 +1,22 @@ +* Guntermann & Drunck Integrated Hardware Systems OSD + +Required properties: +- compatible: "gdsys,ihs_video_out" +- reg: Register base for the video registers +- osd_base: Register base for the OSD registers +- osd_buffer_base: Address of the OSD video memory +- mode: The initial resolution and frequency: "1024_768_60", "720_400_70", or + "640_480_70" +- clk_gen: phandle to the pixel clock generator +- dp_tx: phandle to the display associated with the OSD + +Example: + +fpga0_video0 { + compatible = "gdsys,ihs_video_out"; + reg = <0x100 0x40>; + osd_base = <0x180>; + osd_buffer_base = <0x1000>; + dp_tx = <&fpga0_dp_video0>; + clk_gen = <&fpga0_video0_clkgen>; +}; diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 37be23d2fcc..4ca15174bb2 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -666,4 +666,13 @@ config OSD This supports drivers that provide a OSD (on-screen display), which is a (usually text-oriented) graphics buffer to show information on a display. + +config IHS_VIDEO_OUT + bool "Enable IHS video out driver" + depends on OSD + help + Enable support for the gdsys Integrated Hardware Systems (IHS) video + out On-screen Display (OSD) used on gdsys FPGAs to control dynamic + textual overlays of the display outputs. + endmenu diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 1889c5a5208..44252b5989a 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -56,6 +56,7 @@ obj-${CONFIG_VIDEO_ROCKCHIP} += rockchip/ obj-${CONFIG_VIDEO_STM32} += stm32/
obj-${CONFIG_OSD} += video_osd-uclass.o +obj-$(CONFIG_IHS_VIDEO_OUT) += ihs_video_out.o
obj-y += bridge/ obj-y += sunxi/ diff --git a/drivers/video/ihs_video_out.c b/drivers/video/ihs_video_out.c new file mode 100644 index 00000000000..3a870e22c2e --- /dev/null +++ b/drivers/video/ihs_video_out.c @@ -0,0 +1,277 @@ +/* + * (C) Copyright 2017 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + * + * based on the gdsys osd driver, which is + * + * (C) Copyright 2010 + * Dirk Eibach, Guntermann & Drunck GmbH, dirk.eibach@gdsys.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <display.h> +#include <dm.h> +#include <regmap.h> +#include <video_osd.h> +#include <asm/gpio.h> + +#define MAX_X_CHARS 53 +#define MAX_Y_CHARS 26 +#define MAX_VIDEOMEM_WIDTH (2 * 64) +#define MAX_VIDEOMEM_HEIGHT (2 * 32) +#define CHAR_WIDTH 12 +#define CHAR_HEIGHT 18 + +struct ihs_video_out_regs { + u16 versions; + u16 features; + u16 control; + u16 xy_size; + u16 xy_scale; + u16 x_pos; + u16 y_pos; +}; + +#define ihs_video_out_set(map, member, val) \ + regmap_range_set(map, 1, struct ihs_video_out_regs, member, val) + +#define ihs_video_out_get(map, member, valp) \ + regmap_range_get(map, 1, struct ihs_video_out_regs, member, valp) + +enum { + CONTROL_FILTER_BLACK = (0 << 0), + CONTROL_FILTER_ORIGINAL = (1 << 0), + CONTROL_FILTER_DARKER = (2 << 0), + CONTROL_FILTER_GRAY = (3 << 0), + + CONTROL_MODE_PASSTHROUGH = (0 << 3), + CONTROL_MODE_OSD = (1 << 3), + CONTROL_MODE_AUTO = (2 << 3), + CONTROL_MODE_OFF = (3 << 3), + + CONTROL_ENABLE_OFF = (0 << 6), + CONTROL_ENABLE_ON = (1 << 6), +}; + +struct ihs_video_out_priv { + /* Register map for OSD device */ + struct regmap *map; + /* Pointer to video memory */ + u16 *vidmem; + /* Display width in text columns */ + uint base_width; + /* Display height in text rows */ + uint base_height; + /* x-resolution of the display in pixels */ + uint res_x; + /* y-resolution of the display in pixels */ + uint res_y; + /* OSD's sync mode (resolution + frequency) */ + int sync_src; + /* The display port output for this OSD */ + struct udevice *video_tx; + /* The pixel clock generator for the display */ + struct udevice *clk_gen; +}; + +static const struct udevice_id ihs_video_out_ids[] = { + { .compatible = "gdsys,ihs_video_out" }, + { } +}; + +static int set_control(struct udevice *dev, u16 value) +{ + struct ihs_video_out_priv *priv = dev_get_priv(dev); + + if (priv->sync_src) + value |= ((priv->sync_src & 0x7) << 8); + + ihs_video_out_set(priv->map, control, value); + + return 0; +} + +int ihs_video_out_get_info(struct udevice *dev, struct video_osd_info *info) +{ + struct ihs_video_out_priv *priv = dev_get_priv(dev); + u16 versions; + + ihs_video_out_get(priv->map, versions, &versions); + + info->width = priv->base_width; + info->height = priv->base_height; + info->major_version = versions / 100; + info->minor_version = versions % 100; + + return 0; +} + +int ihs_video_out_set_mem(struct udevice *dev, uint col, uint row, u8 *buf, + size_t buflen, uint count) +{ + struct ihs_video_out_priv *priv = dev_get_priv(dev); + uint offset; + uint k, l; + u16 data; + + for (l = 0; l < count; ++l) { + offset = row * priv->base_width + col + l * (buflen / 2); + + for (k = 0; k < buflen / 2; ++k) { + if (offset + k >= priv->base_width * priv->base_height) + return -E2BIG; + + data = buf[2 * k + 1] + 256 * buf[2 * k]; + out_le16(priv->vidmem + offset + k, data); + } + } + + set_control(dev, CONTROL_FILTER_ORIGINAL | + CONTROL_MODE_OSD | + CONTROL_ENABLE_ON); + + return 0; +} + +inline u16 div2_u16(u16 val) +{ + return (32767 * val) / 65535; +} + +int ihs_video_out_set_size(struct udevice *dev, uint col, uint row) +{ + struct ihs_video_out_priv *priv = dev_get_priv(dev); + + if (!col || col > 64 || col > MAX_X_CHARS || + !row || row > 32 || row > MAX_Y_CHARS) { + return -EINVAL; + } + + ihs_video_out_set(priv->map, xy_size, ((col - 1) << 8) | (row - 1)); + /* Center OSD on screen */ + ihs_video_out_set(priv->map, x_pos, + div2_u16(priv->res_x - CHAR_WIDTH * col)); + ihs_video_out_set(priv->map, y_pos, + div2_u16(priv->res_y - CHAR_HEIGHT * row)); + + return 0; +} + +int ihs_video_out_print(struct udevice *dev, uint col, uint row, ulong color, + char *text) +{ + int res; + u8 buffer[MAX_VIDEOMEM_WIDTH]; + uint k; + uint charcount = strlen(text); + uint len = min(charcount, (uint)(MAX_VIDEOMEM_WIDTH)); + + for (k = 0; k < len; ++k) { + buffer[2 * k] = text[k]; + buffer[2 * k + 1] = color; + } + + res = ihs_video_out_set_mem(dev, col, row, buffer, 2 * len, 1); + + if (res < 0) + return res; + + return 0; +} + +static const struct video_osd_ops ihs_video_out_ops = { + .get_info = ihs_video_out_get_info, + .set_mem = ihs_video_out_set_mem, + .set_size = ihs_video_out_set_size, + .print = ihs_video_out_print, +}; + +int ihs_video_out_probe(struct udevice *dev) +{ + struct ihs_video_out_priv *priv = dev_get_priv(dev); + int len = 0; + struct ofnode_phandle_args phandle_args; + char *mode; + u16 features; + struct display_timing timing; + + regmap_init_mem(dev_ofnode(dev), &priv->map); + + /* Range with index 2 is video memory */ + priv->vidmem = regmap_get_range(priv->map, 2); + + mode = (char *)dev_read_prop(dev, "mode", &len); + + if (!mode) { + debug("%s: Could not read mode property.