[U-Boot] [PATCH 0/8] arm: socfpga: Move to using distro boot
This series adds support to the common socfpga header for distro boot and moves the DE0/1, Socrates, C5/A5 SoCDK, and SoCKIT kits to use the common environment.
Where available, the default devicetree is set to the devicetree for the board available in the kernel source. If none is available in the kernel source, the devicetree is set to the name previously used in the board header file.
Dalon Westergreen (8): arm: socfpga: Add distro boot to socfpga common header arm: socfpga: DE0 use environment in common header arm: socfpga: A5 SoCDK use environment in common header arm: socfpga: C5 SoCDK use environment in common header arm: socfpga: DE1 use environment in common header arm: socfpga: SoCKit use environment in common header arm: socfpga: Socrates use environment in common header arm: socfpga: sr1500 use environment in common header
configs/socfpga_arria5_defconfig | 3 ++ configs/socfpga_cyclone5_defconfig | 3 ++ configs/socfpga_de0_nano_soc_defconfig | 3 ++ configs/socfpga_de1_soc_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + include/configs/socfpga_arria5_socdk.h | 31 ------------------ include/configs/socfpga_common.h | 55 +++++++++++++++++++++++++++++--- include/configs/socfpga_cyclone5_socdk.h | 31 ------------------ include/configs/socfpga_de0_nano_soc.h | 19 ----------- include/configs/socfpga_de1_soc.h | 19 ----------- include/configs/socfpga_sockit.h | 27 ---------------- include/configs/socfpga_socrates.h | 25 --------------- include/configs/socfpga_sr1500.h | 27 ---------------- 15 files changed, 64 insertions(+), 183 deletions(-)
This adds a common environment and support for distro boot in the common socfpga header.
Signed-off-by: Dalon Westergreen dwesterg@gmail.com --- include/configs/socfpga_common.h | 55 +++++++++++++++++++++++++++++++++++++--- 1 file changed, 51 insertions(+), 4 deletions(-)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 582b04a..2b8be8f 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -67,6 +67,9 @@ #define CONFIG_SYS_HOSTNAME CONFIG_SYS_BOARD #endif
+#define CONFIG_CMD_PXE +#define CONFIG_MENU + /* * Cache */ @@ -245,13 +248,13 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * U-Boot environment */ #if !defined(CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_SIZE (8*1024) #endif
/* Environment for SDMMC boot */ #if defined(CONFIG_ENV_IS_IN_MMC) && !defined(CONFIG_ENV_OFFSET) -#define CONFIG_SYS_MMC_ENV_DEV 0 /* device 0 */ -#define CONFIG_ENV_OFFSET 512 /* just after the MBR */ +#define CONFIG_SYS_MMC_ENV_DEV 0 /* device 0 */ +#define CONFIG_ENV_OFFSET (34*512)/* just after the GPT */ #endif
/* Environment for QSPI boot */ @@ -308,8 +311,12 @@ unsigned int cm_get_qspi_controller_clk_hz(void); /* SPL SDMMC boot support */ #ifdef CONFIG_SPL_MMC_SUPPORT #if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) -#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 2 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#endif +#else +#ifndef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION 1 #endif #endif
@@ -331,4 +338,44 @@ unsigned int cm_get_qspi_controller_clk_hz(void); */ #define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR
+/* Extra Environment */ +#ifndef CONFIG_SPL_BUILD +#include <config_distro_defaults.h> + +#ifdef CONFIG_CMD_PXE +#define BOOT_TARGET_DEVICES_PXE(func) func(PXE, pxe, na) +#else +#define BOOT_TARGET_DEVICES_PXE(func) +#endif + +#ifdef CONFIG_CMD_MMC +#define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0) +#else +#define BOOT_TARGET_DEVICES_MMC(func) +#endif + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_DEVICES_MMC(func) \ + BOOT_TARGET_DEVICES_PXE(func) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + +#ifndef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "verify=n\0" \ + "bootimage=" CONFIG_BOOTFILE "\0" \ + "fdt_addr=100\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "bootm_size=0xa000000\0" \ + "kernel_addr_r="__stringify(CONFIG_SYS_LOAD_ADDR)"\0" \ + "fdt_addr_r=0x02000000\0" \ + "scriptaddr=0x02100000\0" \ + "pxefile_addr_r=0x02200000\0" \ + "ramdisk_addr_r=0x02300000\0" \ + BOOTENV + +#endif +#endif + #endif /* __CONFIG_SOCFPGA_COMMON_H__ */
- Cache
- U-Boot environment
Space around the asterisk . Btw this probably broke some existing configurations ...