\n", dev->name); + return -EINVAL; + } + + if (!strcmp(mode, "1024_768_60")) { + priv->sync_src = 2; + priv->res_x = 1024; + priv->res_y = 768; + timing.hactive.typ = 1024; + timing.vactive.typ = 768; + } else if (!strcmp(mode, "720_400_70")) { + priv->sync_src = 1; + priv->res_x = 720; + priv->res_y = 400; + timing.hactive.typ = 720; + timing.vactive.typ = 400; + } else { + priv->sync_src = 0; + priv->res_x = 640; + priv->res_y = 480; + timing.hactive.typ = 640; + timing.vactive.typ = 480; + } + + ihs_video_out_get(priv->map, features, &features); + + set_control(dev, CONTROL_FILTER_ORIGINAL | + CONTROL_MODE_OSD | + CONTROL_ENABLE_OFF); + + priv->base_width = ((features & 0x3f00) >> 8) + 1; + priv->base_height = (features & 0x001f) + 1; + + if (dev_read_phandle_with_args(dev, "clk_gen", NULL, 0, 0, + &phandle_args)) { + debug("%s: Could not get clk_gen node.\n", dev->name); + return -EINVAL; + } + + if (uclass_get_device_by_ofnode(UCLASS_CLK, phandle_args.node, + &priv->clk_gen)) { + debug("%s: Could not get clk_gen dev.\n", dev->name); + return -EINVAL; + } + + if (dev_read_phandle_with_args(dev, "video_tx", NULL, 0, 0, + &phandle_args)) { + debug("%s: Could not get video_tx.\n", dev->name); + return -EINVAL; + } + + if (uclass_get_device_by_ofnode(UCLASS_DISPLAY, phandle_args.node, + &priv->video_tx)) { + debug("%s: Could not get video_tx dev.\n", dev->name); + return -EINVAL; + } + + display_enable(priv->video_tx, 8, &timing); + + return 0; +} + +U_BOOT_DRIVER(ihs_video_out_drv) = { + .name = "ihs_video_out_drv", + .id = UCLASS_VIDEO_OSD, + .ops = &ihs_video_out_ops, + .of_match = ihs_video_out_ids, + .probe = ihs_video_out_probe, + .priv_auto_alloc_size = sizeof(struct ihs_video_out_priv), +}; -- 2.11.0
Hi Mario,
v1 -> v2:
- Renamed x and y parameters to col and row
- Removed duplicate IHS_VIDEO_OUT definition
- Switched error return code of ihs_video_out_set_mem to E2BIG
- Dropped blank lines between dev_read_u32_default calls
- Documented members of ihs_video_out_priv
- Turned printfs into debugs
- Don't display OSD until something has been written to it
- Made the code a bit more readable
- Added binding file
- Expanded documentation and help
- Switched to display_enable
- Switched to regmap usage (instead of fpgamap uclass)
- Renamed 'dp_tx' property to 'video_tx'
You could perhaps s/dev_read_prop/dev_read_string/ to avoid the cast. Also is there a binding file for your driver's device-tree node somewhere?
Hi Simon,
On Wed, May 23, 2018 at 6:33 PM, Simon Glass sjg@chromium.org wrote:
Hi Mario,
v1 -> v2:
Sure, no problem, and, no, there isn't. I will write a binding file for v3.
Best regards, Mario
Add sandbox driver and tests for the new OSD uclass.
v1 -> v2: New in v2
--- arch/sandbox/dts/test.dts | 4 + configs/sandbox64_defconfig | 3 + configs/sandbox_defconfig | 3 + configs/sandbox_flattree_defconfig | 3 + configs/sandbox_noblk_defconfig | 3 + configs/sandbox_spl_defconfig | 3 + drivers/video/Kconfig | 6 ++ drivers/video/Makefile | 1 + drivers/video/sandbox_osd.c | 157 ++++++++++++++++++++++++++++ drivers/video/sandbox_osd.h | 14 +++ drivers/video/video_osd-uclass.c | 9 ++ include/video_osd.h | 7 ++ test/dm/Makefile | 1 + test/dm/osd.c | 208 +++++++++++++++++++++++++++++++++++++ 14 files changed, 422 insertions(+) create mode 100644 drivers/video/sandbox_osd.c create mode 100644 drivers/video/sandbox_osd.h create mode 100644 test/dm/osd.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 5a0f187d8b7..b6cdda0fd33 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -559,6 +559,10 @@ }; }; }; + + osd { + compatible = "sandbox,sandbox_osd"; + }; };
#include "sandbox_pmic.dtsi" diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 20a2ab3ffb7..7464a3ca3af 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_GPT_RENAME=y CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y +CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_READ=y CONFIG_CMD_REMOTEPROC=y @@ -185,6 +186,8 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_OSD=y +CONFIG_SANDBOX_OSD=y CONFIG_WDT=y CONFIG_WDT_SANDBOX=y CONFIG_FS_CBFS=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 2fc84a16c91..f7925dfe6fb 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_GPT_RENAME=y CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y +CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_READ=y CONFIG_CMD_REMOTEPROC=y @@ -186,6 +187,8 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_OSD=y +CONFIG_SANDBOX_OSD=y CONFIG_WDT=y CONFIG_WDT_SANDBOX=y CONFIG_FS_CBFS=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index e922c4b38ff..126b9c07c54 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_DEMO=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y +CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SF=y @@ -167,6 +168,8 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_OSD=y +CONFIG_SANDBOX_OSD=y CONFIG_CMD_DHRYSTONE=y CONFIG_TPM=y CONFIG_LZ4=y diff --git a/configs/sandbox_noblk_defconfig b/configs/sandbox_noblk_defconfig index 8bdd4edcda6..243234b6c72 100644 --- a/configs/sandbox_noblk_defconfig +++ b/configs/sandbox_noblk_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y +CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SF=y @@ -166,6 +167,8 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_OSD=y +CONFIG_SANDBOX_OSD=y CONFIG_FS_CBFS=y CONFIG_FS_CRAMFS=y CONFIG_CMD_DHRYSTONE=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index fb6bb4baa2b..771d0f05a48 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y +CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SF=y @@ -185,6 +186,8 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_OSD=y +CONFIG_SANDBOX_OSD=y CONFIG_FS_CBFS=y CONFIG_FS_CRAMFS=y CONFIG_CMD_DHRYSTONE=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 4ca15174bb2..b1a8e05ad74 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -667,6 +667,12 @@ config OSD is a (usually text-oriented) graphics buffer to show information on a display.
+config SANDBOX_OSD + bool "Enable sandbox OSD" + depends on OSD + help + Enable support for sandbox OSD device used for testing purposes. + config IHS_VIDEO_OUT bool "Enable IHS video out driver" depends on OSD diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 44252b5989a..80a8b19ed5d 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -56,6 +56,7 @@ obj-${CONFIG_VIDEO_ROCKCHIP} += rockchip/ obj-${CONFIG_VIDEO_STM32} += stm32/
obj-${CONFIG_OSD} += video_osd-uclass.o +obj-${CONFIG_SANDBOX_OSD} += sandbox_osd.o obj-$(CONFIG_IHS_VIDEO_OUT) += ihs_video_out.o
obj-y += bridge/ diff --git a/drivers/video/sandbox_osd.c b/drivers/video/sandbox_osd.c new file mode 100644 index 00000000000..4fdae1bbedd --- /dev/null +++ b/drivers/video/sandbox_osd.c @@ -0,0 +1,157 @@ +#include <common.h> +#include <display.h> +#include <dm.h> +#include <video_osd.h> + +#include "sandbox_osd.h" + +struct sandbox_osd_priv { + uint width; + uint height; + u16 *buf; +}; + +static const struct udevice_id sandbox_osd_ids[] = { + { .compatible = "sandbox,sandbox_osd" }, + { } +}; + +inline u16 make_memval(u8 chr, u8 color) +{ + return chr * 0x100 + color; +} + +int sandbox_osd_get_info(struct udevice *dev, struct video_osd_info *info) +{ + struct sandbox_osd_priv *priv = dev_get_priv(dev); + + info->width = priv->width; + info->height = priv->height; + info->major_version = 1; + info->minor_version = 0; + + return 0; +} + +int sandbox_osd_set_mem(struct udevice *dev, uint col, uint row, u8 *buf, + size_t buflen, uint count) +{ + struct sandbox_osd_priv *priv = dev_get_priv(dev); + int pos; + u8 *mem = (u8 *)priv->buf; + int i; + + pos = 2 * (row * priv->width + col); + + if (pos >= 2 * (priv->width * priv->height)) + return -EINVAL; + + for (i = 0; i < count; i++) + memcpy(mem + pos + (i * buflen), buf, buflen); + + return 0; +} + +int _sandbox_osd_set_size(struct udevice *dev, uint col, uint row) +{ + struct sandbox_osd_priv *priv = dev_get_priv(dev); + int i; + uint size; + + priv->width = col; + priv->height = row; + size = priv->width * priv->height; + if (!priv->buf) + priv->buf = calloc(size, sizeof(u16)); + else + priv->buf = realloc(priv->buf, size * sizeof(u16)); + + if (!priv->buf) + return -ENOMEM; + + /* Fill OSD with black spaces */ + for (i = 0; i < size; i++) + priv->buf[i] = make_memval(' ', 'k'); + + return 0; +} + +int sandbox_osd_set_size(struct udevice *dev, uint col, uint row) +{ + return _sandbox_osd_set_size(dev, col, row); +} + +int sandbox_osd_print(struct udevice *dev, uint col, uint row, ulong color, + char *text) +{ + struct sandbox_osd_priv *priv = dev_get_priv(dev); + char cval; + char *p; + int pos; + + if (col >= priv->width || row >= priv->height) + return -EINVAL; + + switch (color) { + case COLOR_BLACK: + cval = 'k'; + break; + case COLOR_WHITE: + cval = 'w'; + break; + case COLOR_RED: + cval = 'r'; + break; + case COLOR_GREEN: + cval = 'g'; + break; + case COLOR_BLUE: + cval = 'b'; + break; + default: + return -EINVAL; + } + + p = text; + pos = row * priv->width + col; + + while (*p) + priv->buf[pos++] = make_memval(*(p++), cval); + + return 0; +} + +int sandbox_osd_get_mem(struct udevice *dev, u8 *buf, size_t buflen) +{ + struct sandbox_osd_priv *priv = dev_get_priv(dev); + uint memsize = 2 * (priv->width * priv->height); + + if (buflen < memsize) + return -EINVAL; + + memcpy(buf, priv->buf, memsize); + + return 0; +} + +static const struct video_osd_ops sandbox_osd_ops = { + .get_info = sandbox_osd_get_info, + .set_mem = sandbox_osd_set_mem, + .set_size = sandbox_osd_set_size, + .print = sandbox_osd_print, + .get_mem = sandbox_osd_get_mem, +}; + +int sandbox_osd_probe(struct udevice *dev) +{ + return _sandbox_osd_set_size(dev, 10, 10); +} + +U_BOOT_DRIVER(sandbox_osd_drv) = { + .name = "sandbox_osd_drv", + .id = UCLASS_VIDEO_OSD, + .ops = &sandbox_osd_ops, + .of_match = sandbox_osd_ids, + .probe = sandbox_osd_probe, + .priv_auto_alloc_size = sizeof(struct sandbox_osd_priv), +}; diff --git a/drivers/video/sandbox_osd.h b/drivers/video/sandbox_osd.h new file mode 100644 index 00000000000..644779913ec --- /dev/null +++ b/drivers/video/sandbox_osd.h @@ -0,0 +1,14 @@ +/* + * (C) Copyright 2018 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +enum { + COLOR_BLACK, + COLOR_WHITE, + COLOR_RED, + COLOR_GREEN, + COLOR_BLUE, +}; diff --git a/drivers/video/video_osd-uclass.c b/drivers/video/video_osd-uclass.c index ae9b6a6fa82..05886f3bd5b 100644 --- a/drivers/video/video_osd-uclass.c +++ b/drivers/video/video_osd-uclass.c @@ -39,6 +39,15 @@ int video_osd_print(struct udevice *dev, uint col, uint row, ulong color, return ops->print(dev, col, row, color, text); }
+#ifdef CONFIG_SANDBOX +int video_osd_get_mem(struct udevice *dev, u8 *buf, size_t buflen) +{ + struct video_osd_ops *ops = video_osd_get_ops(dev); + + return ops->get_mem(dev, buf, buflen); +} +#endif + UCLASS_DRIVER(video_osd) = { .id = UCLASS_VIDEO_OSD, .name = "video_osd", diff --git a/include/video_osd.h b/include/video_osd.h index c3bcd3a4fd8..006cf916c94 100644 --- a/include/video_osd.h +++ b/include/video_osd.h @@ -113,6 +113,9 @@ struct video_osd_ops { */ int (*print)(struct udevice *dev, uint col, uint row, ulong color, char *text); +#ifdef CONFIG_SANDBOX + int (*get_mem)(struct udevice *dev, u8 *buf, size_t buflen); +#endif };
#define video_osd_get_ops(dev) ((struct video_osd_ops *)(dev)->driver->ops) @@ -190,4 +193,8 @@ int video_osd_set_size(struct udevice *dev, uint col, uint row); int video_osd_print(struct udevice *dev, uint col, uint row, ulong color, char *text);