#endif
- BOOT_TARGET_DEVICES_MMC(func) \
- BOOT_TARGET_DEVICES_PXE(func) \
- func(DHCP, dhcp, na)
- "verify=n\0" \
Is this needed ?
- "bootimage=" CONFIG_BOOTFILE "\0" \
- "fdt_addr=100\0" \
Move this to like 0x200000 at least.
- "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \
- "bootm_size=0xa000000\0" \
- "kernel_addr_r="__stringify(CONFIG_SYS_LOAD_ADDR)"\0" \
- "fdt_addr_r=0x02000000\0" \
Hmmmm , what's the relationship between this and fdt_addr ?
- "scriptaddr=0x02100000\0" \
- "pxefile_addr_r=0x02200000\0" \
- "ramdisk_addr_r=0x02300000\0" \
- BOOTENV
+#endif +#endif
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 582b04a..2b8be8f 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -67,6 +67,9 @@ #define CONFIG_SYS_HOSTNAME CONFIG_SYS_BOARD #endif +#define CONFIG_CMD_PXE +#define CONFIG_MENU
/* * Cache */ @@ -245,13 +248,13 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * U-Boot environment */ #if !defined(CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_SIZE (8*1024) #endif /* Environment for SDMMC boot */ #if defined(CONFIG_ENV_IS_IN_MMC) && !defined(CONFIG_ENV_OFFSET) -#define CONFIG_SYS_MMC_ENV_DEV 0 /* device 0 */ -#define CONFIG_ENV_OFFSET 512 /* just after the MBR */ +#define CONFIG_SYS_MMC_ENV_DEV 0 /* device 0 */ +#define CONFIG_ENV_OFFSET (34*512)/* just after the GPT */
It may, but it is unavoidable as the env needs to be larger for distro boot.
#endif /* Environment for QSPI boot */ @@ -308,8 +311,12 @@ unsigned int cm_get_qspi_controller_clk_hz(void); /* SPL SDMMC boot support */ #ifdef CONFIG_SPL_MMC_SUPPORT #if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) -#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 2 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#endif +#else +#ifndef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION 1 #endif #endif @@ -331,4 +338,44 @@ unsigned int cm_get_qspi_controller_clk_hz(void); */ #define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR +/* Extra Environment */ +#ifndef CONFIG_SPL_BUILD +#include <config_distro_defaults.h>
- "verify=n\0" \
Is this needed ?
No
I think i will just remove it too, i dont believe it us used for distro boot.
unrelated, as before i think it better just to remove fdt_addr
- BOOTENV
+#endif +#endif
Thanks, Dalon
- Cache
I'm really not impressed ... sigh.
#endif
- "verify=n\0" \
Is this needed ?
No
OK
Good
- BOOTENV
+#endif +#endif
Thanks, Dalon
I actually dont believe this will cause much of an issue. the env is placed immediately after the partition table. I know this size fits between the table and the typical location of the first partition without issue.
--dalon
- "verify=n\0" \
Is this needed ?
No
OK
Good
- BOOTENV
+#endif +#endif
Thanks, Dalon
- Cache
My rant is more about breaking already running setups, but let's see if someone actually complains.
Hi!
Hmm. It is not immediately after partition table (==MBR), it is at sector 34. Now, by changing size you already break the setups, so moving it back to sector 1 does not help much, but can you explain?
Pavel
On Sun, 2017-02-19 at 20:45 +0100, Pavel Machek wrote:
Hi!
Sorry, you are right. Frank had moved it after the GPT in his patchset and i had just copied that. i will update this to be immediately after the mbr as it was before.
--dalon
Pavel
This removes the default environment from the de0 headers and instead uses the common environment provided in socfpga_common.h which now uses distro boot.