+#ifdef CONFIG_SANDBOX +int video_osd_get_mem(struct udevice *dev, u8 *buf, size_t buflen); +#endif + #endif /* !_VIDEO_OSD_H_ */ diff --git a/test/dm/Makefile b/test/dm/Makefile index 5511a85700c..7b390e1d2a0 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -22,6 +22,7 @@ obj-$(CONFIG_LED) += led.o obj-$(CONFIG_DM_MAILBOX) += mailbox.o obj-$(CONFIG_DM_MMC) += mmc.o obj-y += ofnode.o +obj-$(CONFIG_OSD) += osd.o obj-$(CONFIG_DM_PCI) += pci.o obj-$(CONFIG_PHY) += phy.o obj-$(CONFIG_POWER_DOMAIN) += power-domain.o diff --git a/test/dm/osd.c b/test/dm/osd.c new file mode 100644 index 00000000000..807cb885077 --- /dev/null +++ b/test/dm/osd.c @@ -0,0 +1,208 @@ +/* + * (C) Copyright 2018 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <dm/test.h> +#include <video_osd.h> +#include <display_options.h> +#include <test/ut.h> + +#include "../../drivers/video/sandbox_osd.h" + +const uint memsize = 2 * 10 * 10; + +static void split(u8 *mem, uint size, u8 *text, u8 *colors) +{ + int i; + u16 *p = (u16 *)mem; + + for (i = 0; i < size; i++) { + colors[i] = p[i] % 0x100; + text[i] = p[i] / 0x100; + } +} + +static void print_mem(u8 *mem, uint width, uint height) +{ + const uint memsize = 2 * 10 * 10; + u8 colors[memsize / 2]; + u8 text[memsize / 2]; + int i; + + split(mem, memsize / 2, text, colors); + + for (i = 0; i < width * height; i++) { + printf("%c", text[i]); + if (i > 0 && ((i + 1) % width) == 0) + printf("\n"); + } + + printf("\n"); + + for (i = 0; i < width * height; i++) { + printf("%c", colors[i]); + if (i > 0 && ((i + 1) % width) == 0) + printf("\n"); + } +} + +static int dm_test_osd_basics(struct unit_test_state *uts) +{ + struct udevice *dev; + u8 mem[memsize + 1]; + u8 colors[memsize / 2]; + u8 text[memsize / 2]; + struct video_osd_info info; + + ut_assertok(uclass_first_device_err(UCLASS_VIDEO_OSD, &dev)); + + video_osd_get_info(dev, &info); + + ut_asserteq(10, info.width); + ut_asserteq(10, info.height); + ut_asserteq(1, info.major_version); + ut_asserteq(0, info.minor_version); + + ut_assertok(video_osd_get_mem(dev, mem, memsize)); + split(mem, memsize / 2, text, colors); + + ut_assertok(memcmp(text, " " + " " + " " + " " + " " + " " + " " + " " + " " + " ", memsize / 2)); + + ut_assertok(memcmp(colors, "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk", memsize / 2)); + + print_mem(mem, 10, 10); + + ut_assertok(video_osd_print(dev, 1, 1, COLOR_RED, "Blah")); + + ut_assertok(video_osd_get_mem(dev, mem, memsize)); + split(mem, memsize / 2, text, colors); + + ut_assertok(memcmp(text, " " + " Blah " + " " + " " + " " + " " + " " + " " + " " + " ", memsize / 2)); + + ut_assertok(memcmp(colors, "kkkkkkkkkk" + "krrrrkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk", memsize / 2)); + + print_mem(mem, 10, 10); + + return 0; +} +DM_TEST(dm_test_osd_basics, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +static int dm_test_osd_extended(struct unit_test_state *uts) +{ + struct udevice *dev; + u8 mem[memsize + 1]; + u8 colors[memsize / 2]; + u8 text[memsize / 2]; + struct video_osd_info info; + u16 val; + + ut_assertok(uclass_first_device_err(UCLASS_VIDEO_OSD, &dev)); + + ut_assertok(video_osd_set_size(dev, 20, 5)); + + video_osd_get_info(dev, &info); + + ut_asserteq(20, info.width); + ut_asserteq(5, info.height); + ut_asserteq(1, info.major_version); + ut_asserteq(0, info.minor_version); + + ut_assertok(video_osd_get_mem(dev, mem, memsize)); + split(mem, memsize / 2, text, colors); + + ut_assertok(memcmp(text, " " + " " + " " + " " + " ", memsize / 2)); + + ut_assertok(memcmp(colors, "kkkkkkkkkkkkkkkkkkkk" + "kkkkkkkkkkkkkkkkkkkk" + "kkkkkkkkkkkkkkkkkkkk" + "kkkkkkkkkkkkkkkkkkkk" + "kkkkkkkkkkkkkkkkkkkk", memsize / 2)); + + print_mem(mem, 20, 5); + + /* Draw green border */ + val = '-' * 0x100 + 'g'; + ut_assertok(video_osd_set_mem(dev, 1, 0, (u8 *)&val, 2, 18)); + ut_assertok(video_osd_set_mem(dev, 1, 4, (u8 *)&val, 2, 18)); + ut_assertok(video_osd_print(dev, 0, 1, COLOR_GREEN, "|")); + ut_assertok(video_osd_print(dev, 0, 2, COLOR_GREEN, "|")); + ut_assertok(video_osd_print(dev, 0, 3, COLOR_GREEN, "|")); + ut_assertok(video_osd_print(dev, 19, 1, COLOR_GREEN, "|")); + ut_assertok(video_osd_print(dev, 19, 2, COLOR_GREEN, "|")); + ut_assertok(video_osd_print(dev, 19, 3, COLOR_GREEN, "|")); + ut_assertok(video_osd_print(dev, 0, 0, COLOR_GREEN, "+")); + ut_assertok(video_osd_print(dev, 19, 0, COLOR_GREEN, "+")); + ut_assertok(video_osd_print(dev, 19, 4, COLOR_GREEN, "+")); + ut_assertok(video_osd_print(dev, 0, 4, COLOR_GREEN, "+")); + + /* Add menu caption and entries */ + ut_assertok(video_osd_print(dev, 5, 0, COLOR_GREEN, " OSD menu ")); + ut_assertok(video_osd_print(dev, 2, 1, COLOR_BLUE, " * Entry 1")); + ut_assertok(video_osd_print(dev, 2, 2, COLOR_BLUE, "(*) Entry 2")); + ut_assertok(video_osd_print(dev, 2, 3, COLOR_BLUE, " * Entry 3")); + + ut_assertok(video_osd_get_mem(dev, mem, memsize)); + split(mem, memsize / 2, text, colors); + + print_mem(mem, 20, 5); + + ut_assertok(memcmp(text, "+---- OSD menu ----+" + "| * Entry 1 |" + "| (*) Entry 2 |" + "| * Entry 3 |" + "+------------------+", memsize / 2)); + + ut_assertok(memcmp(colors, "gggggggggggggggggggg" + "gkbbbbbbbbbbbkkkkkkg" + "gkbbbbbbbbbbbkkkkkkg" + "gkbbbbbbbbbbbkkkkkkg" + "gggggggggggggggggggg", memsize / 2)); + + return 0; +} +DM_TEST(dm_test_osd_extended, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); -- 2.11.0
Hi Mario,
v1 -> v2: New in v2
This looks good. But you can't add a new get_mem() operation just for sandbox.
Instead, how about a back-door function that allows sandbox to get its information. You can call it sandbox_video_osd_get_mem(), for example, and just directly call it from you test code and implement it in your driver.
There are some functions like this in arch/sandbox/include/asm/test.h
Hi Simon,
Hi Mario,
v1 -> v2: New in v2
OK, I will do that for v3.
Best regards, Mario
Especially for commands, it is useful to be able to turn a hexadecimal string into its binary representation.
Hence, import the hex_to_bin, bin2hex, and hex2bin functions from the Linux kernel.
v1 -> v2: New in v2
--- include/linux/kernel.h | 4 + lib/Makefile | 1 + lib/hexdump.c | 321 +++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 326 insertions(+) create mode 100644 lib/hexdump.c
diff --git a/include/linux/kernel.h b/include/linux/kernel.h index 04a09eb4f64..ea31759667c 100644 --- a/include/linux/kernel.h +++ b/include/linux/kernel.h @@ -150,6 +150,10 @@ (__x < 0) ? -__x : __x; \ })
+extern int hex_to_bin(char ch); +extern int __must_check hex2bin(u8 *dst, const char *src, size_t count); +extern char *bin2hex(char *dst, const void *src, size_t count); + /* * min()/max()/clamp() macros that also do * strict type-checking.. See the diff --git a/lib/Makefile b/lib/Makefile index d531ea54b31..0f6d744579f 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -29,6 +29,7 @@ obj-$(CONFIG_FIT) += fdtdec_common.o obj-$(CONFIG_TEST_FDTDEC) += fdtdec_test.o obj-$(CONFIG_GZIP_COMPRESSED) += gzip.o obj-$(CONFIG_GENERATE_SMBIOS_TABLE) += smbios.o +obj-y += hexdump.o obj-y += initcall.o obj-$(CONFIG_LMB) += lmb.o obj-y += ldiv.o diff --git a/lib/hexdump.c b/lib/hexdump.c new file mode 100644 index 00000000000..81587c2ee75 --- /dev/null +++ b/lib/hexdump.c @@ -0,0 +1,321 @@ +/* + * lib/hexdump.c + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. See README and COPYING for + * more details. + */ + +#include <linux/compat.h> +#include <linux/types.h> +#include <linux/ctype.h> +#include <linux/errno.h> +#include <linux/kernel.h> +#include <linux/log2.h> +#include <asm/unaligned.h> +#include <vsprintf.h> + +const char hex_asc[] = "0123456789abcdef"; +EXPORT_SYMBOL(hex_asc); +const char hex_asc_upper[] = "0123456789ABCDEF"; +EXPORT_SYMBOL(hex_asc_upper); + +#define hex_asc_lo(x) hex_asc[((x) & 0x0f)] +#define hex_asc_hi(x) hex_asc[((x) & 0xf0) >> 4] + +static inline char *hex_byte_pack(char *buf, u8 byte) +{ + *buf++ = hex_asc_hi(byte); + *buf++ = hex_asc_lo(byte); + return buf; +} + +extern const char hex_asc_upper[]; +#define hex_asc_upper_lo(x) hex_asc_upper[((x) & 0x0f)] +#define hex_asc_upper_hi(x) hex_asc_upper[((x) & 0xf0) >> 4] + +static inline char *hex_byte_pack_upper(char *buf, u8 byte) +{ + *buf++ = hex_asc_upper_hi(byte); + *buf++ = hex_asc_upper_lo(byte); + return buf; +} + +/** + * hex_to_bin - convert a hex digit to its real value + * @ch: ascii character represents hex digit + * + * hex_to_bin() converts one hex digit to its actual value or -1 in case of bad + * input. + */ +int hex_to_bin(char ch) +{ + if ((ch >= '0') && (ch <= '9')) + return ch - '0'; + ch = tolower(ch); + if ((ch >= 'a') && (ch <= 'f')) + return ch - 'a' + 10; + return -1; +} +EXPORT_SYMBOL(hex_to_bin); + +/** + * hex2bin - convert an ascii hexadecimal string to its binary representation + * @dst: binary result + * @src: ascii hexadecimal string + * @count: result length + * + * Return 0 on success, -EINVAL in case of bad input. + */ +int hex2bin(u8 *dst, const char *src, size_t count) +{ + while (count--) { + int hi = hex_to_bin(*src++); + int lo = hex_to_bin(*src++); + + if ((hi < 0) || (lo < 0)) + return -EINVAL; + + *dst++ = (hi << 4) | lo; + } + return 0; +} +EXPORT_SYMBOL(hex2bin); + +/** + * bin2hex - convert binary data to an ascii hexadecimal string + * @dst: ascii hexadecimal result + * @src: binary data + * @count: binary data length + */ +char *bin2hex(char *dst, const void *src, size_t count) +{ + const unsigned char *_src = src; + + while (count--) + dst = hex_byte_pack(dst, *_src++); + return dst; +} +EXPORT_SYMBOL(bin2hex); + +/** + * hex_dump_to_buffer - convert a blob of data to "hex ASCII" in memory + * @buf: data blob to dump + * @len: number of bytes in the @buf + * @rowsize: number of bytes to print per line; must be 16 or 32 + * @groupsize: number of bytes to print at a time (1, 2, 4, 8; default = 1) + * @linebuf: where to put the converted data + * @linebuflen: total size of @linebuf, including space for terminating NUL + * @ascii: include ASCII after the hex output + * + * hex_dump_to_buffer() works on one "line" of output at a time, i.e., + * 16 or 32 bytes of input data converted to hex + ASCII output. + * + * Given a buffer of u8 data, hex_dump_to_buffer() converts the input data + * to a hex + ASCII dump at the supplied memory location. + * The converted output is always NUL-terminated. + * + * E.g.: + * hex_dump_to_buffer(frame->data, frame->len, 16, 1, + * linebuf, sizeof(linebuf), true); + * + * example output buffer: + * 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f @ABCDEFGHIJKLMNO + * + * Return: + * The amount of bytes placed in the buffer without terminating NUL. If the + * output was truncated, then the return value is the number of bytes + * (excluding the terminating NUL) which would have been written to the final + * string if enough space had been available. + */ +int hex_dump_to_buffer(const void *buf, size_t len, int rowsize, int groupsize, + char *linebuf, size_t linebuflen, bool ascii) +{ + const u8 *ptr = buf; + int ngroups; + u8 ch; + int j, lx = 0; + int ascii_column; + int ret; + + if (rowsize != 16 && rowsize != 32) + rowsize = 16; + + if (len > rowsize) /* limit to one line at a time */ + len = rowsize; + if (!is_power_of_2(groupsize) || groupsize > 8) + groupsize = 1; + if ((len % groupsize) != 0) /* no mixed size output */ + groupsize = 1; + + ngroups = len / groupsize; + ascii_column = rowsize * 2 + rowsize / groupsize + 1; + + if (!linebuflen) + goto overflow1; + + if (!len) + goto nil; + + if (groupsize == 8) { + const u64 *ptr8 = buf; + + for (j = 0; j < ngroups; j++) { + ret = snprintf(linebuf + lx, linebuflen - lx, + "%s%16.16llx", j ? " " : "", + get_unaligned(ptr8 + j)); + if (ret >= linebuflen - lx) + goto overflow1; + lx += ret; + } + } else