In addition to the above, add support to boot from the custom a2 type partition
Signed-off-by: Dalon Westergreen dwesterg@gmail.com --- configs/socfpga_de0_nano_soc_defconfig | 3 +++ include/configs/socfpga_de0_nano_soc.h | 19 ------------------- 2 files changed, 3 insertions(+), 19 deletions(-)
diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index af41e1e..b122135 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_TERASIC_DE0_NANO=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de0_nano_soc" +CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_de0_nano_soc.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y @@ -58,3 +59,5 @@ CONFIG_G_DNL_MANUFACTURER="terasic" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USE_TINY_PRINTF=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE=0xa2 \ No newline at end of file diff --git a/include/configs/socfpga_de0_nano_soc.h b/include/configs/socfpga_de0_nano_soc.h index f655972..4b86df7 100644 --- a/include/configs/socfpga_de0_nano_soc.h +++ b/include/configs/socfpga_de0_nano_soc.h @@ -17,8 +17,6 @@
/* Booting Linux */ #define CONFIG_BOOTFILE "fitImage" -#define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) -#define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" #define CONFIG_LOADADDR 0x01000000 #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
@@ -30,23 +28,6 @@
#define CONFIG_ENV_IS_IN_MMC
-/* Extra Environment */ -#define CONFIG_EXTRA_ENV_SETTINGS \ - "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "bootimage=zImage\0" \ - "fdt_addr=100\0" \ - "fdtimage=socfpga.dtb\0" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "mmcroot=/dev/mmcblk0p2\0" \ - "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ - " root=${mmcroot} rw rootwait;" \ - "bootz ${loadaddr} - ${fdt_addr}\0" \ - "mmcload=mmc rescan;" \ - "load mmc 0:1 ${loadaddr} ${bootimage};" \ - "load mmc 0:1 ${fdt_addr} ${fdtimage}\0" \ - /* The rest of the configuration is shared */ #include <configs/socfpga_common.h>
This removes the default environment from the A5 socdk headers and instead uses the common environment provided in socfpga_common.h which now uses distro boot.
Add support to boot from the custom a2 type partition.
Change default devicetree name to match devicetree name in upstream kernel source.
a5 --- configs/socfpga_arria5_defconfig | 3 +++ include/configs/socfpga_arria5_socdk.h | 31 ------------------------------- 2 files changed, 3 insertions(+), 31 deletions(-)
diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 43c51fe..c7d7f93 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_ARRIA5_SOCDK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" +CONFIG_DEFAULT_FDT_FILE="socfpga_arria10_socdk_sdmmc.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y @@ -64,3 +65,5 @@ CONFIG_G_DNL_MANUFACTURER="altera" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USE_TINY_PRINTF=y +ONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE=0xa2 diff --git a/include/configs/socfpga_arria5_socdk.h b/include/configs/socfpga_arria5_socdk.h index 9b1f753..7222505 100644 --- a/include/configs/socfpga_arria5_socdk.h +++ b/include/configs/socfpga_arria5_socdk.h @@ -17,12 +17,6 @@
/* Booting Linux */ #define CONFIG_BOOTFILE "zImage" -#define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) -#ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET -#define CONFIG_BOOTCOMMAND "run ramboot" -#else -#define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" -#endif #define CONFIG_LOADADDR 0x01000000 #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
@@ -34,31 +28,6 @@
-/* Extra Environment */ -#define CONFIG_EXTRA_ENV_SETTINGS \ - "verify=n\0" \ - "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "bootimage=zImage\0" \ - "fdt_addr=100\0" \ - "fdtimage=socfpga.dtb\0" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "mmcroot=/dev/mmcblk0p2\0" \ - "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ - " root=${mmcroot} rw rootwait;" \ - "bootz ${loadaddr} - ${fdt_addr}\0" \ - "mmcload=mmc rescan;" \ - "load mmc 0:1 ${loadaddr} ${bootimage};" \ - "load mmc 0:1 ${fdt_addr} ${fdtimage}\0" \ - "qspiload=sf probe && mtdparts default && run ubiload\0" \ - "qspiboot=setenv bootargs " CONFIG_BOOTARGS \ - " ubi.mtd=1,64 root=ubi0:rootfs rw rootfstype=ubifs;"\ - "bootz ${loadaddr} - ${fdt_addr}\0" \ - "ubiload=ubi part UBI && ubifsmount ubi0 && " \ - "ubifsload ${loadaddr} /boot/${bootimage} && " \ - "ubifsload ${fdt_addr} /boot/${fdtimage}\0" - /* The rest of the configuration is shared */ #include <configs/socfpga_common.h>
a5
^^ What's this ? :)
This is A5 SoCDK , not A10 ;-)
Is this still needed ? ^
@@ -34,31 +28,6 @@
- "verify=n\0" \
This removes the default environment from the C5 SoCDK headers and instead uses the common environment provided in socfpga_common.h which now uses distro boot.
In addition to the above, add support to boot from the custom a2 type partition.