if (groupsize == 4) { + const u32 *ptr4 = buf; + + for (j = 0; j < ngroups; j++) { + ret = snprintf(linebuf + lx, linebuflen - lx, + "%s%8.8x", j ? " " : "", + get_unaligned(ptr4 + j)); + if (ret >= linebuflen - lx) + goto overflow1; + lx += ret; + } + } else if (groupsize == 2) { + const u16 *ptr2 = buf; + + for (j = 0; j < ngroups; j++) { + ret = snprintf(linebuf + lx, linebuflen - lx, + "%s%4.4x", j ? " " : "", + get_unaligned(ptr2 + j)); + if (ret >= linebuflen - lx) + goto overflow1; + lx += ret; + } + } else { + for (j = 0; j < len; j++) { + if (linebuflen < lx + 2) + goto overflow2; + ch = ptr[j]; + linebuf[lx++] = hex_asc_hi(ch); + if (linebuflen < lx + 2) + goto overflow2; + linebuf[lx++] = hex_asc_lo(ch); + if (linebuflen < lx + 2) + goto overflow2; + linebuf[lx++] = ' '; + } + if (j) + lx--; + } + if (!ascii) + goto nil; + + while (lx < ascii_column) { + if (linebuflen < lx + 2) + goto overflow2; + linebuf[lx++] = ' '; + } + for (j = 0; j < len; j++) { + if (linebuflen < lx + 2) + goto overflow2; + ch = ptr[j]; + linebuf[lx++] = (isascii(ch) && isprint(ch)) ? ch : '.'; + } +nil: + linebuf[lx] = '\0'; + return lx; +overflow2: + linebuf[lx++] = '\0'; +overflow1: + return ascii ? ascii_column + len : (groupsize * 2 + 1) * ngroups - 1; +} +EXPORT_SYMBOL(hex_dump_to_buffer); + +#ifdef CONFIG_PRINTK +/** + * print_hex_dump - print a text hex dump to syslog for a binary blob of data + * @level: kernel log level (e.g. KERN_DEBUG) + * @prefix_str: string to prefix each line with; + * caller supplies trailing spaces for alignment if desired + * @prefix_type: controls whether prefix of an offset, address, or none + * is printed (%DUMP_PREFIX_OFFSET, %DUMP_PREFIX_ADDRESS, %DUMP_PREFIX_NONE) + * @rowsize: number of bytes to print per line; must be 16 or 32 + * @groupsize: number of bytes to print at a time (1, 2, 4, 8; default = 1) + * @buf: data blob to dump + * @len: number of bytes in the @buf + * @ascii: include ASCII after the hex output + * + * Given a buffer of u8 data, print_hex_dump() prints a hex + ASCII dump + * to the kernel log at the specified kernel log level, with an optional + * leading prefix. + * + * print_hex_dump() works on one "line" of output at a time, i.e., + * 16 or 32 bytes of input data converted to hex + ASCII output. + * print_hex_dump() iterates over the entire input @buf, breaking it into + * "line size" chunks to format and print. + * + * E.g.: + * print_hex_dump(KERN_DEBUG, "raw data: ", DUMP_PREFIX_ADDRESS, + * 16, 1, frame->data, frame->len, true); + * + * Example output using %DUMP_PREFIX_OFFSET and 1-byte mode: + * 0009ab42: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f @ABCDEFGHIJKLMNO + * Example output using %DUMP_PREFIX_ADDRESS and 4-byte mode: + * ffffffff88089af0: 73727170 77767574 7b7a7978 7f7e7d7c pqrstuvwxyz{|}~. + */ +void print_hex_dump(const char *level, const char *prefix_str, int prefix_type, + int rowsize, int groupsize, + const void *buf, size_t len, bool ascii) +{ + const u8 *ptr = buf; + int i, linelen, remaining = len; + unsigned char linebuf[32 * 3 + 2 + 32 + 1]; + + if (rowsize != 16 && rowsize != 32) + rowsize = 16; + + for (i = 0; i < len; i += rowsize) { + linelen = min(remaining, rowsize); + remaining -= rowsize; + + hex_dump_to_buffer(ptr + i, linelen, rowsize, groupsize, + linebuf, sizeof(linebuf), ascii); + + switch (prefix_type) { + case DUMP_PREFIX_ADDRESS: + printk("%s%s%p: %s\n", + level, prefix_str, ptr + i, linebuf); + break; + case DUMP_PREFIX_OFFSET: + printk("%s%s%.8x: %s\n", level, prefix_str, i, linebuf); + break; + default: + printk("%s%s%s\n", level, prefix_str, linebuf); + break; + } + } +} +EXPORT_SYMBOL(print_hex_dump); + +#if !defined(CONFIG_DYNAMIC_DEBUG) +/** + * print_hex_dump_bytes - shorthand form of print_hex_dump() with default params + * @prefix_str: string to prefix each line with; + * caller supplies trailing spaces for alignment if desired + * @prefix_type: controls whether prefix of an offset, address, or none + * is printed (%DUMP_PREFIX_OFFSET, %DUMP_PREFIX_ADDRESS, %DUMP_PREFIX_NONE) + * @buf: data blob to dump + * @len: number of bytes in the @buf + * + * Calls print_hex_dump(), with log level of KERN_DEBUG, + * rowsize of 16, groupsize of 1, and ASCII output included. + */ +void print_hex_dump_bytes(const char *prefix_str, int prefix_type, + const void *buf, size_t len) +{ + print_hex_dump(KERN_DEBUG, prefix_str, prefix_type, 16, 1, + buf, len, true); +} +EXPORT_SYMBOL(print_hex_dump_bytes); +#endif /* !defined(CONFIG_DYNAMIC_DEBUG) */ +#endif /* defined(CONFIG_PRINTK) */ -- 2.11.0
Hi Mario,
v1 -> v2: New in v2
Does Linux have any tests for this code?
Hi Simon,
Hi Mario,
v1 -> v2: New in v2
No, there are no tests for this. I'll write some for v3, then.
Best regards, Mario
Hi Mario,
v1 -> v2: New in v2
Something is missing?
Note there was a similar discussion some time ago here: https://patchwork.ozlabs.org/patch/633733/, might worth checking.
If of any interest you may pick up my earlier patch and do fix-ups mentioned by Tom: 1. Move hexdump.h away from common.h 2. Update existing users of print_hex_dump() in U-Boot such that they don't use debug level (i.e. drop the first argument)
Or I may do the same re-spin sometime soon.
Still read-on for a couple of comments for your patch.
[snip]
- min()/max()/clamp() macros that also do
- strict type-checking.. See the
U-Boot might be used on targets with limited memory so having ability to include hexdump or not might be beneficial here. Especially in production builds why would you need hexdump?
[snip]
Why PRINTK in U-Boot? It's purely kernel's thing.
Ditto, CONFIG_DYNAMIC_DEBUG has nothing to do with U-Boot.
-Alexey
Hi Alexey,
On Mon, Jun 4, 2018 at 6:05 PM, Alexey Brodkin Alexey.Brodkin@synopsys.com wrote:
Hi Mario,
v1 -> v2: New in v2
- Move hexdump.h away from common.h
- Update existing users of print_hex_dump() in U-Boot such that they don't use debug level (i.e. drop the first argument)
Thanks for your feedback! I saw that you posted a re-spin of your patch; Thank you, that's very helpful.