Signed-off-by: Dalon Westergreen dwesterg@gmail.com --- configs/socfpga_cyclone5_defconfig | 3 +++ include/configs/socfpga_cyclone5_socdk.h | 31 ------------------------------- 2 files changed, 3 insertions(+), 31 deletions(-)
diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 8b050b9..c8b8084 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_CYCLONE5_SOCDK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" +CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_socdk.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y @@ -64,3 +65,5 @@ CONFIG_G_DNL_MANUFACTURER="altera" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_USE_TINY_PRINTF=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE=0xa2 diff --git a/include/configs/socfpga_cyclone5_socdk.h b/include/configs/socfpga_cyclone5_socdk.h index 4100ef9..c5dac8f 100644 --- a/include/configs/socfpga_cyclone5_socdk.h +++ b/include/configs/socfpga_cyclone5_socdk.h @@ -17,12 +17,6 @@
@@ -34,31 +28,6 @@
This removes the default environment from the de1 headers and instead uses the common environment provided in socfpga_common.h which now uses distro boot.
This board does not have a devicetree in the upstream kernel source so leave the default devicetree name socfpga.dtb.
Signed-off-by: Dalon Westergreen dwesterg@gmail.com --- configs/socfpga_de1_soc_defconfig | 1 + include/configs/socfpga_de1_soc.h | 19 ------------------- 2 files changed, 1 insertion(+), 19 deletions(-)
diff --git a/configs/socfpga_de1_soc_defconfig b/configs/socfpga_de1_soc_defconfig index 032deef..19ff608 100644 --- a/configs/socfpga_de1_soc_defconfig +++ b/configs/socfpga_de1_soc_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_SOCFPGA_TERASIC_DE1_SOC=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de1_soc" +CONFIG_DEFAULT_FDT_FILE="socfpga.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/include/configs/socfpga_de1_soc.h b/include/configs/socfpga_de1_soc.h index 2278357..2f31d45 100644 --- a/include/configs/socfpga_de1_soc.h +++ b/include/configs/socfpga_de1_soc.h @@ -17,8 +17,6 @@
@@ -30,23 +28,6 @@
-/* Extra Environment */ -#define CONFIG_EXTRA_ENV_SETTINGS \ - "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \ - "bootm ${loadaddr} - ${fdtaddr}\0" \ - "bootimage=zImage\0" \ - "fdtaddr=100\0" \ - "fdtimage=socfpga.dtb\0" \ - "bootm ${loadaddr} - ${fdtaddr}\0" \ - "mmcroot=/dev/mmcblk0p2\0" \ - "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ - " root=${mmcroot} rw rootwait;" \ - "bootz ${loadaddr} - ${fdtaddr}\0" \ - "mmcload=mmc rescan;" \ - "load mmc 0:1 ${loadaddr} ${bootimage};" \ - "load mmc 0:1 ${fdtaddr} ${fdtimage}\0" \ - /* The rest of the configuration is shared */ #include <configs/socfpga_common.h>
This removes the default environment from the SoCKit headers and instead uses the common environment provided in socfpga_common.h which now uses distro boot.
Signed-off-by: Dalon Westergreen dwesterg@gmail.com --- configs/socfpga_sockit_defconfig | 1 + include/configs/socfpga_sockit.h | 27 --------------------------- 2 files changed, 1 insertion(+), 27 deletions(-)
diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index d0c2bda..bf60783 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_TERASIC_SOCKIT=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sockit" +CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_sockit.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/include/configs/socfpga_sockit.h b/include/configs/socfpga_sockit.h index 326310b..4314b34 100644 --- a/include/configs/socfpga_sockit.h +++ b/include/configs/socfpga_sockit.h @@ -17,8 +17,6 @@
@@ -30,31 +28,6 @@
This removes the default environment from the socrates headers and instead uses the common environment provided in socfpga_common.h which now uses distro boot.