[snip]
Yes, it's probably better to have it deactivatable, true. But as for why production builds need hexdump: It's not so much the hexdump function, but the bin2hex function, which can be used in a number of U-Boot commands that read hexadecimal data. We use one such command to initialize a TPM on one of our boards, for example.
[snip]
Those were copied verbatim from the kernel, I'm pretty sure I just got them by mistake.
-Alexey
Best regards, Mario
On Wed, 2018-06-13 at 10:24 +0200, Mario Six wrote:
Hi Alexey,
Hi Mario,
v1 -> v2: New in v2
Note there was a similar discussion some time ago here: https://urldefense.proofpoint.com/v2/url?u=https-3A__patchwork.ozlabs.org_pa... XO7breS55ytWkhpk5R81I&m=mnw00As1T_NpnFNncTURuK4YkIAYD-Dj-VTNkRqquVY&s=HcgjkTO1GdtGqH9sYIjizH30AC3m_Xfa1F6n_Cy_qZY&e=, might worth checking.
FWIW Tom just pulled that in, see http://git.denx.de/?p=u-boot.git;a=commit;h=f8c987f8f127f867d96ca74bcd1fcb11...
[snip]
I spoke a bit too soon as I forgot what I did before :) We don't disable building of entire hexdump.o instead in hexdump.c we just put some code in #ifdefs that way you may move bin2hex() outside #ifdef.
-Alexey
Add command to query information from and write text to on-screen display (OSD) devices.
v1 -> v2: * Added explanation for what a OSD is * Added explanation of the color parameter * Moved GDSYS_LEGACY_OSD_CMDS to gdsys Kconfig
--- board/gdsys/mpc8308/Kconfig | 11 ++ cmd/Kconfig | 8 + cmd/Makefile | 1 + cmd/osd.c | 378 ++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 398 insertions(+) create mode 100644 cmd/osd.c
diff --git a/board/gdsys/mpc8308/Kconfig b/board/gdsys/mpc8308/Kconfig index cb29c25c650..9d99f686923 100644 --- a/board/gdsys/mpc8308/Kconfig +++ b/board/gdsys/mpc8308/Kconfig @@ -1,3 +1,9 @@ +config GDSYS_LEGACY_OSD_CMDS + bool + help + Use the 'osdw', 'osdp', and 'osdsize' legacy commands required by + gdsys devices. + if TARGET_HRCON
config SYS_BOARD @@ -9,6 +15,9 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "hrcon"
+config GDSYS_LEGACY_OSD_CMDS + default y + endif
if TARGET_STRIDER @@ -22,6 +31,8 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "strider"
+config GDSYS_LEGACY_OSD_CMDS + default y endif
config CMD_IOLOOP diff --git a/cmd/Kconfig b/cmd/Kconfig index 38406fcfdac..898839c8d75 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -865,6 +865,14 @@ config CMD_ONENAND and erasing blocks. It allso provides a way to show and change bad blocks, and test the device.
+config CMD_OSD + bool "osd" + help + Enable the 'osd' command which allows to query information from and + write text data to a on-screen display (OSD) device; a virtual device + associated with a display capable of displaying a text overlay on the + display it's associated with.. + config CMD_PART bool "part" select PARTITION_UUIDS diff --git a/cmd/Makefile b/cmd/Makefile index 0d7322ee0a4..4aeab8e5c77 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -62,6 +62,7 @@ obj-$(CONFIG_CMD_FUSE) += fuse.o obj-$(CONFIG_CMD_GETTIME) += gettime.o obj-$(CONFIG_CMD_GPIO) += gpio.o obj-$(CONFIG_CMD_HVC) += smccc.o +obj-$(CONFIG_CMD_OSD) += osd.o obj-$(CONFIG_CMD_I2C) += i2c.o obj-$(CONFIG_CMD_IOTRACE) += iotrace.o obj-$(CONFIG_CMD_HASH) += hash.o diff --git a/cmd/osd.c b/cmd/osd.c new file mode 100644 index 00000000000..8afbe85475b --- /dev/null +++ b/cmd/osd.c @@ -0,0 +1,378 @@ +/* + * (C) Copyright 2017 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + * + * based on the gdsys osd driver, which is + * + * (C) Copyright 2010 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <video_osd.h> +#include <malloc.h> + +#ifndef CONFIG_GDSYS_LEGACY_OSD_CMDS +static struct udevice *osd_cur; +#endif + +#ifdef CONFIG_GDSYS_LEGACY_OSD_CMDS +int do_osd_write(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + struct udevice *dev; + uint x, y; + uint count; + char *hexstr; + u8 *buffer; + size_t buflen; + + if (argc < 4 || (strlen(argv[3])) % 2) { + cmd_usage(cmdtp); + return CMD_RET_FAILURE; + } + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + hexstr = argv[3]; + count = (argc > 4) ? simple_strtoul(argv[4], NULL, 16) : 1; + + buflen = strlen(hexstr) / 2; + buffer = malloc(buflen); + hex2bin(buffer, hexstr, buflen); + + for (uclass_first_device(UCLASS_VIDEO_OSD, &dev); + dev; + uclass_next_device(&dev)) { + int res; + + res = video_osd_set_mem(dev, x, y, buffer, buflen, count); + + if (res) { + printf("Could not write to video mem on osd %s\n", + dev->name); + return CMD_RET_FAILURE; + } + } + + free(buffer); + + return CMD_RET_SUCCESS; +} + +static int do_osd_print(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + struct udevice *dev; + uint x, y; + u8 color; + char *text; + + if (argc < 5) { + cmd_usage(cmdtp); + return CMD_RET_FAILURE; + } + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + color = simple_strtoul(argv[3], NULL, 16); + text = argv[4]; + + for (uclass_first_device(UCLASS_VIDEO_OSD, &dev); + dev; + uclass_next_device(&dev)) { + int res; + + res = video_osd_print(dev, x, y, color, text); + if (res) { + printf("Could not print string to osd %s\n", dev->name); + return CMD_RET_FAILURE; + } + } + + return CMD_RET_SUCCESS; +} + +int do_osd_size(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + struct udevice *dev; + uint x, y; + + if (argc < 3) { + cmd_usage(cmdtp); + return CMD_RET_FAILURE; + } + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + + for (uclass_first_device(UCLASS_VIDEO_OSD, &dev); + dev; + uclass_next_device(&dev)) { + int res; + res = video_osd_set_size(dev, x, y); + + if (res) { + printf("Could not set size on osd %s\n", dev->name); + return CMD_RET_FAILURE; + } + } + + return CMD_RET_SUCCESS; +} +#else +int do_osd_write(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + uint x, y; + uint count; + char *hexstr; + u8 *buffer; + size_t buflen; + int res; + + if (argc < 4 || (strlen(argv[3]) % 2)) { + cmd_usage(cmdtp); + return CMD_RET_FAILURE; + } + + if (!osd_cur) { + puts("No osd selected\n"); + return CMD_RET_FAILURE; + } + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + hexstr = argv[3]; + count = (argc > 4) ? simple_strtoul(argv[4], NULL, 16) : 1; + + buflen = strlen(hexstr) / 2; + buffer = malloc(buflen); + hex2bin(buffer, hexstr, buflen); + + res = video_osd_set_mem(osd_cur, x, y, buffer, buflen, count); + + if (res) { + printf("Could not write to video mem on osd %s\n", + osd_cur->name); + return CMD_RET_FAILURE; + } + + free(buffer); + + return CMD_RET_SUCCESS; +} + +int do_osd_print(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + uint x, y; + u8 color; + char *text; + int res; + + if (argc < 5) { + cmd_usage(cmdtp); + return CMD_RET_FAILURE; + } + + if (!osd_cur) { + puts("No osd selected\n"); + return CMD_RET_FAILURE; + } + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + color = simple_strtoul(argv[3], NULL, 16); + text = argv[4]; + + res = video_osd_print(osd_cur, x, y, color, text); + if (res) { + printf("Could not print string to osd %s\n", osd_cur->name); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +int do_osd_size(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + uint x, y; + int res; + + if (argc < 3) { + cmd_usage(cmdtp); + return CMD_RET_FAILURE; + } + + if (!osd_cur) { + puts("No osd selected\n"); + return CMD_RET_FAILURE; + } + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + + res = video_osd_set_size(osd_cur, x, y); + if (res) { + printf("Could not set size on osd %s\n", osd_cur->name); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +static void show_osd(struct udevice *osd) +{ + printf("OSD %d:\t%s", osd->req_seq, osd->name); + if (device_active(osd)) + printf(" (active %d)", osd->seq); + printf("\n"); +} + +static int do_show_osd(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + struct udevice *osd; + + if (argc == 1) { + /* show all OSDs */ + struct uclass *uc; + int ret; + + ret = uclass_get(UCLASS_VIDEO_OSD, &uc); + if (ret) + return CMD_RET_FAILURE; + uclass_foreach_dev(osd, uc) + show_osd(osd); + } else { + int i, ret; + + /* show specific OSD */ + i = simple_strtoul(argv[1], NULL, 10); + + ret = uclass_get_device_by_seq(UCLASS_VIDEO_OSD, i, &osd); + if (ret) { + printf("Invalid osd %d: err=%d\n", i, ret); + return CMD_RET_FAILURE; + } + show_osd(osd); + } + + return CMD_RET_SUCCESS; +} + +static int cmd_osd_set_osd_num(unsigned int osdnum) +{ + struct udevice *osd; + int ret; + + ret = uclass_get_device_by_seq(UCLASS_VIDEO_OSD, osdnum, &osd); + if (ret) { + printf("%s: No OSD %d\n", __func__, osdnum); + return ret; + } + osd_cur = osd; + + return 0; +} + +static int osd_get_osd_cur(struct udevice **osdp) +{ + if (!osd_cur) { + puts("No osd selected\n"); + return -ENODEV; + } + *osdp = osd_cur; + + return 0; +} + +static int do_osd_num(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + int ret = 0; + int osd_no; + + if (argc == 1) { + /* querying current setting */ + struct udevice *osd; + + if (!osd_get_osd_cur(&osd)) + osd_no = osd->seq; + else + osd_no = -1; + printf("Current osd is %d\n", osd_no); + } else { + osd_no = simple_strtoul(argv[1], NULL, 10); + printf("Setting osd to %d\n", osd_no); + + ret = cmd_osd_set_osd_num(osd_no); + + if (ret) + printf("Failure changing osd number (%d)\n", ret); + } + + return ret ? CMD_RET_FAILURE : CMD_RET_SUCCESS; +} + +static cmd_tbl_t cmd_osd_sub[] = { + U_BOOT_CMD_MKENT(show, 1, 1, do_show_osd, "", ""), + U_BOOT_CMD_MKENT(dev, 1, 1, do_osd_num, "", ""), + U_BOOT_CMD_MKENT(write, 4, 1, do_osd_write, "", ""), + U_BOOT_CMD_MKENT(print, 4, 1, do_osd_print, "", ""), + U_BOOT_CMD_MKENT(size, 2, 1, do_osd_size, "", ""), +}; + +static int do_osd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + cmd_tbl_t *c; + + if (argc < 2) + return CMD_RET_USAGE; + + /* Strip off leading 'osd' command argument */ + argc--; + argv++; + + c = find_cmd_tbl(argv[0], &cmd_osd_sub[0], ARRAY_SIZE(cmd_osd_sub)); + + if (c) + return c->cmd(cmdtp, flag, argc, argv); + else + return CMD_RET_USAGE; +} +#endif + +#ifdef CONFIG_GDSYS_LEGACY_OSD_CMDS +U_BOOT_CMD( + osdw, 5, 0, do_osd_write, + "write 16-bit hex encoded buffer to osd memory", + "osdw [pos_x] [pos_y] [buffer] [count] - write 8-bit hex encoded buffer to osd memory\n" +); + +U_BOOT_CMD( + osdp, 5, 0, do_osd_print, + "write ASCII buffer to osd memory", + "osdp [pos_x] [pos_y] [color] [text] - write ASCII buffer to osd memory\n" +); + +U_BOOT_CMD( + osdsize, 3, 0, do_osd_size, + "set OSD XY size in characters", + "osdsize [size_x] [size_y] - set OSD XY size in characters\n" +); +#else +static char osd_help_text[] = + "show - show OSD info\n" + "osd dev [dev] - show or set current OSD\n" + "write [pos_x] [pos_y] [buffer] [count] - write 8-bit hex encoded buffer to osd memory at a given position\n" + "print [pos_x] [pos_y] [color] [text] - write ASCII buffer (given by text data and driver-specific color information) to osd memory\n" + "size [size_x] [size_y] - set OSD XY size in characters\n"; + +U_BOOT_CMD( + osd, 6, 1, do_osd, + "OSD sub-system", + osd_help_text +); +#endif -- 2.11.0
Hi Mario,
Signed-off-by: Mario Six mario.six@gdsys.cc
v1 -> v2:
- Added explanation for what a OSD is
- Added explanation of the color parameter
- Moved GDSYS_LEGACY_OSD_CMDS to gdsys Kconfig
To me it seems unfortunate that the legacy and new commands are named the same. I suppose that is unavoidable?
I wonder if the legacy code could be moved to board/gdsys instead? It is out of the way then.
Hi Simon,
Hi Mario,
v1 -> v2:
Sounds like a good idea. I'll separate the commands for v3.
Best regards, Mario
Some devices offer a text-based OSD (on-screen display) that can be programmatically controlled (i.e. text displayed on).
Add a uclass to support such devices.
v1 -> v2:
- Use singular case for UCLASS_VIDEO_OSD description
- Expanded description of video_osd_set_mem with example
- Replaced all left-over mentions of pixels with text
- Expaneded description of color parameter
- Added general description of the OSD uclass
- Expanded description of video_osd_info
drivers/video/Kconfig | 8 ++ drivers/video/Makefile | 2 + drivers/video/video_osd-uclass.c | 46 ++++++++++ include/dm/uclass-id.h | 1 + include/video_osd.h | 193 +++++++++++++++++++++++++++++++++++++++ 5 files changed, 250 insertions(+) create mode 100644 drivers/video/video_osd-uclass.c create mode 100644 include/video_osd.h
Why drop the 'u' on 'colour'?
Hi Simon,
v1 -> v2:
# git grep color | wc -l 794
# git grep colour | wc -l 191
Best regards, Mario
Alexey Brodkin
Mario Six