Signed-off-by: Dalon Westergreen dwesterg@gmail.com --- configs/socfpga_socrates_defconfig | 1 + include/configs/socfpga_socrates.h | 25 ------------------------- 2 files changed, 1 insertion(+), 25 deletions(-)
diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index e9276f9..4246ad6 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_EBV_SOCRATES=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socrates" +CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_socrates.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/include/configs/socfpga_socrates.h b/include/configs/socfpga_socrates.h index 90343b7..b113ddf 100644 --- a/include/configs/socfpga_socrates.h +++ b/include/configs/socfpga_socrates.h @@ -17,8 +17,6 @@
/* Booting Linux */ #define CONFIG_BOOTFILE "zImage" -#define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) -#define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" #define CONFIG_LOADADDR 0x01000000 #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
@@ -30,29 +28,6 @@
-/* Extra Environment */ -#define CONFIG_EXTRA_ENV_SETTINGS \ - "verify=n\0" \ - "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "bootimage=zImage\0" \ - "fdt_addr=100\0" \ - "fdtimage=socfpga.dtb\0" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "mmcroot=/dev/mmcblk0p2\0" \ - "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ - " root=${mmcroot} rw rootwait;" \ - "bootz ${loadaddr} - ${fdt_addr}\0" \ - "mmcload=mmc rescan;" \ - "load mmc 0:1 ${loadaddr} ${bootimage};" \ - "load mmc 0:1 ${fdt_addr} ${fdtimage}\0" \ - "qspiroot=/dev/mtdblock0\0" \ - "qspirootfstype=jffs2\0" \ - "qspiboot=setenv bootargs " CONFIG_BOOTARGS \ - " root=${qspiroot} rw rootfstype=${qspirootfstype};"\ - "bootm ${loadaddr} - ${fdt_addr}\0" - /* The rest of the configuration is shared */ #include <configs/socfpga_common.h>
This removes the default environment from the sr1500 header and instead uses the common environment provided in socfpga_common.h which now uses distro boot.
This board has no upstream devicetree in the kernel source, so leave the default devicetree name socfpga.dtb.
Signed-off-by: Dalon Westergreen dwesterg@gmail.com --- configs/socfpga_sr1500_defconfig | 1 + include/configs/socfpga_sr1500.h | 27 --------------------------- 2 files changed, 1 insertion(+), 27 deletions(-)
diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 981600b..b0925ab 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_SR1500=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" +CONFIG_DEFAULT_FDT_FILE="socfpga.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index f67fafd..d94771c 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -17,8 +17,6 @@
/* Booting Linux */ #define CONFIG_BOOTFILE "uImage" -#define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) -#define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" #define CONFIG_LOADADDR 0x01000000 #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
@@ -28,31 +26,6 @@ #define CONFIG_PHY_MARVELL #define PHY_ANEG_TIMEOUT 8000
-#define CONFIG_EXTRA_ENV_SETTINGS \ - "verify=n\0" \ - "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "bootimage=zImage\0" \ - "fdt_addr=100\0" \ - "fdtimage=socfpga.dtb\0" \ - "fsloadcmd=ext2load\0" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "mmcroot=/dev/mmcblk0p2\0" \ - "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ - " root=${mmcroot} rw rootwait;" \ - "bootz ${loadaddr} - ${fdt_addr}\0" \ - "mmcload=mmc rescan;" \ - "load mmc 0:1 ${loadaddr} ${bootimage};" \ - "load mmc 0:1 ${fdt_addr} ${fdtimage}\0" \ - "qspiload=sf probe && mtdparts default && run ubiload\0" \ - "qspiboot=setenv bootargs " CONFIG_BOOTARGS \ - " ubi.mtd=1,64 root=ubi0:rootfs rw rootfstype=ubifs;"\ - "bootz ${loadaddr} - ${fdt_addr}\0" \ - "ubiload=ubi part UBI && ubifsmount ubi0 && " \ - "ubifsload ${loadaddr} /boot/${bootimage} && " \ - "ubifsload ${fdt_addr} /boot/${fdtimage}\0" - /* Environment */ #define CONFIG_ENV_IS_IN_SPI_FLASH
Shouldn't this be socfpga_cyclone5_sr1500.dtb too ?
- "verify=n\0" \
We discussed this before, my thought was to leave the dtb name as it was before where there was no mainlined device tree in the linux kernel source. CONFIG_DEFAULT_FDT_FILE is specifically the kernel devicetree used for linux boot and is unrelated to the dtb for uboot.
--dalon
CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index f67fafd..d94771c 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -17,8 +17,6 @@ /* Booting Linux */ #define CONFIG_BOOTFILE "uImage" -#define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) -#define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" #define CONFIG_LOADADDR 0x01000000 #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR @@ -28,31 +26,6 @@ #define CONFIG_PHY_MARVELL #define PHY_ANEG_TIMEOUT 8000 -#define CONFIG_EXTRA_ENV_SETTINGS \
- "verify=n\0" \
Well yeah, then again, all the DTs for socfpga are in the form socfpga_{fpga model}_{board model}.dts , so for this board, it would be socfpga_cyclone5_sr1500.dtb . Also, the U-Boot DT is in that form already ... I guess Stefan has some DT for this board stashed somewhere, so he should be able to tell what the name in reality is.
Dalon Westergreen
Pavel Machek
